  4. [Beendet] Test Adapter ecovacs-deebot v0.6.x Latest
deebotecovacssaugrobotervacuum
138 Beiträge 12 Kommentatoren 25.9k Aufrufe 16 Beobachtet
  • C ChrisXY
    Hab nun auch massiv Probleme das er keine Befehle mehr annimmt .. der APP geht es jederzeit
    covacs-deebot.0	2020-11-18 15:01:48.846	info	(23887) Terminated (NO_ERROR): Without reason
    ecovacs-deebot.0	2020-11-18 15:01:48.845	info	(23887) terminating
    ecovacs-deebot.0	2020-11-18 15:01:48.844	info	(23887) cleaned everything up...
    ecovacs-deebot.0	2020-11-18 15:01:48.843	error	(23887) TypeError: Cannot read property 'x' of undefined at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79) at EcovacsMQTT_JSON._han
    ecovacs-deebot.0	2020-11-18 15:01:48.843	error	(23887) uncaught exception: Cannot read property 'x' of undefined
    ecovacs-deebot.0	2020-11-18 15:01:48.455	info	(23887) [vacbot] name: DEEBOT OZMO T8 AIVI
    ecovacs-deebot.0	2020-11-18 15:01:48.454	info	(23887) New Device 0 successfully connected
    ecovacs-deebot.0	2020-11-18 15:01:47.694	info	(23887) Using device Device[0]
    ecovacs-deebot.0	2020-11-18 15:01:47.694	info	(23887) Device[0]: {"did":"cb0e7e17-2fbb-462b-b661-5e47595da2ad","name":"E07D14004B09HDWA0470","class":"x5d34r","resource":"9Zrg","nick":null,"company":"eco-ng","bindTs":1602784388635}
    ecovacs-deebot.0	2020-11-18 15:01:47.693	info	(23887) Number of devices: 1
    ecovacs-deebot.0	2020-11-18 15:01:47.693	info	(23887) Successfully connected to Ecovacs server
    ecovacs-deebot.0	2020-11-18 15:01:46.649	info	(23887) starting. Version 1.0.6-alpha.1 in /opt/iobroker/node_modules/iobroker.ecovacs-deebot, node: v10.20.1, js-controller: 3.1.6
    ecovacs-deebot.0	2020-11-18 15:01:15.269	info	(22955) Terminated (NO_ERROR): Without reason
    ecovacs-deebot.0	2020-11-18 15:01:15.269	info	(22955) terminating
    ecovacs-deebot.0	2020-11-18 15:01:15.254	info	(22955) cleaned everything up...
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at doWrite (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/readable-stream/lib/_stream_writable.js:409:139)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at Writable.writable._write (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:335:5)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at work (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:321:12)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at MqttClient._handlePacket (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:410:12)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at MqttClient._handlePublish (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:1277:12)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at MqttClient.emit (events.js:198:13)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at MqttClient.EcovacsMQTT.client.on (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT.js:44:18)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at EcovacsMQTT_JSON._handle_message (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:230:14)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at EcovacsMQTT_JSON._handle_command (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:306:26)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79)
    ecovacs-deebot.0	2020-11-18 15:01:15.253	error	(22955) TypeError: Cannot read property 'x' of undefined
    ecovacs-deebot.0	2020-11-18 15:01:15.252	error	(22955) uncaught exception: Cannot read property 'x' of undefined
    ecovacs-deebot.0	2020-11-18 15:01:15.142	info	(22955) [vacbot] name: DEEBOT OZMO T8 AIVI
    ecovacs-deebot.0	2020-11-18 15:01:15.137	info	(22955) New Device 0 successfully connected
    ecovacs-deebot.0	2020-11-18 15:01:14.345	info	(22955) Using device Device[0]
    ecovacs-deebot.0	2020-11-18 15:01:14.345	info	(22955) Device[0]: {"did":"cb0e7e17-2fbb-462b-b661-5e47595da2ad","name":"E07D14004B09HDWA0470","class":"x5d34r","resource":"9Zrg","nick":null,"company":"eco-ng","bindTs":1602784388635}
    ecovacs-deebot.0	2020-11-18 15:01:14.345	info	(22955) Number of devices: 1
    ecovacs-deebot.0	2020-11-18 15:01:14.344	info	(22955) Successfully connected to Ecovacs server
    ecovacs-deebot.0	2020-11-18 15:01:13.351	info	(22955) starting. Version 1.0.6-alpha.1 in /opt/iobroker/node_modules/iobroker.ecovacs-deebot, node: v10.20.1, js-controller: 3.1.6
    ecovacs-deebot.0	2020-11-18 15:00:42.111	info	(22251) Terminated (NO_ERROR): Without reason
    ecovacs-deebot.0	2020-11-18 15:00:42.111	info	(22251) terminating
    ecovacs-deebot.0	2020-11-18 15:00:42.109	info	(22251) cleaned everything up...
