  4. Test Adapter device-reminder v0.x
    6.5k
device-remindergeräteüberwachungadaptertest
458 Beiträge 34 Kommentatoren 119.1k Aufrufe 50 Beobachtet
  • G guergen
    @Xenon In der Version 0.3.0 & 0.3.1 auf Git geht das Abschalten nach "0" Minuten nicht mehr:
    2020-11-08 07:50:34.000 - debug: device-reminder.0 (9437) RETURN {"deviceName":"Wasserkocher","deviceType":"Wasserkocher","currentConsumption":"sonoff.0.Wasserkocher.ENERGY_Power","switchPower":"sonoff.0.Wasserkocher.POWER","pathStatus":"Wasserkocher.Zustand","pathLiveConsumption":"Wasserkocher.Verbrauch aktuell","timeTotal":"Wasserkocher.Laufzeit","messageDP":"Wasserkocher.messageDP","startMessageSent":false,"endMessageSent":false,"started":false,"autoOff":true,"verbrauch":null,"resultStart":null,"resultEnd":null,"resultStandby":null,"startValue":10,"endValue":5,"startCount":2,"endCount":2,"timeoutMsg":null,"startZeit":0,"endZeit":0,"arrStart":[],"arrAbbruch":[],"arrStandby":[],"startMessageText":"","startMessage":false,"endMessageText":"Wasserkocher ist fertig","endMessage":true,"timer":false,"timeout":null,"telegramUser":"Ralf","telegram":true,"alexaID":["1"],"alexa":true,"sayIt":false,"whatsapp":false}
    Wenn ich "1" als timeout eintrage geht das Gerät aus und sieht es wie folgt aus:
    2020-11-08 08:10:01.936 - debug: device-reminder.0 (2276) RETURN {"deviceName":"Wasserkocher","deviceType":"Wasserkocher","currentConsumption":"sonoff.0.Wasserkocher.ENERGY_Power","switchPower":"sonoff.0.Wasserkocher.POWER","pathStatus":"Wasserkocher.Zustand","pathLiveConsumption":"Wasserkocher.Verbrauch aktuell","timeTotal":"Wasserkocher.Laufzeit","messageDP":"Wasserkocher.messageDP","startMessageSent":false,"endMessageSent":false,"started":false,"autoOff":true,"verbrauch":null,"resultStart":null,"resultEnd":null,"resultStandby":null,"startValue":10,"endValue":5,"startCount":2,"endCount":2,"timeoutMsg":null,"startZeit":0,"endZeit":0,"arrStart":[],"arrAbbruch":[],"arrStandby":[],"startMessageText":"","startMessage":false,"endMessageText":"Wasserkocher ist fertig","endMessage":true,"timeoutInMS":60000,"timer":true,"timeout":null,"telegramUser":"Ralf","telegram":true,"alexaID":["1"],"alexa":true,"sayIt":false,"whatsapp":false}
    Zum Telegram-Problem: Wähle ich einen User aus, bekommt derjenige die Meldung, trage ich keinen ein, bekommen beide User die Nachricht.
    XenonX Offline
    XenonX Offline
    Xenon
    Forum Testing Developer
    #137
    @guergen sagte in Test Adapter device-reminder v0.x:
    für das auto Off gibts jetzt nen Patch, Telegram muss ich mir in Ruhe anschauen. Du bist auch der einzige der von dem Problem berichtet, muss aber ja nix heißen :P
    Version 0.3.2 ist draußen
    wenn euch mein Beitrag geholfen hat, bewertet ihn bitte unten rechts :)
    G 1 Antwort Letzte Antwort
    • XenonX Xenon
      G Online
      G Online
      guergen
      #138
      @Xenon Die neue Version probiere ich gleich aus....
      Von 0.2.x nach 0.3.x habe ich den alten Adapter komplett gelöscht, muss ich beim Update innerhalb 0.3.x auch alles löschen?
      XenonX 1 Antwort Letzte Antwort
      • G guergen
        XenonX Offline
        XenonX Offline
        Xenon
        #139
        nein, nur unter v 0.2, weil ich da was grundlegendes an der struktur geändert habe
        • XenonX Xenon
          G Online
          G Online
          guergen
          #140
          @Xenon OK
          • G guergen
            @Xenon OK
            XenonX Offline
            XenonX Offline
            Xenon
            #141
            @Xenon OK
            wie gesagt das mit telegram schau ich mir in Ruhe an. Sollten bei der 0.3.2 Fehler auftreten, einfach melden ;)
            • XenonX Xenon
              @Xenon OK
              G Online
              G Online
              guergen
              #142
              @Xenon Nix mit "auto OFF" bei "0"....
              • JB_SullivanJ Offline
                JB_Sullivan
                #143
                Guten Morgen - habe diesen Adapter durch Zufall gefunden und mal installiert. Allerdings werden bei mir keine Objekte angelegt. Die Instanz ist vorhanden und auch Grün.
                Jedoch gibt es keinen Ordner unter den Objekten. Kommen die erst wenn auch Verbrauch über die Steckdose geht?
                • JB_SullivanJ JB_Sullivan
                  G Online
                  G Online
                  guergen
                  #144
                  @JB_Sullivan Anleitung gelesen?
                  Die Objekte musst Du schon selbst im Adapter anlegen....
