  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • S Snapergy
    @simatec
    aktuell:
    [DEBUG] [history] start with {"type":"creator","time":"01:00","debugging":true,"everyXDays":"1","nameSuffix":"Backitup","deleteBackupAfter":0,"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"11. November 2020 um 07:38 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    simatecS Offline
    simatecS Offline
    simatec
    #780
    @Snapergy
    Ok er bleibt bei der History hängen, was bedeutet, das irgendwas bei einem Update mal schief gegangen ist.
    Bitte mache folgendes Schritt für Schritt:
    Gehe per Konsole auf den Ordner /opt/iobroker/node_modules/iobroker.backitup und führe folgende Befehl aus:
    npm install
    Sollte danach der Fehler nicht weg sein, führe bitte folgende Schritte aus:
    • Instanz von Backitup löschen
    • Backitup im Tab Adapter löschen
    • Schauen, ob der Ordner backitup.0 im Tab Objekte gelöscht wurde
    • Dein System rebooten
    • Backitup installieren und konfigurieren
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      @Snapergy
      npm install
      Snapergy
      schrieb am zuletzt editiert von Snapergy
      #781
      @simatec
      mit
      npm install
      geht der Fehler leider nicht weg, den Rest werde ich morgen Vormittag mal ausprobieren. Komischerweise habe ich den Adapter glaube ich gar nicht geupdatet, sonder erst vor zwei Wochen installiert. Bis vor ein paar Tag ging alles reibungslos, erst jetzt taucht der Fehler auf 🤔
      EDIT: Aber grundsätzlich sind die Backups vollständig?
      • S Snapergy
        @simatec
        mit
        npm install
        simatecS Offline
        simatecS Offline
        simatec
        #782
        @Snapergy
        Ja das passiert beim erstellen der History. Die Backups sind da bereits erstellt
        S HALH 2 Antworten Letzte Antwort
        • simatecS simatec
          @Snapergy
          Snapergy
          #783
          @simatec
          Alles wie vorgeschlagen durchgeführt und nun klappt wieder alles, danke :)
          • simatecS simatec
            @Snapergy
            HALH Offline
            HALH Offline
            HAL
            #784
            @simatec mal eine "unverschämte" Frage. Da ich seit kurzem eine PV Anlage mit Speicher + Wallbox habe, nutze ich für die Speicherung der Werte eine influxdb und zur grafischen Anzeige Grafana. Das läuft auch prima mit iobroker zusammen.
            Es wäre toll wenn ich zur Sicherung auch den backitup Adapter nutzen könnte :-)
            Backup für influxdb ist eigentlich ganz einfach:
            sudo influxd backup -portable /opt/backups/influx.backup
            restore auch
            influxd restore -portable /opt/backups/influx.backup
            für Grafana ist es komplizierter (siehe: https://www.bachmann-lan.de/grafana-backup-dashboards-data-sources/)
            Momentan starte ich zwei scripte über die shell.
            Ob man das "irgendwann mal" in den Backitup Adapter aufnehmen könnte ?
            Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
            (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
            simatecS 2 Antworten Letzte Antwort
            • HALH HAL
              restore auch
              simatecS Offline
              simatecS Offline
              simatec
              #785
              @HAL
              Ist mit auf der Todo ...
              • simatecS simatec
                Aktuelle Test Version 3.1.0
                Veröffentlichungsdatum 02.03.2025
                Github Link https://github.com/simatec/ioBroker.backitup
                Wiki Link https://github.com/simatec/ioBroker.backitup/wiki
                Hier geht es um die aktuelle Version von ioBroker.backitup, nachdem der alte Thread langsam zu unübersichtlich wurde.
                Bitte gebt euer Feedback und eure Anregungen hier ab.
