  5. Fenster und andere Geräte zählen opt. Alexa Ansagen
    6.6k
blocklyjavascript
1.2k Beiträge 41 Kommentatoren 493.9k Aufrufe 71 Beobachtet
  • Stephan SchleichS Stephan Schleich
    @dslraser Batterie Prozent:
      "fritzdect.0.Comet_133560281368": {
        "type": "channel",
        "common": {
          "name": "Wohnzimmer Comet DECT",
          "role": "thermo.heat"
        "native": {
          "aid": "133560281368"
        "from": "system.adapter.fritzdect.0",
        "user": "system.user.admin",
        "ts": 1601731472046,
        "_id": "fritzdect.0.Comet_133560281368",
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
      "fritzdect.0.Comet_133560281368.actualtemp": {
        "type": "state",
        "common": {
          "name": "Actual Temp",
          "type": "number",
          "unit": "°C",
          "role": "value.temperature",
          "desc": "Actual Temp",
          "read": true,
          "write": false
        "native": {},
        "ts": 1601731472052,
        "_id": "fritzdect.0.Comet_133560281368.actualtemp",
        "acl": {
          "object": 1636,
          "state": 1636
      "fritzdect.0.Comet_133560281368.battery": {
        "type": "state",
        "common": {
          "name": "Comet Dect Wohnzimmer - Battery",
          "type": "number",
          "unit": "%",
          "read": true,
          "write": false,
          "role": "value.battery",
          "desc": "Battery",
          "enums": [
              "_id": "enum.functions.batterie_prozent",
              "common": {
                "name": "Batterie_Prozent",
                "icon": "data:image/png;base64,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",
                "color": false
        "native": {},
        "ts": 1601731472053,
        "_id": "fritzdect.0.Comet_133560281368.battery",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.batterylow": {
        "type": "state",
        "common": {
          "name": "low Battery",
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "indicator"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.batterylow",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.comfytemp": {
        "type": "state",
        "common": {
          "name": "Comfort Temp",
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": false,
          "desc": "Comfort Temp"
        "native": {},
        "ts": 1601737946327,
        "_id": "fritzdect.0.Comet_133560281368.comfytemp",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.devicelock": {
        "type": "state",
        "common": {
          "name": "Thermostat Button lock",
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "indicator"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.devicelock",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.errorcode": {
        "type": "state",
        "common": {
          "name": "errorcode",
          "type": "number",
          "read": true,
          "write": false,
          "role": "indicator"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.errorcode",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.fwversion": {
        "type": "state",
        "common": {
          "name": "FW version",
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
          "desc": "firmware version"
        "native": {},
        "ts": 1601731472049,
        "_id": "fritzdect.0.Comet_133560281368.fwversion",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.holidayactive": {
        "type": "state",
        "common": {
          "name": "Product Name",
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "indicator",
          "desc": "Product Name"
        "native": {},
        "ts": 1601731472054,
        "_id": "fritzdect.0.Comet_133560281368.holidayactive",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.id": {
        "type": "state",
        "common": {
          "name": "ID",
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
          "desc": "ID"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.id",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.lasttarget": {
        "type": "state",
        "common": {
          "name": "last setting of target temp",
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": false,
          "desc": "last setting of target temp"
        "native": {},
        "ts": 1601731472051,
        "_id": "fritzdect.0.Comet_133560281368.lasttarget",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.lock": {
        "type": "state",
        "common": {
          "name": "Thermostat UI/API lock",
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "indicator"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.lock",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.manufacturer": {
        "type": "state",
        "common": {
          "name": "Manufacturer",
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
          "desc": "Manufacturer"
        "native": {},
        "ts": 1601731472050,
        "_id": "fritzdect.0.Comet_133560281368.manufacturer",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.mode": {
        "type": "state",
        "common": {
          "name": "Thermostat operation mode (0=auto, 1=closed, 2=open)",
          "type": "number",
          "read": true,
          "write": true,
          "role": "value",
          "min": 0,
          "max": 2,
          "desc": "Thermostat operation mode (0=auto, 1=closed, 2=open)"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.mode",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.name": {
        "type": "state",
        "common": {
          "name": "Name",
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
          "desc": "Name"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.name",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.nighttemp": {
        "type": "state",
        "common": {
          "name": "Night Temp",
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": false,
          "desc": "Night Temp"
        "native": {},
        "ts": 1601737946329,
        "_id": "fritzdect.0.Comet_133560281368.nighttemp",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.operationList": {
        "type": "state",
        "common": {
          "name": "List of operation modes",
          "type": "string",
          "read": true,
          "write": false,
          "desc": "List of operation modes"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.operationList",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.operationMode": {
        "type": "state",
        "common": {
          "name": "Current operation mode",
          "type": "string",
          "read": true,
          "write": false,
          "desc": "Current operation mode"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.operationMode",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.present": {
        "type": "state",
        "common": {
          "name": "Device present",
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "indicator.connected",
          "desc": "Device present"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.present",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.prodname": {
        "type": "state",
        "common": {
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.prodname",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.summeractive": {
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": false,
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.summeractive",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.targettemp": {
        "type": "state",
        "common": {
          "name": "Target Temp",
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": true,
          "desc": "Target Temp"
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.targettemp",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Comet_133560281368.temp": {
        "type": "state",
        "common": {
          "name": "actual Temp",
          "type": "number",
          "unit": "°C",
          "desc": "actual Temp",
          "read": true,
          "write": false
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.temp",
        "acl": {
          "object": 1636,
          "state": 1636
      "fritzdect.0.Comet_133560281368.temp_offset": {
        "type": "state",
        "common": {
          "name": "Temp Offset",
          "type": "number",
          "unit": "°C",
          "desc": "Temp Offset",
          "read": true,
          "write": false
        "native": {},
