  4. Twinkly - Basisfunktionen mit ioBroker steuern
    apollon77A
69 Beiträge 8 Kommentatoren 15.4k Aufrufe 9 Beobachtet
  • W W0RSCHD
    @patrickbs96
    Danke, Authentication funktioniert, es spuckt aber noch Fehler aus,
    hier mal der Log
    10:30:07.001	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
    10:30:07.074	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:31:06.063	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607247061634,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607222544951}
    10:31:06.074	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:31:06.075	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
    10:31:06.338	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:190:29
    10:31:06.338	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:188:25)
    10:31:06.338	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mode, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:31:06.339	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.on, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:31:06.340	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
    10:31:06.627	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:196:45
    10:31:06.627	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:195:25)
    10:31:06.628	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.bri, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:31:06.629	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
    10:31:06.829	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:200:44
    10:31:06.829	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:199:25)
    10:31:06.829	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.name, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:31:06.830	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
    10:31:06.969	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mqtt, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:31:06.972	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
    10:31:07.088	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.timer, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:31:07.093	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
    10:31:07.232	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.details, state={"val":"{\"product_name\":\"Twinkly\",\"product_version\":\"16\",\"hardware_version\":\"7\",\"flash_size\":16,\"led_type\":6,\"led_version\":\"1\",\"product_code\":\"TW225SEUP07\",\"device_name\":\"Twinkly_BA1A63\",\"uptime\":\"3842109\",\"hw_id\":\"00ba1a63\",\"mac\":\"84:f3:eb:ba:1a:63\",\"max_supported_led\":255,\"base_leds_number\":225,\"number_of_led\":225,\"led_profile\":\"RGB\",\"frame_rate\":25,\"movie_capacity\":719,\"copyright\":\"LEDWORKS 2017\"}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:31:07.234	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
    10:31:07.383	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:32:06.064	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607247122573,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607222544951}
    10:32:06.064	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:32:06.069	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
    10:32:06.148	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:190:29
    10:32:06.149	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:188:25)
    10:32:06.149	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mode, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:32:06.150	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.on, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:32:06.151	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
    10:32:06.241	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:196:45
    10:32:06.242	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:195:25)
    10:32:06.242	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.bri, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:32:06.243	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
    10:32:06.321	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:200:44
    10:32:06.322	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:199:25)
    10:32:06.322	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.name, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:32:06.324	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
    10:32:06.399	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mqtt, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:32:06.401	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
    10:32:06.485	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.timer, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:32:06.489	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
    10:32:06.555	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.details, state={"val":"{\"product_name\":\"Twinkly\",\"product_version\":\"16\",\"hardware_version\":\"7\",\"flash_size\":16,\"led_type\":6,\"led_version\":\"1\",\"product_code\":\"TW225SEUP07\",\"device_name\":\"Twinkly_BA1A63\",\"uptime\":\"3901446\",\"hw_id\":\"00ba1a63\",\"mac\":\"84:f3:eb:ba:1a:63\",\"max_supported_led\":255,\"base_leds_number\":225,\"number_of_led\":225,\"led_profile\":\"RGB\",\"frame_rate\":25,\"movie_capacity\":719,\"copyright\":\"LEDWORKS 2017\"}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    10:32:06.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: pm6be3o9Vac= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
    10:32:06.618	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
    Schalten kann ich auch noch nichts, es scheint nur die Authentifizierung zu klappen bis jetzt.
    patrickbs96P
    patrickbs96P
    patrickbs96
    @W0RSCHD Könntest du bitte das erweiterte Logging aktivieren und mir dann das Log schicken? Ich habe das Gefühl als werden die Inhalte anders übermittelt als bei der 2. Generation.
    W 1 Antwort Letzte Antwort
    • patrickbs96P patrickbs96
      W
      W
      W0RSCHD
      @patrickbs96
      hier mal ein Auszug
      14:34:03.146	info	javascript.0 (11366) Start javascript script.js.Schaltungen.Twinkly_JS
      14:34:03.201	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setTimeout(ms=2000)
      14:34:03.202	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: onStop(timeout=500)
      14:34:03.204	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: registered 0 subscriptions and 0 schedules
      14:34:03.215	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getObject(id=javascript.0.Weihnachtsbaum, enumName=undefined) => {"common":{"name":"Twinkly","role":"state","type":"mixed"},"native":{},"type":"channel","from":"system.adapter.javascript.0","user":"system.user.admin","ts":1607163615438,"_id":"javascript.0.Weihnachtsbaum","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      14:34:03.216	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setObject(id=javascript.0.Weihnachtsbaum, obj={"common":{"name":"Twinkly","role":"state","type":"mixed"},"native":{},"type":"channel","from":"system.adapter.javascript.0","user":"system.user.admin","ts":1607163615438,"_id":"javascript.0.Weihnachtsbaum","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}})
      14:34:05.203	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: subscribe: {"pattern":{"id":{},"change":"ne","ack":false,"q":0},"name":"script.js.Schaltungen.Twinkly_JS"}
      14:34:05.205	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setInterval(ms=60000)
      14:35:05.206	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: getState(id=ping.0.iobroker.192_168_178_175, timerId=undefined) => {"val":true,"ack":true,"ts":1607261680414,"q":0,"from":"system.adapter.ping.0","user":"system.user.admin","lc":1607256158755}
