  4. Ständig prebuild Fehler beim Adapter installieren / updaten
prebuildinstallationupdateadapterfehlermeldung
34 Beiträge 4 Kommentatoren 4.3k Aufrufe 5 Beobachtet
    @peterfido Da muss noch ein rebuild erfolgen.
    Cache zuvor löschen.
    peterfido
    @Thomas-Braun
    Cache gelöscht, Node-Red aktualisiert, alles neu gebuildet. Ergebnis ernüchternd:
    $ ./iobroker add linkeddevices  --host proxbroker
    NPM version: 6.14.8npm install iobroker.linkeddevices@1.2.2 --loglevel error --prefix "/opt/iobroker" (System call)
    prebuild-install
    info begin
    Prebuild-install version 5.3.3
    prebuild-install info looking for cached prebuild @ /home/iobroker/.npm/_prebuilds/f5a2d7-usb-v1.6.3-node-v72-linux-x64.tar.gz
    prebuild-install info found cached prebuild prebuild-install info unpacking @ /home/iobroker/.npm/_prebuilds/f5a2d7-usb-v1.6.3-node-v72-linux-x64.tar.gz
    prebuild-install
    info unpack resolved to /opt/iobroker/node_modules/usb/build/Release/usb_bindings.node
    prebuild-install info unpack required /opt/iobroker/node_modules/usb/build/Release/usb_bindings.node successfullyprebuild-install info install Successfully installed prebuilt binary!
    In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:128:82: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’   target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:6126:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(                                              ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:6126:46: note:   candidate expects 1 argument, 0 provided
    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:269:109: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’   Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);        ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4281:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4281:44: note:   candidate expects 3 arguments, 2 provided/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4284:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:4284:44: note:   candidate expects 1 argument, 2 provided../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);        ^In file included from ../src/BluetoothHciSocket.cpp:8:../../nan/nan.h:1045:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:395:34: error: no matching function for call to ‘v8::Value::IntegerValue()’       devId = arg0->IntegerValue();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(                                        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note:   candidate expects 1 argument, 0 provided../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:../src/BluetoothHciSocket.cpp:417:34: error: no matching function for call to ‘v8::Value::IntegerValue()’       devId = arg0->IntegerValue();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:67,                 from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(                                        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.19.0/include/node/v8.h:2705:40: note:   candidate expects 1 argument, 0 provided
    In file included from /home/iobroker/.cache/node-gyp/12.19.0/include/node/node_buffer.h:25,                 from ../src/BluetoothHciSocket.cpp:7:../src/BluetoothHciSocket.cpp: At global scope:/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:727:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.19.0/include/node/node.h:761:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/BluetoothHciSocket.cpp:499:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(binding, BluetoothHciSocket::Init); ^~~~~~~~~~~
    make: *** [binding.target.mk:111: Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
    gyp
    ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.0-11-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socketgyp ERR! node -v v12.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    host.proxbroker install adapter linkeddevices
    upload [11] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/words.js words.js application/javascript
    upload [10] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/style.css style.css text/css
    upload [9] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_small.png linkeddevices_small.png image/png
    upload [8] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_missing.png linkeddevices_missing.png image/png
    upload [7] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices_info.png linkeddevices_info.png image/png
    upload [6] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/linkeddevices.png linkeddevices.png image/png
    upload [5] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/index_m.js index_m.js application/javascript
    upload [4] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/index_m.html index_m.html text/html
    upload [3] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/img/info-big.png img/info-big.png image/png
