  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.7k Aufrufe 118 Beobachtet
  • D dirkhe
    @Rushmed ich habe bei mir kein raumwechsel gemacht, daher kann ich das aktuell nicht nachvollziehen. Kannst du das debug log nochmal schicken, wenn du die Karte wechselt? Ich vermute mal, das er auf einen Fehler läuft, wenn er die Räume anlegen will, den ich abfangen muss
    Rushmed
    schrieb am zuletzt editiert von Rushmed
    #1071
    @dirkhe Klaro!
    Karte in der Xiaomi App gewechselt und Räume über DP neu geladen.
    mihome-vacuum.0	2020-08-14 23:55:37.936	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4261,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:55:37.886	debug	(8589) sendMsg[1] >>> {"id":53,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:55:17.966	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4260,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:55:17.885	debug	(8589) sendMsg[1] >>> {"id":52,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:54:58.004	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4259,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:54:58.002	debug	(8589) Receive <<< {"partner_id":"","id":51,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
    mihome-vacuum.0	2020-08-14 23:54:57.883	debug	(8589) Next WiFi check: 14.08 23:55
    mihome-vacuum.0	2020-08-14 23:54:57.883	debug	(8589) sendMsg[1] >>> {"id":51,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:54:57.882	debug	(8589) sendMsg[1] >>> {"id":50,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:54:37.927	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4258,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:54:37.877	debug	(8589) sendMsg[1] >>> {"id":49,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:54:17.959	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4257,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:54:17.875	debug	(8589) sendMsg[1] >>> {"id":48,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:53:57.993	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4256,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:53:57.989	debug	(8589) Receive <<< {"partner_id":"","id":47,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
    mihome-vacuum.0	2020-08-14 23:53:57.874	debug	(8589) Next WiFi check: 14.08 23:54
    mihome-vacuum.0	2020-08-14 23:53:57.873	debug	(8589) sendMsg[1] >>> {"id":47,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:53:57.872	debug	(8589) sendMsg[1] >>> {"id":46,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:53:37.921	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4245,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:53:37.869	debug	(8589) sendMsg[1] >>> {"id":45,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:53:17.955	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4235,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
    mihome-vacuum.0	2020-08-14 23:53:17.867	debug	(8589) sendMsg[1] >>> {"id":44,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:53:16.841	debug	(8589) system.adapter.admin.0: logging true
    mihome-vacuum.0	2020-08-14 23:52:58.455	debug	(8589) system.adapter.admin.0: logging false
    mihome-vacuum.0	2020-08-14 23:52:57.886	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4224,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:52:57.882	debug	(8589) Receive <<< {"partner_id":"","id":43,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"local
    mihome-vacuum.0	2020-08-14 23:52:57.866	debug	(8589) Next WiFi check: 14.08 23:53
    mihome-vacuum.0	2020-08-14 23:52:57.865	debug	(8589) sendMsg[1] >>> {"id":43,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:52:57.864	debug	(8589) sendMsg[1] >>> {"id":42,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:52:53.977	info	(8589) room: 275001013628 not mapped
    mihome-vacuum.0	2020-08-14 23:52:53.976	info	(8589) room: 275001013648 not mapped
    mihome-vacuum.0	2020-08-14 23:52:53.971	info	(8589) room: 275001013621 not mapped
    mihome-vacuum.0	2020-08-14 23:52:53.968	info	(8589) room: 275001013646 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.965	info	(8589) room: 275001013645 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.961	info	(8589) room: 275001013642 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.959	info	(8589) room: 275001013641 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.955	info	(8589) room: 275001013647 mapped with index undefined
    mihome-vacuum.0	2020-08-14 23:52:53.887	debug	(8589) Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":41}
    mihome-vacuum.0	2020-08-14 23:52:53.762	debug	(8589) sendMsg[1] >>> {"id":41,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-08-14 23:52:53.760	debug	(8589) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597441973751,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
    mihome-vacuum.0	2020-08-14 23:52:37.873	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4212,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:52:37.861	debug	(8589) sendMsg[1] >>> {"id":40,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:52:17.946	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4200,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:52:17.860	debug	(8589) sendMsg[1] >>> {"id":39,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:51:57.980	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4199,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:51:57.979	debug	(8589) Receive <<< {"partner_id":"","id":38,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"local
    mihome-vacuum.0	2020-08-14 23:51:57.859	debug	(8589) Next WiFi check: 14.08 23:52
    mihome-vacuum.0	2020-08-14 23:51:57.858	debug	(8589) sendMsg[1] >>> {"id":38,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:51:57.857	debug	(8589) sendMsg[1] >>> {"id":37,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:51:37.912	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4198,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:51:37.855	debug	(8589) sendMsg[1] >>> {"id":36,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:51:17.940	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4197,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:51:17.854	debug	(8589) sendMsg[1] >>> {"id":35,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:51:00.016	debug	(8589) Mappointer_updated
