  4. (gelöst)Fehler von Multihost nach update auf Buster
buster update redis multihostmaster slave
82 Beiträge 4 Kommentatoren 9.1k Aufrufe 3 Beobachtet
  • M Mapio90
    @Meister-Mopper
    pi@Master:~ $ iobroker multihost enable
    Please check the binding of redis service. By default it is only local: http://download.redis.io/redis-stable/redis.conf
    Change "bind 127.0.0.1" to "bind 0.0.0.0" or to others.
    No configuration change needed.
    Multihost discovery server: enabled
    Discovery authentication:   enabled
    Objects:                    redis on 0.0.0.0
    States:                     redis on 0.0.0.0
    Mapio90
    Jetzt blick ich vollkommen nicht mehr durch, jetzt komm ich nicht mal mehr auf die Weboberfläche....
    pi@Master:~ $ iobroker setup custom
    Current configuration:
    - Objects database:
      - Type: file
      - Host/Unix Socket: 0.0.0.0
      - Port: 9001
    - States database:
      - Type: redis
      - Port: 6379
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(f)ile, (r)edis], default [file]: r
    When Objects and Files are stored in a Redis database please consider the following:
    1. All data will be stored in RAM, make sure to have enough free RAM available!
    2. Make sure to check Redis persistence options to make sure a Redis problem will not cause data loss!
    3. The Redis persistence files can get big, make sure not to use an SD card to store them.
    Host / Unix Socket of objects DB(redis), default[127.0.0.1]: 0.0.0.0
    Port of objects DB(redis), default[6379]: 9001
    Type of states DB [(f)file, (r)edis], default [redis]: r
    Host / Unix Socket of states DB (redis), default[0.0.0.0]: 0.0.0.0
    Port of states DB (redis), default[9001]: 6379
    Host name of this machine [Master]:
    Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
    Important: Using Redis for the Objects database is only supported
    with js-controller 2.0 or higher!
    When your system consists of multiple hosts please make sure to have
    js-controller 2.0 or higher installed on ALL hosts *before* continuing!
    Important #2: If you already did the migration on an other host
    please *do not* migrate again! This can destroy your system!
    Important #3: The process will migrate all files that were officially
    uploaded into the ioBroker system. If you have manually copied files into
    iobroker-data/files/... into own directories then these files will NOT be
    migrated! Make sure all files are in adapter directories inside the files
    directory!
    Do you want to migrate objects and states from "file/redis" to "redis/redis" [y/N]: n
    No Database migration was done.
    If this was done on your master host please execute "iobroker setup first" to newly initialize all objects.
    updating conf/iobroker.json
    pi@Master:~ $ ^C
    pi@Master:~ $ iobroker status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    pi@Master:~ $ sudo service iobroker restart
    • M Mapio90
      - Objects database:
        - Type: file
        - Port: 9001
      - States database:
        - Type: redis
        - Port: 6379
      directory!
      pi@Master:~ $ ^C
      Objects type: redis
      States  type: redis
      Mapio90
      @Meister-Mopper
      @arteck
      Habe den Master nun komplett runter geschmissen und ein backup drauf gemacht.
      Wie würdet ihr jetzt vorgehen, dass mir bestmöglich ein backup wieder erspart bleibt?
      auf dem Slave zeigt es folgendes an:
      pi@second-device:~ $ iobroker status
      No connection to states 192.168.178.34:6379[redis]
      auf dem Master:
      Objects type: file
      States  type: redis
      Meister MopperM HomoranH 2 Antworten Letzte Antwort
      • M Mapio90
        @Meister-Mopper
        @arteck
        auf dem Master:
        Objects type: file
        States  type: redis
        Meister MopperM Offline
        Meister Mopper
        schrieb am zuletzt editiert von Meister Mopper
        @Mapio90 Es steht ja geschrieben. Du solltest das binding für redis auf dem Master von 127.0.0.1 auf 0.0.0.0 stellen, damit sich andere hosts mit dem redis-server des masters verbinden können. Das solltest Du in der /etc/redis/redis.conf umstellen.
        Edit: Vorher natürlich noch redis installieren (auf dem master).
        Proxmox und HA ...
        • M Mapio90
          @Meister-Mopper
          @arteck
          auf dem Master:
          Objects type: file
          States  type: redis
          HomoranH Offline
          HomoranH Offline
          @Mapio90 sagte in Fehler von Multihost nach update auf Buster:
          ein Backup von ioBroker?
          Oder von der SD-Karte?
          im ersten Fall dürfte kein Redis drauf sein.
          Was sagt redis-server -v?
          Wenn du dann den redis-server nachinstallierst musst du auch die Konfig von redis für Multihost anpassen
            Mapio90
            @Homoran
            habe die sd-karte formatiert und dann das backup wieder komplett aufgespielt.
            pi@Master:~ $ redis-server -v
            Redis server v=5.0.3 sha=00000000:0 malloc=jemalloc-5.1.0 bits=32 build=1b271fe49834c463
            • M Mapio90
              @Homoran
              HomoranH Offline
              HomoranH Offline
              also incl. der Fehler, die bereits ins Backup gelangt waren 😡
                Mapio90
                @Meister-Mopper sagte in Fehler von Multihost nach update auf Buster:
                Wird das mit iobroker setup custom ausgeführt oder muss ich das mit dem nano, sprich im editor tun?
