  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.7k Aufrufe 118 Beobachtet
  • F freaktech
    @Thomas-Braun
    wie komm ich von
    pi@ioBroker-RasPi4:~ $
    dort hin?
    was genau eintippen?
    danke
    pi@ioBroker-RasPi4:/opt/iobroker $ npm install canvas --unsafe-perm=true
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/canvas
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@^2.0.0 (node_modules/node-dtls-client/node_modules/node-aead-crypto):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for node-aead-crypto@2.2.0: wanted: {"node":">4 <10"} (current: {"node":"12.18.3","npm":"6.14.6"})
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: node-aead-crypto@2.2.0
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-aead-crypto/package.json'
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /opt/iobroker/node_modules/canvas
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/canvas'
    npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/canvas'] {
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/opt/iobroker/node_modules/canvas'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/iobroker/.npm/_logs/2020-08-15T11_21_54_151Z-debug.log
    #1077
    @freaktech
    pi@raspberrypi:~ $ cd /opt/iobroker/
    pi@raspberrypi:/opt/iobroker $ npm list canvas
    iobroker.inst@2.0.3 /opt/iobroker
    ├── canvas@2.6.1
    ├─┬ iobroker.iot@1.7.0
    │ └── canvas@2.6.1  deduped
    └─┬ iobroker.mihome-vacuum@2.1.1
    F 1 Antwort Letzte Antwort
      @freaktech
      ├── canvas@2.6.1
      freaktech
      #1078
      @Thomas-Braun
      pi@ioBroker-RasPi4:/opt/iobroker $ npm list canvas
      ├── canvas@2.6.1
      ├─┬ iobroker.iot@1.5.3
      └─┬ iobroker.mihome-vacuum@2.2.0
      • F freaktech
        @Thomas-Braun
        ├── canvas@2.6.1
        freaktech
        #1079
        @freaktech ```
        mihome-vacuum.0 2020-08-15 13:28:54.574 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1906,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
        mihome-vacuum.0 2020-08-15 13:28:53.134 debug (7072) sendMsg[1] >>> {"id":97,"method":"get_status"}
        mihome-vacuum.0 2020-08-15 13:28:45.683 debug (7072) system.adapter.admin.0: logging true
        mihome-vacuum.0 2020-08-15 13:28:39.140 debug (7072) Mappointer_updated
        mihome-vacuum.0 2020-08-15 13:28:39.138 debug (7072) Receive <<< {"result":["rubyslite%2F320252511%2F1"],"id":96}
        mihome-vacuum.0 2020-08-15 13:28:39.132 debug (7072) sendMsg[1] >>> {"id":96,"method":"get_map_v1"}
        mihome-vacuum.0 2020-08-15 13:28:39.130 debug (7072) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1597490919126,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597432659531}
        mihome-vacuum.0 2020-08-15 13:28:35.470 debug (7072) Mappointer_updated
        mihome-vacuum.0 2020-08-15 13:28:35.469 debug (7072) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":95}
        mihome-vacuum.0 2020-08-15 13:28:35.463 debug (7072) 1. Mappointer_nomap___retry
        mihome-vacuum.0 2020-08-15 13:28:35.462 debug (7072) sendMsg[1] >>> {"id":95,"method":"get_map_v1"}
        mihome-vacuum.0 2020-08-15 13:28:34.961 debug (7072) Receive <<< {"result":["retry"],"id":94}
        mihome-vacuum.0 2020-08-15 13:28:34.955 debug (7072) 0. Mappointer_nomap___retry
        mihome-vacuum.0 2020-08-15 13:28:34.954 debug (7072) sendMsg[1] >>> {"id":94,"method":"get_map_v1"}
        mihome-vacuum.0 2020-08-15 13:28:34.452 debug (7072) Receive <<< {"result":["retry"],"id":93}
        mihome-vacuum.0 2020-08-15 13:28:34.446 debug (7072) sendMsg[1] >>> {"id":93,"method":"get_map_v1"}
        mihome-vacuum.0 2020-08-15 13:28:34.445 debug (7072) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1597490914442,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597432659531}
        mihome-vacuum.0 2020-08-15 13:28:33.430 debug (7072) Receive <<< {"partner_id":"","id":92,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"
        mihome-vacuum.0 2020-08-15 13:28:33.415 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1905,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
        mihome-vacuum.0 2020-08-15 13:28:33.260 debug (7072) system.adapter.admin.0: logging false
        mihome-vacuum.0 2020-08-15 13:28:33.132 debug (7072) Next WiFi check: 15.08 13:29
        mihome-vacuum.0 2020-08-15 13:28:33.131 debug (7072) sendMsg[1] >>> {"id":92,"method":"miIO.info"}
        mihome-vacuum.0 2020-08-15 13:28:33.130 debug (7072) sendMsg[1] >>> {"id":91,"method":"get_status"}
        mihome-vacuum.0 2020-08-15 13:28:13.136 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1904,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
        mihome-vacuum.0 2020-08-15 13:28:13.128 debug (7072) sendMsg[1] >>> {"id":90,"method":"get_status"}
        mihome-vacuum.0 2020-08-15 13:27:53.135 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1903,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
        mihome-vacuum.0 2020-08-15 13:27:53.126 debug (7072) sendMsg[1] >>> {"id":89,"method":"get_status"}
        mihome-vacuum.0 2020-08-15 13:27:33.133 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1902,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
        mihome-vacuum.0 2020-08-15 13:27:33.131 debug (7072) Receive <<< {"partner_id":"","id":88,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"
        mihome-vacuum.0 2020-08-15 13:27:33.126 debug (7072) Next WiFi check: 15.08 13:28
        mihome-vacuum.0 2020-08-15 13:27:33.125 debug (7072) sendMsg[1] >>> {"id":88,"method":"miIO.info"}
        mihome-vacuum.0 2020-08-15 13:27:33.124 debug (7072) sendMsg[1] >>> {"id":87,"method":"get_status"}
        mihome-vacuum.0 2020-08-15 13:27:15.492 debug (7072) system.adapter.admin.0: logging true
        mihome-vacuum.0 2020-08-15 13:27:13.131 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1901,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
        mihome-vacuum.0 2020-08-15 13:27:13.123 debug (7072) sendMsg[1] >>> {"id":86,"method":"get_status"}
        • F freaktech
          @freaktech ```
          #1080
          @freaktech
          ls -la /opt/iobroker/node_modules/canvas/
            @freaktech
            freaktech
            #1081
            @Thomas-Braun
            pi@ioBroker-RasPi4:/opt/iobroker $ ls -la /opt/iobroker/node_modules/canvas/
            insgesamt 144
            drwxr-xr-x+   8 pi       pi        4096 Aug 13 14:37 .
            drwxrwxrwx+ 816 iobroker iobroker 36864 Aug 14 21:15 ..
            -rw-r--r--+   1 pi       pi        6832 Okt 26  1985 binding.gyp
            -rw-r--r--+   1 pi       pi        1064 Okt 26  1985 browser.js
            drwxr-xr-x+   3 pi       pi        4096 Aug 13 14:37 build
            -rw-r--r--+   1 pi       pi       28011 Okt 26  1985 CHANGELOG.md
            -rw-r--r--+   1 pi       pi        2363 Okt 26  1985 index.js
            drwxr-xr-x+   2 pi       pi        4096 Aug 13 14:37 lib
            drwxr-xr-x+  10 pi       pi        4096 Aug 13 14:37 node_modules
            -rw-r--r--+   1 pi       pi        3210 Aug 13 14:37 package.json
            -rw-r--r--+   1 pi       pi       26514 Okt 26  1985 Readme.md
            drwxr-xr-x+   4 pi       pi        4096 Aug 13 14:37 src
            drwxr-xr-x+   2 pi       pi        4096 Aug 13 14:37 types
            drwxr-xr-x+   2 pi       pi        4096 Aug 13 14:37 util
            • F freaktech
              @Thomas-Braun
              insgesamt 144
              #1082
              @freaktech
              Die Dateien gehören dem falschen User.
