  3. Entwicklung
  4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
    1.0k
lgtv
861 Beiträge 113 Kommentatoren 397.0k Aufrufe 69 Beobachtet
  • ChaotC Chaot
    @SchuetzeSchulz Ich habe heute gemerkt das der Adapter scheinbar bei mir vollständig ausgefallen ist.
    Fehler im Log:
    host.ioBroker	2020-07-22 23:38:44.976	info	"system.adapter.lgtv.0" disabled
    host.ioBroker	2020-07-22 23:38:39.874	info	Restart adapter system.adapter.lgtv.0 because enabled
    host.ioBroker	2020-07-22 23:38:39.873	error	instance system.adapter.lgtv.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker	2020-07-22 23:38:39.873	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.ioBroker	2020-07-22 23:38:39.873	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
    host.ioBroker	2020-07-22 23:38:39.872	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
    host.ioBroker	2020-07-22 23:38:39.872	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
    host.ioBroker	2020-07-22 23:38:39.872	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
    host.ioBroker	2020-07-22 23:38:39.872	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
    host.ioBroker	2020-07-22 23:38:39.872	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:622:5)
    host.ioBroker	2020-07-22 23:38:39.871	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:344:15)
    host.ioBroker	2020-07-22 23:38:39.871	error	Caught by controller[0]: at new Adapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:393:32)
    host.ioBroker	2020-07-22 23:38:39.871	error	Caught by controller[0]: at JSON.parse (<anonymous>)
    host.ioBroker	2020-07-22 23:38:39.870	error	Caught by controller[0]: SyntaxError: Unexpected token } in JSON at position 520
    host.ioBroker	2020-07-22 23:38:39.870	error	Caught by controller[0]: ^
    host.ioBroker	2020-07-22 23:38:39.869	error	Caught by controller[0]: },
    host.ioBroker	2020-07-22 23:38:39.869	error	Caught by controller[0]: undefined:17
    host.ioBroker	2020-07-22 23:38:38.513	info	instance system.adapter.lgtv.0 started with pid 17044
    host.ioBroker	2020-07-22 23:38:38.456	info	"system.adapter.lgtv.0" enabled
    Betroffenes Gerät: LG 75UK6200PLB
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    #633
    @Chaot sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
    Bei mir das selbe. Version 1.1.9
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    sigi234S liv-in-skyL ChaotC 3 Antworten Letzte Antwort
    • Jey CeeJ Jey Cee
      sigi234S Online
      sigi234S Online
      #634
      @Jey-Cee sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
      Läuft bei mir einwandfrei.
      • Jey CeeJ Jey Cee
        liv-in-skyL Offline
        liv-in-skyL Offline
        #635
        @Jey-Cee lief bei mir gestern abend noch 1.1.9
        • Jey CeeJ Jey Cee
          ChaotC Offline
          ChaotC Offline
          Chaot
          #636
          @Jey-Cee Die Lösung von dirkhe hat bei mir geholfen.
          Deinstallieren und Ordner löschen. Dann die 1.1.9 komplett neu installieren.
          XxJooOX 1 Antwort Letzte Antwort
          • ChaotC Chaot
            XxJooOX Offline
            XxJooOX Offline
            XxJooO
            #637
            Das scheint aber nur bei denen zu funktionieren, bzw. die zu betreffen, die vorher ein Installationsproblem hatten. Wenn ich jetzt deinstalliere, dann ist der o.g. Ordner schon nicht mehr vorhanden.
            Es scheint also noch ein etwas tieferes Problem zu sein. Denn auch bei mir hat er gestern den ganzen Tag nicht gearbeitet. Erst nach De- und Neuinstallation kommen jetzt wieder Logs vom Adapter...
            ioBroker auf Intel NUC - Homematic CCU3/pivCCU auf Raspi 3B+
            • XxJooOX XxJooO
              ChaotC Offline
              ChaotC Offline
              Chaot
              #638
              @XxJooO Ich hatte eigentlich nie derartige Probleme. Alle Updates wurden immer ohne Fehlermeldungen installiert. Bis eben die 1.1.9 plötzlich nicht mehr lief.
