  4. Error Installation KNX Adapter Ver. 10.0.39
    6.7k
iobroker
71 Beiträge 3 Kommentatoren 6.1k Aufrufe 3 Beobachtet
    @tobiii1810
    iobroker add knx
    Ausgabe posten.
    tobiii1810
    @Thomas-Braun
    iobroker@IoBrokerThinClient:~$ iobroker add knx
    host.IoBrokerThinClient install adapter knx
    npm install --loglevel error --production (System call) in "/node_modules/iobroker.knx"
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /node_modules/iobroker.knx
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.knx'
    npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.knx'] {
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/node_modules/iobroker.knx'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T19_48_30_277Z-debug.log
    Cannot install iobroker.knx: 243
    • T tobiii1810
      @Thomas-Braun
      npm ERR! errno -13
      npm ERR! }
      npm ERR!
      npm ERR!
      @tobiii1810
      Da stimmt der prefix offenbar nicht.
      cd /opt/iobroker
      iobroker add knx
      T GlasfaserG 2 Antworten Letzte Antwort
        @tobiii1810
        cd /opt/iobroker
        iobroker add knx
        tobiii1810
        @Thomas-Braun
        Hat leider nichts gebracht
        iobroker@IoBrokerThinClient:~$ cd /opt/iobroker
        iobroker@IoBrokerThinClient:/opt/iobroker$ iobroker add knx
        npm ERR! errno -13
        npm ERR! }
        npm ERR!
        npm ERR!
        npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T19_52_36_875Z-debug.log
        • T tobiii1810
          @Thomas-Braun
          npm ERR! errno -13
          npm ERR! }
          npm ERR!
          npm ERR!
          GlasfaserG Offline
          GlasfaserG Offline
          @tobiii1810
          iobroker fix
          • GlasfaserG Glasfaser
            @tobiii1810
            iobroker fix
            tobiii1810
            @Glasfaser
            Hat @Thomas-Braun oben schon geschrieben und wurde auch schon ausgeführt.
              @tobiii1810
              cd /opt/iobroker
              iobroker add knx
              GlasfaserG Offline
              GlasfaserG Offline
              @Thomas-Braun
              ich würde die Kiste mal neu durchstarten lassen .....!?
                @Thomas-Braun
                @Glasfaser Ja.
                @tobiii1810
                sudo reboot
                Und ich würde mir auch einen vernünftigen USER anlegen. Da mit dem iobroker rumzumachen ist nicht gerade günstig.
                  @Glasfaser Ja.
                  @tobiii1810
                  sudo reboot
                  tobiii1810
                  @Thomas-Braun
                  Auch ein reboot bringt keinen Erfolg. Sollte ich iobroker komplett neu aufsetzten?
                  • T tobiii1810
                    @Thomas-Braun
                    @tobiii1810
                    iobroker add knx  --prefix "/opt/iobroker"
                    Versuch mal so.
                      @tobiii1810
                      Versuch mal so.
                      tobiii1810
                      @Thomas-Braun said in Error Installation KNX Adapter Ver. 10.0.39:
                      Gleiches Fehlerbild.
                      • T tobiii1810
                        @tobiii1810 Bitte Ausgaben posten.
                          tobiii1810
                          @Thomas-Braun
                          iobroker@IoBrokerThinClient:/$ iobroker add knx  --prefix "/opt/iobroker"
                          npm ERR! errno -13
                          npm ERR! }
                          npm ERR!
                          npm ERR!
                          npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T20_09_43_507Z-debug.log
                            @tobiii1810
                            Versuch mal so.
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @Thomas-Braun
                            ich vermute mal der Ordner ist/war schon da ... aber falsche Rechte gesetzt .
                            und der Fix greift nicht ...
                              @Thomas-Braun
                              @Glasfaser Nee, da greift der Prefix /opt/iobroker nicht und die Installation soll in / erfolgen. Und das darf der iobroker natürlich nicht. Ich weiß aber nicht wo das einzustellen ist.
                              Das Environment für einen Standarduser weicht ja auch vom Systemuser iobroker ab:
                              pi:x:1000:1000:,,,:/home/pi:/bin/bash
                              iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
                              Ich bin aber nicht sicher, ob das damit zu tun haben könnte.
                              In einem 'sauberen' System läuft die Installation ja auch in das richtige Directory rein:
                              iobroker add knx
                              NPM version: 6.14.8
                              npm install iobroker.knx@1.0.42 --loglevel error --prefix "/opt/iobroker" (System call)
                              • T tobiii1810
                                @Thomas-Braun
                                npm ERR! errno -13
                                npm ERR! }
                                npm ERR!
                                npm ERR!
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @Thomas-Braun
                                Er hat :
                                müsste das nicht so sein !?
                                iobroker@IoBrokerThinClient:~#
                                am Ende
                                  @Thomas-Braun
                                  Er hat :
                                  am Ende
                                  @Glasfaser Nee, das ist schon richtig.
                                  # für root
                                  $ für U$ER
                                  Trotzdem ist iobroker kein 'normaler' User.
                                  GlasfaserG T 2 Antworten Letzte Antwort
                                    # für root
                                    $ für U$ER
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @Thomas-Braun
                                    Oh ...
                                    stimmt ich muß immer umdenken , da es bei der Synology (Docker) anders ist ( root) :)
                                      # für root
                                      $ für U$ER
                                      tobiii1810
                                      @Thomas-Braun
                                      Bei der Debian Installation habe ich einen User mit dem Namen "iobroker" angelegt. Vielleicht verwirrt der Name nur ein wenig...
                                      • T tobiii1810
                                        @Thomas-Braun
                                        @tobiii1810 Ääääääh...
                                        GAAAAAAAAAANZ doofe Idee!
                                        Der iobroker ist für andere Dinge vorgesehen.
                                          tobiii1810
                                          @Thomas-Braun
                                          Kann ich den Usernamen nachträglich ändern?
