5.8k Beiträge 156 Kommentatoren 5.6m Aufrufe 138 Beobachtet
  • a200A a200
    @XxJooO sagte in [Linux Shell-Skript] WLAN-Wetterstation:
    @a200 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
    ./wetterstation --debug
    Ergibt:
    root@PiHole:/home/Wetterstation# ./wetterstation.sh --debug
    Connection to 192.168.178.6 8087 port [tcp/*] succeeded!
    Listening on [0.0.0.0] (family 0, port 80)
    Connection from 192.168.178.62 30756 received!
    /home/Wetterstation/wetterstation.sub: line 255: [: : integer expression expected
        "id": "0_userdata.0.Wetterstation.Innentemperatur",
        "val": 23.77
        "id": "0_userdata.0.Wetterstation.Aussentemperatur",
        "val": -0.77
        "id": "0_userdata.0.Wetterstation.Taupunkt",
        "val": -1.5
        "id": "0_userdata.0.Wetterstation.Chillfaktor",
        "val": -0.77
        "id": "0_userdata.0.Wetterstation.Innenfeuchtigkeit",
        "val": 25
        "id": "0_userdata.0.Wetterstation.Aussenfeuchtigkeit",
        "val": 95
        "id": "0_userdata.0.Wetterstation.Wind",
        "val": 0
        "id": "0_userdata.0.Wetterstation.Wind_max",
        "val": 0
        "id": "0_userdata.0.Wetterstation.Windrichtung",
        "val": 105
        "id": "0_userdata.0.Wetterstation.Druck_absolut",
        "val": 1001.01
        "id": "0_userdata.0.Wetterstation.Druck_relativ",
        "val": 1021.67
        "id": "0_userdata.0.Wetterstation.Regen_Tag",
        "val": 0
        "id": "0_userdata.0.Wetterstation.Regen_Woche",
        "val": 2.2
        "id": "0_userdata.0.Wetterstation.Regen_Monat",
        "val": 0
        "id": "0_userdata.0.Wetterstation.Regen_Jahr",
        "val": 0
        "id": "0_userdata.0.Wetterstation.Sonnenstrahlung",
        "val": 0
        "id": "0_userdata.0.Wetterstation.UV_Index",
        "val": 0
        "id": "0_userdata.0.Wetterstation.Zeitstempel",
        "val": "01.01.2021 19:04:25"
        "id": "0_userdata.0.Wetterstation.Regenstatus",
        "val": ""
        "id": "0_userdata.0.Wetterstation.UV_Belastung",
        "val": "keine"
        "id": "0_userdata.0.Wetterstation.Windrichtung_Text",
        "val": "OSO"
        "error": "datapoint \"0_userdata.0.Wetterstation.DP50.7.Temperatur\" not found"
        "error": "datapoint \"0_userdata.0.Wetterstation.DP50.7.Feuchtigkeit\" not found"
    Messwerteblock: 23.77 -.77 -1.50 -.77 25 95 0 0 105 1001.01 1021.67 0 2.2 0 0 0.0 0 01.01.2021%2019:04:25 temp7f 2.83 humidity7 82
    Nicht alle Werte werden unterstützt (abhängig vom Modell der Wetterstation und dem verwendeten Protokoll)!
