  4. Test Adapter Adapter-fritzdect v2.1.x GitHub
fritzdect
197 Beiträge 24 Kommentatoren 43.4k Aufrufe 24 Beobachtet
  • B bob der 1.
    @foxthefox
    Ich bekomme den Adapter nicht zum laufen.
    Ampel Grün,extra FB User angelegt und eingetragen Adapter.
    Fritz7590,7.21 als FW
    Gerät Comet dect Ventil.
    Es werden weder Datenpunkte angelegt noch unter den Objekten der Oberpunkt dect-fritz.
    fritzdect.0	2021-01-22 09:54:41.715	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:54:41.715	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:54:41.572	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:54:41.572	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:54:41.020	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:54:41.019	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:54:40.885	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:54:40.885	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:52:33.704	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:52:33.704	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:52:33.567	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:52:33.566	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:52:32.961	error	(21804) no response part in returned message
    fritzdect.0	2021-01-22 09:52:32.961	error	(21804) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
    fritzdect.0	2021-01-22 09:52:32.828	error	(21804) no response part in returned message
    Egal wie ich mich Anmelde immer diese Logs
    foxthefox
    #108
    @bob-der-1
    das log ist bezüglich der vielen Anmeldeversuche recht aufschlußreich, aber nicht ob der Adapter nach update überhaupt einmal richtig startete.
    Das log zeigt mehrere Zugriffe innerhalb kurze Zeit ind dann 2min nochmal.
    Wo auch immer das herkommt, das zyklische Polling scheint es nicht zu sein.
    Also bitte mal den Start das Adapters anschauen, dort. sollte selbst im info Modus mindestens
    entered ready
    creating ..... kommen.
    und dann auch einmalig die Meldung update
    wenn das durchläuft, dann ist erstmal klar das das login geht, wenn dann nochmal Meldungen mit login/pw und 0000000000 kommen, dann ist nicht zwingend das Passwort das Problem, sondern auch zu viele Zugriffe zur gleichen Zeit.
    Und dabei geht die Fritzbox in immer längere Blockierzeiten, bis ggf. die FB gar nicht mehr mag und neu gebootet werden muß
    wenn hier schon Probleme sind, dann hängt es definitiv am login.
    Also bitte nochmal den Start des Adapters beobachten und ggf. in debug modus schalten.
    Adapterüberblick: Profil Github;
    Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
    Ein Aufruf: video
    • F foxthefox
      @bob-der-1
      entered ready
      bob der 1.
      #109
      @foxthefox
      Also ich weis nun nicht was genau passiert ist....erkläre es mal schrittweise.
      ab hier mal alles auf meinem Testsys, im Endeffkt ein aktuelles Backup des Prodsys. um immer nachvollziehbar zu sagen ab da geht es...
      Ich habe den Adapter gelöscht neu installiert und als User/PW den Fritz Admin genommen ....Verbindung steht und alles wird erkannt.BINGO.....Log sieht super aus.Objekte wurden angelegt.
      Nun habe ich einen neuen User in der Fritte angelegt und verbunden....geht auch sofort,nur ist mir bei der Nachkontrolle aufgefallen das ich Depp den User falsch geschrieben habe.???
      Moment, User falsch und dennoch geht es???? also mehrere Tests ergaben ...einmal angemeldet braucht man den Usernamen gar nicht mehr....nur irgendeinen Eintrag im User!!!
      Nur mit dem 1.Buchstaben des Users sieht das Log nach neustart des Adapters so aus...
