  4. IOBroker Anbindung an einen Kostal Plenticore
1.3k Beiträge 83 Kommentatoren 564.1k Aufrufe 72 Beobachtet
  • HALH HAL
    @joefarm Mich würde ein Adapter für BYD HVS interessieren. Bisher klappt damit nur das Windows Programm "Be Connect Plus-V1.4.exe" und abgespeckt die "Be Connect App". Es soll wohl auch mittels pearl Script gehen, aber auf meinem Tinkerboard kriege ich das nicht zum laufen .
    readBYD.pl
    #!/usr/bin/perl
    # readBYD.pl
    # This program reads some current values from a BYD HVS/HVM Premium Battery Box.
    # There is NO WARRANTY
    # If you find this program useful send me some greetings to forenandi73@kabelmail.de
    # redirect STDERR to nul (Windows) or /dev/null (UNIX) if you are not interested in the debugging output
    use strict;
    use IO::Socket;
    use Digest::CRC;
    # connect to BYD HVS/HVM Premium device, adjust PeerAddr to match your IP
    my $sock = IO::Socket::INET->new(PeerAddr => '192.168.178.78', PeerPort => '8080', Proto => 'tcp') or die;
    # commands to be sent to BYD
    my $tobyd1="\x01\x03\x00\x00\x00\x13\x04\x07";
    my $tobyd2="\x01\x03\x05\x00\x00\x19\x84\xcc";
    # unbuffer output on socket, stdout, stderr
    my $old=select($sock); $|=1;
    select(STDOUT);$|=1;
    select(STDERR);$|=1;
    select($old);
    # always read one byte from stream
    $/=\1;
    # create empty hash for results
    my %rh=();
    # send first command to BYD
    print $sock $tobyd1;
    print STDERR "Data1 sent!\n";
    # read 3 bytes
    my $b11=<$sock>;	# 0x01
    my $b12=<$sock>; 	# 0x03
    my $b13=<$sock>; 	# length of data
    my $dl1=ord($b13);	# data length
    printf STDERR "data length=%d\n",$dl1;
    # read payload
    my $pl1=$b13;
    for (my $i=0;$i<$dl1;$i++)
    	$pl1.=<$sock>;
    # read checksum bytes
    my $c11=<$sock>;	# checksum LSB
    my $c12=<$sock>;	# checksum MSB
    # get overall checksum from data
    my $crc1=ord($c12)*256 + ord($c11);
    # calculate checksum from actual data
    my $ctx1 = Digest::CRC->new(width=>16, init=>0x0284, xorout=>0x0000, refout=>1, poly=>0x8005, refin=>1, cont=>0);
    $ctx1->add($pl1);
    my $digest1=$ctx1->digest;
    printf STDERR "Payload length: %d, Checksum=%04X, Digest=%04X\n",length($pl1),$crc1,$digest1;
    if ($b11 ne "\x01" || $b12 ne "\x03" || $crc1 != $digest1)
    	die "illegal/unexpected data received";
    # print received bytes
    my $num1=0;
    for (my $i=0;$i<length($pl1);$i++)
    	my $c=substr($pl1,$i,1);
    	$num1++;
    	my $o=ord($c);
    	$c=".";
    	if ($o > 31 && $o < 127) { $c=chr($o); }
    	printf STDERR "%03d: %03d %02X %s\n",$num1,$o,$o,$c;
    # extract the values from the payload
    &getvals1(\%rh,$pl1);
    # send second command
    print $sock $tobyd2;
    print STDERR "Data2 sent!\n";
    # read 3 bytes from response
    my $b21=<$sock>;	#0x01
    my $b22=<$sock>; 	#0x03
    my $b23=<$sock>; 	# length of data
    my $dl2=ord($b23);	# data length
    printf STDERR "data length=%d\n",$dl2;
    # read the payload
    my $pl2=$b23;		# payload
    for (my $i=0;$i<$dl2;$i++)
    	$pl2.=<$sock>;
    my $c21=<$sock>;	# checksum LSB
    my $c22=<$sock>;	# checksum MSB
    my $crc2=ord($c22)*256 + ord($c21);
    # calculate checksum from actual payload
    my $ctx2 = Digest::CRC->new(width=>16, init=>0x0284, xorout=>0x0000, refout=>1, poly=>0x8005, refin=>1, cont=>0);
    $ctx2->add($pl2);
    my $digest2=$ctx2->digest;
    printf STDERR "Payload length: %d, Checksum=%04X, Digest=%04X\n",length($pl2),$crc2,$digest2;
    if ($b21 ne "\x01" || $b22 ne "\x03" || $crc2 != $digest2)
    # print payload bytes
    my $num2=0;
    for (my $i=0;$i<length($pl2);$i++)