    upload [2] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/custom_m.html custom_m.html text/html
    upload [1] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/custom.js custom.js application/javascript
    upload [0] linkeddevices.admin /opt/iobroker/node_modules/iobroker.linkeddevices/admin/admin.d.ts admin.d.ts video/mp2t
    host.proxbroker object system.adapter.linkeddevices created/updated
    host.proxbroker create instance linkeddevices
    host.proxbroker object linkeddevices.0.info.notlinkedObjects created
    host.proxbroker object linkeddevices.0.info.linkedObjects created
    host.proxbroker object linkeddevices.0.info created
    host.proxbroker object system.adapter.linkeddevices.0.sigKill created
    host.proxbroker object system.adapter.linkeddevices.0.eventLoopLag created
    host.proxbroker object system.adapter.linkeddevices.0.outputCount created
    host.proxbroker object system.adapter.linkeddevices.0.inputCount created
    host.proxbroker object system.adapter.linkeddevices.0.uptime created
    host.proxbroker object system.adapter.linkeddevices.0.memRss created
    host.proxbroker object system.adapter.linkeddevices.0.memHeapTotal created
    host.proxbroker object system.adapter.linkeddevices.0.memHeapUsed created
    host.proxbroker object system.adapter.linkeddevices.0.cputime created
    host.proxbroker object system.adapter.linkeddevices.0.cpu created
    host.proxbroker object system.adapter.linkeddevices.0.compactMode created
    host.proxbroker object system.adapter.linkeddevices.0.connected created
    host.proxbroker object system.adapter.linkeddevices.0.alive created
    host.proxbroker Set default value of linkeddevices.0.info.notlinkedObjects: 0
    host.proxbroker Set default value of linkeddevices.0.info.linkedObjects: 0
    host.proxbroker object system.adapter.linkeddevices.0 created
    process exited with code 0
    Und das hier:
    v12.19.0 (Es gibt eine neuere Version: v12.16.2 Die Version v12.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v10.20.1)
    Und der HUE Bewegungsmelder hat sich auch verabschiedet. Der lief jetzt seit Tagen mit der minütlichen Abfrage durch.
    Peterfido
    • P peterfido
      @Thomas-Braun
      prebuild-install
      info begin
      prebuild-install
      gyp
      Und das hier:
      @peterfido sagte in Ständig prebuild Fehler beim Adapter installieren / updaten:
      Hast die libudev-dev installiert?
      P 1 Antwort Letzte Antwort
        peterfido
        @Thomas-Braun
        Ja.
        peter@proxbroker:/opt/iobroker$ sudo apt install libudev-dev
        [sudo] Passwort für peter:
        libudev-dev ist schon die neueste Version (241-7~deb10u4).
        Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
         libjsoncpp1
        Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Peterfido
        • P peterfido
          @Thomas-Braun
          Ja.
           libjsoncpp1
          @peterfido
          Das Build-Environment auch?
          On Unix
          Python v2.7, v3.5, v3.6, v3.7, or v3.8
          make
          A proper C/C++ compiler toolchain, like GCC
            @peterfido
            On Unix
            make
            peterfido
            @Thomas-Braun
            peter@proxbroker:/opt/iobroker$ sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
            bluetooth ist schon die neueste Version (5.50-1.2~deb10u1).
            bluez ist schon die neueste Version (5.50-1.2~deb10u1).
            libbluetooth-dev ist schon die neueste Version (5.50-1.2~deb10u1).
             libjsoncpp1
            peter@proxbroker:/opt/iobroker$ python -V
            Python 2.7.16
            peter@proxbroker:/opt/iobroker$ python3 -V
            Python 3.7.3
            peter@proxbroker:/opt/iobroker$ gcc -v
            Using built-in specs.
            COLLECT_GCC=gcc
            COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/8/lto-wrapper
            OFFLOAD_TARGET_NAMES=nvptx-none
            OFFLOAD_TARGET_DEFAULT=1
            Target: x86_64-linux-gnu
            Configured with: ../src/configure -v --with-pkgversion='Debian 8.3.0-6' --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-8 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-libmpx --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib --enable-objc-gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
            Thread model: posix
            gcc version 8.3.0 (Debian 8.3.0-6)
            peter@proxbroker:/tmp$ make -v
            GNU Make 4.2.1
            Gebaut für x86_64-pc-linux-gnu
            Copyright (C) 1988-2016 Free Software Foundation, Inc.
            Lizenz GPLv3+: GNU GPL Version 3 oder später <http://gnu.org/licenses/gpl.html>
            Dies ist freie Software: Sie können sie nach Belieben ändern und weiter verteilen.
            Soweit es die Gesetze erlauben gibt es KEINE GARANTIE.
            Sowas muss sich doch entfernen lassen. Wieso machen die so einen Blödsinn, dass man "Installationen in der Pipeline" nicht einfach entfernen kann?
