  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • F Offline
    Flyor87
    schrieb am zuletzt editiert von Flyor87
    #772
    Ich bekomme leider auch jede Nacht nach dem geplanten Backup die altbekannte Fehlermeldung:
    backitup.0	2020-11-05 02:00:54.047	info	(17562) [iobroker] backup was activated at 02:00 every 1 day(s)
    backitup.0	2020-11-05 02:00:54.035	info	(17562) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.19.0, js-controller: 3.1.6
    host.ubuntu	2020-11-05 02:00:53.117	info	instance system.adapter.backitup.0 started with pid 17562
    host.ubuntu	2020-11-05 02:00:23.108	info	Restart adapter system.adapter.backitup.0 because enabled
    host.ubuntu	2020-11-05 02:00:23.108	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:343:18)
    host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at runMicrotasks (<anonymous>)
    host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:112:15)
    host.ubuntu	2020-11-05 02:00:23.108	error	Caught by controller[0]: Error: Rate Limit Exceeded
    host.ubuntu	2020-11-05 02:00:23.107	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    backitup.0	2020-11-05 02:00:22.598	info	(901) Terminated (NO_ERROR): Without reason
    backitup.0	2020-11-05 02:00:22.597	info	(901) terminating
    backitup.0	2020-11-05 02:00:22.586	info	(901) cleaned everything up...
    backitup.0	2020-11-05 02:00:22.585	error	(901) Error: Rate Limit Exceeded at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:112:15) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/t
    backitup.0	2020-11-05 02:00:22.576	error	(901) unhandled promise rejection: Rate Limit Exceeded
    backitup.0	2020-11-05 02:00:22.574	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().```
    F simatecS 2 Antworten Letzte Antwort
    • F Flyor87
      Flyor87
      #773
      Hab mit jetzt den Thread durchgelesen, den Adapter auf Debug gestellt und manuell gestartet. Da kam die Meldung nicht:
      backitup.0	2020-11-05 02:12:14.074	debug	(18915) [iobroker] exec: done
      backitup.0	2020-11-05 02:12:13.923	debug	(18915) [iobroker/googledrive] done
      backitup.0	2020-11-05 02:12:12.358	debug	(18915) [iobroker/googledrive] Google Drive: Copy zigbee.0_2020_11_05-02_12_04_backupiobroker.tar.gz...
      backitup.0	2020-11-05 02:12:05.989	debug	(18915) [iobroker] exec: done
      backitup.0	2020-11-05 02:12:05.839	debug	(18915) [iobroker/history] backitup.0.history.json
      backitup.0	2020-11-05 02:12:05.837	debug	(18915) [iobroker/history] backitup.0.history.html
      backitup.0	2020-11-05 02:12:05.079	debug	(18915) [iobroker/clean] done
      backitup.0	2020-11-05 02:12:05.078	debug	(18915) [iobroker/googledrive] Google Drive: Copy iobroker_2020_11_05-02_12_00_Saves_backupiobroker.tar.gz...
      backitup.0	2020-11-05 02:12:04.627	debug	(18915) [iobroker/zigbee] done
      backitup.0	2020-11-05 02:12:04.627	debug	(18915) [iobroker/zigbee] found zigbee database: zigbee.0
      backitup.0	2020-11-05 02:12:04.024	debug	(18915) [iobroker/iobroker] done
      backitup.0	2020-11-05 02:12:03.018	debug	(18915) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_11_05-02_12_00_Saves_backupiobroker.tar.gz
      backitup.0	2020-11-05 02:12:01.758	debug	(18915) [iobroker/iobroker] host.ubuntu 7223 objects saved
      backitup.0	2020-11-05 02:12:01.750	debug	(18915) [iobroker/iobroker] host.ubuntu 5928 states saved
      backitup.0	2020-11-05 02:12:00.503	debug	(18915) Backup has started ...
