  4. [gelöst] ROCK64 - Systemabstürze nach Neuinstallation
rock64 image
70 Beiträge 4 Kommentatoren 7.1k Aufrufe 3 Beobachtet
    @BlackTigga Gut!
    BlackTigga
    @Homoran bei iobroker setup custom erhalte ich am Ende folgende Fehlermeldung:
    Connecting to new DB "file" ...
    No connection to states 127.0.0.1:6379[redis]
    [New Database could not be connected. Please check your settings. No settings have been changed..]
    Ich vermute bei Host / Unix Socket of states DB (redis), default[127.0.0.1]: muss was angepasst werden.
    IP vom Rock?
    blacktigga@All-In-One-RasPi:~$ sudo iobroker setup custom
    Current configuration:
    - Objects database:
      - Type: file
      - Host/Unix Socket: 127.0.0.1
      - Port: 9001
    - States database:
      - Type: file
      - Port: 9000
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(f)ile, (r)edis], default [file]:
    Host / Unix Socket of objects DB(file), default[127.0.0.1]:
    Port of objects DB(file), default[9001]:
    Type of states DB [(f)file, (r)edis], default [file]: r
    When States are stored in a Redis database please make sure to configure Redis
    persistence to make sure a Redis problem will not cause data loss!
    Port of states DB (redis), default[6379]:
    Data directory (file), default[../../iobroker-data/]:
    Host name of this machine [All-In-One-RasPi]:
    This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
    Do you want to migrate objects and states from "file/file" to "file/redis" [y/N]: y
    Connecting to previous DB "file"...
    Creating backup ...
    This can take some time ... please be patient!
    host.All-In-One-RasPi 273 states saved
    host.All-In-One-RasPi 361 objects saved
    readFile will not read this file (css/vis-common-user.css) in future versions: vis is not an object of type "meta"
    Backup created: /opt/iobroker/backups/2021_01_01-17_30_19_backupiobroker-migration.tar.gz
    updating conf/iobroker.json
    [New Database could not be connected. Please check your settings. No settings have been changed.]
    restoring conf/iobroker.json
    B Thomas BraunT 2 Antworten Letzte Antwort
    • B BlackTigga
      IP vom Rock?
      - Objects database:
        - Type: file
        - Port: 9001
      - States database:
        - Type: file
        - Port: 9000
      Creating backup ...
      BlackTigga
      @Homoran ...wenn möglich, lösche bitte meinen vorherigen Beitrag
      https://forum.iobroker.net/topic/40289/rock64-systemabstürze-nach-neuinstallation/47
      • B BlackTigga
        IP vom Rock?
        - Objects database:
          - Type: file
          - Port: 9001
        - States database:
          - Type: file
          - Port: 9000
        Creating backup ...
        @BlackTigga Läuft der redis server?
          BlackTigga
          @Thomas-Braun 😖 ja genau das war das Problem
          • B BlackTigga
            @BlackTigga sagte in ROCK64 - Systemabstürze nach Neuinstallation:
            @Homoran OK. Hänge jetzt aber in einer "Sackgasse" fest....
            Versuche mich jetzt so daraus zu "befreien" um wieder an einen sinnvollen Startpunkt zu kommen:
            • Neuinstallation Armbian
            • Hostname festlegen auf "All-In-One-RasPi", damit später das Backup funktioniert
            • Benutzer anlegen und konsequent (!!) nutzen
            • Installation IoBroker
            • Installation redis-server (notwendig ja/nein ??)
            • IoBroker Backup durchführen
            • nach erfolgreichem Backup den Hostname in armbian-config auf "rock64" anpassen
            • abschließend iobroker host this ausführen
            Dann mache ich das wie oben beschrieben, außer
            • Hostname lasse ich jetzt bei All-In-One-Raspi, also keine Änderung des Hostnames, stört mich eigentlich auch nur geringfügig
            • redis-server installieren >> JA
            BlackTigga
            @Homoran @Thomas-Braun
            Habe nun eine neue SD Karte verwendet und wie nachfolgend vorbereitet:
            • IoBroker Wiederherstellung durchführen
            Funktioniert für 10-12 Stunden einwandfrei, aber dann stürzt IoBroker ab und ist nicht mehr erreichbar. Das ist jetzt schon zwei Mal genauso passiert.
            Auffälligkeiten:
            • Infos in der Konsole vor Systemabsturz : Usage of /: 6% of 29G
             ____            _       __   _  _
            |  _ \ ___   ___| | __  / /_ | || |
            | |_) / _ \ / __| |/ / | '_ \| || |_
            |  _ < (_) | (__|   <  | (_) |__   _|
            |_| \_\___/ \___|_|\_\  \___/   |_|
            Welcome to Armbian 20.11.3 Buster with Linux 5.9.14-rockchip64
            System load:   30%              Up time:       0 min
            Memory usage:  3% of 3.82G      IP:            192.168.178.123
            CPU temp:      51°C             Usage of /:    6% of 29G
            [ 0 security updates available, 22 updates total: apt upgrade ]
            Last check: 2021-01-01 10:37
            [ General system configuration (beta): armbian-config ]
            blacktigga@rock64:~$
            Welcome to GNU Parted! Type 'help' to view a list of commands.