                  Woher soll der denn wissen, welche Geräte Du überwachen willst?
                  • G guergen
                    JB_Sullivan
                    schrieb am zuletzt editiert von JB_Sullivan
                    #145
                    Witzig Witzig - das ist mir auch klar.
                    So, jetzt ist ein Objekt angelegt worden, aber der Inhalt ist leer und es wurde die folgende Warn Meldung ausgegeben.
                    device-reminder.0	2020-11-08 10:07:23.958	warn	(8656) value status: 2
                    G XenonX 3 Antworten Letzte Antwort
                      G Online
                      G Online
                      guergen
                      #146
                      @JB_Sullivan Nachdem Du speichern gedrückt hast, sollten die GEräte als DP angelegt werden, zur Not einmal neu laden drücken in der Objekt-Anzeige.
                      Hast Du denn einen Alexa-Device angelegt? Dann klick doch mal auf den schwarzen Pfeil und wähle sie aus!
                      Warnmeldung ist schon "gemeldet" worden.... ist erst seit 0.3.2 so
                        G Online
                        G Online
                        guergen
                        #147
                        @JB_Sullivan Leer ist das immer dann wenn Du keine Meldung haben möchtest!
                        • G guergen
                          XenonX Offline
                          XenonX Offline
                          Xenon
                          #148
                          das ist nur ne debug meldung die ich vergessen hab, hab ich entfernt aber du warst zu schnell :D
                          • XenonX Xenon
                            G Online
                            G Online
                            guergen
                            #149
                            @Xenon ;-)
                              XenonX Offline
                              XenonX Offline
                              Xenon
                              schrieb am zuletzt editiert von Xenon
                              #150
                              @JB_Sullivan sagte in Test Adapter device-reminder v0.x:
                              aktuell ist es noch so, dass du zuerst alles auf der config seite anlegen musst und danach Speichern und Schliessen anklicken musst. Dadurch werden deine angelegten devices, alexas und co auf der Startseite in einer Tabelle erstellt. In dieser kannst du dann alles konfigurieren und musst anschließend nochmals auf Speichern und Schliessen.
                              Wenn alles in Ordnung ist erscheint im Log eine Meldung, die die anzeigt, dass alle Geräte erstellt wurden:
                              device-reminder.0	2020-11-08 10:25:27.457	info	(10706) Gerät "Geschirrspüler" wurde erfolgreich angelegt
                              device-reminder.0	2020-11-08 10:25:27.224	info	(10706) Gerät "Trockner" wurde erfolgreich angelegt
                              device-reminder.0	2020-11-08 10:25:27.072	info	(10706) Gerät "Computer" wurde erfolgreich angelegt
                              device-reminder.0	2020-11-08 10:25:26.883	info	(10706) Gerät "Waschmaschine" wurde erfolgreich angelegt
                              Ich bin da aber dran, dass man das mit einem Klick erledigen kann. Ist aber etwas aufwendiger und dauert noch ein wenig
                              Aber cool das du testest
                              • XenonX Offline
                                XenonX Offline
                                Xenon
                                #151
                                device-reminder.0	2020-11-08 10:25:16.362	warn	(31013) value status: 1
                                device-reminder.0	2020-11-08 10:25:12.404	warn	(31013) value status: 0
                                device-reminder.0	2020-11-08 10:25:09.247	warn	(31013) value status: 1
                                device-reminder.0	2020-11-08 10:25:07.512	warn	(31013) value status: 1
                                device-reminder.0	2020-11-08 10:25:06.440	warn	(31013) value status: 1
                                device-reminder.0	2020-11-08 10:25:02.388	warn	(31013) value status: 0
                                device-reminder.0	2020-11-08 10:24:59.247	warn	(31013) value status: 1
                                device-reminder.0	2020-11-08 10:24:57.649	warn	(31013) value status: 1
                                device-reminder.0	2020-11-08 10:24:56.589	warn	(31013) value status: 1
                                device-reminder.0	2020-11-08 10:24:52.738	warn	(31013) value status: 0
                                device-reminder.0	2020-11-08 10:24:49.268	warn	(31013) value status: 1
                                Das kam daher, dass ich anscheinend die falsche main.js gepusht hatte. Jetzt ist die richtige drauf. Nervig, wenn man auf mehreren Systemen gleichzeitig entwickelt 🙄
                                • XenonX Xenon
                                  G Online
                                  G Online
                                  guergen
                                  #152
                                  @Xenon OK, ist drin... Log ist wieder ruhig.
                                  Aber abschalten macht er bei "0" leider immer noch nicht!
                                  • G guergen
                                    XenonX Offline
                                    XenonX Offline
                                    Xenon
                                    #153
                                    bei mir funktioniert es. Hast du Discord ?
                                    • XenonX Xenon
                                      G Online
                                      G Online
                                      guergen
                                      #154
                                      @Xenon ja
                                      • G guergen
                                        @Xenon ja
                                        XenonX Offline
                                        XenonX Offline
                                        Xenon
                                        #155
                                        @Xenon ja
                                        hätte kurz Zeit mal drüber zu schauen, bin im Channel: 2 user only
                                        • XenonX Xenon
                                          @Xenon ja
                                          G Online
                                          G Online
                                          guergen
                                          #156
                                          @Xenon ... habe ich, lese da mit, ob ich wirklich weiss, was discord kann.....??? Probieren
