  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 786.7k Aufrufe 118 Beobachtet
  • S SchuetzeSchulz
    @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
    @SchuetzeSchulz am besten den adapter msl auf debug stellen und stsrt und stop testen
    Hallo Dirk,
    hier das Log (in Zeile 26 sieht man das ich den Saugvorgang über Objekte gestartet habe, in Zeile 9 habe ich auch wieder über Objekte clean_home auf false gesetzt nur scheint das beim Adapter nicht anzukommen?):
    2020-08-25 09:01:29.399  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":15,"method":"get_status"}
    2020-08-25 09:01:29.405  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"msg_ver":6,"msg_seq":918,"state":8,"battery":100,"clean_time":209,"clean_area":5615000,"error_code":0,"map_present":0,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":15}
    2020-08-25 09:01:29.406  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":16,"method":"get_consumable"}
    2020-08-25 09:01:29.411  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"main_brush_work_time":126741,"side_brush_work_time":126741,"filter_work_time":126741,"sensor_dirty_time":126741}],"id":16}
    2020-08-25 09:01:29.907  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":17,"method":"get_clean_summary"}
    2020-08-25 09:01:29.913  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[3179394,46403550000,1387,[1598248800,1598162400,1598076000,1597989600,1597903200,1597816800,1597730400]],"id":17}
    2020-08-25 09:01:31.479  - debug: mihome-vacuum.1 (7951) system.adapter.admin.0: logging false
    2020-08-25 09:01:31.484  - debug: mihome-vacuum.0 (7940) system.adapter.admin.0: logging false
    2020-08-25 09:01:31.573  - debug: mihome-vacuum.0 (7940) stateChange mihome-vacuum.0.control.clean_home {"val":true,"ack":false,"ts":1598338891571,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1598338891571}
    2020-08-25 09:01:31.573  - debug: mihome-vacuum.0 (7940) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    2020-08-25 09:01:31.574  - info: mihome-vacuum.0 (7940) trigger cleaning all
    2020-08-25 09:01:31.575  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":18,"method":"app_start"}
    2020-08-25 09:01:31.580  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":0,"id":18}
    2020-08-25 09:01:31.930  - debug: mihome-vacuum.1 (7951) sendMsg[1] >>> {"id":28,"method":"get_status"}
    2020-08-25 09:01:33.129  - debug: mihome-vacuum.1 (7951) Receive <<< {"result":[{"msg_ver":8,"msg_seq":979,"state":8,"battery":100,"clean_time":2945,"clean_area":41970000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":28}
    2020-08-25 09:01:33.130  - debug: mihome-vacuum.1 (7951) sendMsg[1] >>> {"id":29,"method":"get_consumable"}
    2020-08-25 09:01:33.135  - debug: mihome-vacuum.1 (7951) Receive <<< {"result":[{"main_brush_work_time":105388,"side_brush_work_time":105388,"filter_work_time":105388,"sensor_dirty_time":105388}],"id":29}
    2020-08-25 09:01:33.574  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":19,"method":"get_status"}
    2020-08-25 09:01:33.581  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"msg_ver":6,"msg_seq":920,"state":5,"battery":100,"clean_time":209,"clean_area":5615000,"error_code":0,"map_present":0,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":19}
    2020-08-25 09:01:33.582  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":20,"method":"get_sound_volume"}
    2020-08-25 09:01:33.587  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[61],"id":20}
    2020-08-25 09:01:33.632  - debug: mihome-vacuum.1 (7951) sendMsg[1] >>> {"id":30,"method":"get_clean_summary"}
    2020-08-25 09:01:33.639  - debug: mihome-vacuum.1 (7951) Receive <<< {"result":[1409063,22058512500,630,[1920696483,1920672653,1598252409,1598247899,1598186699,1598180399,1598168709,1598088609,1597996539,1597927657,1597829053,1597647977,1597586410,1597475136,1597436999,1597411809,1597326301,1597301249,1597212506,1597132810]],"id":30}
    2020-08-25 09:01:35.430  - debug: mihome-vacuum.1 (7951) system.adapter.admin.0: logging true
    2020-08-25 09:01:35.430  - debug: mihome-vacuum.0 (7940) system.adapter.admin.0: logging true
