  4. Test Adapter AlarmControl V0.1.x
alarmanlagemotionsensortür-fenster-kontaktcountdownzeitschaltuhrpresence detection
64 Beiträge 9 Kommentatoren 12.4k Aufrufe 15 Beobachtet
  • sigi234S sigi234
    @wawyo sagte in Test Adapter AlarmControl V0.1.x:
    @sigi234
    Das Polizeilicht ist sehr seltsam!
    Ja, das Senden per E-Mail funktioniert.
    Die Ansage kommt jede Minute...........muss Adapter ausschalten.
    wawyoW Offline
    wawyoW Offline
    wawyo
    @sigi234
    hier ist der Code dafür:
            async StartLevelThree(SendModeState) {
                    const Adapter = this;
                    if (Math.floor((Date.now() - startLevelThreeTimer) / 1000) < 10) {
                        //**********************Very important for the loop / AlarmIsActivThree = true;*********************************
                        Adapter.log.error("Time is less than 10 seconds, execution cannot be repeated! => " + Math.floor((Date.now() - startLevelThreeTimer) / 1000) + " seconds");
                        return;
                    } else {
                        startLevelThreeTimer = Date.now();
                    Adapterarray = [];
                    var GetChangeObjectJson = await Adapter.getStateAsync('Change');
                    Adapter.log.info("The alarm system is set to 3, switch off " + GetChangeObjectJson);
                    if (GetChangeObjectJson !== undefined) {
                        Adapterarray.push(JSON.parse(GetChangeObjectJson.val));
                        var TimeDelaySpeak = 0;
                        var WarnToSendString = '🚨 ' + Thealarmsystemissettolevel[Mylanguage] + '\n';
                        for (let ArrayDev in Adapterarray[0]) {
                            //**************************************Start loop switch off***********************************************
                            if (Adapterarray[0][ArrayDev].DeviceType == "Switch") {
                                //**************************************Subscribe all switch********************************************
                                Adapter.unsubscribeForeignStates(Adapterarray[0][ArrayDev].OnObject);
                                Adapter.unsubscribeForeignStates(Adapterarray[0][ArrayDev].OffObject);
                                setTimeout(function() {
                                    Adapter.subscribeForeignStates(Adapterarray[0][ArrayDev].OnObject);
                                    Adapter.subscribeForeignStates(Adapterarray[0][ArrayDev].OffObject);
                                }, 1000);
                                //================Check State
                                if (Adapterarray[0][ArrayDev].activate) {
                                    TimeDelaySpeak += 1;
                                        var ObjectToCommandoff = Adapterarray[0][ArrayDev].OffObject;
                                        var StringToCommandoff = Adapterarray[0][ArrayDev].OffObjectString;
                                        if (CommandSPTG.AlarmVoice) {
                                            if (Adapterarray[0][ArrayDev].SpeachString) {
                                                Adapter.setForeignStateAsync(CommandSPTG.SpeakObject, Adapterarray[0][ArrayDev].SpeachString);
                                        var WarnToSendState = '';
                                        if (StringToCommandoff) {
                                            WarnToSendState = switchedon[Mylanguage];
                                        } else {
                                            WarnToSendState = switchedoff[Mylanguage];
                                        WarnToSendString += "✔️ " + Adapterarray[0][ArrayDev].DeviceIDName + ' ➢ ' + statechanged[Mylanguage] + ' ➢ ' + WarnToSendState + '\n';
                                        Adapter.log.warn("The alarm system is set to 3, switch off " + Adapterarray[0][ArrayDev].DeviceIDName + " with: " + StringToCommandoff);
                                        if (/^#[0-9A-F]{6}$/i.test(StringToCommandoff)) { //Color
                                            Adapter.setForeignStateAsync(ObjectToCommandoff, StringToCommandoff);
                                        } else if ((/\d+/g.test(StringToCommandoff)) || (/true/g.test(StringToCommandoff)) || (/false/g.test(StringToCommandoff))) { // State
                                            Adapter.setForeignStateAsync(ObjectToCommandoff, eval(StringToCommandoff));
                                        } else { // Other
                                    }, TimeDelaySpeak * 1000);
                        if (Math.floor((Date.now() - SubsLevelThreeTimer) / 1000) < 5) {
                            if (CommandSPTG.SendAlarmChanges) {
                                if (SendModeState) {
                                    Adapter.setForeignStateAsync(CommandSPTG.TelegramObject, WarnToSendString);
                                } else {
                                    return WarnToSendString;
                        } else {
                            SubsLevelThreeTimer = Date.now();
    Der Variable "WarnToSendString" wird nur von "CommandSPTG.TelegramObject" benutzt.