              Nach der Deinstallation hatte ich dann eine Fehlermeldung und konnte den Adapter nicht mehr neu installieren.
              Nach dem Löschen des Ordners hat dann alles ganz normal funktioniert.
              • D dirkhe
                @Ja-rod adapter deinstallieren und dann ggf. Noch unter iobroker/node_modules/ioBroker.lgtv löschen
                XxJooOX Offline
                XxJooOX Offline
                XxJooO
                schrieb am zuletzt editiert von XxJooO
                #639
                @dirkhe ,
                weiterhin nur unerklärliche Logs.
                2020-08-01 00:12:24.937 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: true
                2020-08-01 00:12:26.198 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: false
                2020-08-01 01:16:10.608 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV Connection wurde geändert auf: false
                2020-08-01 11:29:19.639 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV Connection wurde geändert auf: true
                2020-08-01 11:29:19.778 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: true
                2020-08-01 12:57:05.938 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: false
                2020-08-01 12:58:47.989 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: true
                2020-08-01 13:54:21.722 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: false
                2020-08-01 14:18:08.245 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV Connection wurde geändert auf: false
                2020-08-01 16:39:24.309 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV Connection wurde geändert auf: true
                2020-08-01 16:39:24.438 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: true
                2020-08-01 17:05:47.384 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: false
                2020-08-01 17:22:15.152 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV Connection wurde geändert auf: false
                2020-08-01 19:17:36.126 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV Connection wurde geändert auf: true
                2020-08-01 19:17:36.251 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: true
                2020-08-01 19:22:07.597 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: false
                2020-08-01 19:23:12.193 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: true
                2020-08-01 19:23:14.680 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: false
                2020-08-01 21:30:28.208 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV Connection wurde geändert auf: false
                2020-08-01 21:59:28.606 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV Connection wurde geändert auf: true
                2020-08-01 21:59:28.744 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: true
                2020-08-01 21:59:51.096 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: false
                2020-08-01 22:04:12.290 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: true
                2020-08-01 22:04:16.426 - info: javascript.0 (28694) script.js.Geräte.Fernseher_Wohnzimmer: TV ist ON wurde geändert auf: false
                gelogged wurde mit diesem Script:
                  <block type="on_ext" id="~%-|m!#aFtBnPM:)n1`q" x="-513" y="-938">
                    <value name="OID0">
                      <shadow type="field_oid" id="GH4ghj;]BzcVvEZ^;Qu^">
                        <field name="oid">lgtv.0.info.connection</field>
                      </shadow>
                    </value>
                    <statement name="STATEMENT">
                      <block type="controls_if" id="JcF9/z2]UigXs!}q#T3D">
                        <value name="IF0">
                          <block type="on_source" id="lkgKvbBCP;hT.F=q1E|y">
                          </block>
                        </value>
                        <statement name="DO0">
                          <block type="telegram" id="cAiPQpy@H88kL9ztFDpK">
                            <field name="INSTANCE">.0</field>
                            <field name="LOG"></field>
                            <value name="MESSAGE">
                              <shadow type="text" id="eDEGU76AN)9aB*%%o??l">
                                <field name="TEXT">Der Fernseher wurde verbunden...</field>
                              </shadow>
                            </value>
                          </block>
                        </statement>
                        <statement name="ELSE">
                          <block type="telegram" id="Xk+ZK!d5*_C`*2MaSWc$">
