  4. Test Adapter doorio v2.1.2
door intercomdoorpitürsprechstelle
590 Beiträge 36 Kommentatoren 209.9k Aufrufe 39 Beobachtet
  • M MHeymann
    @Wal
    Hab das gerade mal beobachtet. Wenn die Fehlermeldung kommt wird der Adapter rot und kurze Zeit später wider grün.
    doorio.0	2020-08-01 23:47:01.401	info	(15061) Connected to 192.168.2.26
    doorio.0	2020-08-01 23:47:01.179	info	(15061) starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.doorio, node: v12.18.3, js-controller: 3.1.6
    doorio.0	2020-08-01 23:46:28.491	info	(14465) Terminated (NO_ERROR): Without reason
    doorio.0	2020-08-01 23:46:28.490	info	(14465) terminating
    doorio.0	2020-08-01 23:46:28.471	info	(14465) Disconnected from 192.168.2.26
    doorio.0	2020-08-01 23:46:28.469	error	(14465) uncaughtException: TypeError: Cannot read property 'val' of null
    doorio.0	2020-08-01 23:46:28.466	error	(14465) TypeError: Cannot read property 'val' of null at send2Server (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:40:50) at BaresipClient.onStateChange (/opt/iobroker/node_modules
    doorio.0	2020-08-01 23:46:28.463	error	(14465) uncaught exception: Cannot read property 'val' of null
    doorio.0	2020-08-01 23:46:05.129	info	(14465) Connected to 192.168.2.26
    doorio.0	2020-08-01 23:46:05.005	info	(14465) starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.doorio, node: v12.18.3, js-controller: 3.1.6
    doorio.0	2020-08-01 23:45:32.511	info	(11483) Terminated (NO_ERROR): Without reason
    doorio.0	2020-08-01 23:45:32.494	info	(11483) terminating
    doorio.0	2020-08-01 23:45:32.474	info	(11483) Disconnected from 192.168.2.26
    doorio.0	2020-08-01 23:45:32.472	error	(11483) uncaughtException: TypeError: Cannot read property 'val' of null
    doorio.0	2020-08-01 23:45:32.470	error	(11483) TypeError: Cannot read property 'val' of null at send2Server (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:40:50) at BaresipClient.onStateChange (/opt/iobroker/node_modules
    doorio.0	2020-08-01 23:45:32.466	error	(11483) uncaught exception: Cannot read property 'val' of null
    doorio.0	2020-08-01 23:41:26.524	info	(11483) Connected to 192.168.2.26
    doorio.0	2020-08-01 23:41:26.358	info	(11483) starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.doorio, node: v12.18.3, js-controller: 3.1.6
    ioBroker verliert immer wider die Verbindung. Liegt das vielleicht doch an baresip? Gibt da ne Log Datei? Wenn ja wo finde ich die denn? Dann schaue ich da mal rein.
    WalW Offline
    WalW Offline
    Wal
    schrieb am zuletzt editiert von Wal
    #171
    @MHeymann
    hab's gefunden, du hast in der Ring-Konfig das "none" entfernt und den Eingang nicht mit einem Object belegt.
    Der Adapter abonniert dadurch alle Objekte und irgend ein Objekt hat in der Val eine Null stehen.
    Edit: Was einem so nacht's im Bett alles einfällt :-)
    Walter
    DoorIO-Adapter
    M 2 Antworten Letzte Antwort
    • WalW Wal
      @MHeymann
      MHeymann
      #172
      @Wal
      Das kann gut sein das ds kein none bzw. garnichts steht. Ich werde das ausprobieren wenn ich zuhause bin.
      • WalW Wal
        @MHeymann
        MHeymann
        #173
        @Wal
        Jep das ist der Fehler. Ich hab wohl bei der Konfiguration des Adapters das "none" bei "Eingabe für Ring_2" gelöscht 😵. Kleiner Fehler große Wirkung.
        Jetzt kann ich fleißig weiterbauen...
        Vielen vielen Dank für die Unterstützung und den tollen Adapter.
        LG :)
        WalW 1 Antwort Letzte Antwort
        • M MHeymann
          @Wal
          LG :)
          WalW Offline
          WalW Offline
          Wal
          #174
          @MHeymann
          auf Github habe ich Version 1.0.9, die fängt den Fehler auf. :-)
          Walter
          DoorIO-Adapter
          • WalW Offline
            WalW Offline
            Wal
            #175
            Auf Github was neues .