    Ich verstehe nicht, warum das Polizeilicht woanders erscheint!
    • wawyoW wawyo
      Aktuelle Test Version 0.1.x
      Veröffentlichungsdatum 09.09.2020
      Github Link https://github.com/spayrosam/iobroker.alarmcontrol
      Hallo zusammen, ich bin dabei eine neue Adapter zu entwickeln.
      AlarmControl ist ein Alarmsystemadapter mit vier Stufen.
      Erstellen und steuern Sie Tausende von Szenen.
      Integrieren Sie die Sprachunterstützung, um das erstellte Alarmsystem zu steuern.
      Was kann der Adapter?
      1. Alarmanlage mit vier Stufen:
      • Automatische Einschaltung.
      • Sprachsteuerung (Alexa).
      • Telegramm Benachrichtigung.
      Alarmstufe 2:
      1. Eingang öffnet sich:
      2. Prüfen welche Familienmitglied war die Letzen 10 Minuten nicht online.
      3. Familienmitglied X Anwesend => Person X begrüßen und willkommen heißen.
      4. Aktiviere Alarmstufe 2
        => jeder Änderung an Fenstern und Eingangstüren wird akustisch gemeldet.
      Alarmstufe 3:
      2. Prüfen welche Familienmitglied wird die nächsten 10 Minuten nicht online sein dann setze Person X auf abwesend.
      3. Keine Anwesend => Starte Countdown.
      4. Aktiviere Alarmstufe 3.
      5. Alle registrierte Geräte ausschalten.
      Alarmstufe 1
      wird manuell per Sprachbefehl gesteuert.
      => Melde nichts außer Änderungen bei den Eingängen.
      Alarm stufe 0
      wird auch manuell per Sprachbefehl gesteuert.
      Deaktiviere alle Funktionen.
      Mit dem entsprechenden Sprachbefehl wird die Alarmstufe geändert.
      2. Presence Check:
      • Anwesenheit richtig anzeigen (auch wenn das Handy für gewisse Zeit offline ist).
      • Begrüßung.
      • Alarmstufe Steuerung anhand die Anwesenheit.
      • Individuelle Sprachausgabe.
        3. Bewegungsmelder:
      • Helligkeitsteuerung.
      • Zeitverzögerung.
      • Countdown.
      • Steuerung durch Zeit und Tage.
        4. Türen und Fenster Sensoren:
      • Warnfunktion wenn Tür oder Fester offen ist (nach die eingestellte Zeit).
      • Eingangsüberwachung.
      • Sprachausgabe (offen/zu)
      • Zeitverzögerung.
      • Countdown.
        5. Zeitschaltuhr:
      • Steuerung durch alle Sonnenphasen.
      • Zeitverzögerung.
      • Countdown.
        6. Andere Sensoren:
      • Überprüfung von gleich, Kleiner und Größer (=<>), hier sind alle Wert-Format erlaubt.
      • Zeitverzögerung.
      • Countdown.
        8. Temperatur Sensoren:
      • Track temperature bis zu 24 Stunden.
        7. Geräte:
      • Alle Geräte werden durch die vorprogrammierten Sensoren gesteuert.
      • 'Und' Modus gesteuert (wenn mehrere Ereignisse erreicht sind)
      • 'Oder' Modus.
      Achtung, Alexa Adapter muss installiert werden, um alle mit Ihrem Konto verbundenen Echos zu importieren.
      sigi234S Online
      sigi234S Online
      Und wie genau geht das ?