    Temperatur Innen        : 23.77 °C
    Temperatur Aussen       : -.77 °C
    Taupunkt                : -1.50 °C
    Chill-Faktor            : -.77 °C
    Luftfeuchte Innen       : 25 %
    Luftfeuchte Aussen      : 95 %
    Windgeschwindkeit       : 0 km/h
    Windböengeschwindkeit   : 0 km/h
    max. Windböe            :  km/h
    Windrichtung            : 105 °
    Windrichtung            : OSO
    Luftdruck absolut       : 1001.01 hPa
    Luftdruck relativ       : 1021.67 hPa
    Regenrate               :  mm/h
    Regenstatus             :
    Regen seit Regenbeginn  :  mm
    Regen Stunde            :  mm
    Regen Tag               : 0 mm
    Regen Woche             : 2.2 mm
    Regen Monat             : 0 mm
    Regen Jahr              : 0 mm
    Regen Gesamt            :  mm
    Sonnenstrahlung         : 0.0 W/m²
    UV-Index                : 0
    Zeitstempel             : 01.01.2021%2019:04:25
    Firmware                :
    Batteriestand:          :
    Gateway-Modell          :
    Zusatzsensoren:temp7f           : 2.83
    humidity7               : 82
    Datenstring für ioBroker:
    0_userdata.0.Wetterstation.Innentemperatur=23.77&0_userdata.0.Wetterstation.Aussentemperatur=-.77&0_userdata.0.Wetterstation.Taupunkt=-1.50&0_userdata.0.Wetterstation.Chillfaktor=-.77&0_userdata.0.Wetterstation.Innenfeuchtigkeit=25&0_userdata.0.Wetterstation.Aussenfeuchtigkeit=95&0_userdata.0.Wetterstation.Wind=0&0_userdata.0.Wetterstation.Wind_max=0&0_userdata.0.Wetterstation.Windrichtung=105&0_userdata.0.Wetterstation.Druck_absolut=1001.01&0_userdata.0.Wetterstation.Druck_relativ=1021.67&0_userdata.0.Wetterstation.Regen_Tag=0&0_userdata.0.Wetterstation.Regen_Woche=2.2&0_userdata.0.Wetterstation.Regen_Monat=0&0_userdata.0.Wetterstation.Regen_Jahr=0&0_userdata.0.Wetterstation.Sonnenstrahlung=0.0&0_userdata.0.Wetterstation.UV_Index=0&0_userdata.0.Wetterstation.Zeitstempel=01.01.2021%2019:04:25&0_userdata.0.Wetterstation.DP50.7.Temperatur=2.83&0_userdata.0.Wetterstation.DP50.7.Feuchtigkeit=82&0_userdata.0.Wetterstation.Regenstatus=&0_userdata.0.Wetterstation.UV_Belastung=keine&0_userdata.0.Wetterstation.Windrichtung_Text=OSO
    DATA von Wetterstation:
    GET /weatherstation/updateweatherstation.php?ID=xxxxxx&PASSWORD=xxxxxx&indoortempf=74.8&indoorhumidity=25&tempf=30.6&humidity=95&temp7f=37.1&humidity7=82&dewptf=29.3&windchillf=30.6&absbaromin=29.56&baromin=30.17&windspeedmph=0.0&windgustmph=0.0&winddir=105&windspdmph_avg2m=0.0&winddir_avg2m=101&windgustmph_10m=0.0&windgustdir_10m=104&dailyrainin=0.0&weeklyrainin=0.09&monthlyrainin=0.0&yearlyrainin=0&solarradiation=0.0&UV=0&dateutc=2021-1-1%2019:4:25&action=updateraw&realtime=1&rtfreq=5& HTTP/1.0
    Debug VAR:
    Installationsverzeichnis: /home/Wetterstation
    IPP: 192.168.178.6:8087 WS_PORT: 80             WS_POLL: 30             PRE_DP: 0_userdata.0.Wetterstation
    WEB: HTTP               WS_PROT: Wunderground   DP50/100: 1 | 0
    Script-Version: V2.0.0  Config-Version: V2.0.0  Sub-Version: V2.0.0
    Vielleicht noch zur Ergänzung:
    Die Sainlogic FT 0300 unterstützt bis zu 8 externe Sensoren. Ich habe einen davon, dieser stellt je Sensor eine weitere externe Temperatur und Luftfeuchtigkeit zur Verfügung. Lt. Handbuch steht die Station selbst ja in der Sonne, der weitere externe Sensor soll an einer Nordwand im Schatten platziert werden. So habe ich das auch installiert.
    Also das sieht schon ganz gut aus. Die Daten werden erfolgreich ausgelesen. Du kannst in der wetterstation.conf die Anzahl der externen Sensoren angeben, dann sollten sie auch ausgelesen werden. Wenigstens der Sensor auf Kanal 7 wurde bereits ausgelesen. Schreibe mir bitte ob das mit den Sensoren funktioniert, denn bis jetzt habe ich nur mit einem Zusatzsensor testen können. Die Fehlermeldungen musst du vorerst hinnehmen. Ich habe einen Patch für dich erstellt und wenn @SBorg etwas Zeit finden wird, dann kommen die Anpassungen in eine neue Version.
