  4. Error Installation KNX Adapter Ver. 10.0.39
    6.7k
iobroker
71 Beiträge 3 Kommentatoren 6.1k Aufrufe 3 Beobachtet
  • T tobiii1810
    @Thomas-Braun
    Beim Installationsversuch über die Konsole mit folgendem Befehl
    sudo npm i iobroker.knx
    kommt dies hier
    iobroker@IoBrokerThinClient:~$ sudo npm i iobroker.knx                                      [sudo] Passwort für iobroker:
    npm WARN saveError ENOENT: no such file or directory, open '/home/iobroker/packa            ge.json'
    npm WARN enoent ENOENT: no such file or directory, open '/home/iobroker/package.            json'
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    + iobroker.knx@1.0.42
    updated 1 package and audited 53 packages in 3.075s
    3 packages are looking for funding
      run `npm fund` for details
    found 0 vulnerabilities
    @tobiii1810
    Mit npm machst du da nix. Insbesondere nicht in Verbindung mit sudo!
    Zumal das im falschen Verzeichnis ausgeführt wurde.
      @tobiii1810
      iobroker add knx
      Ausgabe posten.
      tobiii1810
      @Thomas-Braun
      iobroker@IoBrokerThinClient:~$ iobroker add knx
      host.IoBrokerThinClient install adapter knx
      npm install --loglevel error --production (System call) in "/node_modules/iobroker.knx"
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /node_modules/iobroker.knx
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/node_modules/iobroker.knx'
      npm ERR!  [Error: EACCES: permission denied, access '/node_modules/iobroker.knx'] {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/node_modules/iobroker.knx'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T19_48_30_277Z-debug.log
      Cannot install iobroker.knx: 243
      • T tobiii1810
        @Thomas-Braun
        npm ERR! errno -13
        npm ERR! }
        npm ERR!
        npm ERR!
        @tobiii1810
        Da stimmt der prefix offenbar nicht.
        cd /opt/iobroker
        iobroker add knx
        T GlasfaserG 2 Antworten Letzte Antwort
          @tobiii1810
          cd /opt/iobroker
          iobroker add knx
          tobiii1810
          @Thomas-Braun
          Hat leider nichts gebracht
          iobroker@IoBrokerThinClient:~$ cd /opt/iobroker
          iobroker@IoBrokerThinClient:/opt/iobroker$ iobroker add knx
          npm ERR! errno -13
          npm ERR! }
          npm ERR!
          npm ERR!
          npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T19_52_36_875Z-debug.log
          • T tobiii1810
            @Thomas-Braun
            npm ERR! errno -13
            npm ERR! }
            npm ERR!
            npm ERR!
            GlasfaserG Offline
            GlasfaserG Offline
            @tobiii1810
            iobroker fix
            • GlasfaserG Glasfaser
              @tobiii1810
              iobroker fix
              tobiii1810
              @Glasfaser
              Hat @Thomas-Braun oben schon geschrieben und wurde auch schon ausgeführt.
                @tobiii1810
                cd /opt/iobroker
                iobroker add knx
                GlasfaserG Offline
                GlasfaserG Offline
                @Thomas-Braun
                ich würde die Kiste mal neu durchstarten lassen .....!?
                  @Thomas-Braun
                  @Glasfaser Ja.
                  @tobiii1810
                  sudo reboot
                  Und ich würde mir auch einen vernünftigen USER anlegen. Da mit dem iobroker rumzumachen ist nicht gerade günstig.
                    @Glasfaser Ja.
                    @tobiii1810
                    sudo reboot
                    tobiii1810
                    @Thomas-Braun
                    Auch ein reboot bringt keinen Erfolg. Sollte ich iobroker komplett neu aufsetzten?
                    • T tobiii1810
                      @Thomas-Braun
                      @tobiii1810
                      iobroker add knx  --prefix "/opt/iobroker"
                      Versuch mal so.
                        @tobiii1810
                        Versuch mal so.
                        tobiii1810
                        @Thomas-Braun said in Error Installation KNX Adapter Ver. 10.0.39:
                        Gleiches Fehlerbild.
                        • T tobiii1810
                          @tobiii1810 Bitte Ausgaben posten.
                            tobiii1810
                            @Thomas-Braun
                            iobroker@IoBrokerThinClient:/$ iobroker add knx  --prefix "/opt/iobroker"
                            npm ERR! errno -13
                            npm ERR! }
                            npm ERR!
                            npm ERR!
                            npm ERR!     /home/iobroker/.npm/_logs/2020-11-02T20_09_43_507Z-debug.log
                              @tobiii1810
                              Versuch mal so.
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @Thomas-Braun
                              ich vermute mal der Ordner ist/war schon da ... aber falsche Rechte gesetzt .
                              und der Fix greift nicht ...
                                @Thomas-Braun
                                @Glasfaser Nee, da greift der Prefix /opt/iobroker nicht und die Installation soll in / erfolgen. Und das darf der iobroker natürlich nicht. Ich weiß aber nicht wo das einzustellen ist.
                                Das Environment für einen Standarduser weicht ja auch vom Systemuser iobroker ab:
                                pi:x:1000:1000:,,,:/home/pi:/bin/bash
                                iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
                                Ich bin aber nicht sicher, ob das damit zu tun haben könnte.
                                In einem 'sauberen' System läuft die Installation ja auch in das richtige Directory rein:
                                iobroker add knx
                                NPM version: 6.14.8
                                npm install iobroker.knx@1.0.42 --loglevel error --prefix "/opt/iobroker" (System call)
                                • T tobiii1810
                                  @Thomas-Braun
                                  npm ERR! errno -13
                                  npm ERR! }
                                  npm ERR!
                                  npm ERR!
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @Thomas-Braun
                                  Er hat :
                                  müsste das nicht so sein !?
                                  iobroker@IoBrokerThinClient:~#
                                  am Ende
                                    @Thomas-Braun
                                    Er hat :
                                    am Ende
                                    @Glasfaser Nee, das ist schon richtig.
                                    # für root
                                    $ für U$ER
                                    Trotzdem ist iobroker kein 'normaler' User.
                                    GlasfaserG T 2 Antworten Letzte Antwort
                                      # für root
                                      $ für U$ER
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @Thomas-Braun
                                      Oh ...
                                      stimmt ich muß immer umdenken , da es bei der Synology (Docker) anders ist ( root) :)
                                        # für root
                                        $ für U$ER
                                        tobiii1810
                                        @Thomas-Braun
                                        Bei der Debian Installation habe ich einen User mit dem Namen "iobroker" angelegt. Vielleicht verwirrt der Name nur ein wenig...
                                        • T tobiii1810
                                          @Thomas-Braun
                                          @tobiii1810 Ääääääh...
                                          GAAAAAAAAAANZ doofe Idee!
                                          Der iobroker ist für andere Dinge vorgesehen.
