  5. Fenster und andere Geräte zählen opt. Alexa Ansagen
blocklyjavascript
1.2k Beiträge 41 Kommentatoren 645.0k Aufrufe 71 Beobachtet
  • dslraserD dslraser
    @sigi234 sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
    "type": "device",
    und das ist der RAW vom device, nicht vom state MOTION, aber egal...
    sigi234S
    sigi234S
    #666
    @dslraser sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
      "type": "state",
      "common": {
        "def": false,
        "type": "boolean",
        "read": true,
        "write": false,
        "role": "sensor.motion",
        "name": "Bewegungsmelder Vorraum.MOTION"
      "native": {
        "MIN": false,
        "OPERATIONS": 5,
        "MAX": true,
        "FLAGS": 1,
        "ID": "MOTION",
        "TYPE": "BOOL",
        "DEFAULT": false,
        "CONTROL": "MOTIONDETECTOR_TRANSCEIVER.MOTION_DETECTION_STATE"
      "from": "system.adapter.hm-rega.0",
      "user": "system.user.admin",
      "ts": 1589987461346,
      "_id": "hm-rpc.1.00091A49A082FC.1.MOTION",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    javascript.0	2020-06-17 16:26:57.110	warn	(12088) at processTimers (internal/timers.js:492:7)
    javascript.0	2020-06-17 16:26:57.110	warn	(12088) at listOnTimeout (internal/timers.js:551:17)
    javascript.0	2020-06-17 16:26:57.109	warn	(12088) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:2039:34)
    javascript.0	2020-06-17 16:26:57.109	warn	(12088) at Object.<anonymous> (script.js.Ansage.Komplettansage:1210:7)
    javascript.0	2020-06-17 16:26:57.109	warn	(12088) at Fenster_zaehlen (script.js.Ansage.Komplettansage:1814:61)
    javascript.0	2020-06-17 16:26:57.109	warn	(12088) at stateText (script.js.Ansage.Komplettansage:924:12)
    javascript.0	2020-06-17 16:26:57.109	warn	(12088) getState "hm-rpc.0.OEQ0926852.1.INSTALL_TEST" not found (3) states[id]=null
    javascript.0	2020-06-17 16:26:57.109	warn	(12088) at processTimers (internal/timers.js:492:7)
    javascript.0	2020-06-17 16:26:57.109	warn	(12088) at listOnTimeout (internal/timers.js:551:17)
    javascript.0	2020-06-17 16:26:57.108	warn	(12088) at Object.<anonymous> (script.js.Ansage.Komplettansage:1210:7)
    javascript.0	2020-06-17 16:26:57.108	warn	(12088) at Fenster_zaehlen (script.js.Ansage.Komplettansage:1814:9)
    javascript.0	2020-06-17 16:26:57.108	warn	(12088) at stateText (script.js.Ansage.Komplettansage:924:12)
    javascript.0	2020-06-17 16:26:57.108	warn	(12088) getState "hm-rpc.0.OEQ0926852.1.INSTALL_TEST" not found (3) states[id]=null
    Diese Warn kommt ja nur weil der State leer ist.
    • sigi234S sigi234
        "type": "state",
        "common": {
          "def": false,
          "type": "boolean",
          "read": true,
          "write": false,
        "native": {
          "MIN": false,
          "OPERATIONS": 5,
          "MAX": true,
          "FLAGS": 1,
          "ID": "MOTION",
          "TYPE": "BOOL",
          "DEFAULT": false,
        "acl": {
          "object": 1636,
          "state": 1636,
      dslraserD
      dslraserD
      dslraser
      #667
      Wie meinst Du das ? Dieser state hat mit dem Blockly eigentlich nichts zu tun.