              So muss das aussehen:
              pi@raspberrypi:~ $ ls -la /opt/iobroker/node_modules/canvas/
              insgesamt 136
              drwxrwxr-x+   8 iobroker iobroker  4096 Mai  9 14:23 .
              drwxrwxr-x+ 806 iobroker iobroker 28672 Aug 14 09:30 ..
              -rw-rwxr--+   1 iobroker iobroker  6832 Okt 26  1985 binding.gyp
              -rw-rwxr--+   1 iobroker iobroker  1064 Okt 26  1985 browser.js
              drwxrwxr-x+   3 iobroker iobroker  4096 Mai  9 14:23 build
              -rw-rwxr--+   1 iobroker iobroker 28011 Okt 26  1985 CHANGELOG.md
              -rw-rwxr--+   1 iobroker iobroker  2363 Okt 26  1985 index.js
              drwxrwxr-x+   2 iobroker iobroker  4096 Apr 29 18:57 lib
              drwxrwxr-x+   9 iobroker iobroker  4096 Apr 29 18:57 node_modules
              -rw-rwxr--+   1 iobroker iobroker  3154 Apr 29 18:57 package.json
              -rw-rwxr--+   1 iobroker iobroker 26514 Okt 26  1985 Readme.md
              drwxrwxr-x+   4 iobroker iobroker  4096 Apr 29 18:57 src
              drwxrwxr-x+   2 iobroker iobroker  4096 Apr 29 18:57 types
              drwxrwxr-x+   2 iobroker iobroker  4096 Apr 29 18:57 util
              pi@raspberrypi:~ $
                @freaktech
                insgesamt 136
                pi@raspberrypi:~ $
                freaktech
                #1083
                @Thomas-Braun
                das versteh ich leider nicht
                • F freaktech
                  @Thomas-Braun
                  freaktech
                  #1084
                  @freaktech said in Test Adapter mihome-vacuum v2.0.x:
                  @Thomas-Braun
                  wie kommt das und wie kann ich das ändern?
                  • F freaktech
                    @Thomas-Braun
                    #1085
                    @freaktech Das kommt durch den falschen Einsatz von sudo vor dem npm Befehl. Das Modul muss dem User und der Gruppe 'iobroker' gehören.
                      freaktech
                      #1086
                      @Thomas-Braun
                      ja aber wie oben beschrieben bin ich da leider in linux zu schwach
                      • F freaktech
                        @Thomas-Braun
                        #1087
                        @freaktech
                        getfacl /opt/iobroker/node_modules/canvas/package.json
                          @freaktech
                          freaktech
                          #1088
                          @Thomas-Braun said in Test Adapter mihome-vacuum v2.0.x:
                          i@ioBroker-RasPi4:/opt/iobroker $ getfacl /opt/iobroker/node_modules/canvas/package.json
                          getfacl: Entferne führende '/' von absoluten Pfadnamen
                          # file: opt/iobroker/node_modules/canvas/package.json
                          # owner: pi
                          # group: pi
                          user::rw-
                          group::r-x			#effective:r--
                          group:iobroker:rwx		#effective:r--
                          mask::r--
                          other::r--
                          • F freaktech
                            # owner: pi
                            # group: pi
                            user::rw-
                            mask::r--
                            other::r--
                            #1089
                            @freaktech Da liegt die falsche Mask drauf.
                            So sieht das bei mir aus:
                            pi@raspberrypi:~ $ getfacl /opt/iobroker/node_modules/canvas/package.json
                            # owner: iobroker
                            # group: iobroker
                            user::rw-
                            group::r-x
                            group:iobroker:rwx
                            mask::rwx
                            other::r--
                            pi@raspberrypi:~ $
                            Ich muss jetzt aber weg. Lies dich mal in ACL unter Linux ein.
                              # owner: iobroker
                              # group: iobroker
                              user::rw-
                              group::r-x
                              group:iobroker:rwx
                              mask::rwx
                              other::r--
                              pi@raspberrypi:~ $
                              freaktech
                              schrieb am zuletzt editiert von freaktech
                              #1090
                              @Thomas-Braun
                              ok mit dem iobroker fixer sieht es jetzt so aus
                              insgesamt 144
                              drwxrwxr-x+   8 iobroker iobroker  4096 Aug 13 14:37 .
                              drwxrwxr-x+   3 iobroker iobroker  4096 Aug 13 14:37 build
                              drwxrwxr-x+   2 iobroker iobroker  4096 Aug 13 14:37 lib
                              drwxrwxr-x+  10 iobroker iobroker  4096 Aug 13 14:37 node_modules
                              -rw-rwxr--+   1 iobroker iobroker  3210 Aug 13 14:37 package.json
                              drwxrwxr-x+   4 iobroker iobroker  4096 Aug 13 14:37 src
                              drwxrwxr-x+   2 iobroker iobroker  4096 Aug 13 14:37 types
                              drwxrwxr-x+   2 iobroker iobroker  4096 Aug 13 14:37 util
                              pi@ioBroker-RasPi4:/opt/iobroker $ iobroker start
                              close	Zeit
                              mihome-vacuum.0	2020-08-15 14:38:20.038	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2016,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                              mihome-vacuum.0	2020-08-15 14:38:20.030	debug	(6984) sendMsg[1] >>> {"id":41,"method":"get_status"}
                              mihome-vacuum.0	2020-08-15 14:38:01.177	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2015,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                              mihome-vacuum.0	2020-08-15 14:38:00.028	debug	(6984) sendMsg[1] >>> {"id":40,"method":"get_status"}
                              mihome-vacuum.0	2020-08-15 14:37:40.035	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2014,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                              mihome-vacuum.0	2020-08-15 14:37:40.032	debug	(6984) Receive <<< {"partner_id":"","id":39,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"1
                              mihome-vacuum.0	2020-08-15 14:37:40.027	debug	(6984) Next WiFi check: 15.08 14:38
                              mihome-vacuum.0	2020-08-15 14:37:40.026	debug	(6984) sendMsg[1] >>> {"id":39,"method":"miIO.info"}
                              mihome-vacuum.0	2020-08-15 14:37:40.024	debug	(6984) sendMsg[1] >>> {"id":38,"method":"get_status"}
                              mihome-vacuum.0	2020-08-15 14:37:20.030	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2013,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                              mihome-vacuum.0	2020-08-15 14:37:20.022	debug	(6984) sendMsg[1] >>> {"id":37,"method":"get_status"}
                              mihome-vacuum.0	2020-08-15 14:37:00.885	debug	(6984) system.adapter.admin.0: logging true
                              mihome-vacuum.0	2020-08-15 14:36:42.042	debug	(6984) Mappointer_updated
                              mihome-vacuum.0	2020-08-15 14:36:42.041	debug	(6984) Receive <<< {"result":["rubyslite%2F320252511%2F5"],"id":34}
