  4. [gelöst] Warn bei allen Adapter Neu-Inst. authenticate_pam
adapter installation warnungenauthentifikationgyp err
23 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • M Online
    M Online
    MCU
    ich bekomme seit einiger Zeit Meldungen bei jeder Adapter-Installation:
    $ ./iobroker upgrade vis-hqwidgets
    Update vis-hqwidgets from @1.1.5 to @1.1.7
    NPM version: 6.14.8
    npm install iobroker.vis-hqwidgets@1.1.7 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../authenticate_pam.cc:23:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^
    ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~
    In file included from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
    ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’ NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 5.4.72-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR!
    not ok
    Hauptsächlich authenticate_pam Fehler oder gyp ERR Fehler.
    Hat da jemand Erfahrungen, was zu tun ist , um diese weg zu bekommen?
    System läuft weiterhin stabil! Ist also nicht zeitkritisch!
    Vielen Dank
    UncleSamU 1 Antwort Letzte Antwort
    • M MCU
      NPM version: 6.14.8
      not ok
      Vielen Dank
      UncleSamU Offline
      UncleSamU Offline
      UncleSam
      @MCU Bitte einfach ignorieren. Ist so, kann man leider nicht ändern (siehe zahlreiche andere Forumsbeiträge zum selben Thema).
      Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
      ♡-lichen Dank an meine Sponsoren
      • UncleSamU UncleSam
        M Online
        M Online
        MCU
        @UncleSam Dann mach ich das mal. Vielen Dank.
        • M MCU
          @MCU @UncleSam
          Vielleicht mal die dev-Pakete nachinstallieren.
            @MCU @UncleSam
            M Online
            M Online
            MCU
            @Thomas-Braun Wie installiere ich denn die def-Pakete nach? Danke.
            • M MCU
              @MCU Schau erstmal wo das Ding überhaupt sitzt.
              cd /opt/iobroker
              npm list authenticate-pam
                cd /opt/iobroker
                M Online
                M Online
                MCU
                @Thomas-Braun
                npm list für authenticate-pam und node-gyp
                pi@pi4-2:/opt/iobroker $ npm list authenticate-pam
                iobroker.inst@2.0.3 /opt/iobroker
                └─┬ iobroker.terminal@0.1.2
                 └── UNMET OPTIONAL DEPENDENCY authenticate-pam@1.0.2
                pi@pi4-2:/opt/iobroker $ npm list gyp
                └── (empty)
                pi@pi4-2:/opt/iobroker $ npm list node-gyp
                ├─┬ iobroker.sql@1.15.3
                │ └─┬ sqlite3@5.0.0
                │   └── node-gyp@3.8.0
                └─┬ iobroker.vis-weather@2.5.2
                 └─┬ npm@6.14.8
                   ├── node-gyp@5.1.0
                   └─┬ npm-lifecycle@3.1.5
                     └── node-gyp@5.1.0  deduped
                • M MCU
                  @Thomas-Braun
                  └── (empty)
                  │ └─┬ sqlite3@5.0.0
                   └─┬ npm@6.14.8
                     ├── node-gyp@5.1.0
                  @MCU Brauchst du terminal? Auf deinem Linux hast du doch eh eine Shell.
                    M Online
                    M Online
                    MCU
                    @Thomas-Braun Brauch ich nicht, hatte es damals mal zum Testen installiert!
                    • M MCU
                      @MCU Dann schmeiß das halt raus.
                      Und bitte Text auch als Text hier rein (CodeTags!), nicht als Screenshot!
                        M Online
                        M Online
                        MCU
                        @Thomas-Braun
                        terminal-Instanz gelöscht
                        Muss ich den Terminal-Adapter auch löschen? Auch gelöscht!
                        • M MCU
                          @Thomas-Braun
                          @MCU Dann würde ich auch mal kritisch über die Instanzen und Adapter gehen und nicht benötigtes Zeug rauskicken
                            M Online
                            M Online
                            MCU
                            @Thomas-Braun Und siehe da, keine Fehler mehr bei einem Upgrade:
                            $ ./iobroker upgrade tuya
                            Update tuya from @3.3.15 to @3.4.1
                            NPM version: 6.14.8
                            npm install iobroker.tuya@3.4.1 --loglevel error --prefix "/opt/iobroker" (System call)
                            upload [3] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                            upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                            upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                            upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/index_m.html index_m.html text/html
                            Adapter "tuya" updated
                            process exited with code 0
                            Prima. Danke.
                            • M MCU
                              NPM version: 6.14.8
                              Prima. Danke.
                              @MCU Kannst ja dem Developer ein issue aufmachen. authenticate-pam scheint mit aktuellen node-Versionen nicht mehr zu laufen. Aber wundert nicht weiter, der Code ist ja auch seit Jahren nicht mehr angefasst worden.
                                M Online
                                M Online
                                MCU
                                @Thomas-Braun
                                Da tut sich wohl nicht viel, letztmalig vor 13 Monaten wurde etwas geändert:
                                https://github.com/Rush/node-authenticate-pam/issues
                                • M MCU
                                  @Thomas-Braun
                                  @MCU Ich meinte auch eher den terminal Adapter. Der muss dann evtl. eine aktuellere Alternative zu authenticate-pam suchen.
                                  Übrigens steht auf der Seite das benötigte dev-Paket:
                                  sudo apt install libpam0g-dev
                                  Könntest du nochmal probieren, ob es nach der Installation davon auch wieder mit dem Terminal Adapter klappt
                                    M Online
                                    M Online
                                    MCU
                                    @Thomas-Braun Direkt im /opt/iobroker ?
                                    • M MCU
                                      @MCU Wie meinen?
                                        @MCU Wie meinen?
                                        M Online
                                        M Online
                                        MCU
                                        @Thomas-Braun Direkt im Ordner /opt/iobroker ausführen?
                                        • M MCU
                                          @MCU Das ist egal.
                                          Das ist ja ein Paket das systemweit installiert wird. apt haut das in das richtige Verzeichnis rein.