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at doWrite (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/readable-stream/lib/_stream_writable.js:409:139)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at Writable.writable._write (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:335:5)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at work (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:321:12)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at MqttClient._handlePacket (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:410:12)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at MqttClient._handlePublish (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:1277:12)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at MqttClient.emit (events.js:198:13)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at MqttClient.EcovacsMQTT.client.on (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT.js:44:18)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at EcovacsMQTT_JSON._handle_message (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:230:14)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at EcovacsMQTT_JSON._handle_command (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:306:26)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79)
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	(22251) TypeError: Cannot read property 'x' of undefined
    ecovacs-deebot.0	2020-11-18 15:00:42.108	error	(22251) uncaught exception: Cannot read property 'x' of undefined
    ecovacs-deebot.0	2020-11-18 15:00:40.947	info	(22251) [vacbot] name: DEEBOT OZMO T8 AIVI
    ecovacs-deebot.0	2020-11-18 15:00:40.946	info	(22251) New Device 0 successfully connected
    ecovacs-deebot.0	2020-11-18 15:00:40.332	info	(22251) Using device Device[0]
    ecovacs-deebot.0	2020-11-18 15:00:40.332	info	(22251) Device[0]: {"did":"cb0e7e17-2fbb-462b-b661-5e47595da2ad","name":"E07D14004B09HDWA0470","class":"x5d34r","resource":"9Zrg","nick":null,"company":"eco-ng","bindTs":1602784388635}
    ecovacs-deebot.0	2020-11-18 15:00:40.332	info	(22251) Number of devices: 1
    ecovacs-deebot.0	2020-11-18 15:00:40.332	info	(22251) Successfully connected to Ecovacs server
    ecovacs-deebot.0	2020-11-18 15:00:39.460	info	(22251) starting. Version 1.0.6-alpha.1 in /opt/iobroker/node_modules/iobroker.ecovacs-deebot, node: v10.20.1, js-controller: 3.1.6
    ecovacs-deebot.0	2020-11-18 15:00:34.339	info	(21868) Terminated (NO_ERROR): Without reason
    ecovacs-deebot.0	2020-11-18 15:00:34.339	info	(21868) terminating
    ecovacs-deebot.0	2020-11-18 15:00:34.338	info	(21868) cleaned everything up...