                              <shadow type="text" id=".D(]iq:yuP@GcB2MwW|M">
                                <field name="TEXT">Der Fernseher wurde getrennt...</field>
                              </shadow>
                            </value>
                          </block>
                        </statement>
                        <next>
                          <block type="debug" id="rXsXe4H!P0aaj?-CSod/">
                            <value name="TEXT">
                              <shadow type="text">
                              </shadow>
                              <block type="text_join" id="dE-fb$4m.TNBFJe~)w*K">
                                <value name="ADD0">
                                  <block type="text" id="JOlNkyB|qc{/06D:$Mzy">
                                    <field name="TEXT">TV Connection wurde geändert auf: </field>
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="on_source" id="+V-^P-VU%(sv!1kzc`Pk">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                    <next>
                      <block type="on_ext" id="aS/^]x:x%;8G^0RGW%NW">
                        <value name="OID0">
                          <shadow type="field_oid" id="@t{hiomC^aAxKCWv%``n">
                            <field name="oid">lgtv.0.states.on</field>
                          </shadow>
                        </value>
                          <block type="controls_if" id="g5):1xP4YcznX@S,YP@0">
                            <value name="IF0">
                              <block type="on_source" id="9/6Y)/xb.:Z9eTq;7wxN">
                              </block>
                            </value>
                              <block type="control" id="GBA3!L}K|1{6_8SBn)j`">
                                <field name="OID">0_userdata.0.Geraete.Fernseher_ist_an</field>
                                <value name="VALUE">
                                  <block type="logic_boolean" id="NpHuP=Ia^)rJ6`FU:.U2">
                                  </block>
                                </value>
                                <next>
                                  <block type="telegram" id="2oPfv{ptPp%y[jwp^@?0">
                                      <shadow type="text" id="lLV8E7P8=x,g1j.M[`#-">
                                        <field name="TEXT">Der Fernseher wurde angeschaltet...</field>
                                      </shadow>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                              <block type="control" id="5%b)MX9s8AN:G-.(m6T~">
                                  <block type="logic_boolean" id="^M,k;EVDTxi*:w@wWfqT">
                                  </block>
                                </value>
                                <next>
                                  <block type="telegram" id="VxKMn*kukZ9.LFX4,|f`">
                                      <shadow type="text" id="sKyyX,f?IkAZP`RFQReF">
                                        <field name="TEXT">Der Fernseher wurde ausgeschaltet...</field>
                                      </shadow>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                            <next>
                              <block type="debug" id="^W%t]$+b_P:Pv;2=c}#,">
                                <value name="TEXT">
                                  <shadow type="text" id="!AKS?w5w/-E^HeHTSaX~">
                                  </shadow>
                                  <block type="text_join" id="*zhDeTqs9oGG8W!7yN,o">
                                    <value name="ADD0">
                                      <block type="text" id="e8Byjxj5|fw6aS{=4rAD">
                                        <field name="TEXT">TV ist ON wurde geändert auf: </field>
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="on_source" id="d?DkP@Mn_-9L*t((]HBO">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </xml>
                Man beachte diese beiden Zeiten im Log:
                und
                Hier wurde der DP von true beim anschalten binnen einer Sekunde wieder auf false geloggt, obwohl der TV nicht aktiv geschaltet wurde.
                Dazwischen sind immer wieder auch korrekte Logs des DP. Aber so ist das nicht brauchbar. Ich habe den Adapter jetzt mehrfach neu installiert. Keine Änderung.
                Kann es am Node liegen? Auch mit V 1.1.5 habe ich inzwischen die gleichen Problemlogs. Als es unter V 1.1.5 noch korrekt funktionierte war ich bei node noch auf 10.x. Inzwischen auf 12.18.3.
                Was ist denn mit den anderen Jungs, die zuletzt Probleme gemeldet hatten?
                PS:
                Interessant noch die influxDB des DP Fernseher_ist_an für den o.g. Zeitraum, der durch das Skript geändert und geloggt wird...
