  4. Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi)
    6.6k
xiaomiviomi
108 Beiträge 19 Kommentatoren 22.7k Aufrufe 26 Beobachtet
  • JayRJ JayR
    @Meistertr said in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
    stateChange
    bitte mal einen debug log vom adapterstart und einem befehlsaufruf
    Adapter start:
    mihome-vacuum.0	2020-11-02 08:03:48.508	debug	(18169) server started on 0.0.0.0:53421
    mihome-vacuum.0	2020-11-02 08:03:48.490	debug	(18169) MIIO: Config: ip:192.168.20.115 token: 51xxxxxxxx
    mihome-vacuum.0	2020-11-02 08:03:48.488	debug	(18169) load Map creator... true
    mihome-vacuum.0	2020-11-02 08:03:48.433	info	(18169) check group user admin group admin: false
    mihome-vacuum.0	2020-11-02 08:03:48.424	info	(18169) check user admin pw iobroker: false
    mihome-vacuum.0	2020-11-02 08:03:48.237	info	(18169) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.19.0, js-controller: 3.1.6
    mihome-vacuum.0	2020-11-02 08:03:47.535	debug	(18169) statesDB connected
    mihome-vacuum.0	2020-11-02 08:03:47.534	debug	(18169) States connected to redis: 0.0.0.0:9000
    mihome-vacuum.0	2020-11-02 08:03:47.505	debug	(18169) States create System PubSub Client
    mihome-vacuum.0	2020-11-02 08:03:47.502	debug	(18169) States create User PubSub Client
    mihome-vacuum.0	2020-11-02 08:03:47.485	debug	(18169) Redis States: Use Redis connection: 0.0.0.0:9000
    mihome-vacuum.0	2020-11-02 08:03:47.482	debug	(18169) objectDB connected
    mihome-vacuum.0	2020-11-02 08:03:47.475	debug	(18169) Objects connected to redis: 0.0.0.0:9001
    mihome-vacuum.0	2020-11-02 08:03:47.426	debug	(18169) Objects client initialize lua scripts
    mihome-vacuum.0	2020-11-02 08:03:47.425	debug	(18169) Objects create User PubSub Client
    mihome-vacuum.0	2020-11-02 08:03:47.424	debug	(18169) Objects create System PubSub Client
    mihome-vacuum.0	2020-11-02 08:03:47.420	debug	(18169) Objects client ready ... initialize now
    mihome-vacuum.0	2020-11-02 08:03:47.369	debug	(18169) Redis Objects: Use Redis connection: 0.0.0.0:9001
    Nach Befehlsausführung:
    mihome-vacuum.0	2020-11-02 08:05:58.465	info	(18169) Terminated (NO_ERROR): Without reason
    mihome-vacuum.0	2020-11-02 08:05:58.464	info	(18169) terminating
    mihome-vacuum.0	2020-11-02 08:05:58.443	error	at processImmediate (internal/timers.js:461:21)
    mihome-vacuum.0	2020-11-02 08:05:58.443	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5388:34)
    mihome-vacuum.0	2020-11-02 08:05:58.443	error	at MihomeVacuum.emit (events.js:314:20)
    mihome-vacuum.0	2020-11-02 08:05:58.443	error	at MihomeVacuum.onStateChange (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:282:16)
    mihome-vacuum.0	2020-11-02 08:05:58.443	error	(18169) TypeError: Cannot read property 'stateChange' of null
    mihome-vacuum.0	2020-11-02 08:05:58.440	error	(18169) unhandled promise rejection: Cannot read property 'stateChange' of null
    mihome-vacuum.0	2020-11-02 08:05:56.426	debug	(18169) system.adapter.admin.0: logging false
    Wenn du weiteren Input benötigst, lass es mich wissen :)
    MeistertrM Offline
    MeistertrM Offline
    Meistertr
    @JayR deinstalliere und lösche den adapter mal komplett und lad ihn dann von meiner git seite.
    J JayRJ 2 Antworten Letzte Antwort
    • MeistertrM Meistertr
      jmyxa
      @Meistertr
      Hallo!
      Der Adapter scheint bei mir gut zu starten. Allerdings werden keine Räume als DP angelegt. In der App sind jedoch da.
      Woran kann dies liegen?
      MeistertrM 1 Antwort Letzte Antwort
      • J jmyxa
        @Meistertr
        Hallo!
        MeistertrM Offline
        MeistertrM Offline
        Meistertr
        @jmyxa
        viele sind die Roborock Modelle gewohnt welche mehr oder minder doppelt bis dreifach so teuer sind. Die neueren modelle aus dem Xiaomi Ökosystem setzten immer mehr auf Cloud Kommunikation, das ist auch bei diesen Modellen der Fall. Die Karte und Die Räume gehen hier NUR über die Cloud. von daher können sie nicht abgebildet werden.