            Peterfido
            • P peterfido
              @Thomas-Braun
               libjsoncpp1
              Python 2.7.16
              Python 3.7.3
              COLLECT_GCC=gcc
              Thread model: posix
              GNU Make 4.2.1
              GlasfaserG Offline
              GlasfaserG Offline
              @peterfido
              Nimm den mal dazu :
              sudo apt update
              sudo apt install libusb-1.0-0-dev
              • GlasfaserG Glasfaser
                @peterfido
                Nimm den mal dazu :
                sudo apt update
                peterfido
                schrieb am zuletzt editiert von peterfido
                @Glasfaser
                Danke. Hat leider auch nichts gebracht.
                Der Bluetooth-Kram scheint eine optionale Abhängigkeit von iobroker zu sein:
                Ausschnitt von
                npm list
                Zeile 27
                ├─┬ iobroker.javascript@4.8.4
                │ ├─┬ @iobroker/adapter-core@2.4.0
                │ │ └─┬ @types/iobroker@3.2.3
                │ │   └── @types/node@12.12.68 deduped
                │ ├── @types/node@12.12.68
                │ ├─┬ @types/request@2.48.5
                │ │ ├── @types/caseless@0.12.2
                │ │ ├── @types/node@12.12.68 deduped
                │ │ ├── @types/tough-cookie@4.0.0
                │ │ └─┬ form-data@2.5.1
                │ │   ├── asynckit@0.4.0 deduped
                │ │   ├── combined-stream@1.0.8 deduped
                │ │   └── mime-types@2.1.26 deduped
                │ ├── async@3.2.0
                │ ├── await@0.2.6
                │ ├── coffee-compiler@0.3.2
                │ ├── coffee-script@1.12.7
                │ ├─┬ fs-extra@9.0.1
                │ │ ├── at-least-node@1.0.0
                │ │ ├── graceful-fs@4.2.3 deduped
                │ │ ├─┬ jsonfile@6.0.1
                │ │ │ ├── graceful-fs@4.2.3 deduped
                │ │ │ └── universalify@1.0.0 deduped
                │ ├── jsonata@1.8.3
                │ ├─┬ noble@1.9.1
                │ │ ├─┬ UNMET OPTIONAL DEPENDENCY bluetooth-hci-socket@0.5.1
                │ │ │ ├── debug@2.6.9 deduped
                │ │ │ ├── nan@2.14.0 deduped
                │ │ │ └─┬ UNMET OPTIONAL DEPENDENCY usb@1.6.3
                │ │ │   ├─┬ UNMET OPTIONAL DEPENDENCY bindings@1.5.0
                │ │ │   │ └── file-uri-to-path@1.0.0 deduped
                │ │ │   ├── UNMET OPTIONAL DEPENDENCY nan@2.13.2
                │ │ │   └── prebuild-install@5.3.3 deduped
                │ │ ├── bplist-parser@0.0.6
                │ │ ├─┬ debug@2.2.0
                │ │ │ └── ms@0.7.1
                │ │ └─┬ UNMET OPTIONAL DEPENDENCY xpc-connection@0.1.4
                │ │   └── nan@2.14.0 deduped
                │ ├── node-schedule@1.3.2 deduped
                │ ├─┬ node-ssh@11.1.1
                installiere ich etwas ohne Abhängigkeit, tritt der Fehler nicht auf:
                peter@proxbroker:/opt/iobroker$ npm install iobroker.logparser@1.0.4 --prefix "/opt/iobroker" --no-optional
                + iobroker.logparser@1.0.4
                updated 1 package in 21.193s
                installiere ich es "normal", kommt der Fehler wieder:
                53 packages are looking for funding
                 run `npm fund` for details
                > usb@1.6.3 install /opt/iobroker/node_modules/usb
                > prebuild-install --verbose || node-gyp rebuild
                prebuild-install info begin Prebuild-install version 5.3.3
                prebuild-install info unpack resolved to /opt/iobroker/node_modules/usb/build/Release/usb_bindings.node
                > bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/bluetooth-hci-socket
                > node-gyp rebuild
                make: Verzeichnis „/opt/iobroker/node_modules/bluetooth-hci-socket/build“ wird betreten
                 CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
                ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka  void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                ../src/BluetoothHciSocket.cpp:251:95: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>* ’ is deprecated [-Wdeprecated-declarations]
                ../src/BluetoothHciSocket.cpp:282:93: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>* ’ is deprecated [-Wdeprecated-declarations]
                make: Verzeichnis „/opt/iobroker/node_modules/bluetooth-hci-socket/build“ wird verlassen
                gyp ERR! build error
                gyp ERR! not ok
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules/bluetooth-hci-socket):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                updated 1 package in 22.61s
                Die Script Engine von iobroker hatte ich eben extra aktualisiert. Da fehlte npm dann auch was:
                npm ERR! missing: @types/node@^12.12.68, required by iobroker.javascript@4.8.4
                Das habe ich dann gleich nachinstalliert
                Peterfido
                • P Offline
                  peterfido
                  Laut Google (gesucht nach: iobroker Release/obj.target/binding/src/BluetoothHciSocket.o) bin ich nicht der einzige mit dem Fehler. Das ist dann was für z.B. @apollon77 . Habe jetzt im Proxmox zurückgerollt, da ich nicht weiß, ob ich evtl. nebenbei was zerschossen hatte.