    	my $c=substr($pl2,$i,1);
    	$num2++;
    	my $o=ord($c);
    	$c=".";
    	printf STDERR "%03d: %03d %02X %s\n",$num2,$o,$o,$c;
    &getvals2(\%rh,$pl2);
    # finally print the accumulated results
    foreach my $k (sort keys %rh)
    	printf STDOUT "%s = %s\n",$k,$rh{$k};
    $sock->close();
    print STDERR "End.\n";
    exit(0);
    sub getvals1
    	my $h=shift @_;
    	my $pl=shift @_;
    	$$h{SerialNo}=substr($pl,1,19);
    	$$h{"BMU-A"}=getvers(substr($pl,25,2));
    	$$h{"BMU-B"}=getvers(substr($pl,27,2));
    	$$h{BMS}=getvers(substr($pl,29,2));
    sub getvals2
    	my $h=shift @_;
    	my $pl=shift @_;
    	$$h{SoC}=getshort(substr($pl,1,2));
    	$$h{CellVhigh}=getshort(substr($pl,3,2))/100;
    	$$h{CellVlow}=getshort(substr($pl,5,2))/100;
    	$$h{SoH}=getshort(substr($pl,7,2));
    	$$h{Vbatt}=getshort(substr($pl,11,2))/100;
    	$$h{CellTempHigh}=getshort(substr($pl,13,2));
    	$$h{CellTempLow}=getshort(substr($pl,15,2));
    	$$h{Vout}=getshort(substr($pl,33,2))/100;
    	my $currval=getshort(substr($pl,9,2));
    	if ($currval < 32768)
    		$$h{Current}=$currval/10;
    	else
    		$$h{Current}=($currval-2**16)/10;
    sub getshort
    	my $v=shift @_;
    	return(
    		ord(substr($v,0,1))*256 + ord(substr($v,1,1))
    sub getvers
    	my $v=shift @_;
    	return(
    		ord(substr($v,0,1)) . "." .  ord(substr($v,1,1))
    joefarm
    #932
    @hal Mit dem HVS kann ich leider nicht helfen, da ich einen HV habe. Und bei der Adapterprogrammierung muss ich leider auch passen.
    Ich habs zumindest per Javascript und einen request geschafft, einzelne Werte aus der Statistik Info der BYD HV auszulesen, als Info, die @arteck noch nicht implementiert hat. Ging mir erst mal nur um Total Charge und Total Discharge Energy. Noch ziemlich rudimentär...
    var request = require("request");
    var username = "user";
    var pass = "user";
    var url = "http://" + username + ":" + pass + "@192.168.6.1/asp/StatisticInformation.asp";
    var cronStr = "3-58/5 * * * *"; // run every 5 minutes starting at 3
    createState('Solar.BydTotalChargeEnergy', 0,
            {type: 'number',unit: 'kWh',role: 'value', name: 'BydTotalChargeEnergy',desc: 'Byd Gesamte Ladeleistung'});
    createState('Solar.BydTotalDischargeEnergy', 0,
            {type: 'number',unit: 'kWh',role: 'value', name: 'BydTotalDischargeEnergy',desc: 'Byd Gesamte Entladeleistung'});
    createState('Solar.BydBatteryEfficiency', 0,
            {type: 'number',unit: '%',role: 'value', name: 'BydBatteryEfficiency',desc: 'Byd Batterieeffizienz'});
    function readBattStatistic() {
        request(url, function(err, state, body) {
            if (body) {
                //console.log(body);
                var match;
                var myRegexp = /Charge Energy:[\s\S]+?>(\d{3,5}\.\d{1,3})[\s\S]+?Discharge Energy:[\s\S]+?(\d{3,5}\.\d{1,3})/m;
                if ((match = body.match(myRegexp)) !== null) {
                    //console.log(match);
                    var charge = parseFloat(match[1]);
                    //console.log(charge);
                    setState('Solar.BydTotalChargeEnergy', charge, true);
                    var discharge = parseFloat(match[2]);
                    //console.log(discharge);
                    setState('Solar.BydTotalDischargeEnergy', discharge, true);
                    setState('Solar.BydBatteryEfficiency', discharge / charge * 100, true);
                else console.log("not matched");
    schedule(cronStr, readBattStatistic);
    • BostilB Offline
      BostilB Offline
      Bostil
      #933
      hoffe hier auf Plenticore-Leidgenossen zu treffen, die auch gerne versch. Infos visualisieren möchten.
