  4. js-controller 3.2 jetzt im Latest!
    1.0k
575 Beiträge 70 Kommentatoren 189.5k Aufrufe 57 Beobachtet
  • crunchipC Abwesend
    crunchipC Abwesend
    #183
    @apollon77 hab ne Verständnisfrage, bzw ein Problem. Habe gerade
    • Js-C upgrade von 3.2.7 auf 3.2.8
    • danach iobroker fix durchlaufen lassen
      nun erhalte ich im Adapter linux-control folgendes
    linux-control.0	2021-01-23 11:37:26.716	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
    linux-control.0	2021-01-23 11:37:26.716	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:87:5)
    linux-control.0	2021-01-23 11:37:26.716	error	at LinuxControl.userCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:196:9)
    linux-control.0	2021-01-23 11:37:26.716	error	at LinuxControl.userCommandExecute (/opt/iobroker/node_modules/iobroker.linux-control/main.js:251:21)
    linux-control.0	2021-01-23 11:37:26.716	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    linux-control.0	2021-01-23 11:37:26.716	error	at runMicrotasks (<anonymous>)
    linux-control.0	2021-01-23 11:37:26.716	error	at LinuxControl.sendCommand (/opt/iobroker/node_modules/iobroker.linux-control/main.js:874:26)
    linux-control.0	2021-01-23 11:37:26.716	error	(22907) [userCommandExecute] iobroker (10.1.1.10:22, id: root-verzeichnis, description: ): response error: /root/.bashrc: Zeile 24: /root/.iobroker/iobroker_completions: Datei oder Verzeichnis nicht
    linux-control.0	2021-01-23 11:37:26.680	error	at LinuxControl.onReady (/opt/iobroker/node_modules/iobroker.linux-control/main.js:54:5)
    linux-control.0	2021-01-23 11:37:26.680	error	at LinuxControl.refreshHost (/opt/iobroker/node_modules/iobroker.linux-control/main.js:82:5)
    linux-control.0	2021-01-23 11:37:26.680	error	at LinuxControl.servicesInfo (/opt/iobroker/node_modules/iobroker.linux-control/main.js:485:21)
    linux-control.0	2021-01-23 11:37:26.680	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    linux-control.0	2021-01-23 11:37:26.680	error	at runMicrotasks (<anonymous>)
    • apollon77A apollon77
      Hallo ioBroker-Community,
      mit etwas zeitlicher Verspätung, dafür aber um so besser, kommt heute der neue js-controller 3.2 (Releasename "Grace") ins Latest Repository (sollte im laufe des Abends bei allen auftauchen). Ein großer Dank geht an alle User die bereits in den Letzten Tagen diese Version im Beta test getestet und Probleme und Fehler zur Behebung gemeldet haben!
      Node.js Versions-Anforderungen
      Die unterstützten Node.js Versionen bleiben in diesem Update gleich: 10.x, 12.x und auch 14.x werden offiziell unterstützt. Aufgrund der übergreifenden Adapter-Kompatibilität bleibt die empfohlene Node.js Version für ioBroker aktuell weiterhin auf 12.x. Falls jemand wirklich mit Node.js 15.x experimentieren will, dann bitte AUSSCHLIESSLICH mit npm 6 !! (die npm Leute haben in npm 7 wieder Dinge geändert, die wir noch untersuchen)
      Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/post/266625
      Informationen zur Version
      Neben einigen Features haben wir unter der Haube weiter aufgeräumt und sehr viel modernisiert und vereinheitlicht.
      Auch daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen wurde weiter gearbeitet, was ggf. zu neuen Log-meldungen für bestimmte Fälle führt. Bitte unterstützt hier wieder und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
      Besonders zu erwähnen ist die Grundlage für das neue Benachrichtigungssystem (kommt dann in einem Admin-Update) und die Reaktivierung von Let's Encrypt zur automatischen Zertifikatsaktualisierung.
      Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
      In Summe sind in diese Version über 650 commits eingeflossen. Dafür bedenke mich diesmal besonders bei foxriver76, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern für die aktive Mitarbeit an dieser Version!