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at doWrite (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/readable-stream/lib/_stream_writable.js:409:139)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at Writable.writable._write (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:335:5)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at work (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:321:12)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at MqttClient._handlePacket (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:410:12)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at MqttClient._handlePublish (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:1277:12)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at MqttClient.emit (events.js:198:13)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at MqttClient.EcovacsMQTT.client.on (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT.js:44:18)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at EcovacsMQTT_JSON._handle_message (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:230:14)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at EcovacsMQTT_JSON._handle_command (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:306:26)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79)
    ecovacs-deebot.0	2020-11-18 15:00:34.337	error	(21868) TypeError: Cannot read property 'x' of undefined
    ecovacs-deebot.0	2020-11-18 15:00:34.336	error	(21868) uncaught exception: Cannot read property 'x' of undefined
    ecovacs-deebot.0	2020-11-18 15:00:31.707	info	(21868) [vacbot] name: DEEBOT OZMO T8 AIVI
    ecovacs-deebot.0	2020-11-18 15:00:31.706	info	(21868) New Device 0 successfully connected
    ecovacs-deebot.0	2020-11-18 15:00:31.009	info	(21868) Using device Device[0]
    ecovacs-deebot.0	2020-11-18 15:00:31.009	info	(21868) Device[0]: {"did":"cb0e7e17-2fbb-462b-b661-5e47595da2ad","name":"E07D14004B09HDWA0470","class":"x5d34r","resource":"9Zrg","nick":null,"company":"eco-ng","bindTs":1602784388635}
    ecovacs-deebot.0	2020-11-18 15:00:31.009	info	(21868) Number of devices: 1
    ecovacs-deebot.0	2020-11-18 15:00:31.008	info	(21868) Successfully connected to Ecovacs server
    ecovacs-deebot.0	2020-11-18 15:00:29.985	info	(21868) starting. Version 1.0.6-alpha.1 in /opt/iobroker/node_modules/iobroker.ecovacs-deebot, node: v10.20.1, js-controller: 3.1.6
    ecovacs-deebot.0	2020-11-18 14:59:58.900	info	(21000) Terminated (NO_ERROR): Without reason
    ecovacs-deebot.0	2020-11-18 14:59:58.900	info	(21000) terminating
    ecovacs-deebot.0	2020-11-18 14:59:58.898	info	(21000) cleaned everything up...
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at doWrite (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/readable-stream/lib/_stream_writable.js:409:139)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at Writable.writable._write (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:335:5)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at work (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:321:12)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at MqttClient._handlePacket (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:410:12)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at MqttClient._handlePublish (/opt/iobroker/node_modules/ecovacs-deebot/node_modules/mqtt/lib/client.js:1277:12)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at MqttClient.emit (events.js:198:13)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at MqttClient.EcovacsMQTT.client.on (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT.js:44:18)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at EcovacsMQTT_JSON._handle_message (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:230:14)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at EcovacsMQTT_JSON._handle_command (/opt/iobroker/node_modules/ecovacs-deebot/library/ecovacsMQTT_JSON.js:306:26)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79)
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	(21000) TypeError: Cannot read property 'x' of undefined
    ecovacs-deebot.0	2020-11-18 14:59:58.897	error	(21000) uncaught exception: Cannot read property 'x' of undefined
    ecovacs-deebot.0	2020-11-18 14:59:58.178	info	(21000) [vacbot] name: DEEBOT OZMO T8 AIVI
    ecovacs-deebot.0	2020-11-18 14:59:58.177	info	(21000) New Device 0 successfully connected
    ecovacs-deebot.0	2020-11-18 14:59:57.548	info	(21000) Using device Device[0]
    Und alle paar minuten taucht das im Log auf:
    ecovacs-deebot.0	2020-11-18 15:02:24.853	error	(24615) TypeError: Cannot read property 'x' of undefined at VacBot_950type._handle_position (/opt/iobroker/node_modules/ecovacs-deebot/library/vacBot_950type.js:54:79) at EcovacsMQTT_JSON._han
    ecovacs-deebot.0	2020-11-18 15:02:24.852	error	(24615) uncaught exception: Cannot read property 'x' of undefined
    mrbungle64M Offline
    mrbungle64M Offline
    mrbungle64
    #90
    @ChrisXY
    Wieso hast Du die (Alpha) Version von GitHub installiert?
    C 1 Antwort Letzte Antwort
    • C ChrisXY
      mrbungle64M Offline
      mrbungle64M Offline
      mrbungle64
      #91
      @ChrisXY said in Test Adapter ecovacs-deebot v0.6.x Latest:
      Und: wer hat denn noch "massiv" Probleme?
      • mrbungle64M mrbungle64
        @ChrisXY
        ChrisXY
        #92
        @mrbungle64
        wieso nicht zurück auf die 1.0.5 und es geht wieder.