                true	false	javascript.0	2020-08-01 00:12:24.938
                false	false	javascript.0	2020-08-01 00:12:26.201
                false	false	javascript.0	2020-08-01 00:59:54.036
                true	false	javascript.0	2020-08-01 11:29:14.662
                true	false	javascript.0	2020-08-01 11:29:19.782
                false	false	javascript.0	2020-08-01 12:57:05.943
                true	false	javascript.0	2020-08-01 12:58:47.992
                false	false	javascript.0	2020-08-01 13:54:21.727
                false	false	javascript.0	2020-08-01 13:56:37.642
                true	false	javascript.0	2020-08-01 16:39:20.764
                true	false	javascript.0	2020-08-01 16:39:24.444
                false	false	javascript.0	2020-08-01 17:05:47.386
                false	false	javascript.0	2020-08-01 17:05:54.134
                true	false	javascript.0	2020-08-01 19:17:28.918
                true	false	javascript.0	2020-08-01 19:17:36.264
                false	false	javascript.0	2020-08-01 19:22:07.600
                true	false	javascript.0	2020-08-01 19:23:12.195
                false	false	javascript.0	2020-08-01 19:23:14.683
                false	false	javascript.0	2020-08-01 21:14:03.844
                true	false	javascript.0	2020-08-01 21:59:20.779
                true	false	javascript.0	2020-08-01 21:59:28.747
                false	false	javascript.0	2020-08-01 21:59:50.428
                false	false	javascript.0	2020-08-01 21:59:51.099
                true	false	javascript.0	2020-08-01 22:04:12.292
                false	false	javascript.0	2020-08-01 22:04:16.431
                • XxJooOX XxJooO
                  @dirkhe ,
                      <value name="OID0">
                        </shadow>
                      </value>
                          <value name="IF0">
                            </block>
                          </value>
                                </shadow>
                              </value>
                            </block>
                          </statement>
                                </shadow>
                              </value>
                            </block>
                          </statement>
                          <next>
                              <value name="TEXT">
                                </shadow>
                                  <value name="ADD0">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <next>
                          <value name="OID0">
                            </shadow>
                          </value>
                              <value name="IF0">
                                </block>
                              </value>
                                    </block>
                                  </value>
                                  <next>
                                        </shadow>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                                    </block>
                                  </value>
                                  <next>
                                        </shadow>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                              <next>
                                  <value name="TEXT">
                                    </shadow>
                                      <value name="ADD0">
                                        </block>
                                      </value>
                                      <value name="ADD1">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </xml>
                  und
                  PS:
                  dirkhe
                  #640
                  @XxJooO sorry, mit blocky kann ich dir nicht helfen, das ist mir zu kompliziert. Schalte doch mal deine scripte ab und setzte de History mal auf den datenpunkt. Weil in deinem Log sehe ich immer nur was von JavaScript, nichts vom Adapter.
                  • D dirkhe
                    XxJooOX Offline
                    XxJooOX Offline
                    XxJooO
                    #641
                    @dirkhe , bitte schön...
                    true	true	lgtv.0	2020-07-29 12:07:55.874
                    false	true	lgtv.0	2020-07-29 14:30:18.658