      14:35:05.207	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.connected, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
      14:35:05.208	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <led/mode>
      14:35:05.209	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token expired, will refresh
      14:35:05.212	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] curl -d '{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="}' -H 'Content-Type: application/json' http://192.168.178.175/xled/v1/login
      14:35:05.212	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -d '{"challenge":"AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="}' -H 'Content-Type: application/json' http://192.168.178.175/xled/v1/login
      14:35:05.303	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"authentication_token":"vZa1C4f9U6E=","authentication_token_expires_in":14400,"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a","code":1000}
      14:35:05.305	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._post] <verify>, {"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}, {"X-Auth-Token":"vZa1C4f9U6E="}
      14:35:05.306	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
      14:35:05.307	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.POST] curl -d '{"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}' -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/verify
      14:35:05.308	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -d '{"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}' -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/verify
      14:35:05.376	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doPostRequest] body: {"code":1102}
      14:35:05.378	warn	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.POST.verify] 1102 (Error), Data: {"challenge-response":"9f0fd8de4ee5869f596dbc60f9cafeea378ff79a"}, Headers: {"X-Auth-Token":"vZa1C4f9U6E=","Content-Type":"application/json"}, Body: {"code":1102}
      14:35:05.380	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
      14:35:05.380	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/mode
      14:35:05.480	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
      14:35:05.485	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:190:29
      14:35:05.485	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:188:25)
      14:35:05.485	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mode, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
      14:35:05.486	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.on, state={"val":true,"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
      14:35:05.487	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <led/out/brightness>
      14:35:05.488	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
      14:35:05.488	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
      14:35:05.489	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/led/out/brightness
      14:35:05.549	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
      14:35:05.552	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:196:45
      14:35:05.553	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:195:25)
      14:35:05.553	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.bri, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
      14:35:05.555	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <device_name>
      14:35:05.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
      14:35:05.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
      14:35:05.557	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/device_name
      14:35:05.621	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
      14:35:05.625	warn	javascript.0 (11366) at script.js.Schaltungen.Twinkly_JS:200:44
      14:35:05.626	warn	javascript.0 (11366) at Object.<anonymous> (script.js.Schaltungen.Twinkly_JS:199:25)
      14:35:05.626	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.name, state={"val":{"ack":true},"ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
      14:35:05.627	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <mqtt/config>
      14:35:05.628	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
      14:35:05.628	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
      14:35:05.629	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/mqtt/config
      14:35:05.702	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
      14:35:05.703	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.mqtt, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
      14:35:05.705	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <timer>
      14:35:05.705	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
      14:35:05.706	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
      14:35:05.706	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/timer
      14:35:05.774	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: "Invalid Token."
      14:35:05.776	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.timer, state={"val":"{}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
      14:35:05.777	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <gestalt>
      14:35:05.778	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
      14:35:05.779	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
      14:35:05.779	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/gestalt
      14:35:05.854	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: {"product_name":"Twinkly","product_version":"16","hardware_version":"7","flash_size":16,"led_type":6,"led_version":"1","product_code":"TW225SEUP07","device_name":"Twinkly_BA1A63","uptime":"1274275","rssi":-78,"hw_id":"00ba1a63","mac":"84:f3:eb:ba:1a:63","uuid":"7F272E77-662E-4E6C-A8A0-D50DCA470F74","max_supported_led":255,"base_leds_number":225,"number_of_led":225,"led_profile":"RGB","frame_rate":25,"movie_capacity":719,"copyright":"LEDWORKS 2017","code":1000}
      14:35:05.857	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.details, state={"val":"{\"product_name\":\"Twinkly\",\"product_version\":\"16\",\"hardware_version\":\"7\",\"flash_size\":16,\"led_type\":6,\"led_version\":\"1\",\"product_code\":\"TW225SEUP07\",\"device_name\":\"Twinkly_BA1A63\",\"uptime\":\"1274275\",\"hw_id\":\"00ba1a63\",\"mac\":\"84:f3:eb:ba:1a:63\",\"max_supported_led\":255,\"base_leds_number\":225,\"number_of_led\":225,\"led_profile\":\"RGB\",\"frame_rate\":25,\"movie_capacity\":719,\"copyright\":\"LEDWORKS 2017\"}","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
      14:35:05.859	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly._get] <fw/version>
      14:35:05.860	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [Twinkly.ensure_token] Authentication token still valid (2020-12-6 18:35:05)
      14:35:05.860	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [httpRequest.GET] curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
      14:35:05.861	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: exec: curl -H 'X-Auth-Token: vZa1C4f9U6E= Content-Type: application/json' http://192.168.178.175/xled/v1/fw/version
      14:35:05.919	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: [doGetRequest] body: {"version":"2.3.5","code":1000}
      14:35:05.920	info	javascript.0 (11366) script.js.Schaltungen.Twinkly_JS: setForeignState(id=javascript.0.Weihnachtsbaum.firmware, state={"val":"2.3.5","ack":true,"c":"script.js.Schaltungen.Twinkly_JS"})
      patrickbs96P 1 Antwort Letzte Antwort
      • W W0RSCHD
        @patrickbs96
        hier mal ein Auszug
        patrickbs96P
        patrickbs96P
        patrickbs96
        @W0RSCHD Versuche es bitte erneut. Da war noch ein Fehler in der curl Anfrage bei der Übergabe des Tokens...
