  4. [gelöst] Warn bei allen Adapter Neu-Inst. authenticate_pam
adapter installation warnungenauthentifikationgyp err
23 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • M MCU
    ich bekomme seit einiger Zeit Meldungen bei jeder Adapter-Installation:
    $ ./iobroker upgrade vis-hqwidgets
    Update vis-hqwidgets from @1.1.5 to @1.1.7
    NPM version: 6.14.8
    npm install iobroker.vis-hqwidgets@1.1.7 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../authenticate_pam.cc:23:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^
    ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~
    In file included from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
    ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’ NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 5.4.72-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR!
    not ok
    Hauptsächlich authenticate_pam Fehler oder gyp ERR Fehler.
    Hat da jemand Erfahrungen, was zu tun ist , um diese weg zu bekommen?
    System läuft weiterhin stabil! Ist also nicht zeitkritisch!
    Vielen Dank
    UncleSamU Offline
    UncleSamU Offline
    UncleSam
    @MCU Bitte einfach ignorieren. Ist so, kann man leider nicht ändern (siehe zahlreiche andere Forumsbeiträge zum selben Thema).
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    • UncleSamU UncleSam
      MCU
      @UncleSam Dann mach ich das mal. Vielen Dank.
      • M MCU
        @MCU @UncleSam
        Vielleicht mal die dev-Pakete nachinstallieren.
          @MCU @UncleSam
          MCU
          @Thomas-Braun Wie installiere ich denn die def-Pakete nach? Danke.
          • M MCU
            @MCU Schau erstmal wo das Ding überhaupt sitzt.
            cd /opt/iobroker
            npm list authenticate-pam
              cd /opt/iobroker
              MCU
              @Thomas-Braun
              npm list für authenticate-pam und node-gyp
              pi@pi4-2:/opt/iobroker $ npm list authenticate-pam
              iobroker.inst@2.0.3 /opt/iobroker
              └─┬ iobroker.terminal@0.1.2
               └── UNMET OPTIONAL DEPENDENCY authenticate-pam@1.0.2
              pi@pi4-2:/opt/iobroker $ npm list gyp
              └── (empty)
              pi@pi4-2:/opt/iobroker $ npm list node-gyp
              ├─┬ iobroker.sql@1.15.3
              │ └─┬ sqlite3@5.0.0
              │   └── node-gyp@3.8.0
              └─┬ iobroker.vis-weather@2.5.2
               └─┬ npm@6.14.8
                 ├── node-gyp@5.1.0
                 └─┬ npm-lifecycle@3.1.5
                   └── node-gyp@5.1.0  deduped
              • M MCU
                @Thomas-Braun
                └── (empty)
                │ └─┬ sqlite3@5.0.0
                 └─┬ npm@6.14.8
                   ├── node-gyp@5.1.0
                @MCU Brauchst du terminal? Auf deinem Linux hast du doch eh eine Shell.
                  MCU
                  @Thomas-Braun Brauch ich nicht, hatte es damals mal zum Testen installiert!
                  • M MCU
                    @MCU Dann schmeiß das halt raus.
                    Und bitte Text auch als Text hier rein (CodeTags!), nicht als Screenshot!
                      MCU
                      @Thomas-Braun
                      terminal-Instanz gelöscht
                      Muss ich den Terminal-Adapter auch löschen? Auch gelöscht!
                      • M MCU
                        @Thomas-Braun
                        @MCU Dann würde ich auch mal kritisch über die Instanzen und Adapter gehen und nicht benötigtes Zeug rauskicken
                          MCU
                          @Thomas-Braun Und siehe da, keine Fehler mehr bei einem Upgrade:
                          $ ./iobroker upgrade tuya
                          Update tuya from @3.3.15 to @3.4.1
                          NPM version: 6.14.8
                          npm install iobroker.tuya@3.4.1 --loglevel error --prefix "/opt/iobroker" (System call)
                          upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                          upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                          upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                          upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                          Adapter "tuya" updated
                          process exited with code 0
                          Prima. Danke.
                          • M MCU
                            NPM version: 6.14.8
                            Prima. Danke.
                            @MCU Kannst ja dem Developer ein issue aufmachen. authenticate-pam scheint mit aktuellen node-Versionen nicht mehr zu laufen. Aber wundert nicht weiter, der Code ist ja auch seit Jahren nicht mehr angefasst worden.
                              MCU
                              @Thomas-Braun
                              Da tut sich wohl nicht viel, letztmalig vor 13 Monaten wurde etwas geändert:
                              https://github.com/Rush/node-authenticate-pam/issues
                              • M MCU
                                @Thomas-Braun
                                @MCU Ich meinte auch eher den terminal Adapter. Der muss dann evtl. eine aktuellere Alternative zu authenticate-pam suchen.
                                Übrigens steht auf der Seite das benötigte dev-Paket:
                                sudo apt install libpam0g-dev
                                Könntest du nochmal probieren, ob es nach der Installation davon auch wieder mit dem Terminal Adapter klappt
                                  MCU
                                  @Thomas-Braun Direkt im /opt/iobroker ?
                                  • M MCU
                                    @MCU Wie meinen?
                                      @MCU Wie meinen?
                                      MCU
                                      @Thomas-Braun Direkt im Ordner /opt/iobroker ausführen?
                                      • M MCU
                                        @MCU Das ist egal.
                                        Das ist ja ein Paket das systemweit installiert wird. apt haut das in das richtige Verzeichnis rein.
                                          @MCU Das ist egal.
                                          MCU
                                          @Thomas-Braun
                                          War schon installiert:
                                          pi@pi4-2:/opt/iobroker $ sudo apt install libpam0g-dev
                                          libpam0g-dev ist schon die neueste Version (1.3.1-5+rpt2).
                                          Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                            libexiv2-14 libgfortran3 libgmime-2.6-0 libncurses5 libssl1.0.2 rpi-eeprom-images
                                          Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 7 nicht aktualisiert.
