  4. Test Adapter Adapter-fritzdect v2.1.x GitHub
fritzdect
197 Beiträge 24 Kommentatoren 43.4k Aufrufe 24 Beobachtet
  • B bob der 1.
    @foxthefox
    Ich bekomme den Adapter nicht zum laufen.
    Ampel Grün,extra FB User angelegt und eingetragen Adapter.
    Fritz7590,7.21 als FW
    Gerät Comet dect Ventil.
    Es werden weder Datenpunkte angelegt noch unter den Objekten der Oberpunkt dect-fritz.
    fritzdect.0	2021-01-22 09:54:41.715	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:54:41.715	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:54:41.572	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:54:41.572	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:54:41.020	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:54:41.019	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:54:40.885	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:54:40.885	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:52:33.704	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:52:33.704	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:52:33.567	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:52:33.566	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:52:32.961	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:52:32.961	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:52:32.828	error	(21804) no response part in returned message
    Egal wie ich mich Anmelde immer diese Logs
    Jan1
    #101
    @bob-der-1
    Da hast definitiv ein Problem mit dem User und dessen Passwort. Hast noch ein anderen Adpater der auf die Fritz zugreift? Wenn ja, verwende mal diese Login und der User muss Zugriff auf die smart Home Geräte haben, wobei hier anscheinend schon voher was nicht stimmt und der User nicht mal das Login schafft.
    War da aber nicht was am Login des Adapter und wurde gifixt ? Welche Version läuft bei Dir?
    • J Jan1
      @bob-der-1
      bob der 1.
      schrieb am zuletzt editiert von bob der 1.
      #102
      @jan1
      Version 2.18
      Habe den Tr064 gestoppt und diesen User genommen,Fritz Neustart.... nichts,gleiches Log file
      dann das PW des Webif der Fritte.....
      User Admin umd dann das Anmelde-PW....Neustart....nichts.
      Tr064 start...der User rennt???
      • B bob der 1.
        @jan1
        Version 2.18
        Jan1
        #103
        @bob-der-1
        Ich bin nicht zu Hause und kann deshalb schlecht schauen welche Version ich habe, aber bist Du default oder im beta Repo?
        Edit:
        War ne blöde Frage, hier geht's ja um die Github Version.
        Geh doch mal mit der Fritz auf beta, hier läuft das so ganz gut und seit dem Update der Fritz gestern wird auch mein Mesh endlich sehr gleichmäßig aufgeteilt.
        • J Jan1
          @bob-der-1
          Edit:
          bob der 1.
          #104
          @jan1
          auch nichts!
          ich werfe den Adapter nun nochmal runter, bau ihn in mein Test SYS ein.....
          nun habe ich den ganzen Fred gelesen,komplexe PW...FW der Fritte pastt ja alles und dann kann es nur bei der Install passiert sein das irgendwas bockt.
          was unnötig war ist wohl der extra User der Fritte, die normalen Anmeldedaten sollten gehen.
          Nun habe ich das PW der Fritte auch mal auf ein sehr simples geändert NICHTS.
          melde mich gleich mal vom Testsys.
          • B bob der 1.
            @jan1
            auch nichts!
            Jan1
            #105
            @bob-der-1
            Der "normale" Admin User hat eben recht viele Rechte und wenn DU das Login für den Adapter verwenden möchtest, musst eben darauf vertrauen, dass hier alles sicher ist. Das ist der einzige Grund, warum man dafür normal nicht den Admin User der Box nimmt ;)
            Dann hat es noch den Vorteil, dass man sieht wann sich der Adapter einloggt und ob die Box das Login zulässt.
            Ich habe übrigens die 2.1.7 laufen, da die im Latest ist.
            • J Jan1
              @bob-der-1
              bob der 1.
              #106
              @jan1
              Welche Rechte hat dein User....
              • B bob der 1.
                @jan1
                Jan1
                #107
                @bob-der-1
                Es reicht eigentlich schon wenn der User keine Rechte hat über das Internet auf die Fritz zu zugreifen.
                An den Rechten liegt Dein Problem aber nicht, da die Box das Login schon verweigert.
                • B bob der 1.
                  @foxthefox
                  foxthefox
                  #108
                  @bob-der-1
                  das log ist bezüglich der vielen Anmeldeversuche recht aufschlußreich, aber nicht ob der Adapter nach update überhaupt einmal richtig startete.