          W
          W
          W0RSCHD
          schrieb am zuletzt editiert von W0RSCHD
          @patrickbs96 jetzt klappts juhuuu TOP, Danke :)
          Es kommt nur dieser Error dauernd im Log, aber an sich gehts
          javascript.0	2020-12-06 21:52:15.249	error	(11366) script.js.Schaltungen.Twinkly_JS: [Weihnachtsbaum.timer] [Twinkly.GET.timer] undefined (undefined), Headers: {"X-Auth-Token":"Knavqszdq6s=","Content-Type":"application/json"}
          • W W0RSCHD
            patrickbs96P
            patrickbs96P
            patrickbs96
            schrieb am zuletzt editiert von patrickbs96
            @W0RSCHD Super, das freut mich zu hören :-)
            Anscheinend wird der Twinkly-Code nicht immer übergeben, dadurch steht dort undefined. Ich habe den Fall ausgeschlossen und der sollte daher keine Fehler mehr produzieren.
            Da es mit curl mit beiden Generationen funktioniert, habe ich die Verarbeitung für beide gleichgezogen. Dadurch entfällt dann auch die Einstellung für curl. Könntest du das eventuell auch einmal testen @siggi85 ?
            EDIT: Noch nicht testen, bei mir kommen aktuell noch Fehler.
            EDIT 2: Bei mir kamen plötzlich "Invalid Token" Meldung und hatten Probleme verursacht. Ich habe es hoffentlich behoben (Es kamen leider keine mehr mit denen ich das testen konnte.)
            siggi85S W 2 Antworten Letzte Antwort
              siggi85S
              siggi85S
              siggi85
              @patrickbs96 Auch die neue Version des Skriptes funktioniert bei mir. Ich benutze weiterhin die Version ohne curl, aber hatte mit dem aktuellen Skript keine Probleme.
              Ich habe übrigens den Link zu deinem Skript im ersten Beitrag ergänzt.
                W
                W
                W0RSCHD
                @patrickbs96 klappt nun auch hier ohne Error, Dankeschön! thumbsup
                siggi85S 1 Antwort Letzte Antwort
                • W W0RSCHD
                  siggi85S
                  siggi85S
                  siggi85
                  @W0RSCHD Super!
                  @patrickbs96 Good job! 👍
                  • flipjizF
                    flipjizF
                    flipjiz
                    Moin! Vorweg: Danke für eure Arbeit :D
                    Muss ich die Datei runterladen und irgendwo hinschieben oder einfach über die ioBroker Oberfläche ein neues Skript mit dem Inhalt hinzufügen?
                    Ich hab es einfach mal unter Common reingeworfen aber dort gibt es diese Fehler beim Starten:
                    2020-12-08 16:49:59.946 - info: javascript.0 (22601) Start javascript script.js.common.twinkly
                    2020-12-08 16:49:59.960 - error: javascript.0 (22601) script.js.common.twinkly compile failed:
                    at script.js.common.twinkly:221
                    2020-12-08 16:49:59.961 - error: javascript.0 (22601) }, POLLING_IN_SEK * 1_000);
                    2020-12-08 16:49:59.962 - error: javascript.0 (22601) ^
                    2020-12-08 16:49:59.963 - error: javascript.0 (22601) SyntaxError: Invalid or unexpected token
                    2020-12-08 16:49:59.964 - error: javascript.0 (22601) at new Script (vm.js:83:7)
                    2020-12-08 16:49:59.964 - error: javascript.0 (22601) at Object.createScript (vm.js:277:10)
                    2020-12-08 16:49:59.965 - error: javascript.0 (22601) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
                    2020-12-08 16:49:59.966 - error: javascript.0 (22601) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
                    2020-12-08 16:49:59.967 - error: javascript.0 (22601) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17)
                    2020-12-08 16:49:59.967 - error: javascript.0 (22601) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17)
                    2020-12-08 16:49:59.968 - error: javascript.0 (22601) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
                    2020-12-08 16:49:59.969 - error: javascript.0 (22601) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    2020-12-08 16:49:59.969 - error: javascript.0 (22601) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                    2020-12-08 16:49:59.970 - error: javascript.0 (22601) at process._tickCallback (internal/process/next_tick.js:68:7)
                    • flipjizF flipjiz
                      patrickbs96P
                      patrickbs96P
                      patrickbs96
                      @flipjiz Genau richtig, neues Skript unter Common erstellen und den Inhalt hineinkopieren. Danach musst du nur den Abschnitt mit den devices anpassen, so wie es in dem Beispiel im Skript oder auf der GitHub Seite gezeigt wird.
                      const devices = {
                          Twinkly1 : {                                         // State-Name in ioBroker
                              name           : 'Twinkly Lichterkette 1',       // Name für ioBroker (Falls nicht hinterlegt wird der State-Name verwendet)
                              ipAdresse      : '192.168.178.52',               // IP-Adresse von der Twinkly-Lichterkette
                              connectedState : 'ping.0.Twinkly_Lichterkette_1' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
                          Twinkly2 : {                                         // State-Name in ioBroker
                              name           : 'Twinkly Lichterkette 2',       // Name für ioBroker (Falls nicht hinterlegt wird der State-Name verwendet)
                              ipAdresse      : '192.168.178.53',               // IP-Adresse von der Twinkly-Lichterkette
                              connectedState : 'ping.0.Twinkly_Lichterkette_2' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
                      Ich vermute mal, dass dort ein Fehler bei den devices ist. Könntest du mir den Abschnitt einmal zeigen?