    Poste einfach die Ausgabe von wetterstation.sh --debug nachdem du die Anzahl der Sensoren angepasst hast.
    Ansonsten hast du eine Version mit der du arbeiten kannst und die Daten sollten bereits in IoBroker angekommen sein.
    XxJooOX
    XxJooOX
    XxJooO
    #1914
    Die Daten kommen herein und es loggt fleißig vor sich hin. Die DP für den Sensor 7 habe ich händisch erstellt. Ich habe aber nur einen Sensor und dessen Kanal mal willkürlich auf 7 gestellt.
    Connection from 192.168.178.62 4918 received!
        "val": 23.77
        "val": -0.5
        "val": -1.5
        "val": -0.5
        "val": 30
        "val": 93
        "val": 0.32
        "val": 1.12
        "val": 76
        "val": 1002.71
        "val": 1023.37
        "val": 0
        "val": 2.2
        "val": 0
        "val": 0
        "val": 0
        "val": 0
        "val": "01.01.2021 22:39:24"
        "id": "0_userdata.0.Wetterstation.DP50.7.Temperatur",
        "val": 1.66
        "id": "0_userdata.0.Wetterstation.DP50.7.Feuchtigkeit",
        "val": 82
        "val": ""
        "val": "keine"
        "val": "ONO"
    Messwerteblock: 23.77 -.50 -1.50 -.50 30 93 .32 1.12 76 1002.71 1023.37 0 2.2 0 0 0.0 0 01.01.2021%2022:39:24 temp7f 1.66 humidity7 82
    Temperatur Aussen       : -.50 °C
    Taupunkt                : -1.50 °C
    Chill-Faktor            : -.50 °C
    Luftfeuchte Innen       : 30 %
    Luftfeuchte Aussen      : 93 %
    Windgeschwindkeit       : .32 km/h
    Windböengeschwindkeit   : 1.12 km/h
    max. Windböe            :  km/h
    Windrichtung            : 76 °
    Windrichtung            : ONO
    Luftdruck absolut       : 1002.71 hPa
    Luftdruck relativ       : 1023.37 hPa
    Regenrate               :  mm/h
    Regenstatus             :
    Regen Stunde            :  mm
    Regen Tag               : 0 mm
    Regen Monat             : 0 mm
    Regen Jahr              : 0 mm
    Regen Gesamt            :  mm
    UV-Index                : 0
    Zeitstempel             : 01.01.2021%2022:39:24
    Firmware                :
    Batteriestand:          :
    Gateway-Modell          :
    Zusatzsensoren:temp7f           : 1.66
    humidity7               : 82
    0_userdata.0.Wetterstation.Innentemperatur=23.77&0_userdata.0.Wetterstation.Aussentemperatur=-.50&0_userdata.0.Wetterstation.Taupunkt=-1.50&0_userdata.0.Wetterstation.Chillfaktor=-.50&0_userdata.0.Wetterstation.Innenfeuchtigkeit=30&0_userdata.0.Wetterstation.Aussenfeuchtigkeit=93&0_userdata.0.Wetterstation.Wind=.32&0_userdata.0.Wetterstation.Wind_max=1.12&0_userdata.0.Wetterstation.Windrichtung=76&0_userdata.0.Wetterstation.Druck_absolut=1002.71&0_userdata.0.Wetterstation.Druck_relativ=1023.37&0_userdata.0.Wetterstation.Regen_Tag=0&0_userdata.0.Wetterstation.Regen_Woche=2.2&0_userdata.0.Wetterstation.Regen_Monat=0&0_userdata.0.Wetterstation.Regen_Jahr=0&0_userdata.0.Wetterstation.Sonnenstrahlung=0.0&0_userdata.0.Wetterstation.UV_Index=0&0_userdata.0.Wetterstation.Zeitstempel=01.01.2021%2022:39:24&0_userdata.0.Wetterstation.DP50.7.Temperatur=1.66&0_userdata.0.Wetterstation.DP50.7.Feuchtigkeit=82&0_userdata.0.Wetterstation.Regenstatus=&0_userdata.0.Wetterstation.UV_Belastung=keine&0_userdata.0.Wetterstation.Windrichtung_Text=ONO
    GET /weatherstation/updateweatherstation.php?ID=xxxxxx&PASSWORD=xxxxxx&indoortempf=74.8&indoorhumidity=30&tempf=31.1&humidity=93&temp7f=35.0&humidity7=82&dewptf=29.3&windchillf=31.1&absbaromin=29.61&baromin=30.22&windspeedmph=0.2&windgustmph=0.7&winddir=76&windspdmph_avg2m=0.4&winddir_avg2m=118&windgustmph_10m=0.7&windgustdir_10m=114&dailyrainin=0.0&weeklyrainin=0.09&monthlyrainin=0.0&yearlyrainin=0&solarradiation=0.0&UV=0&dateutc=2021-1-1%2022:39:24&action=updateraw&realtime=1&rtfreq=5& HTTP/1.0
    Debug VAR:
    Vielen Dank für die großartige Unterstützung!