      backitup.0	2020-11-05 02:11:37.868	debug	(18915) No backup file was found
      backitup.0	2020-11-05 02:11:35.099	info	(18915) [iobroker] backup was activated at 02:00 every 1 day(s)
      backitup.0	2020-11-05 02:11:35.081	info	(18915) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.19.0, js-controller: 3.1.6
      backitup.0	2020-11-05 02:11:35.049	debug	(18915) Plugin sentry Initialize Plugin (enabled=true)
      backitup.0	2020-11-05 02:11:34.629	debug	(18915) statesDB connected
      backitup.0	2020-11-05 02:11:34.628	debug	(18915) States connected to redis: 127.0.0.1:9000
      backitup.0	2020-11-05 02:11:34.625	debug	(18915) States create System PubSub Client
      backitup.0	2020-11-05 02:11:34.625	debug	(18915) States create User PubSub Client
      backitup.0	2020-11-05 02:11:34.622	debug	(18915) Redis States: Use Redis connection: 127.0.0.1:9000
      backitup.0	2020-11-05 02:11:34.622	debug	(18915) objectDB connected
      backitup.0	2020-11-05 02:11:34.620	debug	(18915) Objects connected to redis: 127.0.0.1:9001
      backitup.0	2020-11-05 02:11:34.617	debug	(18915) Objects client initialize lua scripts
      backitup.0	2020-11-05 02:11:34.616	debug	(18915) Objects create User PubSub Client
      backitup.0	2020-11-05 02:11:34.616	debug	(18915) Objects create System PubSub Client
      backitup.0	2020-11-05 02:11:34.615	debug	(18915) Objects client ready ... initialize now
      backitup.0	2020-11-05 02:11:34.607	debug	(18915) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.ubuntu	2020-11-05 02:11:34.095	info	instance system.adapter.backitup.0 started with pid 18915
      host.ubuntu	2020-11-05 02:11:31.598	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      backitup.0	2020-11-05 02:11:31.087	info	(18085) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      backitup.0	2020-11-05 02:11:31.087	info	(18085) terminating
      backitup.0	2020-11-05 02:11:31.087	info	(18085) cleaned everything up...
      backitup.0	2020-11-05 02:11:31.086	info	(18085) Got terminate signal TERMINATE_YOURSELF
      host.ubuntu	2020-11-05 02:11:31.085	info	stopInstance system.adapter.backitup.0 send kill signal
      host.ubuntu	2020-11-05 02:11:31.083	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
      • simatecS simatec
        Aktuelle Test Version 3.1.0
        Veröffentlichungsdatum 02.03.2025
        Github Link https://github.com/simatec/ioBroker.backitup
        Wiki Link https://github.com/simatec/ioBroker.backitup/wiki
        Hier geht es um die aktuelle Version von ioBroker.backitup, nachdem der alte Thread langsam zu unübersichtlich wurde.
        Bitte gebt euer Feedback und eure Anregungen hier ab.
        3.1.0 (2025-03-02)
        • (Bluefox) Dependencies updated
        • (Bluefox) Vite added
        • (simatec) jsonConfig updated
        • (simatec) Fix month for history
        3.0.37 (2025-02-28)
        • (simatec) Fix CronJob
        3.0.36 (2025-02-26)
        • (simatec) Fix src-admin
        3.0.35 (2025-02-26)
        3.0.34 (2025-02-26)
        3.0.33 (2025-02-25)
        • (simatec) Fix cronjob
        • (simatec) Fix Backup Console
        3.0.32 (2025-02-24)
        • (simatec) Error handling for GoogleDrive fix
        • (simatec) globalDependencies updated
        • (simatec) Dependencies updated
        • (simatec) Design Fix
        3.0.31 (2024-11-30)
        • (simatec) Fix Tab Menu
        3.0.30 (2024-11-29)
        3.0.29 (2024-11-29)
        3.0.28 (2024-11-27)
        • (simatec) eslint-config added
        • (bluefox) Allow to store files for up to ca 3 years
        • (Marc-Berg) Grafana Docu updated
        3.0.27 (2024-11-12)
        • (simatec) dependencies updated
        3.0.26 (2024-10-16)
        • (simatec) Fix FTP Connections
        • (simatec) Issue Workflow added
        3.0.25 (2024-09-26)
        • (bluefox) Improvement of Google Drive authentication workflow
        • (bluefox) Removed gulp from a build process
        • (simatec) small Design Fix
        • (simatec) Fix for Admin 7.1.5
        • (simatec) Fix Test & Release
        • (simatec) Fix ESlint errors
        3.0.22 (2024-09-03)
        • (simatec) Fix Notification Instance
        • (simatec) Fix Notification Design
        • (simatec) Fix Default Settings
        3.0.21 (2024-09-01)
        • (simatec) Fix Onedrive Notification
        • (simatec) Fix Zigbee2MQTT Backup
        3.0.20 (2024-08-22)
        • (simatec) Responsive Design for Tab added
        • (simatec) Responsive Design for jsonConfig added
        3.0.19 (2024-08-15)
        • (simatec) Fix CCU Backup
        • (simatec) Fix InfluxDB Backup Config
        • (simatec) Fix Backup-Log for Slave Instanz
