  4. [gelöst] ROCK64 - Systemabstürze nach Neuinstallation
rock64 image
70 Beiträge 4 Kommentatoren 7.1k Aufrufe 3 Beobachtet
  • B BlackTigga
    @Thomas-Braun
    Redis server v=5.0.3 sha=00000000:0 malloc=jemalloc-5.1.0 bits=64 build=1b271fe49834c463
    root@rock64:/home/blacktigga# iobroker list instances
    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0              : backitup              -  enabled
      system.adapter.daikin.0                : daikin                - disabled
      system.adapter.daikin.1                : daikin                - disabled
      system.adapter.daikin.2                : daikin                - disabled
      system.adapter.daswetter.0             : daswetter             - disabled
      system.adapter.discovery.0             : discovery             - disabled
      system.adapter.flot.0                  : flot                  - disabled
      system.adapter.gardena.0               : gardena               - disabled
      system.adapter.harmony.0               : harmony               - disabled
      system.adapter.history.0               : history               - disabled
      system.adapter.hm-rega.0               : hm-rega               - disabled
      system.adapter.hm-rega.1               : hm-rega               - disabled
      system.adapter.hm-rpc.0                : hm-rpc                - disabled, port: 0
      system.adapter.hm-rpc.1                : hm-rpc                - disabled, port: 0
      system.adapter.icons-material-png.0    : icons-material-png    - disabled
      system.adapter.icons-mfd-svg.0         : icons-mfd-svg         - disabled
      system.adapter.icons-ultimate-png.0    : icons-ultimate-png    - disabled
      system.adapter.info.0                  : info                  - disabled
      system.adapter.iot.0                   : iot                   - disabled
      system.adapter.javascript.0            : javascript            - disabled
      system.adapter.mobile.0                : mobile                - disabled
      system.adapter.modbus.0                : modbus                - disabled
      system.adapter.ping.0                  : ping                  - disabled
      system.adapter.pushover.0              : pushover              - disabled
      system.adapter.roomba.0                : roomba                - disabled
      system.adapter.roomba.1                : roomba                - disabled
      system.adapter.scenes.0                : scenes                - disabled
      system.adapter.shelly.0                : shelly                - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.socketio.0              : socketio              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sonoff.0                : sonoff                - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.sonos.0                 : sonos                 - disabled
      system.adapter.tr-064.0                : tr-064                - disabled
      system.adapter.vis-bars.0              : vis-bars              - disabled
      system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     - disabled
      system.adapter.vis-hqwidgets.0         : vis-hqwidgets         - disabled
      system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          - disabled
      system.adapter.vis-justgage.0          : vis-justgage          - disabled
      system.adapter.vis-map.0               : vis-map               - disabled
      system.adapter.vis-metro.0             : vis-metro             - disabled
      system.adapter.vis-plumb.0             : vis-plumb             - disabled
      system.adapter.vis-timeandweather.0    : vis-timeandweather    - disabled
      system.adapter.vis-weather.0           : vis-weather           - disabled
      system.adapter.vis.0                   : vis                   - disabled
      system.adapter.web.0                   : web                   - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    @BlackTigga sagte in ROCK64 - Systemabstürze nach Neuinstallation:
    root@rock64
    Schon wieder...
      root@rock64
      Schon wieder...
      BlackTigga
      @Thomas-Braun Ja, ich gelobe Besserung. Ich übe noch. Bin nach Installation nicht raus aus dem root....😕
      • B BlackTigga
        @BlackTigga
        Dann mach es jetzt. Und dann nie mehr als root rumgurken.
        • B BlackTigga
          du solltest nie etwas als root installieren, dann passen die Rechte nicht
            BlackTigga
            @Homoran OK. Hänge jetzt aber in einer "Sackgasse" fest....
            Versuche mich jetzt so daraus zu "befreien" um wieder an einen sinnvollen Startpunkt zu kommen:
            • Neuinstallation Armbian
            • Hostname festlegen auf "All-In-One-RasPi", damit später das Backup funktioniert
            • Benutzer anlegen und konsequent (!!) nutzen
            • Installation IoBroker
            • Installation redis-server (notwendig ja/nein ??)
            • IoBroker Backup durchführen
            • nach erfolgreichem Backup den Hostname in armbian-config auf "rock64" anpassen
            • abschließend iobroker host this ausführen
            HomoranH Thomas BraunT B 3 Antworten Letzte Antwort
            • B BlackTigga
              • war auf dem RasPi die verwaltung der states über Redis?
                • dann ja
              wenn du das mit backitup machst weiß ich nicht, ob das geht.
              manuell macht man ein iobroker stop, dann ein restore, dann iobroker host this, dann erst iobroker start.