    2020-08-25 09:01:45.212  - debug: mihome-vacuum.0 (7940) stateChange mihome-vacuum.0.control.clean_home {"val":false,"ack":false,"ts":1598338905212,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1598338905212}
    2020-08-25 09:01:45.213  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":21,"method":"app_charge"}
    2020-08-25 09:01:45.219  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":0,"id":21}
    2020-08-25 09:01:47.214  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":22,"method":"get_status"}
    2020-08-25 09:01:47.221  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"msg_ver":6,"msg_seq":921,"state":5,"battery":100,"clean_time":209,"clean_area":5615000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":22}
    2020-08-25 09:01:47.221  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":23,"method":"get_sound_volume"}
    2020-08-25 09:01:47.227  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[61],"id":23}
    2020-08-25 09:01:51.931  - debug: mihome-vacuum.1 (7951) sendMsg[1] >>> {"id":31,"method":"get_status"}
    2020-08-25 09:01:51.938  - debug: mihome-vacuum.1 (7951) Receive <<< {"result":[{"msg_ver":8,"msg_seq":980,"state":8,"battery":100,"clean_time":2945,"clean_area":41970000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":31}
    2020-08-25 09:02:07.216  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":24,"method":"get_status"}
    2020-08-25 09:02:07.228  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"msg_ver":6,"msg_seq":922,"state":5,"battery":100,"clean_time":33,"clean_area":615000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":24}
    D
    D
    dirkhe
    #1153
    @SchuetzeSchulz er gibt das an den Robbie weiter, nämlich den Befehl app_charge. Aber anscheinend mag er den Befehl bei dir nicht. Müssten wir mal schauen, was deiner mag, dann könnte man das ggf. Mal alternativ einbauen. Ich war mal angefangen, die Kommunikation zu abstrahieren, aber mittlerweile hat sich der Code schon wieder soweit verändern, dass ich praktisch von vorne anfangen kann. Ist eher was für den Winter.
    • D dirkhe
      S
      S
      SchuetzeSchulz
      #1154
      Aber es hat ja mal funktioniert.
      Oder wurde durch irgend ein Update des Adapters mal was geändert in der Hinsicht?
      • M moviehunter
        @haselchen @Meistertr @dirkhe
        ich habe das gleiche Problem allerdings mit Version 2.2.3
        Token sind bei mir beide identisch
        Hier ein Auszug meines logs...
        mihome-vacuum.0	2020-08-25 21:13:38.365	debug	(6318) sendMsg[1] >>> {"id":2,"method":"get_status"}
        mihome-vacuum.0	2020-08-25 21:13:38.360	debug	(6318) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-08-25 21:13:38.359	info	(6318) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-08-25 21:13:38.357	debug	(6318) Receive <<< Helo <<< 213100200000000013d62eac5f4562e2ffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-08-25 21:13:33.412	debug	(6318) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-08-25 21:13:33.411	debug	(6318) no answer for id:1 received, giving up
        mihome-vacuum.0	2020-08-25 21:13:28.410	debug	(6318) sendMsg[3] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-08-25 21:13:23.408	debug	(6318) sendMsg[2] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-08-25 21:13:18.836	info	(6318) set nächster Timer: Nicht verfügbar
        mihome-vacuum.0	2020-08-25 21:13:18.407	debug	(6318) sendMsg[1] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-08-25 21:13:18.396	debug	(6318) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-08-25 21:13:18.395	info	(6318) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-08-25 21:13:18.393	debug	(6318) Receive <<< Helo <<< 213100200000000013d62eac5f4562ceffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-08-25 21:13:18.377	debug	(6318) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        mihome-vacuum.0	2020-08-25 21:13:18.341	debug	(6318) server started on 0.0.0.0:53421
        mihome-vacuum.0	2020-08-25 21:13:18.316	info	(6318) Cloud control disabled
        mihome-vacuum.0	2020-08-25 21:13:18.314	info	(6318) Expert mode disabled, states deleted
        mihome-vacuum.0	2020-08-25 21:13:18.258	info	(6318) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.21.0, js-controller: 3.1.6
        kannst du mir auch weiter helfen? Bekomme keine Verbindung zum Sauger...