      Der js-controller 3.2 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2 ist problemlos möglich. Nur die Node.js Version muss jetzt mindestens 10.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
      Es gibt aktuell keine inkompatiblem Adapter, aber einige Empfehlungen weiter unten.
      Installation
      VOR der Installation
      Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Die alte Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version installiert werden und sollte alles wieder herstellen.
      Nötige Adapter-Aktualisierungen
      Aktuell sind keine Inkompatibilitäten bekannt, damit allerdings Let's encrypt wieder funktioniert benötigt es einige Adapter in "Latest" Versionen von mindestens:
      • ioBroker.lovelace 1.4.1 oder höher
      • ioBroker.simple-api 2.5.2 oder höher
      • ioBroker.socketio 3.1.3 oder höher
      • ioBroker.telegram 1.7.0 oder höher
      • ioBroker.web 3.2.2 oder höher
      • ioBroker.admin 4.2.1 oder höher
      Es werden aber, wie oben ausgeführt, einige Adapter ggf Warnungen ins Log schreiben. Falls das Problematisch ist ist aktuell die einzige Option das Loglevel der Instanz auf "Error" zu setzen.
      Achtung: MASTER-Systeme Reihenfolgen beachten!
      Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.1 läuft ist es beim Update auf Version 3.2 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
      Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 3.2 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Beim Slave Updat emuss der alte master aber noch laufen. Die Slaves bleiben nach dem Update offline und können sich nicht zum Master verbinden und werden erst wieder funktionieren wenn auch der Master auf die 3.2 aktualisiert wurde!
      Windows
      Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden weiss ich gerade nicht wie der aktuelle Prozess ist, da der Windows installer nicht ganz aktuell ist. Bitte hier berichten dann kann ich ergänzen.
      Für alle "alten manuellen" Installationen gilt
      • ioBroker muss gestoppt sein.
      • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
      • iobroker update
      • iobroker upgrade self
      • ioBroker starten
      Linux
      • ioBroker stoppen (iobroker stop)
      • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
      • iobroker update
      • Wie üblich wird das Update dann per iobroker upgrade self ausgeführt.
      • ioBroker starten (iobroker start)
      Bei Fehlern:
      Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
      Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
      NACH der Installation
      Nach der Installation den ioBroker wieder starten (z.B. mittels iobroker start).
      Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
      Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
      Mit iobroker help wird eine Liste der möglichen Kommandozeilen-Kommandos angezeigt, die mit Version 2.0 um einige Befehle länger geworden ist. Es geht jetzt auch Kommandospezifisch Hilfe zu erhalten (iobroker upgrade --help)
      Was hat sich geändert, was besonders ansehen/beachten?
      Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
      • generell siehe Changelog, speziell auch für Features
      • Let's Encrypt sollte wieder tun. Minimum Adapterversionen dazu siehe weiter oben!
      • Einige Adapter werden Warnungen ausgeben wenn State-Werte gesetzt werden VOR dem Anlegen von Objekten. Bitte bei den Adapter-Repos melden
      Speziell die Entwickler sollten bitte die genannten Deprecations anschauen und beachten
      Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
      BREAKING CHANGES
      • None, Supported are nodejs 10.x, 12.x and 14.x (Node.js 15.x is also working WHEN USED WITH npm 6!! in the automated tests, but formally not supported)
      • If you have enabled Multihost Discovery please disable and enable it again if you really need it persistant running. By re-enabling it you update the used passphrase with a better encryption mechanism.