    ioBroker auf Intel NUC - Homematic CCU3/pivCCU auf Raspi 3B+
    • S
      S
      sonystar
      #1915
      Hallo @SBorg,
      mir ist heute aufgefallen, dass die Ermittlung der Maximaltemperatur von Vortag nicht funktioniert hat. Habe mal direkt in die Datenbank geschaut:
      SELECT * FROM "0_userdata.0.Statistik.Wetter.VorTag.Temperatur_Hoechstwert" WHERE time > '2021-01-01' tz('Europe/Berlin')
      SELECT * FROM "javascript.0.Wetterstation.Aussentemperatur" WHERE time > '2021-01-01'  and time < '2021-01-02' tz('Europe/Berlin')
      Da kommen 3,5 °C raus als maximaler Eintrag. (Aufgrund der vielzahl der Einträge habe ich mal nicht den kompletten Ausdruck eingefügt.😜
      Eine Durchschnittstemperatur von 2,9 °C kommt wohl auch nicht hin:
      Könnte es damit zusammenhängen, dass ich den noch den Haken bei "Nur Änderungen aufzeichnen" gesetzt hatte? Habe gesehen das teilweise Lücken von 30 Minuten (eingestellte Zeit im Datenpunkt) zwischen den Messwerten sind. Habe den Haken nun mal entfernt.
      • SBorgS SBorg
        @Grantlhaua Läuft er denn jetzt zumindest wieder wenn du ihn per sudo systemctl start wetterstation startest?
        Ansonsten stoppe ihn mal (sicherheitshalber) und führe im Installations-Verzeichnis mal direkt ./wetterstation.sh aus. Kommen da Fehler (Abbruch dann mit CTRL bzw. STRG + C)?
        G
        G
        Grantlhaua
        schrieb am zuletzt editiert von Grantlhaua
        #1916
        @SBorg
        Servus Sborg und frohes neues Jahr.
        mit sudo systemctl start wetterstation läuft er jetzt
        • SBorgS SBorg
          Das ganze entstand aus diesem Thread.
          Damit ist es möglich mit einem Linux-Client die Daten einer WLAN-Wetterstation und/oder mit Hilfe eines Gateways und Zusatzsensoren zu empfangen, aufzubereiten und im ioBroker zur Verfügung zu stellen. Optional können die Daten auch bei AWEKAS.at, OpenSenseMap, Windy und wetter.com zur Verfügung gestellt werden.
          Mein Dank geht an @Latzi für das testen in der Entwicklungsphase und dessen Unterstützung bei der Verfassung der WiKi-Artikel.