      Welche javascript Adapter Version und js-contoller Version setzt Du ein ?
        sigi234S
        sigi234S
        #668
        JS controller 3.1.5
        JS:  4.6.17
        • sigi234S sigi234
            "type": "state",
            "common": {
              "def": false,
              "type": "boolean",
              "read": true,
              "write": false,
            "native": {
              "MIN": false,
              "OPERATIONS": 5,
              "MAX": true,
              "FLAGS": 1,
              "ID": "MOTION",
              "TYPE": "BOOL",
              "DEFAULT": false,
            "acl": {
              "object": 1636,
              "state": 1636,
          dslraserD
          dslraserD
          dslraser
          #669
          @sigi234
          ich habe mir mal Dein RAW importiert, bei mir wird der BWM gefunden.
          • sigi234S sigi234
            JS controller 3.1.5
            JS:  4.6.17
            dslraserD
            dslraserD
            dslraser
            #670
            @sigi234
            hm....ich kann Deinen Fehler leider nicht nachstellen. Warten wir mal ab, ob noch Jemand kommt, der Bewegungsmelder nutzt (am Besten auch HMIP).
            • sigi234S sigi234
              JS controller 3.1.5
              JS:  4.6.17
              dslraserD
              dslraserD
              dslraser
              #671
              @sigi234
              mir ist an Deinem Bild erst jetzt aufgefallen, das da Batterien als Funktion steht, hast Du Batterien im Blockly auch auf wahr stehen ? (da ist auch nicht nur ein state ausgewählt)
              Hier Dein Bild
              falke69F sigi234S 2 Antworten Letzte Antwort
                @sigi234
                Hier Dein Bild
                falke69F
                falke69F
                falke69
                #672
                @dslraser
                kannst Du mal bitte prüfen, ob bei Dir die Ansage über den Fensterstatus über Alexa funktioniert?
                Ich habe aktuell Probleme den Fensterstatus über Alexa abzufragen.
                Batterie und Licht funktioniert. Im iot und in Alexa habe ich alles rausgelöscht und neu erstllen / suchen lassen - leider ohne Erfolg.
                Auch nach der Ansage "Alexa Stop" funktioniert bei mir die Abfrage des Fensterstatus leider nicht.
                Ein manuelles löschen der Datenpunkte, blieb leider auch ohne positives Ergebnis.
                • falke69F falke69
                  @dslraser
                  dslraserD
                  dslraserD
                  dslraser
                  #673
                  @falke69
                  funktioniert bei mir.
                  Wie viele Fenster hast Du ?
                  Bzw. Wieviel zeichen ist die Ansage lang ?
                  • falke69F falke69
                    @dslraser
                    dslraserD
                    dslraserD
                    dslraser
                    #674
                    @falke69
                    Das habe ich weiter oben geschrieben.
                    EDIT: Bei meiner Fensteransage (22 Fenster) kommt es regelmäßig dazu, das die Ansage nicht gestartet wird, da die 250 Zeichen Grenze überschritten wird. (Im Sommer sind halt mehrere Fenster auf) Da werde ich mir jetzt als nächstes was einfallen lassen.
                    Vielleicht ist das auch bei Dir der Fall ?
                    Auf meiner eigenen Testdatei habe ich schon was eingebaut, da spielt diese 250 Zeichen Grenze keine Rolle mehr, die würde ganze Bücher vorlesen.
                    Das will ich aber erst in Ruhe testen.
                    falke69F 1 Antwort Letzte Antwort
                      @falke69
                      falke69F
                      falke69F
                      falke69
                      #675
                      @dslraser ich habe 12 Fenster, das sollte dann eigentlich noch im möglichen sein.
                      Vielleicht ist auch die Bezeichnung der Geräte zu lang, dass ich dann trotzden über die 250 Zeichen komme.
                      Habe jetzt mal bis auf zwei Fenster alle aus den Aufzählungen genommen, so das ich aktuell nur noch zwei Geräte zur Auswahl hatte. Es kam leider auch keine Ansage.
                      Wenn es bei Dir funkioniert, muss ich mal schauen, was noch die Ursache sein könnte. :-)
                        @sigi234
                        Hier Dein Bild
                        sigi234S
                        sigi234S
                        #676
                        Ja, aber ich habe das Skript mal deaktiviert, es bringt mein System an die Grenzen.