                  Das log zeigt mehrere Zugriffe innerhalb kurze Zeit ind dann 2min nochmal.
                  Wo auch immer das herkommt, das zyklische Polling scheint es nicht zu sein.
                  Also bitte mal den Start das Adapters anschauen, dort. sollte selbst im info Modus mindestens
                  entered ready
                  creating ..... kommen.
                  und dann auch einmalig die Meldung update
                  wenn das durchläuft, dann ist erstmal klar das das login geht, wenn dann nochmal Meldungen mit login/pw und 0000000000 kommen, dann ist nicht zwingend das Passwort das Problem, sondern auch zu viele Zugriffe zur gleichen Zeit.
                  Und dabei geht die Fritzbox in immer längere Blockierzeiten, bis ggf. die FB gar nicht mehr mag und neu gebootet werden muß
                  wenn hier schon Probleme sind, dann hängt es definitiv am login.
                  Also bitte nochmal den Start des Adapters beobachten und ggf. in debug modus schalten.
                  Adapterüberblick: Profil Github;
                  Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
                  Ein Aufruf: video
                  • F foxthefox
                    @bob-der-1
                    entered ready
                    bob der 1.
                    #109
                    @foxthefox
                    Also ich weis nun nicht was genau passiert ist....erkläre es mal schrittweise.
                    ab hier mal alles auf meinem Testsys, im Endeffkt ein aktuelles Backup des Prodsys. um immer nachvollziehbar zu sagen ab da geht es...
                    Ich habe den Adapter gelöscht neu installiert und als User/PW den Fritz Admin genommen ....Verbindung steht und alles wird erkannt.BINGO.....Log sieht super aus.Objekte wurden angelegt.
                    Nun habe ich einen neuen User in der Fritte angelegt und verbunden....geht auch sofort,nur ist mir bei der Nachkontrolle aufgefallen das ich Depp den User falsch geschrieben habe.???
                    Moment, User falsch und dennoch geht es???? also mehrere Tests ergaben ...einmal angemeldet braucht man den Usernamen gar nicht mehr....nur irgendeinen Eintrag im User!!!
                    Nur mit dem 1.Buchstaben des Users sieht das Log nach neustart des Adapters so aus...
                    fritzdect.0	2021-01-23 13:17:30.475	info	(1953) going over to cyclic polling, messages to poll activity only in debug-mode
                    fritzdect.0	2021-01-23 13:17:30.475	info	(1953) initial updating devices/groups finished
                    fritzdect.0	2021-01-23 13:17:29.721	info	(1953) creating templates finished
                    fritzdect.0	2021-01-23 13:17:29.216	info	(1953) creating devices/groups finished
                    fritzdect.0	2021-01-23 13:17:29.207	info	(1953) setting up thermostat nextchange
                    fritzdect.0	2021-01-23 13:17:29.163	info	(1953) setting up thermostat
                    fritzdect.0	2021-01-23 13:17:29.159	info	(1953) setting up temperatur
                    fritzdect.0	2021-01-23 13:17:29.141	info	(1953) setting up thermostat nextchange
                    fritzdect.0	2021-01-23 13:17:29.101	info	(1953) setting up thermostat
                    fritzdect.0	2021-01-23 13:17:29.097	info	(1953) setting up temperatur
                    fritzdect.0	2021-01-23 13:17:29.078	info	(1953) setting up thermostat nextchange
                    fritzdect.0	2021-01-23 13:17:29.034	info	(1953) setting up thermostat
                    fritzdect.0	2021-01-23 13:17:29.030	info	(1953) setting up temperatur
                    fritzdect.0	2021-01-23 13:17:29.006	info	(1953) setting up thermostat nextchange
                    fritzdect.0	2021-01-23 13:17:28.918	info	(1953) setting up thermostat
                    fritzdect.0	2021-01-23 13:17:28.913	info	(1953) setting up temperatur
                    fritzdect.0	2021-01-23 13:17:28.893	info	(1953) setting up thermostat nextchange
                    fritzdect.0	2021-01-23 13:17:28.808	info	(1953) setting up thermostat
                    fritzdect.0	2021-01-23 13:17:28.800	info	(1953) setting up temperatur
                    fritzdect.0	2021-01-23 13:17:28.570	info	(1953) CREATE Devices 5
                    fritzdect.0	2021-01-23 13:17:27.761	info	(1953) fritzdect entered ready
                    fritzdect.0	2021-01-23 13:17:27.729	info	(1953) starting. Version 2.1.8 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v12.20.1, js-controller: 3.2.8
                    host.raspberrypi	2021-01-23 13:17:26.073	info	instance system.adapter.fritzdect.0 started with pid 1953
                    host.raspberrypi	2021-01-23 13:17:25.868	info	"system.adapter.fritzdect.0" enabled
                    host.raspberrypi	2021-01-23 13:17:08.916	info	instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    fritzdect.0	2021-01-23 13:17:08.272	info	(1831) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    fritzdect.0	2021-01-23 13:17:08.271	info	(1831) terminating
                    fritzdect.0	2021-01-23 13:17:08.270	info	(1831) cleaned everything up...
