  4. [gelöst] Fehler Adapter tr-064 - Startet nicht
Geplant Angeheftet Gesperrt Verschoben Gelöst ioBroker Allgemein
tr-064
82 Beiträge 14 Kommentatoren 16.8k Aufrufe 9 Beobachtet
  • KusselinK Kusselin
    @thomas....gleich....
    hab das net noch gemacht...was sagt mir das??
    pi@raspberrypi:~ $ iobroker del tr-064
    Delete adapter "tr-064"
    npm uninstall iobroker.tr-064 --error --prefix "/opt/iobroker" (System call)
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dgram
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/ip
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dns-packet
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/sprintf-js
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/serialport/package.json'
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'
    npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext']
    npm ERR!   stack:
    npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path:
    npm ERR!    '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/iobroker/.npm/_logs/2020-06-16T19_12_04_255Z-debug.log
    Error deleting adapter tr-064 from disk: Error: host.raspberrypi: Cannot uninstall iobroker.tr-064: 243
    You might have to delete it yourself!
    GlasfaserG Offline
    GlasfaserG Offline
    @Kusselin
    Stopp mal alles was du machst !!
    Bitte nur noch den Anweisungen von @Thomas-Braun folgen !!!
    • KusselinK Offline
      KusselinK Offline
      Kusselin
      o.k.......das hab ich jetzt mal gemacht wie thomas gesagt hat:
      pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v10.21.0
      /usr/bin/node
      v10.21.0
      /usr/bin/npm
      6.14.5
      nodejs:
        Installiert:           10.21.0-1nodesource1
        Installationskandidat: 10.21.0-1nodesource1
        Versionstabelle:
       *** 10.21.0-1nodesource1 500
              500 https://deb.nodesource.com/node_10.x stretch/main armhf Packages
           8.11.1~dfsg-2~bpo9+1 500
              500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
           4.8.2~dfsg-1 500
              500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
      nodejs:
        Versionstabelle:
           4.8.2~dfsg-1 500
      N: Paket which kann nicht gefunden werden.
      v10.21.0
      /usr/bin/node
      v10.21.0
      /usr/bin/npm
      6.14.5
      nodejs:
        Versionstabelle:
           4.8.2~dfsg-1 500
      pi@raspberrypi:~ $
        /usr/bin/nodejs
        v10.21.0
        /usr/bin/node
        v10.21.0
        /usr/bin/npm
        6.14.5
        nodejs:
          Versionstabelle:
             4.8.2~dfsg-1 500
        nodejs:
          Versionstabelle:
             4.8.2~dfsg-1 500
        v10.21.0
        /usr/bin/node
        v10.21.0
        /usr/bin/npm
        6.14.5
        nodejs:
          Versionstabelle:
             4.8.2~dfsg-1 500
        pi@raspberrypi:~ $
        @Kusselin
        Dann schauen wir jetzt mal, was du da überhaupt alles aktiv hast:
        iobroker list adapters
        • KusselinK Offline
          KusselinK Offline
          Kusselin
          schrieb am zuletzt editiert von Kusselin
          Danke @Thomas-Braun
          pi@raspberrypi:~ $ iobroker list adapters
          system.adapter.admin                   : admin          - v4.0.10
          system.adapter.alexa2                  : alexa2         - v3.0.5
          system.adapter.ble                     : ble            - v0.11.6
          system.adapter.cloud                   : cloud          - v3.0.3
          system.adapter.daswetter               : daswetter      - v3.0.1
          system.adapter.denon                   : denon          - v1.7.7
          system.adapter.discovery               : discovery      - v2.2.2
          system.adapter.fhem                    : fhem           - v1.4.2
          system.adapter.fritzbox                : fritzbox       - v0.2.1
          system.adapter.g-homa                  : g-homa         - v0.5.2
          system.adapter.habpanel                : habpanel       - v0.4.1
          system.adapter.ical                    : ical           - v1.7.0
          system.adapter.info                    : info           - v1.7.2
          system.adapter.iot                     : iot            - v1.5.3
          system.adapter.javascript              : javascript     - v4.5.1
          system.adapter.material                : material       - v0.13.8
          system.adapter.mqtt                    : mqtt           - v2.1.2
          system.adapter.onkyo                   : onkyo          - v2.0.3
          system.adapter.pushover                : pushover       - v2.0.2
          system.adapter.scenes                  : scenes         - v1.1.0
          system.adapter.shelly                  : shelly         - v3.2.8
          system.adapter.sonoff                  : sonoff         - v2.3.3
          system.adapter.terminal                : terminal       - v0.1.2
          system.adapter.text2command            : text2command   - v1.3.0
          system.adapter.vis                     : vis            - v1.2.4
          system.adapter.web                     : web            - v3.0.7
          system.adapter.yahka                   : yahka          - v0.11.0
          system.adapter.zigbee                  : zigbee         - v1.0.4
          pi@raspberrypi:~ $
          der Fritz adapter ist noch aktiv obwohl er nicht zu sehen ist unter adapters
          Thomas BraunT J 2 Antworten Letzte Antwort
            Danke @Thomas-Braun
            pi@raspberrypi:~ $
            @Kusselin tr-064 seh ich da nicht.
