  4. Nach Neuinstallation läuft Java nicht mehr
java-adapter
17 Beiträge 4 Kommentatoren 1.4k Aufrufe 2 Beobachtet
  • R RDE
    @Homoran Hier das Logfile
    javascript.0	2021-01-10 13:31:28.691	error	(20491) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    javascript.0	2021-01-10 13:31:28.691	error	(20491) at runMicrotasks (<anonymous>)
    javascript.0	2021-01-10 13:31:28.690	error	(20491) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    javascript.0	2021-01-10 13:31:28.690	error	(20491) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2021-01-10 13:31:28.689	error	(20491) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
    javascript.0	2021-01-10 13:31:28.689	error	(20491) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
    javascript.0	2021-01-10 13:31:28.688	error	(20491) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
    javascript.0	2021-01-10 13:31:28.688	error	(20491) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
    javascript.0	2021-01-10 13:31:28.687	error	(20491) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
    javascript.0	2021-01-10 13:31:28.687	error	(20491) at Object.createScript (vm.js:261:10)
    javascript.0	2021-01-10 13:31:28.686	error	(20491) at new Script (vm.js:88:7)
    javascript.0	2021-01-10 13:31:28.686	error	(20491) SyntaxError: Unexpected token ':'
    javascript.0	2021-01-10 13:31:28.685	error	(20491) ^
    javascript.0	2021-01-10 13:31:28.685	error	(20491) "common": {
    javascript.0	2021-01-10 13:31:28.683	error	at script.js.RDE_-_Produktive.Prouktive_Objekte.Objekte_Haushalt_anlegen:15
    javascript.0	2021-01-10 13:31:28.683	error	(20491) script.js.RDE_-_Produktive.Prouktive_Objekte.Objekte_Haushalt_anlegen compile failed:
    javascript.0	2021-01-10 13:31:28.673	info	(20491) Start javascript script.js.RDE_-_Produktive.Prouktive_Objekte.Objekte_Haushalt_anlegen
    javascript.0	2021-01-10 13:31:28.644	info	(20491) Stop script script.js.RDE_-_Produktive.Prouktive_Objekte.Objekte_Haushalt_anlegen
    Mod-Edit: Code-tags korrigiert!
    @RDE sagte in Nach Neuinstallation läuft Java nicht mehr:
    Hier das Logfile
    gut: da steht:
    javascript.0 2021-01-10 13:31:28.683 error (20491) script.js.RDE_-Produktive.Prouktive_Objekte.Objekte_Haushalt_anlegen compile failed: at script.js.RDE-_Produktive.Prouktive_Objekte.Objekte_Haushalt_anlegen:15
    dein gepostetes Script besteht aber angeblich nur aus zwei Zeilen
    R 1 Antwort Letzte Antwort
    • R RDE
      UncleSamU Offline
      UncleSamU Offline
      UncleSam
      @RDE Hast du noch globale Skripte? Dazu musst du möglicherweise die Expertenansicht im JavaScript Baum (links) aktivieren.
      Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
      ♡-lichen Dank an meine Sponsoren
      • UncleSamU UncleSam
        RDE
        @UncleSam ![alt text](df029add-ae6b-4b11-99d2-8f4b77b23c4f-image.png image url)
        Meintest du das?
        paul53P UncleSamU 2 Antworten Letzte Antwort
          Hier das Logfile
          gut: da steht:
          RDE
          @Homoran Ja, das Script besteht aus 2 Zeilen wie gepostet, der Name des Scripts lautet "Objekte_Haushalt_anlegen"
          • R RDE
            Meintest du das?
            @RDE sagte:
            Meintest du das?
            Nein, Tab "Skripte"
            R 2 Antworten Letzte Antwort
            • R RDE
              Meintest du das?
              UncleSamU Offline
              UncleSamU Offline
              UncleSam
              schrieb am zuletzt editiert von UncleSam
              @RDE Nein, im Skripte Tab. Dort wo du die Auflistung der Skripte siehst, gibt es in der Expertenansicht einen Ordner "global" oder so. Hast du dort etwas drin?
              Edit: Genau was @paul53 geschrieben hat
                @RDE sagte:
                Meintest du das?
                Nein, Tab "Skripte"
                RDE
                @paul53 ![alt text](4286f5ea-9039-425d-9323-e1c42fbc0137-image.png image url)
                Kein Global Ordner mit Skripten. Den Rest hatte ich aus einem Export importiert.
                • R RDE
                  @UncleSam sagte in Nach Neuinstallation läuft Java nicht mehr:
                    @RDE sagte:
                    Meintest du das?
                    Nein, Tab "Skripte"
                    RDE
                    @paul53 wollte jetzt Ordner "global / common" anlegen. Fehlermeldung das der Ordner schon da ist.
                    Jetzt sehe ich ihn plötzlich, darin ist auch ein Script, welches ich jetzt gestoppt habe
                    • R RDE
                      @RDE sagte:
                      Dann ist auch der Error-Log weg?
