  4. JavaScript
  5. E3DC Hauskraftwerk steuern
    1.0k
3.6k Beiträge 73 Kommentatoren 2.2m Aufrufe 64 Beobachtet
  • A ArnoD
    @smartboart
    kannst du das Test Script starten ohne Fehlermeldung ??
    Bei mir kommt dann immer:
    javascript.1	2020-08-07 16:25:33.618	error	(8936) at Script.runInContext (vm.js:133:20)
    javascript.1	2020-08-07 16:25:33.617	error	(8936) at script.js.common.Skript_1:17:14
    javascript.1	2020-08-07 16:25:33.617	error	(8936) at new ModeOfOperationCBC (/opt/iobroker/node_modules/iobroker.javascript/node_modules/aes-js/index.js:439:19)
    javascript.1	2020-08-07 16:25:33.617	error	(8936) Error: invalid initialation vector size (must be 16 bytes)
    javascript.1	2020-08-07 16:25:33.617	error	(8936) ^
    javascript.1	2020-08-07 16:25:33.617	error	(8936) throw new Error('invalid initialation vector size (must be 16 bytes)');
    javascript.1	2020-08-07 16:25:33.617	error	(8936) script.js.common.Skript_1: /opt/iobroker/node_modules/iobroker.javascript/node_modules/aes-js/index.js:439
    javascript.1	2020-08-07 16:25:33.607	info	(8936) Start javascript script.js.common.Skript_1
    smartboartS Offline
    smartboartS Offline
    smartboart
    schrieb am zuletzt editiert von smartboart
    #286
    @ArnoD sagte in E3DC Hauskraftwerk steuern:
    ich habe das gleiche im log
    javascript.1	2020-08-07 16:29:30.598	error	(21314) at Script.runInContext (vm.js:130:18)
    javascript.1	2020-08-07 16:29:30.598	error	(21314) at script.js.common.Tests.erdctest:31:14
    javascript.1	2020-08-07 16:29:30.598	error	(21314) at new ModeOfOperationCBC (/opt/iobroker/node_modules/iobroker.javascript/node_modules/aes-js/index.js:439:19)
    javascript.1	2020-08-07 16:29:30.597	error	(21314) Error: invalid initialation vector size (must be 16 bytes)
    javascript.1	2020-08-07 16:29:30.597	error	(21314) ^
    javascript.1	2020-08-07 16:29:30.597	error	(21314) throw new Error('invalid initialation vector size (must be 16 bytes)');
    javascript.1	2020-08-07 16:29:30.596	error	(21314) script.js.common.Tests.erdctest: /opt/iobroker/node_modules/iobroker.javascript/node_modules/aes-js/index.js:439
    • smartboartS smartboart
      ArnoD
      #287
      @smartboart
      ok habe den Fehler gefunden, hat nichts mit dem NPM Modul zu tun.
      Vektor darf anscheinend nur 16 bytes haben, E3DC verwendet aber 32, da waren sie schon wieder meine drei Probleme 😖
      • A ArnoD
        @smartboart
        smartboartS Offline
        smartboartS Offline
        smartboart
        #288
        @ArnoD shit
          @ArnoD
          was hälst du davon, die Werte der 5 usecases über vis änderbar zu machen?
          Also im Prinzip würde ich mir das so vorstellen....
          Wenn zB. Programm 1 Aktiv ist, werden meine Änderungen über die Control Eingabe direkt in der Userconfig für 1 übergeben.
          Bei aktivem Program 2 in 2 usw. ..
          Man könnte dann quasi in Echtzeit wenn man gerade auf die vis schaut und sieht, ok hier könnte was angepasst werden eingreifen.
          Das wäre im Prinzip nicht soviel Aufwand, da alle states schon vorhanden sind.
          Im Prinzip würde mit Daten schreiben die controldatei beschrieben und auch die user config. Vorher nur ne if programm 1 2 3 4oder 5 dan übernimm die Werte auf var xyz.
          vlt. noch usecase manuell, dann gelten die Einstellungen die gerade aktiv sind.
          Dann müsste auch Fall 1 mit automatik verriegelt werden.