                    host.raspberrypi	2021-01-23 13:17:08.269	info	stopInstance system.adapter.fritzdect.0 send kill signal
                    fritzdect.0	2021-01-23 13:17:08.269	info	(1831) Got terminate signal TERMINATE_YOURSELF
                    host.raspberrypi	2021-01-23 13:17:08.258	info	stopInstance system.adapter.fritzdect.0 (force=false, process=true)
                    Es funktioniert auch alles ...Skripte schalten etc.
                    Ändert man allerdings das Passwort ,feuert der Broker los....und das im Intervall den man eingestellt hat.
                    fritzdect.0	2021-01-23 13:19:51.676	info	(2197) going over to cyclic polling, messages to poll activity only in debug-mode
                    fritzdect.0	2021-01-23 13:19:51.675	info	(2197) initial updating devices/groups finished
                    fritzdect.0	2021-01-23 13:19:51.674	error	(2197) no response part in returned message
                    fritzdect.0	2021-01-23 13:19:51.672	error	(2197) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
                    fritzdect.0	2021-01-23 13:19:47.199	info	(2197) creating templates finished
                    fritzdect.0	2021-01-23 13:19:47.199	error	(2197) no response part in returned message
                    fritzdect.0	2021-01-23 13:19:47.197	error	(2197) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
                    fritzdect.0	2021-01-23 13:19:44.876	info	(2197) creating devices/groups finished
                    fritzdect.0	2021-01-23 13:19:44.875	error	(2197) no response part in returned message
                    fritzdect.0	2021-01-23 13:19:44.875	error	(2197) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
                    fritzdect.0	2021-01-23 13:19:44.054	info	(2197) fritzdect entered ready
                    fritzdect.0	2021-01-23 13:19:44.017	info	(2197) starting. Version 2.1.8 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v12.20.1, js-controller: 3.2.8
                    Das es nun geht ...auch auf dem Produktivsys. liegt an der erneuten Installation des Adapters.Ich vermute beim 1 mal ging was schief.Nur wie GUT es nun geht auch mit flaschen Usernamen??? denke da passt was nicht im adapter
                    F 1 Antwort Letzte Antwort
                    • B bob der 1.
                      @foxthefox
                      foxthefox
                      #110
                      @bob-der-1
                      schwer nachvollziehbar.
                      beim speichern der adapter config, wird die variable geschrieben und dann startet der adapter neu und liest das abgespeichert.
                      Die Anfrage an die fritzbox ist dann mit dem entsprechenden usereintrag.
                      und dann sollte sich die FB weigern den user zu kennen.
                      lediglich ein Wechsel in einen anderen tab (z.b. Log) speichert nichts ab, da bleibt also der alte Benutzer bestehen.
                      bei mir speichert es sauber ab jedes unpassende USER/PW führt zu Fehler
                      Ein Aufruf: video
                      • F foxthefox
                        @bob-der-1
                        bob der 1.
                        #111
                        @foxthefox
                        Habe dir ein Video Link geschickt.
                        Per PN
                        • B bob der 1.
                          @foxthefox
                          Per PN
                          bob der 1.
                          #112
                          @foxthefox
                          Habe dir mit deinem Adpter 2.19 eine Testreihe gemacht ,ist in deinen PN´s hinterlegt.
