  4. Twinkly - Basisfunktionen mit ioBroker steuern
    apollon77A
69 Beiträge 8 Kommentatoren 15.5k Aufrufe 9 Beobachtet
  • W W0RSCHD
    @patrickbs96
    hier mal ein Auszug
    14:34:03.146	info	javascript.0 (11366) Start javascript script.js.Schaltungen.Twinkly_JS
    14:34:03.201	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setTimeout(ms=2000)
    14:34:03.202	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: onStop(timeout=500)
    14:34:03.204	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: registered 0 subscriptions and 0 schedules
    14:34:03.215	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getObject(id=javascript.0.Weihnachtsbaum, enumName=undefined) => {"common":{"name":"Twinkly","role":"state","type":"mixed"},"native":{},"type":"channel","from":"system.adapter.javascript.0","user":"system.user.admin","ts":1607163615438,"_id":"javascript.0.Weihnachtsbaum","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    14:34:03.216	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setObject(id=javascript.0.Weihnachtsbaum, obj={"common":{"name":"Twinkly","role":"state","type":"mixed"},"native":{},"type":"channel","from":"system.adapter.javascript.0","user":"system.user.admin","ts":1607163615438,"_id":"javascript.0.Weihnachtsbaum","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}})
    14:34:05.203	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: subscribe: {"pattern":{"id":{},"change":"ne","ack":false,"q":0},"name":"script.js.Schaltungen.Twinkly_JS"}
    14:34:05.205	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setInterval(ms=60000)
    14:35:05.206	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607261680414,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607256158755}
    14:35:05.207	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    14:35:05.208	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <led/mode>
    14:35:05.209	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
    14:35:05.212	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] curl -d '{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="}' -H 'Content-Type: application/json' http://192.168.178.175/xled/v1/login
    14:35:05.212	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -d '{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="}' -H 'Content-Type: application/json' http://192.168.178.175/xled/v1/login
    14:35:05.303	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"authentication_token":"vZa1C4f9U6E=","authentication_token_expires_in":14400,"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a","code":1000}
    14:35:05.305	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._post] <verify>, {"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}, {"X-Auth-Token":"vZa1C4f9U6E="}
    14:35:05.306	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
    14:35:05.307	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] curl -d '{"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}' -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/verify
    14:35:05.308	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -d '{"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}' -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/verify
    14:35:05.376	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1102}
    14:35:05.378	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}, Headers: {"X-Auth-Token":"vZa1C4f9U6E=","Content-Type":"application/json"}, Body: {"code":1102}
    14:35:05.380	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
    14:35:05.380	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
    14:35:05.480	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
    14:35:05.485	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:190:29
    14:35:05.485	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:188:25)
    14:35:05.485	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mode, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    14:35:05.486	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.on, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    14:35:05.487	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <led/out/brightness>
    14:35:05.488	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
    14:35:05.488	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
    14:35:05.489	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
    14:35:05.549	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
    14:35:05.552	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:196:45
    14:35:05.553	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:195:25)
    14:35:05.553	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.bri, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    14:35:05.555	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <device_name>
    14:35:05.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
    14:35:05.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
    14:35:05.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
    14:35:05.621	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
    14:35:05.625	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:200:44
    14:35:05.626	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:199:25)
    14:35:05.626	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.name, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    14:35:05.627	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <mqtt/config>
    14:35:05.628	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
    14:35:05.628	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
    14:35:05.629	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
    14:35:05.702	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
    14:35:05.703	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mqtt, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    14:35:05.705	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <timer>
    14:35:05.705	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
    14:35:05.706	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
    14:35:05.706	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
    14:35:05.774	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
    14:35:05.776	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.timer, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    14:35:05.777	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <gestalt>
    14:35:05.778	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
    14:35:05.779	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
    14:35:05.779	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
    14:35:05.854	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: {"product_name":"Twinkly","product_version":"16","hardware_version":"7","flash_size":16,"led_type":6,"led_version":"1","product_code":"TW225SEUP07","device_name":"Twinkly_BA1A63","uptime":"1274275","rssi":-78,"hw_id":"00ba1a63","mac":"84:f3:eb:ba:1a:63","uuid":"7F272E77-662E-4E6C-A8A0-D50DCA470F74","max_supported_led":255,"base_leds_number":225,"number_of_led":225,"led_profile":"RGB","frame_rate":25,"movie_capacity":719,"copyright":"LEDWORKS 2017","code":1000}
    14:35:05.857	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.details, state={"val":"{\"product_name\":\"Twinkly\",\"product_version\":\"16\",\"hardware_version\":\"7\",\"flash_size\":16,\"led_type\":6,\"led_version\":\"1\",\"product_code\":\"TW225SEUP07\",\"device_name\":\"Twinkly_BA1A63\",\"uptime\":\"1274275\",\"hw_id\":\"00ba1a63\",\"mac\":\"84:f3:eb:ba:1a:63\",\"max_supported_led\":255,\"base_leds_number\":225,\"number_of_led\":225,\"led_profile\":\"RGB\",\"frame_rate\":25,\"movie_capacity\":719,\"copyright\":\"LEDWORKS 2017\"}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    14:35:05.859	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <fw/version>
    14:35:05.860	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
    14:35:05.860	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
    14:35:05.861	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
    14:35:05.919	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: {"version":"2.3.5","code":1000}
    14:35:05.920	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    patrickbs96P
    patrickbs96P
    patrickbs96
    @W0RSCHD Versuche es bitte erneut. Da war noch ein Fehler in der curl Anfrage bei der Übergabe des Tokens...
