  4. [gelöst] System startet nicht mehr nach Update
raspi 4bsystem
22 Beiträge 3 Kommentatoren 967 Aufrufe 2 Beobachtet
  • M MCU
    @Thomas-Braun Gar nichts mehr. Kein Kontakt. Nicht mehr über IP erreichbar.
    @MCU
    Neuinstallieren, Backup einspielen.
      @MCU
      MCU
      @Thomas-Braun Ja versuch ich jetzt erstmal. Danke.
      • M MCU
        MCU
        @MCU Auffälligkeiten bei iot.0 Backup-Installation
        2020-12-09 14:51:42.959 - info: host.raspberrypi iobroker install iot@1.8.5 using installedFrom
        2020-12-09 14:51:45.807 - info: host.raspberrypi iobroker npm-install: NPM version: 6.14.9
        2020-12-09 14:51:45.809 - info: host.raspberrypi iobroker npm-install: npm install iobroker.iot@1.8.5 --loglevel error --prefix "/opt/iobroker" (System call)
        2020-12-09 14:52:17.627 - info: host.raspberrypi iobroker npm-install: Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
        2020-12-09 14:52:17.629 - info: host.raspberrypi iobroker npm-install: gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        2020-12-09 14:52:17.645 - info: host.raspberrypi iobroker npm-install: gyp ERR! configure error
        2020-12-09 14:52:17.646 - info: host.raspberrypi iobroker npm-install: gyp
        2020-12-09 14:52:17.648 - info: host.raspberrypi iobroker npm-install: ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack at ChildProcess.emit (events.js:314:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.4.79-v7l+
        2020-12-09 14:52:17.649 - info: host.raspberrypi iobroker npm-install: gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v12.20.0gyp ERR! node-gyp -v
        2020-12-09 14:52:17.650 - info: host.raspberrypi iobroker npm-install: v5.1.0gyp ERR! not ok
        2020-12-09 14:52:17.667 - info: host.raspberrypi iobroker npm-install: node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack at ChildProcess. (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:314:20)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1022:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)node-pre-gyp ERR! System Linux 5.4.79-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.20.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
        2020-12-09 14:52:18.239 - info: host.raspberrypi iobroker npm-install: info
        2020-12-09 14:52:18.241 - info: host.raspberrypi iobroker npm-install:
        2020-12-09 14:52:18.242 - info: host.raspberrypi iobroker npm-install: sharp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.10.0/libvips-8.10.0-linux-armv7.tar.br
        2020-12-09 14:53:18.896 - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter iot@1.8.5
        2020-12-09 14:54:11.060 - info: host.raspberrypi iobroker npm-install: upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.8a2189fc.js.map static/js/runtime-main.8a2189fc.js.map application/json
        2020-12-09 14:54:11.130 - info: host.raspberrypi iobroker npm-install: upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.8a2189fc.js static/js/runtime-main.8a2189fc.js application/javascript
        2020-12-09 14:54:11.187 - info: host.raspberrypi iobroker npm-install: upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.195074e7.chunk.js.map static/js/main.195074e7.chunk.js.map application/json
        2020-12-09 14:54:11.253 - info: host.raspberrypi iobroker npm-install: upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.195074e7.chunk.js static/js/main.195074e7.chunk.js application/javascript
        2020-12-09 14:54:11.321 - info: host.raspberrypi iobroker npm-install: upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.30e27cff.chunk.js.map static/js/2.30e27cff.chunk.js.map application/json
        2020-12-09 14:54:12.392 - info: host.raspberrypi iobroker npm-install: upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.30e27cff.chunk.js.LICENSE.txt static/js/2.30e27cff.chunk.js.LICENSE.txt text/plain
        2020-12-09 14:54:12.450 - info: host.raspberrypi iobroker npm-install: upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.30e27cff.chunk.js static/js/2.30e27cff.chunk.js application/javascript
        2020-12-09 14:54:12.529 - info: host.raspberrypi iobroker npm-install: upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
        2020-12-09 14:54:12.585 - info: host.raspberrypi iobroker npm-install: upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
        2020-12-09 14:54:12.642 - info: host.raspberrypi iobroker npm-install: upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0d046f6c.chunk.css.map static/css/2.0d046f6c.chunk.css.map application/json
        2020-12-09 14:54:12.700 - info: host.raspberrypi iobroker npm-install: upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.0d046f6c.chunk.css static/css/2.0d046f6c.chunk.css text/css
        2020-12-09 14:54:12.759 - info: host.raspberrypi iobroker npm-install: upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
        2020-12-09 14:54:12.819 - info: host.raspberrypi iobroker npm-install: upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.ba20de62a6996a204dad86e6199fcf4d.js precache-manifest.ba20de62a6996a204dad86e6199fcf4d.js application/javascript
        2020-12-09 14:54:12.881 - info: host.raspberrypi iobroker npm-install: upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
        2020-12-09 14:54:12.943 - info: host.raspberrypi iobroker npm-install: upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
        2020-12-09 14:54:13.007 - info: host.raspberrypi iobroker npm-install: upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
        2020-12-09 14:54:13.068 - info: host.raspberrypi iobroker npm-install: upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
        2020-12-09 14:54:13.129 - info: host.raspberrypi iobroker npm-install: upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
        2020-12-09 14:54:13.188 - info: host.raspberrypi iobroker npm-install: upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
        2020-12-09 14:54:13.248 - info: host.raspberrypi iobroker npm-install: upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
        2020-12-09 14:54:13.310 - info: host.raspberrypi iobroker npm-install: upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
        2020-12-09 14:54:13.643 - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.iot created/updated
        2020-12-09 14:54:14.734 - info: host.raspberrypi iobroker npm-install: exit 0
        • M MCU
          HomoranH Offline
          HomoranH Offline
          @MCU sagte in System startet nicht mehr nach Update:
          such mal nach pixman.