        Ich hab paar Wochen kein Update des Adapters gemacht und bevor ich nu mit den Spots und VIS rum mache wollte ich es aktuell haben.
        Wohl zu "aktuell"
        mrbungle64M 1 Antwort Letzte Antwort
        • C ChrisXY
          @mrbungle64
          Wohl zu "aktuell"
          mrbungle64M Offline
          mrbungle64M Offline
          mrbungle64
          #93
          @mrbungle64
          wieso nicht
          Weil Du dann hier von massiven Problemen berichtest anstatt mal auf unsere Fragen bzw. unsere Bitte einzugehen
          • boriswernerB boriswerner
            Hallo, danke für die Ausführliche Erklärung. Mein Aivi T8 hat unter "cleaninglog.last20Logs" und "cleaninglog.lastCleaningMapImageURL" keine einträge. In der App tauchen diese aber auf ...
            @stefande said in Test Adapter ecovacs-deebot v0.6.x Latest:
            OK das kann ich nachvollziehen, und ich muss wohl erstmal damit leben.
            Trotzdem Danke für Eure Bemühungen und die Erstellung des Adapters.
            Mal gucken was die Zukunft noch bringt.
            Falls ihr noch was zu Testen habt, ich wäre bereit.
            Hi @stefande, hi @ChrisXY es gibt in der API wohl eine neue Funktion zum Abruf von Cleaninglogs. Bei mir ist das Ergebnis leer, aber bei meinem 950 funktioniert auch die bestehende Methode noch einwandfrei.
            Wäre cool, wenn ihr (oder natürlich auch jeder andere mit einem 920/950/T5/T8/T8 AIVI, der keine CleanLogs hat) mal eine Testapp aufrufen würdet und das Ergebnis posten könntet. Dazu müsste die library einmal aus meinem github per Kommandozeile installiert werden und eine Testapp ausgeführt werden (die Version in iobroker bleibt dadurch unangetastet):
            Wenn ihr die library vorher schonmal zum debug installiert habt am besten einmal aufräumen (bitte sicherstellen, dass ihr nicht im iobroker Adapterverzeichnis, sondern z.B. im Benutzer home Verzeichnis seid oder alternativ vor den Schritten unten in ein neu erstelltes Verzeichnis wechseln). Der Befehl kann dann nach dem Test auch wieder genutzt werden um aufzuräumen.
            sudo rm -r ecovacs-deebot.js
            Im folgenden bitte in den sed-Befehlen "deineMailAddresse" und "deinPasswort" durch eure Zugangsdaten ersetzen, die werden dann in die Datei geschrieben.
            git clone https://github.com/boriswerner/ecovacs-deebot.js.git
            cd ecovacs-deebot.js
            npm install
            cd example
            sed -i 's/email@domain.com/deineMailAddresse/g' app2TestCleanLogPull.js
            sed -i 's/a1b2c3d4/deinPasswort/g' app2TestCleanLogPull.js
            NODE_ENV=dev node app2TestCleanLogPull.js | grep -E 'Logs'
            Der Output sollte etwa so aussehen:
            [VacBot] action: GetCleanLogsPullCleanF
            [EcovacsMQTT_JSON] Logs: {"resultCode":"0","resultCodeMessage":"ok","resultData":{"ret":"ok","logs":[]}}
            Wie man bei mir sieht, ist das logs-Array leer, ich hoffe, dass da bei euch mehr kommt.
            Achja, das Programm kann dann mit Strg-C ordentlich beendet werden.
            Vielen Dank.
            boriswernerB Online
            boriswernerB Online
            boriswerner
            #94
            @ChrisXY wenn du schonmal dabei bist, könntest du das hier einmal ansehen und das Ergebnis posten?
              ChrisXY
              #95
              @boriswerner
              ohhhhh sorry das hab ich nicht gesehen. Hab es direkt mal gemacht. Gerne auch PN wenn du genaueres testen willst.