                    true	true	lgtv.0	2020-07-29 14:53:05.074
                    false	true	lgtv.0	2020-07-29 15:15:20.727
                    true	true	lgtv.0	2020-07-29 17:10:45.873
                    false	true	lgtv.0	2020-07-29 19:13:14.852
                    true	true	lgtv.0	2020-07-29 20:38:27.763
                    false	true	lgtv.0	2020-07-29 21:58:20.164
                    true	true	lgtv.0	2020-07-29 22:00:55.765
                    false	true	lgtv.0	2020-07-30 10:13:10.677
                    true	true	lgtv.0	2020-07-30 10:36:00.946
                    false	true	lgtv.0	2020-07-30 12:07:32.753
                    true	true	lgtv.0	2020-07-30 12:11:25.597
                    false	true	lgtv.0	2020-07-30 13:01:32.676
                    true	true	lgtv.0	2020-07-30 15:05:51.057
                    false	true	lgtv.0	2020-07-30 16:04:59.603
                    true	true	lgtv.0	2020-07-30 16:12:52.545
                    false	true	lgtv.0	2020-07-30 16:12:54.697
                    true	true	lgtv.0	2020-07-30 18:35:13.491
                    false	true	lgtv.0	2020-07-30 18:48:36.277
                    true	true	lgtv.0	2020-07-30 18:50:18.088
                    false	true	lgtv.0	2020-07-30 18:50:18.741
                    true	true	lgtv.0	2020-07-30 19:13:28.994
                    false	true	lgtv.0	2020-07-30 19:13:29.048
                    true	true	lgtv.0	2020-07-30 19:17:33.233
                    false	true	lgtv.0	2020-07-30 19:17:34.089
                    true	true	lgtv.0	2020-07-30 20:08:03.876
                    false	true	lgtv.0	2020-07-30 20:08:04.654
                    true	true	lgtv.0	2020-07-30 21:40:47.101
                    false	true	lgtv.0	2020-07-30 21:41:13.149
                    true	true	lgtv.0	2020-07-30 21:41:24.865
                    false	true	lgtv.0	2020-07-30 21:41:28.671
                    true	true	lgtv.0	2020-07-30 21:41:50.303
                    false	true	lgtv.0	2020-07-30 21:41:53.400
                    true	true	lgtv.0	2020-08-03 18:29:47.445
                    false	true	lgtv.0	2020-08-03 19:07:06.929
                    true	true	lgtv.0	2020-08-03 19:19:48.598
                    false	true	lgtv.0	2020-08-03 19:56:42.319
                    true	true	lgtv.0	2020-08-03 20:05:26.257
                    false	true	lgtv.0	2020-08-03 20:05:28.094
                    true	true	lgtv.0	2020-08-03 21:28:42.841
                    false	true	lgtv.0	2020-08-03 21:35:01.458
                    true	true	lgtv.0	2020-08-04 21:48:39.513
                    false	true	lgtv.0	2020-08-04 22:53:49.119
                    true	true	lgtv.0	2020-08-05 19:43:40.679
                    false	true	lgtv.0	2020-08-05 21:16:39.059
                    true	true	lgtv.0	2020-08-05 21:28:17.563
                    false	true	lgtv.0	2020-08-05 21:28:21.357
                    Es sind genügend geloggte Ereignisse bei denen, an- und binnen einer Sekunde wieder ausgeschaltet geloggt wurde...
                    usw.
                    Und ich möchte betonen, dass die Corona-Kinder under der Rest der Familie im Ausland weilt. Ich bin alleine und veranschalte keine Schaltorgien...
                    • XxJooOX XxJooO
                      usw.
                      dirkhe
                      #642
                      @XxJooO hattest du deine JavaScript bzw blocky abgeschaltet? Wie ich schon mal geschrieben habe, müsste im debug Log dann auch diese schaltvotgänge geloggt werden
                      • D dirkhe
                        DalmatinoD Offline
                        DalmatinoD Offline
                        Dalmatino
                        #643
                        @dirkhe
                        Danke, mir hats geholfen
                        Lg👍🏻
                          blackeagle998
                          #644
                          bei mir wird die aktuelle Lautstärke im Datenpunkt Volume nicht angezeigt (bleibt leer).
                          Die Steuerung lauter/leiser funktioniert.
                          Das betrifft alle Eingänge, egal ob interne Antenne oder HDMI.
                          Adapterversion: 1.1.9
                          WebOS: 5.1.0-3304
                          Hat noch jemand das Problem?