      Würde gerne in einer Wochenansicht (Mo - So) den Hausverbrauch + Erzeugung PV auf Tagesebene nachvollziehen können. Wenn möglich gerne als klassisches Säulendiagramm.
      Hat von euch jemand dies schon bewerkstelligt bekommen? Denke, dass @Scrounger material design bar chart von Hilfe sein könnte. Aber hier habe ich so meine Probleme dies zu über ein JSON zu realisieren.
      Jemand eine Idee?? DANKE.
      Das sind die Datensätze, die die Meisten kennen werden:
      StrathColeS 1 Antwort Letzte Antwort
      • BostilB Bostil
        StrathColeS Offline
        StrathColeS Offline
        StrathCole
        schrieb am zuletzt editiert von StrathCole
        #934
        @bostil Ich nutze Influxdb für die Sammlung (also statt history Adapter) und habe dann Grafana installiert, das auf Influx zugreift.
        Mein Graph sieht so aus:
        So sieht es dann mit der Einstellung 6 Monate aus
        Und so mit der von dir genannten Woche
        SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
        • DiginixD Diginix
          @strathcole Ok, na ich hab einfach mal den loglevel vom Adapter auf "error" gestellt, damit das Log nicht explodiert und ich eventuelle Probleme anderer Adapter überhaupt noch sehe.
          StrathColeS Offline
          StrathColeS Offline
          StrathCole
          #935
          @diginix
          Kannst du mal bitte folgendes testen:
          In der Datei /opt/iobroker/node_modules/iobroker.plenticore/node_modules/@strathcole/iob-lib/lib/iob-lib.js
          Zeile 111:
          delete objectStates[id];
          direkt dahinter noch eine Zeile einfügen:
          delete stateStates[id];
          Dann Adapter neu starten und nach dem nächsten Löschen der States (also Tageswechsel) den Logmodus wieder umstellen
          Danke.
          • StrathColeS StrathCole
            @diginix
            Zeile 111:
            Danke.
            DiginixD Offline
            DiginixD Offline
            Diginix
            #936
            @strathcole In Version 2.1.6 gibt es die Ordnerstruktur so nicht. Ich finde nicht mal eine Datei mit "delete objectStates[id];" unterhalb von /opt/iobroker/node_modules/iobroker.plenticore/
            Ich vermute dass es bei dieser Ver. noch in /opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js ist?
            ..:: So long! Tom ::..
            • DiginixD Diginix
              StrathColeS Offline
              StrathColeS Offline
              StrathCole
              #937
              @diginix vielleicht hat er das iob-lib direkt im Hauptverzeichnis node_modules installiert. Sollte es schon länger geben.
                DiginixD Offline
                DiginixD Offline
                Diginix
                #938
                @strathcole Stimmt, da liegt die Datei.
                Sieht nun so aus. Den Loglevel aber erst morgen früh von error zurück nehmen?
                • DiginixD Diginix
                  StrathColeS Offline
                  StrathColeS Offline
                  StrathCole
                  #939
                  @diginix kannst du auch jetzt schon
                  DiginixD 2 Antworten Letzte Antwort
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    #940
                    @strathcole Ok, erledigt. Ich werde berichten.
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #941
                      @strathcole Die Anpassung hat leider keine Besserung gebracht:
                      2021-02-04 07:48:47.262 - warn: plenticore.0 (1512441) State "plenticore.0.forecast.day1.power.1h.generated" has no existing object, this might lead to an error in future versions
                      Ich habe aber eben noch mal ein "adapter upload" gemacht und somit die Instanz neu gestartet. In den 10 Minuten seit dem sind keine Meldungen mehr gekommen.
                      • DiginixD Diginix
                        StrathColeS Offline
                        StrathColeS Offline
                        StrathCole
                        #942
                        @diginix Hm, ich glaub aber auch die Meldungen kommen immer nur nach Mitternacht, wenn man nicht neu startet, oder? Nach einem Neustart müssten sie ja immer bis zum nächsten Tageswechsel weg sein?
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #943
                          @strathcole Das kann natürlich auch sein. Dann würde es morgen trotz der Anpassung wieder losgehen.
                          Ich dachte nur, dass die gepatchte javascript Datei vllt nicht direkt verarbeitet wird und deswegen hab ich das "upload" getriggert. Was aber eben auch den Neustart der Instanz bedeutet und dadurch nur vermeintlich Ruhe herrscht.