    W 1 Antwort Letzte Antwort
    • patrickbs96P patrickbs96
      W
      W
      W0RSCHD
      schrieb am zuletzt editiert von W0RSCHD
      @patrickbs96 jetzt klappts juhuuu TOP, Danke :)
      Es kommt nur dieser Error dauernd im Log, aber an sich gehts
      javascript.0	2020-12-06 21:52:15.249	error	(11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.timer] [Twinkly.GET.timer] undefined (undefined), Headers: {"X-Auth-Token":"Knavqszdq6s=","Content-Type":"application/json"}
      patrickbs96P 1 Antwort Letzte Antwort
      • W W0RSCHD
        patrickbs96P
        patrickbs96P
        patrickbs96
        schrieb am zuletzt editiert von patrickbs96
        @W0RSCHD Super, das freut mich zu hören :-)
        Anscheinend wird der Twinkly-Code nicht immer übergeben, dadurch steht dort undefined. Ich habe den Fall ausgeschlossen und der sollte daher keine Fehler mehr produzieren.
        Da es mit curl mit beiden Generationen funktioniert, habe ich die Verarbeitung für beide gleichgezogen. Dadurch entfällt dann auch die Einstellung für curl. Könntest du das eventuell auch einmal testen @siggi85 ?
        EDIT: Noch nicht testen, bei mir kommen aktuell noch Fehler.
        EDIT 2: Bei mir kamen plötzlich "Invalid Token" Meldung und hatten Probleme verursacht. Ich habe es hoffentlich behoben (Es kamen leider keine mehr mit denen ich das testen konnte.)
        siggi85S W 2 Antworten Letzte Antwort
          siggi85S
          siggi85S
          siggi85
          @patrickbs96 Auch die neue Version des Skriptes funktioniert bei mir. Ich benutze weiterhin die Version ohne curl, aber hatte mit dem aktuellen Skript keine Probleme.
          Ich habe übrigens den Link zu deinem Skript im ersten Beitrag ergänzt.
            W
            W
            W0RSCHD
            @patrickbs96 klappt nun auch hier ohne Error, Dankeschön! thumbsup
            siggi85S 1 Antwort Letzte Antwort
            • W W0RSCHD
              siggi85S
              siggi85S
              siggi85
              @W0RSCHD Super!
              @patrickbs96 Good job! 👍
              • flipjizF
                flipjizF
                flipjiz
                Moin! Vorweg: Danke für eure Arbeit :D
                Muss ich die Datei runterladen und irgendwo hinschieben oder einfach über die ioBroker Oberfläche ein neues Skript mit dem Inhalt hinzufügen?
                Ich hab es einfach mal unter Common reingeworfen aber dort gibt es diese Fehler beim Starten:
                2020-12-08 16:49:59.946 - info: javascript.0 (22601) Start javascript script.js.common.twinkly
                2020-12-08 16:49:59.960 - error: javascript.0 (22601) script.js.common.twinkly compile failed:
                at script.js.common.twinkly:221
                2020-12-08 16:49:59.961 - error: javascript.0 (22601) }, POLLING_IN_SEK * 1_000);
                2020-12-08 16:49:59.962 - error: javascript.0 (22601) ^
                2020-12-08 16:49:59.963 - error: javascript.0 (22601) SyntaxError: Invalid or unexpected token
                2020-12-08 16:49:59.964 - error: javascript.0 (22601) at new Script (vm.js:83:7)
                2020-12-08 16:49:59.964 - error: javascript.0 (22601) at Object.createScript (vm.js:277:10)
                2020-12-08 16:49:59.965 - error: javascript.0 (22601) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
                2020-12-08 16:49:59.966 - error: javascript.0 (22601) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
                2020-12-08 16:49:59.967 - error: javascript.0 (22601) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17)
                2020-12-08 16:49:59.967 - error: javascript.0 (22601) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17)
                2020-12-08 16:49:59.968 - error: javascript.0 (22601) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
                2020-12-08 16:49:59.969 - error: javascript.0 (22601) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                2020-12-08 16:49:59.969 - error: javascript.0 (22601) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                2020-12-08 16:49:59.970 - error: javascript.0 (22601) at process._tickCallback (internal/process/next_tick.js:68:7)
                • flipjizF flipjiz
                  patrickbs96P
                  patrickbs96P
                  patrickbs96
                  @flipjiz Genau richtig, neues Skript unter Common erstellen und den Inhalt hineinkopieren. Danach musst du nur den Abschnitt mit den devices anpassen, so wie es in dem Beispiel im Skript oder auf der GitHub Seite gezeigt wird.
