  4. Admin nicht erreichbar, ioBroker läuft
adminnotreachable
37 Beiträge 4 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • F freak1051
    @Thomas-Braun ging erst nicht. Er meinte, dazu muss iobroker aus sein, also
    iobroker@iobroker: cd /opt/iobroker
    iobroker@iobroker: iobroker stop
    iobroker@iobroker: iobroker fix
        Welcome to the ioBroker installation fixer!
        Script version: 2020-06-15
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Holen:1 http://security.debian.org/debian-security buster/updates InRelease [65,        4 kB]
    Holen:2 http://ftp.de.debian.org/debian buster InRelease [122 kB]
    Holen:3 http://security.debian.org/debian-security buster/updates/main Sources [        136 kB]
    Holen:4 http://ftp.de.debian.org/debian buster-updates InRelease [51,9 kB]
    Holen:5 http://security.debian.org/debian-security buster/updates/main amd64 Pac        kages [224 kB]
    Holen:6 http://security.debian.org/debian-security buster/updates/main Translati        on-en [122 kB]
    Holen:7 http://ftp.de.debian.org/debian buster/main Sources [7.840 kB]
    Holen:8 http://ftp.de.debian.org/debian buster-updates/main Sources.diff/Index [        3.688 B]
    Holen:9 http://ftp.de.debian.org/debian buster-updates/main amd64 Packages.diff/        Index [3.688 B]
    Holen:10 http://ftp.de.debian.org/debian buster-updates/main Translation-en.diff        /Index [3.196 B]
    Holen:11 http://ftp.de.debian.org/debian buster-updates/main Sources 2020-06-04-        2016.16.pdiff [239 B]
    Holen:12 http://ftp.de.debian.org/debian buster-updates/main Sources 2020-06-07-        1403.53.pdiff [540 B]
    Holen:13 http://ftp.de.debian.org/debian buster-updates/main Sources 2020-06-13-        2000.26.pdiff [690 B]
    Holen:14 http://ftp.de.debian.org/debian buster-updates/main amd64 Packages 2020        -06-04-2016.16.pdiff [1.101 B]
    Holen:15 http://ftp.de.debian.org/debian buster-updates/main amd64 Packages 2020        -06-07-1403.53.pdiff [439 B]
    Holen:16 http://ftp.de.debian.org/debian buster-updates/main amd64 Packages 2020        -06-13-2000.26.pdiff [552 B]
    Holen:17 http://ftp.de.debian.org/debian buster-updates/main Translation-en 2020        -06-07-1403.53.pdiff [368 B]
    Holen:18 http://ftp.de.debian.org/debian buster-updates/main Translation-en 2020        -06-13-2000.26.pdiff [423 B]
    Holen:19 http://ftp.de.debian.org/debian buster/main amd64 Packages [7.906 kB]
    Holen:20 http://ftp.de.debian.org/debian buster/main Translation-en [5.968 kB]
    Holen:21 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
    Holen:22 https://deb.nodesource.com/node_12.x buster/main amd64 Packages [767 B]
    Es wurden 22,5 MB in 5 s geholt (4.216 kB/s).
    N: Für das Depot »http://ftp.de.debian.org/debian buster InRelease« wurde der »Version«-Wert von »10.4« in »10.5« geändert.