                      flipjizF 1 Antwort Letzte Antwort
                        const devices = {
                        flipjizF
                        flipjizF
                        flipjiz
                        @patrickbs96
                         * Settings
                        const PATH_ID          = 'javascript.0.MyDevices.Twinkly.'; // Pfad für die Datenpunkte
                        const POLLING_IN_SEK   = 60;                                // Wie oft sollen die Daten abgefragt werden
                        const EXTENDED_LOGGING = true;                             // Mehr Informationen loggen
                        const devices = {
                            Twinkly : {                                   // State-Name in ioBroker
                                name           : 'Twinkly',               // Name für ioBroker (Falls nicht hinterlegt wird der State-Name verwendet)
                                ipAdresse      : '192.168.25.168',               // IP-Adresse von der Twinkly-Lichterkette
                                connectedState : 'ping.0.Twinkly' // State mit true/false der den aktuellen Status der Lichterkette überwacht (bspw. ping, tr-064)
                        • flipjizF flipjiz
                          @patrickbs96
                           * Settings
                          const devices = {
                          patrickbs96P
                          patrickbs96P
                          patrickbs96
                          @flipjiz Das sieht soweit richtig aus. Kannst du mir das gesamte Skript einmal schicken?
                            flipjizF
                            flipjizF
                            flipjiz
                            @patrickbs96
                            Ich habe im Skript einfach die Unterstriche in Zeile 221 und 222 entfernt:
                                        }, 2_000);
                            zu
                                            }, POLLING_IN_SEK * 1000);
                                        }, 2000);
                            nun läuft es!
                            • flipjizF flipjiz
                              @patrickbs96
                                          }, 2_000);
                              zu
                                          }, 2000);
                              nun läuft es!
                              patrickbs96P
                              patrickbs96P
                              patrickbs96
                              @flipjiz Komisch hätte nicht gedacht, dass das Fehler verursacht. Dann werde ich das mal im Skript korrigieren :-)
                              • siggi85S siggi85
                                Ursprünglich habe ich ein kleines Blockly geschrieben (siehe unten in diesem Post). Allerdings hat mittlerweile @patrickbs96 ein wesentlich umfangreiches Skript erstellt, um Twinkly Systeme zu steuern. Die aktuelle Version davon könnt ihr hier finden.
                                Für alle Fälle lasse ich mein altes Blockly hier drin, aber ich würde definitiv das Skript von @patrickbs96 empfehlen.
                                Alt:
                                Ich habe ein kleines Blockly geschrieben, was über Curl Aufrufe die API anfragt und damit Basisfunktionen steuerbar macht wie an/aus (letzte Szene) und die Helligkeit. Die Datenpunkte habe ich unter 0_userdata.0 gepackt.
                                Damit das Ganze funktioniert, einfach die Datenpunkte importieren und im Blockly die IP-Adresse eures Twinkly Devices eintragen. Zusätzlich mit im Javascript Adapter das exec Kommando erlaubt sein. (Konfiguration in der JavaScript Instanz)
                                Blockly
                                 <variables>
                                   <variable id="C2}3(QK:sjn_0;M@WXM6">ip-address</variable>
                                   <variable id="Li8l,iD*a4lAUfTrR./#">result</variable>
                                   <variable id="ATDr!5*=f1mXSwF*B31X">onoff</variable>
                                   <variable id="tvi|}J~k+`CSxDW?#-_G">login_list</variable>
                                   <variable type="timeout" id="timeout2">timeout2</variable>
                                   <variable type="timeout" id="timeout3">timeout3</variable>
                                   <variable type="timeout" id="timeout">timeout</variable>
                                 </variables>
                                 <block type="comment" id="7aO~bSI=}sBUF]!Uj5VW" x="113" y="-12">
                                   <field name="COMMENT">Hier die IP-Adresse des Twinkly angeben.</field>
                                   <next>
                                     <block type="variables_set" id="})]:dOnZEgaB;GwFMYm7">
                                       <field name="VAR" id="C2}3(QK:sjn_0;M@WXM6">ip-address</field>
                                       <value name="VALUE">
                                         <block type="text" id="UPk-=X649M@ReWw=d!/Y">
                                           <field name="TEXT">192.168.1.241</field>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="on_ext" id="hjfZPnTX~Ue*9(8]/!;C">
                                           <value name="OID0">
                                             <shadow type="field_oid" id="9twVsr7m@F^_y.SIh3v/">
                                               <field name="oid">0_userdata.0.devices.twinkly1.on</field>
                                             </shadow>
                                           </value>
                                           <statement name="STATEMENT">
                                             <block type="controls_if" id="Vyh(4M|:$PiwH3:ODZ(v">
                                               <value name="IF0">
                                                 <block type="on_source" id=".8e69^VPY]Vwj!#QB8;b">
                                                 </block>
                                               </value>
                                               <statement name="DO0">
                                                 <block type="variables_set" id="[Pbb5axB^[hOzmHwfPcs">
                                                   <field name="VAR" id="ATDr!5*=f1mXSwF*B31X">onoff</field>
                                                     <block type="text" id="qYAqrB@?4{kDiZ*iP5Nv">
                                                       <field name="TEXT">movie</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </statement>
                                               <value name="IF1">