    mihome-vacuum.0	2020-08-14 23:51:00.015	debug	(8589) Receive <<< {"result":["roboroommap%2F321636546%2F1"],"id":34}
    mihome-vacuum.0	2020-08-14 23:50:59.979	debug	(8589) sendMsg[1] >>> {"id":34,"method":"get_map_v1"}
    mihome-vacuum.0	2020-08-14 23:50:58.588	debug	(8589) Receive <<< {"result":[10854,145977500,26,[1597438510,1597437891,1597437765,1597437590,1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,159732
    mihome-vacuum.0	2020-08-14 23:50:58.479	debug	(8589) sendMsg[1] >>> {"id":33,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-08-14 23:50:57.985	debug	(8589) Receive <<< {"result":[{"main_brush_work_time":10854,"side_brush_work_time":10854,"filter_work_time":10854,"filter_element_work_time":7737,"sensor_dirty_time":10854}],"id":32}
    mihome-vacuum.0	2020-08-14 23:50:57.977	debug	(8589) sendMsg[1] >>> {"id":32,"method":"get_consumable"}
    mihome-vacuum.0	2020-08-14 23:50:57.975	info	(8589) create states for water box filter
    mihome-vacuum.0	2020-08-14 23:50:57.973	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4196,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:50:57.852	debug	(8589) sendMsg[1] >>> {"id":31,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:50:42.847	debug	(8589) CLEAN_LOGGING[{"Datum":"14.8","Start":"22:55","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"14.8","Start":"22:44","Saugzeit":"1 min","Fläche":"1.52 m²","Error":0,"Ende":
    mihome-vacuum.0	2020-08-14 23:50:42.653	debug	(8589) Receive <<< {"result":[[1597268211,1597268217,6,0,0,0,2,1,60]],"id":30}
    mihome-vacuum.0	2020-08-14 23:50:42.646	debug	(8589) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1597268211]}
    mihome-vacuum.0	2020-08-14 23:50:42.453	debug	(8589) Receive <<< {"result":[[1597294395,1597296293,1898,32012500,0,1,5,1,52]],"id":29}
    mihome-vacuum.0	2020-08-14 23:50:42.445	debug	(8589) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1597294395]}
    mihome-vacuum.0	2020-08-14 23:50:42.252	debug	(8589) Receive <<< {"result":[[1597319289,1597319912,605,7660000,0,1,5,1,52]],"id":28}
    mihome-vacuum.0	2020-08-14 23:50:42.243	debug	(8589) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1597319289]}
    mihome-vacuum.0	2020-08-14 23:50:42.049	debug	(8589) Receive <<< {"result":[[1597320739,1597320899,15,220000,0,0,1,1,43]],"id":27}
    mihome-vacuum.0	2020-08-14 23:50:42.040	debug	(8589) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1597320739]}
    mihome-vacuum.0	2020-08-14 23:50:41.846	debug	(8589) Receive <<< {"result":[[1597320922,1597320988,23,0,0,0,2,2,61]],"id":26}
    mihome-vacuum.0	2020-08-14 23:50:41.837	debug	(8589) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1597320922]}
    mihome-vacuum.0	2020-08-14 23:50:41.643	debug	(8589) Receive <<< {"result":[[1597321049,1597321413,346,3345000,0,1,2,1,52]],"id":25}
    mihome-vacuum.0	2020-08-14 23:50:41.634	debug	(8589) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1597321049]}
    mihome-vacuum.0	2020-08-14 23:50:41.444	debug	(8589) Receive <<< {"result":[[1597321488,1597321547,59,1775000,0,0,1,1,43]],"id":24}
    mihome-vacuum.0	2020-08-14 23:50:41.432	debug	(8589) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1597321488]}
    mihome-vacuum.0	2020-08-14 23:50:41.239	debug	(8589) Receive <<< {"result":[[1597321619,1597322479,844,7545000,0,1,2,1,52]],"id":23}
    mihome-vacuum.0	2020-08-14 23:50:41.230	debug	(8589) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1597321619]}
    mihome-vacuum.0	2020-08-14 23:50:41.036	debug	(8589) Receive <<< {"result":[[1597322633,1597325189,2556,33375000,0,1,2,1,52]],"id":22}
    mihome-vacuum.0	2020-08-14 23:50:41.028	debug	(8589) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1597322633]}
    mihome-vacuum.0	2020-08-14 23:50:40.835	debug	(8589) Receive <<< {"result":[[1597326675,1597328878,2203,31472500,0,1,1,1,52]],"id":21}
    mihome-vacuum.0	2020-08-14 23:50:40.826	debug	(8589) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1597326675]}
    mihome-vacuum.0	2020-08-14 23:50:40.633	debug	(8589) Receive <<< {"result":[[1597331343,1597331356,13,0,0,0,5,1,60]],"id":20}
    mihome-vacuum.0	2020-08-14 23:50:40.625	debug	(8589) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1597331343]}
    mihome-vacuum.0	2020-08-14 23:50:40.430	debug	(8589) Receive <<< {"result":[[1597332841,1597332874,33,482500,0,0,5,1,60]],"id":19}
    mihome-vacuum.0	2020-08-14 23:50:40.421	debug	(8589) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1597332841]}
    mihome-vacuum.0	2020-08-14 23:50:40.370	warn	(8589) HTTP error when getting token cookie
    mihome-vacuum.0	2020-08-14 23:50:40.369	error	(8589) HTTP error when getting token cookie{}
    mihome-vacuum.0	2020-08-14 23:50:40.225	debug	(8589) Receive <<< {"result":[[1597344916,1597344932,16,0,0,0,5,1,60]],"id":18}
    mihome-vacuum.0	2020-08-14 23:50:40.220	debug	(8589) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1597344916]}
    mihome-vacuum.0	2020-08-14 23:50:40.216	debug	(8589) Mappointer_updated
    mihome-vacuum.0	2020-08-14 23:50:40.215	debug	(8589) Receive <<< {"result":["roboroommap%2F321636546%2F0"],"id":17}
    mihome-vacuum.0	2020-08-14 23:50:40.208	debug	(8589) 1. Mappointer_nomap___retry
    mihome-vacuum.0	2020-08-14 23:50:40.207	debug	(8589) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
    mihome-vacuum.0	2020-08-14 23:50:40.027	debug	(8589) Receive <<< {"result":[[1597411995,1597412226,231,5247500,0,1,2,3,56]],"id":16}
    mihome-vacuum.0	2020-08-14 23:50:40.018	debug	(8589) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1597411995]}
    mihome-vacuum.0	2020-08-14 23:50:39.829	debug	(8589) Receive <<< {"result":[[1597414047,1597415374,1327,9362500,0,1,2,3,56]],"id":15}
    mihome-vacuum.0	2020-08-14 23:50:39.817	debug	(8589) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1597414047]}
    mihome-vacuum.0	2020-08-14 23:50:39.705	debug	(8589) Receive <<< {"result":["retry"],"id":14}
    mihome-vacuum.0	2020-08-14 23:50:39.700	debug	(8589) 0. Mappointer_nomap___retry
    mihome-vacuum.0	2020-08-14 23:50:39.699	debug	(8589) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
    mihome-vacuum.0	2020-08-14 23:50:39.624	debug	(8589) Receive <<< {"result":[[1597423082,1597423092,10,0,0,0,2,2,61]],"id":13}
    mihome-vacuum.0	2020-08-14 23:50:39.616	debug	(8589) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1597423082]}