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
    [sudo] Passwort für iobroker:
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    iobroker@iobroker:/opt/iobroker$ iobroker start
    gleiches Fehlerbild wie zuvor. Alles läuft, allerdings komme ich auf das WebUI des iobrokers nicht. Vis etc tun. Skripte funktionieren, leider also kein erfolg
    haselchenH Offline
    haselchenH Offline
    haselchen
    @freak1051
    gib in der konsole mal
    pkill io
    ein
    und dann
    iobroker start admin oder nur iobroker start
    F 1 Antwort Letzte Antwort
      @freak1051
      iobroker list instances
      freak1051
      @Thomas-Braun
      iobroker@iobroker:~$ iobroker list instances
        system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                : alexa2                -  enabled
      + system.adapter.backitup.0              : backitup              -  enabled
      + system.adapter.ble.0                   : ble                   -  enabled
      + system.adapter.denon.0                 : denon                 -  enabled
      + system.adapter.discovery.0             : discovery             -  enabled
      + system.adapter.fritzdect.0             : fritzdect             -  enabled
      + system.adapter.history.0               : history               -  enabled
      + system.adapter.hue-extended.0          : hue-extended          -  enabled
      + system.adapter.hue.0                   : hue                   -  enabled, port: 80
      + system.adapter.info.0                  : info                  -  enabled
      + system.adapter.iot.0                   : iot                   -  enabled
      + system.adapter.javascript.0            : javascript            -  enabled
      + system.adapter.node-red.0              : node-red              -  enabled, port: 1880, bind: 192.168.16.178
      + system.adapter.ping.0                  : ping                  -  enabled
      + system.adapter.proxmox.0               : proxmox               -  enabled, port: 8006
      + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 192.168.16.178, run as: admin
      + system.adapter.text2command.0          : text2command          -  enabled
      + system.adapter.tuya.0                  : tuya                  -  enabled
        system.adapter.vis-bars.0              : vis-bars              -  enabled
        system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
        system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
        system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
        system.adapter.vis-google-fonts.0      : vis-google-fonts      -  enabled
        system.adapter.vis-history.0           : vis-history           -  enabled
        system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
        system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
        system.adapter.vis-justgage.0          : vis-justgage          -  enabled
        system.adapter.vis-keyboard.0          : vis-keyboard          -  enabled
        system.adapter.vis-map.0               : vis-map               -  enabled
        system.adapter.vis-players.0           : vis-players           -  enabled
        system.adapter.vis-rgraph.0            : vis-rgraph            -  enabled
        system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
        system.adapter.vis-weather.0           : vis-weather           -  enabled
        system.adapter.vis.0                   : vis                   -  enabled
      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.worx.0                  : worx                  -  enabled
        system.adapter.zigbee.0                : zigbee                - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00
      • haselchenH haselchen
        @freak1051
        pkill io
        ein
        und dann
        freak1051
        @haselchen
        leider kein erfolg. gleiches problem
        • F freak1051
          @haselchen
          @freak1051 https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md
            freak1051
            @Homoran wie in meinem Initialbeitrag erwähnt, hab ich diese Anleitung schon druch.
            Die Ergebnisse sind in den Spoilern versteckt.
            Einzige sache, was ich noch nicht gemacht hab, ist eine zweite Admin Instanz installieren.. Davor will ich sicher sein, dass nichts anderes sein kann.. Glaub das des auf dauer nicht gut ist, 2 admin-Instanzen parallel zu betreiben
            • F freak1051
              @freak1051 sagte in Admin nicht erreichbar, ioBroker läuft:
              Wer hat dir diesen Glauben vermittelt?
              aber warum läuft denn der admin.0 nicht?
              Steht wirklich nichts im log?
                freak1051
                @Homoran wenn du mir sagst, wie ich das Log finde :)
                zumdinest bei iobroker list instances steht er auf enabled.. Allerings fehlt das + bei intance is alive....
                Den glauben hab ich mir selbst vermittelt... weil ich installier Word ja auch nicht 2 mal in unterschiedlichen pfaden... :) kann aber auch nur schwachfug sein...
                • F freak1051
                  ja, aber er läuft nicht weil das + fehlt
                  /opt/iobroker/log/datumvonheute
                  du sollst ja auch nicht iobroker doppelt installieren, nur das Word-Dokument unter anderem Namen, ähh Port;-)
                    freak1051
                    @Homoran Mod-Edit: Datei entfernt
                    Ist leider zu groß um hier als Text anzuhängen
                    HomoranH F 2 Antworten Letzte Antwort
                    • F freak1051
                      @freak1051 der admin stoppt und startet alle 30 Sekunden!