              Hättest du die letzte Version noch zum spielen, hätte ich dort einfach mal ein iobroker host this probiert und ggf. den bereits falsch angelegten system.host gelöscht
              • B BlackTigga
                Offenbar ist deine Ur-Version mit redis aufgesetzt gewesen.
                (Wobei man sich halt schon die Frage stellen kann, warum? Wenn man sich nicht daran erinnert scheint ja keine Notwendigkeit dafür gegeben zu sein).
                  @Thomas-Braun sagte in ROCK64 - Systemabstürze nach Neuinstallation:
                  Wenn man sich nicht daran erinnert scheint es ja keine Notwendigkeit dafür gegeben zu sein
                  wenn man vor Jahrhunderten ein fertiges All-In-One-Image mit Redis genommen hatte, kann man sich vielleicht nur nicht mehr erinnern
                  Redis war bei schwächeren SBC notwendig um die I/O Vorgänge zu minimieren
                  Thomas BraunT B 2 Antworten Letzte Antwort
                    @Homoran
                    Okay, das war vor meiner Zeit... ;-D
                      @Homoran
                      @Homoran
                      Jepp!
                        BlackTigga
                        Ich bin vor ca. 2,5 Jahren mit den Standard Download Images (https://www.iobroker.net/#de/download) und einem Standard RasPi gestartet.
                        Aktiv habe ich da nichts mit Redis machen müssen. Bin dann irgendwann auf Rock64 umgestiegen, was nicht komplikationsfrei verlief und ich deshalb u.a. noch den Hostname All-In-One-RasPi mitschleppe. Beim fixen der Komplikationen kam ich dann das erste Mal aktiv in Kontakt mit Redis (https://forum.iobroker.net/topic/20866/umzug-raspberry-pi-3-modell-b-plus-nach-rock64/18). Es hat dann einfach funktioniert, und ich war froh.
                        • B BlackTigga
                          Da kann Redis noch in den Images gewesen sein.
                          Wenn du später immer Redis nachinstallieren musstest wird das sogar so gewesen sein.
                          Vor dem Backup müsste man dann die states wieder auf File umstellen, dann gibt es kein Problem.
                          Kannst du natürlich auch jetzt nochmal versuchen mit iobroker setup custom
                            BlackTigga
                            @Homoran sagte in ROCK64 - Systemabstürze nach Neuinstallation:
                            blacktigga@rock64:~$ iobroker setup custom
                            Current configuration:
                            - Objects database:
                              - Type: file
                              - Host/Unix Socket: 127.0.0.1
                              - Port: 9001
                            - States database:
                              - Type: redis
                              - Port: 6379
                            - Data Directory: ../../iobroker-data/
                            Type of objects DB [(f)ile, (r)edis], default [file]:
                            Host / Unix Socket of objects DB(file), default[127.0.0.1]:
                            Port of objects DB(file), default[9001]:
                            Type of states DB [(f)file, (r)edis], default [redis]:
                            Host / Unix Socket of states DB (redis), default[127.0.0.1]:
                            Port of states DB (redis), default[6379]:
                            Data directory (file), default[../../iobroker-data/]:
                            Host name of this machine [rock64]:
                            updating conf/iobroker.json
                            • B BlackTigga
                              - Objects database:
                                - Type: file
                                - Port: 9001
                              - States database:
                                - Type: redis
                                - Port: 6379
                              Jepp - die States sind auf Redis.
                              Du hättest in Zeile 4 vor dem <Enter> noch ein f setzen müssen, dann wäre das auf Fole umgestellt worden
                                @Homoran @BlackTigga
                                Oder halt auf redis belassen. Ist ja grundsätzlich kein Problem, wenn man sich dessen bewusst ist, dass die Datenbank halt auf redis läuft.
                                  korrekt!
                                  das spart -wie bereits geschrieben- einiges an I/O Operationen
                                  • B BlackTigga
                                    BlackTigga
                                    Dann mache ich das wie oben beschrieben, außer
                                    • Hostname lasse ich jetzt bei All-In-One-Raspi, also keine Änderung des Hostnames, stört mich eigentlich auch nur geringfügig
                                    • redis-server installieren >> JA
                                    HomoranH B 2 Antworten Letzte Antwort
                                    • B BlackTigga
                                      @BlackTigga Gut!
                                        @BlackTigga Gut!
                                        BlackTigga
                                        @Homoran
                                        Frage nebenbei:
                                        apt remove unattended-upgrades
                                        Sinnvoll ja/nein? Hatte ich irgendwo in einem Thread mal mitgeschnitten, bin mir aber nicht mehr sicher über das "Warum".
                                        HomoranH B Thomas BraunT Meister MopperM 4 Antworten Letzte Antwort
                                        • B BlackTigga
                                          @Homoran
                                          Frage nebenbei:
                                          Sinnvoll ja/nein?
                                          das kann ich nicht beantworten, mal @Thomas-Braun fragen