        3.0.18 (2024-08-14)
        • (simatec) Package optimisation
        • (simatec) Fix the warning when opening the configuration
        3.0.17 (2024-08-12)
        • (simatec) Fix io-package for Release
        • (simatec) manual-review added
        • (simatec) Fix Slave Backup
        3.0.16 (2024-08-05)
        • (bluefox) dependencies updated
        • (simatec) Rename json5 Files
        3.0.15 (2024-08-03)
        • (simatec) fix dependencies
        3.0.14 (2024-08-02)
        • (simatec) Improved log outputs
        3.0.12 (2024-08-01)
        • (simatec) Backup Log for History added
        • (simatec) Added separate selection for deleting FTP backups
        • (simatec) Added separate selection for deleting Onedrive backups
        • (simatec) Added separate selection for deleting Webdav backups
        • (simatec) Added separate selection for deleting Dropbox backups
        • (simatec) Added separate selection for deleting Googledrive backups
        • (simatec) Source code cleaned up
        3.0.11 (2024-07-28)
        3.0.10 (2024-07-22)
        • (simatec) Design Fix for Dark Mode
        3.0.9 (2024-07-11)
        • (simatec) Tab Icons added
        • (simatec) small fix
        • (simatec) Docu updated
        3.0.8 (2024-07-01)
        • (Grothesk242/simatec) forceuid and forcegid added
        3.0.7 (2024-06-26)
        • (simatec) Restore Information added
        • (simatec) Fix Formaterrors
        • (bluefox) Fixing the problems with styles
        • (simatec) Fix iobroker Backup Error
        3.0.6 (2024-06-26)
        3.0.5 (2024-06-18)
        • (simatec) Fix Build
        3.0.4 (2024-06-18)
        • (simatec) History Gui Fix
        • (simatec) Tab GUI modified
        • (bluefox) Added support for Admin 7
        • (simatec) Onedrive ready for School/Business Accounts
        3.0.3 (2024-06-10)
        • (simatec) Fixed WebDav
        • (simatec) Admin Notification for Backup errors added
        • (simatec) Remove Sentry Config
        • (simatec) Translations updated
        • (simatec) Error handling optimized
        3.0.2 (2024-06-06)
        • (simatec) Fixed Google Drive
        • (simatec) Fixed Translations
        • (simatec) Fixed Onedrive
        • (simatec) Fixed MySql Backup
        • (simatec) Fixed Translation added
        • (simatec) new notifications content added
        3.0.1 (2024-05-29)
        • (simatec) Fixed umount callback
        • (simatec) Fixed Backup Message
        • (simatec) Fixed InfluxDB Multi Backup
        • (simatec) Fixed Restore Console
        • (simatec) Fixed Backup Console
        3.0.0 (2024-05-28)
        • (simatec) jsonConfig added
        • (bluefox) Conversion to React
        • (bluefox) Added react components
        • (bluefox/simatec) Working on React GUI
        • (simatec) Fix Yahka Backup
        • (simatec) Fix Nodered Backup
        • (simatec) some bugs fixed
        • (bluefox/simatec) New Restore-Interface
        • (simatec) Translation updated
        JayRJ Offline
        JayRJ Offline
        JayR
        schrieb am zuletzt editiert von JayR
        #774
        @simatec : Ich habe ein Problem, beim herstellen eines Backups, dass auf einem Pi 4 gemacht wurde und auf einem 3er hergestellt wird. Hast du eine Idee, wie ich das Backup auf dem Pi3 herstellen kann?
        pi@raspberrypi:/opt/iobroker $ sudo iobroker restore 0
        host.raspberrypi Using backup file iobroker_2020_11_04-02_00_10_iobroker_backupiobroker.tar.gz
        iobroker controller daemon is not running
        host.raspberrypi OK.
        <--- Last few GCs --->
        [1202:0x22292e0]     6704 ms: Scavenge 13.6 (16.7) -> 11.8 (17.2) MB, 3.8 / 0.0 ms  (average mu = 0.973, current mu = 0.979) allocation failure
        [1202:0x22292e0]     9239 ms: Mark-sweep 153.3 (157.5) -> 151.4 (157.5) MB, 17.3 / 0.0 ms  (+ 0.9 ms in 2 steps since start of marking, biggest step 0.9 ms, walltime since start of marking 2220 ms) (average mu = 0.992, current mu = 0.995) allocation failu
        <--- JS stacktrace --->
        Cannot get stack trace in GC.
        FATAL ERROR: MarkCompactCollector: semi-space copy, fallback in old gen Allocation failed - JavaScript heap out of memory
        /usr/bin/iobroker: Zeile 8:  1201 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
        RAM:
        pi@raspberrypi:/opt/iobroker $ free
        Mem:         947032       46132      619760        2672      281140      845912
        Swap:        102396        3840       98556
        Vielen Dank und Gruß
        • JayRJ JayR
          RAM:
          #775
          @JayR
          Ohne sudo vorweg.
          Warum nutzt du nicht den Backitup-Adapter?