              Leider kommt nicht mehr soll ich mal eien Reinigung durchlaufen lassen?
              boriswernerB 1 Antwort Letzte Antwort
              • C ChrisXY
                @boriswerner
                boriswernerB Online
                boriswernerB Online
                boriswerner
                #96
                @ChrisXY Okay, dank dir. Du hast aber weiterhin
                wie du letztens mal geschrieben hast? Auch nicht mit der alternativen Funktion in der Instanzkonfiguration (unter "weiteres")?
                Dann haben wir wohl leider doch nicht die neue magische Log-Abruffunktion gefunden...
                  ChrisXY
                  #97
                  @boriswerner genau da war noch nie etwas glaub ich .. Zeigt mir nur die Totale Laufzeiten.
                  Ich hab mit den alternativ API schon rumprobiert ändert nichts
                  Gibt es etwas zur Erkennung in welchem Raum er sich aktuell befindet ? 90% hab ich immer unknown dort stehen.
                  • C ChrisXY
                    boriswernerB Online
                    boriswernerB Online
                    boriswerner
                    #98
                    @ChrisXY Komisch. Bei mir funktioniert das sehr zuverlässig, außer in Randbereichen/Übergängen zwischen zwei Räumen. Siehe meine Erklärung hier:
                    https://github.com/mrbungle64/ioBroker.ecovacs-deebot/issues/94
                    Wichtig ist halt, dass es in der Karte in der App vom farbigen Bereich abgedeckt sein muss. Nur das Polygon wird dann als Raum erkannt
                    C S 2 Antworten Letzte Antwort
                      ChrisXY
                      #99
                      @boriswerner ja habe eine saubere Karte mit Bereichen.
                      Glaube es trifft einen Raum den ich zusammengefügt und wieder getrennt habe. Danach wieder sauber beschriftet. Unter den Objekten bei Control stehen die Räume drin aber nicht mit meinem Namen.
                      Kann man das irgendwie neu updaten ? Cool wäre auch wenn die Spots verschwinden die nicht aktiv sind.
                      • C ChrisXY
                        boriswernerB Online
                        boriswernerB Online
                        boriswerner
                        #100
                        @ChrisXY Im control stehen die auch nicht mit den Namen drin (ich glaube, die werden mittlerweile auch gar nicht mehr angelegt, wenn man neu aufsetzt, oder @mrbungle64 ? also du meinst die spotArea_0, spotArea_1 usw. oder?).
                        Die Namen gibt es nur unter den Objekten unter dem map-Ordner.
                        Da findest du dann alle Karten als Ordner (die Ordner, wo mapIsAvailable auf false steht, kannst du manuell löschen, ebenso die spotAreas wo spotAreaIsAvailable false ist um aufzuräumen). Da gibt es dann u.a. auch für jede existierende spotArea einen clean-Button/State
                        Beobachte mal, ob der Bot bei einer Reinigung auch unknown als currentSpotArea liefert, wenn er sich "mitten" in einem farbigen Bereich der Karte befindet oder nur in Randbereichen.
                          stefande
                          #101
                          @boriswerner @mrbungle64
                          Bei meinem 950er bekomme ich seit rund einer Woche öfters mal den Status "unknown" in den Objekten: chargestatus, cleanstatus und deviceStatus.
                          Aktuell bin ich auf der Version 1.0.5
                          Blöderweise nutze ich den chargestatus, um zu detektieren, ob der Saugi in der Station ist.
                          In den Log Dateien ist nix zu erkennen.
                          Debug hab ich aktuell noch nicht aktiviert, da der Fehler immer nur mal sporadisch auftritt. Trotzdem war ich letzte Nacht etwas angepisst, als mir Alexa gegen kurz nach 4 Uhr mitteilte, dass "Saugi unterwegs ist".
                          Hat jemand von Euch ne Idee, woher das "unknown" plötzlich kommt, oder zumindest eine Idee, wie ich zuverlässig erkennen kann, ob Saugi in der Station ist?
                          mrbungle64M boriswernerB 2 Antworten Letzte Antwort
                          • S stefande
                            mrbungle64M Offline
                            mrbungle64M Offline
                            mrbungle64
                            schrieb am zuletzt editiert von mrbungle64
                            #102
                            Hallo @stefande
                            wird die Adapter Instanz nachts um 4 Uhr autom. neu gestartet?