                                                 <block type="logic_negate" id="[)WH1r7P]c-i1[{xOXce">
                                                   <value name="BOOL">
                                                     <block type="on_source" id="LfiaUSvy[Zo`?iQA0%AA">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <statement name="DO1">
                                                 <block type="variables_set" id="$75d~3~;/E1{z?f6Uw`7">
                                                     <block type="text" id="t`KFGE2EgS={pHOe({dy">
                                                       <field name="TEXT">off</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </statement>
                                               <next>
                                                 <block type="exec" id="a8Xsf6X|RT_RKWu+m|4D">
                                                   <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                                   <field name="WITH_STATEMENT">TRUE</field>
                                                   <field name="LOG"></field>
                                                   <value name="COMMAND">
                                                     <shadow type="text">
                                                     </shadow>
                                                     <block type="text_join" id="x.E)Ijwm[WHV!_bPRK4/">
                                                       <mutation items="9"></mutation>
                                                       <value name="ADD0">
                                                         <block type="text" id="bMn%~Q14lVR9+BCwRR/1">
                                                           <field name="TEXT">curl -d '{"mode":"</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD1">
                                                         <block type="variables_get" id="6yJXT{FImP5pG}/rrtNy">
                                                         </block>
                                                       </value>
                                                       <value name="ADD2">
                                                         <block type="text" id="^ujE4oo_X%]da4,(ppuL">
                                                           <field name="TEXT">"}' -H 'Content-Type: application/json</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD3">
                                                         <block type="text_newline" id="c!_Px216Os[.$S/~rarw">
                                                           <field name="Type">\n</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD4">
                                                         <block type="text" id="$Fg2yhXiAQ){16U@!ZSu">
                                                           <field name="TEXT">X-Auth-Token: </field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD5">
                                                         <block type="get_value" id="IXl+3AbS2B.l]YvbqzM6">
                                                           <field name="OID">0_userdata.0.devices.twinkly1.token</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD6">
                                                         <block type="text" id="S{EEHm.[zP|vcm#1tnS#">
                                                           <field name="TEXT">'  http://</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD7">
                                                         <block type="variables_get" id="]u@TMc}oUr*ZKNMfa4*r">
                                                         </block>
                                                       </value>
                                                       <value name="ADD8">
                                                         <block type="text" id="bz;89=2*~U#c3SZm,`3R">
                                                           <field name="TEXT">/xled/v1/led/mode</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                     <block type="control" id=")*EuNf:*?Mej|oX]c[YG">
                                                       <field name="OID">0_userdata.0.devices.twinkly1.last_response</field>
                                                         <block type="variables_get" id="sO6_Jt^$^o?%u_FndEof">
                                                           <field name="VAR" id="Li8l,iD*a4lAUfTrR./#">result</field>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="controls_if" id="6G?]0D()J)}!$||^GZ[g">
                                                           <value name="IF0">
                                                             <block type="logic_compare" id="{`cuuloZIeqXKe;Iydaw">
                                                               <field name="OP">EQ</field>
                                                               <value name="A">
        <block type="variables_get" id=".|80~sPZrcTq)~D%FLqS">
        </block>
                                                               </value>
                                                               <value name="B">
        <block type="text" id="V1j|Yla.{Pkhx;t!dL5A">
        <field name="TEXT">Invalid Token</field>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                             <block type="timeouts_settimeout" id="*hEGRE,x!rFyGvx1sGnk">
                                                               <field name="NAME">timeout2</field>
                                                               <field name="DELAY">1000</field>
                                                               <field name="UNIT">ms</field>
        <block type="procedures_callnoreturn" id="47rDf|TIj){(r%S/jL|t">
        <mutation name="tokenerstellung"></mutation>
        <next>
        <block type="exec" id="vmrb/I[xcD|UrCR{N5,}">
        <shadow type="text" id="1oqX0]_@1GCaqA|AYG9V">
        </shadow>
        <block type="text_join" id=";|wMTJLvzMlbPBE.f}8(">
        <value name="ADD0">
        <block type="text" id="vSqJqFViMtF_b70KZZ4U">
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="iL*:FiISRruR#*B:SpWU">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="_H7ZwE!fF3Lh:;B6+mC`">
        </block>
        </value>
        <value name="ADD3">
        <block type="text_newline" id="EMmO8}AnS:G1L0.zG*(K">
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="IffU.a}O8pGD]^*9G,e5">
        </block>
        </value>
        <value name="ADD5">
        <block type="get_value" id="KN#wwJ9wRg[}}Tbh4A)S">
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="?QBxH#Gn#va8-Fur=Mri">
        </block>
        </value>
        <value name="ADD7">