        "_id": "fritzdect.0.Comet_133560281368.temp_offset",
        "acl": {
          "object": 1636,
          "state": 1636
      "fritzdect.0.Comet_133560281368.windowopenactiv": {
        "type": "state",
        "common": {
          "name": "Window open",
          "type": "boolean",
          "read": true,
          "write": false,
          "desc": "Window open"
        "native": {},
        "ts": 1601731472058,
        "_id": "fritzdect.0.Comet_133560281368.windowopenactiv",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.GuestWLAN": {
        "_id": "fritzdect.0.GuestWLAN",
        "type": "channel",
        "common": {
          "name": "GuestWLAN",
          "role": "switch"
        "native": {},
        "acl": {
          "object": 1636,
      "fritzdect.0.GuestWLAN.state": {
        "_id": "fritzdect.0.GuestWLAN.state",
        "type": "state",
        "common": {
          "name": "GuestWLAN  on/off",
          "type": "boolean",
          "role": "switch",
          "read": true,
          "write": true,
          "desc": "GuestWLAN  on/off"
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5": {
        "type": "channel",
        "common": {
          "name": "Wohnzimmer",
        "native": {
          "aid": "grpDAF0E0-3BA5A8CF5"
        "ts": 1601731472626,
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5",
        "acl": {
          "object": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.actualtemp": {
        "type": "state",
        "common": {
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": false,
        "native": {},
        "ts": 1601731472630,
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.actualtemp",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.batterylow": {
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "indicator"
        "native": {},
        "ts": 1601731472631,
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.batterylow",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.comfytemp": {
        "type": "state",
        "common": {
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": false,
        "native": {},
        "ts": 1601731472629,
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.comfytemp",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.devicelock": {
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "indicator"
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.devicelock",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.errorcode": {
        "type": "state",
        "common": {
          "type": "number",
          "read": true,
          "write": false,
          "role": "indicator"
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.errorcode",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.fwversion": {
        "type": "state",
        "common": {
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
        "native": {},
        "ts": 1601731472627,
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.fwversion",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.holidayactive": {
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": false,
        "native": {},
        "ts": 1601731472632,
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.holidayactive",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.id": {
        "type": "state",
        "common": {
          "name": "ID",
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
          "desc": "ID"
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.id",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.lasttarget": {
        "type": "state",
        "common": {
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": false,
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.lasttarget",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.lock": {
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "indicator"
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.lock",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.manufacturer": {
        "type": "state",
        "common": {
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
        "native": {},
        "ts": 1601731472628,
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.manufacturer",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.masterdeviceid": {
        "type": "state",
        "common": {
          "name": "masterdeviceid",
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
          "desc": "masterdeviceid"
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.masterdeviceid",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.members": {
        "type": "state",
        "common": {
          "name": "members",
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
          "desc": "members"
        "native": {},
        "ts": 1601731472636,
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.members",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.mode": {
        "type": "state",
        "common": {
          "type": "number",
          "read": true,
          "write": true,
          "role": "value",
          "min": 0,
          "max": 2,
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.mode",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.name": {
        "type": "state",
        "common": {
          "name": "Name",
          "type": "string",
          "read": true,
          "write": false,
          "role": "text",
          "desc": "Name"
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.name",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.nighttemp": {
        "type": "state",
        "common": {
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": false,
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.nighttemp",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.operationList": {
        "type": "state",
        "common": {
          "type": "string",
          "read": true,
          "write": false,
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.operationList",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.operationMode": {
        "type": "state",
        "common": {
          "type": "string",
          "read": true,
          "write": false,
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.operationMode",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.present": {
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": false,
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.present",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.summeractive": {
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": false,
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.summeractive",
        "acl": {
          "object": 1636,
          "state": 1636,
      "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.targettemp": {
        "type": "state",
        "common": {
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": true,
        "native": {},
        "_id": "fritzdect.0.Hgroup_grpDAF0E0-3BA5A8CF5.targettemp",
        "acl": {
          "object": 1636,
          "state": 1636,
    sigi234S Online
    sigi234S Online
    #1150
    @Stephan-Schleich
    Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    • dslraserD dslraser
      @sigi234 sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
      @dslraser
      Wie ist der Stand für Türen und Fenster?
      @Sequal @FuXXz2 @Mr-Robot @DocGame @MartyBr
      Fenster habe ich eben eingefügt. Bitte testen. Keine Ahnung ob ich alle Optionen schon korrekt drinn hab.
      (Dieses Blockly ist auf Grund der ganzen HTML Optionen und wegen der Anzeige Fenster gekippt/geöffnet(geschlossen recht groß geworden)
      https://forum.iobroker.net/post/530382
      Wenn das von einigen getestet wurde und alles laufen sollte mache ich dann das Türen Blockly.
      Sequal
      #1151
      @dslraser said in Fenster und andere Geräte zählen opt. Alexa Ansagen:
      Das Fensterblockly läuft 1A. Ich beschäftige mich gerade damit wie ich die "Hausansage" entfernen kann :)
      Sequal
      • S Sequal
        Sequal
        dslraserD Offline
        dslraserD Offline
        dslraser
        #1152
        @Sequal sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
        Sequal
        In diesen beiden Funktionen....
        in den beiden Funktionen jeweils
        und in der Funktion main
          Sequal
          Sequal
          #1153
          @dslraser
          super, danke.....alles hatte ich noch nicht gefunden. Aber das sollte ich hinkriegen.
