[Vorlage] Script für Sonos-Adapter
@Mic klar. das wären sie...
/******************************************************************************* * --------------------------- * SONOS-Script: Bietet diverse Zusatz-Funktionen zur Steuerung von SONOS-Geräten * mit dem SONOS-Adapter (https://github.com/ioBroker/ioBroker.sonos). * --------------------------- * Quelle: https://github.com/Mic-M/iobroker.sonos-script * Autor: Mic (ioBroker) | Mic-M (github) * Support: https://forum.iobroker.net/topic/24743/ * Change log: * 1.2 + Use new Sonos adapter state (since 2.0.0, pull request 55) 'favorites_list_array' to allow comma * in favorite name, see https://github.com/ioBroker/ioBroker.sonos/pull/55 * + Replaced state 'customFavoriteList' with 'customFavoriteListArray', to allow semicolon in fav name * 1.1 + On script start, push all Sonos favorites into custom favorites initially * 1.0 + Major release, added several additional functions and improvements * 0.3 + Create states for each Sonos device automatically * + New state 'allStop' to stop all Sonos devices * 0.2 - Fix: added missing function isLikeEmpty() * 0.1 - initial version ******************************************************************************/ /**************************************************************************************** * Einstellungen: Allgemein ****************************************************************************************/ // Datenpunkt-Pfad, unter dem die entsprechenden Script-Datenpunkte angelegt werden. const SCRIPT_STATE_PATH = 'javascript.'+ instance + '.' + 'Sonos'; // Instanz des SONOS-Adapters. Standard ist 0. const SONOS_ADAPTER_INSTANCE = 0; /**************************************************************************************** * Einstellungen: Favoriten-Liste für VIS ****************************************************************************************/ // Favoriten-Liste: alphabetisch sortieren? true = ja, false = nein const SORT_LIST = true; // Favoriten-Liste: Den Favoriten eine fortlaufende Nummer voranstellen (1, 2, 3, ...)? const LIST_NO_ADD = true; // auf false setzen, wenn nicht gewünscht. const LIST_NO_SEP = '. ' // Trennzeichen nach der Nummer. Gilt nur, wenn LIST_NO_ADD = true gesetzt. // Favoriten-Liste: CSS-Bezeichnungen. Kann man einfach so stehen lassen. const CSS_CURRENT_SEL = 'currentSonosFavorite'; // CSS-ID für die aktuelle Auswahl const CSS_FAVORITE_ELEM = 'favoriteSonosTitle' // CSS-Klasse für jeden Eintrag der Liste /**************************************************************************************** * Einstellungen: 'favoritesPlayPrevious' und 'favoritesPlayNext' ****************************************************************************************/ // Normalerweise wird bei Klicken auf Datenpunkt favoritesPlayNext/favoritesPlayPrevious // der nächste/vorherige Favorit lt. SONOS-App abgespielt. Wir können dies aber hiermit // alphabetisch sortieren, so dass der nächste/vorherige lt. Alphabet gespielt wird. // true = alphabetisch sortieren, false = nicht alphabetisch sortieren const FAVORITES_PLAY_PREV_NEXT_SORT = true; /**************************************************************************************** * Einstellungen: Buttons volumeUp/volumeDown zum erhöhen/verringern der Lautstärke ****************************************************************************************/ // um wie viel % wird erhöht/verringert beim klicken auf volumeUp/volumeDown? const VOL_VALUE = 3; // Maximale Lautstärke in %, mehr wird nicht erhöht. const MAX_VOLUME = 80; /**************************************************************************************** * Einstellungen: Beim Abspielen immer Sonos-Geräte als Gruppe hinzufügen ****************************************************************************************/ // Hiermit kann man Sonos-Geräte definieren, zu denen immer beim Abspielen weitere Geräte // als Gruppe hinzugefügt werden. // Zum Einschalten: auf true setzen. const GROUP_ON_PLAY = false; // Falls GROUP_ON_PLAY = false, fann kann man folgendes ignorieren. // Es können beliebig viele Zeilen hinzugefügt werden. // channelMain: Hier den Channel des 1. Gerätes eintragen, also die IP, aber "_" statt Punkt, also z.B. '192_168_10_12' // channelsToAdd: Hier Geräte eintragen, welche