                  Script Engine ist bei mir wieder auf 4.6.17., da die Fehlermeldung
                  ja auch noch war.
                  Peterfido
                    Wie kommt npm darauf, dass jeder, wirklich jeder Adapter das USB-node benötigt?
                    Tut nicht jeder. Aber npm unternimmt immer einen neuen Versuch die Arbeit zu Ende zu bringen, wenn es aufgerufen wird.
                    Mach den cache mal leer:
                    npm cache clean --force
                    node 10.21.0? Da würde ich ja auf die aktuelle LTS node12 gehen.
                    @Thomas-Braun sagte in Ständig prebuild Fehler beim Adapter installieren / updaten:
                    Jain, npm analysiert bei jeder aktion die es tut immer den gesamten Dependency Baum weil er ja immer schauen muss was schon da ist und so. Damit stolpert er jedes mal über ein pot. nicht vollständig installiertes Paket und will es fixen. Das ist erstmal ganz normal.
                    Bei
                    make: *** [binding.target.mk:103: Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
                    leigt es meistens daran das ein Adapter eine alte version des einer der CLuetooth libs will die ggf ein aktuelleres nodejs dazu bringt diese Fehler auszuwerfen (oder anders herum).Am Ende ist es das Modul bluetooth-hci-socket. EIn "npm ls" im iobroker Ordner sollte dir zeigen wer das alles als dep haben will, dann kann man weiter sehen.
                    Der npm cache hat damit NIX zu tun!!
                    • P peterfido
                      ja auch noch war.
                      @peterfido Ohne Kontext schwierig, aber effektiv wohl ignorierbar
                      • P peterfido
                        @Glasfaser
                        Ausschnitt von
                        npm list
                        Zeile 27
                        │ ├── async@3.2.0
                        │ ├── await@0.2.6
                        │ ├── jsonata@1.8.3
                        │ ├─┬ noble@1.9.1
                        │ │ ├─┬ debug@2.2.0
                        │ │ │ └── ms@0.7.1
                        > node-gyp rebuild
                        gyp ERR! not ok
                        @peterfido Ok, lese ...bluetooth-hci-socket ist dep von noble 1.9.1 und das ist dep von javascript ... Da es aber keine echte Dep ist hast Du das ggf manuell im javascript Adapter mal installiert!
                        Noble 1.9.1 ist 3 Jahre akt und nicht mit nodejs 12 kompatibel ... damit alles eindeutig. Noble muss auf @abandonware/noble 1.9.2-10 aktualisiert werden, das aktualisiert dann das .bluetooth-hci-socketmit ... Fertig
                        Also: Wo kam das noble her?
                        • apollon77A apollon77
                          peterfido
                          @apollon77
                          Danke für die Antwort. Ich kann mich erinnern, mal mit dem Radar / Radar2 -Adapter Bluetooth Geräte ausgewertet zu haben.