          [Edit:] Doppelpost! Hier geht es weiter:
          https://forum.iobroker.net/topic/38346/backup-kann-nicht-wieder-hergestellt-werden
          • F Flyor87
            simatecS Offline
            simatecS Offline
            simatec
            #776
            @Flyor87
            Kannst du mir mal bitte deine Config als json hier posten?
            Du nutzt wie ich sehe Google Drive. Wie viele Backups hast du zur in der Cloud liegen, bevor gelöscht wird?
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
              Snapergy
              schrieb am zuletzt editiert von Snapergy
              #777
              Hab seit einigen Tagen ein komisches Verhalten beim Adapter. Jeden Tag um 1:00 Uhr in der Nacht wird das Backup ausgeführt und auch eine Backup-Datei (korrekt) angelegt, jedoch sind die Objekte iobrokerSuccess auf false und iobrokerLastTime beginnt mit "error". Ein händisch ausgeführtes Backup führte wieder zu einer erfolgreichen Durchführung und Setzen des Success-Wertes auf true, doch seit heute geht auch das nicht mehr. Der Log wirft aus meiner Sicht aber keinen Fehler
              backitup.0	2020-11-11 07:39:45.581	debug	(7494) No backup file was found
              backitup.0	2020-11-11 07:39:45.577	debug	(7494) [iobroker] 10 00 01 */1 * *
              backitup.0	2020-11-11 07:39:45.565	info	(7494) [iobroker] backup was activated at 01:00 every 1 day(s)
              backitup.0	2020-11-11 07:39:45.524	info	(7494) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.17.0, js-controller: 3.1.6
              backitup.0	2020-11-11 07:39:45.045	debug	(7494) Plugin sentry Initialize Plugin (enabled=true)
              backitup.0	2020-11-11 07:39:43.879	debug	(7494) statesDB connected
              backitup.0	2020-11-11 07:39:43.878	debug	(7494) States connected to redis: 127.0.0.1:9000
              backitup.0	2020-11-11 07:39:43.867	debug	(7494) States create System PubSub Client
              backitup.0	2020-11-11 07:39:43.865	debug	(7494) States create User PubSub Client
              backitup.0	2020-11-11 07:39:43.857	debug	(7494) Redis States: Use Redis connection: 127.0.0.1:9000
              backitup.0	2020-11-11 07:39:43.855	debug	(7494) objectDB connected
              backitup.0	2020-11-11 07:39:43.848	debug	(7494) Objects connected to redis: 127.0.0.1:9001
              backitup.0	2020-11-11 07:39:43.833	debug	(7494) Objects client initialize lua scripts
              backitup.0	2020-11-11 07:39:43.832	debug	(7494) Objects create User PubSub Client
              backitup.0	2020-11-11 07:39:43.831	debug	(7494) Objects create System PubSub Client
              backitup.0	2020-11-11 07:39:43.827	debug	(7494) Objects client ready ... initialize now
              backitup.0	2020-11-11 07:39:43.796	debug	(7494) Redis Objects: Use Redis connection: 127.0.0.1:9001
              • S Snapergy
                simatecS Offline
                simatecS Offline
                simatec
                #778
                @Snapergy
                Was steht nach dem Backup im Objekt backitup.0.output.line??
                • simatecS simatec
                  @Snapergy
                  Snapergy
                  #779
                  @simatec
                  aktuell:
                  [DEBUG] [history] start with {"type":"creator","time":"01:00","debugging":true,"everyXDays":"1","nameSuffix":"Backitup","deleteBackupAfter":0,"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"11. November 2020 um 07:38 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                  • S Snapergy
                    @simatec
                    aktuell:
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #780
                    @Snapergy
                    Ok er bleibt bei der History hängen, was bedeutet, das irgendwas bei einem Update mal schief gegangen ist.
                    Bitte mache folgendes Schritt für Schritt:
                    Gehe per Konsole auf den Ordner /opt/iobroker/node_modules/iobroker.backitup und führe folgende Befehl aus:
                    npm install
                    Sollte danach der Fehler nicht weg sein, führe bitte folgende Schritte aus:
                    • Instanz von Backitup löschen
                    • Backitup im Tab Adapter löschen
                    • Schauen, ob der Ordner backitup.0 im Tab Objekte gelöscht wurde
                    • Dein System rebooten
                    • Backitup installieren und konfigurieren
                    • simatecS simatec
                      @Snapergy
                      npm install
                      Snapergy
                      #781
                      @simatec
                      mit
                      npm install
                      geht der Fehler leider nicht weg, den Rest werde ich morgen Vormittag mal ausprobieren. Komischerweise habe ich den Adapter glaube ich gar nicht geupdatet, sonder erst vor zwei Wochen installiert. Bis vor ein paar Tag ging alles reibungslos, erst jetzt taucht der Fehler auf 🤔
                      EDIT: Aber grundsätzlich sind die Backups vollständig?
