  4. (Alexa Adapter) Cannot find module 'https-proxy-agent'
alexahttps-proxy-agenterror
31 Beiträge 7 Kommentatoren 5.9k Aufrufe 7 Beobachtet
  • C
    C
    Chrischo
    Dabei bleibt´s dann stehen und der Adapter startet nicht.
    • C Chrischo
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @Chrischo Und was sagt das Log? Und ist nodejs sauber?
      C 1 Antwort Letzte Antwort
        C
        C
        Chrischo
        @Thomas-Braun
        nicht viel Neues :-(
        host.raspberrypi	2020-07-19 14:20:20.839	error	instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi	2020-07-19 14:20:20.839	error	Caught by controller[0]: }
        host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: ]
        host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.alexa2/main.js'
        host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js',
        host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js',
        host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: requireStack: [
        host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
        host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
        host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
        host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
        host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
        host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js:41:23)
        host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
        host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
        host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
        host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
        host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
        host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js
        host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js
        host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: Require stack:
        host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: Error: Cannot find module 'https-proxy-agent'
        host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: ^
        host.raspberrypi	2020-07-19 14:20:20.834	error	Caught by controller[0]: throw err;
        host.raspberrypi	2020-07-19 14:20:20.834	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
        • C Chrischo
          @Thomas-Braun
          Thomas BraunT
          Thomas BraunT
          @Chrischo nodejs sauber?
            C
            C
            Chrischo
            @Thomas-Braun wie überprüfe ich die "Sauberkeit"?
            Augenscheinlich macht es keine Probleme.
            • C Chrischo
              Thomas BraunT
              Thomas BraunT
              @Chrischo
              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                @Chrischo
                C
                C
                Chrischo
                @Thomas-Braun
                pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                /usr/bin/nodejs
                v12.18.2
                /usr/bin/node
                v12.18.2
                /usr/bin/npm
                6.14.5
                nodejs:
                  Installed: 12.18.2-1nodesource1
                  Candidate: 12.18.2-1nodesource1
                  Version table:
                 *** 12.18.2-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x buster/main arm64 Packages
                     10.21.0~dfsg-1~deb10u1 500
                        500 http://deb.debian.org/debian-security buster/updates/main arm64 Packages
                     10.19.0~dfsg1-1 500
                        500 http://deb.debian.org/debian buster/main arm64 Packages
                Das hatte ich aber bereits weiter oben im Beitrag schon gepostet.
                • C Chrischo
                  @Thomas-Braun
                  /usr/bin/nodejs
                  v12.18.2
                  /usr/bin/node
                  v12.18.2
                  /usr/bin/npm
                  6.14.5
                  nodejs:
                    Version table:
                       10.19.0~dfsg1-1 500
                  Thomas BraunT
                  Thomas BraunT
                  @Chrischo Passt. Dann installier den Adapter nochmals frisch neu
                    C
                    C
                    Chrischo
                    @Thomas-Braun alles schon gemacht, selbst ein Downgrade auf eine ältere Adapter-Version funktioniert nicht mehr. Die 3.2.8 muss irgendwas im System zerschossen haben 🙄 .
                    • C
                      C
                      Chrischo
                      LÖSUNG:
                      So hat´s nun bei mir funktioniert, danke an Apollon77.
                      • ListenpunktInstanz & Adapter komplett deinstalliert
                      • Login per SSH in das Verzeichnis /opt/iobroker/
                      • folgenden Befehl ausgeführt: npm install iobroker.alexa2@3.2.8 --production
                      • Alexa/Amazon Anmeldedaten neu eingegeben - dann lief der Adapter wieder 👍
                      • C Chrischo
                        LÖSUNG:
                        Thomas BraunT
                        Thomas BraunT
                        @Chrischo Sagte ich doch auch schon. Frische Neuinstallation.
                          C
                          C
                          Chrischo
                          @Thomas-Braun ja, funktioniert aber nur "manuell" per SSH-Zugriff - nicht über das GUI.