                          Den nutze ich allerdings nicht mehr. Hatte den auch nochmal installiert und wieder entfernt. Brachte keine Besserung. Dann nochmal mittels der --safe Option entfernt. Das war dann schlecht, da einiges Anderes auch nicht mehr lief. Also im Proxmox zurückgerollt und mich um was Anderes als den Fehler gekümmert...
                          Die Abhängigkeit zu noble hatte ich auch entdeckt und dann noble mal "zu Fuss" entfernt. Da dann eine Meldung kam, dass 12 Sachen deinstalliert wurden, bin ich auch da wieder zurückgerollt...
                          Peterfido
                          • P Offline
                            peterfido
                            Noble war im Javascript Adapter angegeben. Das habe ich mal entfernt. Dann tauchte es noch in der package.json vom Javascript Adapter auf.
                            Auch direkt unter iobroker wurde es gelistet. Also uninstall.
                            Jetzt gibt es nur noch ein paar Warnungen:
                            $ ./iobroker del logparser
                            Delete adapter "logparser"
                            host.proxbroker Counted 1 instances of logparser
                            host.proxbroker Counted 1 meta of logparser
                            host.proxbroker Counted 1 adapter for logparser
                            host.proxbroker Counted 33 states of logparser
                            host.proxbroker Counted 15 states of system.adapter.logparser
                            host.proxbroker Counted 33 states (io.logparser.*) from states
                            host.proxbroker Counted 16 states (system.adapter.logparser.*) from states
                            host.proxbroker Counted 1 objects of logparser
                            host.proxbroker file logparser.admin deleted
                            host.proxbroker object logparser.admin deletedhost.proxbroker Deleting 52 object(s).
                            host.proxbroker Deleting 49 state(s).
                            npm uninstall iobroker.logparser --error --prefix "/opt/iobroker" (System call)
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                            npm
                            WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):npm
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                            Die scheinen dann wohl normal zu sein. Bremsen auch nicht so wie der Bluetooth-Kram aus.
                            Peterfido
                            • P peterfido
                              npm
                              @peterfido J die sind ok weil optionale deps die unter linux nicht relevant sind
                                peterfido
                                @apollon77
                                Ich habe "meine" States alle nach 0_userdata.0 portiert gehabt. Dafür braucht man die Scriptengine 4.6.20 oder höher, damit da von CreateState nichts überschrieben wird. Daher habe ich das von 4.6.17 geupdatet.
                                Nach ein paar Tagen fehlten mir die Werte. Nachgesehen und - nanu? - Scriptengine wieder die 4.6.17. Also wieder ein Update auf 4.8.4.
                                Heute auf einen neuen Server umgezogen. Wieder fehlten mir die Werte 👿
                                Also wieder auf 4.8.4 aktualisiert. Unter Adapter wurde mir auch die 4.8.4 angezeigt. Unter Infos>Updates jedoch noch die Möglichkeit von 4.6.17 auf 4.8.4 zu aktualisieren. Demnach lief das Update nicht sauber durch. Also auf die Suche gemacht und eine Lösung gefunden.
                                Seit ich
                                peter@proxbroker:/opt/iobroker$ npm i fsevents@latest -f --save-optional
                                ausgeführt habe, tauchen die Warnungen mit fsevents nicht mehr auf und auch die ScriptEngine scheint endlich wirklich aktualisiert worden zu sein.
                                Hier die Ausgabe de oben genannten Befehls:
                                npm WARN using --force I sure hope you know what you are doing.
                                > osx-temperature-sensor@1.0.7 install /opt/iobroker/node_modules/osx-temperature-sensor
                                > node-gyp rebuild
                                make: Verzeichnis „/opt/iobroker/node_modules/osx-temperature-sensor/build“ wird betreten
                                  SOLINK_MODULE(target) Release/obj.target/none.node
                                  COPY Release/none.node
                                make: Verzeichnis „/opt/iobroker/node_modules/osx-temperature-sensor/build“ wird verlassen
                                > fsevents@1.2.13 install /opt/iobroker/node_modules/zigbee-herdsman/node_modules/fsevents
                                > node install.js
                                Skipping 'fsevents' build as platform linux is not supported
                                + fsevents@2.2.1
                                added 6 packages from 6 contributors and removed 17 packages in 12.206s
                                Peterfido
                                • apollon77A Offline
                                  Also es wäre mal cool ein uzpdate log von javascript zu sehen, weil das ewas Du so beschreibst kann nur passieren wenn das Update nicht tut.