          Aktuelle Version auf GitHub: Current Release
          Neue Versionen im Thread sind ab V2.15.0 (Juli 2022) unterschiedlich farblich gekennzeichnet:
          • Beta-Releases haben dann eine rote Versionsnummer
          • stabile Releases haben dann eine grüne Versionsnummer
          Projektseite (inkl. WiKi): https://sborg2014.github.io/WLAN-Wetterstation/
          Da es sich um keinen Adapter handelt, ist dies eine "Vorschaltseite" von GitHub. Nicht das wer auf die Idee kommt von der URL im ioBroker installieren zu wollen ;)
          Zum Download/WiKi geht es dann weiter per View on GitHub
          Bisher geteste Stationen:
          • BRESSER
            • WLAN Farb-Wetter Center mit 5-in-1 Profi-Sensor V (1) @pandor
            • WLAN Comfort Wetterstation mit 7-in-1 Profi-Sensor (1)
          • ChiliTec Funk Wetterstation 12in1 @tege0
          • DNT Weatherscreen PRO @Petersilie
          • Ecowitt
            • GW1000
            • GW2000A
            • GW3000A @MartyBr
            • HP2564 @Mike77
            • WS2910 @Nashra
            • WS3800A @hoschi2007
            • WS3900 @Mike77
          • ELV WS980WiFi @sonystar
          • Eurochron EFWS2900 @Latzi, @ilovegym, @SBorg (baugleich mit Ambient Weather WS-2902, Chilitec CTW-902, Sainlogic 10 in 1)
          • Froggit
            • Gateway/USB-Dongle DP1500/DP2000 @Boronsbruder
            • HP1000SE Pro @Stormbringer
            • WH3000 SE @ToxSox, @crunchip
            • WH4000 SE @unltdnetworx, @Glasfaser, @Negalein, @Boronsbruder
            • WH6000 Pro @Mugel80
          • Renkforce WH2600
          • Sainlogic
            • 7 in 1 WiFi WS3500 @tritor, @manu96
            • Profi Wlan Wetterstation FT0300 (1) @XxJooO
          • Ventus W830 @CiroCool, @Rushmed
          (1) Abfrage per DNS-Server wie bspw. PiHole oder dnsmasq
          Bisher unterstütze Zusatzsensoren per Station oder mittels DP1500/DP2000/GW1000/GW2000A - Gateway:
          • bis zu 8 Stück DP35/WN34 Wassertemperatur-Sensoren
          • ein DP40/WH32 (bzw. WH26) Außentemperatur- und Luftfeuchtigkeitssensor
          • bis zu 8 Stück DP50/WH31 Temperatur-/Luftfeuchtigkeit-Sensoren
          • ein DP60/WH57 Blitzsensor
          • bis zu 4 Stück DP70/WH55 Wasserleckage-Sensoren
          • bis zu 16 Stück DP100/WH51 Bodenfeuchte-Sensoren
          • bis zu 4 Stück DP200/WH43 PM2.5 Feinstaub-Sensoren
          • ein DP250/WH45 5-In-1 CO2 / PM2.5 / PM10 / Temperatur / Luftfeuchte Innenraumsensor
          • ein DP300/WS68 Solarunterstütztes Anemometer mit UV-Lichtsensor
          • ein WH31 (bzw. WH25) Sensor
          • ein WH40H Sensor
          • ein WS80 Sensor
          • ein WS90 "Wittboy" Sensor
          • BRESSER (1)
            • bis zu 4 Stück(2) BRESSER Thermo-/Hygro-Sensor 7 Kanal #7009999
          Für den WFC01 hat @Rand nun hier und folgende ein kleines Javascript gebaut, um diesen auch auslesen zu können.
          (1) nicht alle Bresser-Stationen unterstützen Zusatzsensoren! siehe hier
          (2) durch das verwendete Wunderground-Protokoll limitiert
          Die mögliche Anzahl der Zusatzsensoren ist nicht durch das Skript begrenzt, sondern wird vom Display und/oder Gateway bestimmt.
          Es besteht ferner auch die Möglichkeit Stationen (wie bspw. Sainlogic Profi Wlan Wetterstation FT0300) einzubinden die nicht per WS View[+] App konfiguriert werden können und nur ein Web-Interface bieten, dass keine Angabe eines eigenen Wetterdienst-Servers zulässt. Hierfür kann man den Umweg eines eigenen DNS-Servers wie dnsmasq oder Pi-hole gehen. Für Pi-hole hat @XxJooO freundlicherweise hier im Forum eine ausführliche Doku erstellt: klick mich
          Wäre schön wenn sich weitere User mit entsprechenden Modellen melden bei denen es funktioniert (auch wenn es baugleiche sein sollten, so ist man sich wenigstens sicher ;) )
          Update von einer Vorgängerversion (bei Nutzung per systemd):
          Im Installationsverzeichnis ./ws_updater.sh ausführen.