                          • A
                            A
                            Adnim
                            Hi!
                            habe auch das gleiche Modul Problem, bekomme aber Alexa Adapter nicht gelöscht. Via Gui oder CLI kommt immer der gleiche Fehler, hat mir wer einen Tipp?
                            $ ./iobroker del alexa2
                            Delete adapter "alexa2"
                            npm uninstall iobroker.alexa2 --error --prefix "/opt/iobroker" (System call)
                            npm
                             ERR! code ELOOPnpm ERR! syscall opennpm ERR! path /opt/iobroker/node_modules/iobroker.objects-redis/package.jsonnpm ERR! errno -40
                            npm
                            ERR! ELOOP: too many symbolic links encountered, open '/opt/iobroker/node_modules/iobroker.objects-redis/package.json'
                            npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-07-25T07_50_39_421Z-debug.log
                            ERROR: Error deleting adapter alexa2 from disk: Error: host.iobroker1: Cannot uninstall iobroker.alexa2: 216You might have to delete it yourself!
                            process exited with code 0
                            Ist ein Proxmox Container:
                            root@iobroker1:/opt/iobroker# which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                            /usr/bin/nodejs
                            v12.18.3
                            /usr/bin/node
                            v12.18.3
                            /usr/bin/npm
                            6.14.6
                            nodejs:
                              Installed: 12.18.3-1nodesource1
                              Candidate: 12.18.3-1nodesource1
                              Version table:
                             *** 12.18.3-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages
                                 4.8.2~dfsg-1 500
                                    500 http://ftp.debian.org/debian stretch/main amd64 Packages
                            npm list http-proxy-agent
                            root@iobroker1:/opt/iobroker# npm list http-proxy-agent
                            iobroker.inst@1.1.2 /opt/iobroker
                            +-- iobroker.alexa2@3.3.1
                            | `-- virtual-device-sdk@1.7.3
                            |   `-- http-proxy-agent@4.0.1
                            +-- iobroker.unifi@0.5.5
                            | `-- node-unifi@1.3.3
                            |   `-- snyk@1.339.2
                            |     `-- proxy-agent@3.1.1
                            |       +-- http-proxy-agent@2.1.0
                            |       `-- pac-proxy-agent@3.0.1
                            |         `-- http-proxy-agent@2.1.0
                            `-- iobroker.vis-weather@2.5.2
                              `-- npm@6.14.4
                                `-- npm-registry-fetch@4.0.3
                                  `-- make-fetch-happen@5.0.2
                            Vg
                            • A Adnim
                              Hi!
                              npm
                              npm
                              /usr/bin/nodejs
                              v12.18.3
                              /usr/bin/node
                              v12.18.3
                              /usr/bin/npm
                              6.14.6
                              nodejs:
                                Version table:
                                   4.8.2~dfsg-1 500
                              |   `-- snyk@1.339.2
                                `-- npm@6.14.4
                              Vg
                              Thomas BraunT
                              Thomas BraunT
                              @Adnim
                              Ja. Nicht als root anmelden.
                              • moelskiM
                                moelskiM
                                moelski
                                Moin !
                                Bei mir klappt das leider nicht. Ich habe den Adapter gelöscht:
                                habe dann den Adapter neu installiert:
                                npm install iobroker.alexa2@3.3.0 --production
                                Und danach in der Admin Seite eine neue Instanz angelegt.
                                Vermutlich irgendwas noch nicht richtig gemacht.
                                Könnte mal jemand kurz niederschreiben welche Kommandos ich in der Konsole alle in welche Reihenfolge absetzen muss?
                                Grüße Dominik
                                Grüße Dominik
                                • moelskiM moelski
                                  Moin !
                                  Grüße Dominik
                                  Thomas BraunT
                                  Thomas BraunT
                                  @moelski
                                  Als USER, nicht als root:
                                  cd /opt/iobroker
                                  iobroker del alexa2
                                  iobroker add alexa2
                                  84.2k