          Eine Frage hab ich gleich noch: Im Alias-Script hast Du die Dreh-Kipp-Sensoren für Türen (0,1,und 2 im Zustand) in die Fenster_alias gelegt.
          //2 x Fensterdrehgriffe HMIP
          //HMIP Fensterdrehgriffe über rpc-Adapter in function fenster_alias
          //{0: 'geschlossen', 1: 'gekippt', 2: 'geöffnet'}
          Können die auch in tueren_alias oder kommt dann das Türen-Blockly durcheinander, wenn es fertig ist? Im Fensterscript läuft es prima. An einer Tür hab ich diesen Sensor, zwar kein IP sondern normal RF, aber es wäre "hübscher" wenn die Terrassentür auch in die Türenliste kann.
          Sequal
          • S Sequal
            @dslraser
            Sequal
            dslraserD Offline
            dslraserD Offline
            dslraser
            #1154
            ist eigentlich da auch drinn. Geht denn was nicht ?
            • S Sequal
              @dslraser
              Sequal
              dslraserD Offline
              dslraserD Offline
              dslraser
              #1155
              @Sequal
              ach Du meinst im alias ? Da kannst Du es auch einfügen. (meine Vorlage für alias sollte nur als Beispiel dienen.)
              • dslraserD Offline
                dslraserD Offline
                dslraser
                #1156
                Versionen 1.6.4 in den ersten Beitrag geladen.
                https://forum.iobroker.net/post/273896
                Ich habe bei allen Listen für die Sprachausgabe auf Semikolon als Trennung umgestellt. (Um das 250 Zeichen Limit in speak zu umgehen)
                  @Sequal
                  Sequal
                  #1157
                  @Sequal
                  Ich versuche halt noch alle Zusammenhänge zu verstehen ;) Es funktioniert jetzt alles bestens!
                    sigi234S Online
                    sigi234S Online
                    #1158
                    @dslraser sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
                    Link Falsch?
                    • sigi234S sigi234
                      Link Falsch?
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      #1159
                      Link Falsch?
                      wieso ? (ist der erste Beitrag)
                      Edit:
                      • dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #1160
                        ich habe im ersten Beitrag Batterien_Prozent Version 1.6.4 im Spoiler Blockly Exporte eingefügt.
                          Link Falsch?
                          Edit:
                          sigi234S Online
                          sigi234S Online
                          #1161
                          Link Falsch?
                          Edit:
                          Jupp geht.
                            DocGame
                            #1162
                            Die Batterie in Prozentanzeige funktioniert soweit (Muss noch etwas die Namen der States anpassen). Was mir aufgefallen ist:
                            Könnte man die Spalte der Werte etwas Breiter machen? Bei einer Nachkommastelle gibt es sonst einen Zeilenumbruch
                            • D DocGame
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #1163
                              @DocGame
                              ich schau mal (Die Breite passt sich selbst an. Ich schau mal das ich den Zeilenumbruch verbieten kann)
                              • D DocGame
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #1164
                                @DocGame
                                Das passiert bei mit nur wenn der Geräte Name so lang ist, also wenn es einen Zeilenumbruch bei einem Gerät mit Kommastelle gibt, dann wird alles mit Kommastelle umgebrochen.
                                  Versionen 1.6.7
                                  aktualisiert am 23.12.2020
                                  Typ Blockly mit JavaScript Funktionen
                                  verwendete Adapter je nach dem was im Blockly aktiviert ist
                                  verwendete Geräte verschieden - gemischt
                                  was kann das Blockly wird hier beschrieben
                                  Hallo Zusammen.
                                  Ich stelle hier mein Blockly zum Geräte zählen und optional zum Ansagen über den Alexa2 Adapter über speak, sowie optionaler Versand über Telegram / E-Mail zur Verfügung.
                                  Das gesamte Blockly nutzt "alias'e". Alle anderen benötigten Datenpunkte erstellt und löscht das Blockly selbst, je nach dem was verwendet werden soll.
                                  Wer also keine alias erstellen oder nutzen möchte kann an dieser Stelle aufhören zu lesen, für alle anderen Interessierten versuche ich möglichst genau zu beschreiben was zu tun ist.
                                  Mit Alexa geht dann z.B.
                                  • Alexa, welche Fenster sind noch auf
                                  • Alexa, welche Türen sind noch auf
                                  • Alexa, welche Steckdosen sind noch an
                                  • Alexa, welche Lampen sind noch an
                                  • Alexa, was machen die Batterien
                                  • Alexa, welche Bewegungsmelder sind aktiv
                                  • Alexa, wie sind die Temperaturen (Ansage, aller Temperaturen meiner Räume und Außentemperatur nacheinander in einer Ansage)
                                  Welche Frage in welcher Formulierung gestellt wird bestimmt Ihr natürlich selbst, da dies über eine Routine in der Alexa App gesteuert wird. Dazu später mehr.
                                  Ein Hinweis gleich noch zu Beginn. Da die Ansage am angesprochenen ECHO erfolgen soll, kann es vorkommen, das, wenn es mehrere ECHO's in Hörweite gibt, die Ansage an einem anderen ECHO ausgegeben wird, weil sich ein anderer ECHO "angesprochen fühlt". Wenn ich in einem Raum bin, wo mich nur ein ECHO hören kann, funktioniert es bei mir zuverlässig.