                3.1.0 (2025-03-02)
                • (Bluefox) Dependencies updated
                • (Bluefox) Vite added
                • (simatec) jsonConfig updated
                • (simatec) Fix month for history
                3.0.37 (2025-02-28)
                • (simatec) Fix CronJob
                3.0.36 (2025-02-26)
                • (simatec) Fix src-admin
                3.0.35 (2025-02-26)
                3.0.34 (2025-02-26)
                3.0.33 (2025-02-25)
                • (simatec) Fix cronjob
                • (simatec) Fix Backup Console
                3.0.32 (2025-02-24)
                • (simatec) Error handling for GoogleDrive fix
                • (simatec) globalDependencies updated
                • (simatec) Dependencies updated
                • (simatec) Design Fix
                3.0.31 (2024-11-30)
                • (simatec) Fix Tab Menu
                3.0.30 (2024-11-29)
                3.0.29 (2024-11-29)
                3.0.28 (2024-11-27)
                • (simatec) eslint-config added
                • (bluefox) Allow to store files for up to ca 3 years
                • (Marc-Berg) Grafana Docu updated
                3.0.27 (2024-11-12)
                • (simatec) dependencies updated
                3.0.26 (2024-10-16)
                • (simatec) Fix FTP Connections
                • (simatec) Issue Workflow added
                3.0.25 (2024-09-26)
                • (bluefox) Improvement of Google Drive authentication workflow
                • (bluefox) Removed gulp from a build process
                • (simatec) small Design Fix
                • (simatec) Fix for Admin 7.1.5
                • (simatec) Fix Test & Release
                • (simatec) Fix ESlint errors
                3.0.22 (2024-09-03)
                • (simatec) Fix Notification Instance
                • (simatec) Fix Notification Design
                • (simatec) Fix Default Settings
                3.0.21 (2024-09-01)
                • (simatec) Fix Onedrive Notification
                • (simatec) Fix Zigbee2MQTT Backup
                3.0.20 (2024-08-22)
                • (simatec) Responsive Design for Tab added
                • (simatec) Responsive Design for jsonConfig added
                3.0.19 (2024-08-15)
                • (simatec) Fix CCU Backup
                • (simatec) Fix InfluxDB Backup Config
                • (simatec) Fix Backup-Log for Slave Instanz
                3.0.18 (2024-08-14)
                • (simatec) Package optimisation
                • (simatec) Fix the warning when opening the configuration
                3.0.17 (2024-08-12)
                • (simatec) Fix io-package for Release
                • (simatec) manual-review added
                • (simatec) Fix Slave Backup
                3.0.16 (2024-08-05)
                • (bluefox) dependencies updated
                • (simatec) Rename json5 Files
                3.0.15 (2024-08-03)
                • (simatec) fix dependencies
                3.0.14 (2024-08-02)
                • (simatec) Improved log outputs
                3.0.12 (2024-08-01)
                • (simatec) Backup Log for History added
                • (simatec) Added separate selection for deleting FTP backups
                • (simatec) Added separate selection for deleting Onedrive backups
                • (simatec) Added separate selection for deleting Webdav backups
                • (simatec) Added separate selection for deleting Dropbox backups
                • (simatec) Added separate selection for deleting Googledrive backups
                • (simatec) Source code cleaned up
                3.0.11 (2024-07-28)
                3.0.10 (2024-07-22)
                • (simatec) Design Fix for Dark Mode
                3.0.9 (2024-07-11)
                • (simatec) Tab Icons added
                • (simatec) small fix
                • (simatec) Docu updated
                3.0.8 (2024-07-01)
                • (Grothesk242/simatec) forceuid and forcegid added
                3.0.7 (2024-06-26)
                • (simatec) Restore Information added
                • (simatec) Fix Formaterrors
                • (bluefox) Fixing the problems with styles
                • (simatec) Fix iobroker Backup Error
                3.0.6 (2024-06-26)
                3.0.5 (2024-06-18)
                • (simatec) Fix Build
                3.0.4 (2024-06-18)
                • (simatec) History Gui Fix
                • (simatec) Tab GUI modified
                • (bluefox) Added support for Admin 7
                • (simatec) Onedrive ready for School/Business Accounts
                3.0.3 (2024-06-10)
                • (simatec) Fixed WebDav
                • (simatec) Admin Notification for Backup errors added
                • (simatec) Remove Sentry Config
                • (simatec) Translations updated
                • (simatec) Error handling optimized
                3.0.2 (2024-06-06)
                • (simatec) Fixed Google Drive
                • (simatec) Fixed Translations
                • (simatec) Fixed Onedrive
                • (simatec) Fixed MySql Backup
                • (simatec) Fixed Translation added
                • (simatec) new notifications content added
                3.0.1 (2024-05-29)
                • (simatec) Fixed umount callback
                • (simatec) Fixed Backup Message
                • (simatec) Fixed InfluxDB Multi Backup
                • (simatec) Fixed Restore Console
                • (simatec) Fixed Backup Console
                3.0.0 (2024-05-28)
                • (simatec) jsonConfig added
                • (bluefox) Conversion to React
                • (bluefox) Added react components
                • (bluefox/simatec) Working on React GUI
                • (simatec) Fix Yahka Backup
                • (simatec) Fix Nodered Backup
                • (simatec) some bugs fixed
                • (bluefox/simatec) New Restore-Interface
                • (simatec) Translation updated
                tobitobsta
                schrieb am zuletzt editiert von tobitobsta
                #786
                Super cooler Adapter, der mir schon einige Male den Hintern gerettet hat! Danke!