            Eine zweite Nummer pro Klingel zum eintragen und jeweils 1 Objekt("detour") zugefügt.
            Wird das Objekt auf "True" gesetzt, wird die zweite Nummer angerufen.
            Falls man nicht zu Hause ist, könnte man sich so auf dem Handy anrufen lassen.
            Walter
            DoorIO-Adapter
            • R Offline
              Ralf87
              #176
              ich versuche mich gerade an der Installation von baresip auf einem Raspberry Pi 4. Ich habe die Image Datei aus dem ersten Post genommen und installiert.
              Wollte dann Baresip accounts anlegen und wenn ich anschließend baresip -v ausführe bekomme ich die Meldung:
              ua: SIP Transport failed: Adress allready in use
              ua: Init failed Adress allready in use
              Ich hoffe ihr könnt mir helfen.
              Grüße Ralf
              • R Ralf87
                Grüße Ralf
                WalW Offline
                WalW Offline
                Wal
                #177
                @Ralf87 ,
                im Image ist ein Baresip-Service schon vorhanden. Du startest Baresip zum zweiten mal. Falls du baresip -v ausführen möchtest, musst du erst ein "sudo systemctl stop baresip" machen.
                Walter
                DoorIO-Adapter
                P 1 Antwort Letzte Antwort
                • WalW Wal
                  @Ralf87 ,
                  peterfido
                  #178
                  @Wal
                  ich habe Baresip jetzt auf einer virtuellen Maschine im Proxmox auf dem NUC installiert. DoorIO funktioniert damit.
                  Meine Fragen:
                  1. Besteht die Möglichkeit die Rufnummer des Anrufenden mit auszugeben?
                  2. Gibt es eine Alternative zu "answermode=auto", sodass DoorIO nur bei bestimmten Anrufern abhebt?
                  Vielen Dank im Voraus.
                  Peterfido
                  • P peterfido
                    @Wal
                    Meine Fragen:
                    WalW Offline
                    WalW Offline
                    Wal
                    #179
                    @peterfido sagte in Test Adapter doorio v1.0.x:
                    @Wal
                    Meine Fragen:
                    Ich steh im Moment auf dem Schlauch :-) , möchtest du DoorIO zweckentfremden ?
                    Die Rufnummer von der Klingel ist doch immer gleich.
                    So wie ich das lese möchtest du die Türstation anrufen was ja geht, aber im Normalfall ruft die Türstation an wenn jemand klingelt. Ich denke ein Objekt befüllen das die Nummer des Anrufenden zur Türstation zeigt, müsste zu machen sein. Da muss ich mal die Baresipmeldungen durchforsten.
                    Walter
                    DoorIO-Adapter
                    P 2 Antworten Letzte Antwort
                    • WalW Wal
                      @Wal
                      Meine Fragen:
                      peterfido
                      #180
                      @Wal
                      Ja, erweitern, oder halt zweckentfremden ;)
                      Ich dachte mir eine Steuerung per Telefon und DTMF-Codes. Klappt soweit auch schon. Mir fehlt halt eine Möglichkeit, nur auf bestimmte Rufnummern zu reagieren.
                      Die Nummer kann ich mir nun schon anzeigen lassen. Was mir jetzt noch fehlt, ist dass nur bei bestimmten Nummern abgehoben wird.
                      Peterfido
                      • WalW Wal
                        @Wal
                        Meine Fragen:
                        peterfido
                        schrieb am zuletzt editiert von peterfido
                        #181
                        @Wal
                        Die Anrufernummer filtere ich so raus (client.js:
                        //Zeile 186 im 'call_closed':
                        adapter.setState('CALLING_NUMBER', 'none', true);
                        //dann, nach 'call_closed':
                                           case ('CALL_INCOMING'):
                                               let callerID = jsonContent.peeruri;
                                               var pos = callerID.indexOf(":");
                                               if (pos >= 0){
                                                   callerID = callerID.substring(pos + 1);
                                               pos = callerID.indexOf("@");
                                               if (pos >= 0){
                                                   callerID = callerID.substring(0, pos - 1);
                                               adapter.log.debug('incoming call from:' + callerID);
                                               adapter.setState('CALLING_NUMBER', callerID, true);
                                              break;
                        Das Objekt 'CALLING_NUMBER' habe ich schon bei der io-package.json hinzugefügt.