      Features
      • (raintonr) Update Let's encrypt implementation; all relevent adapters (web and such) need updates to use it! NEEDS NODE.JS 12.x+! (see DOCS LINK TODO)
      • (bluefox) Restart adapters that use Let's encrypt after certificates were updated
      • (bluefox) Provide min/max for convert alias functions
      • (foxriver76) handling major adapter upgrades more carefully (CLI on upgrade will show if it's a major upgrade and major upgrades will be skipped on upgrade all when executed by admin
      • (AlCalzone) detect and allow short github URL format when (auto-)installing adapters (iobroker url User/repo#branchorcommit)
      • (foxriber76) Add notification system (see DOCS LINK TODO)
      • (foxriver76) enhance setup (and setup first) with redis to all port configuration
      • (foxriver76) set connectionName for redis connections and simulator support (see DOCS LINK TODO)
      Optimizations and Fixes
      • (foxriver76) Detect adapter restart loops and stop restarting after 3 crashes (an adapter is considered "working" when no crash by an exception happens within 10 minutes)
      • (foxriver76) Fix failed logins if username is uppercase, be reworking user logic and caching
      • (bluefox) Set for def states the quality: QUALITY_SUBS_INITIAL
      • (AlCalzone) fix npm uninstall loglevel argument
      • (foxriver76) delete pids.txt when iobroker was stopped
      • (bluefox) Add missing attributes by multihost if Redis is used for objects/states, Remove unused settings from iobroker-dist.json, Remove pass and user from connection settings. Use options.auth_pass
      • (AlCalzone) Package-Manager: log which packages were (already) installed
      • (foxriver76) replace redis "KEYS" command by "SCAN" to optimize redis access performance
      • (foxriver76) optimize redis library usage to prevent errors on redis outages
      • (bluefox) Catch errors by plugins load. At least log will work and could be checked for errors.
      • (foxriver76) allow migration of instances to already existing host
      • (foxriver76) also allow <adapter>.<instance-nr> for install/add cli command
      • (AlCalzone) buffer streams that are piped to stdout to fix weird Windows logging cases
      • (foxriver76/AlCalzone) Optimize upgrade/downgrade logic for adapters, ask for a downgrade only if lower version is to be installed
      • (foxriver76) allow redis redis migration when changing host of redis - fix bug where process crashes when controller is running when migrating
      • (bluefox) Catch errors for subscribe on alias without target
      • (foxriver76) only perform auto scaling on alias if not null
      • (foxriver76) if repository request fails also use cached sources on updating repository
      • (foxriver76) prevent host deletion from same host - otherwise it will remove the system.host states but instances will still be on the removed host, because transfer happens to itself
      • (foxriver76) use instanceObjects from system.adapter.* object instead from io-package.json
      • (foxriver76) notify of errors on readFileCertificates to show permission problems etc.
      • (foxriver76) multihost discovery now logs ignored messages on debug and also logs the senders address
      • (foxriver76) sync up created objects on instance start and instance creation by using helper function in tools.js, e.g. .loglevel was missing on instance creation
      • (bluefox) Package-Manager: Filter empty packets out to suppress error message
      • (foxriver76) rename repository names for new installations and on updates to beta/stable
      • (foxriver76) rewrite collectDiagInfo to Promises and fix minor issue with it
      • (foxriver76) only scale aliases if target or source is represented by unit %
      • (foxriver76) create meta.user on file sync cli, if not existing (see DOCS LINK TODO)
      • (Apollon77) also create meta.user on setup first if not existing
      • (foxriver76) fix enumInstances used by CLI commands
      • (foxriver76) when missing rights to access log dir do not crash hard anymore, instead fallback to default directory
      • (bluefox) Fix error if type of native data changed in the new version from basic type e.g. 'string' to 'object'.