                              mihome-vacuum.0	2020-08-15 14:36:42.033	debug	(6984) sendMsg[1] >>> {"id":34,"method":"get_map_v1"}
                              mihome-vacuum.0	2020-08-15 14:36:40.541	debug	(6984) Receive <<< {"result":[23651,324502500,122,[1597486566,1597478982,1597471813,1597471747,1597442430,1597442077,1597442057,1597441956,1597441792,1597441673,1597441472,1597441343,1597440959,15974
                              mihome-vacuum.0	2020-08-15 14:36:40.533	debug	(6984) sendMsg[1] >>> {"id":33,"method":"get_clean_summary"}
                              mihome-vacuum.0	2020-08-15 14:36:40.042	debug	(6984) Receive <<< {"result":[{"main_brush_work_time":24359,"side_brush_work_time":24359,"filter_work_time":24359,"filter_element_work_time":0,"sensor_dirty_time":23651}],"id":32}
                              mihome-vacuum.0	2020-08-15 14:36:40.031	debug	(6984) sendMsg[1] >>> {"id":32,"method":"get_consumable"}
                              mihome-vacuum.0	2020-08-15 14:36:40.029	info	(6984) create states for water box filter
                              mihome-vacuum.0	2020-08-15 14:36:40.028	info	(6984) create states for water box
                              mihome-vacuum.0	2020-08-15 14:36:40.026	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2011,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                              mihome-vacuum.0	2020-08-15 14:36:40.018	debug	(6984) sendMsg[1] >>> {"id":31,"method":"get_status"}
                              mihome-vacuum.0	2020-08-15 14:36:36.902	debug	(6984) Mappointer_updated
                              mihome-vacuum.0	2020-08-15 14:36:36.901	debug	(6984) Receive <<< {"result":["rubyslite%2F320252511%2F4"],"id":30}
                              mihome-vacuum.0	2020-08-15 14:36:36.890	debug	(6984) sendMsg[1] >>> {"id":30,"method":"get_map_v1"}
                              mihome-vacuum.0	2020-08-15 14:36:36.888	debug	(6984) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1597494996878,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597432659531}
                              mihome-vacuum.0	2020-08-15 14:36:25.160	debug	(6984) CLEAN_LOGGING[{"Datum":"15.8","Start":"12:16","Saugzeit":"8 min","Fläche":"5.24 m²","Error":0,"Ende":true},{"Datum":"15.8","Start":"10:09","Saugzeit":"9 min","Fläche":"8.19 m²","Error":0,"Ende
                              mihome-vacuum.0	2020-08-15 14:36:24.964	debug	(6984) Receive <<< {"result":[[1597435574,1597435596,22,0,0,0,2,3,60]],"id":29}
                              mihome-vacuum.0	2020-08-15 14:36:24.958	debug	(6984) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1597435574]}
                              mihome-vacuum.0	2020-08-15 14:36:24.763	debug	(6984) Receive <<< {"result":[[1597435610,1597435624,14,0,0,0,2,3,60]],"id":28}
                              mihome-vacuum.0	2020-08-15 14:36:24.756	debug	(6984) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1597435610]}
                              mihome-vacuum.0	2020-08-15 14:36:24.561	debug	(6984) Receive <<< {"result":[[1597435636,1597435656,20,0,0,0,2,3,60]],"id":27}
                              mihome-vacuum.0	2020-08-15 14:36:24.554	debug	(6984) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1597435636]}
                              mihome-vacuum.0	2020-08-15 14:36:24.358	debug	(6984) Receive <<< {"result":[[1597436334,1597436350,16,140000,0,0,2,1,60]],"id":26}
                              mihome-vacuum.0	2020-08-15 14:36:24.351	debug	(6984) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1597436334]}
                              mihome-vacuum.0	2020-08-15 14:36:24.183	debug	(6984) Receive <<< {"result":[[1597440532,1597440545,13,0,0,0,2,3,60]],"id":25}
                              mihome-vacuum.0	2020-08-15 14:36:24.148	debug	(6984) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1597440532]}
                              mihome-vacuum.0	2020-08-15 14:36:23.953	debug	(6984) Receive <<< {"result":[[1597440550,1597440556,6,0,0,0,2,3,60]],"id":24}
                              mihome-vacuum.0	2020-08-15 14:36:23.947	debug	(6984) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1597440550]}
                              mihome-vacuum.0	2020-08-15 14:36:23.752	debug	(6984) Receive <<< {"result":[[1597440787,1597440812,25,465000,0,0,2,3,60]],"id":23}
                              mihome-vacuum.0	2020-08-15 14:36:23.746	debug	(6984) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1597440787]}
                              mihome-vacuum.0	2020-08-15 14:36:23.550	debug	(6984) Receive <<< {"result":[[1597440959,1597440974,15,0,0,0,2,3,60]],"id":22}
                              mihome-vacuum.0	2020-08-15 14:36:23.544	debug	(6984) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1597440959]}
                              mihome-vacuum.0	2020-08-15 14:36:23.349	debug	(6984) Receive <<< {"result":[[1597441343,1597441359,16,0,0,0,2,3,60]],"id":21}
                              mihome-vacuum.0	2020-08-15 14:36:23.343	debug	(6984) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1597441343]}
                              mihome-vacuum.0	2020-08-15 14:36:23.148	debug	(6984) Receive <<< {"result":[[1597441472,1597441672,13,0,0,0,2,3,60]],"id":20}
                              mihome-vacuum.0	2020-08-15 14:36:23.140	debug	(6984) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1597441472]}
                              mihome-vacuum.0	2020-08-15 14:36:23.136	debug	(6984) Xiaomi Cloud: Login successful
                              mihome-vacuum.0	2020-08-15 14:36:22.934	debug	(6984) Receive <<< {"result":[[1597441673,1597441687,14,0,0,0,2,3,60]],"id":19}
                              mihome-vacuum.0	2020-08-15 14:36:22.927	debug	(6984) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1597441673]}
                              mihome-vacuum.0	2020-08-15 14:36:22.648	debug	(6984) Receive <<< {"result":[[1597441792,1597441955,13,0,0,0,2,3,60]],"id":18}
                              mihome-vacuum.0	2020-08-15 14:36:22.632	debug	(6984) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1597441792]}
                              mihome-vacuum.0	2020-08-15 14:36:22.437	debug	(6984) Receive <<< {"result":[[1597441956,1597441969,13,140000,0,0,2,3,60]],"id":17}
                              mihome-vacuum.0	2020-08-15 14:36:22.430	debug	(6984) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1597441956]}
                              mihome-vacuum.0	2020-08-15 14:36:22.235	debug	(6984) Receive <<< {"result":[[1597442057,1597442076,13,0,0,0,2,3,60]],"id":16}
                              mihome-vacuum.0	2020-08-15 14:36:22.228	debug	(6984) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1597442057]}
                              mihome-vacuum.0	2020-08-15 14:36:22.033	debug	(6984) Receive <<< {"result":[[1597442077,1597442083,6,0,0,0,2,3,60]],"id":15}
                              mihome-vacuum.0	2020-08-15 14:36:22.026	debug	(6984) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1597442077]}
                              mihome-vacuum.0	2020-08-15 14:36:21.911	debug	(6984) Mappointer_updated
                              mihome-vacuum.0	2020-08-15 14:36:21.910	debug	(6984) Receive <<< {"result":["rubyslite%2F320252511%2F3"],"id":14}
                              mihome-vacuum.0	2020-08-15 14:36:21.904	debug	(6984) 0. Mappointer_nomap___retry
                              mihome-vacuum.0	2020-08-15 14:36:21.904	debug	(6984) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
                              mihome-vacuum.0	2020-08-15 14:36:21.831	debug	(6984) Receive <<< {"result":[[1597442430,1597442445,15,0,0,0,2,3,60]],"id":13}
