  4. Test Adapter doorio v2.1.2
door intercomdoorpitürsprechstelle
590 Beiträge 36 Kommentatoren 209.8k Aufrufe 39 Beobachtet
  • M MHeymann
    @Wal sagte in Test Adapter doorio v1.0.x:
    systemctl
    Das dachte ich eigentlich auch. Wenn ich den Pi neustarte und lasse mir den Status von baresip anzeigen bekomme ich u.a. Ausgabe.
    ● baresip.service - baresip
       Loaded: loaded (/etc/systemd/system/baresip.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Sat 2020-08-01 17:39:09 CEST; 21min ago
     Main PID: 521 (code=exited, status=99)
    Aug 01 17:39:08 Klingel systemd[1]: Started baresip.
    Aug 01 17:39:08 Klingel baresip[521]: baresip v0.6.1 Copyright (C) 2010 - 2019 Alfred E. Heggestad et al.
    Aug 01 17:39:09 Klingel baresip[521]: Local network address:  IPv4=wlan0:192.168.2.26  IPv6=wlan0:fd00::b48f:f4bd:29b:a62f
    Aug 01 17:39:09 Klingel baresip[521]: tcp: sock_bind: bind: Cannot assign requested address (af=10, [fd00::b48f:f4bd:29b:a62f]:5060)
    Aug 01 17:39:09 Klingel baresip[521]: ua: SIP Transport failed: Cannot assign requested address
    Aug 01 17:39:09 Klingel baresip[521]: ua: init failed (Cannot assign requested address)
    Aug 01 17:39:09 Klingel baresip[521]: ua: stop all (forced=1)
    Aug 01 17:39:09 Klingel systemd[1]: baresip.service: Main process exited, code=exited, status=99/n/a
    Aug 01 17:39:09 Klingel systemd[1]: baresip.service: Failed with result 'exit-code'.
    wenn ich sudo systemctl enable baresip erneut ausführe bekomme ich folgende Ausgabe:
    pi@Klingel:/etc/systemd/system $ sudo systemctl enable baresip
    Synchronizing state of baresip.service with SysV service script with /lib/systemd/systemd-sysv-install.
    Executing: /lib/systemd/systemd-sysv-install enable baresip
    update-rc.d: error: baresip Default-Start contains no runlevels, aborting.
    Nach Eingabe von "systemctl start baresip" und "systemctl status baresip" funktioniert baresip.
       Active: active (running) since Sat 2020-08-01 18:06:55 CEST; 4s ago
     Main PID: 865 (baresip)
       CGroup: /system.slice/baresip.service
               └─865 /usr/bin/baresip -f /home/pi/.baresip
    Aug 01 18:06:55 Klingel baresip[865]: Populated 1 audio filter
    Aug 01 18:06:55 Klingel baresip[865]: Populated 0 video codecs
    Aug 01 18:06:55 Klingel baresip[865]: Populated 0 video filters
    Aug 01 18:06:55 Klingel baresip[865]: baresip is ready.
    Aug 01 18:06:55 Klingel baresip[865]: DoorIOSIP@192.168.2.1: {0/UDP/v4} 200 OK () [1 binding]
    Was mache ich falsch?
    WalW Offline
    WalW Offline
    Wal
    #148
    @MHeymann
    schalt mal ipv6 in der cmdline.txt aus.
    .... rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait ipv6.disable=1
    Walter
    DoorIO-Adapter
    • WalW Wal
      @MHeymann
      MHeymann
      #149
      @Wal
      Vielen lieben Dank. Jetzt funktioniert der Start beim hochfahren.
      ... Dann baue ich mal weiter.
      • M MHeymann
        @Wal
        MHeymann
        #150
        Na toll neues Problem :(
        Im ioBroker bekomme ich folgende Fehlermeldung:
        doorio.0	2020-08-01 18:50:35.102	error	(10064) uncaughtException: TypeError: Cannot read property 'val' of null
        doorio.0	2020-08-01 18:50:35.096	error	(10064) TypeError: Cannot read property 'val' of null at send2Server (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:40:50) at BaresipClient.onStateChange (/opt/iobroker/node_modules
        doorio.0	2020-08-01 18:50:35.090	error	(10064) uncaught exception: Cannot read property 'val' of null
        doorio.0	2020-08-01 18:45:34.864	error	(4324) uncaughtException: TypeError: Cannot read property 'val' of null
        doorio.0	2020-08-01 18:45:34.861	error	at processImmediate (timers.js:658:5)
        doorio.0	2020-08-01 18:45:34.861	error	at tryOnImmediate (timers.js:676:5)
        doorio.0	2020-08-01 18:45:34.861	error	at runCallback (timers.js:705:18)
        doorio.0	2020-08-01 18:45:34.861	error	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5388:34)
        doorio.0	2020-08-01 18:45:34.861	error	at Adapter.emit (events.js:198:13)
        doorio.0	2020-08-01 18:45:34.861	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.doorio/main.js:35:16)
        doorio.0	2020-08-01 18:45:34.861	error	at BaresipClient.onStateChange (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:37:41)
        doorio.0	2020-08-01 18:45:34.861	error	at send2Server (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:40:50)
        doorio.0	2020-08-01 18:45:34.861	error	(4324) TypeError: Cannot read property 'val' of null
        und der baresip Status dazu:
           Active: active (running) since Sat 2020-08-01 18:28:56 CEST; 18min ago
         Main PID: 479 (baresip)
                   └─479 /usr/bin/baresip -f /home/pi/.baresip
        Aug 01 18:34:10 Klingel baresip[479]: DoorIOSIP@192.168.2.1: {0/UDP/v4} 200 OK () [1 binding]
        Aug 01 18:38:40 Klingel baresip[479]: reg: sip:DoorIOSIP@192.168.2.1: 401 Unauthorized ()
        Aug 01 18:39:37 Klingel baresip[479]: DoorIOSIP@192.168.2.1: {0/UDP/v4} 200 OK () [1 binding]
        Aug 01 18:44:07 Klingel baresip[479]: reg: sip:DoorIOSIP@192.168.2.1: 401 Unauthorized ()
        Aug 01 18:44:44 Klingel baresip[479]: DoorIOSIP@192.168.2.1: {0/UDP/v4} 200 OK () [1 binding]
        Was könnte das sein?