      • (AlCalzone) Remove hardcoded references to GitHub master branch because newer repositories use "main"
      • (Apollon77) update _design objects also on js-controller upgrade/setup first
      • (Apollon77) optimize deletion of files in ioBroker file storage
      • (foxriver76) do not return an error if object does not exist on del*Object
      • (Apollon77) optimize logs when instance is restarted
      • (foxriver76) Preserve name field on instance object creation/update
      • (foxriver76) optimize parameters and flags on CLI
      • (foxriver76) Use yargs helper instead of building our own string output to allow showing --help for a specific command instead of the whole output and allow support for auto completion (iobroker _createCompletion >> ~/.bashrc)
      • (foxriver76, Apollon77) also accept pre-release version in some semver checks for dependencies
      • (foxriver76) replace outdated encryption mechanism of multihost
      • (Apollon77, foxriver, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
      Developer relevant DEPRECATIONS/WARNINGS
      • (foxriver76) we warn if object not exists when setting a state via adapter.setState. Adjust your code that a state value is NOT set before the object is successfully created. If this deep check is NOT wanted for performance reasons the adapter needs to be initialized with strictObjectChecks = false!! (see DOCS LINK TODO)
      • (foxriver76) readFile should not validate meta object, we now throw on writeFile if id is no valid meta object
      • (AlCalzone) update Forbidden ID Characters: use Unicode properties to define which characters are allowed instead of blacklisting. For ASCII the allowed characters are the same as before - for other languages mainly character class of Unicode are allowed! (see DOCS LINK TODO)
      • (foxriver76) Throw on invalid setState objects; was logged as deprecated before
      • (foxriver76) remove getMessage shim, no adapter uses it anymore; was logged as deprecated before
      Developer relevant new Features
      • (foxriver76) use aes-192-cbc as encryption - backward compatible with current encryption, nothing to do for adapter-developers (see DOCS LINK TODO)
      • (bluefox) Add system view to filter for "folder" objects
      • (bluefox) add set/clearTimeout and set/clearInterval to adapter methods and check on unload that they were all cleared and clear if needed with logging, so developers are reminded to clean up!
      • (AlCalzone) Add ...Async version for getChannels - make sure to check before using or use correct js-controller version dependency!
      • (Apollon77) modularize databases into own npm packages and basically support adding new types of databases; add deprecation infos and logging to "old legacy" files in lib/states and lib/objects to not be used anymore; requires mostly updates in testing (see DOCS LINK TODO)
      • (foxriver76) allow to specify the instance for debug starts (iobroker debug adaptername.1)
      • (foxriver76) Enhance extendObject to allow to preserve specified fields (e.g. common.name)
      Developer relevant Optimizations and Fixes
      • (foxriver76) implement maybeCallback and maybeCallbackWithError and use it in adapter.js
      • (AlCalzone) use fs-extra instead of mkdirp
      • (AlCalzone) read JSON files using fs-extra's readJSONSync
      • (AlCalzone) fix callback definitions in adapter.js, We have signatures for (almost) everything in @types/iobroker and we should use them
      • (AlCalzone) move from Promises to async/await in some places, use a single readyPromise instead of an array
      • (bluefox) Added "http" and "stream" options for logs
      • (foxriver76) migrated ci tests to github actions
      • (foxriver76) resolve adapter main file as tools.js method
      • (foxriver76) optimize extendObject with def value
      • (AlCalzone) Handle existing, but undefined properties in validateSetStateObjectArgument
      • (foxriver76) also escape + char on regex, it's not forbidden
      • (bluefox) Set default state only for objects of type "state"
      • (AlCalzone) include folders in the result of getAdapterObjects
      • general dependency updates
      • code style optimizations
      Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
      Wie Fehler melden?
      Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
      Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
      Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
      Ingo
      KHK
      #184
      @apollon77
      Mit dem Update auf einem RPi4 habe ich schon beim Start folgende Fehler:
      wenn ich iobroker fix mache kommt ähnliches :
      Karl
      • DiginixD Offline
        DiginixD Offline
        Diginix
        #185
        @apollon77 mein Host lief bisher mit loglevel warn. Ob es daran liegt, dass man nicht mehr sieht weiß ich nicht.
        Hier mal von 11:00 Uhr und 11:30 wieder so ein Fall wo die Instanz nicht gestartet wurde und jeweils zweimal die 3 Prozesse zum Restart der Instanz nicht beendert wurden. 11:45 Uhr hat es dann funktioniert. Aber die Zombies von den 2 Läufen davor blieben. Die CPU Last steigt mit jedem mal wo die 3 Prozesse bleiben um ca. 1-2.