        <block type="variables_get" id="F8ff%~_KvjsS/r{.$)!A">
        </block>
        </value>
        <value name="ADD8">
        <block type="text" id="bZ1Z,*N[OcaWiEp;f%P8">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="Dq-:j;brnrXMKn(MM*]8">
        <block type="variables_get" id="%1_~*tS$$o%-C~FLfV,A">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                               </statement>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                           <next>
                                             <block type="on_ext" id="*d77h3XvC|Tj~C2z*Gd`">
                                               <value name="OID0">
                                                 <shadow type="field_oid" id="sl:%ZP;c-3T~K6vz?rya">
                                                   <field name="oid">0_userdata.0.devices.twinkly1.bri</field>
                                                 </shadow>
                                               </value>
                                                 <block type="exec" id="SwV21J;Rhw=V[z^`IJw,">
                                                     </shadow>
                                                     <block type="text_join" id="9G(1o6:8.FmD^^LOK8Cn">
                                                       <value name="ADD0">
                                                         <block type="text" id="+GA1[uhyM:KfX1qzqUEF">
                                                           <field name="TEXT">curl -d '{"value":</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD1">
                                                         <block type="on_source" id="_l@jyLbrNk{7FxZj$Zmh">
                                                         </block>
                                                       </value>
                                                       <value name="ADD2">
                                                         <block type="text" id="|7^t}Cu}B6~Y1mC(0#UL">
                                                           <field name="TEXT">,"mode":"enabled","type":"A"}' -H 'Content-Type: application/json</field>
                                                         </block>
                                                       </value>
                                                       <value name="ADD3">
                                                         <block type="text_newline" id="cm,kmJNBdr]RQ%aT^mz.">
                                                         </block>
                                                       </value>
                                                       <value name="ADD4">
                                                         <block type="text" id="z;)h^VxAjQk8sNE@yXm6">
                                                         </block>
                                                       </value>
                                                       <value name="ADD5">
                                                         <block type="get_value" id="SN0q;T8G^i,z`[mK|cbi">
                                                         </block>
                                                       </value>
                                                       <value name="ADD6">
                                                         <block type="text" id="Qs]@)sCx^T~4~O:-~N%]">
                                                         </block>
                                                       </value>
                                                       <value name="ADD7">
                                                         <block type="variables_get" id="Q3qO2s#P(jH/]+s=`sg;">
                                                         </block>
                                                       </value>
                                                       <value name="ADD8">
                                                         <block type="text" id="[GRuP4kVQ)yBXm_~?XLn">
                                                           <field name="TEXT">/xled/v1/led/out/brightness</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                     <block type="control" id="w46r4o:A,,aVgr@NCGW2">
                                                         <block type="variables_get" id="VXXDL).b0.4NB_KKb(+v">
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="controls_if" id="+3OyyHh$$_UZAgnj,!EX">
                                                           <value name="IF0">
                                                             <block type="logic_compare" id="*r7*K4LHSml!_+c@?0nf">
                                                               <value name="A">
        <block type="variables_get" id="oFL-r!ZE;^X3v-E5{q@r">
        </block>
                                                               </value>
                                                               <value name="B">
        <block type="text" id=".crTI6#$|W5R_}1|8c~D">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                             <block type="timeouts_settimeout" id="]!]T:3c[:^C]UD/4vpaV">
                                                               <field name="NAME">timeout3</field>
        <block type="procedures_callnoreturn" id="EiS$0K4lv~,deH6%Vqi*">
        <next>
        <block type="exec" id="{nu5Ft~q(!9,39eE8O,H">
        <shadow type="text" id="]MnC9RK!/]8A^d2-p{.$">
        </shadow>
        <block type="text_join" id="y6bUQx$R#^T}AEn?e(^r">
        <value name="ADD0">
        <block type="text" id="m:@7^x{FFQvWHWfZ?K0r">
        </block>
        </value>
        <value name="ADD1">
        <block type="on_source" id="{A,ZJ=}qtv?/9{U-J5Z}">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="DaHQVOV.9DNj`NPEJ;LE">
        </block>
        </value>
        <value name="ADD3">
        <block type="text_newline" id="1#3uF7ndLmSv1*Am2g[7">
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="KDy19da_TUp?9`Xb@L|F">
        </block>
        </value>
        <value name="ADD5">
        <block type="get_value" id="7_ycWMaJu(pS;yvdSQId">
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="3C;CZ]:wKA*AK6l`f8:}">
        </block>
        </value>
        <value name="ADD7">
        <block type="variables_get" id="K4er1ePuhS)xrpTBSh1+">
        </block>
        </value>
        <value name="ADD8">
        <block type="text" id="BLz=[InZOBRg#-5m/jvo">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="1%ERGs|hD2^:gC[sA^}z">
        <block type="variables_get" id="L1-0?qL3zOPU)]Q8L-^~">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
