  4. [Tablet Control] Tablet Steuerung möchte getestet werden
    6.6k
adapterfully kiosk browserfullybrowsertablettablet-controltesttesten
512 Beiträge 50 Kommentatoren 128.1k Aufrufe 71 Beobachtet
  • M michihorn
    Hallöchen, gibt es eine Chance Brightness manuell per Script zu ändern?
    Michael
    IssiI Online
    IssiI Online
    Issi
    #327
    Unter Punkt Nr 3 ist der dp dazu bitte die Beschreibung auf github lesen da ist alles beschrieben.
    • NashraN Offline
      NashraN Offline
      Nashra
      Most Active Forum Testing
      #328
      Moin, bei der Helligkeitssteuerung bekomme ich immer eine Error-Meldung wenn er umschalten soll
      2020-10-30 07:37:37.128 - info: host.ioBroker stopInstance system.adapter.fully-tablet-control.0 (force=false, process=true)
      2020-10-30 07:37:37.129 - info: host.ioBroker stopInstance system.adapter.fully-tablet-control.0 send kill signal
      2020-10-30 07:37:37.134 - info: fully-tablet-control.0 (15544) Got terminate signal TERMINATE_YOURSELF
      2020-10-30 07:37:37.135 - info: fully-tablet-control.0 (15544) Adapter Tablet Constrol stopped...
      2020-10-30 07:37:37.136 - info: fully-tablet-control.0 (15544) terminating
      2020-10-30 07:37:37.138 - info: fully-tablet-control.0 (15544) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-10-30 07:37:37.680 - info: host.ioBroker instance system.adapter.fully-tablet-control.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-10-30 07:37:40.222 - info: host.ioBroker instance system.adapter.fully-tablet-control.0 started with pid 16525
      2020-10-30 07:37:41.747 - info: fully-tablet-control.0 (16525) starting. Version 0.2.11 in /opt/iobroker/node_modules/iobroker.fully-tablet-control, node: v12.19.0, js-controller: 3.1.6
      2020-10-30 07:37:43.343 - error: fully-tablet-control.0 (16525) [stateRequest] : Cannot read property 'replace' of undefined, stack: TypeError: Cannot read property 'replace' of undefined
      at FullyTabletControl.stateRequest (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:565:34)
      at processTicksAndRejections (internal/process/task_queues.js:97:5)
      at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:110:3)
      2020-10-30 07:37:45.492 - error: fully-tablet-control.0 (16525) [stateRequest] : Cannot read property 'replace' of undefined, stack: TypeError: Cannot read property 'replace' of undefined
      at FullyTabletControl.dayBri (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:1357:12)
      Gruß Ralf
      IssiI 1 Antwort Letzte Antwort
      • NashraN Nashra
        IssiI Online
        IssiI Online
        Issi
        #329
        @Nashra welche Adapter Version und app Version?
        • IssiI Issi
          NashraN Offline
          NashraN Offline
          Nashra
          #330
          @Issi sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
          Adapter 0.2.11
          App 1.41
          Gruß Ralf
          • NashraN Nashra
            Adapter 0.2.11
            App 1.41
            IssiI Online
            IssiI Online
            Issi
            #331
            @Nashra installiere bitte die neueste Adapter Version die api hat sich geändert und es gab einige Änderungen im Adapter
            • IssiI Issi
              NashraN Offline
              NashraN Offline
              Nashra
              #332
              Von Github installiert, Fehler weg, Danke 👍
              Gruß Ralf
              • jackblacksonJ Offline
                jackblackson
                #333
                Hallo! Ich versuche gerade, mein Tablet als "kleine Alarmanlage" aufzusetzen, das sobald Bewegung entsteht, ein Camshot gemacht wird. Ich habe es soweit geschafft aufzusetzen, das sobald ich auf das Object "Camshot" drücke, das Bild erstellt wird - Pfad aktualisiert sich. Nur funktioniert es nicht, wenn ich vorbeigehe. Weiß jemand, was ich hier noch aktivieren muss, das bei jeder erkannten Bewegung automatisch ein Camshot gemacht wird?
                • jackblacksonJ jackblackson
                  IssiI Online
                  IssiI Online
                  Issi
                  #334
                  @jackblackson
                  das wird nicht Funktionieren da der Fully Browser von sich aus keine screenshots bei Bewegung macht dafür habe ich jedenfalls keine Funktion gefunden.