        iobroker   28628  0.0  0.0  10156  2888 ?        S    11:00   0:00 /bin/bash /usr/bin/iobroker restart radar2.0
        root       28629  0.0  0.1  12640  4944 ?        S    11:00   0:00 sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js restart radar2.0
        iobroker   28630 98.2  3.4 743112 134900 ?       Rl   11:00  45:34 node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js restart radar2.0
        iobroker   32996  0.0  0.0  10156  2900 ?        S    11:30   0:00 /bin/bash /usr/bin/iobroker restart radar2.0
        root       32997  0.0  0.1  12636  4932 ?        S    11:30   0:00 sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js restart radar2.0
        iobroker   32998 95.8  2.9 743352 118528 ?       Rl   11:30  15:42 node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js restart radar2.0
        iobroker   35355 16.2  1.9 638660 77188 ?        Sl   11:46   0:03 io.radar2.0
        Und hier das Log:
        2021-01-23 11:00:06.485  - info: javascript.0 (1408) script.js.automatization.Door_Window.Smart_Lock: *** Smart Lock radar2.0.alive: false / radar2.0.connected: false
        2021-01-23 11:00:14.150  - info: javascript.0 (1408) script.js.automatization.Door_Window.Smart_Lock: *** Smart Lock: unlocked #1
        2021-01-23 11:00:17.152  - info: javascript.0 (1408) script.js.automatization.Door_Window.Smart_Lock: *** Smart Lock: #1 Starting radar2
        2021-01-23 11:00:27.096  - info: javascript.0 (1408) script.js.automatization.Door_Window.Smart_Lock: *** Smart Lock: #1 Unable to increase LUA script timeout: Error: Connection is closed.
         Cannot load "custom": Error: Connection is closed.
        over 40000 mal die Zeile "Cannot load "custom": Error: Connection is closed."
        2021-01-23 11:30:48.377  - info: javascript.0 (1408) script.js.automatization.Door_Window.Smart_Lock: *** Smart Lock: #1 radar2.0.connected: false
        2021-01-23 11:30:48.378  - info: javascript.0 (1408) script.js.automatization.Door_Window.Smart_Lock: *** Smart Lock: #2 Starting radar2
        2021-01-23 11:30:55.122  - info: javascript.0 (1408) script.js.automatization.Door_Window.Smart_Lock: *** Smart Lock: #2 The adapter "radar2.0" was started.
        2021-01-23 11:31:15.124  - info: javascript.0 (1408) script.js.automatization.Door_Window.Smart_Lock: *** Smart Lock: #2 radar2.0.connected: true
        2021-01-23 11:31:58.030  - error: daswetter.0 (33006) force terminate
        2021-01-23 11:31:58.036  - warn: daswetter.0 (33006) Terminated (15): Without reason
        2021-01-23 11:32:04.439  - warn: daswetter.0 (33006) get state Error: DB closed
        2021-01-23 11:32:04.440  - warn: daswetter.0 (33006) get state Error: DB closed
        2021-01-23 11:32:04.441  - warn: daswetter.0 (33006) get state Error: DB closed
        2021-01-23 11:32:04.442  - warn: daswetter.0 (33006) get state Error: DB closed
        2021-01-23 11:32:04.443  - warn: daswetter.0 (33006) get state Error: DB closed
        2021-01-23 11:32:04.444  - warn: daswetter.0 (33006) get state Error: DB closed
        2021-01-23 11:32:04.445  - warn: daswetter.0 (33006) get state Error: DB closed
        2021-01-23 11:32:04.446  - warn: daswetter.0 (33006) get state Error: DB closed
        2021-01-23 11:32:04.447  - warn: daswetter.0 (33006) get state Error: DB closed
        2021-01-23 11:32:04.451  - error: daswetter.0 (33006) exception in await insertIntoList [Error: DB closed]
        2021-01-23 11:32:05.765  - error: daswetter.0 (33006) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-01-23 11:32:05.766  - error: daswetter.0 (33006) unhandled promise rejection: Cannot read property 'setState' of null
        2021-01-23 11:32:05.812  - error: daswetter.0 (33006) TypeError: Cannot read property 'setState' of null
            at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6065:35)
        2021-01-23 11:32:05.813  - error: daswetter.0 (33006) Cannot read property 'setState' of null
        2021-01-23 11:32:06.187  - error: host.BT3-PRO instance system.adapter.daswetter.0 terminated with code 15 (15)
        2021-01-23 11:40:23.212  - warn: ical.0 (34385) get state Error: Connection is closed.