                      Was sagt top auf der Konsole
                      • F freak1051
                        freak1051
                        @Homoran
                        hab jetzt auch schnell ne zweite Instanz erstellt. Danach iobroker list instances... sieht gleich aus
                         system.adapter.admin.1                 : admin                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                         system.adapter.zigbee.0                : zigbee                - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00194A202C-if00
                        + instance is alive
                          freak1051
                          schrieb am zuletzt editiert von freak1051
                          @Homoran wenn ich da was top eingebe hab ich da wechselnde tasks.. ich versuch mal zu kopieren, wenn "Viel"drin steht
                          top - 15:57:47 up  1:31,  1 user,  load average: 0,07, 0,06, 0,01
                          Tasks:  98 total,   1 running,  97 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  5,2 us,  1,5 sy,  0,0 ni, 93,1 id,  0,0 wa,  0,0 hi,  0,2 si,  0,0 st
                          MiB Mem :   3946,8 total,   2558,2 free,   1042,1 used,    346,4 buff/cache
                          MiB Swap:   4500,0 total,   4500,0 free,      0,0 used.   2680,8 avail Mem
                           PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                          1972 iobroker  20   0  742300 175652  29488 S   6,6   4,3   1:03.45 iobroker.js-con
                          2439 iobroker  20   0  636952  74080  29908 S   5,6   1,8   0:19.26 io.hue-extended
                          2417 iobroker  20   0  694052 120596  29584 S   1,0   3,0   0:13.34 io.javascript.0
                          2402 iobroker  20   0  626576  69984  29928 S   0,7   1,7   0:06.28 io.hue.0
                          2012 iobroker  20   0  684464  60964  30576 S   0,3   1,5   0:01.73 io.info.0
                          2031 iobroker  20   0  609296  49728  29444 S   0,3   1,2   0:01.36 io.denon.0
                          2623 iobroker  20   0  632372  59872  29404 S   0,3   1,5   0:01.88 io.sonoff.0
                          4183 iobroker  20   0   11096   3504   2924 R   0,3   0,1   0:00.05 top
                             1 root      20   0   21856   9808   7680 S   0,0   0,2   0:00.79 systemd
                             2 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kthreadd
                             3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                             4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                             6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/0:0H-kblockd
                             8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                             9 root      20   0       0      0      0 S   0,0   0,0   0:00.03 ksoftirqd/0
                            10 root      20   0       0      0      0 I   0,0   0,0   0:00.50 rcu_sched
                            11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_bh
                            12 root      rt   0       0      0      0 S   0,0   0,0   0:00.00 migration/0
                            14 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
                            15 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
                            16 root      rt   0       0      0      0 S   0,0   0,0   0:00.30 migration/1
                            17 root      20   0       0      0      0 S   0,0   0,0   0:00.10 ksoftirqd/1
                            19 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:0H-kblockd
                            20 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kdevtmpfs
                            21 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
                            22 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
                            23 root      20   0       0      0      0 S   0,0   0,0   0:00.00 khungtaskd
                            24 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
                            25 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
                            26 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kcompactd0
                            27 root      25   5       0      0      0 S   0,0   0,0   0:00.00 ksmd
                            28 root      39  19       0      0      0 S   0,0   0,0   0:00.08 khugepaged
                            29 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 crypto
                            30 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kintegrityd
                            31 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
                            32 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 edac-poller
                            33 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 devfreq_wq
                            34 root      rt   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
                            35 root      20   0       0      0      0 I   0,0   0,0   0:00.46 kworker/1:1-events_power_efficient
                            36 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kswapd0
                            54 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
                            55 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 ipv6_addrconf
                            56 root      20   0       0      0      0 I   0,0   0,0   0:00.01 kworker/u4:1-events_unbound
                            66 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kstrp
                           116 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 ata_sff
                           117 root      20   0       0      0      0 S   0,0   0,0   0:00.00 scsi_eh_0
                           118 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 scsi_tmf_0
                           119 root      20   0       0      0      0 S   0,0   0,0   0:00.00 scsi_eh_1
                           120 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 scsi_tmf_1
                           122 root      20   0       0      0      0 S   0,0   0,0   0:00.00 scsi_eh_2
                           123 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 scsi_tmf_2
                           125 root      20   0       0      0      0 I   0,0   0,0   0:00.66 kworker/0:3-events_freezable
                           126 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:1H-kblockd
                           127 root       0 -20       0      0      0 I   0,0   0,0   0:00.07 kworker/0:1H-kblockd
                           160 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/u5:0-hci0
                           162 root      20   0       0      0      0 S   0,0   0,0   0:00.04 jbd2/sda1-8
                           163 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 ext4-rsv-conver
                           189 root      20   0   24460   7980   6932 S   0,0   0,2   0:00.23 systemd-journal
                           212 root      20   0   21920   4880   4008 S   0,0   0,1   0:00.06 systemd-udevd
                           251 systemd+  20   0   95144   6420   5556 S   0,0   0,2   0:00.04 systemd-timesyn
                           290 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 ttm_swap
                           291 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/u5:2-hci0
                          ist aber nicht die komplette liste... gamerhand ist eingerostet^^
                          und warum der immer wieder stoppt und startet... kp.. darum bin ich vielleicht hier :) ^^?