                        Dann wollte ich noch mehrere Telefonnummern (4 oder mehr) parametrierbar machen. Da kämpfe ich allerdings gerade mit dem
                                               var stateswl = "";
                                               adapter.getState('whitelist.NUMBER_1', function (err, state) {
                                                   stateswl = state.val;
                                               if (callerID.indexOf(stateswl) >= 0) {
                                                 inWL = true;
                        Die Werte wollte ich dann nach der getstate mit der callerID vergleichen. Allerdings bekomme ich die Variable 'stateswl' nicht global ausgelesen.
                        Da mache ich dann nächstes Wochenende weiter...
                        Und dem Baresip sagen, dass er abheben soll, fehlt halt auch noch.
                        Peterfido
                        • P peterfido
                          @Wal
                                                 if (pos >= 0){
                                                 if (pos >= 0){
                                                break;
                                                 var stateswl = "";
                                                   inWL = true;
                          WalW Offline
                          WalW Offline
                          Wal
                          #182
                          @peterfido
                          Abheben müsste so funktionieren :
                          client.write(Netstring.write('{"command":"accept","params":""}'))
                          Der "answermode" muss da aber auf "manual" eingestellt sein.
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            @peterfido
                            peterfido
                            #183
                            @Wal
                            Perfekt, danke. Das funktioniert. 😊
                            Peterfido
                            • P Offline
                              peterfido
                              #184
                              So, die Erweiterung ist soweit eingebaut. Allerdings aktuell nur in meinem Fork. Es fehlen noch einige Übersetzungen.
                              Möglich ist jetzt die Angabe von bis zu 6 Telefonnummern (Ausschnitte reichen), bei welchen überhaupt der Anruf angenommen werden soll. Zusätzlich kann man jede Rufnummer wählen.
                              Gibt man in den Einstellungen an, dass Baresip automatisch abhebt, dann läuft es so, wie gehabt.
                              Vielen Dank für die prima Vorlage.
                              Peterfido
                              • P peterfido
                                WalW Offline
                                WalW Offline
                                Wal
                                #185
                                Wenn du ein Pull Request machst, kann ich das übernehmen.
                                Walter
                                DoorIO-Adapter
                                • WalW Wal
                                  peterfido
                                  #186
                                  @Wal
                                  Okay, ist erledigt.
                                  Peterfido
                                  • P peterfido
                                    @Wal
                                    Okay, ist erledigt.
                                    WalW Offline
                                    WalW Offline
                                    Wal
                                    #187
                                    @Wal
                                    Okay, ist erledigt.
                                    Hi, so kann ich das leider nicht übernehmen. Die Übersetzungen sind nicht korrekt, schau mal hier wie das gemacht wird.. Version 1.0.10.1 gibts auch nicht :-) mach einfach 1.0.11 draus.
                                    Walter
                                    DoorIO-Adapter
                                    • WalW Wal
                                      @Wal
                                      Okay, ist erledigt.
                                      peterfido
                                      #188
                                      @Wal
                                      Das mit dem Übersetzungen hatte ich erwähnt. Deutsch und Englisch habe ich zu Fuss eingetippt.
                                      Ich nutze leider kein VS Code, nur den Atom Editor.
                                      Peterfido
                                      • P peterfido
                                        @Wal
                                        WalW Offline
                                        WalW Offline
                                        Wal
                                        #189
                                        Version 1.0.12 auf Github
                                        Änderungen von peterfido hinzugefügt. Evtl. kann er über die Funktion und den Einsatzbereich etwas schreiben. Mir ist das noch nicht ganz klar. ;-)
                                        Walter
                                        DoorIO-Adapter
                                        • WalW Wal
                                          peterfido
                                          #190
                                          Super, danke.
                                          Der Anwendungszweck ist folgender:
                                          Doorio hat die Auswertung der DTMF. Diese dient der Steuerung bestimmter Funktionen.
                                          Durch die hinzugefügte Rufnummernerkennung und der Whitelist nimmt Doorio nur Anrufe an, die es soll.
                                          So kann man von unterwegs per einfachem Tasten-Telefon / Handy Zuhause eine Aktion auslösen. Z.B. Zentralaus, Zutrittskontrolle, Außenbeleuchtung, etc.
                                          Die Whitelist erkennt auch Teile von Rufnummern. So kann man auch vom Büro aus anrufen, wo die Absenderkennung wegen verschiedener Durchwahlen evtl. variiert.
                                          Peterfido
