  4. [gelöst] HM-Rega Fehler nach Update auf 2.6.18
    6.8k
hm-regabug2.6.18
18 Beiträge 6 Kommentatoren 2.1k Aufrufe 4 Beobachtet
  • afuerhoffA afuerhoff
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Tinker Board S
    Arbeitsspeicher: 2GB
    Festplattenart: HDD
    Betriebssystem: Armbian
    Node-Version: 12.18.3
    Nodejs-Version: 12.18.3
    NPM-Version: 6.14.6
    Installationsart: Manuell
    Image genutzt: Nein
    Ort/Name der Imagedatei:
    Seit dem Update auf Version 2.6.18 habe ich folgende Fehlermeldungen:
    2020-08-23 11:13:26.567 - info: host.tinkerboard iobroker upgrade hm-rega
    2020-08-23 11:13:29.071 - info: host.tinkerboard iobroker Update hm-rega from @2.6.17 to @2.6.18
    2020-08-23 11:13:29.689 - info: host.tinkerboard iobroker NPM version: 6.14.5
    2020-08-23 11:13:29.690 - info: host.tinkerboard iobroker npm install iobroker.hm-rega@2.6.18 --loglevel error --prefix "/opt/iobroker" (System call)
    2020-08-23 11:13:47.818 - info: host.tinkerboard iobroker upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
    2020-08-23 11:13:47.947 - info: host.tinkerboard iobroker Update "system.adapter.hm-rega.0"
    2020-08-23 11:13:47.997 - info: host.tinkerboard stopInstance system.adapter.hm-rega.0 (force=false, process=true)
    2020-08-23 11:13:48.001 - info: host.tinkerboard stopInstance system.adapter.hm-rega.0 send kill signal
    2020-08-23 11:13:48.107 - info: host.tinkerboard iobroker upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
    2020-08-23 11:13:48.169 - info: host.tinkerboard iobroker upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
    2020-08-23 11:13:48.234 - info: host.tinkerboard iobroker upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
    2020-08-23 11:13:48.291 - info: host.tinkerboard iobroker Adapter "hm-rega" updated
    2020-08-23 11:13:48.558 - info: host.tinkerboard instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2020-08-23 11:13:49.306 - info: host.tinkerboard iobroker exit 0
    2020-08-23 11:13:51.346 - info: host.tinkerboard instance system.adapter.hm-rega.0 started with pid 19232
    2020-08-23 11:13:56.760 - error: hm-rega.0 (19232) Cannot parse answer for variables: "40":{"Name":"Alarmmeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Alarmmeldungen","Value":0,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
    "41":{"Name":"Servicemeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Servicemeldungen","Value":0,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""}{,
    "1233":{"Name":"Alarmzone%201","TypeName":"ALARMDP","DPInfo":"Alarmmeldung%20Alarmzone%201","Value":false,"Timestamp":"1970-01-01 01:00:00","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":6,"ValueList":"nicht%20ausgel%F6st%3Bausgel%F6st"},
    Nach Downgrade auf 2.6.17 sind diese wieder verschwunden.
    @afuerhoff
    nodejs -v
    node -v
      Festplattenart: HDD
      NPM-Version: 6.14.6
      Image genutzt: Nein
      haselchenH Offline
      haselchenH Offline
      haselchen
      @afuerhoff
      @Thomas-Braun geht schon in die richtige Richtung, Du hast 2 verschiedene Node Versionen.
      Hab auch 2.6.18 und keine Fehler.
      Wobei das Update mit exit0 ja erfolgreich durchgelaufen ist.
      Hast du HM-RPC auch geupdatet?
        @afuerhoff
        nodejs -v
        node -v
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        @Thomas-Braun
        Schon gesehen. Bin da irgendwie beim Ausfüllen in der Zeile verrutscht. Korrigiere ich gleich
        • haselchenH haselchen
          @afuerhoff
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          @haselchen sagte in HM-Rega Fehler nach Update auf 2.6.18 - Cannot parse answer:
          RPC Version ist 1.14.21.
          Das mit den Node Versionen war ein Eintragungsfehler. Habe ich oben schon korrigiert.
            @afuerhoff node12 würde ich aber dann auch mal auf den letzten Stand bringen.
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              @Thomas-Braun
              Im Info Adapter zeit er mit eine kleinere neue Version an ???
              Node.js
              v12.18.1 (Es gibt eine neuere Version: v12.16.3)
                @Thomas-Braun
                Node.js
                @afuerhoff
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  @afuerhoff
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  schrieb am zuletzt editiert von afuerhoff
                  @Thomas-Braun
                  Hab inzwischen auf 12.18.3 ein update gemacht und die neue Version von HM-Rega geladen.