                        • sigi234S sigi234
                          dslraserD
                          dslraserD
                          dslraser
                          #677
                          In wie fern ?
                          • falke69F falke69
                            dslraserD
                            dslraserD
                            dslraser
                            #678
                            @falke69 sagte in Fenster und andere Geräte zählen opt. Alexa Ansagen:
                            Lade es nochmal aus dem Beitrag runter.
                            Ich weiß nicht wann Du es geladen hattest. Das letzte, (ich hatte nochmal kleine Änderung gemacht) was da im Beitrag ist benutze ich auch.
                              In wie fern ?
                              sigi234S
                              sigi234S
                              #679
                              In wie fern ?
                              JS reagiert sehr träge. Beim start des Skript dauert es lange bis die Bausteine angezeigt werden. Sind auch über 5000
                              • sigi234S sigi234
                                In wie fern ?
                                dslraserD
                                dslraserD
                                dslraser
                                #680
                                Kann ich bei mir nicht sagen.
                                Es kann aber sein das Du durch die "falschen Selektoren" bzw. das Du z.B. bei den Batterien das ganze Device oder den ganzen Channel in der Aufzählung hast nicht funktioniert. Dann mußt Du entweder die Aufzählungen anpassen wie beschrieben, oder Deinen Selektor anders einstellen, so das nur auf den benötigten state selektiert wird.
                                  falke69F
                                  falke69F
                                  falke69
                                  #681
                                  @dslraser jetzt geht es. Dann hatte ich bestimmt die erste Version 😊 👍
                                    sigi234S
                                    sigi234S
                                    #682
                                    Jupp, ich werde alles mal kontrollieren. Es kommen noch einen Menge an Warnmeldungen.
                                    • dslraserD
                                      dslraserD
                                      dslraser
                                      #683
                                      Ist sowas für Euch auch von Interesse ?
                                      (könnte man auch Ansagen lassen, per Telegram oder E-Mail versenden und eben als html Ausgabe verwenden, z.B. in iQontrol)
                                      Wen es interessiert:
                                      Als erstes habe ich mir eine neue Aufzählung, in meinem Fall Temperaturen angelegt.
                                      Man achte auf die Schreibweise ganz rechts(groß oder klein)
                                      Danach habe ich mir mit dem alias erstellen Script von @paul53 für meine Thermostate aliase angelegt es geht immer nur einer auf einmal). (mit den Namen wie die dann auch heißen sollen, da die ja sonst oft irgendwelche Thermostatbezeichnungen haben.) Dieses Script packt die aliase auch gleich in diese Aufzählung (kann man im Script einstellen)
                                      // Original-Datenpunkt
                                      const idOrigin = 'hm-rpc.0.xxx.1.ACTUAL_TEMPERATURE'/*Wandthermostat Gästezimmer:1 ACTUAL TEMPERATURE*/;
                                      // Alias-Datenpunkt
                                      const idAlias = 'Temperaturen.Gaestezimmer';
                                      var typeAlias, read, write, nameAlias, role, desc, min, max, unit, states, custom, raum, gewerk;
                                      // Folgende kommentieren, wenn keine Änderung der Eigenschaft erforderlich
                                      nameAlias = 'Gaestezimmer';
                                      //desc = 'per Script erstellt';
                                      // typeAlias = 'boolean'; // oder 'number'
                                      read = "Math.round(val * 10) / 10"
                                      // write = "val ? 'Ein' : 'Aus'";
                                      // role = 'indicator';
                                      // min = 0; // nur Zahlen
                                      // max = 100; // nur Zahlen
                                      // unit = '%'; // nur für Zahlen
                                      // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
                                      // custom = []; // verhindert doppelte Ausführung von history, ...
                                      // raum = 'EG_Flur'; // Groß-/Kleinschreibung in der ID beachten !
                                      gewerk = 'Temperaturen'; // Groß-/Kleinschreibung in der ID beachten !