    mihome-vacuum.0	2020-08-14 23:50:39.423	debug	(8589) Receive <<< {"result":[[1597437590,1597437762,70,970000,0,0,2,3,60]],"id":12}
    mihome-vacuum.0	2020-08-14 23:50:39.415	debug	(8589) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1597437590]}
    mihome-vacuum.0	2020-08-14 23:50:39.218	debug	(8589) Receive <<< {"result":[[1597437765,1597437801,36,470000,0,0,2,3,60]],"id":11}
    mihome-vacuum.0	2020-08-14 23:50:39.213	debug	(8589) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1597437765]}
    mihome-vacuum.0	2020-08-14 23:50:39.196	debug	(8589) Receive <<< {"result":["retry"],"id":10}
    mihome-vacuum.0	2020-08-14 23:50:39.191	debug	(8589) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
    mihome-vacuum.0	2020-08-14 23:50:39.021	debug	(8589) Receive <<< {"result":[[1597437891,1597437942,51,1522500,0,0,2,3,60]],"id":9}
    mihome-vacuum.0	2020-08-14 23:50:39.010	debug	(8589) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1597437891]}
    mihome-vacuum.0	2020-08-14 23:50:39.004	debug	(8589) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":8}
    mihome-vacuum.0	2020-08-14 23:50:39.003	info	(8589) create state for carpet_mode
    mihome-vacuum.0	2020-08-14 23:50:39.001	debug	(8589) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
    mihome-vacuum.0	2020-08-14 23:50:38.992	debug	(8589) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-08-14 23:50:38.991	debug	(8589) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
    mihome-vacuum.0	2020-08-14 23:50:38.815	debug	(8589) Receive <<< {"result":[[1597438510,1597438518,8,0,0,0,2,3,60]],"id":6}
    mihome-vacuum.0	2020-08-14 23:50:38.808	debug	(8589) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1597438510]}
    mihome-vacuum.0	2020-08-14 23:50:38.802	debug	(8589) Receive <<< {"result":[10854,145977500,26,[1597438510,1597437891,1597437765,1597437590,1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,159732
    mihome-vacuum.0	2020-08-14 23:50:38.792	debug	(8589) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-08-14 23:50:38.601	debug	(8589) Receive <<< {"result":[{"main_brush_work_time":10854,"side_brush_work_time":10854,"filter_work_time":10854,"filter_element_work_time":7737,"sensor_dirty_time":10854}],"id":4}
    mihome-vacuum.0	2020-08-14 23:50:38.591	debug	(8589) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
    mihome-vacuum.0	2020-08-14 23:50:38.404	debug	(8589) Receive <<< {"result":[90],"id":3}
    mihome-vacuum.0	2020-08-14 23:50:38.393	debug	(8589) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
    mihome-vacuum.0	2020-08-14 23:50:38.391	info	(8589) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-08-14 23:50:38.198	debug	(8589) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
    mihome-vacuum.0	2020-08-14 23:50:38.194	debug	(8589) Next WiFi check: 14.08 23:51
    mihome-vacuum.0	2020-08-14 23:50:38.192	debug	(8589) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
    mihome-vacuum.0	2020-08-14 23:50:37.989	info	(8589) Connected
    mihome-vacuum.0	2020-08-14 23:50:37.986	debug	(8589) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-08-14 23:50:37.983	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4195,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
    mihome-vacuum.0	2020-08-14 23:50:37.972	debug	(8589) sendMsg[1] >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-08-14 23:50:37.940	debug	(8589) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    mihome-vacuum.0	2020-08-14 23:50:37.939	info	(8589) connecting, this can take up to 10 minutes ...
    mihome-vacuum.0	2020-08-14 23:50:37.937	debug	(8589) Receive <<< Helo <<< 2131002000000000132bc8c25f37072dffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-08-14 23:50:37.930	info	(8589) New generation or new fw(3.5.8,4436) detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-08-14 23:50:37.916	debug	(8589) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    mihome-vacuum.0	2020-08-14 23:50:37.857	debug	(8589) server started on 0.0.0.0:53421
    mihome-vacuum.0	2020-08-14 23:50:37.842	info	(8589) Create state clean_home for controlling by cloud adapter
    mihome-vacuum.0	2020-08-14 23:50:37.840	info	(8589) Expert mode disabled, states deleted
    mihome-vacuum.0	2020-08-14 23:50:37.831	debug	(8589) Xiaomi Cloud: Logging in
    mihome-vacuum.0	2020-08-14 23:50:37.828	debug	(8589) load Map creator... true
    mihome-vacuum.0	2020-08-14 23:50:37.730	info	(8589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
    mihome-vacuum.0	2020-08-14 23:50:36.347	debug	(8589) statesDB connected
    mihome-vacuum.0	2020-08-14 23:50:36.346	debug	(8589) States connected to redis: 127.0.0.1:9000
    mihome-vacuum.0	2020-08-14 23:50:36.311	debug	(8589) States create System PubSub Client
    mihome-vacuum.0	2020-08-14 23:50:36.308	debug	(8589) States create User PubSub Client
    mihome-vacuum.0	2020-08-14 23:50:36.296	debug	(8589) Redis States: Use Redis connection: 127.0.0.1:9000
    mihome-vacuum.0	2020-08-14 23:50:36.294	debug	(8589) objectDB connected
    mihome-vacuum.0	2020-08-14 23:50:36.287	debug	(8589) Objects connected to redis: 127.0.0.1:9001
    mihome-vacuum.0	2020-08-14 23:50:36.262	debug	(8589) Objects client initialize lua scripts
    mihome-vacuum.0	2020-08-14 23:50:36.261	debug	(8589) Objects create User PubSub Client
    mihome-vacuum.0	2020-08-14 23:50:36.260	debug	(8589) Objects create System PubSub Client
    mihome-vacuum.0	2020-08-14 23:50:36.256	debug	(8589) Objects client ready ... initialize now
    mihome-vacuum.0	2020-08-14 23:50:36.216	debug	(8589) Redis Objects: Use Redis connection: 127.0.0.1:9001
    mihome-vacuum.0	2020-08-14 23:50:31.904	info	(12559) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    mihome-vacuum.0	2020-08-14 23:50:31.903	info	(12559) terminating
    mihome-vacuum.0	2020-08-14 23:50:31.900	info	(12559) Got terminate signal TERMINATE_YOURSELF
    Die Datenpunkte "roomClean" und "state" werden bei Kartenwechsel jeweils neu angelegt und in den ordner "mapIndex" verschoben. Das macht mir erstens den gezielten Raumzugriff unmöglich und eliminiert zweitens meine IOT smart Devices.
    • F Offline
      freaktech
      schrieb am zuletzt editiert von freaktech
      #1072
      Hallo Leute!
      Hab jetzt nen S5 Max und bekomme in den Kartenlink keinen Eintrag.