                      • S Snapergy
                        @simatec
                        mit
                        npm install
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #782
                        @Snapergy
                        Ja das passiert beim erstellen der History. Die Backups sind da bereits erstellt
                        S HALH 2 Antworten Letzte Antwort
                        • simatecS simatec
                          @Snapergy
                          Snapergy
                          #783
                          @simatec
                          Alles wie vorgeschlagen durchgeführt und nun klappt wieder alles, danke :)
                          • simatecS simatec
                            @Snapergy
                            HALH Offline
                            HALH Offline
                            HAL
                            #784
                            @simatec mal eine "unverschämte" Frage. Da ich seit kurzem eine PV Anlage mit Speicher + Wallbox habe, nutze ich für die Speicherung der Werte eine influxdb und zur grafischen Anzeige Grafana. Das läuft auch prima mit iobroker zusammen.
                            Es wäre toll wenn ich zur Sicherung auch den backitup Adapter nutzen könnte :-)
                            Backup für influxdb ist eigentlich ganz einfach:
                            sudo influxd backup -portable /opt/backups/influx.backup
                            restore auch
                            influxd restore -portable /opt/backups/influx.backup
                            für Grafana ist es komplizierter (siehe: https://www.bachmann-lan.de/grafana-backup-dashboards-data-sources/)
                            Momentan starte ich zwei scripte über die shell.
                            Ob man das "irgendwann mal" in den Backitup Adapter aufnehmen könnte ?
                            Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
                            (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
                            • HALH HAL
                              restore auch
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #785
                              @HAL
                              Ist mit auf der Todo ...
                              • simatecS simatec
                                3.1.0 (2025-03-02)
                                3.0.37 (2025-02-28)
                                3.0.36 (2025-02-26)
                                3.0.35 (2025-02-26)
                                3.0.34 (2025-02-26)
                                3.0.33 (2025-02-25)
                                3.0.32 (2025-02-24)
                                3.0.31 (2024-11-30)
                                3.0.30 (2024-11-29)
                                3.0.29 (2024-11-29)
                                3.0.28 (2024-11-27)
                                3.0.27 (2024-11-12)
                                3.0.26 (2024-10-16)
                                3.0.25 (2024-09-26)
                                3.0.22 (2024-09-03)
                                3.0.21 (2024-09-01)
                                3.0.20 (2024-08-22)
                                3.0.19 (2024-08-15)
                                3.0.18 (2024-08-14)
                                3.0.17 (2024-08-12)
                                3.0.16 (2024-08-05)
                                3.0.15 (2024-08-03)
                                3.0.14 (2024-08-02)
                                3.0.12 (2024-08-01)
                                3.0.11 (2024-07-28)
                                3.0.10 (2024-07-22)
                                3.0.9 (2024-07-11)
                                3.0.8 (2024-07-01)
                                3.0.7 (2024-06-26)
                                3.0.6 (2024-06-26)
                                3.0.5 (2024-06-18)
                                3.0.4 (2024-06-18)
                                3.0.3 (2024-06-10)
                                3.0.2 (2024-06-06)
                                3.0.1 (2024-05-29)
                                3.0.0 (2024-05-28)
                                tobitobsta
                                schrieb am zuletzt editiert von tobitobsta
                                #786
                                Super cooler Adapter, der mir schon einige Male den Hintern gerettet hat! Danke!
                                beim gestrigen Schrotten meines iobroker rasp pi ist beim Zurückspielen auf die frische Installation folgender Fehler aufgetreten:
                                DEBUG] [redis] Start Redis Restore ...
                                [DEBUG] [redis] Created Redis tmp
                                [ERROR] [redis] Redis Restore not completed
                                [ERROR] [redis] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/tmp/'
                                [EXIT] undefined **** Restore completed successfully!! ****
                                The log can be closed ...
                                Der Restore von Iobroker selbst hat funktioniert... nur eben Redis nicht. Auch die fehlenden Werte in den Objekten (und die sehr kleinen Redis-Backups nach diesem restore) deuten darauf hin dass das Zurückspielen nicht funktioniert hat.
                                Habe die frische Installation zuvor auf Redis umgestellt und Redis vorher installiert.
                                Dann habe ich auch
                                sudo usermod -a -G redis iobroker
                                und zur Vorsicht noch
                                curl -fsL https://iobroker.net/fix.sh | bash -
                                sowie zwischendurch immer reboots durchgeführt. So langsam komme ich mit meinen begrenzten Mitteln nicht weiter. Hat jemand eine Idee?
                                Tobi
                                update:
                                ich habe mal diesen ordner /opt/iobroker/backups/tmp als root mit 0777 angelegt -> selbe Fehlermeldung und nachdem Redis-Restore-Versuch ist der wieder weg.