                  Die Funktion in dem Adapter wird auch nur dann aktualisiert wen man den button drückt da könnte man theoretisch eine Funktion machen wen Bewegung erkannt wird soll er ein Bild machen, aber da ist schon das nächste Problem man kann den Motion Status nicht abfragen ich kann nur Sechen, ob es an oder aus ist aber nicht den Status das gibt die API leider nicht her.
                  jackblacksonJ 1 Antwort Letzte Antwort
                  • IssiI Issi
                    @jackblackson
                    jackblackson
                    #335
                    @Issi ok..d.h. man würde einen extra Bewegungsmelder benötigen, der dann den Camshot auslöst..
                      crunchipC Offline
                      crunchipC Offline
                      #336
                      @jackblackson ja, ich habe es mit nem xiaomi Sensor und nem script laufen
                        jackblackson
                        #337
                        @crunchip Ok, gut zu wissen. Ich hab dem Entwickler von Fully mal geschrieben, er könnte es ja vermutlich ohne allzu großen Aufwand umsetzen, da er ja einerseits das Camshot Feature schon hat, und auch schon auf Bewegung reagiert.
                          jackblackson
                          #338
                          Hallo! Hab vor einigen Tagen die 0.3.0 beta 5 installiert, da ich Probleme mit dem Ladezyklus hatte - hat aber scheinbar mit etwas anderes zum tun. Da ist mir jetzt aber aufgefallen, dass der Vis-Wechsel nicht mehr funktioniert. Nutzt das sonst noch jemand, und es geht dort auch nicht?
                            IssiI Online
                            IssiI Online
                            Issi
                            #339
                            @jackblackson
                            also der Vis-Wechsel funktioniert bei mir habe auch die 0.3.0 beta 5 installiert.
                            ist deine Vis View Name groß geschrieben oder klein ?
                            • IssiI Issi
                              @jackblackson
                              jackblackson
                              #340
                              @jackblackson
                              So schaut die URL aus:
                              http://192.168.1.123:8082/vis/index.html?Lauterach1#Main
                                @jackblackson
                                IssiI Online
                                IssiI Online
                                Issi
                                #341
                                @jackblackson hmm dann sollte es funktionieren versuche mal die zeit runter zu stellen auf 60 oder 30 und schau unter fully-tablet-control.0.vis_View ob der state Timer_View_Switch runter zählt wen ja dann schau noch unter vis.0.control.command ob es sich ändert nach der zeit die eingestellt ist.
                                • IssiI Issi
                                  jackblackson
                                  #342
                                  @Issi Danke, hab ich versucht. Es zählt runter, und am Ende werden auch Stati angepasst, aber leider wechselt er nicht. Das ist der Inhalt von vis.0.control.command. Sieht das so gut aus?
                                  {"instance": "FFFFFFFF", "command": "changeView", "date": "Lauterach1/Main"}
                                    IssiI Online
                                    IssiI Online
                                    Issi
                                    schrieb am zuletzt editiert von Issi
                                    #343
                                    @jackblackson
                                    nur mal so ne frage hat es den schon mal funktionirt ?
                                    habe da nämlich ein fehler gefunden werde es versuchen morgen mit paar anderen sachen auf github hoch zuladen
                                    der fehler ist in der {"instance": "FFFFFFFF", "command": "changeView", "--->date <---": "Lauterach1/Main"} solte so sein {"instance": "FFFFFFFF", "command": "changeView", "data": "Lauterach1/Main"}
                                    jackblacksonJ Meister MopperM 2 Antworten Letzte Antwort
                                    • IssiI Issi
                                      @jackblackson
                                      jackblackson
                                      #344
                                      @Issi Ja, es hat funktioniert, frag mich nicht..erst seit ich es neu installiert habe, und ein paar Versionen hoch gesprungen bin dadurch, geht es nicht mehr. Dann warte ich mal die neue Version ab - danke für deine Mühe!
                                      • IssiI Issi
                                        @jackblackson
                                        Meister MopperM Online
                                        Meister Mopper
                                        #345
                                        @Issi wollte mal die neueste Version testen und habe den alten Adapter komplett von meinem Testsystem entfernt. Die Installation des Adapters funktioniert jedoch nicht. Was bedeutet diese Fehlermeldung?
                                        Proxmox und HA ...
                                          IssiI Online
                                          IssiI Online
                                          Issi
                                          #346
                                          @Meister-Mopper
                                          Lehrzeichen in der Url mit kopiert