      Bin leider nicht so der Profi, aber hier mal meine Infos und Einstellungen
      PI4
      Adapter mihome-vacuum Version 2.2.0
      Modell S5 Max
      Firmware lt Mi Home APP 3.5.8_0876
      Logging:
      mihome-vacuum.0	2020-08-15 08:41:49.625	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1012,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":
      mihome-vacuum.0	2020-08-15 08:41:49.621	debug	(28150) Receive <<< {"partner_id":"","id":119,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp":
      mihome-vacuum.0	2020-08-15 08:41:49.615	debug	(28150) Next WiFi check: 15.08 08:42
      mihome-vacuum.0	2020-08-15 08:41:49.614	debug	(28150) sendMsg[1] >>> {"id":119,"method":"miIO.info"}
      mihome-vacuum.0	2020-08-15 08:41:49.613	debug	(28150) sendMsg[1] >>> {"id":118,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 08:41:41.447	debug	(28150) system.adapter.admin.0: logging true
      mihome-vacuum.0	2020-08-15 08:41:29.617	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1011,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 08:41:29.608	debug	(28150) sendMsg[1] >>> {"id":117,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 08:41:10.637	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1010,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 08:41:09.606	debug	(28150) sendMsg[1] >>> {"id":116,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 08:40:49.613	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1009,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 08:40:49.610	debug	(28150) Receive <<< {"partner_id":"","id":115,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp"
      mihome-vacuum.0	2020-08-15 08:40:49.605	debug	(28150) Next WiFi check: 15.08 08:41
      mihome-vacuum.0	2020-08-15 08:40:49.604	debug	(28150) sendMsg[1] >>> {"id":115,"method":"miIO.info"}
      mihome-vacuum.0	2020-08-15 08:40:49.603	debug	(28150) sendMsg[1] >>> {"id":114,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 08:40:29.608	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1008,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 08:40:29.601	debug	(28150) sendMsg[1] >>> {"id":113,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 08:40:09.608	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1007,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 08:40:09.600	debug	(28150) sendMsg[1] >>> {"id":112,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 08:39:49.608	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1006,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 08:39:49.606	debug	(28150) Receive <<< {"partner_id":"","id":111,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp"
      mihome-vacuum.0	2020-08-15 08:39:49.599	debug	(28150) Next WiFi check: 15.08 08:40
      mihome-vacuum.0	2020-08-15 08:39:49.598	debug	(28150) sendMsg[1] >>> {"id":111,"method":"miIO.info"}
      mihome-vacuum.0	2020-08-15 08:39:49.593	debug	(28150) sendMsg[1] >>> {"id":110,"method":"get_status"}
      der Adapter selbst läuft nun
      die Räume sind drinnen und auf Steuerungsbefehle per Blockly reagiert er auch
      Bildschirmfoto 2020-08-15 um 08.43.28.png Bildschirmfoto 2020-08-15 um 08.43.54.png Bildschirmfoto 2020-08-15 um 08.43.58.png
      danke Tom
      evtl. kann mal wer mit Teamviewer helfen, ich checks nicht mehr
      • F freaktech
        Hallo Leute!
        PI4
        Modell S5 Max
        Logging:
        danke Tom
        #1073
        @freaktech in dem Log seh ich jetzt weniger einen Fehler, der wichtige Teil fehlt anscheinend... ?
        Hast du mal canvas neu gebaut? ( falls nicht, google mal hier im Thread danach, ist xmal beschrieben)
        Ansonsten hilft für die Fehlersuche immer das Log vom Starten des Adapters
        F 1 Antwort Letzte Antwort
          freaktech
          #1074
          @ilovegym
          Please install canvas and the libs manually with:
          sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
          sudo npm install canvas --unsafe-perm=true
          das hab ich probiert
          jetzt versucht er wieder seit 10 min zu verbinden ?!?
          • F freaktech
            @ilovegym
            #1075
            @freaktech npm ohne sudo
            Dafür musst du aber in /opt/iobroker stehen.
            Was liefert denn nachfolgende Befehlsfolge bei dir?
            pi@raspberrypi:~ $ cd /opt/iobroker/
            pi@raspberrypi:/opt/iobroker $ npm list canvas
            iobroker.inst@2.0.3 /opt/iobroker
            ├── canvas@2.6.1
            ├─┬ iobroker.iot@1.7.0
            │ └── canvas@2.6.1  deduped
            └─┬ iobroker.mihome-vacuum@2.1.1
              ├── canvas@2.6.1
              freaktech
              #1076
              @Thomas-Braun
              wie komm ich von
              pi@ioBroker-RasPi4:~ $
              dort hin?
              was genau eintippen?
              danke
              pi@ioBroker-RasPi4:/opt/iobroker $ npm install canvas --unsafe-perm=true
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/canvas
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@^2.0.0 (node_modules/node-dtls-client/node_modules/node-aead-crypto):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for node-aead-crypto@2.2.0: wanted: {"node":">4 <10"} (current: {"node":"12.18.3","npm":"6.14.6"})
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: node-aead-crypto@2.2.0
              npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-aead-crypto/package.json'
              npm ERR! code EACCES
              npm ERR! syscall access
              npm ERR! path /opt/iobroker/node_modules/canvas
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/canvas'
              npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/canvas'] {
              npm ERR!   errno: -13,
              npm ERR!   code: 'EACCES',
              npm ERR!   syscall: 'access',
              npm ERR!   path: '/opt/iobroker/node_modules/canvas'
              npm ERR! }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              npm ERR!     /home/iobroker/.npm/_logs/2020-08-15T11_21_54_151Z-debug.log
              • F freaktech
                @Thomas-Braun
                wie komm ich von
                dort hin?
                danke
                npm ERR! errno -13
                npm ERR! }
                npm ERR!
                npm ERR!
                #1077
                @freaktech
                ├── canvas@2.6.1
                  @freaktech
                  ├── canvas@2.6.1
                  freaktech
                  #1078
                  @Thomas-Braun
                  pi@ioBroker-RasPi4:/opt/iobroker $ npm list canvas
                  ├── canvas@2.6.1
                  ├─┬ iobroker.iot@1.5.3
                  └─┬ iobroker.mihome-vacuum@2.2.0
                  • F freaktech
                    @Thomas-Braun
                    ├── canvas@2.6.1
                    freaktech
                    #1079
                    @freaktech ```
                    mihome-vacuum.0 2020-08-15 13:28:54.574 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1906,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                    mihome-vacuum.0 2020-08-15 13:28:53.134 debug (7072) sendMsg[1] >>> {"id":97,"method":"get_status"}
                    mihome-vacuum.0 2020-08-15 13:28:45.683 debug (7072) system.adapter.admin.0: logging true
                    mihome-vacuum.0 2020-08-15 13:28:39.140 debug (7072) Mappointer_updated
                    mihome-vacuum.0 2020-08-15 13:28:39.138 debug (7072) Receive <<< {"result":["rubyslite%2F320252511%2F1"],"id":96}
                    mihome-vacuum.0 2020-08-15 13:28:39.132 debug (7072) sendMsg[1] >>> {"id":96,"method":"get_map_v1"}