                  Es hat sich jetzt die Anzahl der Fehler verringert. Es wird nur noch der eine angezeigt. Vorher war es für jede Systemvariable einer.
                  hm-rega.0	2020-08-23 12:58:47.136	error	(7461) Cannot parse answer for variables: "40":{"Name":"Alarmmeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Alarmmeldungen","Value":0,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"Val
                  host.tinkerboard	2020-08-23 12:58:42.369	info	instance system.adapter.hm-rega.0 started with pid 7461
                  host.tinkerboard	2020-08-23 12:58:40.427	info	iobroker exit 0
                  host.tinkerboard	2020-08-23 12:58:39.676	info	instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  host.tinkerboard	2020-08-23 12:58:39.415	info	iobroker Adapter "hm-rega" updated
                  host.tinkerboard	2020-08-23 12:58:39.357	info	iobroker upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                  host.tinkerboard	2020-08-23 12:58:39.299	info	iobroker upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                  host.tinkerboard	2020-08-23 12:58:39.232	info	iobroker upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                  host.tinkerboard	2020-08-23 12:58:39.130	info	stopInstance system.adapter.hm-rega.0 send kill signal
                  host.tinkerboard	2020-08-23 12:58:39.127	info	stopInstance system.adapter.hm-rega.0 (force=false, process=true)
                  host.tinkerboard	2020-08-23 12:58:39.069	info	iobroker Update "system.adapter.hm-rega.0"
                  host.tinkerboard	2020-08-23 12:58:38.981	info	iobroker upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                  Ausgabe der Befehle von oben:
                  /usr/bin/nodejs
                  v12.18.3
                  /usr/bin/node
                  v12.18.3
                  /usr/bin/npm
                  6.14.6
                  nodejs:
                    Installed: 12.18.3-1nodesource1
                    Candidate: 12.18.3-1nodesource1
                    Version table:
                   *** 12.18.3-1nodesource1 500
                          500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                       8.11.1~dfsg-2~bpo9+1 100
                          100 http://httpredir.debian.org/debian stretch-backports/main armhf Packages
                       4.8.2~dfsg-1 500
                          500 http://httpredir.debian.org/debian stretch/main armhf Packages
                  • KnallochseK Offline
                    KnallochseK Offline
                    Knallochse
                    Bei mir werden mit der 2.6.18 keine Systemvariablen mehr aktualisiert.
                    Bin zurück auf 2.6.17 und da war gleich wieder alles i.O.
                    • KnallochseK Knallochse
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      Ich habe bei mir jetzt alle Systemvariablen einmal gelöscht. Mit der 2.6.18 werden sie nicht wieder angelegt. Mit der 2.6.17 waren sie sofort wieder vorhanden.
                        afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        Mit der Version 2.6.19 scheint das Problem gelöst zu sein, Danke an die Entwickler.
                          knopers1
                          schrieb am zuletzt editiert von knopers1
                          Hallo an die Helfer...
                          bei mir schein es nicht zu funktionieren....!
                          ich habe ein Update des hm-rega Adapters vom 2.6.17 auf 2.6.19 gemacht.
                          Seit dem werden die Variablen unter "Objekte" im IObroker" nicht aktualisiert.
                          Auf der Homematic sind die Daten aktuell.
                          Zurück auf die Hm-rega 2.6.17 - läuft das ganze wieder!
                          pi@raspberrypi:~ $ nodejs -v
                          v10.22.0
                          pi@raspberrypi:~ $ node -v
                          v10.22.0
                          pi@raspberrypi:~ $
                          • K knopers1
                            v10.22.0
                            v10.22.0
                            pi@raspberrypi:~ $
                            sigi234S Online
                            sigi234S Online
                            @knopers1
                            Variablen angehackt ?
                            • sigi234S sigi234
                              @knopers1
                              knopers1
                              @sigi234
                              habe soeben wieder die 2.6.19 aufgespielt.
                              Variablen waren angehackt, dafür keine Zeit (bei Dir 30sek) eingetragen. Lief so aber in der V 2.6.17....
                              Jetzt muß ich mal schauen, ob es funktioniert... Meine Wetterstaion sendet die Daten alle 30min.
                              • K knopers1
                                @sigi234
                                knopers1
                                okay.... V2.6.19 funzt nicht....
                                bin wieder bei 2.6.17 und es läuft erneut.
                                • K knopers1
                                  knopers1
                                  nun ist die V.2.6.20 online, hierbei geht es auch nicht mit den Variablen.....
                                  Habe ich nur das Problem?
                                  • K knopers1
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    @knopers1
                                    Am besten neues Thema aufmachen und den Entwickler anschreiben.