                                  Meine verwendeten Adapter dafür sind:
                                  • Alexa2 Adapter 3.4.0
                                  • iot Adapter 1.8.8
                                  • Javascript Adapter 4.10.8
                                  • Telegram Adapter 1.5.9 (optional)
                                  • E-Mail Adapter 1.0.7 (optional)
                                  • und wenn gewünscht (optional) iQontrol 1.5.2
                                  • TR-064 4.2.1 Anruferansage (optional Telegram/EMAIL-extra Blockly im zweiten Beitrag)
                                  SmartGeräte für den iot Adapter werden direkt im Blockly erstellt, das sind dann die Button für die spätere Routine in der Amazon App.
                                  Das Blockly legt die benötigten Datenpunkte wahlweise unter 0_userdata.0 oder javascript.x selbst an (x=Javascript Instanznummer). Für die Erstellung der Datenpunkte nutze ich das Script von @Mic in einer Funktion. Dafür muß die Option "Erlaube das Kommando "setObject" im Javascript Adapter erlaubt sein.
                                  Der Versand aller Nachrichten (Telegram oder EMAIL) ist immer schaltbar, z.B. wenn man eine Anwesenheitsfunktion hat, dann könnte man den Versand bei Abwesenheit "scharf" schalten.
                                  Die Button hingegen funktionieren immer. Hier könnte man jeweils eine Routine in der Alexa App anlegen und den Versand des Gerätestatus-Versand auslösen.
                                  Z.B.
                                  Alexa, schicke mir den Fensterstatus.
                                  Alexa, schicke mir den Lichtstatus
                                  Alexa, schicke mir den Steckdosenstatus usw...
                                  Über diesen Weg lasse ich mir auch zum Beispiel auf Anforderung den Batteriestatus aller meiner Geräte mit Batterien als Liste schicken. Oder auch, Alexa schicke mir ein Bild von der Eingangskamera. Wenn man es auf die Spitze treibt, dann geht auch: Alexa, schicke mir den kompletten Status und dann trudeln bei mir nacheinander Bilder von drei Kameras, alle Batteriezustände, eine Liste mit geöffneten/gekippten Fenstern, ein Liste mit eingeschalteten Lampen usw. usw. usw. ein.
                                  Wenn Ihr nun Lust auf das Blockly habt, dann ist jetzt einmalig etwas Fleißarbeit angesagt. Bevor Ihr das Blockly nutzen könnt, müssen die Alias für Eure Geräte, die Ihr im Blockly verwenden wollt, erstellt werden. Dafür eignet sich die Scriptvorlage von @CruziX hervorragend. Mit dieser Vorlage können alle Alias auf einmal erstellt werden. Eine Vorlage als Beispiel findet Ihr im Spoiler. An dieser Stelle sei gleich gesagt, sinnvolle Namen im Alias zu verwenden (id ist egal, nur der Name ist gemeint), da diese Namen dann für alles im Blockly verwendet werden, also alle Gerätenamen allgemein. Also immer so erstellen, das sich der Name auch z.B. für Alexa aussprechen lässt.
                                  In der id keine Leerzeichen/Sonderzeichen oder Umlaute verwenden, damit vermeidet man direkt im Vorfeld mögliche Fehler.
                                  Als erstes solltet ihr in den Aufzählungen neue Funktionen erstellen, diese kann man dann gleich im alias Script benutzen. Da auf das Plus drücken.
                                  dann auf das Plus bei neue benutzerdefinierte Gruppe klicken
                                  Ich habe folgende erstellt (wenn Ihr die gleichen nehmt müsst Ihr das nichtmal im Blockly umstellen)
                                  batterien_voll_leer_alias
                                  batterien_volt_alias
                                  bewegungsmelder_alias
                                  fenster_alias
                                  licht_alias
                                  steckdosen_alias
                                  temperaturen_alias
                                  tueren_alias
                                  batterien_prozent_alias
                                  Das sind die Selektoren im Blockly
                                  Das ganze sieht dann nach dem Blockly Start in den Objekten z.B. so aus: (wenn alle Schalter im Blockly auf wahr stehen)
                                  01_Anzeigen_und_Listen
                                  02_Trigger_und_Schalter
                                  03_HTML_Daten hat zwei Unterordner
                                  01_HTML_Hell_Dunkel_Festeinstellung ist nicht veränderbar und sieht so aus (helle Einstellung aktiv)
                                  03_HTML_Eigene_Einstellung enthält die gleichen Datenpunkte und wird beim ersten verwenden des Triggers mit Standardwerten befüllt. Diese Werte können dann mit eigenen Werten überschrieben werden.
                                  Und hier noch der Rest
                                  Die Bilder bzw. Icon links und rechts habe ich als Base64 eingefügt. Ich benutze dafür das hier: https://www.base64-image.de/
                                  Wenn iQontrol installiert ist, dann funktioniert auch der Pfad zu einem Icon (einfach den eingestellten Pfad zum Icon aus iQontrol kopieren und einfügen)
                                  In den eigenen 02_HTML_Eigene_Einstellungen kann alles selbst an die eigenen Wünsche angepasst werden.
                                  Hier noch ein kurzes GiF
                                  (klick auf das linke Icon schaltet die Farbeinstellungen durch. klick auf das rechte Icon blendet die Tabelle ein und aus bzw. schaltet auf aktiv/inaktiv)
                                  Das ganze sieht dann so bei mir aus (ich habe immer nur die ersten fünf auf den Bildern)
                                  Im Beispielvideo werden die eigenen Alias ab Zeile 271 eingefügt, also ab dem ersten createAlias
                                  Video Beispiel:
                                  Alias_per_Script_erstellen.m4v
                                  In der Vorlage habe ich jeweils zwei meiner verwendeten Geräte als Beispiel eingefügt.