                          Hoffe konnte so etwas helfen.
                          • F foxthefox
                            Aktuelle Test Version 2.1.7
                            Veröffentlichungsdatum 03.01.2021
                            Github Link https://github.com/foxthefox/ioBroker.fritzdect
                            Changes
                            Habe den Adapter komplett überarbeitet:
                            • auf klassenbasierte Struktur umgestellt
                            • die Routinen komplett überarbeitet (hälfte des Codes)
                            • eine neue API für die Fritzbox erstellt, damit ab 7.25 auch mit dem neuen Verschlüsselungsverfahren ein login möglich ist
                            • DECT500 und ihre Gruppen sind enthalten
                            • Rolladensteuerung ist drin
                            • DECT440 hat nun untergeordnete Buttons
                            • wenn es neue Datenpunkte seitens der fritzbox gibt, wird eine Warnung ausgegeben
                            BREAKING Change!
                            Durch die Überarbeitung sind nun alle Objekte mit DECT_ ohne irgendwelche Zusätze mit 200 o.ä.
                            Am Anfang gab es nur die Steckdose und Thermostat und nun ist es überholt.
                            des Weiteren sind die Datenpunkte nun mit den Namen aus der Fritzbox-API gleich. Das vereinfacht das Einlesen und Update ungemein.
                            Ich hoffe es funktioniert soweit alles noch (ich habe nur DECT200 und DECT300 und da scheint es OK).
                            Klaus
                            PS. mit der Ampel muß ich noch schauen, ob ich das so richtig interpretiert habe.
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #113
                            @foxthefox
                            buuuh - 2 stunden wildes ändern in script's, umstellung auf aliase und vis
                            aber scheint erstmal alles zu funktionieren - adapter installation ohne probleme
                            danke fürs update
                            • liv-in-skyL liv-in-sky
                              @foxthefox
                              danke fürs update
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #114
                              @foxthefox
                              Ich bin nun auch von dem Fehler betroffen in unregelmässigen Abständen:
                              fritzdect.0	2021-02-07 15:00:23.424	error	(17092) no response part in returned message
                              fritzdect.0	2021-02-07 15:00:23.422	error	(17092) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
                              Als Intervall waren zum Testen diverse Sekunden eingestellt: 300, 120....
                              Ein einfacher Adapterneustart funktioniert normal alles, wird angelegt und aktualisiert.
                              Adapter Version 2.1.10 von Github. Mit 2.1.7 war es schon dasselbe.
                              Issue ist eröffnet
                              Probiert mit Beta, Labor und Stable Software der Fritzbox.
                              Seit der 7.24 (glaube ich) gibt es statt dem Admin einen neuen FB User.
                              fritz und 4 Zahlen dahinter, so wird er jedenfalls von meiner FB angelegt.
                              Habe ich aber auch im Adapter geändert. Fehler bleibt.
                              liv-in-skyL J 2 Antworten Letzte Antwort
                              • haselchenH haselchen
                                @foxthefox
                                Issue ist eröffnet
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #115
                                @haselchen ich glaube, dass habe ich bei mir auch schon mal gesehen
                                  @foxthefox
                                  Issue ist eröffnet
                                  Jan1
                                  #116
                                  @haselchen
                                  Das liegt an zu schnell hintereinander erfolgter Zugriffe, da blockt die Box einfach. Da hilft nur Scripte optimieren.
                                  • J Jan1
                                    @haselchen
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    #117
                                    @jan1
                                    Aber da greift nüscht auf die Box zu.
                                    Ausser dem fritzdect alle 300sek.
                                    J F 2 Antworten Letzte Antwort
                                      @jan1
                                      Jan1
                                      #118
                                      @haselchen
                                      Und was macht der Adapter?
                                      • J Jan1
                                        @haselchen
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #119
                                        @jan1
                                        Kontrolliert 1 !!! Steckdose von Fr!tz :)
                                        Das sollte FB und Adapter nicht überfordern ;)
                                          @jan1
                                          Jan1
                                          #120
                                          @haselchen
                                          Ich habe den Fehler wenn meine Heizung anspringt, weil dann die Regelung greift und hier kurzfristig viel Verkehr ist. Wenn sich das eingependelt hat, geht auch das Problem weg.