                                • T tobitobsta
                                  Dann habe ich auch
                                  Tobi
                                  update:
                                  #787
                                  @tobitobsta sagte in Test Adapter Backitup v1.7.x:
                                  Ganz schlechte Idee...
                                  Im Normalzustand gibt es den Ordner auf meinem System auch gar nicht. Vermutlich wird der während des Backups wirklich nur temporär angelegt.
                                  Was jetzt aber da konkret bei dir falsch / anders läuft kann ich nur raten.
                                  Apropos raten: Ich würde dir raten, dich nicht als root anzmelden und dann in den Verzeichnispfaden rumzufummeln.
                                  Dateisystem ist aber gesund?
                                  Mit
                                  dmesg
                                  mal schauen.
                                  Die user sind in den passenden Gruppen?
                                  sudo -u iobroker groups
                                  groups
                                    Mit
                                    dmesg
                                    mal schauen.
                                    groups
                                    tobitobsta
                                    #788
                                    @Thomas-Braun
                                    Danke für den Hinweis bzgl root und Verzeichnisstrukturen.
                                    Dateisystem sieht erstmal okay aus.
                                    iobroker befindet sich auch in der redis-gruppe. Der user "pi" jedoch nicht - müsste er das? Denke iobroker sollte reichen.
                                    leider kann ich aus dem redis log auch nichts rauslesen - zumindest sieht es da nicht nach einem abgelehnten zugriffsversuch aus.
                                    • T tobitobsta
                                      @Thomas-Braun
                                      #789
                                      @tobitobsta Poste doch mal bitte die Ausgaben der Befehle.
                                        tobitobsta
                                        #790
                                        @Thomas-Braun
                                        here we go (dmesg):
                                        [    0.872784] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                                        [    0.873037] io scheduler mq-deadline registered
                                        [    0.873066] io scheduler kyber registered
                                        [    0.877118] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                                        [    0.877163] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                                        [    0.877268] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
                                        [    0.877359] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
                                        [    0.936694] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
                                        [    0.937034] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                                        [    0.937069] pci_bus 0000:00: root bus resource [bus 00-ff]
                                        [    0.937103] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
                                        [    0.937183] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                                        [    0.937467] pci 0000:00:00.0: PME# supported from D0 D3hot
                                        [    0.940741] PCI: bus0: Fast back to back transfers disabled
                                        [    0.940990] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                                        [    0.941153] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                                        [    0.941602] pci 0000:01:00.0: PME# supported from D0 D3cold
                                        [    0.944910] PCI: bus1: Fast back to back transfers disabled
                                        [    0.944986] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                                        [    0.945024] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                                        [    0.945125] pci 0000:00:00.0: PCI bridge to [bus 01]
                                        [    0.945164] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                                        [    0.945492] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                                        [    0.945754] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
                                        [    0.946174] pcieport 0000:00:00.0: AER: enabled with IRQ 55
                                        [    0.946534] pci 0000:01:00.0: enabling device (0140 -> 0142)
                                        [    0.953506] iproc-rng200 fe104000.rng: hwrng registered
                                        [    0.953858] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                                        [    0.954521] vc-sm: Videocore shared memory driver
                                        [    0.955174] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                                        [    0.967382] brd: module loaded
                                        [    0.979746] loop: module loaded
                                        [    0.981183] Loading iSCSI transport class v2.0-870.