                                  Hier und in den folgenden Beiträgen versuche ich die Alias Funktion vom Script etwas zu erklären:
                                  Klick Erklärung alias Funktion
                                  Github - https://github.com/xCruziX/ioBroker-Creating-Alias/blob/master/CreateAlias.js
                                     			Changelog
                                  Version 1.1.4
                                  - fix error by using bCreateAliasPath and bConvertExistingPath (has no target 9/Error creating alias-path)
                                     	Flags /
                                     	Variablen
                                  // typeAlias = 'boolean'; // oder 'number'
                                  // read = "val == 'Ein' ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
                                  // write = "val ? 'Ein' : 'Aus'";
                                  // nameAlias = 'Licht Haustür';
                                  // role = 'switch';
                                  // desc = 'per Script erstellt';
                                  // min = 0; // nur Zahlen
                                  // max = 100; // nur Zahlen
                                  // unit = '%'; // nur für Zahlen
                                  // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
                                  let bCreateAliasPath = true;  // If this flag is true, each folder is created seperately so rooms and functions can be assigned.
                                  Requirements: bCreateAliasPath == true
                                  If this flag is true, existing folders in the path will be converted so rooms and functions can be assigned.
                                  let bConvertExistingPath = false;
                                     	Don't change anything from here /
                                     	Ab hier nichts verändern
                                  let arEnum = [];
                                  let arId = [];
                                  let timeoutAssignEnum;
                                  var callbackAlias = undefined;
                                  function createAlias(idSrc, idDst,raum, gewerk,typeAlias, read, write, nameAlias, role, desc, min, max, unit, states) {
                                   if(!idDst.includes('alias.0.'))
                                       idDst = 'alias.0.' + idDst;
                                   if(!existsObject(idSrc))
                                       log('Source-Id ' + idSrc +' does not exists.','warn');
                                       return;
                                   // Create the object Path for alias id,
                                   // so you can assign rooms and function to the parents
                                   var createAliasPath = (id) => {
                                        if(bCreateAliasPath){
                                             let lisMergedIds = [];
                                             let mergedId = 'alias.0';
                                             id = id.replace(mergedId + '.', ''); // Remove prefix alias so it will not be changed
                                             let split = id.split('.');
                                             for(let i=0;i<split.length-1;i++){
                                                 mergedId += '.' + split[i];
                                                 lisMergedIds.push(mergedId);
                                             function path(){
                                                 if(lisMergedIds.length == 0) {
                                                     alias();
                                                     return;
                                                 let tmpId = lisMergedIds[0];
                                                 lisMergedIds.splice(0,1); // remove element
                                                 if(!existsObject(tmpId) || bConvertExistingPath){ // not exists
                                                     let obj;
                                                     if(existsObject(tmpId))
                                                         obj = getObject(tmpId);
                                                     else
                                                         obj = {};
                                                     let bApply = false;
                                                     if(obj != undefined){
                                                         if(obj.type == undefined || String(obj.type) != 'meta'){
                                                             obj.type = 'meta';
                                                             bApply = true;
                                                         if(obj.common == undefined){
                                                             obj.common = {};
                                                             obj.common.type = 'meta.folder';
                                                             bApply = true;
                                                         else if(obj.common.type == undefined || String(obj.common.type) != 'meta.folder'){
                                                             bApply = true;
                                                         if(obj.native == undefined){
                                                             obj.native = {};
                                                             bApply = true;
                                                     else{
                                                         path();
                                                         log('Object is undefined');
                                                         return;
                                                     if(bApply){
                                                         setObject(tmpId, obj, (err) =>{
                                                         if(!err){
                                                             log('Created Alias-Path ' + tmpId);
                                                             path();
                                                         else
                                                             log('Error creating alias-path','error');
                                                     else
                                                         path();
                                             path();
                                        else
                                          alias();
                                   function alias(){
                                       // Create alias object
                                         if(!existsObject(idDst)){