                          • F freak1051
                            @Homoran
                            + instance is alive
                            war, nachdem ich das log gesehen habe, keine gute Idee
                            Wie hast du dir den Platz auf der Platte vergrößert?
                            nur über das PVE oder anschließend auch per gparted?
                              freak1051
                              @Homoran
                              ich hatte auf dem Proxmox
                              den iobroker + eine sehr alte sicherung
                              eine Win10 VM + sicherung. Diese hab ich jetzt weggeworfen
                              und noch eine Debian VM, falls ich mal was brauch.
                              Alles ist auf eine Platte.
                              das sind die Daten des ioBroker:
                              • F freak1051
                                 top - 15:57:47 up  1:31,  1 user,  load average: 0,07, 0,06, 0,01        Tasks:  98 total,   1 running,  97 sleeping,   0 stopped,   0 zombie        %Cpu(s):  5,2 us,  1,5 sy,  0,0 ni, 93,1 id,  0,0 wa,  0,0 hi,  0,2 si,  0,0 st        MiB Mem :   3946,8 total,   2558,2 free,   1042,1 used,    346,4 buff/cache        MiB Swap:   4500,0 total,   4500,0 free,      0,0 used.   2680,8 avail Mem
                                Sieht von daher alles sauber aus.
                                versuch es mal mit
                                top | grep io.ad
                                da sollte jetzt alle 30 Sekunden ein neuer Prozess erscheinen
                                und nur einer - keine zwei!
                                • F freak1051
                                  @Homoran
                                  also keine VM vergrößertoder so?
                                    freak1051
                                    @Homoran doch aber schon lange her. kann dir aber nicht merh sagen ob ich da gparted drüber hab lassen.
                                    Ich vermute aber stark.. nutzen im Geschäft ausschließlich (wiondows) VM´s (vmware) und da isses ja nicht anders. Mehr platz zuweisen-->Datenträgerverwaltung-->Volume vergrößern
                                    Aber die Io´broker VM vergrößert
                                      versuch es mal mit
                                      top | grep io.ad
                                      freak1051
                                      @Homoran said in Admin nicht erreichbar, ioBroker läuft:
                                      versuch es mal mit
                                      top | grep io.ad
                                      Kam jezt 2 minuten lang nichts...
                                      • F freak1051
                                        nun weiß das Dateisystem der VM noch nicht, dass du ihm mehr Platz geben willst. Das musst du noch mit Gparted (live iso) auch dem Dateisystem mitteilen, sonst liegt der neue Platz unpartitioniert rum.
                                        Dazu gibt es einen Thread (irgendwo :-( )
                                        Ansonsten habe ich (fast) keinen Ansatz mehr.
                                        was sagt iobroker list adapters
                                        • F freak1051
                                          versuch es mal mit
                                          top | grep io.ad
                                          seltsam:
                                          pi@raspberrypi:~ $ top | grep io.ad
                                           5123 iobroker  20   0  201616  80656   7644 S   0,7   4,1  47:20.55 io.admin.0
                                           5123 iobroker  20   0  201616  80656   7644 S   0,7   4,1  47:20.57 io.admin.0