      fritzdect.0	2021-01-23 13:17:30.475	info	(1953) going over to cyclic polling, messages to poll activity only in debug-mode
      fritzdect.0	2021-01-23 13:17:30.475	info	(1953) initial updating devices/groups finished
      fritzdect.0	2021-01-23 13:17:29.721	info	(1953) creating templates finished
      fritzdect.0	2021-01-23 13:17:29.216	info	(1953) creating devices/groups finished
      fritzdect.0	2021-01-23 13:17:29.207	info	(1953) setting up thermostat nextchange
      fritzdect.0	2021-01-23 13:17:29.163	info	(1953) setting up thermostat
      fritzdect.0	2021-01-23 13:17:29.159	info	(1953) setting up temperatur
      fritzdect.0	2021-01-23 13:17:29.141	info	(1953) setting up thermostat nextchange
      fritzdect.0	2021-01-23 13:17:29.101	info	(1953) setting up thermostat
      fritzdect.0	2021-01-23 13:17:29.097	info	(1953) setting up temperatur
      fritzdect.0	2021-01-23 13:17:29.078	info	(1953) setting up thermostat nextchange
      fritzdect.0	2021-01-23 13:17:29.034	info	(1953) setting up thermostat
      fritzdect.0	2021-01-23 13:17:29.030	info	(1953) setting up temperatur
      fritzdect.0	2021-01-23 13:17:29.006	info	(1953) setting up thermostat nextchange
      fritzdect.0	2021-01-23 13:17:28.918	info	(1953) setting up thermostat
      fritzdect.0	2021-01-23 13:17:28.913	info	(1953) setting up temperatur
      fritzdect.0	2021-01-23 13:17:28.893	info	(1953) setting up thermostat nextchange
      fritzdect.0	2021-01-23 13:17:28.808	info	(1953) setting up thermostat
      fritzdect.0	2021-01-23 13:17:28.800	info	(1953) setting up temperatur
      fritzdect.0	2021-01-23 13:17:28.570	info	(1953) CREATE Devices 5
      fritzdect.0	2021-01-23 13:17:27.761	info	(1953) fritzdect entered ready
      fritzdect.0	2021-01-23 13:17:27.729	info	(1953) starting. Version 2.1.8 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v12.20.1, js-controller: 3.2.8
      host.raspberrypi	2021-01-23 13:17:26.073	info	instance system.adapter.fritzdect.0 started with pid 1953
      host.raspberrypi	2021-01-23 13:17:25.868	info	"system.adapter.fritzdect.0" enabled
      host.raspberrypi	2021-01-23 13:17:08.916	info	instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      fritzdect.0	2021-01-23 13:17:08.272	info	(1831) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fritzdect.0	2021-01-23 13:17:08.271	info	(1831) terminating
      fritzdect.0	2021-01-23 13:17:08.270	info	(1831) cleaned everything up...
      host.raspberrypi	2021-01-23 13:17:08.269	info	stopInstance system.adapter.fritzdect.0 send kill signal
      fritzdect.0	2021-01-23 13:17:08.269	info	(1831) Got terminate signal TERMINATE_YOURSELF
      host.raspberrypi	2021-01-23 13:17:08.258	info	stopInstance system.adapter.fritzdect.0 (force=false, process=true)
      Es funktioniert auch alles ...Skripte schalten etc.
      Ändert man allerdings das Passwort ,feuert der Broker los....und das im Intervall den man eingestellt hat.
      fritzdect.0	2021-01-23 13:19:51.676	info	(2197) going over to cyclic polling, messages to poll activity only in debug-mode
      fritzdect.0	2021-01-23 13:19:51.675	info	(2197) initial updating devices/groups finished
      fritzdect.0	2021-01-23 13:19:51.674	error	(2197) no response part in returned message
      fritzdect.0	2021-01-23 13:19:51.672	error	(2197) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
      fritzdect.0	2021-01-23 13:19:47.199	info	(2197) creating templates finished
      fritzdect.0	2021-01-23 13:19:47.199	error	(2197) no response part in returned message
      fritzdect.0	2021-01-23 13:19:47.197	error	(2197) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
      fritzdect.0	2021-01-23 13:19:44.876	info	(2197) creating devices/groups finished
      fritzdect.0	2021-01-23 13:19:44.875	error	(2197) no response part in returned message
      fritzdect.0	2021-01-23 13:19:44.875	error	(2197) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
      fritzdect.0	2021-01-23 13:19:44.054	info	(2197) fritzdect entered ready
      fritzdect.0	2021-01-23 13:19:44.017	info	(2197) starting. Version 2.1.8 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v12.20.1, js-controller: 3.2.8
      Das es nun geht ...auch auf dem Produktivsys. liegt an der erneuten Installation des Adapters.Ich vermute beim 1 mal ging was schief.Nur wie GUT es nun geht auch mit flaschen Usernamen??? denke da passt was nicht im adapter
      F 1 Antwort Letzte Antwort
      • B bob der 1.