                  const devices = {
                      Twinkly1 : {                                         // State-Name in ioBroker
                          name           : 'Twinkly Lichterkette 1',       // Name für ioBroker (Falls nicht hinterlegt wird der State-Name verwendet)
                          ipAdresse      : '192.168.178.52',               // IP-Adresse von der Twinkly-Lichterkette
                          connectedState : 'ping.0.Twinkly_Lichterkette_1' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
                      Twinkly2 : {                                         // State-Name in ioBroker
                          name           : 'Twinkly Lichterkette 2',       // Name für ioBroker (Falls nicht hinterlegt wird der State-Name verwendet)
                          ipAdresse      : '192.168.178.53',               // IP-Adresse von der Twinkly-Lichterkette
                          connectedState : 'ping.0.Twinkly_Lichterkette_2' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
                  Ich vermute mal, dass dort ein Fehler bei den devices ist. Könntest du mir den Abschnitt einmal zeigen?
                  flipjizF 1 Antwort Letzte Antwort
                    const devices = {
                    flipjizF
                    flipjizF
                    flipjiz
                    @patrickbs96
                     * Settings
                    const PATH_ID          = 'javascript.0.MyDevices.Twinkly.'; // Pfad für die Datenpunkte
                    const POLLING_IN_SEK   = 60;                                // Wie oft sollen die Daten abgefragt werden
                    const EXTENDED_LOGGING = true;                             // Mehr Informationen loggen
                    const devices = {
                        Twinkly : {                                   // State-Name in ioBroker
                            name           : 'Twinkly',               // Name für ioBroker (Falls nicht hinterlegt wird der State-Name verwendet)
                            ipAdresse      : '192.168.25.168',               // IP-Adresse von der Twinkly-Lichterkette
                            connectedState : 'ping.0.Twinkly' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
                    • flipjizF flipjiz
                      @patrickbs96
                       * Settings
                      const devices = {
                      patrickbs96P
                      patrickbs96P
                      patrickbs96
                      @flipjiz Das sieht soweit richtig aus. Kannst du mir das gesamte Skript einmal schicken?
                        flipjizF
                        flipjizF
                        flipjiz
                        @patrickbs96
                        Ich habe im Skript einfach die Unterstriche in Zeile 221 und 222 entfernt:
                                    }, 2_000);
                        zu
                                        }, POLLING_IN_SEK * 1000);
                                    }, 2000);
                        nun läuft es!
                        • flipjizF flipjiz
                          @patrickbs96
                                      }, 2_000);
                          zu
                                      }, 2000);
                          nun läuft es!
                          patrickbs96P
                          patrickbs96P
                          patrickbs96
                          @flipjiz Komisch hätte nicht gedacht, dass das Fehler verursacht. Dann werde ich das mal im Skript korrigieren :-)
                          • siggi85S siggi85
                            Ursprünglich habe ich ein kleines Blockly geschrieben (siehe unten in diesem Post). Allerdings hat mittlerweile @patrickbs96 ein wesentlich umfangreiches Skript erstellt, um Twinkly Systeme zu steuern. Die aktuelle Version davon könnt ihr hier finden.
                            Für alle Fälle lasse ich mein altes Blockly hier drin, aber ich würde definitiv das Skript von @patrickbs96 empfehlen.
                            Alt:
                            Ich habe ein kleines Blockly geschrieben, was über Curl Aufrufe die API anfragt und damit Basisfunktionen steuerbar macht wie an/aus (letzte Szene) und die Helligkeit. Die Datenpunkte habe ich unter 0_userdata.0 gepackt.