                                             let obj = {};
                                             obj.type = 'state';
                                             obj.common = getObject(idSrc).common;
                                             obj.common.alias = {};
                                             obj.common.alias.id = idSrc;
                                             if(typeAlias !== undefined)
                                                 obj.common.type = typeAlias;
                                             if(obj.common.read !== undefined)
                                                 obj.common.alias.read = read;
                                             if(obj.common.write !== undefined)
                                                 obj.common.alias.write = write;
                                             if(nameAlias !== undefined)
                                                 obj.common.name = nameAlias;
                                             if(role !== undefined)
                                                 obj.common.role = role;
                                             if(desc !== undefined)
                                                 obj.common.desc = desc;
                                             if(min !== undefined)
                                                 obj.common.min = min;
                                             if(max !== undefined)
                                                 obj.common.max = max;
                                             if(unit !== undefined)
                                                 obj.common.unit = unit;
                                             if(states !== undefined)
                                                 obj.common.states = states;
                                             obj.native = {};
                                             obj.common.custom = []; // Damit die Zuordnung zu iQontrol, Sql etc. nicht übernommen wird
                                             log('Created Alias-State ' + idDst);
                                             setObject(idDst, obj,(err) =>{
                                                 if(!err)
                                                     startAttach();
                                                 else
                                                     log('Error creating-alias','error');
                                         else
                                             startAttach();
                                   // Save ID and Enum (room or function)
                                   var attach = (id, enu,value) => {
                                       if(id.length == 0){
                                           log('ID has lenght 0, can not attach to enum','warn');
                                           return;
                                       if(value.length == 0){
                                           log('Value has lenght 0','warn');
                                           return;
                                       let sEnuId = 'enum.' + enu + '.' + value;
                                       if(enu.length > 0 && existsObject(sEnuId))
                                           let obj = getObject(sEnuId)
                                           let members = obj.common.members;
                                           if(!members.includes(id)){
                                               arEnum.push(sEnuId);
                                               arId.push(id);
                                       else
                                    	      log('Can not find enum ' + sEnuId,'warn');
                                  function startAttach(){
                                     let bRoom = raum !== undefined && raum.length > 0;
                                     let bGewerk = gewerk !== undefined && gewerk.length > 0;
                                     if(bRoom)
                                         attach(idDst,'rooms',raum);
                                     if(bGewerk)
                                         attach(idDst,'functions',gewerk);
                                     if(bRoom || bGewerk){
                                             if(timeoutAssignEnum){
                                                 clearTimeout(timeoutAssignEnum);
                                                 timeoutAssignEnum = null;
                                             timeoutAssignEnum = setTimeout(finishScript,100);
                                   createAliasPath(idDst);
                                  function finishScript(){
                                     assignEnums();
                                  // Add the saved IDs to the rooms/functions
                                  function assignEnums(){
                                  if(arEnum.length == 0 || arId.length == 0){
                                       return;
                                  if(arEnum.length != arId.length){
                                       log('Arrays have different size','error');
                                       return;
                                  let mapEnumId = new Map();
                                  for(let i=0;i < arEnum.length; i++){
                                      let enu = arEnum[i];
                                      let id = arId[i];
                                      if(existsObject(id)){
                                     	 let obj = getObject(enu)
                                     	 let members;
                                     	 if(!mapEnumId.has(enu)){
                                     		 mapEnumId.set(enu,members);
                                     	 else
                                     		 members = mapEnumId.get(enu);
                                     		  log("Adding " + id + " to " + enu);
                                     		  members.push(id);
                                      else
                                          log('Can not find Alias ' + id,'error');
                                   function setMembers(members,enu,map){
                                       let obj = getObject(enu);
                                       obj.common.members = members;
                                       setObject(enu,obj);
                                   mapEnumId.forEach(setMembers);
                                     	END /
                                     	ENDE
                                  //  Fenster
                                  //2 x Fenstersensoren HMIP
                                  //einfache HMIP Fenstersensoren über rpc-Adapter in function fenster_alias
                                  //{0: 'geschlossen', 1: 'geöffnet'}