      W wawyoW 2 Antworten Letzte Antwort
      • wawyoW wawyo
        Alarmstufe 2:
        Alarmstufe 3:
        Alarmstufe 1
        Alarm stufe 0
        2. Presence Check:
        • Begrüßung.
          3. Bewegungsmelder:
        • Zeitverzögerung.
        • Countdown.
        • Zeitverzögerung.
        • Countdown.
          5. Zeitschaltuhr:
        • Zeitverzögerung.
        • Countdown.
          6. Andere Sensoren:
        • Zeitverzögerung.
        • Countdown.
          7. Geräte:
        • 'Oder' Modus.
        sigi234S Online
        sigi234S Online
        @wawyo
        Beim deaktivieren des Adapters verliert er die Config.
        Ist das so gewollt?
        host.Medion(Test)	2020-09-17 11:32:58.967	error	instance system.adapter.alarmcontrol.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        alarmcontrol.0	2020-09-17 11:32:58.430	warn	(4820) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        alarmcontrol.0	2020-09-17 11:32:58.364	error	(4820) adapter disabled
        • W web4wasch
          @Glasfaser
          Ich hab noch ne andere Frage ---> habe gesehen das du "View Alarmanlage..." deine gepostet hast.
          Ich würde gerne von CCU auf ioBroker umziehen, mit welchen Mitteln (Script, Adapter etc.) setzt du deine Alarmanlage um?
          Danke dir für die RI.
          GlasfaserG Offline
          GlasfaserG Offline
          @web4wasch sagte in Test Adapter AlarmControl V0.1.x:
          Das ist eine fest verbaute Alarmanlage vom Hersteller Jablotron .
          Die Abfrage erfolgt über KNX und wird in ioBroker Visualisiert.
          • wawyoW wawyo
            @canim said in Test Adapter AlarmControl V0.1.x:
            Geile Adapter :)!, Ich würde das ganze ohne Presens machen können. Kannst du die Option mit RFID hinzufügen statt Presens?
            Im Moment ist Präsenz der Kern des Adapters. Vielleicht kann ich RFID für einen späteren Zeitpunkt einfügen ;)
            canim
            @wawyo kann doch einfach den datenpunk für rfid Präsens nehmen oder nicht? Baue mir ein Script wenn ich da bin das er ein Objekt auf True setzt und wenn ich wieder dran halte fals, sollte ja so funktionieren oder?
            • wawyoW wawyo
              @web4wasch said in Test Adapter AlarmControl V0.1.x:
              Servus zusammen,
              hört sich gut an!!!!! :-)
              Bei mir springt die Instanz nicht auf grün ---> Auszug aus dem Log
              evtl einer ne Idee?
              Danke für die RI.
              Bitte installiere moment.js
              Install moment.js package:
              npm install moment --save-prod
              GlasfaserG Offline
              GlasfaserG Offline
              @web4wasch
              Frage ... warum soll er es über " npm " nachinstallieren !?
              Er hat doch kein Fehler mehr !???
              • wawyoW wawyo
                @web4wasch
                Dies ist die Warnfunktion, wenn ein Eingang die eingestellte Zeit überschreitet!
                Wenn Du einen Eingang definiert hast, darf der Eingang bis zur eingestellten Zeit geöffnet bleiben.
                W Offline
                W Offline
                web4wasch
                @wawyo Ist die Durchsage dann einmalig nach der eingestellten Zeit? Oder wird die zyklisch wiederholt?
                Danke. Ok
                • sigi234S sigi234
                  W Offline
                  W Offline
                  web4wasch
                  @sigi234 hast du das schon raus gefunden?
                  • W web4wasch
                    sigi234S Online
                    sigi234S Online
                    Was?
                    W 1 Antwort Letzte Antwort
                    • sigi234S sigi234
                      Was?
                      W Offline
                      W Offline
                      web4wasch
                      @sigi234 said in Test Adapter AlarmControl V0.1.x:
                      Was?