                            Damit das Ganze funktioniert, einfach die Datenpunkte importieren und im Blockly die IP-Adresse eures Twinkly Devices eintragen. Zusätzlich mit im Javascript Adapter das exec Kommando erlaubt sein. (Konfiguration in der JavaScript Instanz)
                            Blockly
                             <variables>
                               <variable id="C2}3(QK:sjn_0;M@WXM6">ip-address</variable>
                               <variable id="Li8l,iD*a4lAUfTrR./#">result</variable>
                               <variable id="ATDr!5*=f1mXSwF*B31X">onoff</variable>
                               <variable id="tvi|}J~k+`CSxDW?#-_G">login_list</variable>
                               <variable type="timeout" id="timeout2">timeout2</variable>
                               <variable type="timeout" id="timeout3">timeout3</variable>
                               <variable type="timeout" id="timeout">timeout</variable>
                             </variables>
                             <block type="comment" id="7aO~bSI=}sBUF]!Uj5VW" x="113" y="-12">
                               <field name="COMMENT">Hier die IP-Adresse des Twinkly angeben.</field>
                               <next>
                                 <block type="variables_set" id="})]:dOnZEgaB;GwFMYm7">
                                   <field name="VAR" id="C2}3(QK:sjn_0;M@WXM6">ip-address</field>
                                   <value name="VALUE">
                                     <block type="text" id="UPk-=X649M@ReWw=d!/Y">
                                       <field name="TEXT">192.168.1.241</field>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="on_ext" id="hjfZPnTX~Ue*9(8]/!;C">
                                       <value name="OID0">
                                         <shadow type="field_oid" id="9twVsr7m@F^_y.SIh3v/">
                                           <field name="oid">0_userdata.0.devices.twinkly1.on</field>
                                         </shadow>
                                       </value>
                                       <statement name="STATEMENT">
                                         <block type="controls_if" id="Vyh(4M|:$PiwH3:ODZ(v">
                                           <value name="IF0">
                                             <block type="on_source" id=".8e69^VPY]Vwj!#QB8;b">
                                             </block>
                                           </value>
                                           <statement name="DO0">
                                             <block type="variables_set" id="[Pbb5axB^[hOzmHwfPcs">
                                               <field name="VAR" id="ATDr!5*=f1mXSwF*B31X">onoff</field>
                                                 <block type="text" id="qYAqrB@?4{kDiZ*iP5Nv">
                                                   <field name="TEXT">movie</field>
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                           <value name="IF1">
                                             <block type="logic_negate" id="[)WH1r7P]c-i1[{xOXce">
                                               <value name="BOOL">
                                                 <block type="on_source" id="LfiaUSvy[Zo`?iQA0%AA">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <statement name="DO1">
                                             <block type="variables_set" id="$75d~3~;/E1{z?f6Uw`7">
                                                 <block type="text" id="t`KFGE2EgS={pHOe({dy">
                                                   <field name="TEXT">off</field>
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                           <next>
                                             <block type="exec" id="a8Xsf6X|RT_RKWu+m|4D">
                                               <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                               <field name="WITH_STATEMENT">TRUE</field>
                                               <field name="LOG"></field>
                                               <value name="COMMAND">
                                                 <shadow type="text">
                                                 </shadow>
                                                 <block type="text_join" id="x.E)Ijwm[WHV!_bPRK4/">
                                                   <mutation items="9"></mutation>
                                                   <value name="ADD0">
                                                     <block type="text" id="bMn%~Q14lVR9+BCwRR/1">
                                                       <field name="TEXT">curl -d '{"mode":"</field>
                                                     </block>
                                                   </value>
                                                   <value name="ADD1">
                                                     <block type="variables_get" id="6yJXT{FImP5pG}/rrtNy">
                                                     </block>
                                                   </value>
                                                   <value name="ADD2">
                                                     <block type="text" id="^ujE4oo_X%]da4,(ppuL">
                                                       <field name="TEXT">"}' -H 'Content-Type: application/json</field>
                                                     </block>
                                                   </value>
                                                   <value name="ADD3">
                                                     <block type="text_newline" id="c!_Px216Os[.$S/~rarw">
                                                       <field name="Type">\n</field>
                                                     </block>
                                                   </value>
                                                   <value name="ADD4">
                                                     <block type="text" id="$Fg2yhXiAQ){16U@!ZSu">
                                                       <field name="TEXT">X-Auth-Token: </field>
                                                     </block>
                                                   </value>
                                                   <value name="ADD5">
                                                     <block type="get_value" id="IXl+3AbS2B.l]YvbqzM6">
                                                       <field name="OID">0_userdata.0.devices.twinkly1.token</field>
                                                     </block>
                                                   </value>