        J da_WoodyD 2 Antworten Letzte Antwort
          @jmyxa
          jmyxa
          @Meistertr
          Das ist mir klar, aber ich beziehe mich darauf: https://github.com/MeisterTR/ioBroker.mihome-vacuum#rooms
          Das sollte doch normalerweise gehen, oder?
            JayRJ Offline
            JayRJ Offline
            JayR
            @Meistertr : Hat nicht geholfen. Bekomme folgenden Fehler:
            mihome-vacuum.0	2020-11-08 19:15:09.505	error	(20809) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
            mihome-vacuum.0	2020-11-08 19:15:09.504	error	(20809) unhandled promise rejection: Cannot read property 'val' of null
            mihome-vacuum.0	2020-11-08 19:15:09.504	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            mihome-vacuum.0	2020-11-08 19:14:59.406	info	(20809) check group user admin group admin: false
            JayRJ 1 Antwort Letzte Antwort
            • JayRJ JayR
              JayRJ Offline
              JayRJ Offline
              JayR
              @JayR : funktioniert doch. Habe nach dem neuinstallierten vergessen den Key zu kopieren.
              da_WoodyD JayRJ 2 Antworten Letzte Antwort
              • JayRJ JayR
                da_WoodyD Offline
                da_WoodyD Offline
                @JayR sorry...
                irgendwas ist immer... ;)
                  beigi2512
                  Habe den Xiaomi Mi Robot Vacuum Mop Pro. Funktioniert auch wunderbar. Nur wenn ich den Sauger über den Iobroker starte glaubt er immer er ist im Saug und Wischmodus und fährt dadurch immer so ruckartig( ist normal beim Wischen). Wenn ich es in den Objekten auf Saugen umstelle aktualisiert er es immer wiedwer auf Saugen und Wischen.
                  Gibt es dafür eine Lösung?
                  • JayRJ JayR
                    JayRJ Offline
                    JayRJ Offline
                    JayR
                    @JayR : Hallo zusammen, ich habe noch eine Frage zu dem Adapter. Die Werte werden oft durch die vordefinierten Werte aufgelöst.
                    Wie kann ich die im VIS darstellen, dass die Werte übersetzt werden. Am besten in einem HTML Widget.
                      Solider
                      Moin!
                      Seit heute haben ich auch meinen STYJ02YM.
                      Nach etwas lesen hab ich jetzt erfolgreich die 3.x beta des adapters installiert.
                      Die Verbindung klappt wunderbar. Leider hab ich auch das Problem wie beigi2512 mit dem ungewollten zurückspringen des "is_mop" states.
                      aktion "dock" funktioniert nicht.
                      Funktion "return_dock" klappt.
                      Der Name(Beschreibung) des Objekts "water_grade" stimmt nicht.
                      "is_charge" denke ich mal soll eigentlich zeigen, dass bzw. ob der Robo gerade lädt?
                      Das steht bei mir immer auf "true". obwohl er nicht an der Ladestation hängt. (wird auch immer brav mit "true" aktualisiert :D )
                      Vielleicht ist das obvious, aber ich dachte ich geb mal Feedback ^^
                      ich warte gespannt auf die Kartenumsetzung :o ;)
                      Und evtl. dann mal die Objekte etwas aufräumen. ("battery" in den Ordner "deviceInfo" z.B)
                      Das ist ne Beta und WIP. Also alles in Ordnung ;)
                      Ich stehe gern zum Testen zu Verfügung, bin aktuell 80% im Home-Office ;)
                      Vielen Vielen Dank bisher schonmal! Ich liebe diese Community echt!
                        Aktuelle Test Version 3.0.1-alpha
                        Veröffentlichungsdatum 22.09.2020
                        Github Link https://github.com/MeisterTR/ioBroker.mihome-vacuum
                        Hallo Leute in der letzten Zeit bring Xioami immer mehr Saugroboter auf den Markt die keine Eigenmarke sind und von der bisherigen Api vollkommen abweichen.
                        Um diese und die Zukünftigen Geräte besser und schneller integrieren zu können, war ein kompletter rework des Adapters erforderlich.
                        Was hat sich geändert:
                        • erstmal alles
                        • im alten Adapter wurden erstmal alle daten abgefragt ohne überhaupt zu wissen ob das Model überhaupt die Eigenschaften hat, jetzt wird erst das Model ermittelt und je nachdem dann die verschieden Dateien geladen. Das stabilisiert die Verbindung und führt zu keinen Verbindungsproblemen mehr
                        • jede api/Model bekommt sein eigenes File wo ggf. Funktionen wie Raumreinigung und Karte geladen werden.