                beim gestrigen Schrotten meines iobroker rasp pi ist beim Zurückspielen auf die frische Installation folgender Fehler aufgetreten:
                DEBUG] [redis] Start Redis Restore ...
                [DEBUG] [redis] Created Redis tmp
                [ERROR] [redis] Redis Restore not completed
                [ERROR] [redis] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/tmp/'
                [EXIT] undefined **** Restore completed successfully!! ****
                The log can be closed ...
                Der Restore von Iobroker selbst hat funktioniert... nur eben Redis nicht. Auch die fehlenden Werte in den Objekten (und die sehr kleinen Redis-Backups nach diesem restore) deuten darauf hin dass das Zurückspielen nicht funktioniert hat.
                Habe die frische Installation zuvor auf Redis umgestellt und Redis vorher installiert.
                Dann habe ich auch
                sudo usermod -a -G redis iobroker
                und zur Vorsicht noch
                curl -fsL https://iobroker.net/fix.sh | bash -
                sowie zwischendurch immer reboots durchgeführt. So langsam komme ich mit meinen begrenzten Mitteln nicht weiter. Hat jemand eine Idee?
                Tobi
                update:
                ich habe mal diesen ordner /opt/iobroker/backups/tmp als root mit 0777 angelegt -> selbe Fehlermeldung und nachdem Redis-Restore-Versuch ist der wieder weg.
                • T tobitobsta
                  Dann habe ich auch
                  Tobi
                  update:
                  #787
                  @tobitobsta sagte in Test Adapter Backitup v1.7.x:
                  Ganz schlechte Idee...
                  Im Normalzustand gibt es den Ordner auf meinem System auch gar nicht. Vermutlich wird der während des Backups wirklich nur temporär angelegt.
                  Was jetzt aber da konkret bei dir falsch / anders läuft kann ich nur raten.
                  Apropos raten: Ich würde dir raten, dich nicht als root anzmelden und dann in den Verzeichnispfaden rumzufummeln.
                  Dateisystem ist aber gesund?
                  Mit
                  dmesg
                  mal schauen.
                  Die user sind in den passenden Gruppen?
                  sudo -u iobroker groups
                  groups
                    Mit
                    dmesg
                    mal schauen.
                    groups
                    tobitobsta
                    #788
                    @Thomas-Braun
                    Danke für den Hinweis bzgl root und Verzeichnisstrukturen.
                    Dateisystem sieht erstmal okay aus.
                    iobroker befindet sich auch in der redis-gruppe. Der user "pi" jedoch nicht - müsste er das? Denke iobroker sollte reichen.
                    leider kann ich aus dem redis log auch nichts rauslesen - zumindest sieht es da nicht nach einem abgelehnten zugriffsversuch aus.
                    • T tobitobsta
                      @Thomas-Braun
                      #789
                      @tobitobsta Poste doch mal bitte die Ausgaben der Befehle.