                                                   <value name="ADD6">
                                                     <block type="text" id="S{EEHm.[zP|vcm#1tnS#">
                                                       <field name="TEXT">'  http://</field>
                                                     </block>
                                                   </value>
                                                   <value name="ADD7">
                                                     <block type="variables_get" id="]u@TMc}oUr*ZKNMfa4*r">
                                                     </block>
                                                   </value>
                                                   <value name="ADD8">
                                                     <block type="text" id="bz;89=2*~U#c3SZm,`3R">
                                                       <field name="TEXT">/xled/v1/led/mode</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                 <block type="control" id=")*EuNf:*?Mej|oX]c[YG">
                                                   <field name="OID">0_userdata.0.devices.twinkly1.last_response</field>
                                                     <block type="variables_get" id="sO6_Jt^$^o?%u_FndEof">
                                                       <field name="VAR" id="Li8l,iD*a4lAUfTrR./#">result</field>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="controls_if" id="6G?]0D()J)}!$||^GZ[g">
                                                       <value name="IF0">
                                                         <block type="logic_compare" id="{`cuuloZIeqXKe;Iydaw">
                                                           <field name="OP">EQ</field>
                                                           <value name="A">
                                                             <block type="variables_get" id=".|80~sPZrcTq)~D%FLqS">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="text" id="V1j|Yla.{Pkhx;t!dL5A">
                                                               <field name="TEXT">Invalid Token</field>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                         <block type="timeouts_settimeout" id="*hEGRE,x!rFyGvx1sGnk">
                                                           <field name="NAME">timeout2</field>
                                                           <field name="DELAY">1000</field>
                                                           <field name="UNIT">ms</field>
                                                             <block type="procedures_callnoreturn" id="47rDf|TIj){(r%S/jL|t">
                                                               <mutation name="tokenerstellung"></mutation>
                                                               <next>
        <block type="exec" id="vmrb/I[xcD|UrCR{N5,}">
        <shadow type="text" id="1oqX0]_@1GCaqA|AYG9V">
        </shadow>
        <block type="text_join" id=";|wMTJLvzMlbPBE.f}8(">
        <value name="ADD0">
        <block type="text" id="vSqJqFViMtF_b70KZZ4U">
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="iL*:FiISRruR#*B:SpWU">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="_H7ZwE!fF3Lh:;B6+mC`">
        </block>
        </value>
        <value name="ADD3">
        <block type="text_newline" id="EMmO8}AnS:G1L0.zG*(K">
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="IffU.a}O8pGD]^*9G,e5">
        </block>
        </value>
        <value name="ADD5">
        <block type="get_value" id="KN#wwJ9wRg[}}Tbh4A)S">
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="?QBxH#Gn#va8-Fur=Mri">
        </block>
        </value>
        <value name="ADD7">
        <block type="variables_get" id="F8ff%~_KvjsS/r{.$)!A">
        </block>
        </value>
        <value name="ADD8">
        <block type="text" id="bZ1Z,*N[OcaWiEp;f%P8">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="Dq-:j;brnrXMKn(MM*]8">
        <block type="variables_get" id="%1_~*tS$$o%-C~FLfV,A">
        </block>
        </value>
        </block>
        </statement>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                       <next>
                                         <block type="on_ext" id="*d77h3XvC|Tj~C2z*Gd`">
                                           <value name="OID0">
                                             <shadow type="field_oid" id="sl:%ZP;c-3T~K6vz?rya">
                                               <field name="oid">0_userdata.0.devices.twinkly1.bri</field>
                                             </shadow>
                                           </value>
                                             <block type="exec" id="SwV21J;Rhw=V[z^`IJw,">
                                                 </shadow>
                                                 <block type="text_join" id="9G(1o6:8.FmD^^LOK8Cn">
                                                   <value name="ADD0">
                                                     <block type="text" id="+GA1[uhyM:KfX1qzqUEF">
                                                       <field name="TEXT">curl -d '{"value":</field>
                                                     </block>
                                                   </value>
                                                   <value name="ADD1">
                                                     <block type="on_source" id="_l@jyLbrNk{7FxZj$Zmh">
                                                     </block>
                                                   </value>
                                                   <value name="ADD2">
                                                     <block type="text" id="|7^t}Cu}B6~Y1mC(0#UL">
                                                       <field name="TEXT">,"mode":"enabled","type":"A"}' -H 'Content-Type: application/json</field>
                                                     </block>
                                                   </value>
                                                   <value name="ADD3">
                                                     <block type="text_newline" id="cm,kmJNBdr]RQ%aT^mz.">
                                                     </block>
                                                   </value>
                                                   <value name="ADD4">
                                                     <block type="text" id="z;)h^VxAjQk8sNE@yXm6">
                                                     </block>
                                                   </value>
                                                   <value name="ADD5">
                                                     <block type="get_value" id="SN0q;T8G^i,z`[mK|cbi">
