  4. Z-Wave Adapter
Z-Wave Adapter
110 Beiträge 13 Kommentatoren 35.3k Aufrufe
  • AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #99
    Das passiert, wenn ich im Admin-Interface den Wert umstelle:
    zwave.0	2016-05-01 19:17:09	debug	inMem message * system.adapter.javascript.0.alive
    zwave-0	2016-05-01 17:17:05	debug	That's ok, ready Object do nothing
    zwave-0	2016-05-01 17:17:05	debug	stateChange for zwave.0.NODE4.SWITCH_BINARY.Switch_1 found state = {"val":true,"ack":false,"ts":1462123025,"q":0,"from":"system.adapter.admin.0","lc":1462123025}
    inMem	2016-05-01 17:17:05	debug	message * zwave.0.NODE4.SWITCH_BINARY.Switch_1 val=true, ack=false, ts=1462123025, q=0, from=system.adapter.admin.0, lc=1462123025
    Das beim Versuch via JS:
    19:20:30.528	[debug]	inMem message * script.js.Test
    19:20:30.529	[debug]	zwave.0 objectChange for script.js.Test found, obj = {"common":{"name":"Test","engineType":"Javascript/js","source":"setState(\"zwave.0.NODE4.SWITCH_BINARY.Switch_1\"/*zwave.0.NODE4.SWITCH_BINARY.Switch_1*/, true, true)","enabled":true,"engine":"system.adapter.javascript.0"},"type":"script","_id":"script.js.Test"}
    19:20:30.677	[info]	javascript.0 Start javascript script.js.Test
    19:20:30.680	[info]	javascript.0 script.js.Test: registered 0 subscriptions and 0 schedules
    Das bei manueller Betätigung:
    zwave.0	2016-05-01 19:21:26	debug	zwave.0 That's ok, ready Object do nothing
    zwave.0	2016-05-01 19:21:26	debug	zwave.0 stateChange for zwave.0.NODE4.SWITCH_BINARY.Switch_1 found state = {"val":false,"ack":true,"ts":1462123287,"q":0,"from":"system.adapter.zwave.0","lc":1462123287}
    zwave.0	2016-05-01 19:21:26	debug	inMem message * zwave.0.NODE4.SWITCH_BINARY.Switch_1
    zwave.0	2016-05-01 19:21:26	debug	zwave.0 Value changed: zwave.0.NODE4.SWITCH_BINARY.Switch_1 from false to false
    zwave.0	2016-05-01 19:21:26	debug	zwave.0 Nothing todo for zwave.0.NODE4.SWITCH_BINARY.Switch_1
    zwave.0	2016-05-01 19:21:26	debug	zwave.0 ----------> DIFF (1) D, [object Object]|undefined, ["acl"]
    zwave.0	2016-05-01 19:21:26	debug	zwave.0 ####################################### zwave.0.NODE4.SWITCH_BINARY.Switch_1
    zwave.0	2016-05-01 19:21:26	debug	zwave.0 ##### Value added: zwave.0.NODE4.SWITCH_BINARY.Switch_1 = false index = 0 comclass = 37 instance = 1
    zwave.0	2016-05-01 19:21:26	debug	zwave.0 -----------> NODE: 4-----37-----{"value_id":"4-37-1-0","node_id":4,"class_id":37,"type":"bool","genre":"user","instance":1,"index":0,"label":"Switch","units":"","help":"","read_only":false,"wr
    zwave.0	2016-05-01 19:21:26	debug	zwave.0 value changed: 4 comclass: 37 value: {"value_id":"4-37-1-0","node_id":4,"class_id":37,"type":"bool","genre":"user","instance":1,"index":0,"label":"Switch","units":"","help":"","read_only":fals
      #100
      so, jetzt bin ich leider raus - für mich sieht es so aus, dass ack nicht auf true geht.
      da muss versteckt nochmal ran.
      Dankke für die ausführliche Doku.
        AlCalzoneA Offline
        AlCalzone
        #101
        Alles klar, dann werde ich mal abwarten was er dazu sagen kann. Danke schonmal!
          AlCalzoneA Offline
          AlCalzone
          #102
          Da mein Problem relativ dringend war, habe ich mir jetzt temporär mit einer Anpassung der main.js beholfen. Unter Zeile 506 (Stand v0.3.0) habe ich folgenden Code eingefügt:
                                          	case "changeValue2":
                                          		var nodeId = state.val.nodeId;
                                          		var commclass = state.val.commandclass;
                                          		var instance = state.val.instance;
                                          		var index = state.val.index;
                                          		var value = state.val.value;
                                          		adapter.log.info("setValue: nodeid=" + nodeId + "; comclass=" + commclass + "; instance=" + instance + "; index=" + index + "; value=" + value);
                                          		zwave.setValue(nodeId, commclass, instance, index, value);
                                          		break
          und schalte das Relais jetzt mit Code ähnlich dem der zum aktivieren des Inclusion-Modus (siehe Seite 5) verwendet wird:
          setState("zwave.0.NODE5.GLOBAL_ACTION"/*GLOBAL_ACTION*/, {
              val: {action: 'changeValue2', nodeId: 5, commandclass: 37, instance: 1, index: 0, value: false},
              ack: true
          Nicht schön, aber funktioniert vorerst. Vielleicht hilft das ja, den Bug einzugrenzen.