        Thomas BraunT WalW 2 Antworten Letzte Antwort
        • M MHeymann
          #151
          @MHeymann
          Welche node-Version ist da installiert?
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          WalW 1 Antwort Letzte Antwort
          • M MHeymann
            WalW Offline
            WalW Offline
            Wal
            #152
            @MHeymann
            die Baresip-Meldungen sind i.O.
            Evtl. den Adapter auf Debug stellen, um mehr Log-Ausgabe zu erhalten.
            Diese Fehler kenne ich jetzt nicht.
            Walter
            DoorIO-Adapter
              @MHeymann
              WalW Offline
              WalW Offline
              Wal
              #153
              @Thomas-Braun sagte in Test Adapter doorio v1.0.x:
              @MHeymann
              Wie Thomas vermutet, könnte es auch an der Version von node liegen.
              Der Adapter ist für Node 10 u. 12, das ist i.M. Standard im ioBroker.
              Walter
              DoorIO-Adapter
              • WalW Wal
                @MHeymann
                MHeymann
                #154
                @Wal
                Es ist Node.js v10.22.0 installiert. Debug log schaue ich später mal nach.
                • M MHeymann
                  @Wal
                  #155
                  @MHeymann
                  Auch richtig?
                  Die Ausgabe der obigen Befehlskette würde helfen...
                  Ich würde auch auf node12 gehen.
                    @MHeymann
                    Auch richtig?
                    MHeymann
                    #156
                    Hier mal die Ausgabe.
                    root@ioBroker:~# which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    v10.22.0
                    /usr/bin/node
                    v10.22.0
                    /usr/bin/npm
                    6.14.6
                    nodejs:
                      Installed: 10.22.0-1nodesource1
                      Candidate: 10.22.0-1nodesource1
                      Version table:
                     *** 10.22.0-1nodesource1 500
                            500 https://deb.nodesource.com/node_10.x bionic/main amd64 Packages
                         8.10.0~dfsg-2ubuntu0.4 500
                            500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                         8.10.0~dfsg-2ubuntu0.2 500
                            500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                         8.10.0~dfsg-2 500
                            500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                    • M MHeymann
                      /usr/bin/nodejs
                      v10.22.0
                      /usr/bin/node
                      v10.22.0
                      /usr/bin/npm
                      6.14.6
                      nodejs:
                        Version table:
                           8.10.0~dfsg-2 500
                      #157
                      @MHeymann
                      Man meldet sich nicht als root an.
                      Unter Ubuntu immer als normaler User und dann bei Notwendigkeit mit sudo den Befehl absetzen.
                        @MHeymann
                        MHeymann
                        #158
                        @Thomas-Braun
                        Ok. Ist meine Testumgebung auf Proxmox. Aber ist ist ja nicht der Fehler oder?
                        • M MHeymann
                          @Thomas-Braun
                          #159
                          @MHeymann
                          Doch, das ist grundsätzlich ein Fehler. Das zerschießt dir u. U. die Pfade und Rechte.
                          Und auch in einem Testsystem arbeitet man nicht als root.
                            @MHeymann
                            MHeymann
                            #160
                            @Thomas-Braun
                            Da hast du sicherlich recht. Aber die anderen 30 Instanzen laufen ja problemlos.
                            • M MHeymann
                              @Thomas-Braun
                              #161
                              @MHeymann
                              Heißt jetzt genau was? Die doorio-Instanz aber nicht.
                              Jetzt meldest du dich als USER an und jagst den
                              iobroker fix
                              durch das System.
                              Vielleicht hast du auch baresip durch den root-login krumm installiert.
                              M 2 Antworten Letzte Antwort
                                @MHeymann
                                iobroker fix
                                durch das System.
                                MHeymann
                                schrieb am zuletzt editiert von MHeymann
                                #162
                                iobroker fix
                                Habe ich gemacht Fehler ist immer noch da.
                                Habe DoorIO im debug mode laufen lassen. Ich habe innerhalb weniger Minuten 1000de Einträge. Hatte das davor über mein Handy eingestellt und ca. eine Stunde laufen gelassen. Die Log Datei ist ca 550 MB groß. Ist das normal?
                                • M MHeymann
                                  iobroker fix
                                  #163
                                  @MHeymann
                                  Nein.
                                    @MHeymann
                                    iobroker fix
                                    durch das System.
                                    MHeymann
                                    #164
                                    baresip läuft auf nem anderen pi.
                                    • M MHeymann
                                      #165
                                      @MHeymann Orgelst du da auch als root rum?
                                        MHeymann
                                        #166
                                        @Thomas-Braun
                                        Nein.
                                        • M MHeymann
                                          @Thomas-Braun
                                          Nein.
                                          MHeymann
                                          #167
                                          Hier mal ein Auszug aus der Log.
                                          Log.txt