        M
        M
        moviehunter
        #1155
        @moviehunter said in Test Adapter mihome-vacuum v2.0.x:
        Welche Informationen benötigt ihr, um mir helfen zu können?
        • S SchuetzeSchulz
          D
          D
          dirkhe
          #1156
          @SchuetzeSchulz kann ich so direkt nicht sagen. Ich glaube in einer früheren Version würde mal erst Pause und dann charge gesendet. Vlt kannst das ja Bei dir mal ausprobieren?
          • M moviehunter
            D
            D
            dirkhe
            #1157
            @moviehunter ggf.mal die mihome App öffnen und einen Moment warten, dazu muss der natürlich Internet haben und mit der App connected sein. Wenn das alles nicht hilft,anstimmt irgendwas mit deinem Token nicht, würde ich vermuten
            • D dirkhe
              S
              S
              SchuetzeSchulz
              #1158
              Hallo Dirk,
              habe das eben ausprobiert.
              Mit clean_home gestartet, kurz gewartet und dann erst "pause" und dann "home" gedrückt.
              Das funktioniert.
              Kann man das irgendwie im "clean_home" false auch so machen? Gern auch als Haken in den Einstellungen?
              • D dirkhe
                @blackeagle998 über die API nicht. Ich hatte mal angefangen, die Map auszulesen und die Koordinaten entsprechend umzurechnen, ist aber mangels Zeit eingeschlafen.
                B
                B
                blackeagle998
                #1159
                @dirkhe
                Danke für die Info, auch wenn ich mir etwas anderes erhofft hatte 🙁
                • S SchuetzeSchulz
                  Hallo Dirk,
                  Das funktioniert.
                  D
                  D
                  dirkhe
                  #1160
                  @SchuetzeSchulz das mit der Einstellung ist eine gute Idee. Ich schaue mal, das ich das einbaue
                  S 2 Antworten Letzte Antwort
                  • D dirkhe
                    S
                    S
                    SchuetzeSchulz
                    #1161
                    Das wäre klasse...
                    • D dirkhe
                      M
                      M
                      moviehunter
                      #1162
                      @dirkhe
                      danke für die Rückmeldung.
                      Das mit dem App öffnen klappt leider nicht. Nutze die App regelmäßig um den Sauber zu starten, teilweise von zu Hause, teilweise von unterwegs. Somit kann ich auf jeden Fall gewährleisten, dass der Sauger Internet hat.
                      Den Token habe ich nun 3mal neu eingegeben, ohne Besserung.
                      Bekomme bei "Verbunden mit mihome-vacuum" einfach keine Verbindung.
                      Hatte vorher die stable Version 2.0.7 installiert.
                      Dort hatte ich bei "Verbunden mit mihome-vacuum" ein true...trotzdem hat sich der Sauger nicht gerührt.
                      Nun bei der aktuell installierten 2.2.3 habe ich bei "Verbunden mit mihome-vacuum" ein false und natürlich tut sich beim Sauger auch nichts... Hast du weitere Lösungsvorschläge?
                      Viele Grüße
                      coyoteC D 2 Antworten Letzte Antwort
                      • M moviehunter
                        @dirkhe
                        Viele Grüße
                        coyoteC
                        coyoteC
                        coyote
                        #1163
                        @dirkhe @Meistertr ist es möglich von ValetudoRE verschiedene Karten über den Adapter zu laden?
                        • M moviehunter
                          @dirkhe
                          Viele Grüße
                          D
                          D
                          dirkhe
                          #1164
                          @moviehunter Nein, dann habe ich auch keine Idee mehr. Aber wir reden von der mihome App und nicht der roborock App? Warum gibst du den Token ein und holst ihn dir nicht per adapter?
                          • D dirkhe
                            M
                            M
                            moviehunter
                            schrieb am zuletzt editiert von moviehunter
                            #1165
                            @dirkhe Ja klar...im iobroker habe ich den Adapter mihome-vacuum Version 2.2.3
                            Also Android App nutze ich die Xiaomi Home App Version 5.8.7
                            Den Token beziehe ich ja durch das Eingeben meiner Zugangsdaten aus der Android App.