                                        [    0.983154] libphy: Fixed MDIO Bus: probed
                                        [    0.983801] bcmgenet fd580000.ethernet: failed to get enet clock
                                        [    0.983837] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                                        [    0.983875] bcmgenet fd580000.ethernet: failed to get enet-wol clock
                                        [    0.983911] bcmgenet fd580000.ethernet: failed to get enet-eee clock
                                        [    0.983954] bcmgenet: Skipping UMAC reset
                                        [    0.994628] libphy: bcmgenet MII bus: probed
                                        [    1.084660] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                                        [    1.085698] usbcore: registered new interface driver r8152
                                        [    1.085779] usbcore: registered new interface driver lan78xx
                                        [    1.085853] usbcore: registered new interface driver smsc95xx
                                        [    1.086309] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                        [    1.086358] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                                        [    1.088980] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
                                        [    1.090301] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
                                        [    1.090340] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                        [    1.090375] usb usb1: Product: xHCI Host Controller
                                        [    1.090403] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
                                        [    1.090432] usb usb1: SerialNumber: 0000:01:00.0
                                        [    1.091051] hub 1-0:1.0: USB hub found
                                        [    1.091175] hub 1-0:1.0: 1 port detected
                                        [    1.091773] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                        [    1.091815] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                                        [    1.091857] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                                        [    1.092403] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
                                        [    1.092442] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                        [    1.092476] usb usb2: Product: xHCI Host Controller
                                        [    1.092505] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
                                        [    1.092534] usb usb2: SerialNumber: 0000:01:00.0
                                        [    1.093132] hub 2-0:1.0: USB hub found
                                        [    1.093248] hub 2-0:1.0: 4 ports detected
                                        [    1.094789] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                        [    1.095098] dwc_otg: FIQ enabled
                                        [    1.095111] dwc_otg: NAK holdoff enabled
                                        [    1.095123] dwc_otg: FIQ split-transaction FSM enabled
                                        [    1.095139] Module dwc_common_port init
                                        [    1.095581] usbcore: registered new interface driver uas
                                        [    1.095704] usbcore: registered new interface driver usb-storage
                                        [    1.095912] mousedev: PS/2 mouse device common for all mice
                                        [    1.097794] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                        [    1.101249] sdhci: Secure Digital Host Controller Interface driver
                                        [    1.101281] sdhci: Copyright(c) Pierre Ossman
                                        [    1.101909] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                                        [    1.102495] sdhci-pltfm: SDHCI platform and OF driver helper
                                        [    1.106361] ledtrig-cpu: registered to indicate activity on CPUs
                                        [    1.106691] hidraw: raw HID events driver (C) Jiri Kosina
                                        [    1.106903] usbcore: registered new interface driver usbhid
                                        [    1.106931] usbhid: USB HID core driver
                                        [    1.107978] vchiq: vchiq_init_state: slot_zero = (ptrval)
                                        [    1.111604] [vc_sm_connected_init]: start
                                        [    1.120598] [vc_sm_connected_init]: end - returning 0
                                        [    1.122844] Initializing XFRM netlink socket
                                        [    1.122898] NET: Registered protocol family 17
                                        [    1.123030] Key type dns_resolver registered
                                        [    1.123414] Registering SWP/SWPB emulation handler
                                        [    1.123733] registered taskstats version 1
                                        [    1.123766] Loading compiled-in X.509 certificates
                                        [    1.124310] Key type ._fscrypt registered
                                        [    1.124338] Key type .fscrypt registered
                                        [    1.135099] uart-pl011 fe201000.serial: cts_event_workaround enabled
                                        [    1.135193] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
                                        [    1.141319] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                                        [    1.142324] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                        [    1.142356] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                                        [    1.194371] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                                        [    1.196125] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                        [    1.197983] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                        [    1.201000] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                                        [    1.202690] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                        [    1.209837] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                                        [    1.213028] of_cfs_init
                                        [    1.213159] of_cfs_init: OK
                                        [    1.214435] Waiting for root device PARTUUID=7482b1ce-02...
                                        [    1.253748] random: fast init done
                                        [    1.287420] mmc1: new high speed SDIO card at address 0001
                                        [    1.320454] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                                        [    1.321388] mmcblk0: mmc0:aaaa SH32G 29.7 GiB
                                        [    1.323765]  mmcblk0: p1 p2
                                        [    1.345587] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                        [    1.345677] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [    1.351019] devtmpfs: mounted
                                        [    1.359759] Freeing unused kernel memory: 2048K
                                        [    1.374863] Run /sbin/init as init process
                                        [    1.454614] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                                        [    1.637382] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                                        [    1.637426] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                                        [    1.637458] usb 1-1: Product: USB2.0 Hub
                                        [    1.639630] hub 1-1:1.0: USB hub found
                                        [    1.639915] hub 1-1:1.0: 4 ports detected
                                        [    1.815053] systemd[1]: System time before build time, advancing clock.
                                        [    1.912629] NET: Registered protocol family 10
                                        [    1.914054] Segment Routing with IPv6
                                        [    1.943043] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
                                        [    1.943863] systemd[1]: Detected architecture arm.
                                        [    1.964604] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
                                        [    2.034737] systemd[1]: Set hostname to <iobroker>.
                                        [    2.105077] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
                                        [    2.105125] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                        [    2.105161] usb 1-1.3: Product: TI CC2531 USB CDC
                                        [    2.105190] usb 1-1.3: Manufacturer: Texas Instruments
                                        [    2.105219] usb 1-1.3: SerialNumber: __0X00124B000BE8A20E
                                        [    2.707077] random: systemd: uninitialized urandom read (16 bytes read)
                                        [    2.721301] random: systemd: uninitialized urandom read (16 bytes read)
                                        [    2.721858] systemd[1]: Listening on udev Kernel Socket.
                                        [    2.722800] random: systemd: uninitialized urandom read (16 bytes read)
                                        [    2.728270] systemd[1]: Listening on Syslog Socket.
                                        [    2.731895] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                                        [    2.732758] systemd[1]: Listening on initctl Compatibility Named Pipe.