                              mihome-vacuum.0	2020-08-15 14:36:21.824	debug	(6984) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1597442430]}
                              mihome-vacuum.0	2020-08-15 14:36:21.637	debug	(6984) Receive <<< {"result":[[1597471747,1597471761,14,122500,0,0,2,1,60]],"id":12}
                              mihome-vacuum.0	2020-08-15 14:36:21.622	debug	(6984) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1597471747]}
                              mihome-vacuum.0	2020-08-15 14:36:21.418	debug	(6984) Receive <<< {"result":[[1597471813,1597471826,13,140000,0,0,2,1,60]],"id":11}
                              mihome-vacuum.0	2020-08-15 14:36:21.411	debug	(6984) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1597471813]}
                              mihome-vacuum.0	2020-08-15 14:36:21.401	debug	(6984) Receive <<< {"result":["retry"],"id":10}
                              mihome-vacuum.0	2020-08-15 14:36:21.395	debug	(6984) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
                              mihome-vacuum.0	2020-08-15 14:36:21.220	debug	(6984) Receive <<< {"result":[[1597478982,1597479687,533,8185000,0,1,2,3,56]],"id":9}
                              mihome-vacuum.0	2020-08-15 14:36:21.208	debug	(6984) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1597478982]}
                              mihome-vacuum.0	2020-08-15 14:36:21.205	debug	(6984) Receive <<< {"result":[[16,"320001013943"],[17,"320001013946"],[18,"320001013989"],[19,"320001013938"],[20,"320001013934"],[21,"320001013937"],[22,"320001013942"],[23,"320001013990"]],"id":8}
                              mihome-vacuum.0	2020-08-15 14:36:21.203	info	(6984) create state for carpet_mode
                              mihome-vacuum.0	2020-08-15 14:36:21.202	debug	(6984) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
                              mihome-vacuum.0	2020-08-15 14:36:21.195	debug	(6984) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
                              mihome-vacuum.0	2020-08-15 14:36:21.194	debug	(6984) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
                              mihome-vacuum.0	2020-08-15 14:36:21.011	debug	(6984) Receive <<< {"result":[[1597486566,1597487061,495,5242500,0,1,2,3,56]],"id":6}
                              mihome-vacuum.0	2020-08-15 14:36:21.005	debug	(6984) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1597486566]}
                              mihome-vacuum.0	2020-08-15 14:36:21.002	debug	(6984) Receive <<< {"result":[23651,324502500,122,[1597486566,1597478982,1597471813,1597471747,1597442430,1597442077,1597442057,1597441956,1597441792,1597441673,1597441472,1597441343,1597440959,15974
                              mihome-vacuum.0	2020-08-15 14:36:20.994	debug	(6984) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
                              mihome-vacuum.0	2020-08-15 14:36:20.800	debug	(6984) Receive <<< {"result":[{"main_brush_work_time":24359,"side_brush_work_time":24359,"filter_work_time":24359,"filter_element_work_time":0,"sensor_dirty_time":23651}],"id":4}
                              mihome-vacuum.0	2020-08-15 14:36:20.794	debug	(6984) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
                              mihome-vacuum.0	2020-08-15 14:36:20.611	info	(6984) set nächster Timer: Nicht verfügbar
                              mihome-vacuum.0	2020-08-15 14:36:20.600	debug	(6984) Receive <<< {"result":[78],"id":3}
                              mihome-vacuum.0	2020-08-15 14:36:20.594	debug	(6984) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
                              mihome-vacuum.0	2020-08-15 14:36:20.402	debug	(6984) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"1
                              mihome-vacuum.0	2020-08-15 14:36:20.397	debug	(6984) Next WiFi check: 15.08 14:37
                              mihome-vacuum.0	2020-08-15 14:36:20.395	debug	(6984) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
                              mihome-vacuum.0	2020-08-15 14:36:20.192	info	(6984) Connected
                              mihome-vacuum.0	2020-08-15 14:36:20.178	debug	(6984) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                              mihome-vacuum.0	2020-08-15 14:36:20.175	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2010,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                              mihome-vacuum.0	2020-08-15 14:36:20.163	debug	(6984) sendMsg[1] >>> {"id":1,"method":"get_status"}
                              mihome-vacuum.0	2020-08-15 14:36:20.122	debug	(6984) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                              mihome-vacuum.0	2020-08-15 14:36:20.120	info	(6984) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-08-15 14:36:20.118	debug	(6984) Receive <<< Helo <<< 21310020000000001316aa5f5f37d6c4ffffffffffffffffffffffffffffffff
                              mihome-vacuum.0	2020-08-15 14:36:20.108	info	(6984) New generation or new fw(3.5.8,0876) detected, create new states goto and zoneclean
                              mihome-vacuum.0	2020-08-15 14:36:20.096	debug	(6984) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                              mihome-vacuum.0	2020-08-15 14:36:20.027	debug	(6984) server started on 0.0.0.0:53421
                              mihome-vacuum.0	2020-08-15 14:36:20.003	info	(6984) Cloud control disabled
                              mihome-vacuum.0	2020-08-15 14:36:20.000	info	(6984) Expert mode disabled, states deleted
                              mihome-vacuum.0	2020-08-15 14:36:19.982	debug	(6984) Xiaomi Cloud: Logging in
                              mihome-vacuum.0	2020-08-15 14:36:19.975	debug	(6984) load Map creator... false
                              mihome-vacuum.0	2020-08-15 14:36:19.847	info	(6984) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
                              mihome-vacuum.0	2020-08-15 14:36:18.546	debug	(6984) statesDB connected
                              mihome-vacuum.0	2020-08-15 14:36:18.545	debug	(6984) States connected to redis: 127.0.0.1:9000
                              mihome-vacuum.0	2020-08-15 14:36:18.513	debug	(6984) States create System PubSub Client
                              mihome-vacuum.0	2020-08-15 14:36:18.509	debug	(6984) States create User PubSub Client
                              mihome-vacuum.0	2020-08-15 14:36:18.493	debug	(6984) Redis States: Use Redis connection: 127.0.0.1:9000
                              mihome-vacuum.0	2020-08-15 14:36:18.490	debug	(6984) objectDB connected
                              mihome-vacuum.0	2020-08-15 14:36:18.481	debug	(6984) Objects connected to redis: 127.0.0.1:9001
                              mihome-vacuum.0	2020-08-15 14:36:18.420	debug	(6984) Objects client initialize lua scripts
                              mihome-vacuum.0	2020-08-15 14:36:18.419	debug	(6984) Objects create User PubSub Client
                              mihome-vacuum.0	2020-08-15 14:36:18.416	debug	(6984) Objects create System PubSub Client
                              mihome-vacuum.0	2020-08-15 14:36:18.362	debug	(6984) Objects client ready ... initialize now
                              mihome-vacuum.0	2020-08-15 14:36:17.369	debug
                              der MAPS link ist weiterhin leer
                              • R Rushmed
                                @dirkhe Klaro!
                                Karte in der Xiaomi App gewechselt und Räume über DP neu geladen.