          Nur so ne idee...
          vlt. legt man noch templates an, wenn man mal toal daneben liegt, kann man den template wieder laden...
          stevie77
          #289
          @smartboart sagte in E3DC Hauskraftwerk steuern:
          @ArnoD
          Wenn möglich parametrierbar ob wie bisher oder wie vorgeschlagen...ich habe erst vor 1-2 Tagen endlich die festen Werte für die unterschiedlichen Einstellungen gefunden und denke nicht im Traum daran die nochmals ändern zu wollen. ;-)
          Das habe ich mir selbst in nem separaten Skript tatsächlich auch noch dazu gebaut, falls man was blöd eingestellt hat oder was schief geht. Und noch den Panik-Knopf bei schlechtem Wetter, der alles übersteuert und auf 100% Eigenverbrauch und sofort alles Laden umstellt. :-)
          • S stevie77
            @ArnoD
            ArnoD
            #290
            @stevie77
            Den Schietwetter Panik Taster hast du doch schon, einfach "Ladeschwelle" auf 100% und es wird alles in den Speicher geladen. :-)
            • A ArnoD
              @stevie77
              stevie77
              #291
              @ArnoD Möglicherweise verstehe ich E3DC-Control noch nicht so gut. Ladeschwelle = 100 ist völlig unabhängig von den ganzen anderen Zeitwerten und oberer Ladekorridor und den Ladeende-Werten? Ein wie auch immer gesetzter unload-Wert pfuscht da auch nicht rein?
              • S stevie77
                ArnoD
                #292
                @stevie77
                Richtig, Ladeschwelle überlagert fast alles.
                siehe Beschreibung im ersten Post:
                ladeschwelle = Bis zu diesem SoC Wert wird sofort mit der gesamten überschüssigen PV-Leistung geladen. Erst wenn die ladeschwelle erreicht wird, wird mit dem geregelten Laden begonnen.
                edit: Außer unload dieser Parameter überlagert Ladeschwelle.
                smartboartS S 2 Antworten Letzte Antwort
                  ArnoD
                  #293
                  Man kann die Seite mit den Parameter eventuell sinnvoll aufbauen.
                  Es gibt einige die man sicher nicht verstellen will oder nicht verwendet, wie z.B.
                  • Maximum Ladeleistung
                  • minimum Ladeleistung
                  • oberer Ladekorridor
                  • unterer Ladekorridor
                  • Peakshave
                  • Speichergröße
                  Das sind z.B. die die ich nicht benötigen würde.
                  Diese könnte man in Vis von der Seite entfernen und somit das ganze übersichtlicher gestalten und Platz schaffen für eine manuelle Anwahl von Einstellung 1 bis 5 und die einzelnen Werte jeder Einstellung.
                  • A ArnoD
                    @stevie77
                    smartboartS Offline
                    smartboartS Offline
                    smartboart
                    #294
                    OK, das ist genau der Bereich den ich auch noch nicht so ganz kapiert habe... Was macht Unload genau?
                    EDIT: ich habe den Text oben gelesen. Mir fehlt nur die Fantasie wie ich das sinnvoll nutzen würde. Vlt. Hilft ein anwendungsfall um das genau zu verstehen..
                    Und warum ist Programm 1 nicht mit Automatik verriegelt?
                    Ich würde sagen wenn automatik off kann ich in vis manuell rum spielen und testen..
                    dann gelten die in vis gesendeten Werte..
                    • A ArnoD
                      @stevie77
                      stevie77
                      #295
                      @ArnoD Ah, okay, da muss ich jedes Mal drüber nachdenken und in ein paar Monaten oder Jahren sicher wieder. Außerdem wären es dann zwei Sliderwerte und ein Button. Mit meinem Panik-Button hab ich nur einen Klick (ohne Nachdenken). ;-) Nicht lachen, aber mein Kunde investiert 1000e Euro um seinen Anwendern ein paar Klicks zu sparen... :-)
                        ArnoD
                        #296
                        Ein Anwendungsfall ist, dass dein Verbrauch in der Nacht zu gering ist und dein Speicher am Morgen noch so voll ist, dass du Überkapazitäten nicht mehr puffern kannst, und du somit in die Abregelung kommen würdest. Dann kannst du am Morgen mit unload deinen Speicher ins Netz entladen und so Platz schafen.
                        Den zweiten Anwendungsfall verwende ich bei schönem Wetter (Einstellung2), indem ich unload = BatterieSoC einstelle. Dann wird nicht entladen aber das Laden der Batterie bis zum Beginn der Regelung verhindert und ermöglicht so erst später zu laden.
                        Da hast du recht ist ein Denkfehler von mir.
                        smartboartS 2 Antworten Letzte Antwort
                        • A ArnoD
                          smartboartS Offline
                          smartboartS Offline
                          smartboart
                          #297
                          @ArnoD super Erklärung, jetzt hab auch ich es kapiert! Kam bei mir nur noch nicht vor, weil meine Frau immer erst Abends anfängt strom zu verbrauchen...😬
                          • A ArnoD
                            smartboartS Offline
                            smartboartS Offline
                            smartboart
                            #298
                            @ArnoD ich glaube ich mache mir zu jedem Einstellungsparameter noch nen info button in welchem die Funktionen erklärt angezeigt werden können...