                        tobitobsta
                        #790
                        @Thomas-Braun
                        here we go (dmesg):
                        [    0.872784] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                        [    0.873037] io scheduler mq-deadline registered
                        [    0.873066] io scheduler kyber registered
                        [    0.877118] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                        [    0.877163] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                        [    0.877268] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
                        [    0.877359] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
                        [    0.936694] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
                        [    0.937034] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                        [    0.937069] pci_bus 0000:00: root bus resource [bus 00-ff]
                        [    0.937103] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
                        [    0.937183] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                        [    0.937467] pci 0000:00:00.0: PME# supported from D0 D3hot
                        [    0.940741] PCI: bus0: Fast back to back transfers disabled
                        [    0.940990] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                        [    0.941153] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                        [    0.941602] pci 0000:01:00.0: PME# supported from D0 D3cold
                        [    0.944910] PCI: bus1: Fast back to back transfers disabled
                        [    0.944986] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                        [    0.945024] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                        [    0.945125] pci 0000:00:00.0: PCI bridge to [bus 01]
                        [    0.945164] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                        [    0.945492] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                        [    0.945754] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
                        [    0.946174] pcieport 0000:00:00.0: AER: enabled with IRQ 55
                        [    0.946534] pci 0000:01:00.0: enabling device (0140 -> 0142)
                        [    0.953506] iproc-rng200 fe104000.rng: hwrng registered
                        [    0.953858] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                        [    0.954521] vc-sm: Videocore shared memory driver
                        [    0.955174] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                        [    0.967382] brd: module loaded
                        [    0.979746] loop: module loaded
                        [    0.981183] Loading iSCSI transport class v2.0-870.
                        [    0.983154] libphy: Fixed MDIO Bus: probed
                        [    0.983801] bcmgenet fd580000.ethernet: failed to get enet clock
                        [    0.983837] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                        [    0.983875] bcmgenet fd580000.ethernet: failed to get enet-wol clock
                        [    0.983911] bcmgenet fd580000.ethernet: failed to get enet-eee clock
                        [    0.983954] bcmgenet: Skipping UMAC reset
                        [    0.994628] libphy: bcmgenet MII bus: probed
                        [    1.084660] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                        [    1.085698] usbcore: registered new interface driver r8152
                        [    1.085779] usbcore: registered new interface driver lan78xx
                        [    1.085853] usbcore: registered new interface driver smsc95xx
                        [    1.086309] xhci_hcd 0000:01:00.0: xHCI Host Controller
                        [    1.086358] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                        [    1.088980] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
                        [    1.090301] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
                        [    1.090340] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                        [    1.090375] usb usb1: Product: xHCI Host Controller
                        [    1.090403] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
                        [    1.090432] usb usb1: SerialNumber: 0000:01:00.0
                        [    1.091051] hub 1-0:1.0: USB hub found
                        [    1.091175] hub 1-0:1.0: 1 port detected
                        [    1.091773] xhci_hcd 0000:01:00.0: xHCI Host Controller
                        [    1.091815] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                        [    1.091857] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                        [    1.092403] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
                        [    1.092442] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                        [    1.092476] usb usb2: Product: xHCI Host Controller
                        [    1.092505] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
                        [    1.092534] usb usb2: SerialNumber: 0000:01:00.0
                        [    1.093132] hub 2-0:1.0: USB hub found
                        [    1.093248] hub 2-0:1.0: 4 ports detected
                        [    1.094789] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                        [    1.095098] dwc_otg: FIQ enabled
                        [    1.095111] dwc_otg: NAK holdoff enabled
                        [    1.095123] dwc_otg: FIQ split-transaction FSM enabled
                        [    1.095139] Module dwc_common_port init
                        [    1.095581] usbcore: registered new interface driver uas