                                  fsevents ist ein Macos Package und ist optional ... es wird also nicht irgendein update aufhalten. Da macht als irgendwas keinen echten Sinn.
                                    peterfido
                                    @apollon77
                                    Ich habe mir die Log-Dateien angesehen.
                                    Hier die relevanten Einträge im Log:
                                    2020-11-12 17:40:27.602  - info: host.proxbroker iobroker upgrade javascript
                                    2020-11-12 17:40:28.997  - info: host.proxbroker iobroker Update javascript from @4.6.17 to @4.8.4
                                    2020-11-12 17:40:29.284  - info: host.proxbroker iobroker NPM version: 6.14.8npm install iobroker.javascript@4.8.4 --loglevel error --prefix "/opt/iobroker" (System call)
                                    2020-11-12 17:40:56.490  - info: host.proxbroker iobroker Update "system.adapter.javascript.0"
                                    2020-11-12 17:40:56.555  - info: host.proxbroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                                    2020-11-12 17:40:56.557  - info: host.proxbroker stopInstance system.adapter.javascript.0 send kill signal
                                    2020-11-12 17:40:56.576  - info: javascript.0 (28968) terminating
                                    2020-11-12 17:40:56.576  - info: javascript.0 (28968) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2020-11-12 17:40:57.115  - info: host.proxbroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2020-11-12 17:40:59.362  - info: host.proxbroker iobroker upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/postiats/postiats.js vs/basic-languages/postiats/postiats.js application/javascript
                                    2020-11-12 17:40:59.664  - info: host.proxbroker instance system.adapter.javascript.0 started with pid 4372
                                    2020-11-12 17:41:00.020  - info: host.proxbroker iobroker upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/ini/ini.js vs/basic-languages/ini/ini.js application/javascript
                                    2020-11-12 17:41:01.073  - info: host.proxbroker iobroker upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/coffee/coffee.js vs/basic-languages/coffee/coffee.js application/javascript
                                    2020-11-12 17:41:02.295  - info: javascript.0 (4372) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.19.0, js-controller: 3.1.6
                                    2020-11-12 17:41:02.329  - info: javascript.0 (4372) npm install xml2js --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-12 17:41:02.681  - info: host.proxbroker iobroker upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/2.7e0b7583.chunk.js.LICENSE.txt static/js/2.7e0b7583.chunk.js.LICENSE.txt text/plain
                                    2020-11-12 17:41:03.249  - info: host.proxbroker iobroker upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
                                    2020-11-12 17:41:03.795  - info: host.proxbroker iobroker upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
                                    2020-11-12 17:41:04.165  - error: javascript.0 (4372) npm
                                    2020-11-12 17:41:04.166  - error: javascript.0 (4372)
                                    2020-11-12 17:41:04.167  - error: javascript.0 (4372) notice
                                    2020-11-12 17:41:04.168  - error: javascript.0 (4372)  created a lockfile as package-lock.json. You should commit this file.