                          • B blackeagle998
                            WebOS: 5.1.0-3304
                            dirkhe
                            #645
                            @blackeagle998 kannst du mal den adapter auf debug stellen und dann die Lautstärke ändern und das dann hier Posten, bitte
                            • D dirkhe
                              blackeagle998
                              schrieb am zuletzt editiert von blackeagle998
                              #646
                              @dirkhe
                              lgtv.0	2020-08-21 00:04:30.573	debug	(22310) TV is off
                              lgtv.0	2020-08-21 00:04:29.071	debug	(22310) DEBUGGING getForegroundAppInfo: {"subscribed":true,"appId":"","returnValue":true,"windowId":"","processId":""}
                              lgtv.0	2020-08-21 00:04:28.703	debug	(22310) State change "remote.power" - VALUE: {"val":true,"ack":false,"ts":1597961068696,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597961068696}
                              lgtv.0	2020-08-21 00:04:28.702	debug	(22310) State change "remote.power" - VALUE: true
                              lgtv.0	2020-08-21 00:04:15.197	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":4,"soundOutput":"tv_speaker","maxVolume":100},"retur
                              lgtv.0	2020-08-21 00:04:15.191	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                              lgtv.0	2020-08-21 00:04:15.191	debug	(22310) State change "states.volumeDown" - VALUE: true
                              lgtv.0	2020-08-21 00:04:14.366	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":5,"soundOutput":"tv_speaker","maxVolume":100},"retur
                              lgtv.0	2020-08-21 00:04:14.349	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                              lgtv.0	2020-08-21 00:04:14.348	debug	(22310) State change "states.volumeDown" - VALUE: true
                              lgtv.0	2020-08-21 00:04:13.101	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeUp","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":6,"soundOutput":"tv_speaker","maxVolume":100},"returnV
                              lgtv.0	2020-08-21 00:04:13.086	debug	(22310) Sending volumeUp true command to WebOS TV: 192.xxx.xxx.xx
                              lgtv.0	2020-08-21 00:04:13.085	debug	(22310) State change "states.volumeUp" - VALUE: true
                              lgtv.0	2020-08-21 00:04:11.528	debug	(22310) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                              lgtv.0	2020-08-21 00:04:11.506	debug	(22310) State change "states.soundOutput" - VALUE: tv_speaker
                              lgtv.0	2020-08-21 00:04:09.639	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":5,"soundOutput":"tv_speaker","maxVolume":100},"retur
                              lgtv.0	2020-08-21 00:04:09.633	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                              lgtv.0	2020-08-21 00:04:09.632	debug	(22310) State change "states.volumeDown" - VALUE: true
                              lgtv.0	2020-08-21 00:04:08.235	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":6,"soundOutput":"tv_speaker","maxVolume":100},"retur
                              lgtv.0	2020-08-21 00:04:08.230	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                              lgtv.0	2020-08-21 00:04:08.230	debug	(22310) State change "states.volumeDown" - VALUE: true
                              lgtv.0	2020-08-21 00:04:07.088	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":7,"soundOutput":"tv_speaker","maxVolume":100},"retur
                              lgtv.0	2020-08-21 00:04:07.082	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                              lgtv.0	2020-08-21 00:04:07.081	debug	(22310) State change "states.volumeDown" - VALUE: true
                              lgtv.0	2020-08-21 00:04:01.907	debug	(22310) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                              lgtv.0	2020-08-21 00:04:01.863	debug	(22310) getCurrentSWInformation: {"returnValue":true,"product_name":"webOSTV 5.0","model_name":"HE_DTV_W20H_AFADABAA","sw_type":"FIRMWARE","major_ver":"03","minor_ver":"10.28","country":"DE","country
                              lgtv.0	2020-08-21 00:04:01.555	debug	(22310) getSystemInfo: {"returnValue":true,"features":{"dvr":false},"receiverType":"DVB","modelName":"86UN85006LA","programMode":true}
                              lgtv.0	2020-08-21 00:04:01.504	debug	(22310) renew connection in one minute for stable subscriptions...
                              lgtv.0	2020-08-21 00:04:01.491	debug	(22310) Service list: {"returnValue":true,"services":[{"name":"api","version":1},{"name":"audio","version":1},{"name":"config","version":1},{"name":"externalpq","version":1},{"name":"media.controls",
                              lgtv.0	2020-08-21 00:04:01.433	debug	(22310) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":8,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerI
                              lgtv.0	2020-08-21 00:04:01.431	debug	(22310) cur app is com.webos.app.hdmi1
                              lgtv.0	2020-08-21 00:04:01.430	debug	(22310) DEBUGGING getForegroundAppInfo: {"appId":"com.webos.app.hdmi1","subscribed":true,"returnValue":true,"windowId":"","processId":""}
                              lgtv.0	2020-08-21 00:04:01.218	debug	(22310) WebOS TV Connected
                              lgtv.0	2020-08-21 00:04:00.707	debug	(22310) Connecting to WebOS TV: ws://192.xxx.xxx.xx:3000
                              lgtv.0	2020-08-21 00:03:59.668	debug	(22310) Send WOL to MAC: {xx:xx:xx:xx:xx:xx} OK
                              lgtv.0	2020-08-21 00:03:59.657	debug	(22310) GetState mac: {"val":"xx:xx:xx:xx:xx:xx","ack":true,"ts":1597957048597,"q":0,"from":"system.adapter.lgtv.0","user":"system.user.admin","lc":1597954699324}
                              lgtv.0	2020-08-21 00:03:59.654	debug	(22310) State change "states.power" - VALUE: true
                              • B blackeagle998
                                @dirkhe
                                dirkhe
                                #647
                                @blackeagle998 ok, anscheinend haben die das Antwort JSON geändert. Kannst du mir bitte nochmal den gefallen tun und mute drücken und das loggen? Ich würde das dann einbauen.