                                                     </block>
                                                   </value>
                                                   <value name="ADD6">
                                                     <block type="text" id="Qs]@)sCx^T~4~O:-~N%]">
                                                     </block>
                                                   </value>
                                                   <value name="ADD7">
                                                     <block type="variables_get" id="Q3qO2s#P(jH/]+s=`sg;">
                                                     </block>
                                                   </value>
                                                   <value name="ADD8">
                                                     <block type="text" id="[GRuP4kVQ)yBXm_~?XLn">
                                                       <field name="TEXT">/xled/v1/led/out/brightness</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                 <block type="control" id="w46r4o:A,,aVgr@NCGW2">
                                                     <block type="variables_get" id="VXXDL).b0.4NB_KKb(+v">
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="controls_if" id="+3OyyHh$$_UZAgnj,!EX">
                                                       <value name="IF0">
                                                         <block type="logic_compare" id="*r7*K4LHSml!_+c@?0nf">
                                                           <value name="A">
                                                             <block type="variables_get" id="oFL-r!ZE;^X3v-E5{q@r">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="text" id=".crTI6#$|W5R_}1|8c~D">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                         <block type="timeouts_settimeout" id="]!]T:3c[:^C]UD/4vpaV">
                                                           <field name="NAME">timeout3</field>
                                                             <block type="procedures_callnoreturn" id="EiS$0K4lv~,deH6%Vqi*">
                                                               <next>
        <block type="exec" id="{nu5Ft~q(!9,39eE8O,H">
        <shadow type="text" id="]MnC9RK!/]8A^d2-p{.$">
        </shadow>
        <block type="text_join" id="y6bUQx$R#^T}AEn?e(^r">
        <value name="ADD0">
        <block type="text" id="m:@7^x{FFQvWHWfZ?K0r">
        </block>
        </value>
        <value name="ADD1">
        <block type="on_source" id="{A,ZJ=}qtv?/9{U-J5Z}">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="DaHQVOV.9DNj`NPEJ;LE">
        </block>
        </value>
        <value name="ADD3">
        <block type="text_newline" id="1#3uF7ndLmSv1*Am2g[7">
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="KDy19da_TUp?9`Xb@L|F">
        </block>
        </value>
        <value name="ADD5">
        <block type="get_value" id="7_ycWMaJu(pS;yvdSQId">
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="3C;CZ]:wKA*AK6l`f8:}">
        </block>
        </value>
        <value name="ADD7">
        <block type="variables_get" id="K4er1ePuhS)xrpTBSh1+">
        </block>
        </value>
        <value name="ADD8">
        <block type="text" id="BLz=[InZOBRg#-5m/jvo">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="1%ERGs|hD2^:gC[sA^}z">
        <block type="variables_get" id="L1-0?qL3zOPU)]Q8L-^~">
        </block>
        </value>
        </block>
        </statement>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                             <block type="on_ext" id="*=Rz8c^+(Uep[d%kgN^Z" x="913" y="113">
                               <value name="OID0">
                                 <shadow type="field_oid" id="b-H}2tTFUu5fH^xR5S0G">
                                   <field name="oid">0_userdata.0.devices.twinkly1.generate_token</field>
                                 </shadow>
                               </value>
                                 <block type="controls_if" id="w)JwIcM8fG[^G2o@g#IU">
                                   <value name="IF0">
                                     <block type="on_source" id="S7l^Ygh^qp/THpb#N/Vi">
                                     </block>
                                   </value>
                                     <block type="procedures_callnoreturn" id="glH8Vnu3lq|zhdL*!B4P">
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                             <block type="procedures_defnoreturn" id="^9??;ZMVyU07(54V3Eu6" x="938" y="388">
                               <field name="NAME">tokenerstellung</field>
                               <statement name="STACK">
                                 <block type="exec" id="Bq5LNu.#~ON+t,OLyd(I">
                                     <shadow type="text" id="O9{;*_0^t`dZ%{JAl{J{">
                                       <field name="TEXT"></field>
                                     </shadow>
                                     <block type="text_join" id="#jTB:KIs,db`$/4bj!]I">
                                       <value name="ADD0">
                                         <block type="text" id="lO4T;Ob7;f$%g?a{lMLD">
                                           <field name="TEXT">curl -d '{"challenge": "AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="}' -H 'Content-Type: application/json' http://</field>
                                         </block>
                                       </value>
                                       <value name="ADD1">
                                         <block type="variables_get" id="N(fQwlPipS~;`%=JO?7G">
                                         </block>
                                       </value>
                                       <value name="ADD2">
                                         <block type="text" id=")UJ3i2ob.UVF3E3)9TO@">
                                           <field name="TEXT">/xled/v1/login</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                     <block type="control" id="Y3E;QMmY1QNsX#EJBcAF">
                                       <field name="OID">0_userdata.0.devices.twinkly1.invalid_token_counter</field>
                                         <block type="math_arithmetic" id="`C:HNYfvK.FSEllWcW:W">
                                           <field name="OP">ADD</field>
                                           <value name="A">
                                             <shadow type="math_number" id="^:exn5EkqE)Xz?D|SKy}">
                                               <field name="NUM">1</field>
                                             </shadow>