                      Die Sprachsteuerung der Alarmlevel Schaltung?
                      • W web4wasch
                        Was?
                        sigi234S Online
                        sigi234S Online
                        Was?
                        Nein
                        • sigi234S sigi234
                          wawyoW Offline
                          wawyoW Offline
                          wawyo
                          schrieb am zuletzt editiert von wawyo
                          Beispiel:
                          1. Unter die Einstellungen (Sprachbefehl zum Ändern der Alarmstufe) du hast "alarm auf stufe" eingestellt (Achtung! Bitte schaust Du in der Historie nach, ob die Eingabe mit dem gesprochenen Satz übereinstimmt).
                            => wenn du sagst "Alexa, Alarm auf stufe drei", wechselt der Alarm auf Stufe drei
                          2. Unter die Einstellungen (Sprachbefehl zum Ausschalten des Alarms) du hast "ich bin hier" eingestellt.
                            => wenn du sagst "Alexa, Ich bin hier", wechselt der Alarm auf Stufe zwei.
                          @Glasfaser said in Test Adapter AlarmControl V0.1.x:
                          @web4wasch
                          dann ist alles in Ordnung ;)
                          Die nächste Version unterstützt RFID:
                          Danke. Ok
                          Die Durchsage wird zyklisch wiederholt (10 Sek.)
                          Wenn die Durchsage dich stört, du kannst die Zeit Höhe anpassen ;)
                          C sigi234S 2 Antworten Letzte Antwort
                          • wawyoW wawyo
                            Beispiel:
                            @web4wasch
                            Danke. Ok
                            canim
                            @wawyo geil :D
                            • wawyoW wawyo
                              Beispiel:
                              @web4wasch
                              Danke. Ok
                              sigi234S Online
                              sigi234S Online
                              Beispiel:
                              Das geht nicht , ein manuels ändern der DP auch nicht:
                              alarmcontrol.0	2020-09-20 00:40:13.125	info	(27156) Terminated (NO_ERROR): Without reason
                              alarmcontrol.0	2020-09-20 00:40:13.124	info	(27156) terminating
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	at processImmediate (internal/timers.js:456:21)
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	at Immediate.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:5388:34)
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	at alarmcontrol.emit (events.js:315:20)
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	at alarmcontrol.onStateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.alarmcontrol\main.js:2533:37)
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	at alarmcontrol.setForeignStateAsync (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\tools.js:1584:16)
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	at new Promise (<anonymous>)
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	at C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\tools.js:1585:16
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	at alarmcontrol.setForeignState (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:5988:17)
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	at validateId (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:482:19)
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	(27156) Error: The id is empty! Please provide a valid id.
                              alarmcontrol.0	2020-09-20 00:40:13.120	error	(27156) unhandled promise rejection: The id is empty! Please provide a valid id.
                              alarmcontrol.0	2020-09-20 00:40:13.119	info	(27156) cleaned everything up...
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	at processImmediate (internal/timers.js:456:21)
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	at Immediate.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:5388:34)
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	at alarmcontrol.emit (events.js:315:20)
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	at alarmcontrol.onStateChange (C:\Program Files\iobroker\Test\node_modules\iobroker.alarmcontrol\main.js:2530:37)
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	at alarmcontrol.setForeignStateAsync (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\tools.js:1584:16)
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	at new Promise (<anonymous>)
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	at C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\tools.js:1585:16
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	at alarmcontrol.setForeignState (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:5988:17)
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	at validateId (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:482:19)
                              alarmcontrol.0	2020-09-20 00:40:13.119	error	(27156) Error: The id is empty! Please provide a valid id.
                              alarmcontrol.0	2020-09-20 00:40:13.117	error	(27156) unhandled promise rejection: The id is empty! Please provide a valid id.