                                  createAlias('hm-rpc.0.xxx.1.STATE'/*Wohnzimmer Fenster links STATE*/, 'Fenster.Wohnzimmer_Fenster_links', undefined, 'fenster_alias', 'number', undefined, undefined, 'Wohnzimmer links', 'window.value', 'per Script erstellt', 0, 1, '',{0: 'geschlossen', 1: 'geöffnet'})
                                  createAlias('hm-rpc.0.xxx.1.STATE'/*Küche Fenster links STATE*/, 'Fenster.Kueche_Fenster_links', undefined, 'fenster_alias', 'number',undefined, undefined, 'Küche links', 'window.value', 'per Script erstellt', 0, 1, '',{0: 'geschlossen', 1: 'geöffnet'})
                                  //einfache HM Fenstersensoren über rpc-Adapter in function fenster_alias
                                  //{false: 'geschlossen', true: 'geöffnet'}
                                  createAlias('hm-rpc.0.xxx.1.STATE'/*Wohnzimmer Fenster links STATE*/, 'Fenster.Wohnzimmer_Fenster_links', undefined, 'fenster_alias', 'boolean', undefined, undefined, 'Wohnzimmer links', 'window.value', 'per Script erstellt', undefined, undefined, undefined, {false: 'geschlossen', true: 'geöffnet'})
                                  createAlias('hm-rpc.0.xxx.1.STATE'/*Küche Fenster links STATE*/, 'Fenster.Kueche_Fenster_links', undefined, 'fenster_alias', 'boolean',undefined, undefined, 'Küche links', 'window.value', 'per Script erstellt', undefined, undefined, undefined, {false: 'geschlossen', true: 'geöffnet'})
                                  createAlias('hm-rpc.0.xxx.1.STATE'/*Keller W-Baum Fenster STATE*/, 'Fenster.Keller_Weihnachtsbaum_Fenster', undefined, 'fenster_alias', 'number',undefined, undefined, 'Keller W Baum', 'window.value', 'per Script erstellt', 0, 2, '',{0: 'geschlossen', 1: 'gekippt', 2: 'geöffnet'})
                                  createAlias('hm-rpc.0.xxx.1.STATE'/*Keller Wohnzimmer Fenster mitte STATE*/, 'Fenster.Keller_Wohnzimmer_Fenster_mitte', undefined, 'fenster_alias', 'number',undefined, undefined, 'Keller Wohnzimmer mitte', 'window.value', 'per Script erstellt', 0, 2, '',{0: 'geschlossen', 1: 'gekippt', 2: 'geöffnet'})
                                  //2 x Fenster(Türen) Sensoren HMIP
                                  //einfache HMIP Fenstersensoren über rpc-Adapter in function tueren_alias
                                  createAlias('hm-rpc.0.xxx.1.STATE'/*Wohnzimmer Terrassentür STATE*/, 'Tueren.Terrassentuer', undefined, 'tueren_alias', 'number',undefined, undefined, 'Terrassentür', 'window.value', 'per Script erstellt', 0, 1, '',{0: 'geschlossen', 1: 'geöffnet'})
                                  createAlias('hm-rpc.0.xxx.1.STATE'/*Haustür STATE*/, 'Tueren.Haustuer', undefined, 'tueren_alias', 'number',undefined, undefined, 'Haustür', 'window.value', 'per Script erstellt', 0, 1, '',{0: 'geschlossen', 1: 'geöffnet'})
                                  //  Steckdosen
                                  //2 x Steckdosen
                                  //HMIP Steckdosen über rpc-Adapter in function steckdosen_alias
                                  //{false: 'aus', true: 'an'}
                                  createAlias('hm-rpc.0.xxx.3.STATE'/*Waschmaschine STATE*/, 'Steckdosen.Waschmaschine', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Waschmaschine', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
                                  createAlias('hm-rpc.0.xxx.3.STATE'/*Geschirrspueler STATE*/, 'Steckdosen.Geschirrspueler', undefined, 'steckdosen_alias', 'boolean', undefined, undefined, 'Geschirrspüler', 'switch', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
                                  //  Bewegungsmelder
                                  //2 x Bewegungsmelder und 2 x Präsenzmelder und 1 x Erschütterungssensor
                                  //HMIP Bewegungsmelder und Präsenzmelder über rpc-Adapter in function bewegungsmelder_alias
                                  //{false: 'inaktiv', true: 'aktiv'}
                                  createAlias('hm-rpc.0.xxx.1.MOTION'/*Bewegungsmelder Weihnachtsbaumkeller MOTION*/, 'Bewegungsmelder.Bewegungsmelder_Weihnachtsbaumkeller', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'W Baum Keller', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
                                  createAlias('hm-rpc.0.xxx.1.MOTION'/*Bewegungsmelder Heizungskeller MOTION*/, 'Bewegungsmelder.Bewegungsmelder_Heizungskeller', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'Heizungskeller', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
                                  //ab hier 2 x Präsenzmelder
                                  createAlias('hm-rpc.0.xxx.1.PRESENCE_DETECTION_STATE'/*Präsenzmelder Badezimmer PRESENCE DETECTION STATE*/, 'Bewegungsmelder.Praesenzmelder_Badezimmer', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'Badezimmer', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
                                  createAlias('hm-rpc.0.xxx.1.PRESENCE_DETECTION_STATE'/*Präsenzmelder Dusche PRESENCE DETECTION STATE*/, 'Bewegungsmelder.Praesenzmelder_Dusche', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'Dusche', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
                                  //ab hier 1 x Erschütterungssensor
                                  createAlias('hm-rpc.0.xxx.1.MOTION'/*Briefkasten MOTION*/, 'Bewegungsmelder.Praesenzmelder_Briefkasten', undefined, 'bewegungsmelder_alias', 'boolean', undefined, undefined, 'Briefkasten', 'sensor.motion', 'per Script erstellt', undefined, undefined, undefined, {false: 'inaktiv', true: 'aktiv'})
                                  //  Licht
                                  //2 x HUE und 5 x HMIP Licht über HUE und rpc-Adapter in function licht_alias
                                  createAlias('hue.0.Badezimmerlampe_links.on'/*Badezimmerlampe links on*/, 'Licht.Badezimmer_Licht_links', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Badezimmer links', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
                                  createAlias('hue.0.Badezimmerlampe_rechts.on'/*Badezimmerlampe rechts on*/, 'Licht.Badezimmer_Licht_rechts', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Badezimmer rechts', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
                                  //ab hier 2 x Licht HMIP Steckdosen über rpc Adapter
                                  createAlias('hm-rpc.0.xxx.3.STATE'/*Kugellampe STATE*/, 'Licht.Wohnzimmer_Kugel_Licht', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Kugellicht', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
                                  createAlias('hm-rpc.0.xxx.3.STATE'/*Gäste WC Licht STATE*/, 'Licht.Gaeste_WC_Licht', undefined, 'licht_alias', 'boolean', undefined, undefined, 'Gäste WC Licht', 'switch.light', 'per Script erstellt', undefined, undefined, undefined, {false: 'aus', true: 'an'})
                                  //  Temperaturen
                                  //HMIP 2 x Temperaturen über rpc-Adapter in function temperaturen_alias