          Alternativ (falls die aktuell installierte Version kleiner als V2.12.0 ist): im Installationsverzeichnis bash <(curl -s https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/ws_updater.sh) ausführen
          Update von einer Vorgängerversion (bei Nutzung als cronjob):
          Am besten das laufende Skript mit pkill -9 wetterstation.sh stoppen, wetterstation.sh und -.sub ersetzen (-.conf und -.js nur nach Aufforderung nötig; conf dann neu konfigurieren / js ersetzen und einmalig ausführen), dann entweder
          • direkt am Linux-Client ./wetterstation.sh &
          • oder per Putty oä. nohup ./wetterstation.sh & (erzeugt dabei eine Datei nohup.out)
          • oder reboot des Systemes (Skript wird dann per cronjob wieder gestartet)
          jeweils im Installationsverzeichnis ausführen. Sonst befindet sich ggf. noch das alte Skript im RAM und läuft munter bis zum nächsten Reboot weiter ;)
          Beispiele einer grafischen Umsetzung:
          @Glasfaser: View / zum Beitrag
          View
          @crunchip: Grafana / zum Beitrag
          Grafana
          Wetterstation-Statistik (JS-Addon)
          Statistikmodul als Javascript. Liefert diverse Statistiken:
          Javascript für eine HTML-Tabelle vorheriger Monatswerte ( @liv-in-sky ) :
          Beispiel 1Beispiel 2
          zum Thread
          Neues Projekt PimpMyStation (14.11.2020)
          Google Spreadsheet
          Kein Support per PM/Chat !
          P
          P
          Petersilie
          #1917
          Danke für das tolle Skript, habe extra ioBroker, InfluxDB und Grafana dafür in meinem Proxmox aufgesetzt.
          Das Skript selbst funktioniert auch und liest die Daten meiner DNT Weatherscreen PRO ein und übergibt diese nach ioBroker.
          Was kann der Grund sein, dass nur ein kleiner Teil der Daten, die in ioBroker korrekt angezeigt werden, in Grafana angezeigt werden? In meinem Fall z.B Innentemperatur ok, Außentemperatur fehlt. Dort steht N/A.
          a200A SBorgS 2 Antworten Letzte Antwort
          • P Petersilie
            a200A
            a200A
            a200
            #1918
            @Petersilie sagte in [Linux Shell-Skript] WLAN-Wetterstation:
            stoppe mal den service und zeige mal was deine WS liefert:
            service wetterstation stop
            Passwort & Co aus-x-en.
            IoBroker auf QNAP TS-451, Raspi und NUC
            P 1 Antwort Letzte Antwort
            • a200A a200
              P
              P
              Petersilie
              #1919
              Das wären die Daten:
              Temperatur Innen: 21.77 °C
              Temperatur Aussen: 3.50 °C
              Taupunkt: 1.38 °C
              Chill-Faktor: 3.50 °C
              Luftfeuchte Innen: 55 %
              Luftfeuchte Aussen: 86 %
              Windgeschwindkeit: 0 km/h
              Windböengeschwindkeit: 0 km/h
              max. Windböe:  km/h
              Windrichtung: 61 °
              Windrichtung: ONO
              Luftdruck absolut: 1003.42 hPa
              Luftdruck relativ: 1003.42 hPa
              Regenrate: 0 mm/h
              Regenstatus: kein Regen
              Regen seit Regenbeginn:  mm
              Regen Stunde:  mm
              Regen Tag: 0 mm
              Regen Woche: 12.3 mm
              Regen Monat: 0 mm
              Regen Jahr: 0 mm
              Regen Gesamt:  mm
              Sonnenstrahlung: 0.00 W/m²
              UV-Index: 0
              Zeitstempel: 02.01.2021%2017:21:19
              Firmware: EasyWeatherV1.5.6
              Batteriestand::
              Gateway-Modell:
              Zusatzsensoren: keine
              P a200A 2 Antworten Letzte Antwort
              • P Petersilie
                Taupunkt: 1.38 °C
                max. Windböe:  km/h
                Windrichtung: 61 °
                Windrichtung: ONO
                Regenrate: 0 mm/h
                Regen Stunde:  mm
                Regen Tag: 0 mm
                Regen Monat: 0 mm
                Regen Jahr: 0 mm
                Regen Gesamt:  mm
                UV-Index: 0
                Batteriestand::
                Gateway-Modell:
                P
                P
                Petersilie
                #1920
                und so im ioBroker:
                a200A 1 Antwort Letzte Antwort
                • P Petersilie
                  Taupunkt: 1.38 °C
                  max. Windböe:  km/h
                  Windrichtung: 61 °
                  Windrichtung: ONO
                  Regenrate: 0 mm/h
                  Regen Stunde:  mm
                  Regen Tag: 0 mm
                  Regen Monat: 0 mm
                  Regen Jahr: 0 mm
                  Regen Gesamt:  mm
                  UV-Index: 0
                  Batteriestand::
                  Gateway-Modell:
                  a200A
                  a200A
                  a200
                  #1921
                  @Petersilie das ist noch etwas wenig. was unten kommt ist interessant. Dort kann man die Parameter sehen, die an IoBroker übertragen werden.