            iobroker update
            iobroker add tr-064
              Danke @Thomas-Braun
              pi@raspberrypi:~ $
              Jan1
              @Kusselin
              der Fritzbox Adapter ist aber auch nicht der TR0-64 Adapter
              KusselinK 1 Antwort Letzte Antwort
              • J Jan1
                @Kusselin
                KusselinK Offline
                KusselinK Offline
                Kusselin
                @Jan1 sagte in [gelöst] Fehler Adapter tr-064 - Startet nicht:
                @Kusselin
                o.k. eben kapiert...danke
                • KusselinK Offline
                  KusselinK Offline
                  Kusselin
                  pi@raspberrypi:~ $ iobroker update
                  Used repository: default
                  hash changed or no sources cached => force download of new sources
                  update done
                  Adapter    "admin"         : 4.0.10   , installed 4.0.10
                  Adapter    "alarm"         : 0.3.0
                  Adapter    "alexa2"        : 3.0.5    , installed 3.0.5
                  Adapter    "alpha2"        : 1.0.0
                  Adapter    "amazon-dash"   : 1.1.0
                  Adapter    "artnet"        : 1.2.2
                  Adapter    "asterisk"      : 1.0.6
                  Adapter    "asuswrt"       : 1.0.1
                  Adapter    "b-control-em"  : 0.2.1
                  Adapter    "backitup"      : 1.4.5
                  Adapter    "beckhoff"      : 1.2.2
                  Adapter    "benq"          : 0.2.0
                  Adapter    "binance"       : 1.1.2
                  Adapter    "ble"           : 0.11.6   , installed 0.11.6
                  Adapter    "bmw"           : 1.3.3
                  Adapter    "bosesoundtouch": 0.2.4
                  Adapter    "botvac"        : 1.0.0
                  Adapter    "bring"         : 1.7.2
                  Adapter    "broadlink2"    : 2.0.3
                  Adapter    "bsblan"        : 0.1.0
                  Adapter    "bshb"          : 0.1.10
                  Adapter    "chromecast"    : 2.3.1
                  Adapter    "cloud"         : 3.0.3    , installed 3.0.3
                  Adapter    "comfoair"      : 0.3.2
                  Adapter    "contactid"     : 1.0.1
                  Adapter    "coronavirus-statistics": 0.5.9
                  Adapter    "countdown"     : 1.1.0
                  Adapter    "cul"           : 1.2.1
                  Adapter    "daikin"        : 1.0.5
                  Adapter    "daswetter"     : 3.0.1    , installed 3.0.1
                  Adapter    "deconz"        : 1.3.9
                  Adapter    "denon"         : 1.7.7    , installed 1.7.7
                  Adapter    "devices"       : 0.3.6
                  Adapter    "digitalstrom"  : 0.5.5
                  Adapter    "discovergy"    : 0.5.0
                  Adapter    "discovery"     : 2.3.5    , installed 2.2.2 [Updateable]
                  Adapter    "ds18b20"       : 1.1.4
                  Adapter    "dwd"           : 2.4.9
                  Adapter    "ebus"          : 2.0.0
                  Adapter    "ecovacs-deebot": 1.0.0
                  Adapter    "egigeozone"    : 0.1.2
                  Adapter    "ekey"          : 1.1.0
                  Adapter    "email"         : 1.0.6
                  Adapter    "emby"          : 1.0.2
                  Adapter    "energymanager" : 1.2.2
                  Adapter    "enet"          : 1.0.1
                  Adapter    "epson_stylus_px830": 0.2.1
                  Adapter    "exchangerates" : 0.0.13
                  Adapter    "fakeroku"      : 0.2.1
                  Adapter    "fb-checkpresence": 1.0.3