zum ersten Gerät als Gruppe hinzugefügt werden sollen // Außerdem unter volumeAdjust das Volumen gegenüber dem channelMain nach oben oder unten anpassen. const GROUP_ON_PLAY_DEVICES = [ {channelMain: '192_168_1_111', channelsToAdd: [{channel:'192_168_1_110', volumeAdjust:-3}]}, {channelMain: '192_168_1_111', channelsToAdd: [{channel:'192_168_10_25', volumeAdjust:-2}, {channel:'192_168_10_26', volumeAdjust:0}]}, ]; /**************************************************************************************** * Einstellungen: Sonstige ****************************************************************************************/ // Standard-Lautstärke beim Starten mit customFavoritesPlay / .customFavoritesPlayG const PRESET_VOLUME = 15; // Ein paar Infos im Log anzeigen? const LOG_INFO = true; /************************************************************************************************************************* * Das war es auch schon. Ab hier nichts mehr ändern! *************************************************************************************************************************/ /**************************************************************************************** * Global variables and constants ****************************************************************************************/ // Alle Sonos-States (Geräte) in Array, also z.B. ['sonos.0.root.192_168_0_12', 'sonos.0.root.192_168_0_13'] const SONOS_CHANNELS = getAllSonosChannels(SONOS_ADAPTER_INSTANCE); /**************************************************************************************** * Initialize ************************************************************ -
@aca_home
Die Fehlermeldungen sagen mir leider nichts. Am besten schreibst du mal genauer, wie du vorgegangen bist, und auch die Versionen (VIS, ioBroker etc.) die du einsetzt. Dann kann man das ggf. besser nachvollziehen. -
Hallo
Erstmal vielen Dank für diese Vorlage.
Ich bin noch nicht all zu lange bei iobroker und meine JS-kenntnisse reichen um das grobe drumrum etwas zu blicken. Trotzdem versuche viel selber zu machen oder halt vorlagen nach meinem Geschmack und in meinem Rahmen anzupassen.
Nachdem ich das Script gesehen habe musste ich feststellen das ich das so wohl nie alleine hinbekommen hätte.Hat alles wunderbar geklappt und ich bastele schon um es in meine View zu bekommen.
Nun habe ich aber eine Anfrage/Wunsch/Verbesserungsvorschlag:
Und zwar mag der rest meines Haushalts es gerne Klickibunti.
Von meiner vorherigen Version waren meine Leute Senderpiktogramme bzw. Albumcover gewohnt die sie nur antippen mussten, so wie hier die eintrage in der Favoritenliste.
Die Schaltflächen funktionieren jetzt natürlich auch noch
Besteht die möglichkeit die Liste mit Covers oder Senderlogos zu versehen, oder gar wie im angefügten Bild nebeneinander darstellen zu lassen, evtl. auch so einfach austauschbar wie bei der Liste?
Würde mich freuen wenn mein Anliegen interessen finden, und umgesetzt werden könnte.
MFG Wobbix
Hallo
MFG Wobbix
@wobbix
Danke für dein Feedback.
Ich bin derzeit mit anderen Entwicklungsprojekten beschäftigt, vor allem: https://forum.iobroker.net/post/443727Mein Plan ist, das Script in einen Adapter zu überführen, sobald ich dafür Zeit habe.
Bis dahin ist jeder willkommen, das Script weiter zu entwickeln ;-)Für etwaige Enhancements / Feature Requests bitte am besten hier ein Issue eintragen, kann gerne auch in Deutsch sein und copy/paste oder Link zu einem Forum Post. https://github.com/Mic-M/iobroker.sonos-script/issues
Hey,
erst einmal vielen Dank für das Script!
Bei mir funktioniert die Fav-Liste perfekt, allerdings werden die Buttons für Play, pause, Group etc. nicht angezeigt.
Woran könnte das liegen?
@stockics6
ich habe gerade das Skript als auch das VIS Projekt importiert... Leider habe ich das gleiche Problem. Die Buttons werden nicht angezeigt...Gibt es eine Lösung hierfür?
Danke! -
Danke für dieses Script, irgendwie läuft es bei mir aber noch nicht wie Sinne des Erfinders
Im Log taucht dieser Fehler auf:
sonos.0 2020-12-18 15:10:38.561 info (5226) try to control id sonos.0.root.192_168_200_150.group_volume with {"val":20,"ack":false,"ts":1608300638556,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1608300638556}Kann mir jemand weiterhelfen?