                            Dann muss ich den Token ja unten nochmal manuell eingeben oder sehe ich das falsch? Jedenfalls wenn ich das nicht tue, bekomme ich immer eine Fehlermeldung beim speichern.
                            Was genau bedeuten denn die drei Zeilen, wenn man über den bei mir gelben Button geht bei Instanzen?
                            Verbunden mit Host: wahr
                            Lebenszeichen: wahr
                            Verbunden mit mihome-vacuum: falsch
                            Habe jetzt nochmal die stable 2.0.7 installiert. Dort ist die Lampe wieder grün aber trotzdem keine Reaktion vom Sauber...
                            Hier mal ein Auszug ausm Log:
                            mihome-vacuum.0	2020-09-01 20:50:41.069	debug	(1229) no answer for get_sound_volume(id:62) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:40.869	debug	(1229) no answer for get_clean_summary(id:61) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:40.669	debug	(1229) no answer for get_consumable(id:60) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:39.126	debug	(1229) no answer for get_sound_volume(id:58) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:38.930	debug	(1229) no answer for get_clean_summary(id:57) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:38.724	debug	(1229) no answer for get_consumable(id:56) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:38.525	debug	(1229) no answer for get_status(id:54) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:26.619	debug	(1229) no answer for get_status(id:53) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:25.461	debug	(1229) requesting params every: 60 Sec
                            mihome-vacuum.0	2020-09-01 20:50:23.517	debug	(1229) requesting params every: 60 Sec
                            mihome-vacuum.0	2020-09-01 20:50:23.514	info	(1229) Connected
                            mihome-vacuum.0	2020-09-01 20:50:23.402	info	(1229) Disconnect
                            mihome-vacuum.0	2020-09-01 20:50:21.401	info	(1229) should trigger cleaning all null, but is currently active. Add to queue
                            mihome-vacuum.0	2020-09-01 20:50:21.396	debug	(1229) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                            mihome-vacuum.0	2020-09-01 20:50:21.395	debug	(1229) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1598986221392,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1598986056217}
                            mihome-vacuum.0	2020-09-01 20:50:16.618	debug	(1229) no answer for get_status(id:52) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:07.258	debug	(1229) no answer for get_sound_volume(id:51) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:07.057	debug	(1229) no answer for get_clean_summary(id:50) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:06.857	debug	(1229) no answer for get_consumable(id:49) received, giving up
                            mihome-vacuum.0	2020-09-01 20:50:06.653	debug	(1229) no answer for get_status(id:47) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:56.590	debug	(1229) no answer for get_status(id:46) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:51.649	debug	(1229) requesting params every: 60 Sec
                            mihome-vacuum.0	2020-09-01 20:49:51.646	info	(1229) Connected
                            mihome-vacuum.0	2020-09-01 20:49:51.586	info	(1229) Disconnect
                            mihome-vacuum.0	2020-09-01 20:49:46.589	debug	(1229) no answer for get_status(id:45) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:41.072	debug	(1229) no answer for get_sound_volume(id:44) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:40.870	debug	(1229) no answer for get_clean_summary(id:43) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:40.668	debug	(1229) no answer for get_consumable(id:42) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:37.255	debug	(1229) no answer for get_sound_volume(id:40) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:37.055	debug	(1229) no answer for get_clean_summary(id:39) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:36.853	debug	(1229) no answer for get_consumable(id:38) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:36.651	debug	(1229) no answer for get_status(id:36) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:26.583	debug	(1229) no answer for get_status(id:35) received, giving up
                            mihome-vacuum.0	2020-09-01 20:49:25.461	debug	(1229) requesting params every: 60 Sec
                            B M 2 Antworten Letzte Antwort
                            • M moviehunter
                              Lebenszeichen: wahr
                              B
                              B
                              blacksheep587
                              schrieb am zuletzt editiert von blacksheep587
                              #1166
                              Hallo Zusammen,
                              ich habe heute versucht den mihome-vacuum adapter zum Laufen zu kriegen, er wird aber nur Gelb und ich bekomme keine Verbindung zum Robi. Token auslesen hat mit der Anleitung soweit geklappt. Anbei mal die Fehlermeldung aus dem Log:
                              mihome-vacuum.0	2020-09-01 20:12:57.820	error	(19455) Cannot send ping: Error: getaddrinfo ENOTFOUND 192.168.178.32
                              mihome-vacuum.0	2020-09-01 20:12:57.817	info	(19455) Disconnect