                                  createAlias('hm-rpc.0.xxx.1.ACTUAL_TEMPERATURE'/*Wandthermostat Schlafzimmer:1 ACTUAL TEMPERATURE*/, 'Temperaturen.Temperatur_Schlafzimmer', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Schlafzimmer', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
                                  createAlias('hm-rpc.0.xxx.1.ACTUAL_TEMPERATURE'/*Wandthermostat Wohnzimmer:1 ACTUAL TEMPERATURE*/, 'Temperaturen.Temperatur_Wohnzimmer', undefined, 'temperaturen_alias', 'number', 'Math.round(val * 10) / 10', undefined, 'Wohnzimmer', 'value.temperature', 'per Script erstellt', undefined, undefined, '°C', undefined)
                                  //  Batterien_voll_leer
                                  //2 x Batterien voll-leer über boolean Wert false/true in function batterien_voll_leer_alias
                                  createAlias('hm-rpc.0.xxx.0.LOW_BAT'/*Wohnzimmer Fenster links:0 LOW BAT*/, 'Batterien_voll_leer.Wohnzimmer_Fenster_links', undefined, 'batterien_voll_leer_alias', 'boolean', undefined, undefined, 'Wohnzimmer Fenster links', 'indicator.lowbat', 'per Script erstellt', undefined, undefined, undefined, {false: 'voll', true: 'leer'})
                                  createAlias('hm-rpc.0.xxx.0.LOW_BAT'/*Küche Fenster links:0 LOW BAT*/, 'Batterien_voll_leer.Kueche_Fenster_links', undefined, 'batterien_voll_leer_alias', 'boolean', undefined, undefined, 'Küche Fenster links', 'indicator.lowbat', 'per Script erstellt', undefined, undefined, undefined, {false: 'voll', true: 'leer'})
                                  //  Batterien_Volt
                                  //2 x Batterien Volt Anzeige in function batterien_volt_alias
                                  createAlias('hm-rpc.0.xxx.0.OPERATING_VOLTAGE'/*Wohnzimmer Fenster links:0 OPERATING VOLTAGE*/, 'Batterien_Volt.Wohnzimmer_Fenster_links', undefined, 'batterien_volt_alias', 'number', undefined, undefined, 'Wohnzimmer Fenster links', 'value.voltage', 'per Script erstellt', undefined, undefined, 'Volt', undefined)
                                  createAlias('hm-rpc.0.xxx.0.OPERATING_VOLTAGE'/*Küche Fenster links:0 OPERATING VOLTAGE*/, 'Batterien_Volt.Kueche_Fenster_links', undefined, 'batterien_volt_alias', 'number', undefined, undefined, 'Küche Fenster links', 'value.voltage', 'per Script erstellt', undefined, undefined, 'Volt', undefined)
                                  nach dem Alias erstellen das hier beachten: Klick
                                  bitte das Blockly auf den eigenen Rechner downloaden und dort mit einem Editor öffnen und den gesamten Inhalt der Textdatei in die Zwischenablage kopieren und anschließend in ein neues leeres Blockly importieren. Nicht direkt im Browser öffnen und kopieren, dann kommt es oft zu Umlaute Fehlern im Blockly.
                                  Hier ist der Blockly Export
                                  Temperaturen_1-6-7.zip
                                  Batterien_Volt_1-6-7.zip
                                  Steckdosen_1-6-7.zip
                                  Lichter_1-6-7.zip
                                  Bewegungsmelder_1-6-7.zip
                                  Batterien_voll_leer_1-6-7.zip
                                  Fenster_1-6-7.zip
                                  Tueren_1-6-7.zip
                                  Batterien_Prozent_1-6-7.zip
                                  meine iQontrol Einstellungen
                                  Hier der Export von diesem View
                                  2020-12-20_iqontrol_0_selected_views.json.zip
                                  Zuerst muß das neue SmartGerät aus iot gesucht und gefunden werden. Dazu ist es wichtig einmal den iot Adapter zu öffnen und in den Reiter "SMART-GERÄTE" zu wechseln. Das neue Gerät sollte da sein, aber wenn man diesen Schritt nicht macht, dann werden von Alexa keine neuen Geräte gefunden. Danach kann der Adapter wieder geschlossen werden.
                                  Nun entweder in der App neue Geräte suchen lassen, oder kurz den Sprachbefehl: "Alexa, suche neue Geräte" ausführen. Wenn das durchgelaufen ist und ein neues oder mehrere neue Geräte gefunden wurden, dann geht es mit dem Einrichten der Routine weiter.
                                  neue Geräte suchen lassen in der Alexa App
                                  ein neues Gerät (oder mehrere) wurde gefunden
                                  alles überspringen und dann zu den Routinen. Dort dann auf das Plus (oben rechts) drücken und eine neue Routine anlegen. Satz bzw. Frage eingeben bei Stimme
                                  Dann als nächstes die Aktion hinzufügen (SmartHome), alle Geräte auswählen und das passende Gerät einfügen.
                                  Oben rechts auf speichern, dann kurz warten und ausprobieren...
                                  sigi234S Online
                                  sigi234S Online
                                  #1165
                                  @dslraser
                                  Hallo, wo kann ich die Überschrift beeinflussen, habe 2 mal Batterien Haus?
                                  Und wie bekomme ich die Scroll Balken weg?
                                  Stephan SchleichS dslraserD 3 Antworten Letzte Antwort
                                  • sigi234S sigi234
                                    @dslraser
                                    Stephan SchleichS Offline
                                    Stephan Schleich
                                    #1166
                                    @dslraser
                                      @dslraser
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      #1167
                                      @Stephan-Schleich
                                      Wie sehen Deine Einstellungen aus ? Hast Du was verändert ?
                                      • sigi234S sigi234
                                        @dslraser
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #1168
                                        keine Ahnung, frag mal im iQontrol Thread
                                        Bitte mal Version 1.6.5 probieren (eigene Überschrift/selbst definieren)
                                        @DocGame
                                        in Version 1.6.5 ist der Zeilenumbruch in der Spalte mit den Werten deaktiviert.
                                        Batterien_Prozent_1-6-5.zip
                                        • sigi234S sigi234
                                          @dslraser
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          #1169
                                          ich könnte das scrollen in der HTML Liste ausschalten, aber wenn die Liste länger ist, dann kann man sie nicht scrollen. Dann würde die Liste bei einer 3x3 Kachel abgeschnitten. Bei Vollbild würde da abgeschnitten, wo der Bildschirm unten zu Ende ist.