        2021-01-23 11:40:23.232  - warn: ical.0 (34385) get state Error: DB closed
        Die Konsolenausgaben bei "iobroker restart radar2.0" sind entweder: "The adapter "radar2.0" was started." oder gar keine.
        Im Fall von "...was started" läuft nicht zwingend die Instanz wieder. Deswegen prüfe ich den .connected state.
        Wenn gar keine Ausgabe kommt, ist es der zur Zeit der Fall mit "Cannot load "custom": Error: Connection is closed."
        Das Skript ist eigentlich ein Blockly, aber hier mal der Teil zum Stoppen und Starten der Instanz als Javascript:
        var command, restart_count, run_count, result, timeout_keyble, check_radar_running, timeout_radar_restart;
        // Smart Lock Control
        async function control_smart_lock(command) {
          run_count = (typeof run_count == 'number' ? run_count : 0) + 1;
          exec('iobroker stop radar2.0', async function (error, result, stderr) {
              // 5000 ms bis 2020-05-25
            timeout_keyble = setTimeout(async function () {
              console.log((['*** Smart Lock radar2 alive: ',getState("system.adapter.radar2.0.alive").val,' / connected: ',getState("system.adapter.radar2.0.connected").val].join('')));
              exec('keyble-sendcommand --address 00:11:22:33:44:55 --user_id 2 --user_key *** --command status', async function (error, result, stderr) {
                  console.log(('*** Smart Lock: ' + String(result)));
                // war 20s und nach exec keyble, nicht innerhalb
                // bis 2020-05-25
                // seit 2020-06-25 7s statt 2s damit bei unlock/lock
                // retry radar2 nicht erst zwischen gestartet wird
                timeout_radar_restart = setTimeout(async function () {
                  await start_radar2(1);
                }, 3000);
            }, 2000);
        // Beschreibe diese Funktion …
        async function start_radar2(restart_count) {
          console.log((['*** Smart Lock: #',restart_count,' Starting radar2'].join('')));
          exec('iobroker restart radar2.0', async function (error, result, stderr) {
              console.log((['*** Smart Lock: #',restart_count,' ',result].join('')));
            check_radar_running = setTimeout(async function () {
              console.log((['*** Smart Lock: #',restart_count,' radar2 connected: ',getState("system.adapter.radar2.0.connected").val].join('')));
              if (getState("system.adapter.radar2.0.connected").val != true && restart_count < 3) {
                restart_count = (typeof restart_count == 'number' ? restart_count : 0) + 1;
                await start_radar2(restart_count);
              } else if (getState("system.adapter.radar2.0.connected").val != true && restart_count >= 3) {
                console.log((['*** Smart Lock radar2 running: ',getState("system.adapter.radar2.0.connected").val,', kein ',restart_count + 1,'. Versuch'].join('')));
            }, 20000);
        await control_smart_lock('status');
        ..:: So long! Tom ::..
        M apollon77A 2 Antworten Letzte Antwort
        • DiginixD Diginix
          Und hier das Log:
                  // bis 2020-05-25
                  }, 3000);
              }, 2000);
              }, 20000);
          MHeymann
          schrieb am zuletzt editiert von MHeymann
          #186
          Ich habe eben auch auf 3.2.8 geupdatet. Jetzt bleibt mein Mein javascript Adapter rot.