                        [    1.095704] usbcore: registered new interface driver usb-storage
                        [    1.095912] mousedev: PS/2 mouse device common for all mice
                        [    1.097794] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                        [    1.101249] sdhci: Secure Digital Host Controller Interface driver
                        [    1.101281] sdhci: Copyright(c) Pierre Ossman
                        [    1.101909] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                        [    1.102495] sdhci-pltfm: SDHCI platform and OF driver helper
                        [    1.106361] ledtrig-cpu: registered to indicate activity on CPUs
                        [    1.106691] hidraw: raw HID events driver (C) Jiri Kosina
                        [    1.106903] usbcore: registered new interface driver usbhid
                        [    1.106931] usbhid: USB HID core driver
                        [    1.107978] vchiq: vchiq_init_state: slot_zero = (ptrval)
                        [    1.111604] [vc_sm_connected_init]: start
                        [    1.120598] [vc_sm_connected_init]: end - returning 0
                        [    1.122844] Initializing XFRM netlink socket
                        [    1.122898] NET: Registered protocol family 17
                        [    1.123030] Key type dns_resolver registered
                        [    1.123414] Registering SWP/SWPB emulation handler
                        [    1.123733] registered taskstats version 1
                        [    1.123766] Loading compiled-in X.509 certificates
                        [    1.124310] Key type ._fscrypt registered
                        [    1.124338] Key type .fscrypt registered
                        [    1.135099] uart-pl011 fe201000.serial: cts_event_workaround enabled
                        [    1.135193] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
                        [    1.141319] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                        [    1.142324] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                        [    1.142356] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                        [    1.194371] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                        [    1.196125] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                        [    1.197983] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                        [    1.201000] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                        [    1.202690] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                        [    1.209837] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                        [    1.213028] of_cfs_init
                        [    1.213159] of_cfs_init: OK
                        [    1.214435] Waiting for root device PARTUUID=7482b1ce-02...
                        [    1.253748] random: fast init done
                        [    1.287420] mmc1: new high speed SDIO card at address 0001
                        [    1.320454] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                        [    1.321388] mmcblk0: mmc0:aaaa SH32G 29.7 GiB
                        [    1.323765]  mmcblk0: p1 p2
                        [    1.345587] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                        [    1.345677] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [    1.351019] devtmpfs: mounted
                        [    1.359759] Freeing unused kernel memory: 2048K
                        [    1.374863] Run /sbin/init as init process
                        [    1.454614] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                        [    1.637382] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                        [    1.637426] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                        [    1.637458] usb 1-1: Product: USB2.0 Hub
                        [    1.639630] hub 1-1:1.0: USB hub found
                        [    1.639915] hub 1-1:1.0: 4 ports detected
                        [    1.815053] systemd[1]: System time before build time, advancing clock.
                        [    1.912629] NET: Registered protocol family 10
                        [    1.914054] Segment Routing with IPv6
                        [    1.943043] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
                        [    1.943863] systemd[1]: Detected architecture arm.
                        [    1.964604] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
                        [    2.034737] systemd[1]: Set hostname to <iobroker>.
                        [    2.105077] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
                        [    2.105125] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        [    2.105161] usb 1-1.3: Product: TI CC2531 USB CDC
                        [    2.105190] usb 1-1.3: Manufacturer: Texas Instruments
                        [    2.105219] usb 1-1.3: SerialNumber: __0X00124B000BE8A20E
                        [    2.707077] random: systemd: uninitialized urandom read (16 bytes read)
                        [    2.721301] random: systemd: uninitialized urandom read (16 bytes read)
                        [    2.721858] systemd[1]: Listening on udev Kernel Socket.
                        [    2.722800] random: systemd: uninitialized urandom read (16 bytes read)
                        [    2.728270] systemd[1]: Listening on Syslog Socket.
                        [    2.731895] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                        [    2.732758] systemd[1]: Listening on initctl Compatibility Named Pipe.
                        [    2.733855] systemd[1]: Listening on fsck to fsckd communication Socket.
                        [    2.734760] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                        [    2.736088] systemd[1]: Listening on Journal Socket.