                        in den ersten 3er Versionen geht es NUR im die Viomi Modelle (STYJ02YM /Mi Mop Pro und STYJ02YM)
                        wenn die soweit laufen hole ich die anderen nach und nach mit an board
                        JayRJ Offline
                        JayRJ Offline
                        JayR
                        @Meistertr : Ich habe noch Probleme beim Modus einstellen ob dieser Saugen oder Saugen und Wischen soll. Dieses springt immer wieder zurück.
                        Das gleich für das Wasserlevel und Saugstärke. Der Ton abspielen funktioniert auch nicht. Wenn du Logs benötigst oder irgendwelche Hilfe bitte einfach melden.
                        Vielen Dank für die Hilfe und den coolen Adapter.
                        S JayRJ 2 Antworten Letzte Antwort
                        • JayRJ JayR
                          Solider
                          @JayR @Meistertr
                          Ja die Probleme habe ich auch.
                          Verbindung klappt, losschicken und return to dock
                          Mehr aber bisher nicht
                          Merkwürdigerweise kann ich mit Wireshark auch keinen Traffic auslesen bzw zeigt er keinen traffic vom Robo an. alles versucht. Filter: Udp (54321), tcp, ipv4, (ipv6 hat er nicht), Mac Adresse.
                          Immer 0 Pakete.
                            @da_Woody in den ersten 3er Versionen geht es NUR im die Viomi Modelle (STYJ02YM /Mi Mop Pro und STYJ02YM) bei dir liegt es an einem verbindungsabruch, roboter neustarten sollte helfen
                            Flo RianF Offline
                            Flo RianF Offline
                            Flo Rian
                            @Meistertr Hallo, Wird denn hier noch weiter entwickelt?
                            Ich habe das Modell dreame.vacuum.mc1808. Bin mittlerweile wieder auf iRobot umgestiegen bis der Xiaomi eingebunden werden kann :(
                              @jmyxa
                              da_WoodyD Offline
                              da_WoodyD Offline
                              @Meistertr btw: grad gesehn das der iRobot Roomba 960 bei Amazon als "last minute angebot" um 299,99 zu haben ist...
                              • JayRJ JayR
                                JayRJ Offline
                                JayRJ Offline
                                JayR
                                @Meistertr : Kann ich dich dabei unterstützen, den Fehler beim Mop Pro zu finden. Für mich wäre es sehr wichtig. dass es funktioniert.
                                • Jan KappenJ Offline
                                  Jan KappenJ Offline
                                  Jan Kappen
                                  ist der Plan, in der 3.x alle Features der aktuellen 2.1.1 zu integrieren? Wenn ja, können wir dabei unterstützen? @Meistertr , in dem genannten GitHub Repo sind keine Issues aktiv. Möchtest du, dass wir das hier besprechen oder kannst du dich sowieso im Moment nicht gut darum kümmern?
                                    meerkat
                                    habe nun einen 2. Sauger (Xiaomi Mop Pro) zugelegt und habe schon den Roborock S5max. Vom Roborock bin ich auch echt überzeugt, gerade in Verbindung mit der Alexa Steuerung.
                                    Besteht eine Hoffnung, dass man zumindest die Räume in ioBroker vom Xiaomi eingelesen bekommt?
                                    Sonst würde ich das Ding zurücksenden und doch mehr investieren und den kleinen Bruder des S5Max holen.
                                    Gruß und Danke an euch
                                      kakacs
                                      @Meistertr Hallo ich bin gerade auf dein beitrag gestossen, ich habe mir den Xiaomi Viomi Se vor 2 tagen geholt,ich hatte schon raus gelesen das er nicht Alexa fähig ist. aber da ich Iobroker nutze dachte ich ich könnte in einbinden ich habe mir den adapter installiert und er verbindet sich auch die ersten 2 lämpchen nur wie es aus sieht verbindet er sich nicht zum staubsauger. in Objekten ist dann auch der ordner klar steht da xiaomi vacum. Gibts eine möglich keit das ich meinen viomi se richtig einbinden kann ??
                                      • K kakacs
                                        @kakacs Hallo,
                                        Hatte das selbe Problem auch. Es gibt zwei Xiaomi Adapter von MeisterTR. Da der eine Adapter nur geforked ist und leider nicht auf den ersten Blick klar erkennbar ist ob es der Testadapter für die Viomi Geräte ist. Für die Viomi bitte diesen Link folgen und den Adapter installieren. Vorher den alten Adapter löschen. Dieser sollte sich dann sofort nach Konfiguration mit dem Sauger verbinden.
                                          kakacs
                                          @ciddi89 danke für die schnelle antwort. ich hab den link genommen und manuel installiert aber der wird mir nicht in den instanzen angezeigt woran kann das liegen ???