                                                               </statement>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                                 <block type="on_ext" id="*=Rz8c^+(Uep[d%kgN^Z" x="913" y="113">
                                   <value name="OID0">
                                     <shadow type="field_oid" id="b-H}2tTFUu5fH^xR5S0G">
                                       <field name="oid">0_userdata.0.devices.twinkly1.generate_token</field>
                                     </shadow>
                                   </value>
                                     <block type="controls_if" id="w)JwIcM8fG[^G2o@g#IU">
                                       <value name="IF0">
                                         <block type="on_source" id="S7l^Ygh^qp/THpb#N/Vi">
                                         </block>
                                       </value>
                                         <block type="procedures_callnoreturn" id="glH8Vnu3lq|zhdL*!B4P">
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                                 <block type="procedures_defnoreturn" id="^9??;ZMVyU07(54V3Eu6" x="938" y="388">
                                   <field name="NAME">tokenerstellung</field>
                                   <statement name="STACK">
                                     <block type="exec" id="Bq5LNu.#~ON+t,OLyd(I">
                                         <shadow type="text" id="O9{;*_0^t`dZ%{JAl{J{">
                                           <field name="TEXT"></field>
                                         </shadow>
                                         <block type="text_join" id="#jTB:KIs,db`$/4bj!]I">
                                           <value name="ADD0">
                                             <block type="text" id="lO4T;Ob7;f$%g?a{lMLD">
                                               <field name="TEXT">curl -d '{"challenge": "AAECAwQFBgcICQoLDA0ODxAREhMUFRYXGBkaGxwdHh8="}' -H 'Content-Type: application/json' http://</field>
                                             </block>
                                           </value>
                                           <value name="ADD1">
                                             <block type="variables_get" id="N(fQwlPipS~;`%=JO?7G">
                                             </block>
                                           </value>
                                           <value name="ADD2">
                                             <block type="text" id=")UJ3i2ob.UVF3E3)9TO@">
                                               <field name="TEXT">/xled/v1/login</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                         <block type="control" id="Y3E;QMmY1QNsX#EJBcAF">
                                           <field name="OID">0_userdata.0.devices.twinkly1.invalid_token_counter</field>
                                             <block type="math_arithmetic" id="`C:HNYfvK.FSEllWcW:W">
                                               <field name="OP">ADD</field>
                                               <value name="A">
                                                 <shadow type="math_number" id="^:exn5EkqE)Xz?D|SKy}">
                                                   <field name="NUM">1</field>
                                                 </shadow>
                                                 <block type="get_value" id="vy(qI~n0+neTVRz79^xM">
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 <shadow type="math_number" id="BE#f|Dp3linv[rzbqD7,">
                                                 </shadow>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                             <block type="control" id="us?L?4O4rHFC5D!fDsdJ">
                                                 <block type="variables_get" id="7S0c3_b[:aEVF](uS:iX">
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="debug" id="7`oD1gOEU#uh+EL?AUc.">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="^IpRqdiDT*-j/Q^/QW,_">
                                                       <field name="TEXT">Starte Tokenerstellung</field>
                                                     </shadow>
                                                   </value>
                                                   <next>
                                                     <block type="debug" id="Xs6X/K_nR}k-ykL[M`16" disabled="true">
                                                       <value name="TEXT">
                                                         <shadow type="text" id="js$]6ILdYcAJhz8W=;/n">
                                                         </shadow>
                                                         <block type="variables_get" id="aI{(nALcBG$eenM_JT=b">
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="variables_set" id="B5y.Gk@ojBh]^gBn7Ri|">
                                                           <field name="VAR" id="tvi|}J~k+`CSxDW?#-_G">login_list</field>
                                                             <block type="lists_split" id="`#WZQy~#_]DAD#ySTlVV">
                                                               <mutation mode="SPLIT"></mutation>
                                                               <field name="MODE">SPLIT</field>
                                                               <value name="INPUT">
        <block type="variables_get" id="M]:lZztzzg!QI;t@mWzg">
        </block>
                                                               </value>
                                                               <value name="DELIM">
        <shadow type="text" id="f;7]A0]C9Iorq7FUh*+I">
        <field name="TEXT">"</field>
        </shadow>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="control" id="2`c=|y/iww3.=^}.8I59">
        <block type="lists_getIndex" id="F1-qcRR[;NFa^DMlqV{o">
        <mutation statement="false" at="true"></mutation>
        <field name="MODE">GET</field>
        <field name="WHERE">FROM_START</field>
        <block type="variables_get" id="R2XhFDen:RGmV1nikpp[">
        </block>
        </value>
        <value name="AT">
        <block type="math_number" id="270Qn=t=#(OQM?R3r!+u">
        <field name="NUM">4</field>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        <block type="timeouts_settimeout" id=",hW#SP83S3D]=+0I3JoQ">
        <block type="debug" id="^=K4IGZtu1BUem~dDnFk" disabled="true">
        <value name="TEXT">
        <shadow type="text" id=".g[a3HxSe}og?21x+^Qk">
        </shadow>
        <block type="get_value" id="qV_*%10mt5bVx~B/53[A">
        </block>
        </value>
        <next>
        <block type="exec" id="F?4D@ZgD!6%*)kMw+C`#">