                • M Mapio90
                  HomoranH Offline
                  HomoranH Offline
                  ja
                    Mapio90
                    @Homoran Nein ich habe bevor ich buster aufgespielt hatte ein Backup durchgeführt.
                    als ich den slave aktuallisiert (auf Buster) habe, war multihost noch stabil, d.h. der Slave war online.
                    als ich dann aber den Master auf buster upgedatet habe, dann war der Slave offline.
                    Dann habe ich versucht mit iobroker setup custom wieder zu verbinden und dann ging es nach hinten los. Admin-Oberfläche vom Master nicht mehr erreichbar, fehler in der setup custom... naja dann heute den tag das backup (wo alles noch gelaufen ist) aufgespielt. Jetzt nach langem hin und her sind alle Adapter vom Master grün, (roborock, zigbee und ble ). Jetzt muss ich meiner meinung nach wieder die Multihost umgebung verbinden, dass es wieder ist wie davor.
                    • M Mapio90
                      Meister Mopper
                      @Mapio90 Da ja redis bei Dir läuft, solltest Du das erstmal sauber konfigurieren, bevor Du den Multihost einrichtest.
                      Proxmox und HA ...
                        Mapio90
                        schrieb am zuletzt editiert von Mapio90
                        @Meister-Mopper
                        okay. also dann installiere ich jetzt redis mit folgendem Befehl?
                        sudo apt-get update
                        sudo apt-get install redis-server
                        sudo usermod -a -G redis iobroker
                        sudo reboot now
                        • M Mapio90
                          @Meister-Mopper
                          sudo apt-get update
                          sudo reboot now
                          HomoranH Offline
                          HomoranH Offline
                          Nein!
                          Wo hast du das her?
                          Ganz abgesehen davon hgast du redis bereits und es läuft
                          M Meister MopperM 3 Antworten Letzte Antwort
                            Nein!
                            Wo hast du das her?
                            Mapio90
                            @Homoran
                            Das steht im HowTo: Backup wiederherstellen (Linux) hier im Forum
                            Ich möchte es einfach schrittweise durchgehen, dass ich nicht wieder einen Tag beschäftigt bin den iobroker wieder zum laufen zu bringen.
                              Nein!
                              Wo hast du das her?
                              Meister Mopper
                              @Homoran Genau, redis läuft. Jetzt
                              sudo nano /etc/redis/redis.conf
                              127.0.0.1 in 0.0.0.0 umbenennen und 'protected_mode no'
                              Proxmox und HA ...
                                Nein!
                                Wo hast du das her?
                                Meister Mopper
                                @Homoran sagte in Fehler von Multihost nach update auf Buster:
                                Wo hast du das her?
                                Das ist nötig, wenn der backitup-Adapter die redis dump-Datei sichern soll, dann muss der iobroker-Nutzer user von redis sein.
                                Proxmox und HA ...
                                HomoranH M 2 Antworten Letzte Antwort
                                  Wo hast du das her?
                                  HomoranH Offline
                                  HomoranH Offline
                                  Wo hast du das her?
                                  das passt!
                                    Wo hast du das her?
                                    Mapio90
                                    @Meister-Mopper
                                    so?
                                    # IF YOU ARE SURE YOU WANT YOUR INSTANCE TO LISTEN TO ALL THE INTERFACES
                                    # JUST COMMENT THE FOLLOWING LINE.
                                    bind 0.0.0.0 ::1
                                    # Protected mode is a layer of security protection, in order to avoid that
                                    # Redis instances left open on the internet are accessed and exploited.
                                    # When protected mode is on and if:
                                    # 1) The server is not binding explicitly to a set of addresses using the
                                    #    "bind" directive.
                                    # 2) No password is configured.
                                    # The server only accepts connections from clients connecting from the
                                    # IPv4 and IPv6 loopback addresses 127.0.0.1 and ::1, and from Unix domain
                                    # sockets.
                                    # By default protected mode is enabled. You should disable it only if
                                    # you are sure you want clients from other hosts to connect to Redis
                                    # even if no authentication is configured, nor a specific set of interfaces
                                    # are explicitly listed using the "bind" directive.
                                    protected-mode no
                                    # Accept connections on the specified port, default is 6379 (IANA #815344).
                                    # If port 0 is specified Redis will not listen on a TCP socket.
                                    port 6379
                                    # TCP listen() backlog.
                                    # In high requests-per-second environments you need an high backlog in order
                                    # to avoid slow clients connections issues. Note that the Linux kernel
                                    # will silently truncate it to the value of /proc/sys/net/core/somaxconn so
                                    # make sure to raise both the value of somaxconn and tcp_max_syn_backlog
                                    # in order to get the desired effect.
                                    tcp-backlog 511
                                    # Unix socket.
                                    • M Mapio90
                                      @Meister-Mopper
                                      so?
                                      bind 0.0.0.0 ::1
                                      #    "bind" directive.
                                      # sockets.
                                      protected-mode no
                                      port 6379
                                      tcp-backlog 511
                                      # Unix socket.
                                      HomoranH Offline
                                      HomoranH Offline
                                      @Mapio90
                                      wo kommt das ::1 her?
                                      das sieht wie Reste(??) einer IPv6 Adresse aus?
                                        @Mapio90
                                        Mapio90
                                        @Homoran
                                        Wenn die Frage an mich ging, das stand da schon drin.
                                        • M Mapio90
                                          @Homoran
                                          Meister Mopper
                                          @Mapio90 Genau so (mit den Punkten) läuft es bei mir. Hast Du bei protected-mode den Bindestrich geändert, oder war der vorher auch da?
                                          Proxmox und HA ...