                        [    3.365389] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                        [    3.457918] systemd-journald[113]: Received request to flush runtime journal from PID 1
                        [    3.966447] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                        [    3.966956] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                        [    3.970164] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                        [    3.976805] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                        [    4.107110] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                        [    4.107282] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                        [    4.111882] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                        [    4.111908] [vc_sm_connected_init]: start
                        [    4.117593] [vc_sm_connected_init]: installed successfully
                        [    4.134353] mc: Linux media interface: v0.10
                        [    4.194400] bcm2835_audio bcm2835_audio: card created with 8 channels
                        [    4.200184] videodev: Linux video capture interface: v2.00
                        [    4.265102] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                        [    4.270376] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                        [    4.285473] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                        [    4.289686] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                        [    4.292951] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                        [    4.293715] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                        [    4.293751] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                        [    4.293775] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                        [    4.293821] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                        [    4.293842] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                        [    4.293847] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                        [    4.294064] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                        [    4.349366] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                        [    4.352132] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                        [    4.370527] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                        [    4.370572] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                        [    4.387377] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                        [    4.387420] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                        [    4.427223] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                        [    4.427266] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                        [    4.497829] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                        [    4.508478] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                        [    4.593744] brcmfmac: F1 signature read @0x18000000=0x15264345
                        [    4.611429] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                        [    4.611868] usbcore: registered new interface driver brcmfmac
                        [    4.635275] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                        [    4.666016] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                        [    4.666506] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                        [    4.666559] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                        [    4.666591] [drm] No driver support for vblank timestamp query.
                        [    4.666623] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
                        [    4.682271] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                        [    4.721812] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                        [    4.725955] usbcore: registered new interface driver cdc_acm
                        [    4.726028] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                        [    4.872041] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                        [    4.887639] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
                        [    6.649834] uart-pl011 fe201000.serial: no DMA platform data
                        [    6.793534] 8021q: 802.1Q VLAN Support v1.8
                        [    6.833530] random: crng init done
                        [    6.833547] random: 7 urandom warning(s) missed due to ratelimiting
                        [    7.004588] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:307200k SSFS
                        [    7.231550] bcmgenet: Skipping UMAC reset
                        [    7.233099] bcmgenet fd580000.ethernet: configuring instance for external RGMII
                        [    7.233291] bcmgenet fd580000.ethernet eth0: Link is Down
                        [   12.394731] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                        [   12.394778] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                        [   13.390194] Bluetooth: Core ver 2.22
                        [   13.390278] NET: Registered protocol family 31
                        [   13.390292] Bluetooth: HCI device and connection manager initialized
                        [   13.390319] Bluetooth: HCI socket layer initialized
                        [   13.390339] Bluetooth: L2CAP socket layer initialized
                        [   13.390370] Bluetooth: SCO socket layer initialized
                        [   13.400185] Bluetooth: HCI UART driver ver 2.3
                        [   13.400204] Bluetooth: HCI UART protocol H4 registered
                        [   13.400291] Bluetooth: HCI UART protocol Three-wire (H5) registered
                        [   13.400609] Bluetooth: HCI UART protocol Broadcom registered
                        [   13.645614] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                        [   13.645624] Bluetooth: BNEP filters: protocol multicast
                        [   13.645637] Bluetooth: BNEP socket layer initialized
                        [   13.677962] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                        [   36.486035] FS-Cache: Netfs 'cifs' registered for caching
                        [   36.494244] Key type cifs.spnego registered
                        [   36.494260] Key type cifs.idmap registered
                        [   36.497493] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [  179.685049] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [  211.740935] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [  211.794216] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [  211.794274] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
                        [ 2926.815460] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [ 3049.571700] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [ 3083.871685] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [ 3083.946733] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [ 3083.946792] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
                        [ 4364.779967] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [ 4396.513037] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [ 4396.585580] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [ 4396.585637] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
                        [ 4618.763633] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        [ 9755.613491] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                        pi@iobroker: sudo -u iobroker groups
                        iobroker tty dialout audio video bluetooth redis gpio i2c
                        pi@iobroker:/opt/iobroker $ groups
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                        Thomas BraunT simatecS 2 Antworten Letzte Antwort
                        • T tobitobsta
                          @Thomas-Braun
                          here we go (dmesg):
                          #791
                          Du hättest ja auch mal verkünden können, das das ein gemountetes Dateisystem an der Stelle ist.
