  4. [Tablet Control] Tablet Steuerung möchte getestet werden
    6.6k
adapterfully kiosk browserfullybrowsertablettablet-controltesttesten
512 Beiträge 50 Kommentatoren 128.1k Aufrufe 71 Beobachtet
  • NashraN Nashra
    Moin, bei der Helligkeitssteuerung bekomme ich immer eine Error-Meldung wenn er umschalten soll
    2020-10-30 07:37:37.128 - info: host.ioBroker stopInstance system.adapter.fully-tablet-control.0 (force=false, process=true)
    2020-10-30 07:37:37.129 - info: host.ioBroker stopInstance system.adapter.fully-tablet-control.0 send kill signal
    2020-10-30 07:37:37.134 - info: fully-tablet-control.0 (15544) Got terminate signal TERMINATE_YOURSELF
    2020-10-30 07:37:37.135 - info: fully-tablet-control.0 (15544) Adapter Tablet Constrol stopped...
    2020-10-30 07:37:37.136 - info: fully-tablet-control.0 (15544) terminating
    2020-10-30 07:37:37.138 - info: fully-tablet-control.0 (15544) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2020-10-30 07:37:37.680 - info: host.ioBroker instance system.adapter.fully-tablet-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2020-10-30 07:37:40.222 - info: host.ioBroker instance system.adapter.fully-tablet-control.0 started with pid 16525
    2020-10-30 07:37:41.747 - info: fully-tablet-control.0 (16525) starting. Version 0.2.11 in /opt/iobroker/node_modules/iobroker.fully-tablet-control, node: v12.19.0, js-controller: 3.1.6
    2020-10-30 07:37:43.343 - error: fully-tablet-control.0 (16525) [stateRequest] : Cannot read property 'replace' of undefined, stack: TypeError: Cannot read property 'replace' of undefined
    at FullyTabletControl.stateRequest (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:565:34)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:110:3)
    2020-10-30 07:37:45.492 - error: fully-tablet-control.0 (16525) [stateRequest] : Cannot read property 'replace' of undefined, stack: TypeError: Cannot read property 'replace' of undefined
    at FullyTabletControl.dayBri (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:1357:12)
    IssiI Online
    IssiI Online
    Issi
    #329
    @Nashra welche Adapter Version und app Version?
    • IssiI Issi
      NashraN Offline
      NashraN Offline
      Nashra
      Most Active Forum Testing
      #330
      @Issi sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
      Adapter 0.2.11
      App 1.41
      Gruß Ralf
      IssiI 1 Antwort Letzte Antwort
      • NashraN Nashra
        Adapter 0.2.11
        App 1.41
        IssiI Online
        IssiI Online
        Issi
        #331
        @Nashra installiere bitte die neueste Adapter Version die api hat sich geändert und es gab einige Änderungen im Adapter
        • IssiI Issi
          NashraN Offline
          NashraN Offline
          Nashra
          #332
          Von Github installiert, Fehler weg, Danke 👍
          Gruß Ralf
          • jackblacksonJ Offline
            jackblackson
            #333
            Hallo! Ich versuche gerade, mein Tablet als "kleine Alarmanlage" aufzusetzen, das sobald Bewegung entsteht, ein Camshot gemacht wird. Ich habe es soweit geschafft aufzusetzen, das sobald ich auf das Object "Camshot" drücke, das Bild erstellt wird - Pfad aktualisiert sich. Nur funktioniert es nicht, wenn ich vorbeigehe. Weiß jemand, was ich hier noch aktivieren muss, das bei jeder erkannten Bewegung automatisch ein Camshot gemacht wird?
            • jackblacksonJ jackblackson
              IssiI Online
              IssiI Online
              Issi
              #334
              @jackblackson
              das wird nicht Funktionieren da der Fully Browser von sich aus keine screenshots bei Bewegung macht dafür habe ich jedenfalls keine Funktion gefunden.
              Die Funktion in dem Adapter wird auch nur dann aktualisiert wen man den button drückt da könnte man theoretisch eine Funktion machen wen Bewegung erkannt wird soll er ein Bild machen, aber da ist schon das nächste Problem man kann den Motion Status nicht abfragen ich kann nur Sechen, ob es an oder aus ist aber nicht den Status das gibt die API leider nicht her.
              jackblacksonJ 1 Antwort Letzte Antwort
              • IssiI Issi
                @jackblackson
                jackblackson
                #335
                @Issi ok..d.h. man würde einen extra Bewegungsmelder benötigen, der dann den Camshot auslöst..