                    mihome-vacuum.0 2020-08-15 13:28:39.130 debug (7072) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1597490919126,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597432659531}
                    mihome-vacuum.0 2020-08-15 13:28:35.470 debug (7072) Mappointer_updated
                    mihome-vacuum.0 2020-08-15 13:28:35.469 debug (7072) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":95}
                    mihome-vacuum.0 2020-08-15 13:28:35.463 debug (7072) 1. Mappointer_nomap___retry
                    mihome-vacuum.0 2020-08-15 13:28:35.462 debug (7072) sendMsg[1] >>> {"id":95,"method":"get_map_v1"}
                    mihome-vacuum.0 2020-08-15 13:28:34.961 debug (7072) Receive <<< {"result":["retry"],"id":94}
                    mihome-vacuum.0 2020-08-15 13:28:34.955 debug (7072) 0. Mappointer_nomap___retry
                    mihome-vacuum.0 2020-08-15 13:28:34.954 debug (7072) sendMsg[1] >>> {"id":94,"method":"get_map_v1"}
                    mihome-vacuum.0 2020-08-15 13:28:34.452 debug (7072) Receive <<< {"result":["retry"],"id":93}
                    mihome-vacuum.0 2020-08-15 13:28:34.446 debug (7072) sendMsg[1] >>> {"id":93,"method":"get_map_v1"}
                    mihome-vacuum.0 2020-08-15 13:28:34.445 debug (7072) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1597490914442,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597432659531}
                    mihome-vacuum.0 2020-08-15 13:28:33.430 debug (7072) Receive <<< {"partner_id":"","id":92,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"
                    mihome-vacuum.0 2020-08-15 13:28:33.415 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1905,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                    mihome-vacuum.0 2020-08-15 13:28:33.260 debug (7072) system.adapter.admin.0: logging false
                    mihome-vacuum.0 2020-08-15 13:28:33.132 debug (7072) Next WiFi check: 15.08 13:29
                    mihome-vacuum.0 2020-08-15 13:28:33.131 debug (7072) sendMsg[1] >>> {"id":92,"method":"miIO.info"}
                    mihome-vacuum.0 2020-08-15 13:28:33.130 debug (7072) sendMsg[1] >>> {"id":91,"method":"get_status"}
                    mihome-vacuum.0 2020-08-15 13:28:13.136 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1904,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                    mihome-vacuum.0 2020-08-15 13:28:13.128 debug (7072) sendMsg[1] >>> {"id":90,"method":"get_status"}
                    mihome-vacuum.0 2020-08-15 13:27:53.135 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1903,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                    mihome-vacuum.0 2020-08-15 13:27:53.126 debug (7072) sendMsg[1] >>> {"id":89,"method":"get_status"}
                    mihome-vacuum.0 2020-08-15 13:27:33.133 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1902,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                    mihome-vacuum.0 2020-08-15 13:27:33.131 debug (7072) Receive <<< {"partner_id":"","id":88,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"
                    mihome-vacuum.0 2020-08-15 13:27:33.126 debug (7072) Next WiFi check: 15.08 13:28
                    mihome-vacuum.0 2020-08-15 13:27:33.125 debug (7072) sendMsg[1] >>> {"id":88,"method":"miIO.info"}
                    mihome-vacuum.0 2020-08-15 13:27:33.124 debug (7072) sendMsg[1] >>> {"id":87,"method":"get_status"}
                    mihome-vacuum.0 2020-08-15 13:27:15.492 debug (7072) system.adapter.admin.0: logging true
                    mihome-vacuum.0 2020-08-15 13:27:13.131 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1901,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                    mihome-vacuum.0 2020-08-15 13:27:13.123 debug (7072) sendMsg[1] >>> {"id":86,"method":"get_status"}
                    • F freaktech
                      @freaktech ```
                      #1080
                      @freaktech
                      ls -la /opt/iobroker/node_modules/canvas/
                        @freaktech
                        freaktech
                        #1081
                        @Thomas-Braun
                        pi@ioBroker-RasPi4:/opt/iobroker $ ls -la /opt/iobroker/node_modules/canvas/
                        insgesamt 144
                        drwxr-xr-x+   8 pi       pi        4096 Aug 13 14:37 .
                        drwxrwxrwx+ 816 iobroker iobroker 36864 Aug 14 21:15 ..
                        -rw-r--r--+   1 pi       pi        6832 Okt 26  1985 binding.gyp
                        -rw-r--r--+   1 pi       pi        1064 Okt 26  1985 browser.js
                        drwxr-xr-x+   3 pi       pi        4096 Aug 13 14:37 build
                        -rw-r--r--+   1 pi       pi       28011 Okt 26  1985 CHANGELOG.md
                        -rw-r--r--+   1 pi       pi        2363 Okt 26  1985 index.js
                        drwxr-xr-x+   2 pi       pi        4096 Aug 13 14:37 lib
                        drwxr-xr-x+  10 pi       pi        4096 Aug 13 14:37 node_modules
                        -rw-r--r--+   1 pi       pi        3210 Aug 13 14:37 package.json
                        -rw-r--r--+   1 pi       pi       26514 Okt 26  1985 Readme.md
                        drwxr-xr-x+   4 pi       pi        4096 Aug 13 14:37 src
                        drwxr-xr-x+   2 pi       pi        4096 Aug 13 14:37 types
                        drwxr-xr-x+   2 pi       pi        4096 Aug 13 14:37 util
                        • F freaktech
                          @Thomas-Braun
                          insgesamt 144
                          #1082
                          @freaktech
                          Die Dateien gehören dem falschen User.
                          So muss das aussehen:
                          pi@raspberrypi:~ $ ls -la /opt/iobroker/node_modules/canvas/
                          insgesamt 136
                          drwxrwxr-x+   8 iobroker iobroker  4096 Mai  9 14:23 .
                          drwxrwxr-x+ 806 iobroker iobroker 28672 Aug 14 09:30 ..
                          -rw-rwxr--+   1 iobroker iobroker  6832 Okt 26  1985 binding.gyp
                          -rw-rwxr--+   1 iobroker iobroker  1064 Okt 26  1985 browser.js
                          drwxrwxr-x+   3 iobroker iobroker  4096 Mai  9 14:23 build
                          -rw-rwxr--+   1 iobroker iobroker 28011 Okt 26  1985 CHANGELOG.md
                          -rw-rwxr--+   1 iobroker iobroker  2363 Okt 26  1985 index.js
                          drwxrwxr-x+   2 iobroker iobroker  4096 Apr 29 18:57 lib
                          drwxrwxr-x+   9 iobroker iobroker  4096 Apr 29 18:57 node_modules
                          -rw-rwxr--+   1 iobroker iobroker  3154 Apr 29 18:57 package.json
                          -rw-rwxr--+   1 iobroker iobroker 26514 Okt 26  1985 Readme.md
                          drwxrwxr-x+   4 iobroker iobroker  4096 Apr 29 18:57 src
                          drwxrwxr-x+   2 iobroker iobroker  4096 Apr 29 18:57 types
                          drwxrwxr-x+   2 iobroker iobroker  4096 Apr 29 18:57 util
                          pi@raspberrypi:~ $
                            @freaktech
                            insgesamt 136
                            pi@raspberrypi:~ $
                            freaktech
                            #1083
                            @Thomas-Braun
                            das versteh ich leider nicht
                            • F freaktech
                              @Thomas-Braun
                              freaktech
                              #1084
                              @freaktech said in Test Adapter mihome-vacuum v2.0.x:
                              @Thomas-Braun
                              wie kommt das und wie kann ich das ändern?