                                mihome-vacuum.0	2020-08-14 23:55:37.936	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4261,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                                mihome-vacuum.0	2020-08-14 23:55:37.886	debug	(8589) sendMsg[1] >>> {"id":53,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:55:17.966	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4260,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                                mihome-vacuum.0	2020-08-14 23:55:17.885	debug	(8589) sendMsg[1] >>> {"id":52,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:54:58.004	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4259,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                                mihome-vacuum.0	2020-08-14 23:54:58.002	debug	(8589) Receive <<< {"partner_id":"","id":51,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
                                mihome-vacuum.0	2020-08-14 23:54:57.883	debug	(8589) Next WiFi check: 14.08 23:55
                                mihome-vacuum.0	2020-08-14 23:54:57.883	debug	(8589) sendMsg[1] >>> {"id":51,"method":"miIO.info"}
                                mihome-vacuum.0	2020-08-14 23:54:57.882	debug	(8589) sendMsg[1] >>> {"id":50,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:54:37.927	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4258,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                                mihome-vacuum.0	2020-08-14 23:54:37.877	debug	(8589) sendMsg[1] >>> {"id":49,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:54:17.959	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4257,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                                mihome-vacuum.0	2020-08-14 23:54:17.875	debug	(8589) sendMsg[1] >>> {"id":48,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:53:57.993	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4256,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                                mihome-vacuum.0	2020-08-14 23:53:57.989	debug	(8589) Receive <<< {"partner_id":"","id":47,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
                                mihome-vacuum.0	2020-08-14 23:53:57.874	debug	(8589) Next WiFi check: 14.08 23:54
                                mihome-vacuum.0	2020-08-14 23:53:57.873	debug	(8589) sendMsg[1] >>> {"id":47,"method":"miIO.info"}
                                mihome-vacuum.0	2020-08-14 23:53:57.872	debug	(8589) sendMsg[1] >>> {"id":46,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:53:37.921	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4245,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                                mihome-vacuum.0	2020-08-14 23:53:37.869	debug	(8589) sendMsg[1] >>> {"id":45,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:53:17.955	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4235,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                                mihome-vacuum.0	2020-08-14 23:53:17.867	debug	(8589) sendMsg[1] >>> {"id":44,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:53:16.841	debug	(8589) system.adapter.admin.0: logging true
                                mihome-vacuum.0	2020-08-14 23:52:58.455	debug	(8589) system.adapter.admin.0: logging false
                                mihome-vacuum.0	2020-08-14 23:52:57.886	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4224,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                                mihome-vacuum.0	2020-08-14 23:52:57.882	debug	(8589) Receive <<< {"partner_id":"","id":43,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"local
                                mihome-vacuum.0	2020-08-14 23:52:57.866	debug	(8589) Next WiFi check: 14.08 23:53
                                mihome-vacuum.0	2020-08-14 23:52:57.865	debug	(8589) sendMsg[1] >>> {"id":43,"method":"miIO.info"}
                                mihome-vacuum.0	2020-08-14 23:52:57.864	debug	(8589) sendMsg[1] >>> {"id":42,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:52:53.977	info	(8589) room: 275001013628 not mapped
                                mihome-vacuum.0	2020-08-14 23:52:53.976	info	(8589) room: 275001013648 not mapped
                                mihome-vacuum.0	2020-08-14 23:52:53.971	info	(8589) room: 275001013621 not mapped
                                mihome-vacuum.0	2020-08-14 23:52:53.968	info	(8589) room: 275001013646 mapped with index undefined
                                mihome-vacuum.0	2020-08-14 23:52:53.965	info	(8589) room: 275001013645 mapped with index undefined
                                mihome-vacuum.0	2020-08-14 23:52:53.961	info	(8589) room: 275001013642 mapped with index undefined
                                mihome-vacuum.0	2020-08-14 23:52:53.959	info	(8589) room: 275001013641 mapped with index undefined
                                mihome-vacuum.0	2020-08-14 23:52:53.955	info	(8589) room: 275001013647 mapped with index undefined
                                mihome-vacuum.0	2020-08-14 23:52:53.887	debug	(8589) Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":41}
                                mihome-vacuum.0	2020-08-14 23:52:53.762	debug	(8589) sendMsg[1] >>> {"id":41,"method":"get_room_mapping"}
                                mihome-vacuum.0	2020-08-14 23:52:53.760	debug	(8589) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597441973751,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
                                mihome-vacuum.0	2020-08-14 23:52:37.873	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4212,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                                mihome-vacuum.0	2020-08-14 23:52:37.861	debug	(8589) sendMsg[1] >>> {"id":40,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:52:17.946	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4200,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                                mihome-vacuum.0	2020-08-14 23:52:17.860	debug	(8589) sendMsg[1] >>> {"id":39,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:51:57.980	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4199,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                                mihome-vacuum.0	2020-08-14 23:51:57.979	debug	(8589) Receive <<< {"partner_id":"","id":38,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"local
                                mihome-vacuum.0	2020-08-14 23:51:57.859	debug	(8589) Next WiFi check: 14.08 23:52
                                mihome-vacuum.0	2020-08-14 23:51:57.858	debug	(8589) sendMsg[1] >>> {"id":38,"method":"miIO.info"}
                                mihome-vacuum.0	2020-08-14 23:51:57.857	debug	(8589) sendMsg[1] >>> {"id":37,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:51:37.912	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4198,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                                mihome-vacuum.0	2020-08-14 23:51:37.855	debug	(8589) sendMsg[1] >>> {"id":36,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:51:17.940	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4197,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                                mihome-vacuum.0	2020-08-14 23:51:17.854	debug	(8589) sendMsg[1] >>> {"id":35,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:51:00.016	debug	(8589) Mappointer_updated
                                mihome-vacuum.0	2020-08-14 23:51:00.015	debug	(8589) Receive <<< {"result":["roboroommap%2F321636546%2F1"],"id":34}
                                mihome-vacuum.0	2020-08-14 23:50:59.979	debug	(8589) sendMsg[1] >>> {"id":34,"method":"get_map_v1"}
                                mihome-vacuum.0	2020-08-14 23:50:58.588	debug	(8589) Receive <<< {"result":[10854,145977500,26,[1597438510,1597437891,1597437765,1597437590,1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,159732
                                mihome-vacuum.0	2020-08-14 23:50:58.479	debug	(8589) sendMsg[1] >>> {"id":33,"method":"get_clean_summary"}
                                mihome-vacuum.0	2020-08-14 23:50:57.985	debug	(8589) Receive <<< {"result":[{"main_brush_work_time":10854,"side_brush_work_time":10854,"filter_work_time":10854,"filter_element_work_time":7737,"sensor_dirty_time":10854}],"id":32}
                                mihome-vacuum.0	2020-08-14 23:50:57.977	debug	(8589) sendMsg[1] >>> {"id":32,"method":"get_consumable"}
                                mihome-vacuum.0	2020-08-14 23:50:57.975	info	(8589) create states for water box filter
                                mihome-vacuum.0	2020-08-14 23:50:57.973	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4196,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                                mihome-vacuum.0	2020-08-14 23:50:57.852	debug	(8589) sendMsg[1] >>> {"id":31,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:50:42.847	debug	(8589) CLEAN_LOGGING[{"Datum":"14.8","Start":"22:55","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"14.8","Start":"22:44","Saugzeit":"1 min","Fläche":"1.52 m²","Error":0,"Ende":
                                mihome-vacuum.0	2020-08-14 23:50:42.653	debug	(8589) Receive <<< {"result":[[1597268211,1597268217,6,0,0,0,2,1,60]],"id":30}