                                             <block type="get_value" id="vy(qI~n0+neTVRz79^xM">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <shadow type="math_number" id="BE#f|Dp3linv[rzbqD7,">
                                             </shadow>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="control" id="us?L?4O4rHFC5D!fDsdJ">
                                             <block type="variables_get" id="7S0c3_b[:aEVF](uS:iX">
                                             </block>
                                           </value>
                                           <next>
                                             <block type="debug" id="7`oD1gOEU#uh+EL?AUc.">
                                               <value name="TEXT">
                                                 <shadow type="text" id="^IpRqdiDT*-j/Q^/QW,_">
                                                   <field name="TEXT">Starte Tokenerstellung</field>
                                                 </shadow>
                                               </value>
                                               <next>
                                                 <block type="debug" id="Xs6X/K_nR}k-ykL[M`16" disabled="true">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="js$]6ILdYcAJhz8W=;/n">
                                                     </shadow>
                                                     <block type="variables_get" id="aI{(nALcBG$eenM_JT=b">
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="variables_set" id="B5y.Gk@ojBh]^gBn7Ri|">
                                                       <field name="VAR" id="tvi|}J~k+`CSxDW?#-_G">login_list</field>
                                                         <block type="lists_split" id="`#WZQy~#_]DAD#ySTlVV">
                                                           <mutation mode="SPLIT"></mutation>
                                                           <field name="MODE">SPLIT</field>
                                                           <value name="INPUT">
                                                             <block type="variables_get" id="M]:lZztzzg!QI;t@mWzg">
                                                             </block>
                                                           </value>
                                                           <value name="DELIM">
                                                             <shadow type="text" id="f;7]A0]C9Iorq7FUh*+I">
                                                               <field name="TEXT">"</field>
                                                             </shadow>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="control" id="2`c=|y/iww3.=^}.8I59">
                                                             <block type="lists_getIndex" id="F1-qcRR[;NFa^DMlqV{o">
                                                               <mutation statement="false" at="true"></mutation>
                                                               <field name="MODE">GET</field>
                                                               <field name="WHERE">FROM_START</field>
        <block type="variables_get" id="R2XhFDen:RGmV1nikpp[">
        </block>
                                                               </value>
                                                               <value name="AT">
        <block type="math_number" id="270Qn=t=#(OQM?R3r!+u">
        <field name="NUM">4</field>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="timeouts_settimeout" id=",hW#SP83S3D]=+0I3JoQ">
        <block type="debug" id="^=K4IGZtu1BUem~dDnFk" disabled="true">
        <value name="TEXT">
        <shadow type="text" id=".g[a3HxSe}og?21x+^Qk">
        </shadow>
        <block type="get_value" id="qV_*%10mt5bVx~B/53[A">
        </block>
        </value>
        <next>
        <block type="exec" id="F?4D@ZgD!6%*)kMw+C`#">
        <shadow type="text" id="hpVJ5z*?j?fV#n/rTh}i">
        </shadow>
        <block type="text_join" id="9#Ev1:g,Ufv^SHikoIon">
        <mutation items="7"></mutation>
        <value name="ADD0">
        <block type="text" id="7CCd?lZeczQAQpjj6(??">
        <field name="TEXT">curl -d '{"challenge-response": "4ecffc0c669796ea843c4ef4dc7d2a33cf081d92"}' -H 'Content-Type: application/json</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="text_newline" id="{79JO}FxsmNg_rO],+T^">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="$n6sdnx`e!VGaK*!He[G">
        </block>
        </value>
        <value name="ADD3">
        <block type="get_value" id="L^*fU+dFPAr!s;E{H`EJ">
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="F5J!U?U$yq-,3xS7UPO(">
        </block>
        </value>
        <value name="ADD5">
        <block type="variables_get" id="{rr$];i8Kyl{k0boEz[S">
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="$`0sn]I1P5!8_rl3`:hx">
        <field name="TEXT">/xled/v1/verify</field>
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="|4x]CJ+``GuPe~viuF}*">
        <block type="variables_get" id="9HuL3|uRhcfeHa.dU$G6">
        </block>
        </value>
        <next>
        <block type="controls_if" id="JjJG3UmSBHE@6./RA~1K">
        <value name="IF0">
        <block type="logic_compare" id="9GB#=W%O2|z3oZc(QCV)">
        <value name="A">
        <block type="variables_get" id="AsZF48_sLRx}5(@:O=hQ">
        </block>
        </value>
        <value name="B">
        <block type="text" id="1fN*O!Pf=sm`ovt,0/nN">
        <field name="TEXT">{"code":1000}</field>
        </block>
        </value>
        </block>
        </value>
        <block type="debug" id="NHzT/CsYQxEDy9~R6MSQ">
        <value name="TEXT">
        <shadow type="text" id="#fx%mvWHriHU8Vw{rnw8">
        <field name="TEXT">Tokenerstellung erfolgreich.</field>
        </shadow>
        </value>
        <next>
        <block type="control" id="{9;o6mIpuEf`7xT-n)3L">
        <field name="OID">0_userdata.0.devices.twinkly1.token_verify</field>
        <block type="logic_boolean" id="}=yzK!`!Q@E_hN):CP_d">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="debug" id="+2J+Qkd$;V|:M.)E)4qK">
        <value name="TEXT">
        <shadow type="text" id="}TE#6+G@7Zq*9jwGt]}`">
        <field name="TEXT">Tokenerstellung fehlgeschlagen.</field>
        </shadow>
        </value>
        <next>
        <block type="control" id="2;nVgYFKxBDzpT+aGsxq">
        <block type="logic_boolean" id="V(w(5r+]OyK6/=sn{xA@">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                               </statement>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                            </xml>
                            Datenpunkte
                            0_userdata.0.devices.twinkly1.json
                            Die API Dokumentation habe ich hierher.