                                @SchuetzeSchulz ich denke, wir müssen hier nach cause suchen anstelle von changed. Soll ich das machen oder willst du das direkt machen?
                                B S 2 Antworten Letzte Antwort
                                • D dirkhe
                                  blackeagle998
                                  #648
                                  @dirkhe
                                  Na aber sehr gerne doch, Mute geht zu schalten:
                                  2020-08-21 21:38:50.176  - debug: lgtv.0 (19579) adapter.config = {"ip":"192.xxx.xxx.xx","mac":"xx:xx:xx:xx:xx:xx","timeout":"5000","reconnect":"5000","power":true,"healthIntervall":""}
                                  2020-08-21 21:38:50.225  - debug: lgtv.0 (19579) Connecting to WebOS TV: ws://192.xxx.xxx.xx:3000
                                  2020-08-21 21:38:50.331  - debug: lgtv.0 (19579) WebOS TV Connected
                                  2020-08-21 21:38:50.349  - debug: lgtv.0 (19579) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":10,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerId":"secondscreen.client"}
                                  2020-08-21 21:38:50.416  - debug: lgtv.0 (19579) DEBUGGING getForegroundAppInfo: {"appId":"com.webos.app.hdmi1","subscribed":true,"returnValue":true,"windowId":"","processId":""}
                                  2020-08-21 21:38:50.417  - debug: lgtv.0 (19579) cur app is com.webos.app.hdmi1
                                  2020-08-21 21:38:50.424  - debug: lgtv.0 (19579) Service list: {"returnValue":true,"services":[{"name":"api","version":1},{"name":"audio","version":1},{"name":"config","version":1},{"name":"externalpq","version":1},{"name":"media.controls","version":1},{"name":"media.viewer","version":1},{"name":"pairing","version":1},{"name":"settings","version":1},{"name":"system","version":1},{"name":"system.launcher","version":1},{"name":"system.notifications","version":1},{"name":"timer","version":1},{"name":"tv","version":1},{"name":"user","version":1},{"name":"webapp","version":2}]}
                                  2020-08-21 21:38:50.434  - debug: lgtv.0 (19579) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                                  2020-08-21 21:38:50.437  - debug: lgtv.0 (19579) renew connection in one minute for stable subscriptions...