          da muss noch was installiert werden, ich weiß gerade nicht was
            MCU
            @Homoran Installation nach Vorgabe gemacht:
            https://www.iobroker.net/#de/documentation/install/linux.md
            Installiert noch die Adapter, abwarten, vielleicht startet er auch so.
            Meldet beim Starten folgende Fehler:
            2020-12-09 15:25:24.221 - error: iot.0 (10054) The password must be at least 8 characters long and have numbers, upper and lower case letters. Please change the password in the profile https://iobroker.pro/accountProfile.
            2020-12-09 15:27:13.203 - error: iot.0 (10075) Cannot read keys: error:0909006C:PEM routines:get_name:no start line
            • M MCU
              @MCU
              sudo apt update
              sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-dev
              sudo apt dist-upgrade
              sudo reboot
              Und bist du sicher, dass nodeJS sauber ist? Die Versionsnummer von deinem npm ist glaube ich nicht die standardmäßige von node12.
              M 2 Antworten Letzte Antwort
                @MCU
                sudo apt update
                sudo reboot
                MCU
                @Thomas-Braun
                  @MCU
                  sudo apt update
                  sudo reboot
                  MCU
                  @Thomas-Braun Man musste neues Zertifikat anfordern, dann wurde die Instanz grün und ist connected. Danke.
                  • M MCU
                    @Thomas-Braun
                    @MCU
                    Schau mal damit nach:
                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    Und bitte keine Bilder von Texten sondern den Text auch als solchen (in CodeTags) wieder hier rein.
                    • M MCU
                      HomoranH Offline
                      HomoranH Offline
                      du solltest im Forum nach dem Begriff suchen ;-)
                        @MCU
                        MCU
                        @Thomas-Braun
                        /usr/bin/nodejs
                        v12.20.0
                        /usr/bin/node
                        v12.20.0
                        /usr/local/bin/npm
                        6.14.9
                        nodejs:
                          Installiert:           12.20.0-1nodesource1
                          Installationskandidat: 12.20.0-1nodesource1
                          Versionstabelle:
                         *** 12.20.0-1nodesource1 500
                                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                             10.21.0~dfsg-1~deb10u1+rpi1 500
                        Läuft aber wieder Alles. Danke an alle.
                        Zur Info für andere, die es auch machen müssen. Ich musste beim Restore mit Backitup-Adapter einige Dinge noch nach bearbeiten.
                        iot->neues Zertifikat
                        meross -> passwort eingeben
                        sonoff-> passwort eingeben
                        pushover->API Token falsch mit Backup neu eingeben
                        • M MCU
                          @Thomas-Braun
                          /usr/bin/nodejs
                          v12.20.0
                          /usr/bin/node
                          v12.20.0
                          /usr/local/bin/npm
                          6.14.9
                          nodejs:
                            Versionstabelle:
                          /usr/local/bin/npm
                          6.14.9
                          Siehste...
                          Das ist falsch.
                            /usr/local/bin/npm
                            6.14.9
                            Siehste...
                            Das ist falsch.
                            MCU
                            @Thomas-Braun Also ich hab das nicht gemacht, was soll ich da jetzt ändern?
                            • M MCU
                              @MCU
                              Vermutlich npm global aktualisiert. Der Vorschlag kommt schon mal von npm, das zu tun.
                              Sollte man aber nicht. Schau hier wie man das wieder einfängt:
                              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/3
                                @MCU
                                MCU
                                @Thomas-Braun
                                /usr/bin/nodejs
                                v12.20.0
                                /usr/bin/node
                                v12.20.0
                                /usr/bin/npm
                                6.14.8
                                nodejs:
                                  Versionstabelle:
                                • M MCU
                                  @Thomas-Braun
                                  /usr/bin/nodejs
                                  v12.20.0
                                  /usr/bin/node
                                  v12.20.0
                                  /usr/bin/npm
                                  6.14.8
                                  nodejs:
                                    Versionstabelle:
                                  @MCU Ja, jetzt passt es und npm kommt aus dem nodeJS-Paket so wie es von nodesource gebaut wurde.
                                  Bei Updates/Upgrades von nodejs kommt dann jetzt auch immer die passende npm-Version mit.
                                  In deinem Setup wäre die sonst immer auf 6.14.9 stehen geblieben.
                                    MCU
                                    @Thomas-Braun Ok.Danke.