                              • F freaktech
                                @Thomas-Braun
                                #1085
                                @freaktech Das kommt durch den falschen Einsatz von sudo vor dem npm Befehl. Das Modul muss dem User und der Gruppe 'iobroker' gehören.
                                  freaktech
                                  #1086
                                  @Thomas-Braun
                                  ja aber wie oben beschrieben bin ich da leider in linux zu schwach
                                  • F freaktech
                                    @Thomas-Braun
                                    #1087
                                    @freaktech
                                    getfacl /opt/iobroker/node_modules/canvas/package.json
                                      @freaktech
                                      freaktech
                                      #1088
                                      @Thomas-Braun said in Test Adapter mihome-vacuum v2.0.x:
                                      i@ioBroker-RasPi4:/opt/iobroker $ getfacl /opt/iobroker/node_modules/canvas/package.json
                                      getfacl: Entferne führende '/' von absoluten Pfadnamen
                                      # file: opt/iobroker/node_modules/canvas/package.json
                                      # owner: pi
                                      # group: pi
                                      user::rw-
                                      group::r-x			#effective:r--
                                      group:iobroker:rwx		#effective:r--
                                      mask::r--
                                      other::r--
                                      • F freaktech
                                        # owner: pi
                                        # group: pi
                                        user::rw-
                                        mask::r--
                                        other::r--
                                        #1089
                                        @freaktech Da liegt die falsche Mask drauf.
                                        So sieht das bei mir aus:
                                        pi@raspberrypi:~ $ getfacl /opt/iobroker/node_modules/canvas/package.json
                                        # owner: iobroker
                                        # group: iobroker
                                        user::rw-
                                        group::r-x
                                        group:iobroker:rwx
                                        mask::rwx
                                        other::r--
                                        pi@raspberrypi:~ $
                                        Ich muss jetzt aber weg. Lies dich mal in ACL unter Linux ein.
                                          # owner: iobroker
                                          # group: iobroker
                                          user::rw-
                                          group::r-x
                                          group:iobroker:rwx
                                          mask::rwx
                                          other::r--
                                          pi@raspberrypi:~ $
                                          freaktech
                                          #1090
                                          @Thomas-Braun
                                          ok mit dem iobroker fixer sieht es jetzt so aus
                                          insgesamt 144
                                          drwxrwxr-x+   8 iobroker iobroker  4096 Aug 13 14:37 .
                                          drwxrwxr-x+   3 iobroker iobroker  4096 Aug 13 14:37 build
                                          drwxrwxr-x+   2 iobroker iobroker  4096 Aug 13 14:37 lib
                                          drwxrwxr-x+  10 iobroker iobroker  4096 Aug 13 14:37 node_modules
                                          -rw-rwxr--+   1 iobroker iobroker  3210 Aug 13 14:37 package.json
                                          drwxrwxr-x+   4 iobroker iobroker  4096 Aug 13 14:37 src
                                          drwxrwxr-x+   2 iobroker iobroker  4096 Aug 13 14:37 types
                                          drwxrwxr-x+   2 iobroker iobroker  4096 Aug 13 14:37 util
                                          pi@ioBroker-RasPi4:/opt/iobroker $ iobroker start
                                          close	Zeit
                                          mihome-vacuum.0	2020-08-15 14:38:20.038	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2016,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                                          mihome-vacuum.0	2020-08-15 14:38:20.030	debug	(6984) sendMsg[1] >>> {"id":41,"method":"get_status"}
                                          mihome-vacuum.0	2020-08-15 14:38:01.177	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2015,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                                          mihome-vacuum.0	2020-08-15 14:38:00.028	debug	(6984) sendMsg[1] >>> {"id":40,"method":"get_status"}
                                          mihome-vacuum.0	2020-08-15 14:37:40.035	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2014,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                                          mihome-vacuum.0	2020-08-15 14:37:40.032	debug	(6984) Receive <<< {"partner_id":"","id":39,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"1
                                          mihome-vacuum.0	2020-08-15 14:37:40.027	debug	(6984) Next WiFi check: 15.08 14:38
                                          mihome-vacuum.0	2020-08-15 14:37:40.026	debug	(6984) sendMsg[1] >>> {"id":39,"method":"miIO.info"}
                                          mihome-vacuum.0	2020-08-15 14:37:40.024	debug	(6984) sendMsg[1] >>> {"id":38,"method":"get_status"}
                                          mihome-vacuum.0	2020-08-15 14:37:20.030	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2013,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                                          mihome-vacuum.0	2020-08-15 14:37:20.022	debug	(6984) sendMsg[1] >>> {"id":37,"method":"get_status"}
                                          mihome-vacuum.0	2020-08-15 14:37:00.885	debug	(6984) system.adapter.admin.0: logging true
                                          mihome-vacuum.0	2020-08-15 14:36:42.042	debug	(6984) Mappointer_updated
                                          mihome-vacuum.0	2020-08-15 14:36:42.041	debug	(6984) Receive <<< {"result":["rubyslite%2F320252511%2F5"],"id":34}
                                          mihome-vacuum.0	2020-08-15 14:36:42.033	debug	(6984) sendMsg[1] >>> {"id":34,"method":"get_map_v1"}
                                          mihome-vacuum.0	2020-08-15 14:36:40.541	debug	(6984) Receive <<< {"result":[23651,324502500,122,[1597486566,1597478982,1597471813,1597471747,1597442430,1597442077,1597442057,1597441956,1597441792,1597441673,1597441472,1597441343,1597440959,15974
                                          mihome-vacuum.0	2020-08-15 14:36:40.533	debug	(6984) sendMsg[1] >>> {"id":33,"method":"get_clean_summary"}
                                          mihome-vacuum.0	2020-08-15 14:36:40.042	debug	(6984) Receive <<< {"result":[{"main_brush_work_time":24359,"side_brush_work_time":24359,"filter_work_time":24359,"filter_element_work_time":0,"sensor_dirty_time":23651}],"id":32}