                  • P Petersilie
                    und so im ioBroker:
                    a200A
                    a200A
                    a200
                    #1922
                    und so im ioBroker:
                    und was an Außentemp stimmt jetzt nicht?
                    • a200A a200
                      P
                      P
                      Petersilie
                      #1923
                      @a200
                      javascript.0.Wetterstation.Innentemperatur=21.77&javascript.0.Wetterstation.Aussentemperatur=3.50&javascript.0.Wetterstation.Taupunkt=1.38&javas
                      cript.0.Wetterstation.Chillfaktor=3.50&javascript.0.Wetterstation.Innenfeuchtigkeit=55&javascript.0.Wetterstation.Aussenfeuchtigkeit=86&javascri
                      pt.0.Wetterstation.Wind=0&javascript.0.Wetterstation.Wind_max=0&javascript.0.Wetterstation.Windrichtung=61&javascript.0.Wetterstation.Druck_abso
                      lut=1003.42&javascript.0.Wetterstation.Druck_relativ=1003.42&javascript.0.Wetterstation.Regenrate=0&javascript.0.Wetterstation.Regen_Tag=0&javas
                      cript.0.Wetterstation.Regen_Woche=12.3&javascript.0.Wetterstation.Regen_Monat=0&javascript.0.Wetterstation.Regen_Jahr=0&javascript.0.Wetterstati
                      on.Sonnenstrahlung=0.00&javascript.0.Wetterstation.UV_Index=0&javascript.0.Wetterstation.Zeitstempel=02.01.2021%2017:21:19&javascript.0.Wetterst
                      ation.Info.FW_Version=EasyWeatherV1.5.6&javascript.0.Wetterstation.Regenstatus=kein Regen&javascript.0.Wetterstation.UV_Belastung=keine&javascri
                      pt.0.Wetterstation.Windrichtung_Text=ONO
                      GET /weatherstation/updateweatherstation.php?ID=xxxxxx&PASSWORD=xxxxxx&indoortempf=71.2&tempf=38.3&dewptf=34.5&windchillf=38.3&indoorhumidity=55
                      &humidity=86&windspeedmph=0.0&windgustmph=0.0&winddir=61&absbaromin=29.631&baromin=29.631&rainin=0.000&dailyrainin=0.000&weeklyrainin=0.488&mont
                      hlyrainin=0.000&yearlyrainin=0.000&solarradiation=0.00&UV=0&dateutc=2021-01-02%2016:21:19&softwaretype=EasyWeatherV1.5.6&action=updateraw&realti
                      me=1&rtfreq=5 HTTP/1.0
                      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
                      Hier gehts zur Hilfe.
                      • P Petersilie
                        @a200
                        a200A
                        a200A
                        a200
                        #1924
                        @Petersilie Das sieht doch gut aus. Und was in IoBroker steht passt dazu. Wo siehst du jetzt ein Problem?
                        • a200A a200
                          P
                          P
                          Petersilie
                          #1925
                          @a200 Das Problem ist, was davon im Grafana landet:
                          • P Petersilie
                            a200A
                            a200A
                            a200
                            schrieb am zuletzt editiert von a200
                            #1926
                            @Petersilie ok. Deine Datenbank hast du in Grafana eingebunden? Was steht unter: Configuration -> Data Sources
                            Sollte in etwa so aussehen:
                            Falls nicht, dann eine neue Datenquelle hinzufügen:
                            • a200A a200
                              P
                              P
                              Petersilie
                              #1927
                              @a200 Die Datenbank ist eingebunden und einige Werte werden ja auch angezeigt.