            (parted) print
            Model: SD SE32G (sd/mmc)
            Disk /dev/mmcblk0: 31,9GB
            Sector size (logical/physical): 512B/512B
            Partition Table: msdos
            Disk Flags:
            Number  Start   End     Size    Type     File system  Flags
             1      16,8MB  31,6GB  31,6GB  primary  ext4
            • Infos in der Konsole nach Systemabsturz : Usage of /: 100% of 29G
             ____            _       __   _  _
            Welcome to Debian GNU/Linux 10 (buster) with Linux 5.9.14-rockchip64
            System load:   46%              Up time:       1 min
            CPU temp:      60°C             Usage of /:    100% of 29G
            Last login: Fri Jan  1 17:17:38 2021 from 192.168.178.114
            blacktigga@All-In-One-RasPi:~$ sudo parted
            GNU Parted 3.2
            Using /dev/mmcblk0
            (parted) print
            Disk Flags:
            (parted)
            Irgendetwas zerschießt weiterhin das System....
            Weitere Ideen? 🙄
            • B BlackTigga
              Auffälligkeiten:
               ____            _       __   _  _
              (parted) print
              Disk Flags:
               ____            _       __   _  _
              GNU Parted 3.2
              Using /dev/mmcblk0
              (parted) print
              Disk Flags:
              (parted)
              Weitere Ideen? 🙄
              @BlackTigga Wenn dir das root-Verzeichnis vollläuft kein Wunder.
              Schau mit
              ncdu
              oder
              du
              nach was da passiert.
              Die Partitionierung mit nur einer primären Partition ist auch ungewöhnlich. Macht der Installer von Armbian das so? Wundert mich.
              B 2 Antworten Letzte Antwort
                Schau mit
                ncdu
                oder
                du
                BlackTigga
                @Thomas-Braun sagte in ROCK64 - Systemabstürze nach Neuinstallation:
                Habe 1:1 das Armbian Image aufgespielt, ohne etwas zu verändern.
                • B BlackTigga
                  @BlackTigga
                  Ich bin ja kein Freund von Images. Ich würde wo es nur geht immer selber installieren.
                    Schau mit
                    ncdu
                    oder
                    du
                    BlackTigga
                    @Thomas-Braun
                    ncdu kann ich leider nicht nachinstallieren (mangels Platz), deswegen eine Datei mit Auswertung mit du
                    du.txt
                      @BlackTigga
                      Das meint er ja!
                      Armbian OS nennt er image
                      • B BlackTigga
                        @Thomas-Braun
                        du.txt
                        @BlackTigga
                        Hangel dich per
                        cd /
                        du -shx ./* | sort -h
                        durch den Verzeichnisbaum.
                          @BlackTigga
                          Hangel dich per
                          cd /
                          BlackTigga
                          @Thomas-Braun
                          blacktigga@All-In-One-RasPi:/opt/iobroker$ cd /opt/iobroker/backups
                          blacktigga@All-In-One-RasPi:/opt/iobroker/backups$ sudo du -shx ./* | sort -h
                          112K    ./2021_01_01-17_30_19_backupiobroker-migration.tar.gz
                          112K    ./2021_01_01-17_56_38_backupiobroker-migration.tar.gz
                          11M     ./iobroker_2020_12_26-05_00_10_StandardBackup_backupiobroker.tar.gz
                          11M     ./iobroker_2021_01_02-05_00_10_StandardBackup_backupiobroker.tar.gz
                          26G     ./historyDB_2021_01_02-05_00_25_backupiobroker.tar.gz
                          Übeltäter scheint historyDB zu sein, oder?
                          Und ich kann noch berichten, dass die täglichen BackUps um 5:00 Uhr durchgeführt werden und die beiden Abstürze jeweils kurz nach 5:00 Uhr passiert sind.
                          • B BlackTigga
                            @Thomas-Braun
                            @BlackTigga Ja, wenn die historyDB ganze 26 GB wegschnuckelt, dann wird es für das System mehr als eng und es hat dann keine Lust mehr...
                            Was ballerst du denn da alles rein?
                              BlackTigga
                              @Thomas-Braun
                              Ich aktiviere nur "History Daten" im BackItUp, weitere Einstellungen sind da ja nicht möglich, oder?
                              • B BlackTigga
                                @Thomas-Braun
                                @BlackTigga Ich meinte eigentlich, was alles in die HistoryDB reinläuft, dass die so ein dickes Backupfile generiert?
                                  Möglich, dass der Pfad falsch ist und dort auch die ganzen Backups der History noch mit drin sind?
                                  Thomas BraunT B 2 Antworten Letzte Antwort
                                    @Homoran @BlackTigga Könnte es sein, dass es da einen 'Kurzschluss' gibt und immer weiter das Backupfile mit sich selber gefüllt wird?
                                    Ich hab selber history nicht laufen und daher kein Gefühl wie dick die Datenbank da werden kann. Aber 26 GB in ein paar Stunden hört sich bei normaler Konfiguration unmöglich an.
                                      das ist was ich meinte!
                                      gab es schon paarmal
                                      EDIT:
                                      ich logge schon wirklich gewaltige Mengen, aber 26GB an einem Tag schaffe selbst ich nicht:
                                        BlackTigga
                                        @Homoran sagte in ROCK64 - Systemabstürze nach Neuinstallation:
                                        Der Pfad?
                                        • B BlackTigga
                                          Der Pfad?
                                          #66
                                          Der Pfad?
                                          Bingo!
                                          das ist nicht der offizielle Speicherpfad für History
                                          Diesen siehst du in meinem Filezilla Screenshot