                          Fazit: Höchstwahrscheinlich hilft dieser Patch noch nicht. Genau wissen wir es aber erst morgen kurz vor 8 Uhr.
                          • DiginixD Diginix
                            StrathColeS Offline
                            StrathColeS Offline
                            StrathCole
                            #944
                            @diginix Interessant ist allerdings: Ich habe gestern extra mal den jscontroller aus dem latest installiert, also 3.2 – und bei mir tritt es nicht auf, habe allerdings auch nicht ohne den Patch getestet.
                              DiginixD Offline
                              DiginixD Offline
                              Diginix
                              #945
                              @strathcole Dann wäre die einzige Erklärung, dass der Patch eben bis zu "adapter upload" heute noch nicht wirklich gegriffen hat und erst morgen wirklich funktioniert. Mehr als Abwarten geht nun nicht. Außer ich manipuliere die Systemzeit.
                              • DiginixD Diginix
                                StrathColeS Offline
                                StrathColeS Offline
                                StrathCole
                                #946
                                @diginix Ich hab einfach mal die neue 2.1.7 und das neue Lib veröffentlicht. Dann können wir sicher sein, dass er auch das richtige Lib nimmt. Bei mir gab es nämlich 4 Instanzen vom Lib in iobroker.
                                  DiginixD Offline
                                  DiginixD Offline
                                  Diginix
                                  #947
                                  @strathcole Die iob-lib gab es bei mir nur einmal auf dem System und die Zeile 112 war gepatcht.
                                  Habe nun de 2.1.7 installiert und die iob-lib wurde neu erstellt, ist aber in Zeile 112 inhaltlich identisch zu der gepatchten von mir. Instanz läuft bisher ohne Logfehler. Wenn es morgen früh nicht ruhig bleibt, ist guter Rat teuer. ;-)
                                    DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #948
                                    @strathcole Leider auch mit 2.1.7 keine Besserung:
                                    2021-02-05 07:47:30.116  - warn: plenticore.0 (1622132) State "plenticore.0.forecast.day1.power.1h.generated" has no existing object, this might lead to an error in future versions
                                    • DiginixD Diginix
                                      StrathColeS Offline
                                      StrathColeS Offline
                                      StrathCole
                                      #949
                                      @diginix Jetzt hab ich es bei mir auch endlich und kann auf Fehlersuche gehen.
                                        DiginixD Offline
                                        DiginixD Offline
                                        Diginix
                                        #950
                                        @strathcole "Gut" aber merkwürdig dass es bei dir erst jetzt durchschlägt.
                                        lemonbiterL 1 Antwort Letzte Antwort
                                        • DiginixD Diginix
                                          lemonbiterL Offline
                                          lemonbiterL Offline
                                          lemonbiter
                                          #951
                                          Bei mir kommt diese Fehlermeldung sogar im Bündel...
                                          plenticore.0	2021-02-11 17:40:29.921	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:40:29.920	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:40:19.117	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:40:19.116	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:40:08.477	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:40:08.476	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:57.773	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:57.772	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:47.058	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:36.464	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:36.463	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:36.423	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:25.793	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:25.792	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:15.125	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:15.124	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:05.052	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:39:05.049	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:53.924	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:53.923	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:43.386	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:43.384	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:43.383	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:32.648	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:32.647	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:22.087	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:22.037	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:11.443	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:11.387	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:00.766	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:38:00.765	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:50.161	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:50.160	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:39.532	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:39.531	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:28.213	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:28.212	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:17.377	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:17.376	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:06.772	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:06.771	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:37:06.722	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:56.007	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:56.004	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:45.396	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:45.395	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:34.663	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:23.908	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:23.907	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:13.257	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:13.256	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:02.625	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:36:02.624	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:51.854	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:51.847	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:41.297	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:41.296	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:41.246	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:30.715	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:30.674	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:19.982	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:19.981	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:09.160	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:35:09.154	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:58.180	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:58.179	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:58.116	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:47.524	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:47.523	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:36.913	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:36.912	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:26.475	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:26.430	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:15.894	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:15.835	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:15.821	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:05.209	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:34:05.208	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:54.597	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:54.596	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:43.956	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:43.955	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:33.048	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:33.047	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:22.584	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:11.913	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:01.324	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
                                          plenticore.0	2021-02-11 17:33:01.320	warn	(20815) State "plenticore.0.forecast.day1.power.10h.generated" has no existing object, this might lead to an error in future versions