                                    2020-11-12 17:41:04.367  - info: host.proxbroker iobroker upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
                                    2020-11-12 17:41:04.506  - info: javascript.0 (4372) + xml2js@0.4.23
                                    2020-11-12 17:41:04.523  - info: javascript.0 (4372) found 0 vulnerabilities
                                    2020-11-12 17:41:04.535  - info: javascript.0 (4372) npm install fs-extra --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-12 17:41:04.919  - info: host.proxbroker iobroker upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
                                    2020-11-12 17:41:05.494  - info: host.proxbroker iobroker upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
                                    2020-11-12 17:41:05.549  - info: host.proxbroker iobroker upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
                                    2020-11-12 17:41:05.604  - info: host.proxbroker iobroker upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
                                    2020-11-12 17:41:05.659  - info: host.proxbroker iobroker upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
                                    2020-11-12 17:41:05.715  - info: host.proxbroker iobroker upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
                                    2020-11-12 17:41:05.770  - info: host.proxbroker iobroker upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                                    2020-11-12 17:41:05.827  - info: host.proxbroker iobroker upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                                    2020-11-12 17:41:05.890  - info: host.proxbroker iobroker upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                                    2020-11-12 17:41:05.950  - info: host.proxbroker iobroker upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                                    2020-11-12 17:41:06.016  - info: host.proxbroker iobroker upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                                    2020-11-12 17:41:06.073  - info: host.proxbroker iobroker upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
                                    2020-11-12 17:41:06.130  - info: host.proxbroker iobroker upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                                    2020-11-12 17:41:06.185  - info: host.proxbroker iobroker upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                                    2020-11-12 17:41:06.241  - info: host.proxbroker iobroker upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                                    2020-11-12 17:41:06.301  - info: host.proxbroker iobroker upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
                                    2020-11-12 17:41:06.356  - info: host.proxbroker iobroker upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
                                    2020-11-12 17:41:06.411  - info: host.proxbroker iobroker upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
                                    2020-11-12 17:41:06.611  - info: host.proxbroker iobroker upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                                    2020-11-12 17:41:06.673  - info: host.proxbroker iobroker upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                    2020-11-12 17:41:06.728  - info: host.proxbroker iobroker upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
                                    2020-11-12 17:41:06.784  - info: host.proxbroker iobroker upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                    2020-11-12 17:41:06.839  - info: host.proxbroker iobroker Adapter "javascript" updated
                                    2020-11-12 17:41:07.409  - info: javascript.0 (4372) + fs-extra@9.0.1
                                    2020-11-12 17:41:07.427  - info: javascript.0 (4372) found 0 vulnerabilities
                                    2020-11-12 17:41:07.443  - info: javascript.0 (4372) npm install async --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-12 17:41:10.034  - info: javascript.0 (4372) + async@3.2.0
                                    2020-11-12 17:41:10.059  - info: javascript.0 (4372) found 0 vulnerabilities
                                    2020-11-12 17:41:10.092  - info: javascript.0 (4372) npm install await --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-12 17:41:13.030  - info: javascript.0 (4372) + await@0.2.6
                                    2020-11-12 17:41:13.046  - info: javascript.0 (4372) found 0 vulnerabilities
                                    2020-11-12 17:41:13.058  - info: javascript.0 (4372) npm install node-ssh --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-12 17:41:15.959  - info: javascript.0 (4372) + node-ssh@11.1.1
                                    2020-11-12 17:41:15.988  - info: javascript.0 (4372)
                                    2020-11-12 17:41:15.990  - info: javascript.0 (4372) found 0 vulnerabilities
                                    2020-11-12 17:41:16.059  - info: javascript.0 (4372) requesting all states
                                    2020-11-12 17:41:16.060  - info: javascript.0 (4372) requesting all objects
                                    2020-11-12 17:41:16.973  - info: javascript.0 (4372) received all objects
                                    2020-11-12 17:41:17.049  - info: javascript.0 (4372) received all states
                                    2020-11-13 07:10:21.037  - info: host.proxbroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                                    2020-11-13 07:10:21.195  - info: host.proxbroker stopInstance system.adapter.javascript.0 send kill signal
                                    2020-11-13 07:10:21.732  - info: javascript.0 (4372) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2020-11-13 07:10:22.203  - info: host.proxbroker stopInstance system.adapter.javascript.0 killing pid 4372
                                    2020-11-13 07:10:22.483  - warn: host.proxbroker instance system.adapter.javascript.0 terminated due to SIGTERM
                                    2020-11-13 07:10:22.483  - info: host.proxbroker instance system.adapter.javascript.0 terminated with code null ()
                                    2020-11-13 08:57:30.223  - info: host.proxbroker instance system.adapter.javascript.0 started with pid 821
                                    2020-11-13 08:57:31.525  - info: javascript.0 (821) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.19.0, js-controller: 3.1.6
                                    2020-11-13 08:57:31.610  - info: javascript.0 (821) requesting all states
                                    2020-11-13 08:57:31.611  - info: javascript.0 (821) requesting all objects
                                    2020-11-13 08:57:32.307  - info: javascript.0 (821) received all objects
                                    2020-11-13 08:57:32.350  - info: javascript.0 (821) received all states
                                    		...startet paar Skripte...