          host.ioBroker	2021-01-23 12:08:46.875	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.ioBroker	2021-01-23 12:08:46.875	error	Caught by controller[0]: }
          host.ioBroker	2021-01-23 12:08:46.875	error	Caught by controller[0]: ]
          host.ioBroker	2021-01-23 12:08:46.875	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
          host.ioBroker	2021-01-23 12:08:46.875	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
          host.ioBroker	2021-01-23 12:08:46.875	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: requireStack: [
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: {
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.ioBroker	2021-01-23 12:08:46.874	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: Require stack:
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: Error: Cannot find module 'typescript'
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: ^
          host.ioBroker	2021-01-23 12:08:46.873	error	Caught by controller[0]: throw err;
          host.ioBroker	2021-01-23 12:08:46.872	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
          host.ioBroker	2021-01-23 12:08:16.724	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.ioBroker	2021-01-23 12:08:16.724	error	Caught by controller[0]: }
          host.ioBroker	2021-01-23 12:08:16.724	error	Caught by controller[0]: ]
          host.ioBroker	2021-01-23 12:08:16.724	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: requireStack: [
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: {
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.ioBroker	2021-01-23 12:08:16.723	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: Require stack:
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: Error: Cannot find module 'typescript'
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: ^
          host.ioBroker	2021-01-23 12:08:16.722	error	Caught by controller[0]: throw err;
          host.ioBroker	2021-01-23 12:08:16.721	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
          host.ioBroker	2021-01-23 12:07:46.602	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.ioBroker	2021-01-23 12:07:46.602	error	Caught by controller[0]: }
          host.ioBroker	2021-01-23 12:07:46.602	error	Caught by controller[0]: ]
          host.ioBroker	2021-01-23 12:07:46.602	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
          host.ioBroker	2021-01-23 12:07:46.602	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
          host.ioBroker	2021-01-23 12:07:46.602	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: requireStack: [
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: {
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.ioBroker	2021-01-23 12:07:46.601	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: Require stack:
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: Error: Cannot find module 'typescript'
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: ^
          host.ioBroker	2021-01-23 12:07:46.600	error	Caught by controller[0]: throw err;
          host.ioBroker	2021-01-23 12:07:46.599	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
          host.ioBroker	2021-01-23 12:07:16.473	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: }
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: ]
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: requireStack: [
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: {
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.ioBroker	2021-01-23 12:07:16.473	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          host.ioBroker	2021-01-23 12:07:16.472	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          host.ioBroker	2021-01-23 12:07:16.471	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
          host.ioBroker	2021-01-23 12:07:16.471	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
          host.ioBroker	2021-01-23 12:07:16.471	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
          host.ioBroker	2021-01-23 12:07:16.471	error	Caught by controller[0]: Require stack:
          host.ioBroker	2021-01-23 12:07:16.471	error	Caught by controller[0]: Error: Cannot find module 'typescript'
          host.ioBroker	2021-01-23 12:07:16.471	error	Caught by controller[0]: ^
          host.ioBroker	2021-01-23 12:07:16.471	error	Caught by controller[0]: throw err;
          host.ioBroker	2021-01-23 12:07:16.471	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
          Keine Ahnung was da falsch gelaufen ist.
          Hat da jemand ne lösung für mich?
          LG Marko
          Thomas BraunT apollon77A 2 Antworten Letzte Antwort
          • M MHeymann
            LG Marko
            #187
            @mheymann
            node-Installation sauber?
              @mheymann
              MHeymann
              #188
              Keine Ahnung??? Wie Prüfe ich das? Vor dem Update war alles io.
              • M MHeymann
                #189
                @mheymann
                Sicher das du im Beta-Zweig richtig bist?
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  #190
                  @crunchip Hm .. ok denke braucht einen neuen installer bzw fixer. Dann ist das weg. sind dran
                  • K KHK
                    @apollon77
                    Karl
                    #191
                    @khk Liegt am installation fixer, nicht controller. Fix kommt nachher
                      HomoranH Offline
                      HomoranH Offline
                      #192
                      @apollon77 sagte in js-controller 3.2 jetzt im Latest!:
                      bleibt der dann 3.1.x oder gar 2.2.x kompatibel?
                      • M MHeymann
                        LG Marko
                        #193
                        @mheymann AM besten den javascript Adapte rnochmals installieren ...
                        am besten in /opt/iobroker
                        ein "npm i iobroker.javascript"
                        ausführen. Das ist komisch
                          #194
                          @homoran Komplett unabhängig vom controller
                          • DiginixD Diginix
                            Und hier das Log:
                                    // bis 2020-05-25
                                    }, 3000);
                                }, 2000);
                                }, 20000);
                            #195
                            @diginix Ich bereite für nachmittag eine 3.2.9 vor (muss nur erst einkaufen), dann müsste das problem weg sein
                              @mheymann
                              MHeymann
                              #196
                              Durchaus möglich das ich hier nicht ganz richtig bin. Hab nur gelesen das crunchip auch nen Fehler nach dem update hat. Da mir ehrlich gesagt gerade das Hertz in die Hose gerutscht ist als ich die lange Fehlermeldung gesehen habe versuche ich einfach hier mein Glück. Sorry dafür.