                                          mihome-vacuum.0	2020-08-15 14:36:40.031	debug	(6984) sendMsg[1] >>> {"id":32,"method":"get_consumable"}
                                          mihome-vacuum.0	2020-08-15 14:36:40.029	info	(6984) create states for water box filter
                                          mihome-vacuum.0	2020-08-15 14:36:40.028	info	(6984) create states for water box
                                          mihome-vacuum.0	2020-08-15 14:36:40.026	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2011,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                                          mihome-vacuum.0	2020-08-15 14:36:40.018	debug	(6984) sendMsg[1] >>> {"id":31,"method":"get_status"}
                                          mihome-vacuum.0	2020-08-15 14:36:36.902	debug	(6984) Mappointer_updated
                                          mihome-vacuum.0	2020-08-15 14:36:36.901	debug	(6984) Receive <<< {"result":["rubyslite%2F320252511%2F4"],"id":30}
                                          mihome-vacuum.0	2020-08-15 14:36:36.890	debug	(6984) sendMsg[1] >>> {"id":30,"method":"get_map_v1"}
                                          mihome-vacuum.0	2020-08-15 14:36:36.888	debug	(6984) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1597494996878,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597432659531}
                                          mihome-vacuum.0	2020-08-15 14:36:25.160	debug	(6984) CLEAN_LOGGING[{"Datum":"15.8","Start":"12:16","Saugzeit":"8 min","Fläche":"5.24 m²","Error":0,"Ende":true},{"Datum":"15.8","Start":"10:09","Saugzeit":"9 min","Fläche":"8.19 m²","Error":0,"Ende
                                          mihome-vacuum.0	2020-08-15 14:36:24.964	debug	(6984) Receive <<< {"result":[[1597435574,1597435596,22,0,0,0,2,3,60]],"id":29}
                                          mihome-vacuum.0	2020-08-15 14:36:24.958	debug	(6984) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1597435574]}
                                          mihome-vacuum.0	2020-08-15 14:36:24.763	debug	(6984) Receive <<< {"result":[[1597435610,1597435624,14,0,0,0,2,3,60]],"id":28}
                                          mihome-vacuum.0	2020-08-15 14:36:24.756	debug	(6984) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1597435610]}
                                          mihome-vacuum.0	2020-08-15 14:36:24.561	debug	(6984) Receive <<< {"result":[[1597435636,1597435656,20,0,0,0,2,3,60]],"id":27}
                                          mihome-vacuum.0	2020-08-15 14:36:24.554	debug	(6984) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1597435636]}
                                          mihome-vacuum.0	2020-08-15 14:36:24.358	debug	(6984) Receive <<< {"result":[[1597436334,1597436350,16,140000,0,0,2,1,60]],"id":26}
                                          mihome-vacuum.0	2020-08-15 14:36:24.351	debug	(6984) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1597436334]}
                                          mihome-vacuum.0	2020-08-15 14:36:24.183	debug	(6984) Receive <<< {"result":[[1597440532,1597440545,13,0,0,0,2,3,60]],"id":25}
                                          mihome-vacuum.0	2020-08-15 14:36:24.148	debug	(6984) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1597440532]}
                                          mihome-vacuum.0	2020-08-15 14:36:23.953	debug	(6984) Receive <<< {"result":[[1597440550,1597440556,6,0,0,0,2,3,60]],"id":24}
                                          mihome-vacuum.0	2020-08-15 14:36:23.947	debug	(6984) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1597440550]}
                                          mihome-vacuum.0	2020-08-15 14:36:23.752	debug	(6984) Receive <<< {"result":[[1597440787,1597440812,25,465000,0,0,2,3,60]],"id":23}
                                          mihome-vacuum.0	2020-08-15 14:36:23.746	debug	(6984) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1597440787]}
                                          mihome-vacuum.0	2020-08-15 14:36:23.550	debug	(6984) Receive <<< {"result":[[1597440959,1597440974,15,0,0,0,2,3,60]],"id":22}
                                          mihome-vacuum.0	2020-08-15 14:36:23.544	debug	(6984) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1597440959]}
                                          mihome-vacuum.0	2020-08-15 14:36:23.349	debug	(6984) Receive <<< {"result":[[1597441343,1597441359,16,0,0,0,2,3,60]],"id":21}
                                          mihome-vacuum.0	2020-08-15 14:36:23.343	debug	(6984) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1597441343]}
                                          mihome-vacuum.0	2020-08-15 14:36:23.148	debug	(6984) Receive <<< {"result":[[1597441472,1597441672,13,0,0,0,2,3,60]],"id":20}
                                          mihome-vacuum.0	2020-08-15 14:36:23.140	debug	(6984) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1597441472]}
                                          mihome-vacuum.0	2020-08-15 14:36:23.136	debug	(6984) Xiaomi Cloud: Login successful
                                          mihome-vacuum.0	2020-08-15 14:36:22.934	debug	(6984) Receive <<< {"result":[[1597441673,1597441687,14,0,0,0,2,3,60]],"id":19}
                                          mihome-vacuum.0	2020-08-15 14:36:22.927	debug	(6984) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1597441673]}
                                          mihome-vacuum.0	2020-08-15 14:36:22.648	debug	(6984) Receive <<< {"result":[[1597441792,1597441955,13,0,0,0,2,3,60]],"id":18}
                                          mihome-vacuum.0	2020-08-15 14:36:22.632	debug	(6984) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1597441792]}
                                          mihome-vacuum.0	2020-08-15 14:36:22.437	debug	(6984) Receive <<< {"result":[[1597441956,1597441969,13,140000,0,0,2,3,60]],"id":17}
                                          mihome-vacuum.0	2020-08-15 14:36:22.430	debug	(6984) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1597441956]}
                                          mihome-vacuum.0	2020-08-15 14:36:22.235	debug	(6984) Receive <<< {"result":[[1597442057,1597442076,13,0,0,0,2,3,60]],"id":16}
                                          mihome-vacuum.0	2020-08-15 14:36:22.228	debug	(6984) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1597442057]}
                                          mihome-vacuum.0	2020-08-15 14:36:22.033	debug	(6984) Receive <<< {"result":[[1597442077,1597442083,6,0,0,0,2,3,60]],"id":15}
                                          mihome-vacuum.0	2020-08-15 14:36:22.026	debug	(6984) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1597442077]}
                                          mihome-vacuum.0	2020-08-15 14:36:21.911	debug	(6984) Mappointer_updated
                                          mihome-vacuum.0	2020-08-15 14:36:21.910	debug	(6984) Receive <<< {"result":["rubyslite%2F320252511%2F3"],"id":14}
                                          mihome-vacuum.0	2020-08-15 14:36:21.904	debug	(6984) 0. Mappointer_nomap___retry
                                          mihome-vacuum.0	2020-08-15 14:36:21.904	debug	(6984) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
                                          mihome-vacuum.0	2020-08-15 14:36:21.831	debug	(6984) Receive <<< {"result":[[1597442430,1597442445,15,0,0,0,2,3,60]],"id":13}
                                          mihome-vacuum.0	2020-08-15 14:36:21.824	debug	(6984) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1597442430]}
                                          mihome-vacuum.0	2020-08-15 14:36:21.637	debug	(6984) Receive <<< {"result":[[1597471747,1597471761,14,122500,0,0,2,1,60]],"id":12}