                                mihome-vacuum.0	2020-08-14 23:50:42.646	debug	(8589) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1597268211]}
                                mihome-vacuum.0	2020-08-14 23:50:42.453	debug	(8589) Receive <<< {"result":[[1597294395,1597296293,1898,32012500,0,1,5,1,52]],"id":29}
                                mihome-vacuum.0	2020-08-14 23:50:42.445	debug	(8589) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1597294395]}
                                mihome-vacuum.0	2020-08-14 23:50:42.252	debug	(8589) Receive <<< {"result":[[1597319289,1597319912,605,7660000,0,1,5,1,52]],"id":28}
                                mihome-vacuum.0	2020-08-14 23:50:42.243	debug	(8589) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1597319289]}
                                mihome-vacuum.0	2020-08-14 23:50:42.049	debug	(8589) Receive <<< {"result":[[1597320739,1597320899,15,220000,0,0,1,1,43]],"id":27}
                                mihome-vacuum.0	2020-08-14 23:50:42.040	debug	(8589) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1597320739]}
                                mihome-vacuum.0	2020-08-14 23:50:41.846	debug	(8589) Receive <<< {"result":[[1597320922,1597320988,23,0,0,0,2,2,61]],"id":26}
                                mihome-vacuum.0	2020-08-14 23:50:41.837	debug	(8589) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1597320922]}
                                mihome-vacuum.0	2020-08-14 23:50:41.643	debug	(8589) Receive <<< {"result":[[1597321049,1597321413,346,3345000,0,1,2,1,52]],"id":25}
                                mihome-vacuum.0	2020-08-14 23:50:41.634	debug	(8589) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1597321049]}
                                mihome-vacuum.0	2020-08-14 23:50:41.444	debug	(8589) Receive <<< {"result":[[1597321488,1597321547,59,1775000,0,0,1,1,43]],"id":24}
                                mihome-vacuum.0	2020-08-14 23:50:41.432	debug	(8589) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1597321488]}
                                mihome-vacuum.0	2020-08-14 23:50:41.239	debug	(8589) Receive <<< {"result":[[1597321619,1597322479,844,7545000,0,1,2,1,52]],"id":23}
                                mihome-vacuum.0	2020-08-14 23:50:41.230	debug	(8589) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1597321619]}
                                mihome-vacuum.0	2020-08-14 23:50:41.036	debug	(8589) Receive <<< {"result":[[1597322633,1597325189,2556,33375000,0,1,2,1,52]],"id":22}
                                mihome-vacuum.0	2020-08-14 23:50:41.028	debug	(8589) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1597322633]}
                                mihome-vacuum.0	2020-08-14 23:50:40.835	debug	(8589) Receive <<< {"result":[[1597326675,1597328878,2203,31472500,0,1,1,1,52]],"id":21}
                                mihome-vacuum.0	2020-08-14 23:50:40.826	debug	(8589) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1597326675]}
                                mihome-vacuum.0	2020-08-14 23:50:40.633	debug	(8589) Receive <<< {"result":[[1597331343,1597331356,13,0,0,0,5,1,60]],"id":20}
                                mihome-vacuum.0	2020-08-14 23:50:40.625	debug	(8589) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1597331343]}
                                mihome-vacuum.0	2020-08-14 23:50:40.430	debug	(8589) Receive <<< {"result":[[1597332841,1597332874,33,482500,0,0,5,1,60]],"id":19}
                                mihome-vacuum.0	2020-08-14 23:50:40.421	debug	(8589) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1597332841]}
                                mihome-vacuum.0	2020-08-14 23:50:40.370	warn	(8589) HTTP error when getting token cookie
                                mihome-vacuum.0	2020-08-14 23:50:40.369	error	(8589) HTTP error when getting token cookie{}
                                mihome-vacuum.0	2020-08-14 23:50:40.225	debug	(8589) Receive <<< {"result":[[1597344916,1597344932,16,0,0,0,5,1,60]],"id":18}
                                mihome-vacuum.0	2020-08-14 23:50:40.220	debug	(8589) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1597344916]}
                                mihome-vacuum.0	2020-08-14 23:50:40.216	debug	(8589) Mappointer_updated
                                mihome-vacuum.0	2020-08-14 23:50:40.215	debug	(8589) Receive <<< {"result":["roboroommap%2F321636546%2F0"],"id":17}
                                mihome-vacuum.0	2020-08-14 23:50:40.208	debug	(8589) 1. Mappointer_nomap___retry
                                mihome-vacuum.0	2020-08-14 23:50:40.207	debug	(8589) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
                                mihome-vacuum.0	2020-08-14 23:50:40.027	debug	(8589) Receive <<< {"result":[[1597411995,1597412226,231,5247500,0,1,2,3,56]],"id":16}
                                mihome-vacuum.0	2020-08-14 23:50:40.018	debug	(8589) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1597411995]}
                                mihome-vacuum.0	2020-08-14 23:50:39.829	debug	(8589) Receive <<< {"result":[[1597414047,1597415374,1327,9362500,0,1,2,3,56]],"id":15}
                                mihome-vacuum.0	2020-08-14 23:50:39.817	debug	(8589) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1597414047]}
                                mihome-vacuum.0	2020-08-14 23:50:39.705	debug	(8589) Receive <<< {"result":["retry"],"id":14}
                                mihome-vacuum.0	2020-08-14 23:50:39.700	debug	(8589) 0. Mappointer_nomap___retry
                                mihome-vacuum.0	2020-08-14 23:50:39.699	debug	(8589) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
                                mihome-vacuum.0	2020-08-14 23:50:39.624	debug	(8589) Receive <<< {"result":[[1597423082,1597423092,10,0,0,0,2,2,61]],"id":13}
                                mihome-vacuum.0	2020-08-14 23:50:39.616	debug	(8589) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1597423082]}
                                mihome-vacuum.0	2020-08-14 23:50:39.423	debug	(8589) Receive <<< {"result":[[1597437590,1597437762,70,970000,0,0,2,3,60]],"id":12}
                                mihome-vacuum.0	2020-08-14 23:50:39.415	debug	(8589) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1597437590]}
                                mihome-vacuum.0	2020-08-14 23:50:39.218	debug	(8589) Receive <<< {"result":[[1597437765,1597437801,36,470000,0,0,2,3,60]],"id":11}
                                mihome-vacuum.0	2020-08-14 23:50:39.213	debug	(8589) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1597437765]}
                                mihome-vacuum.0	2020-08-14 23:50:39.196	debug	(8589) Receive <<< {"result":["retry"],"id":10}
                                mihome-vacuum.0	2020-08-14 23:50:39.191	debug	(8589) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
                                mihome-vacuum.0	2020-08-14 23:50:39.021	debug	(8589) Receive <<< {"result":[[1597437891,1597437942,51,1522500,0,0,2,3,60]],"id":9}
                                mihome-vacuum.0	2020-08-14 23:50:39.010	debug	(8589) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1597437891]}
                                mihome-vacuum.0	2020-08-14 23:50:39.004	debug	(8589) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":8}
                                mihome-vacuum.0	2020-08-14 23:50:39.003	info	(8589) create state for carpet_mode
                                mihome-vacuum.0	2020-08-14 23:50:39.001	debug	(8589) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
                                mihome-vacuum.0	2020-08-14 23:50:38.992	debug	(8589) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
                                mihome-vacuum.0	2020-08-14 23:50:38.991	debug	(8589) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
                                mihome-vacuum.0	2020-08-14 23:50:38.815	debug	(8589) Receive <<< {"result":[[1597438510,1597438518,8,0,0,0,2,3,60]],"id":6}
                                mihome-vacuum.0	2020-08-14 23:50:38.808	debug	(8589) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1597438510]}
                                mihome-vacuum.0	2020-08-14 23:50:38.802	debug	(8589) Receive <<< {"result":[10854,145977500,26,[1597438510,1597437891,1597437765,1597437590,1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,159732
                                mihome-vacuum.0	2020-08-14 23:50:38.792	debug	(8589) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
                                mihome-vacuum.0	2020-08-14 23:50:38.601	debug	(8589) Receive <<< {"result":[{"main_brush_work_time":10854,"side_brush_work_time":10854,"filter_work_time":10854,"filter_element_work_time":7737,"sensor_dirty_time":10854}],"id":4}
                                mihome-vacuum.0	2020-08-14 23:50:38.591	debug	(8589) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
                                mihome-vacuum.0	2020-08-14 23:50:38.404	debug	(8589) Receive <<< {"result":[90],"id":3}
                                mihome-vacuum.0	2020-08-14 23:50:38.393	debug	(8589) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
                                mihome-vacuum.0	2020-08-14 23:50:38.391	info	(8589) set nächster Timer: Nicht verfügbar
                                mihome-vacuum.0	2020-08-14 23:50:38.198	debug	(8589) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