                              /usr/bin/nodejs
                              v12.20.1
                              /usr/bin/node
                              v12.20.1
                              /usr/bin/npm
                              6.14.10
                              nodejs:
                                Installed: 12.20.1-1nodesource1
                                Candidate: 12.20.1-1nodesource1
                                Version table:
                               *** 12.20.1-1nodesource1 500
                                      500 https://deb.nodesource.com/node_12.x bionic/main amd64 Packages
                                   8.10.0~dfsg-2ubuntu0.4 500
                                      500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                                   8.10.0~dfsg-2ubuntu0.2 500
                                      500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                                   8.10.0~dfsg-2 500
                                      500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                              • M MHeymann
                                /usr/bin/nodejs
                                v12.20.1
                                /usr/bin/node
                                v12.20.1
                                /usr/bin/npm
                                6.14.10
                                nodejs:
                                  Version table:
                                     8.10.0~dfsg-2 500
                                #197
                                @mheymann Passt soweit.
                                Dann die Änderungen abwarten.
                                  MHeymann
                                  #198
                                  @apollon77
                                  ein "npmi iobroker.javascript"
                                  Hat funktioniert. Vielen Dank für die Hilfe.
                                  • apollon77A Offline
                                    #199
                                    Der Installation Fixer ist "gefixt" :-) Also bitte nochmal iobroker stoppen und "iobroker fix" ausführen, dann sollten die komischen Shell meldungen weg sein
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #200
                                      @apollon77 super und danke für den schnellen fix, läuft wieder👍
                                      was mir grad aufgefallen ist, die zweite Zeile, die ist neu
                                      tankerkoenig.0	2021-01-23 13:47:47.399	warn	(15196) State "tankerkoenig.0.stations.8.e10.combined" has no existing object, this might lead to an error in future versions
                                      tankerkoenig.0	2021-01-23 13:47:46.387	warn	(15196) Please update js-controller to at least 1.2.0
                                        #201
                                        @crunchip Nee die ist Uralt und kommt dann wenn der zum anlegen der Objekte mal "Länger" als erwartet braucht ... ist ein mega hack und bullshit inzwischen :-) leg mal eher ein issue an das man das ausbaut ;-)
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #202
                                          @apollon77 ok, mach ich
                                          seltsam, sonst wurde mir nur die erste Zeile angezeigt
                                          edit:
                                          @apollon77 Alexa2 (weil es ja dein Part ist☺ und ich den passenden Thread grad nicht finde)
                                          version 3.5.6 bei start von iobroker
                                          2021-01-23 13:47:18.036 - error: alexa2.0 (14667) Error: Error while checking Authentication: Error: no JSON
                                          2021-01-23 13:47:18.039 - info: alexa2.0 (14667) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-01-23 13:47:19.461 - error: alexa2.0 (14667) Cannot check object existence of "alexa2.0.info.connection": Error: Connection is closed.
                                          2021-01-23 13:47:19.462 - warn: alexa2.0 (14667) Could not check object existence of state alexa2.0.info.connection: Error: Cannot check object existence of "alexa2.0.info.connection": Error: Connection is closed.
                                          2021-01-23 13:47:19.463 - error: alexa2.0 (14667) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2021-01-23 13:47:19.463 - error: alexa2.0 (14667) unhandled promise rejection: Cannot read property 'setState' of null
                                          2021-01-23 13:47:19.492 - error: alexa2.0 (14667) TypeError: Cannot read property 'setState' of null
                                          2021-01-23 13:47:19.493 - error: alexa2.0 (14667) Cannot read property 'setState' of null
                                          2021-01-23 13:47:19.494 - info: alexa2.0 (14667) sendToHost not processed because States database not connected
                                          2021-01-23 13:47:20.015 - info: alexa2.0 (14667) terminating