Hallo Mic,
Ich kann kein Wort Deutsch und habe dies alles über Google Übersetzer durchgeführt, um meine Frage zu stellen. Ich entschuldige mich dafür.
Ich denke, das haben Sie gemacht, um die Sonos in iobroker zu steuern, sehr nett. und würde dies gerne selbst nutzen. Ich habe das Skript auch ordentlich in js in meinem iobroker abgelegt und ausgeführt. Ich habe das Fischprojekt auch ordentlich als Projekt genutzt.
Ich sehe auch alles ordentlich und kann die Lautstärke hoch und runter drehen und ein- und ausschalten.
Ich sehe auch das Logo des ausgewählten Radios. Ich denke, das alles ist auch gut gelaufen.
Nur ich sehe nichts im Favoritenbereich. Ich denke, das Skript funktioniert nicht richtig, da ich die Datenpunkte, von denen Sie ein Bild in der Erklärung des Installationsskripts platziert haben, nicht finden kann.Ich bin noch neu bei iobroker und habe noch viel zu lernen. Ich denke, ich habe den Skript-Teil gut gemacht, aber ich befürchte, dass etwas nicht stimmt.
Kannst du mir dabei weiter helfen, damit alles richtig funktioniert?
Vielleicht gibt es mehr Leute, die darauf stoßen. und es könnte schön sein, wenn Sie es in kleinen Schritten erklären.Mit freundlichen Grüßen,
chris -
Hallo Mic,
chris@chris-nij
Wenn ich mich recht erinnere, dann werden die Favoriten ausschließlich in der SONOS-App angelegt und verwaltet.
Der Adapter und das Script holen sich diese Informationen aus der App.Also müssen die Favoriten zunächst in der original SONOS-App verfügbar sein.
Hallo Mic,
chris@chris-nij
hi chris, to make sure that mic gets a message about your contribution you have to put an @ in front of his name. -
@ Hallo BBtown,
Ich habe meine Favoriten in der Sonos App. nur ich sehe sie nicht.
hat ein Foto hinzugefügt, wie es jetzt aussieht.
Ich hoffe du kannst mir weiter helfen.@michmein danke für deine erklärung. Das wusste ich nicht.
Viele Grüße und ein gesundes 2021
@ Hallo BBtown,
@chris-nij said in [Vorlage] Script für Sonos-Adapter:
@ Hallo BBtown,
@ Hallo BBtown,
@chris-nij In deinem Screenshot kann ich sowohl in der "Favorites List" als auch im "Favorites Array" Einträge sehen. Also sind deine Favoriten vorhanden 👍
@Mic
Hi,kaum macht man es richtig, geht es auch.
Ja, das mit dem Stift ist nicht so wirklich intuitiv, der ist mir gar nicht aufgefallen und hatte ich auch nirgends gelesen. Kaum drauf geklickt, und schon waren sie da.
Nun teste ich aber dennoch die neue Version, man will ja up to date bleiben. Dickes Danke!Gruss, Jürgen
EDIT: Läuft. Datenpunkte gelöscht, Skript aktualisiert und neu gestartet und alles da, wie ich es ursprünglich dachte. TOP
@Wildbill sagte in [Vorlage] Script für Sonos-Adapter:
Wo kann ich die Datenpunkte finden/löschen?
@BlackTigga sagte in [Vorlage] Script für Sonos-Adapter:
@Mic @Wildbill
Hat sich erledigt, steht ja im Kopf des Skriptes.
Habt ihr eine Idee, warum bei mir nur ein Datenpunkt erzeugt wird?
@Mic @Wildbill
@BlackTigga Bei mir das gleiche Bild
Hast du schon eine Lösung gefunden? -
Hast du schon eine Lösung gefunden?@leuchtturm Leider nein.
Aber interessant ist, dass es grundsätzlich funktioniert außer die Funktionalitäten mit der Favoritenliste. Das sieht bei mir so aus:
Und da weiß ich jetzt halt nicht, ob das mit den fehlenden Datenpunkten zusammenhängt?
@BlackTigga
Auch hier das gleiche Bild bei mir.
Da die VIew auf die Datenpunkte verlinkt,
Hast du sicherlich Recht.