        @foxthefox
        foxthefox
        #110
        @bob-der-1
        schwer nachvollziehbar.
        beim speichern der adapter config, wird die variable geschrieben und dann startet der adapter neu und liest das abgespeichert.
        Die Anfrage an die fritzbox ist dann mit dem entsprechenden usereintrag.
        und dann sollte sich die FB weigern den user zu kennen.
        lediglich ein Wechsel in einen anderen tab (z.b. Log) speichert nichts ab, da bleibt also der alte Benutzer bestehen.
        bei mir speichert es sauber ab jedes unpassende USER/PW führt zu Fehler
        Ein Aufruf: video
        • F foxthefox
          @bob-der-1
          bob der 1.
          #111
          @foxthefox
          Habe dir ein Video Link geschickt.
          Per PN
          • B bob der 1.
            @foxthefox
            Per PN
            bob der 1.
            #112
            @foxthefox
            Habe dir mit deinem Adpter 2.19 eine Testreihe gemacht ,ist in deinen PN´s hinterlegt.
            Hoffe konnte so etwas helfen.
            • F foxthefox
              Aktuelle Test Version 2.1.7
              Veröffentlichungsdatum 03.01.2021
              Github Link https://github.com/foxthefox/ioBroker.fritzdect
              Changes
              Habe den Adapter komplett überarbeitet:
              • auf klassenbasierte Struktur umgestellt
              • die Routinen komplett überarbeitet (hälfte des Codes)
              • eine neue API für die Fritzbox erstellt, damit ab 7.25 auch mit dem neuen Verschlüsselungsverfahren ein login möglich ist
              • DECT500 und ihre Gruppen sind enthalten
              • Rolladensteuerung ist drin
              • DECT440 hat nun untergeordnete Buttons
              • wenn es neue Datenpunkte seitens der fritzbox gibt, wird eine Warnung ausgegeben
              BREAKING Change!
              Durch die Überarbeitung sind nun alle Objekte mit DECT_ ohne irgendwelche Zusätze mit 200 o.ä.
              Am Anfang gab es nur die Steckdose und Thermostat und nun ist es überholt.
              des Weiteren sind die Datenpunkte nun mit den Namen aus der Fritzbox-API gleich. Das vereinfacht das Einlesen und Update ungemein.
              Ich hoffe es funktioniert soweit alles noch (ich habe nur DECT200 und DECT300 und da scheint es OK).
              Klaus
              PS. mit der Ampel muß ich noch schauen, ob ich das so richtig interpretiert habe.
              liv-in-skyL Offline
              liv-in-skyL Offline
              #113
              @foxthefox
              buuuh - 2 stunden wildes ändern in script's, umstellung auf aliase und vis
              aber scheint erstmal alles zu funktionieren - adapter installation ohne probleme
              danke fürs update
              • liv-in-skyL liv-in-sky
                @foxthefox
                danke fürs update
                haselchenH Offline
                haselchenH Offline
                haselchen
                #114
                @foxthefox
                Ich bin nun auch von dem Fehler betroffen in unregelmässigen Abständen:
                fritzdect.0	2021-02-07 15:00:23.424	error	(17092) no response part in returned message
                fritzdect.0	2021-02-07 15:00:23.422	error	(17092) fritzbox returned this {"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}
                Als Intervall waren zum Testen diverse Sekunden eingestellt: 300, 120....
                Ein einfacher Adapterneustart funktioniert normal alles, wird angelegt und aktualisiert.
                Adapter Version 2.1.10 von Github. Mit 2.1.7 war es schon dasselbe.
                Issue ist eröffnet
                Probiert mit Beta, Labor und Stable Software der Fritzbox.
                Seit der 7.24 (glaube ich) gibt es statt dem Admin einen neuen FB User.
                fritz und 4 Zahlen dahinter, so wird er jedenfalls von meiner FB angelegt.
                Habe ich aber auch im Adapter geändert. Fehler bleibt.
                liv-in-skyL J 2 Antworten Letzte Antwort
                • haselchenH haselchen
                  @foxthefox
                  Issue ist eröffnet
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #115
                  @haselchen ich glaube, dass habe ich bei mir auch schon mal gesehen
                    @foxthefox
                    Issue ist eröffnet
                    Jan1
                    #116
                    @haselchen
                    Das liegt an zu schnell hintereinander erfolgter Zugriffe, da blockt die Box einfach. Da hilft nur Scripte optimieren.