                            Der Wert "unknown" wird nämlich beim Start eingetragen (quasi als Reset) und wieder direkt befüllt (vorausgesetzt die Verbindung wird erfolgreich hergestellt).
                            Evtl. kam heute Nacht dann keine Verbindung zum Ecovacs Server zustande.
                            Ich werde das evtl. mal wieder ausbauen, dass die Status resettet werden.
                              mrbungle64M Offline
                              mrbungle64M Offline
                              mrbungle64
                              #103
                              @boriswerner said in Test Adapter ecovacs-deebot v0.6.x Latest:
                              Da steckt noch was im Code was die mit den Ordnern unter "map" synchronisieren sollte - aber das Löschen ist auskommentiert und das Anlegen scheint nicht richtig zu funktionieren.
                              Das hatte ich wegen diesem Issue hier mal eingebaut - aber vom Ersteller dann keine Rückmeldung mehr bekommen...
                              • S stefande
                                boriswernerB Online
                                boriswernerB Online
                                boriswerner
                                #104
                                @stefande mir ist das auch aufgefallen. Ich bekomme auch ab und an mal den Status "alert". Ecovacs scheint da etwas an der API getan zu haben soweit ich das auf die schnelle beurteilen kann. Ich wollte mir das am Wochenende mal genauer ansehen.
                                Das mit dem reset des Status, den @mrbungle64 erwähnt hat ist aber natürlich auch ein guter Punkt.
                                  stefande
                                  #105
                                  In der Tat wird bei mir, in jeder Nacht zum Mittwoch, die Internet Verbindung kurz getrennt.
                                  Nicht desto trotz hatte ich das "unknown" in der letzten Woche zwei oder drei Mal, ohne dass die Internet Verbindung weg war.
                                  Ihr werde jetzt erstmal die Ansage deaktivieren, bevor ich nachts wieder geweckt werde.
                                  Vielleicht überdenkt ihr das Feature noch mal. 👼
                                  • S stefande
                                    mrbungle64M Offline
                                    mrbungle64M Offline
                                    mrbungle64
                                    #106
                                    Hatte ich ja schon geschrieben ;)
                                      stefande
                                      #107
                                      @mrbungle64 sagte in Test Adapter ecovacs-deebot v0.6.x Latest:
                                      • S stefande
                                        ChrisXY
                                        schrieb am zuletzt editiert von ChrisXY
                                        #108
                                        Fände es auch gut wenn er sich vielleicht den letzten Ort merkt auch wenn er mal an den Rand der Karte fährt. Hab bei mir eine anzeige gebaut und wenn er nur im schmalen Flur ist zeigt diese oft keinen Standort mehr an ;)
                                        Und oft steht bei mir Status Idle obwohl er was macht. Gibt es einen zuverlässigen Status wenn er Reinigt ?
                                        mrbungle64M 2 Antworten Letzte Antwort
                                        • C ChrisXY
                                          mrbungle64M Offline
                                          mrbungle64M Offline
                                          mrbungle64
                                          #109
                                          Das wurde hier schon mal angefangen zu diskutieren.
                                          Ich werfe noch mal meine Frage in den Raum - vielleicht können wir uns ja darauf einigen ;)
                                          Definiere "zuverlässig" ;)
                                          Ich denke Nutzer von Ecovacs Geräten kennen das alle, dass die App gar nicht mal so selten keine Verbindung bekommt.
                                          Wir können leider nicht garantieren, dass der Adapter zuverlässiger funktioniert als die Hersteller-eigene Software, da auch der Adapter darauf angewiesen ist, was die Ecovacs Server liefern. Eine direkte Verbindung zu den Geräten ist lt. aktuellem Stand leider nicht möglich.
                                          Von daher würde ich Dich bitten detaillierte Informationen zu liefern und auch möglichst einen Issue auf GitHub zu erstellen, so dass wir das Problem analysieren und lösen können.