                                mihome-vacuum.0	2020-08-14 23:50:38.194	debug	(8589) Next WiFi check: 14.08 23:51
                                mihome-vacuum.0	2020-08-14 23:50:38.192	debug	(8589) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
                                mihome-vacuum.0	2020-08-14 23:50:37.989	info	(8589) Connected
                                mihome-vacuum.0	2020-08-14 23:50:37.986	debug	(8589) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                mihome-vacuum.0	2020-08-14 23:50:37.983	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4195,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                                mihome-vacuum.0	2020-08-14 23:50:37.972	debug	(8589) sendMsg[1] >>> {"id":1,"method":"get_status"}
                                mihome-vacuum.0	2020-08-14 23:50:37.940	debug	(8589) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                mihome-vacuum.0	2020-08-14 23:50:37.939	info	(8589) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-08-14 23:50:37.937	debug	(8589) Receive <<< Helo <<< 2131002000000000132bc8c25f37072dffffffffffffffffffffffffffffffff
                                mihome-vacuum.0	2020-08-14 23:50:37.930	info	(8589) New generation or new fw(3.5.8,4436) detected, create new states goto and zoneclean
                                mihome-vacuum.0	2020-08-14 23:50:37.916	debug	(8589) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                mihome-vacuum.0	2020-08-14 23:50:37.857	debug	(8589) server started on 0.0.0.0:53421
                                mihome-vacuum.0	2020-08-14 23:50:37.842	info	(8589) Create state clean_home for controlling by cloud adapter
                                mihome-vacuum.0	2020-08-14 23:50:37.840	info	(8589) Expert mode disabled, states deleted
                                mihome-vacuum.0	2020-08-14 23:50:37.831	debug	(8589) Xiaomi Cloud: Logging in
                                mihome-vacuum.0	2020-08-14 23:50:37.828	debug	(8589) load Map creator... true
                                mihome-vacuum.0	2020-08-14 23:50:37.730	info	(8589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
                                mihome-vacuum.0	2020-08-14 23:50:36.347	debug	(8589) statesDB connected
                                mihome-vacuum.0	2020-08-14 23:50:36.346	debug	(8589) States connected to redis: 127.0.0.1:9000
                                mihome-vacuum.0	2020-08-14 23:50:36.311	debug	(8589) States create System PubSub Client
                                mihome-vacuum.0	2020-08-14 23:50:36.308	debug	(8589) States create User PubSub Client
                                mihome-vacuum.0	2020-08-14 23:50:36.296	debug	(8589) Redis States: Use Redis connection: 127.0.0.1:9000
                                mihome-vacuum.0	2020-08-14 23:50:36.294	debug	(8589) objectDB connected
                                mihome-vacuum.0	2020-08-14 23:50:36.287	debug	(8589) Objects connected to redis: 127.0.0.1:9001
                                mihome-vacuum.0	2020-08-14 23:50:36.262	debug	(8589) Objects client initialize lua scripts
                                mihome-vacuum.0	2020-08-14 23:50:36.261	debug	(8589) Objects create User PubSub Client
                                mihome-vacuum.0	2020-08-14 23:50:36.260	debug	(8589) Objects create System PubSub Client
                                mihome-vacuum.0	2020-08-14 23:50:36.256	debug	(8589) Objects client ready ... initialize now
                                mihome-vacuum.0	2020-08-14 23:50:36.216	debug	(8589) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                mihome-vacuum.0	2020-08-14 23:50:31.904	info	(12559) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                mihome-vacuum.0	2020-08-14 23:50:31.903	info	(12559) terminating
                                mihome-vacuum.0	2020-08-14 23:50:31.900	info	(12559) Got terminate signal TERMINATE_YOURSELF
                                Die Datenpunkte "roomClean" und "state" werden bei Kartenwechsel jeweils neu angelegt und in den ordner "mapIndex" verschoben. Das macht mir erstens den gezielten Raumzugriff unmöglich und eliminiert zweitens meine IOT smart Devices.
                                dirkhe
                                #1091
                                @Rushmed die Räume werden falsch angelegt.Der interessante logeintrag ist
                                Kannst du mir den nochmal senden, wenn du jetzt auch die andere Karte umschaltet? Oder da das Log noch mal. Dann versuche ich da mal was zu basteln, dass die Räume bleiben. Ich habe jetzt immer alle automatisch angelegten Räume gesandt, sprich nicht mehr vorhandene gelöscht und due anderen neu angelegt. Als Workaround könntest du die Räume manuell anlegen, die lässt er in Ruhe
                                R 1 Antwort Letzte Antwort
                                • F Offline
                                  freaktech
                                  #1092
                                  so ich komm leider nicht weiter
                                  hier auch mal ein Log wenn er reinigt
                                  	2020-08-16 01:53:34.685	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:34.684	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F9"],"id":2360}
                                  mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) update_Map need new mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) sendMsg[1] >>> {"id":2360,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:33.672	debug	(2779) Receive <<< {"result":["ok"],"id":2359}
                                  mihome-vacuum.0	2020-08-16 01:53:33.666	debug	(2779) sendMsg[1] >>> {"id":2359,"method":"app_charge"}
                                  mihome-vacuum.0	2020-08-16 01:53:33.663	debug	(2779) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1597535613659,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1597432361481}
                                  mihome-vacuum.0	2020-08-16 01:53:32.676	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:32.538	debug	(2779) update_Map got new time:1597535612
                                  mihome-vacuum.0	2020-08-16 01:53:32.537	debug	(2779) update_Map got new expires:1597537412
                                  mihome-vacuum.0	2020-08-16 01:53:32.537	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/7?Expires=1597537412000&GalaxyAccessKeyId=5271733786445&Signature=Nq3Ni/4ckjx++Ljv13AfRfvC24U=
                                  mihome-vacuum.0	2020-08-16 01:53:32.441	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:32.441	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F8"],"id":2358}
                                  mihome-vacuum.0	2020-08-16 01:53:32.427	debug	(2779) update_Map need new mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:32.427	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:32.426	debug	(2779) sendMsg[1] >>> {"id":2358,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:31.927	debug	(2779) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4260,"state":5,"battery":100,"clean_time":19,"clean_area":405000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0
                                  mihome-vacuum.0	2020-08-16 01:53:31.926	debug	(2779) Receive <<< {"partner_id":"","id":2357,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp":
                                  mihome-vacuum.0	2020-08-16 01:53:31.921	debug	(2779) Next WiFi check: 16.08 01:54
                                  mihome-vacuum.0	2020-08-16 01:53:31.920	debug	(2779) sendMsg[1] >>> {"id":2357,"method":"miIO.info"}
                                  mihome-vacuum.0	2020-08-16 01:53:31.920	debug	(2779) sendMsg[1] >>> {"id":2356,"method":"get_status"}
                                  mihome-vacuum.0	2020-08-16 01:53:30.426	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new time:1597535610
                                  mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new expires:1597537410
                                  mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/6?Expires=1597537410000&GalaxyAccessKeyId=5271733786445&Signature=I1r1YsjSLQJlM7Qw8SP/DCkR/SI=
                                  mihome-vacuum.0	2020-08-16 01:53:30.208	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:30.207	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F7"],"id":2355}
                                  mihome-vacuum.0	2020-08-16 01:53:30.201	debug	(2779) update_Map need new mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:30.201	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:30.200	debug	(2779) sendMsg[1] >>> {"id":2355,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:28.199	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:28.068	debug	(2779) update_Map got new time:1597535607
                                  mihome-vacuum.0	2020-08-16 01:53:28.067	debug	(2779) update_Map got new expires:1597537408
                                  mihome-vacuum.0	2020-08-16 01:53:28.065	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/5?Expires=1597537408000&GalaxyAccessKeyId=5271733786445&Signature=JTBJCqLKf/mXJCpVIeWEPLTGFfQ=
                                  mihome-vacuum.0	2020-08-16 01:53:27.928	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:27.927	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F6"],"id":2354}