                    • J Jan1
                      @haselchen
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #117
                      @jan1
                      Aber da greift nüscht auf die Box zu.
                      Ausser dem fritzdect alle 300sek.
                      J F 2 Antworten Letzte Antwort
                        @jan1
                        Jan1
                        #118
                        @haselchen
                        Und was macht der Adapter?
                        • J Jan1
                          @haselchen
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          #119
                          @jan1
                          Kontrolliert 1 !!! Steckdose von Fr!tz :)
                          Das sollte FB und Adapter nicht überfordern ;)
                            @jan1
                            Jan1
                            #120
                            @haselchen
                            Ich habe den Fehler wenn meine Heizung anspringt, weil dann die Regelung greift und hier kurzfristig viel Verkehr ist. Wenn sich das eingependelt hat, geht auch das Problem weg.
                            • F Offline
                              foxthefox
                              #121
                              @haselchen
                              In Github hab ich schon die Antwort geschrieben.
                              Es ist weniger ein Fehler sondern eine Eigenschaft der FB nicht zu viele Logins zuzulassen.
                              wenn User und Passwort stimmen, dann hatte höchstwahrscheinlich die Fritzbox zu viele Logins abbekommen, die dann zum Verweigern führen.
                              Ursache kann eine recht schnelles Abfrageintervall, viele Befehle zur gleichen Zeit (ggf. "unsaubere" Skripte, andere Adapter/apps die auch auf FB einloggen) sein.
                              Dazu müsste man ggf. das log ,al anschauen, wann es passiert und in welchem sonstigen Umfeld.
                              da ist die Version des Adapters egal, die Einstellungen und das Drumherum entscheidet
                              Ein Aufruf: video
                                @jan1
                                foxthefox
                                #122
                                @haselchen
                                es gab auch schon user, die noch einen anderen Rechner hatten, wo noch andere smarthome Sachen darauf laufen und da schlummerte dann noch eine Instanz die sich mit FB beschäftigt hat.
                                300sek und eine DECT200 sollten stabil laufen.
                                Ein Aufruf: video
                                • F foxthefox
                                  @haselchen
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #123
                                  @foxthefox
                                  Hab eben auf Github geantwortet.
                                  Ich hab sonst nichts was auf die FB zugreift.
                                  Wie schon erwähnt auf Github, ist es meines Erachtens seit der Einführung des neuen FB Benutzers so.
                                  • J Offline
                                    Jan1
                                    #124
                                    Mich wundert es auch, dass die Fehlermeldung auch nur in Verbindung mit dem DECT Adapter kommt. Beim TR064 Adapter kommt das nie, was schon ein Rückschluss auf den Adapter zulässt. Ich müsste zum Testen mal beide Adapter mit dem selben User laufen lassen, wenn dann immer noch nur der DECT den Fehler bringt, liegt es doch am Adapter.
                                    • J Jan1
                                      foxthefox
                                      #125
                                      @jan1
                                      aus Adaptersicht ist der User ein String, also da schließe ich mal den Adapter aus, eher ist 7.24 als Laborversion eine Ursache.
                                      Mit 7.24 ändert sich das Anmeldeverfahren und evtl. gibt es Probleme den Hash schnell genug auszurechnen.
                                      Ein Aufruf: video
                                      • F foxthefox
                                        @jan1
                                        Jan1
                                        #126
                                        @foxthefox
                                        Da war ja was mit beta bei der Fritz. Bist Du da noch dran?
                                        Mich stört die Fehlermeldung nicht wirklich, da die Heizung auch ein paar Minuten warten kann bis die Werte gesetzt werden. Iritiert nur etwas wenn man ins Log schaut.
                                        • J Jan1
                                          @foxthefox
                                          foxthefox
                                          #127
                                          @jan1
                                          der neue Login Mechanismus, der ab 7.25 kommt und schon jetzt in 7.24 enthalten ist, wird seit 2.1.x unterstützt.
                                          Aus meiner Sicht ist erstmal nichts zu tun.
                                          Ein Aufruf: video
                                          lemonbiterL 1 Antwort Letzte Antwort
