  4. Frage : Migrate MySQL nach Influxdb
151 Beiträge 31 Kommentatoren 36.7k Aufrufe 25 Beobachtet
  • JackGruberJ JackGruber
    @MezzoDO ok, das ack feld ist bereits als boolen angelegt, kommt nun aber als int.
    Ihc könnte es anpassen, dass dies beim import convertiert wird.
    MezzoDO
    schrieb am zuletzt editiert von MezzoDO
    @JackGruber said in Frage : Migrate MySQL nach Influxdb:
    Das wäre grandios :)
    Mein Script, was ich einsetze:
    ### MySQL DB info ###
    #import MySQLdb
    import pymysql
    conn = pymysql.connect(host="localhost",  # your host, usually localhost
                         user="xxx",         # your username
                         passwd="xxx",  # your password
                         db="iobroker")        # name of the data base
    ### PostgreSQL DB info ###
    import psycopg2
    import psycopg2.extras
    # connection data for PostgreSQL
    #conn = psycopg2.connect("dbname=xxx user=xxx password=xxx host=xxx.xxx.xxx.xxx port =5432")
    # InfluxDB info #
    from influxdb import InfluxDBClient
    #####connection data for InfluxDB#####
    influxClient = InfluxDBClient(host='localhost', port=8086, username='xxx', password='xxx', database='iobroker')
    #influxClient.delete_database(influx_db_name)
    #influxClient.create_database(influx_db_name)
    # dictates how columns will be mapped to key/fields in InfluxDB
    schema = {
        "time_column": "time", # the column that will be used as the time stamp in influx
        "columns_to_fields" : ["ack","q", "from","value"], # columns that will map to fields
        # "columns_to_tags" : ["",...], # columns that will map to tags
        "table_name_to_measurement" : "name", # table name that will be mapped to measurement
    Generates an collection of influxdb points from the given SQL records
    def generate_influx_points(records):
        influx_points = []
        for record in records:
            #tags = {},
            fields = {}
            #for tag_label in schema['columns_to_tags']:
            #   tags[tag_label] = record[tag_label]
            for field_label in schema['columns_to_fields']:
                fields[field_label] = record[field_label]
            influx_points.append({
                "measurement": record[schema['table_name_to_measurement']],
                #"tags": tags,
                "time": record[schema['time_column']],
                "fields": fields
        return influx_points
    # query relational DB for all records
    #curr = conn.cursor('cursor', cursor_factory=psycopg2.extras.RealDictCursor)
    curr = conn.cursor(cursor=pymysql.cursors.DictCursor)
    # curr = conn.cursor(dictionary=True)
    # SQL query for PostgreSQL, syntax for MySQL differs
    # query provide desired columns as a view on the sql server
    # request data from SQL, adjust ...from <view name>
    curr.execute("Select * from InfluxData;")
    row_count = 0
    # process 1000 records at a time
    while True:
        print("Processing row #" + str(row_count + 1))
        selected_rows = curr.fetchmany(1000)
        influxClient.write_points(generate_influx_points(selected_rows))
        row_count += 1000
        if len(selected_rows) < 1000:
            break
    conn.close()
    JackGruberJ 1 Antwort Letzte Antwort
    • M MezzoDO
      #import MySQLdb
      import pymysql
      import psycopg2
      # InfluxDB info #
      schema = {
          influx_points = []
              #tags = {},
              fields = {}
                  #"tags": tags,
                  "fields": fields
      row_count = 0
      while True:
          row_count += 1000
              break
      conn.close()
      JackGruberJ Offline
      JackGruberJ Offline
      JackGruber
      @MezzoDO
      Ersetze in deinem Script Zeile 47 mit folgenden zwei zeilen. Auf das einrücken achten!:
                  if field_label == "ack":
                      record[field_label] = bool(record[field_label])
        @MezzoDO
        simatecS Offline
        simatecS Offline
        simatec
        @JackGruber
        Ich komme leider auch nicht weiter ...
        Habe deinen Script von Github installiert und bekomme folgende Ausgabe:
        pi@raspberrypi:~/iobroker_mysql_2_influxdb $ python3 migrate.py all
        Migrate 'all' datapoint(s) ...
        Total metrics in ts_number: 0
        Total metrics in ts_bool: 0
        Total metrics in ts_string: 0
        Migrated: 0
        Das ganze passiert innerhalb einer Sekunde .
        Die Influxdb habe ich über den iobroker Adapter angelegt.
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • simatecS simatec
          @JackGruber
          Migrated: 0
          JackGruberJ Offline
          JackGruberJ Offline
          JackGruber
          Hi @simatec, hab einen mini Fehler im Script gefunden. Durch einen BUG musste das ALL großgeschrieben werden.