                                  2020-08-21 21:38:50.443  - debug: lgtv.0 (19579) getSystemInfo: {"returnValue":true,"features":{"dvr":false},"receiverType":"DVB","modelName":"xxx","programMode":true}
                                  2020-08-21 21:38:50.499  - debug: lgtv.0 (19579) getCurrentSWInformation: {"returnValue":true,"product_name":"webOSTV 5.0","model_name":"xxx","sw_type":"FIRMWARE","major_ver":"03","minor_ver":"10.28","country":"DE","country_group":"EU","device_id":"xx:xx:xx:xx:xx:xx","auth_flag":"N","ignore_disable":"N","eco_info":"01","config_key":"00","language_code":"de-DE"}
                                  2020-08-21 21:39:00.438  - debug: lgtv.0 (19579) State change "states.soundOutput" - VALUE: tv_speaker
                                  2020-08-21 21:39:00.466  - debug: lgtv.0 (19579) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                                  2020-08-21 21:39:25.476  - debug: lgtv.0 (19579) State change "states.mute" - VALUE: true
                                  2020-08-21 21:39:25.477  - debug: lgtv.0 (19579) Sending mute true command to WebOS TV: 192.xxx.xxx.xx
                                  2020-08-21 21:39:25.486  - debug: lgtv.0 (19579) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":true,"volume":10,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerId":"com.webos.service.apiadapter"}
                                  2020-08-21 21:39:31.050  - debug: lgtv.0 (19579) State change "states.mute" - VALUE: false
                                  2020-08-21 21:39:31.051  - debug: lgtv.0 (19579) Sending mute false command to WebOS TV: 192.xxx.xxx.xx
                                  2020-08-21 21:39:31.061  - debug: lgtv.0 (19579) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":10,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerId":"com.webos.service.apiadapter"}
                                  2020-08-21 21:39:35.216  - debug: lgtv.0 (19579) system.adapter.admin.0: logging true
                                  2020-08-21 21:39:48.305  - debug: lgtv.0 (19579) system.adapter.admin.0: logging false
                                  2020-08-21 21:39:50.443  - debug: lgtv.0 (19579) Connection closed: 1000
                                  2020-08-21 21:39:50.941  - debug: lgtv.0 (19579) Connecting to WebOS TV: ws://192.xxx.xxx.xx:3000
                                  2020-08-21 21:39:51.006  - debug: lgtv.0 (19579) WebOS TV Connected
                                  2020-08-21 21:39:51.027  - debug: lgtv.0 (19579) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":10,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerId":"secondscreen.client"}
                                  2020-08-21 21:39:51.070  - debug: lgtv.0 (19579) DEBUGGING getForegroundAppInfo: {"appId":"com.webos.app.hdmi1","subscribed":true,"returnValue":true,"windowId":"","processId":""}
                                  2020-08-21 21:39:51.071  - debug: lgtv.0 (19579) cur app is com.webos.app.hdmi1
                                  2020-08-21 21:39:51.075  - debug: lgtv.0 (19579) Service list: {"returnValue":true,"services":[{"name":"api","version":1},{"name":"audio","version":1},{"name":"config","version":1},{"name":"externalpq","version":1},{"name":"media.controls","version":1},{"name":"media.viewer","version":1},{"name":"pairing","version":1},{"name":"settings","version":1},{"name":"system","version":1},{"name":"system.launcher","version":1},{"name":"system.notifications","version":1},{"name":"timer","version":1},{"name":"tv","version":1},{"name":"user","version":1},{"name":"webapp","version":2}]}
                                  2020-08-21 21:39:51.083  - debug: lgtv.0 (19579) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                                  2020-08-21 21:39:51.088  - debug: lgtv.0 (19579) getSystemInfo: {"returnValue":true,"features":{"dvr":false},"receiverType":"DVB","modelName":"xxx","programMode":true}
                                  2020-08-21 21:39:51.155  - debug: lgtv.0 (19579) getCurrentSWInformation: {"returnValue":true,"product_name":"webOSTV 5.0","model_name":"xxx","sw_type":"FIRMWARE","major_ver":"03","minor_ver":"10.28","country":"DE","country_group":"EU","device_id":"xx:xx:xx:xx:xx:xx","auth_flag":"N","ignore_disable":"N","eco_info":"01","config_key":"00","language_code":"de-DE"}
                                  • D dirkhe
                                    SchuetzeSchulz
                                    #649
                                    @dirkhe Kannst Du gern machen.
                                    Machst Du dann einen Pull-Request?
                                    • B blackeagle998
                                      @dirkhe
                                      dirkhe
                                      #650
                                      @blackeagle998 Kannst du bitte mal von github (https://github.com/dirkhe/ioBroker.lgtv) installieren und schauen, ob es funktioniert? Ich habe jetzt mal zusätzlich die neue Struktur abgefragt. Wenn es klappt, würde ich den PR stellen
                                      • D dirkhe
                                        blackeagle998
                                        #651
                                        @dirkhe
                                        Funktioniert, besten Dank für den schnellen Support!!!
                                          SchuetzeSchulz
                                          #652
                                          Pull request ist gemerged. :)
                                          Danke Dirk!