                                        [    2.733855] systemd[1]: Listening on fsck to fsckd communication Socket.
                                        [    2.734760] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                                        [    2.736088] systemd[1]: Listening on Journal Socket.
                                        [    3.365389] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                        [    3.457918] systemd-journald[113]: Received request to flush runtime journal from PID 1
                                        [    3.966447] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                                        [    3.966956] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                                        [    3.970164] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                                        [    3.976805] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                                        [    4.107110] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    4.107282] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    4.111882] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                        [    4.111908] [vc_sm_connected_init]: start
                                        [    4.117593] [vc_sm_connected_init]: installed successfully
                                        [    4.134353] mc: Linux media interface: v0.10
                                        [    4.194400] bcm2835_audio bcm2835_audio: card created with 8 channels
                                        [    4.200184] videodev: Linux video capture interface: v2.00
                                        [    4.265102] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    4.270376] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    4.285473] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                                        [    4.289686] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                                        [    4.292951] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                                        [    4.293715] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                                        [    4.293751] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                        [    4.293775] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                        [    4.293821] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                        [    4.293842] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                        [    4.293847] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    4.294064] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                        [    4.349366] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                        [    4.352132] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                        [    4.370527] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                        [    4.370572] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                        [    4.387377] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                        [    4.387420] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                        [    4.427223] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                        [    4.427266] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                        [    4.497829] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                        [    4.508478] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                                        [    4.593744] brcmfmac: F1 signature read @0x18000000=0x15264345
                                        [    4.611429] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                        [    4.611868] usbcore: registered new interface driver brcmfmac
                                        [    4.635275] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                                        [    4.666016] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                                        [    4.666506] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                                        [    4.666559] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
                                        [    4.666591] [drm] No driver support for vblank timestamp query.
                                        [    4.666623] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
                                        [    4.682271] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                                        [    4.721812] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                                        [    4.725955] usbcore: registered new interface driver cdc_acm
                                        [    4.726028] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                                        [    4.872041] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                        [    4.887639] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
                                        [    6.649834] uart-pl011 fe201000.serial: no DMA platform data
                                        [    6.793534] 8021q: 802.1Q VLAN Support v1.8
                                        [    6.833530] random: crng init done
                                        [    6.833547] random: 7 urandom warning(s) missed due to ratelimiting
                                        [    7.004588] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:307200k SSFS
                                        [    7.231550] bcmgenet: Skipping UMAC reset
                                        [    7.233099] bcmgenet fd580000.ethernet: configuring instance for external RGMII
                                        [    7.233291] bcmgenet fd580000.ethernet eth0: Link is Down
                                        [   12.394731] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                                        [   12.394778] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                        [   13.390194] Bluetooth: Core ver 2.22
                                        [   13.390278] NET: Registered protocol family 31
                                        [   13.390292] Bluetooth: HCI device and connection manager initialized
                                        [   13.390319] Bluetooth: HCI socket layer initialized
                                        [   13.390339] Bluetooth: L2CAP socket layer initialized
                                        [   13.390370] Bluetooth: SCO socket layer initialized
                                        [   13.400185] Bluetooth: HCI UART driver ver 2.3
                                        [   13.400204] Bluetooth: HCI UART protocol H4 registered
                                        [   13.400291] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                        [   13.400609] Bluetooth: HCI UART protocol Broadcom registered
                                        [   13.645614] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                        [   13.645624] Bluetooth: BNEP filters: protocol multicast
                                        [   13.645637] Bluetooth: BNEP socket layer initialized
                                        [   13.677962] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                                        [   36.486035] FS-Cache: Netfs 'cifs' registered for caching
                                        [   36.494244] Key type cifs.spnego registered
                                        [   36.494260] Key type cifs.idmap registered
                                        [   36.497493] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [  179.685049] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [  211.740935] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [  211.794216] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [  211.794274] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
                                        [ 2926.815460] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [ 3049.571700] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [ 3083.871685] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [ 3083.946733] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [ 3083.946792] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
                                        [ 4364.779967] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [ 4396.513037] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [ 4396.585580] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [ 4396.585637] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
                                        [ 4618.763633] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        [ 9755.613491] CIFS: Attempting to mount //server/tobi/Backup/iobroker
                                        pi@iobroker: sudo -u iobroker groups
                                        iobroker tty dialout audio video bluetooth redis gpio i2c
                                        pi@iobroker:/opt/iobroker $ groups
                                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                        Thomas BraunT simatecS 2 Antworten Letzte Antwort
                                        • T tobitobsta
                                          @Thomas-Braun
                                          here we go (dmesg):
                                          #791
                                          Du hättest ja auch mal verkünden können, das das ein gemountetes Dateisystem an der Stelle ist.
                                          Wie sehen die mount-Optionen aus?