                                    		... arbeitet normal...
                                    2020-11-13 09:31:43.765  - info: javascript.0 (821) Stop script script.js.NormalAus.Steckdoseneinrichten
                                    		...stoppt Skripte...
                                    2020-11-13 09:34:08.356  - info: javascript.0 (821) Got terminate signal TERMINATE_YOURSELF
                                    2020-11-13 09:34:08.266  - info: host.proxbroker stopInstance system.adapter.javascript.0 (force=false, process=true)
                                    2020-11-13 09:34:08.304  - info: host.proxbroker stopInstance system.adapter.javascript.0 send kill signal
                                    2020-11-13 09:34:08.585  - info: javascript.0 (821) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2020-11-13 09:34:09.229  - info: host.proxbroker instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    		...Neustart der VM....
                                    2020-11-13 10:34:41.524  - info: host.proxbroker instance system.adapter.javascript.0 started with pid 863
                                    2020-11-13 10:34:42.862  - info: javascript.0 (863) starting. Version 4.6.17 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.19.0, js-controller: 3.1.6
                                    2020-11-13 10:34:42.881  - info: javascript.0 (863) npm install xml2js --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-13 10:34:44.844  - error: javascript.0 (863) npm notice
                                    2020-11-13 10:34:44.845  - error: javascript.0 (863)  created a lockfile as package-lock.json. You should commit this file.
                                    2020-11-13 10:34:44.846  - info: javascript.0 (863) + xml2js@0.4.23
                                    2020-11-13 10:34:44.857  - info: javascript.0 (863)
                                    2020-11-13 10:34:44.857  - info: javascript.0 (863) found 0 vulnerabilities
                                    2020-11-13 10:34:44.872  - info: javascript.0 (863) npm install fs-extra --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-13 10:34:46.008  - info: javascript.0 (863) + fs-extra@9.0.1
                                    2020-11-13 10:34:46.018  - info: javascript.0 (863)
                                    2020-11-13 10:34:46.019  - info: javascript.0 (863) found 0 vulnerabilities
                                    2020-11-13 10:34:46.032  - info: javascript.0 (863) npm install async --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-13 10:34:47.010  - info: javascript.0 (863) + async@3.2.0
                                    2020-11-13 10:34:47.037  - info: javascript.0 (863)
                                    2020-11-13 10:34:47.038  - info: javascript.0 (863) found 0 vulnerabilities
                                    2020-11-13 10:34:47.051  - info: javascript.0 (863) npm install await --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-13 10:34:49.422  - info: javascript.0 (863) + await@0.2.6
                                    2020-11-13 10:34:49.440  - info: javascript.0 (863)
                                    2020-11-13 10:34:49.441  - info: javascript.0 (863) found 0 vulnerabilities
                                    2020-11-13 10:34:49.454  - info: javascript.0 (863) npm install node-ssh --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
                                    2020-11-13 10:34:51.004  - info: javascript.0 (863) + node-ssh@11.1.1
                                    2020-11-13 10:34:51.018  - info: javascript.0 (863)
                                    2020-11-13 10:34:51.019  - info: javascript.0 (863) found 0 vulnerabilities
                                    2020-11-13 10:34:51.102  - info: javascript.0 (863) requesting all states
                                    2020-11-13 10:34:51.103  - info: javascript.0 (863) requesting all objects
                                    2020-11-13 10:34:51.731  - info: javascript.0 (863) received all objects
                                    2020-11-13 10:34:51.777  - info: javascript.0 (863) received all states
                                    Interessant ist, dass da nach den Starts was installiert wurde. Evtl. bog das die Version um. Ich starte jetzt nochmal die VM und gucke mir dann die Logs an.
                                    Peterfido
                                    • P peterfido
                                      @apollon77
                                      peterfido
                                      Der Neustart war unauffällig. Die Version ist auf 4.8.4 geblieben und kein
                                      npm install
                                      im Log zu finden.
                                      Daher gehe ich davon aus, dass die Installationsversuche was umgebogen haben und diese bleiben nach dem
                                      aus.
                                      Peterfido