                          Wie sehen die mount-Optionen aus?
                            tobitobsta
                            #792
                            @Thomas-Braun ja das hätte ich tun können...
                                "connectType": "CIFS",
                                "cifsMount": "*****",
                                "cifsDomain": "",
                                "cifsUser": "******",
                                "cifsPassword": "******",
                                "smbType": "vers=3.0",
                                "sudoMount": true,
                                "cifsDeleteOldBackup": false,
                                "cifsOwnDir": false,
                                "wakeOnLAN": true,
                            mounting scheint zumindest so weit zu funktionieren, dass ich die backups in der Auswahlliste sehe. Und acuh das Backup erstellen funktioniert auf dem mount ohne Probleme.
                            • T tobitobsta
                              @Thomas-Braun
                              here we go (dmesg):
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #793
                              @tobitobsta
                              Mache mal bitte den Restore Lokal. Cloud und NAS ist immer nicht so das Gelbe vom Ei ;-) ....
                              • T tobitobsta
                                    "cifsDomain": "",
                                    "sudoMount": true,
                                    "wakeOnLAN": true,
                                #794
                                @tobitobsta
                                Wird über die fstab gemounted?
                                Dann bitte die dortigen Einträge nennen.
                                Ansonsten das was @simatec sagt.
                                  @tobitobsta
                                  tobitobsta
                                  #795
                                  @Thomas-Braun mounting passiert über den Adapter
                                  @simatec vielen Dank für den Hinweis. So funktioniert es dann. Dann verstehe ich zwar noch nicht warum das auf dem alten System ohne weiteres ging - aber erstmal bin ich natürlich glücklich das es so geht. Danke Dir!!!
                                  Was ich noch nicht verstehe ist, dass mein Redis-Backup, was ich drauf spiele, ca 3.7MB groß ist und nach einem Zurückspielen und erneutem Backup das Redis-Backup nur noch 650KB groß ist. Aber wie ihr ja bereits merkt - meine Mittel sind begrenzt ;-)
                                  • T tobitobsta
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #796
                                    @tobitobsta
                                    Prüfe mal die Rechte auf deinem NAS. So wie es aussieht, hat iobroker bzw. Backitup keine Schreibrechte
                                      Bibo*13
                                      schrieb am zuletzt editiert von Bibo*13
                                      #797
                                      seit 2 Tagen werden keine iobroker Archive mehr in mein NAS Drive geschrieben.
                                      Pushover sagt immer erfolgreich im VIS HTML steht aber immer name undefined.
                                      redis und zigbee.0 kommen an und werden auch geschrieben.
                                      Ich habe jetzt backitup mit debug laufen lassen und hänge mal das Log mit an.
                                      Ebenso das log wenn ich den Adapter zum backuppen händisch starte.
                                      Vielleicht gibt es ja einen Tip von Euch
                                      vielen Dank
                                      Backitup2.txt Backitup1.txt
                                      • simatecS simatec
                                        @tobitobsta
                                        tobitobsta
                                        #798
                                        @simatec Aber dann könnte er ja das Backup auch dort nicht erstellen - aber das geht ja wunderbar. Oder er hängt es beim Backup "anders" ein als beim Wiederherstellen... Aber ich Denke im Grunde hast Du recht: Es scheint ein Rechte-Problem zu sein. Der Mount Befehl für die Wiederherstellung im log sieht für mich jetzt auch okay aus:
                                        sudo mount -t cifs -o username=tobi,password=****,rw,file_mode=0777,dir_mode=0777 //server/tobi/Backup/iobroker /opt/iobroker/backups
                                        Unterschied: der Ordner "backups" gehört vor dem mounten user iobroker - nachdem mounten "root" - aber er ist tatsächlich 0777 Rechten versehen.
                                        • HALH HAL
                                          restore auch
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #799
                                          @HAL
                                          Wenn du Influxdb mal testen willst, kannst du gerne mal die DEV Version testen.
                                          Im Moment geht noch kein Restore
                                          https://github.com/simatec/ioBroker.backitup/tarball/dev
                                          HALH 1 Antwort Letzte Antwort