                              ArnoD
                              #299
                              Hier die Ladekurve von heute:
                              Die grüne Linie zeigt die Ladeleistung der Batterie. Am Anfang wird nicht geladen (das macht unload=BatterieSoC) ,dann beginnt die Laderegelung und die Batterie wird mit einer niedrigen konstanten Leistung geladen. Um ca. 15:45 Uhr ist die Laderegelung beendet und es wird auf den Wert Ladeende2 geladen. Hätte ich jetzt wärend der Laderegulung einen niedrigeren Eigenverbrauch, sodass ich in die Abregelung kommen würde, Hätte E3DC-Control die Ladeleistung für diese Spitzen erhöht und eine Abregelung verhindert. Absolut Batterieschonend und mit der Steuerung von E3DC leider nicht realisierbar.
                              • A ArnoD
                                smartboartS Offline
                                smartboartS Offline
                                smartboart
                                #300
                                @ArnoD ja cool....
                                Aber schon krass, diesen Peak von Batsoc nach unten habe ich auch fast jede nacht...hab schon nen ticket aufgemacht...was ist das?
                                • A ArnoD
                                  smartboartS Offline
                                  smartboartS Offline
                                  smartboart
                                  #301
                                  ja das ist voll cool...
                                  in dem Bereich lasse ich im Moment immer die klima losmaschieren...bei dem Wetter genau richtig...Aber das ist natürlich so besser... die klima brauche ich ja nicht immer...
                                    @ArnoD ja cool....
                                    ArnoD
                                    #302
                                    @smartboart
                                    Habe mal im Photovoltaik Forum gelesen, bringe es leider nicht mehr ganz zusammen, irgendwas macht E3DC in der Nacht mit dem Wechselrichter. Neustart, Justage oder so was ähnliches, fällt mir jetzt nicht mehr ein. Kann vielleicht @stevie77 beantworten.
                                    smartboartS S 3 Antworten Letzte Antwort
                                    • A ArnoD
                                      @smartboart
                                      smartboartS Offline
                                      smartboartS Offline
                                      smartboart
                                      #303
                                      @ArnoD ok...also kein Fehler...mal gespannt was die Antwort ist auf das ticket...Dachte das hat vlt. was mit meinen Lastabwurf Nachts im Notstrombetrieb zu tun...Würde ja passen...
                                      • A ArnoD
                                        @smartboart
                                        smartboartS Offline
                                        smartboartS Offline
                                        smartboart
                                        #304
                                        @ArnoD Noch ne Frag zu den Zeiten,
                                        muss ich die in vis noch umrechnen oder passt die Eingabe zu meiner Systemzeit?
                                        EDIT: und zu dem Code Teil...
                                        ist das nicht überflüssig?
                                        oder verstehe ich es nur nicht..
                                          // Korrekturwert abziehen wenn Prognose über 87 kWh
                                          // ??????????ist das Ergebnis nicht immer das selbe?????????????????
                                            if (Prognose_kWh_heute > 87) {Prognose_kWh_heute = Prognose_kWh_heute;}
                                            if (Prognose_kWh_Tag1 > 87) {Prognose_kWh_Tag1 = Prognose_kWh_Tag1;}
                                            if (Prognose_kWh_Tag2 > 87) {Prognose_kWh_Tag2 = Prognose_kWh_Tag2;}
                                            if (Prognose_kWh_Tag3 > 87) {Prognose_kWh_Tag3 = Prognose_kWh_Tag3;}
                                        • A ArnoD
                                          @smartboart
                                          stevie77
                                          #305
                                          @smartboart Nee, kann ich nichts dazu sagen. Außer dass ich das selbst mit meinem PRO noch nie hatte. Bei mir geht das immer gleichmäßig nach unten. Ich glaub' ich hab' aber auch so gut wie nie ne Notstromreserve eingestellt.
                                          @ArnoD Dein Akku ist einfach viel zu groß. :-D Bei einem normal dimensionierten Speicher (oder einer dem Verbrauch angepassten Speichergröße) schafft man fast nen Zyklus und braucht unload deshalb nie. ;-) Aber sie dir gegönnt, will keine Speichergrößendiskussion anzetteln.
                                          smartboartS A 3 Antworten Letzte Antwort