                                      function createAlias(idSrc, idDst) {
                                       if(existsState(idDst)) log(idDst + ' schon vorhanden !', 'warn');
                                       else {
                                          var obj = {};
                                          obj.type = 'state';
                                          obj.common = getObject(idSrc).common;
                                          obj.common.alias = {};
                                          obj.common.alias.id = idSrc;
                                          if(typeAlias) obj.common.type = typeAlias;
                                          if(obj.common.read !== false && read) obj.common.alias.read = read;
                                          if(obj.common.write !== false && write) obj.common.alias.write = write;
                                          if(nameAlias) obj.common.name = nameAlias;
                                          if(role) obj.common.role = role;
                                          if(desc) obj.common.desc = desc;
                                          if(min !== undefined) obj.common.min = min;
                                          if(max !== undefined) obj.common.max = max;
                                          if(unit) obj.common.unit = unit;
                                          if(states) obj.common.states = states;
                                          if(custom && obj.common.custom) obj.common.custom = custom;
                                          obj.native = {};
                                          setObject(idDst, obj);
                                          if(raum && getObject('enum.rooms.' + raum)) {
                                             let obj = getObject('enum.rooms.' + raum)
                                             obj.common.members.push(idDst);
                                             setObject('enum.rooms.' + raum, obj);
                                          if(gewerk && getObject('enum.functions.' + gewerk)) {
                                             let obj = getObject('enum.functions.' + gewerk)
                                             setObject('enum.functions.' + gewerk, obj);
                                      createAlias(idOrigin, 'alias.0.' + idAlias);
                                      so sehen die aliase bei mir aus
                                      Datenpunkte fürs Blockly
                                      dirk1962D 1 Antwort Letzte Antwort
                                      • dslraserD
                                        dslraserD
                                        dslraser
                                        #684
                                        Zum Thema Textlänge (250 Zeichen) für die Ausgabe über Alexa.
                                        Ich habe damit jetzt ne ganze Menge getestet.
                                        Die Ausgabe über ssml ist so ca. auf 1000 Zeichen begrenzt. ssml interessiert auch die Trennung mit einem Semikolon nach 250 Zeichen nicht !
                                        Mit speak funktioniert diese Trennung über das Semikolon, dann ist die Ansage quasi nicht mehr begrenzt. Der Nachteil ist allerdings, man hat nur die Stimme von Alexa.
                                        Ich habe für mich eine Datei erstellt, die nur speak nutzt. Wenn die Gesamtansage (dazu zählt auch was vor und nach der eigentlichen Geräteansage angesagt wird, das sind schon alleine ca. 80 Zeichen) kürzer als 250 Zeichen ist, dann wird mit Komma getrennt, sonst mit Semikolon. Nachteil der Ansage länger als 250 Zeichen, sie ist langsamer, weil jedes Semikolon eine kleine Sprechpause bewirkt. Vorteil, die Ansage kommt immer, egal wie lang.
                                        Auch intern im Blockly habe ich Änderungen gemacht. (Sortierungen "korrigiert". Ich denke die Testdatei über ssml hat noch Fehler bei der Sortierung gehabt, auch wenn die nicht in jedem Fall zu sehen ist)
                                        Hier das Blockly inklusive Temperaturen, wie hier beschrieben
                                        wird gerade bearbeitet
                                          // Alias-Datenpunkt
                                           else {
                                              var obj = {};
                                              obj.type = 'state';
                                              obj.native = {};
                                          dirk1962D
                                          dirk1962D
                                          dirk1962
                                          #685
                                          Hallo @dslraser, habe für alle Thermostate die Aliase angelegt. Die Datenpunkte werden gefüllt und die html-Tabellen zeigen auch alles an. In iot werden die Aliase auch angezeigt und auch in der Alexa App werden die Aliase angezeigt. Wenn ich aber die Routinen anlegen will, werden die Aliase unter Smart Home nicht angezeigt.
                                          Irgendeine Idee?
                                          NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
                                          33.2k
                                          84.3k