                              mihome-vacuum.0	2020-09-01 20:12:50.835	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                              mihome-vacuum.0	2020-09-01 20:12:50.829	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                              mihome-vacuum.0	2020-09-01 20:12:45.831	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                              mihome-vacuum.0	2020-09-01 20:12:45.825	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                              mihome-vacuum.0	2020-09-01 20:12:40.828	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                              mihome-vacuum.0	2020-09-01 20:12:40.827	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                              mihome-vacuum.0	2020-09-01 20:12:38.338	info	(19455) set nächster Timer: Nicht verfügbar
                              mihome-vacuum.0	2020-09-01 20:12:37.870	error	(19455) Cannot send ping: Error: getaddrinfo ENOTFOUND 192.168.178.32
                              mihome-vacuum.0	2020-09-01 20:12:37.813	info	(19455) Disconnect
                              mihome-vacuum.0	2020-09-01 20:12:37.776	info	(19455) Cloud control disabled
                              mihome-vacuum.0	2020-09-01 20:12:37.771	info	(19455) Expert mode disabled, states deleted
                              mihome-vacuum.0	2020-09-01 20:12:37.697	info	(19455) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.22.0, js-controller: 3.1.6
                              mihome-vacuum.0	2020-09-01 20:12:37.412	warn	(19455) This object will not be created in future versions. Please report this to the developer.
                              mihome-vacuum.0	2020-09-01 20:12:37.409	warn	(19455) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                              mihome-vacuum.0	2020-09-01 20:12:31.622	info	(19440) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              mihome-vacuum.0	2020-09-01 20:12:31.620	info	(19440) terminating
                              mihome-vacuum.0	2020-09-01 20:12:31.616	info	(19440) Got terminate signal TERMINATE_YOURSELF
                              Habt ihr eine Idee?
                              Danke schon mal.
                              Thomas BraunT D 2 Antworten Letzte Antwort
                              • B blacksheep587
                                Hallo Zusammen,
                                Habt ihr eine Idee?
                                Danke schon mal.
                                Thomas BraunT
                                Thomas BraunT
                                Most Active Developer
                                #1167
                                @blacksheep587 Bitte Konsolentext in CodeTags setzen. Danke.
                                • M moviehunter
                                  Lebenszeichen: wahr
                                  M
                                  M
                                  moviehunter
                                  #1168
                                  Lebenszeichen: wahr
                                  Ist der Adapter für alle Xiaomi Roboter kompatibel?
                                  • K kristina.da
                                    @Meistertr Super - Danke Dir. Gibst einfach kurz Bescheid, wenn ich testen kann/soll/darf.
                                    K
                                    K
                                    kristina.da
                                    #1169
                                    @Meistertr: Ich wollte nett nachfragen, ob du zu den MAP Änderung schon gekommen bist?
                                    Schönen Freitag euch Allen!
                                    Kristina
                                    MeistertrM 1 Antwort Letzte Antwort
                                    • B blacksheep587
                                      Hallo Zusammen,
                                      Habt ihr eine Idee?
                                      Danke schon mal.
                                      D
                                      D
                                      dirkhe
                                      #1170
                                      @blacksheep587 die Fehlermeldung ist doch eindeutig, der Roboter ist vom adapter über die eingegebene ip nicht erreichbar
                                      • K kristina.da
                                        Kristina
                                        MeistertrM
                                        MeistertrM
                                        Meistertr
                                        schrieb am zuletzt editiert von Meistertr
                                        #1171
                                        @kristina-da angefangen. mir ist aber ein anderer Adapter dazwischen gekommen. die migration der neuen valetudo map ist etwas komplexer und erfordert mehr Arbeit als anfangs gedacht.
                                        K 2 Antworten Letzte Antwort
                                        • MeistertrM Meistertr
                                          K
                                          K
                                          kristina.da
                                          #1172
                                          @Meistertr: Okay kein Problem.
                                          84.1k