        <shadow type="text" id="hpVJ5z*?j?fV#n/rTh}i">
        </shadow>
        <block type="text_join" id="9#Ev1:g,Ufv^SHikoIon">
        <mutation items="7"></mutation>
        <value name="ADD0">
        <block type="text" id="7CCd?lZeczQAQpjj6(??">
        <field name="TEXT">curl -d '{"challenge-response": "4ecffc0c669796ea843c4ef4dc7d2a33cf081d92"}' -H 'Content-Type: application/json</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="text_newline" id="{79JO}FxsmNg_rO],+T^">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="$n6sdnx`e!VGaK*!He[G">
        </block>
        </value>
        <value name="ADD3">
        <block type="get_value" id="L^*fU+dFPAr!s;E{H`EJ">
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="F5J!U?U$yq-,3xS7UPO(">
        </block>
        </value>
        <value name="ADD5">
        <block type="variables_get" id="{rr$];i8Kyl{k0boEz[S">
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="$`0sn]I1P5!8_rl3`:hx">
        <field name="TEXT">/xled/v1/verify</field>
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="|4x]CJ+``GuPe~viuF}*">
        <block type="variables_get" id="9HuL3|uRhcfeHa.dU$G6">
        </block>
        </value>
        <next>
        <block type="controls_if" id="JjJG3UmSBHE@6./RA~1K">
        <value name="IF0">
        <block type="logic_compare" id="9GB#=W%O2|z3oZc(QCV)">
        <value name="A">
        <block type="variables_get" id="AsZF48_sLRx}5(@:O=hQ">
        </block>
        </value>
        <value name="B">
        <block type="text" id="1fN*O!Pf=sm`ovt,0/nN">
        <field name="TEXT">{"code":1000}</field>
        </block>
        </value>
        </block>
        </value>
        <block type="debug" id="NHzT/CsYQxEDy9~R6MSQ">
        <value name="TEXT">
        <shadow type="text" id="#fx%mvWHriHU8Vw{rnw8">
        <field name="TEXT">Tokenerstellung erfolgreich.</field>
        </shadow>
        </value>
        <next>
        <block type="control" id="{9;o6mIpuEf`7xT-n)3L">
        <field name="OID">0_userdata.0.devices.twinkly1.token_verify</field>
        <block type="logic_boolean" id="}=yzK!`!Q@E_hN):CP_d">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="debug" id="+2J+Qkd$;V|:M.)E)4qK">
        <value name="TEXT">
        <shadow type="text" id="}TE#6+G@7Zq*9jwGt]}`">
        <field name="TEXT">Tokenerstellung fehlgeschlagen.</field>
        </shadow>
        </value>
        <next>
        <block type="control" id="2;nVgYFKxBDzpT+aGsxq">
        <block type="logic_boolean" id="V(w(5r+]OyK6/=sn{xA@">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                                </xml>
                                Datenpunkte
                                0_userdata.0.devices.twinkly1.json
                                Die API Dokumentation habe ich hierher.
                                Ich habe auch versucht die MQTT Konfiguration anzupassen, jedoch scheint diese mittlerweile verschlüsselt zu sein (zumindest laut meinen Netzwerk Mitschnitten). Man kann den Datenverkehr zwar zum ioBroker schicken, der kann ohne passendes Zertifikat aber leider nichts damit anfangen. Ich konnte die Verschlüsselung über die API leider nicht deaktvieren oder anpassen. Schade, denn über MQTT lassen sich anscheinend auch die jeweiligen Szenen ansteuern.
                                Achja, ich bin kein Programmierer. Bspw. ist die direkte Umsetzung in Javascript sicher wesentlich eleganter und/oder das gleichzeitige packen in einen Adapter. Ich bitte um Nachsicht und hoffe einfach, dass ihr (so wie ich jetzt auch) zumindest zufrieden seid, wenn ihr euer Twinkly nun per ioBroker zumindest an und aus schalten könnt. :)
                                patrickbs96P
                                patrickbs96P
                                patrickbs96
                                @siggi85 @W0RSCHD Ich habe den Adapter soweit fertiggestellt. Mir fehlen zwar noch die Übersetzungen aber vom technischen her ist der fertig. Würde mich freuen, wenn ihr den testen würdet :-)
                                  M
                                  M
                                  MCU
                                  @patrickbs96 Wie muss man den Adapter einstellen, bekomme keinen Connect. Obwohl die Instanz auf grün ist.
                                  Beim Speichern bekomme ich immer:
                                  Bin angemeldet als User. v2.12.9(build 5611) als App von gestern.
                                  • M MCU
                                    patrickbs96P
                                    patrickbs96P
                                    patrickbs96
                                    @MCU Sorry, da war ich wohl etwas zu voreilig mit der Veröffentlichung... Ist mein erster Adapter gewesen, da hatte ich bei der Menge an Aufgaben für die Veröffentlichung das wohl vergessen... Ich habe die Anleitung angepasst.
                                    Ändert trotzdem nichts an deinem Fehler, es ist soweit alles richtig konfiguriert. Könntest du dir die neue Version holen, den Adapter dann auf Debug stellen und mir das Log schicken? Dann kann ich zumindest prüfen, weshalb der nicht startet.
                                    @apollon77 Die Fehlermeldung beim Speichern bekomme ich komischerweise jetzt auch (raspberry pi). Unter Windows habe ich keine Fehler erhalten. Komischerweise kriege ich die Fehlermeldung auch, wenn ich die Einstellungen direkt am Datenpunkt system.adapter.twinkly.0 ändere. Hast du eine Idee woran das liegen kann?
                                    apollon77A patrickbs96P M 3 Antworten Letzte Antwort
                                      apollon77A
                                      apollon77A
                                      @patrickbs96 welchen Fehler? Den oben mit dem invalid token? Dann checke mal das skript, dann ist da ein Fehler drin
                                      • apollon77A apollon77
                                        patrickbs96P
                                        patrickbs96P
                                        patrickbs96
                                        @apollon77 Ne nicht den Invalid Token, sondern das beim Speichern die Meldung kommt "Einige Daten wurden nicht gespeichert. Verwerfen?"
                                          apollon77A
                                          apollon77A
                                          #66
                                          @patrickbs96 hm ... da muss mal schauen, keine ahnung ... Bist du in einem der dev chnnel im discord oder telegram? Frag mal da ... bzw kommentiere es im repo, muss man schauen
                                          84.0k