                              alarmcontrol.0	2020-09-20 00:40:13.115	warn	(27156) Alarm wurde geändert von Stufe 2 zu 3
                              • leika241265L Offline
                                leika241265
                                ich würde den Adapter gerne testen aber ich bekomme dise fehler meldungen:
                                Caught by controller[0]: }
                                Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.alarmcontrol/main.js' ]
                                Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12) {
                                Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
                                Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
                                Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
                                Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
                                Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alarmcontrol/main.js:5:17)
                                Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                                Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
                                Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:841:27)
                                Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
                                Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alarmcontrol/main.js
                                Caught by controller[0]: Require stack:
                                Caught by controller[0]: Error: Cannot find module 'suncalc'
                                Caught by controller[0]: ^
                                Caught by controller[0]: throw err;
                                Caught by controller[0]: internal/modules/cjs/loader.js:968~~~~
                                Wobei ich das paket "moment.js package " eingebaut habe und die Instance nicht startet.
                                Hat jemand eine Idee?
                                CKMartensC 1 Antwort Letzte Antwort
                                • leika241265L leika241265
                                  CKMartensC Offline
                                  CKMartensC Offline
                                  CKMartens
                                  @leika241265 ich habe heute vormittag auch den Adapter testen wollen und auch bei mir wurde erst moment-duration-format und dann suncalc moniert obwohl beide im Adapter der JavaScriptEngine als zusätzliche Module ei gebunden sind.
                                  Mir hat nur
                                  cd /opt/iobroker
                                  npm install moment-duration-format
                                  npm install suncalc
                                  geholfen
                                    leika241265
                                    @CKMartens sagte in Test Adapter AlarmControl V0.1.x:
                                    npm install suncalc
                                    Hi, hatte ich eigentlich schon gemacht aber ich habe die pakete noch einmal gelöscht und neu installiert. Nun klappt es.
                                    wawyoW 1 Antwort Letzte Antwort
                                      npm install suncalc
                                      wawyoW Offline
                                      wawyoW Offline
                                      wawyo
                                      Hallo zusammen, ich habe heute nach lange Zeit mich beschäftigt mit dem Code 🙂
                                      Version 0.2.0 ist Online.
                                      Changelog:
                                      Energieüberwachung hinzugefügt
                                      RFID hinzufügt
                                      Mehrere Bugs fixes.
                                      Viel Spaß
                                      PS:
                                      Die Energie Benachrichtigung kann gesendet oder gesprochen werden mit dem Verbrauch.
                                      Beispiel: "Die Waschmaschine ist fertig, die Kosten belaufen sich auf %1 Cent, die Waschmaschine hat %2 Kilowatt Stunden verbraucht."
                                      => %1 ist die Kosten und %2 ist der Verbrauch
                                      Bitte, nehmt es mir nicht Übel wenn ich nicht die Fragen nicht sofort beantworten kann..
                                      XenonX 1 Antwort Letzte Antwort
                                      • wawyoW wawyo
                                        Changelog:
                                        RFID hinzufügt
                                        Mehrere Bugs fixes.
                                        Viel Spaß
                                        PS:
                                        XenonX Offline
                                        XenonX Offline
                                        Xenon
                                        Forum Testing Developer
                                        schrieb am zuletzt editiert von Xenon
                                        Changelog:
                                        RFID hinzufügt
                                        Mehrere Bugs fixes.
                                        Viel Spaß
                                        PS:
                                        Das ich seit Wochen genau dafür einen Adapter am entwickeln bin, ist dir nicht aufgefallen? Soll am Wochenende ins latest
                                        https://forum.iobroker.net/topic/37915/test-adapter-device-reminder-v0-x
                                        Und kurze Frage nebenbei: Was hat sowas mit einer Alarmanlage zu tun?
                                        wenn euch mein Beitrag geholfen hat, bewertet ihn bitte unten rechts :)
                                        C wawyoW 2 Antworten Letzte Antwort
                                        • XenonX Xenon
                                          Changelog:
                                          RFID hinzufügt
                                          Mehrere Bugs fixes.
                                          Viel Spaß
                                          PS:
                                          canim
                                          schrieb am zuletzt editiert von canim
                                          Der Punkt wo 2 Entwickler sich gegenseitig die Arbeit machen xD xD . @wawyo @Xenon hat recht. Man sollte 2 Paar Schuhe nicht mischen,