                            Ich habe auch versucht die MQTT Konfiguration anzupassen, jedoch scheint diese mittlerweile verschlüsselt zu sein (zumindest laut meinen Netzwerk Mitschnitten). Man kann den Datenverkehr zwar zum ioBroker schicken, der kann ohne passendes Zertifikat aber leider nichts damit anfangen. Ich konnte die Verschlüsselung über die API leider nicht deaktvieren oder anpassen. Schade, denn über MQTT lassen sich anscheinend auch die jeweiligen Szenen ansteuern.
                            Achja, ich bin kein Programmierer. Bspw. ist die direkte Umsetzung in Javascript sicher wesentlich eleganter und/oder das gleichzeitige packen in einen Adapter. Ich bitte um Nachsicht und hoffe einfach, dass ihr (so wie ich jetzt auch) zumindest zufrieden seid, wenn ihr euer Twinkly nun per ioBroker zumindest an und aus schalten könnt. :)
                            patrickbs96P
                            patrickbs96P
                            patrickbs96
                            @siggi85 @W0RSCHD Ich habe den Adapter soweit fertiggestellt. Mir fehlen zwar noch die Übersetzungen aber vom technischen her ist der fertig. Würde mich freuen, wenn ihr den testen würdet :-)
                              M
                              M
                              MCU
                              @patrickbs96 Wie muss man den Adapter einstellen, bekomme keinen Connect. Obwohl die Instanz auf grün ist.
                              Beim Speichern bekomme ich immer:
                              Bin angemeldet als User. v2.12.9(build 5611) als App von gestern.
                              • M MCU
                                patrickbs96P
                                patrickbs96P
                                patrickbs96
                                @MCU Sorry, da war ich wohl etwas zu voreilig mit der Veröffentlichung... Ist mein erster Adapter gewesen, da hatte ich bei der Menge an Aufgaben für die Veröffentlichung das wohl vergessen... Ich habe die Anleitung angepasst.
                                Ändert trotzdem nichts an deinem Fehler, es ist soweit alles richtig konfiguriert. Könntest du dir die neue Version holen, den Adapter dann auf Debug stellen und mir das Log schicken? Dann kann ich zumindest prüfen, weshalb der nicht startet.
                                @apollon77 Die Fehlermeldung beim Speichern bekomme ich komischerweise jetzt auch (raspberry pi). Unter Windows habe ich keine Fehler erhalten. Komischerweise kriege ich die Fehlermeldung auch, wenn ich die Einstellungen direkt am Datenpunkt system.adapter.twinkly.0 ändere. Hast du eine Idee woran das liegen kann?
                                apollon77A patrickbs96P M 3 Antworten Letzte Antwort
                                  apollon77A
                                  apollon77A
                                  @patrickbs96 welchen Fehler? Den oben mit dem invalid token? Dann checke mal das skript, dann ist da ein Fehler drin
                                  • apollon77A apollon77
                                    patrickbs96P
                                    patrickbs96P
                                    patrickbs96
                                    @apollon77 Ne nicht den Invalid Token, sondern das beim Speichern die Meldung kommt "Einige Daten wurden nicht gespeichert. Verwerfen?"
                                      apollon77A
                                      apollon77A
                                      #66
                                      @patrickbs96 hm ... da muss mal schauen, keine ahnung ... Bist du in einem der dev chnnel im discord oder telegram? Frag mal da ... bzw kommentiere es im repo, muss man schauen
                                        patrickbs96P
                                        patrickbs96P
                                        patrickbs96
                                        #67
                                        @apollon77 In welchem der vielen Räume im Discord würde das denn passen? #adapter?
                                        Kommentiere im Repo meinst du mein eigenes oder das vom ioBroker?
                                          patrickbs96P
                                          patrickbs96P
                                          patrickbs96
                                          #68
                                          Ich habe zum Testen einen eigenen Forum Eintrag erstellt: https://forum.iobroker.net/topic/39632/new-adapter-twinkly
                                          84.1k