            AlCalzoneA Offline
            AlCalzone
            #103
            Nächster Bug-Report:
            Wenn ich meinen Fibaro FGS212 einbinde, erscheint die Info korrekt im Event Log:
             node ready nodeid:3 nodeinfo:{'manufacturer':'FIBARO System','manufacturerid':'0x010f','product':'FGS212 Switch 3kW','producttype':'0x0402','productid':'0x1002','type':'Binary Power Switch','name':'','loc':''}
            und der Switch lässt sich auch ansprechen.
            Allerdings scheint das Objekt im ioBroker nicht vollständig angelegt zu werden:
            ~~![](</s><URL url=)http://i.imgur.com/ElP0jT2.png" />
            ~~![](</s><URL url=)http://i.imgur.com/tE4JVdF.png" />
            Neustart des zwave-Adapters behebt den Fehler:
            ~~![](</s><URL url=)http://i.imgur.com/xrA5HaJ.png" />
            ![](</s><URL url=)http://i.imgur.com/OQOB4rx.png" />~~~~~~
              AlCalzoneA Offline
              AlCalzone
              #104
              Und noch einer:
              Im eingebauten Konfigurator kann ich Werte nur setzen, wenn sie sich vom ursprünglichen Wert unterscheiden.
              Beispiel 1:
              Ursprungswert: 10, setze auf 15 (funktioniert), setze auf 20 (funktioniert).
              Der Konfigurator zeigt weiterhin 10 als Vergleichswert neben dem Eingabefeld an.
              Beispiel 2:
              Ursprungswert: 10, setze auf 15 (funktioniert), setze zurück auf 10 (<u>funktioniert nicht</u>, kein Kommando wird übermittelt, Wert bleibt 15)
                AlCalzoneA Offline
                AlCalzone
                #105
                Nächstes Problem:
                Wenn ich versuche, einen Greenwave NS310-F zu inkludieren, stürzt zwave mit der Meldung "cannot set manufacturer of undefined" ab. Nach einem manuellen Restart des Adapters mit der Option "force objects re-init" funktioniert es wieder.
                Edit: Mit einer weiteren Steckdose des Typs will es einfach nicht funktionieren. Das Problem scheint am code in zwave.on('value removed'… zu liegen, speziell die letzte Zeile
                delete nodes[nodeid];
                Die Steckdose schickt (warum auch immer) während dem Anmeldeprozess "value removed" Kommandos, die das zuvor in zwave.on('node added' angelegte Dummy-Objekt löschen. Beim Abschluss des Prozesses in zwave.on('node available' ist nodes[nodeid] demnach null, was zu dem Fehler führt.
                Habe jetzt einfach den Löschbefehl auskommentiert. Mein Problem ist weg und ich habe noch keine Nebenwirkungen bemerkt.
                • Lenny.CBL Offline
                  Lenny.CBL Offline
                  Lenny.CB
                  #106
                  hallo zusammen,
                  ich habe mal wieder ein Problem mit meinem Z-wave-Adapter.
                  Installation läuft perfekt durch. Nur steuern kann ich meine Roller-Shutter nicht mehr.
                  Erkannt wird vom iobroker der Stick und ein Shutter (zur Zeit auch nur einer am Stick angelernt)
                  wenn ich über VIS versuche zu schalten, ändert sich der Status (Level_1) im Reiter Objekte. Die Zahl wird aber sofort rot (also "nicht bestätigt")
                  Auch wenn ich den Status direkt unter Objekte ändere passiert nicht.
                  Es werden auch keine Logeinträge angezeigt die auf eine "Verarbeitung " schließen lassen (auch nicht im Debug-Modus)
                  Letzte funktionierende Version war die 2.5.0.
                  Ich hänge noch ein Bild dran von der Controller-Sektion im Reiter Z-Wave.
                  da steht "Static Controller false", muss das so sein? man könnte meinen, dass der Controller doch nicht korrekt erkannt wird.
                  Ausserdem wundert mich der Logeintrag "nodeid 1 is now available, but maybe not ready"?
                  Wer kann helfen?
                  EDIT: wenn man am Fenster direkt die Rollos betätigt, änder sich der Status (Level_1) im Reiter Objekte wie folgt:
                  offen = 99
                  zu = 0
                  alle anderen Stellungen dazwischen = 254
                  Hier sollten je ja Stellung ein Wert zwischen 0 und 99 stehen.
                  • Lenny.CBL Offline
                    Lenny.CBL Offline
                    Lenny.CB
                    #107
                    Moin zusammen,
                    weiß jemand wie man auf eine "ältere" Adapterversion zurück wechseln kann?
                    Würde zum Testen gern wieder z-wave 0.2.5. haben.
                    • C Offline
                      courson
                      #108
                      Einfach mit update und upgrade.
                      Da das nicht die gepublishte Version ist springt er dann auf 0.2.5 zurück.
                      Kann sein dass du es zwei mal laufen lassen musst, lief bei mir nicht immer durch
                      • C Offline
                        courson
                        #109
                        Gibt's Neuigkeiten bezüglich einem Update für den Adapter? @ versteckt
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          #110
                          @Christoph:
                          ich habe einen Z-Wave Lan Gateway (TCP/IP) am laufen. Wie kann ich das denn unter dem Z-Wave Adapter einbinden.
                          Es ist ein Raspberry mit einem Razberry.z-wave Board, das ich auch noch für andere Zwecke nutze.
                          lg Chris `
                          Schau doch bitte ins Topic zwave von bluefox er hat den Adapter neu geschrieben und die discussion läuft in einem anderen thread.