                                  mihome-vacuum.0	2020-08-16 01:53:27.916	debug	(2779) update_Map need new mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:27.916	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:27.907	debug	(2779) sendMsg[1] >>> {"id":2354,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:25.904	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new time:1597535605
                                  mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new expires:1597537405
                                  mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/4?Expires=1597537405000&GalaxyAccessKeyId=5271733786445&Signature=+eko4U453CCKnyc+RiWm9W1RDt4=
                                  mihome-vacuum.0	2020-08-16 01:53:25.577	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:25.575	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F5"],"id":2353}
                                  mihome-vacuum.0	2020-08-16 01:53:25.566	debug	(2779) update_Map need new mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:25.566	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:25.565	debug	(2779) sendMsg[1] >>> {"id":2353,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:23.564	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new time:1597535603
                                  mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new expires:1597537403
                                  mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/3?Expires=1597537403000&GalaxyAccessKeyId=5271733786445&Signature=CiWtSOVFBD9uxVjOJ9fDCF//pKU=
                                  mihome-vacuum.0	2020-08-16 01:53:23.296	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:23.295	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F4"],"id":2352}
                                  mihome-vacuum.0	2020-08-16 01:53:23.287	debug	(2779) update_Map need new mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:23.287	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:23.286	debug	(2779) sendMsg[1] >>> {"id":2352,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:21.284	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:21.147	debug	(2779) update_Map got new time:1597535601
                                  mihome-vacuum.0	2020-08-16 01:53:21.147	debug	(2779) update_Map got new expires:1597537401
                                  mihome-vacuum.0	2020-08-16 01:53:21.146	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/2?Expires=1597537401000&GalaxyAccessKeyId=5271733786445&Signature=71qd2EM76sazK0HXc6UgwCqlK+E=
                                  mihome-vacuum.0	2020-08-16 01:53:21.047	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:21.046	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F3"],"id":2351}
                                  mihome-vacuum.0	2020-08-16 01:53:21.034	debug	(2779) update_Map need new mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:21.034	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:21.033	debug	(2779) sendMsg[1] >>> {"id":2351,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:19.033	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:18.918	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:18.918	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F2"],"id":2350}
                                  mihome-vacuum.0	2020-08-16 01:53:18.909	debug	(2779) update_Map use old mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:18.908	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:18.908	debug	(2779) sendMsg[1] >>> {"id":2350,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:16.906	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:16.661	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:16.660	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":2349}
                                  mihome-vacuum.0	2020-08-16 01:53:16.654	debug	(2779) update_Map use old mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:16.653	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:16.653	debug	(2779) sendMsg[1] >>> {"id":2349,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:16.424	debug	(2779) Mappointer_updated
                                  mihome-vacuum.0	2020-08-16 01:53:16.423	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":2348}
                                  mihome-vacuum.0	2020-08-16 01:53:16.416	debug	(2779) 1. Mappointer_nomap___retry
                                  mihome-vacuum.0	2020-08-16 01:53:16.415	debug	(2779) sendMsg[1] >>> {"id":2348,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:15.913	debug	(2779) Receive <<< {"result":["retry"],"id":2347}
                                  mihome-vacuum.0	2020-08-16 01:53:15.909	debug	(2779) 0. Mappointer_nomap___retry
                                  mihome-vacuum.0	2020-08-16 01:53:15.908	debug	(2779) sendMsg[1] >>> {"id":2347,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:15.408	debug	(2779) Receive <<< {"result":["retry"],"id":2346}
                                  mihome-vacuum.0	2020-08-16 01:53:14.652	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:14.428	debug	(2779) update_Map use old mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:14.427	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:14.427	debug	(2779) sendMsg[1] >>> {"id":2346,"method":"get_map_v1"}
                                  mihome-vacuum.0	2020-08-16 01:53:12.426	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
                                  mihome-vacuum.0	2020-08-16 01:53:12.131	debug	(2779) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":2345}
                                  mihome-vacuum.0	2020-08-16 01:53:12.126	debug	(2779) sendMsg[1] >>> {"id":2345,"method":"get_carpet_mode"}
                                  mihome-vacuum.0	2020-08-16 01:53:12.114	debug	(2779) update_Map got new time:1597535591
                                  mihome-vacuum.0	2020-08-16 01:53:12.114	debug	(2779) update_Map got new expires:1597537392
                                  mihome-vacuum.0	2020-08-16 01:53:12.113	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/0?Expires=1597537392000&GalaxyAccessKeyId=5271733786445&Signature=KZiZxJjzO5quElJw1dYHDqyhz9s=
                                  mihome-vacuum.0	2020-08-16 01:53:11.939	debug	(2779) Receive <<< {"result":[78],"id":2344}
                                  mihome-vacuum.0	2020-08-16 01:53:11.926	debug	(2779) update_Map need new mapurl
                                  mihome-vacuum.0	2020-08-16 01:53:11.926	debug	(2779) update_Map Mimap enabled
                                  mihome-vacuum.0	2020-08-16 01:53:11.925	debug	(2779) sendMsg[1] >>> {"id":2344,"method":"get_sound_volume"}
                                  mihome-vacuum.0	2020-08-16 01:53:11.924	debug	(2779) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4259,"state":5,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_
                                  mihome-vacuum.0	2020-08-16 01:53:11.918	debug	(2779) sendMsg[1] >>> {"id":2343,"method":"get_status"}
                                  mihome-vacuum.0	2020-08-16 01:53:09.924	debug	(2779) Receive <<< {"result":["ok"],"id":2342}
                                  mihome-vacuum.0	2020-08-16 01:53:09.918	debug	(2779) sendMsg[1] >>> {"id":2342,"method":"app_start"}
                                  mihome-vacuum.0	2020-08-16 01:53:09.917	info	(2779) trigger cleaning all
                                  da steht doch so was wie ne url drinnen. ?!?
                                  aber wenn ich die jetzt imbrowser ansehe kommt so was wie
                                  url expired
                                  • F freaktech
                                    url expired
                                    dirkhe
                                    #1093
                                    @freaktech du hast canvas nicht oder nicht korrekt installiert, gibt es genug Hinweise hier
                                    • D dirkhe
                                      freaktech
                                      #1094
                                      @dirkhe
                                      hallo
                                      leider bekomme ich es nicht hin, 2 Leute hätten es auch schon probiert.
                                      könntest du mir helfen?
                                      • F freaktech
                                        @dirkhe
                                        hallo
                                        #1095
                                        @freaktech Da sind vermutlich immer noch Rechte falsch gesetzt.
                                        bringt z. B.?
                                        F 2 Antworten Letzte Antwort
                                          bringt z. B.?
                                          freaktech
                                          #1096
                                          @Thomas-Braun
                                          ja leider bin ich halt nicht so der Profi und mittlerweile steh ich an
                                          wenn ein Profi evtl mal 5 min mit teamvifer zeit hätte wär ich da sehr verbunden, denn nach 2 tagen macht das echt keinen Spaß mehr.