          Hab das Script angepasst, einfach neu herunterladen oder das ALL großschreiben.
            simatecS Offline
            simatecS Offline
            simatec
            @JackGruber
            Danke für den Tipp ... Ich hatte es auch einzeln versucht und dann auch jedes Objekt einzeln importiert.
            War zwar etwas Aufwand aber ging super ;-)
              base
              Wie und wo kann ich das Script benutzen? In iobroker javascript oder Konsole? iobroker läuft bei mir im Docker Container....
              • B base
                JackGruberJ Offline
                JackGruberJ Offline
                JackGruber
                @base python auf deinem PC installieren, das script wie auf der git seite beschrieben installieren und benutzen.
                  base
                  @JackGruber
                  ich bekomme in diese Zeile einen Syntax Error:
                              print(f"Processing row {processed_rows + 1:,} to {processed_rows + len(selected_rows):,} from LIMIT {start_row:,} / {start_row + query_max_rows:,} " + table + " - " + metric['name'] + " (" + str(metric_nr) + "/" + str(metric_count) + ")")
                  er meckert die Anführungsstriche vor table an
                  simatecS JackGruberJ 2 Antworten Letzte Antwort
                  • B base
                    @JackGruber
                    simatecS Offline
                    simatecS Offline
                    simatec
                    @base
                    So war es bei mir auch.
                    Hast du mal versucht, die Daten einzeln pro Objekt zu importieren? Das half bei mir.
                    • simatecS simatec
                      @base
                      base
                      schrieb am zuletzt editiert von base
                      @simatec habe dein Script von oben ausprobiert, dass holt aber nicht alle Objekte...
                      was muss ich da ändern?
                      ok, habs gefunden. Muss natürlich die SQL Abfrage anpassen. Jetzt klappts
                      • B base
                        @JackGruber
                        JackGruberJ Offline
                        JackGruberJ Offline
                        JackGruber
                        @base was für eine python version nutzt du?
                        Bei mir läuft das script ohne probleme durch.
                          base
                          @JackGruber hab jetzt Version 3.7.9, hatte vorher 3.9, da ging gar nichts.
                          Den Befehl pip install -r requirements.txt habe ich in der Eingabeaufforderung im entsprechenden Ordner durchgeführt, war das so richtig?
                          • B base
                            JackGruberJ Offline
                            JackGruberJ Offline
                            JackGruber
                            @base Ja, genau, dann sollte er alle nötigen module installieren.
                            Hm, muss ich mir mal mit python 3.9 anschauen ...
                            B 2 Antworten Letzte Antwort
                              base
                              @JackGruber wie gesagt, 3.9 hat gar nicht funktioniert bei mir und bei der 3.7.9 bekomme ich die Fehlermeldung
                                base
                                @JackGruber Habe gerade festgestellt, dass die Fehlermeldung nur bei der 64bit Version kommt.
                                Bei der 32èr gehts.
                                Leider bekomme ich jetzt noch einen:
                                MySQL connection error
                                '192.168.1.100'
                                • B base
                                  Bei der 32èr gehts.
                                  '192.168.1.100'
                                  JackGruberJ Offline
                                  JackGruberJ Offline
                                  JackGruber
                                  @base hm komisch grad mit Python 3.9 64 bit getetet und geht 1a.
                                  Python 3.9.0 (tags/v3.9.0:9cf6752, Oct 5 2020, 15:34:40) [MSC v.1927 64 bit (AMD64)]
                                  Das ist die ganze Fehlerausgabe?
                                    base
                                    @JackGruber ja
                                    RESTART: C:\Users\Base\Downloads\iobroker_mysql_2_influxdb-master\iobroker_mysql_2_influxdb-master\migrate.py
                                    '192.168.1.100'
                                    • B base
                                      @JackGruber ja
                                      '192.168.1.100'
                                      JackGruberJ Offline
                                      JackGruberJ Offline
                                      JackGruber
                                      @base teste doch mal in einer powershell folgendes:
                                      Test-NetConnection 192.168.1.100 -p 3307
                                        base
                                        @JackGruber Lernen Sie das neue plattformübergreifende PowerShell kennen – https://aka.ms/pscore6 PS C:\Users\Base> Test-NetConnection 192.168.1.100 -p 3307 WARNUNG: TCP connect to (192.168.1.100 : 3307) failed
                                        ComputerName : 192.168.1.100
                                        RemoteAddress : 192.168.1.100
                                        RemotePort : 3307
                                        InterfaceAlias : WiFi
                                        SourceAddress : 192.168.1.72
                                        PingSucceeded : True
                                        PingReplyDetails (RTT) : 6 ms
                                        TcpTestSucceeded : False
                                          base
                                          @JackGruber PS C:\Users\Base> Test-NetConnection 192.168.1.100 -p 3306 ComputerName : 192.168.1.100
                                          RemotePort : 3306
                                          TcpTestSucceeded : True
                                          PS C:\Users\Base>