                              • P Petersilie
                                a200A
                                a200A
                                a200
                                #1928
                                @Petersilie wenn du jetzt in Grafana auf Außentemp klickst und dann auf Edit gehst:
                                sollte in etwa so aussehen. Prüfe die Bereiche.
                                • a200A a200
                                  P
                                  P
                                  Petersilie
                                  #1929
                                  @a200 danke für den Tipp. Scheint ein Grafana Problem mit dem kopierten Template zu sein. Wenn ich im Feld der Innentemperatur das Datenbankfeld der Aussentemperatur auswähle, wird die Aussentemperatur richtig angezeigt. Die Daten sind also da.
                                  Ist im Augenblick aber schwer zu beheben, da ich im Augenblick nur mein Android Tablet nutze. Mache deshalb morgen weiter. Schönen Abend!
                                  • P Petersilie
                                    a200A
                                    a200A
                                    a200
                                    #1930
                                    @Petersilie Wenn die Werte vorhanden sind, dann versuche mal mit reload der Seite.
                                    • SBorgS SBorg
                                      @All: Frohes Neues :)
                                      Hat mit zwei kleinen Fehllerchen perfekt funktioniert 😁
                                      1. beim Statistik-Addon wurden nicht alle Gradtage für 2020 archiviert. Leider hat hier der "Speicher-Bug" beim JS-Controller bei mir zugeschlagen und nicht alle Änderungen wurden im JS gespeichert. Ist mir nicht aufgefallen, erst jetzt durch den Fehler. Aber verschmerzbar, die Gradtage wurden sowieso erst seit einem Tag gesammelt. Extra Fix gibt es keinen, da es erst wieder in einem Jahr auftritt + es bis dahin eh ein neues Release gibt --> fixed in V0.1.7
                                      2. beim WLAN-Skript wurde die kumulierte Jahresregenmenge nicht genullt. Bitte den DP per Hand auf "0" setzen. Habe ich schlichtweg einfach vergessen und auch hier: extra Fix gibt es keinen, da es erst wieder in einem Jahr auftritt + es bis dahin eh ein neues Release gibt --> fixed in V2.1.0
                                      NegaleinN
                                      NegaleinN
                                      Negalein
                                      #1931
                                      @SBorg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                      Regen_Jahr wurde auch nicht genullt
                                      ° Fixer ---> iob fix
                                      • SBorgS
                                        SBorgS
                                        SBorg
                                        #1932
                                        @sonystar sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                        Die Trockenperiode im Jahr wurde auf "2" gesetzt und unter Rekordwerte wurde diese bei mir noch nie beschrieben. Ist das bei euch auch so?
                                        Muss bei allen so sein, zumindest wenn es dieses Jahr noch keinen Regenpuls gab.
                                        Entweder nähen nachts die Kleiderzwerge nicht nur die Klamotten enger und löschen was aus meinem Quellcode, oder der JS-Speicherbug hat auch da zugeschlagen. Die kpl. Routine fehlt schon seit etlichen Versionen... 😠
                                        Vorsichtig ausgedrückt krieg ich so langsam das kalte ko**en...
                                        ...als hätte ich ja sonst nix zu tun, aber bringt ja nix --> fixed in V0.1.7
                                        Kann ich nicht bestätigen:
                                        Stimmt bis auf die Rundungsfehler von WU ziemlich genau. Wenn du eine Influx-Abfrage fährst, daran denken, es handelt sich um eine Statistik, die Werte sind also nicht von Heute, sondern die "aktuellen" von Gestern, Vorgestern etc. ;)
                                        Eigentlich müsste ich "Werte von Gestern" genau genommen in "Werte von Vorgestern" ändern.
                                        LG SBorg ( SBorg auf GitHub)
                                        • NegaleinN Negalein
                                          SBorgS
                                          SBorgS
                                          SBorg
                                          #1933
                                          @Negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                          Der Wert (Regenmenge Jahr aus Station) ist auch nicht von mir, dass schickt die Station so und wird nur ausgelesen. Musst du also am Display resetten ;)
                                          84.2k