                                          mihome-vacuum.0	2020-08-15 14:36:21.622	debug	(6984) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1597471747]}
                                          mihome-vacuum.0	2020-08-15 14:36:21.418	debug	(6984) Receive <<< {"result":[[1597471813,1597471826,13,140000,0,0,2,1,60]],"id":11}
                                          mihome-vacuum.0	2020-08-15 14:36:21.411	debug	(6984) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1597471813]}
                                          mihome-vacuum.0	2020-08-15 14:36:21.401	debug	(6984) Receive <<< {"result":["retry"],"id":10}
                                          mihome-vacuum.0	2020-08-15 14:36:21.395	debug	(6984) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
                                          mihome-vacuum.0	2020-08-15 14:36:21.220	debug	(6984) Receive <<< {"result":[[1597478982,1597479687,533,8185000,0,1,2,3,56]],"id":9}
                                          mihome-vacuum.0	2020-08-15 14:36:21.208	debug	(6984) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1597478982]}
                                          mihome-vacuum.0	2020-08-15 14:36:21.205	debug	(6984) Receive <<< {"result":[[16,"320001013943"],[17,"320001013946"],[18,"320001013989"],[19,"320001013938"],[20,"320001013934"],[21,"320001013937"],[22,"320001013942"],[23,"320001013990"]],"id":8}
                                          mihome-vacuum.0	2020-08-15 14:36:21.203	info	(6984) create state for carpet_mode
                                          mihome-vacuum.0	2020-08-15 14:36:21.202	debug	(6984) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
                                          mihome-vacuum.0	2020-08-15 14:36:21.195	debug	(6984) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
                                          mihome-vacuum.0	2020-08-15 14:36:21.194	debug	(6984) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
                                          mihome-vacuum.0	2020-08-15 14:36:21.011	debug	(6984) Receive <<< {"result":[[1597486566,1597487061,495,5242500,0,1,2,3,56]],"id":6}
                                          mihome-vacuum.0	2020-08-15 14:36:21.005	debug	(6984) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1597486566]}
                                          mihome-vacuum.0	2020-08-15 14:36:21.002	debug	(6984) Receive <<< {"result":[23651,324502500,122,[1597486566,1597478982,1597471813,1597471747,1597442430,1597442077,1597442057,1597441956,1597441792,1597441673,1597441472,1597441343,1597440959,15974
                                          mihome-vacuum.0	2020-08-15 14:36:20.994	debug	(6984) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
                                          mihome-vacuum.0	2020-08-15 14:36:20.800	debug	(6984) Receive <<< {"result":[{"main_brush_work_time":24359,"side_brush_work_time":24359,"filter_work_time":24359,"filter_element_work_time":0,"sensor_dirty_time":23651}],"id":4}
                                          mihome-vacuum.0	2020-08-15 14:36:20.794	debug	(6984) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
                                          mihome-vacuum.0	2020-08-15 14:36:20.611	info	(6984) set nächster Timer: Nicht verfügbar
                                          mihome-vacuum.0	2020-08-15 14:36:20.600	debug	(6984) Receive <<< {"result":[78],"id":3}
                                          mihome-vacuum.0	2020-08-15 14:36:20.594	debug	(6984) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
                                          mihome-vacuum.0	2020-08-15 14:36:20.402	debug	(6984) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"1
                                          mihome-vacuum.0	2020-08-15 14:36:20.397	debug	(6984) Next WiFi check: 15.08 14:37
                                          mihome-vacuum.0	2020-08-15 14:36:20.395	debug	(6984) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
                                          mihome-vacuum.0	2020-08-15 14:36:20.192	info	(6984) Connected
                                          mihome-vacuum.0	2020-08-15 14:36:20.178	debug	(6984) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                          mihome-vacuum.0	2020-08-15 14:36:20.175	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2010,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                                          mihome-vacuum.0	2020-08-15 14:36:20.163	debug	(6984) sendMsg[1] >>> {"id":1,"method":"get_status"}
                                          mihome-vacuum.0	2020-08-15 14:36:20.122	debug	(6984) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                          mihome-vacuum.0	2020-08-15 14:36:20.120	info	(6984) connecting, this can take up to 10 minutes ...
                                          mihome-vacuum.0	2020-08-15 14:36:20.118	debug	(6984) Receive <<< Helo <<< 21310020000000001316aa5f5f37d6c4ffffffffffffffffffffffffffffffff
                                          mihome-vacuum.0	2020-08-15 14:36:20.108	info	(6984) New generation or new fw(3.5.8,0876) detected, create new states goto and zoneclean
                                          mihome-vacuum.0	2020-08-15 14:36:20.096	debug	(6984) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                          mihome-vacuum.0	2020-08-15 14:36:20.027	debug	(6984) server started on 0.0.0.0:53421
                                          mihome-vacuum.0	2020-08-15 14:36:20.003	info	(6984) Cloud control disabled
                                          mihome-vacuum.0	2020-08-15 14:36:20.000	info	(6984) Expert mode disabled, states deleted
                                          mihome-vacuum.0	2020-08-15 14:36:19.982	debug	(6984) Xiaomi Cloud: Logging in
                                          mihome-vacuum.0	2020-08-15 14:36:19.975	debug	(6984) load Map creator... false
                                          mihome-vacuum.0	2020-08-15 14:36:19.847	info	(6984) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
                                          mihome-vacuum.0	2020-08-15 14:36:18.546	debug	(6984) statesDB connected
                                          mihome-vacuum.0	2020-08-15 14:36:18.545	debug	(6984) States connected to redis: 127.0.0.1:9000
                                          mihome-vacuum.0	2020-08-15 14:36:18.513	debug	(6984) States create System PubSub Client
                                          mihome-vacuum.0	2020-08-15 14:36:18.509	debug	(6984) States create User PubSub Client
                                          mihome-vacuum.0	2020-08-15 14:36:18.493	debug	(6984) Redis States: Use Redis connection: 127.0.0.1:9000
                                          mihome-vacuum.0	2020-08-15 14:36:18.490	debug	(6984) objectDB connected
                                          mihome-vacuum.0	2020-08-15 14:36:18.481	debug	(6984) Objects connected to redis: 127.0.0.1:9001
                                          mihome-vacuum.0	2020-08-15 14:36:18.420	debug	(6984) Objects client initialize lua scripts
                                          mihome-vacuum.0	2020-08-15 14:36:18.419	debug	(6984) Objects create User PubSub Client
                                          mihome-vacuum.0	2020-08-15 14:36:18.416	debug	(6984) Objects create System PubSub Client
                                          mihome-vacuum.0	2020-08-15 14:36:18.362	debug	(6984) Objects client ready ... initialize now
                                          mihome-vacuum.0	2020-08-15 14:36:17.369	debug
                                          der MAPS link ist weiterhin leer