                  crunchipC Offline
                  crunchipC Offline
                  #336
                  @jackblackson ja, ich habe es mit nem xiaomi Sensor und nem script laufen
                    jackblackson
                    #337
                    @crunchip Ok, gut zu wissen. Ich hab dem Entwickler von Fully mal geschrieben, er könnte es ja vermutlich ohne allzu großen Aufwand umsetzen, da er ja einerseits das Camshot Feature schon hat, und auch schon auf Bewegung reagiert.
                      jackblackson
                      #338
                      Hallo! Hab vor einigen Tagen die 0.3.0 beta 5 installiert, da ich Probleme mit dem Ladezyklus hatte - hat aber scheinbar mit etwas anderes zum tun. Da ist mir jetzt aber aufgefallen, dass der Vis-Wechsel nicht mehr funktioniert. Nutzt das sonst noch jemand, und es geht dort auch nicht?
                        IssiI Online
                        IssiI Online
                        Issi
                        #339
                        @jackblackson
                        also der Vis-Wechsel funktioniert bei mir habe auch die 0.3.0 beta 5 installiert.
                        ist deine Vis View Name groß geschrieben oder klein ?
                        • IssiI Issi
                          @jackblackson
                          jackblackson
                          #340
                          @jackblackson
                          So schaut die URL aus:
                          http://192.168.1.123:8082/vis/index.html?Lauterach1#Main
                            @jackblackson
                            IssiI Online
                            IssiI Online
                            Issi
                            #341
                            @jackblackson hmm dann sollte es funktionieren versuche mal die zeit runter zu stellen auf 60 oder 30 und schau unter fully-tablet-control.0.vis_View ob der state Timer_View_Switch runter zählt wen ja dann schau noch unter vis.0.control.command ob es sich ändert nach der zeit die eingestellt ist.
                            • IssiI Issi
                              jackblackson
                              #342
                              @Issi Danke, hab ich versucht. Es zählt runter, und am Ende werden auch Stati angepasst, aber leider wechselt er nicht. Das ist der Inhalt von vis.0.control.command. Sieht das so gut aus?
                              {"instance": "FFFFFFFF", "command": "changeView", "date": "Lauterach1/Main"}
                                IssiI Online
                                IssiI Online
                                Issi
                                schrieb am zuletzt editiert von Issi
                                #343
                                @jackblackson
                                nur mal so ne frage hat es den schon mal funktionirt ?
                                habe da nämlich ein fehler gefunden werde es versuchen morgen mit paar anderen sachen auf github hoch zuladen
                                der fehler ist in der {"instance": "FFFFFFFF", "command": "changeView", "--->date <---": "Lauterach1/Main"} solte so sein {"instance": "FFFFFFFF", "command": "changeView", "data": "Lauterach1/Main"}
                                jackblacksonJ Meister MopperM 2 Antworten Letzte Antwort
                                • IssiI Issi
                                  @jackblackson
                                  jackblackson
                                  #344
                                  @Issi Ja, es hat funktioniert, frag mich nicht..erst seit ich es neu installiert habe, und ein paar Versionen hoch gesprungen bin dadurch, geht es nicht mehr. Dann warte ich mal die neue Version ab - danke für deine Mühe!
                                  • IssiI Issi
                                    @jackblackson
                                    Meister MopperM Online
                                    Meister Mopper
                                    #345
                                    @Issi wollte mal die neueste Version testen und habe den alten Adapter komplett von meinem Testsystem entfernt. Die Installation des Adapters funktioniert jedoch nicht. Was bedeutet diese Fehlermeldung?
                                    Proxmox und HA ...
                                      IssiI Online
                                      IssiI Online
                                      Issi
                                      #346
                                      @Meister-Mopper
                                      Lehrzeichen in der Url mit kopiert
                                      • IssiI Issi
                                        @Meister-Mopper
                                        Meister Mopper
                                        #347
                                        @Issi genau, jetzt ist die Installation gelungen.
                                        Danke Dir 👍
                                        Proxmox und HA ...
                                          IssiI Online
                                          IssiI Online
                                          Issi
                                          #348
                                          @jackblackson
                                          Neue Version 0.3.1-Beta.0 ist auf Github und NPM verfügbar
                                          NPM: npm i iobroker.fully-tablet-control@0.3.1-beta.0
                                          GitHub: https://github.com/xXBJXx/ioBroker.fully-tablet-control
                                          Changes:
                                          • config Seite etwas überarbeitet > habe eine vorab Prüfung ob die Tablets, die in die Tabelle eingetragen wurden, auch erreichbar sind. Dazu muss der adapter laufen, wenn er nicht aktiviert ist kann man auch keine Konfiguration machen.
                                          • Prüfung, ob die Steckdose ein true oder eine 1 zum Schalten benötigt implementiert.
                                          • dependencies update