                  Adapter    "feiertage"     : 1.0.17
                  Adapter    "fhem"          : 1.3.0    , installed 1.4.2
                  Adapter    "find-my-iphone": 0.2.15
                  Adapter    "firetv"        : 0.0.27
                  Adapter    "flot"          : 1.9.2
                  Adapter    "foobar2000"    : 2.0.3
                  Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
                  Adapter    "fritzdect"     : 0.2.4
                  Adapter    "fronius"       : 1.0.5
                  Adapter    "fullcalendar"  : 1.1.0
                  Adapter    "fullybrowser"  : 1.0.3
                  Adapter    "g-homa"        : 0.5.2    , installed 0.5.2
                  Adapter    "geofency"      : 0.3.2
                  Adapter    "gruenbeck"     : 0.0.18
                  Adapter    "habpanel"      : 0.4.1    , installed 0.4.1
                  Adapter    "haier"         : 1.0.2
                  Adapter    "ham"           : 1.1.2
                  Adapter    "ham-wemo"      : 1.0.1
                  Adapter    "harmony"       : 1.2.2
                  Adapter    "heatingcontrol": 0.3.19
                  Adapter    "heytech"       : 0.2.0
                  Adapter    "hid"           : 0.1.17
                  Adapter    "history"       : 1.9.6
                  Adapter    "hm-rega"       : 2.5.5
                  Adapter    "hm-rpc"        : 1.14.2
                  Adapter    "hmip"          : 0.0.11
                  Adapter    "homeconnect"   : 0.0.30
                  Adapter    "homee"         : 0.3.1
                  Adapter    "homepilot"     : 1.0.3
                  Adapter    "hp-ilo"        : 1.0.5
                  Adapter    "hs100"         : 2.0.0
                  Adapter    "hue"           : 3.3.2
                  Adapter    "hue-extended"  : 1.2.3
                  Adapter    "ical"          : 1.7.0    , installed 1.7.0
                  Adapter    "icons-addictive-flavour-png": 0.1.0
                  Adapter    "icons-fatcow-hosting": 0.1.0
                  Adapter    "icons-icons8"  : 0.0.1
                  Adapter    "icons-material-png": 0.1.0
                  Adapter    "icons-material-svg": 0.1.0
                  Adapter    "icons-mfd-png" : 1.0.2
                  Adapter    "icons-mfd-svg" : 1.0.2
                  Adapter    "icons-open-icon-library-png": 0.1.2
                  Adapter    "icons-ultimate-png": 1.0.1
                  Adapter    "influxdb"      : 1.8.6
                  Adapter    "info"          : 1.7.2    , installed 1.7.2
                  Adapter    "innogy-smarthome": 0.3.3
                  Adapter    "iogo"          : 0.5.9
                  Adapter    "iot"           : 1.5.3    , installed 1.5.3
                  Adapter    "iqontrol"      : 1.0.0
                  Adapter    "javascript"    : 4.6.17   , installed 4.6.17
                  Adapter    "jeelink"       : 0.1.0
                  Controller "js-controller" : 3.1.4    , installed 3.1.4
                  Adapter    "kecontact"     : 0.1.0
                  Adapter    "klf200"        : 0.9.5
                  Adapter    "km200"         : 1.1.6
                  Adapter    "knmi-weather"  : 0.2.0
                  Adapter    "knx"           : 1.0.39
                  Adapter    "kodi"          : 2.0.1
                  Adapter    "kress"         : 2.5.5
                  Adapter    "lametric"      : 0.0.9
                  Adapter    "landroid"      : 1.0.3
                  Adapter    "lcn"           : 0.3.2
                  Adapter    "letrika_comgw" : 0.0.5
                  Adapter    "lgtv"          : 1.1.6
                  Adapter    "lgtv-rs"       : 0.1.0
                  Adapter    "lgtv11"        : 1.0.5
                  Adapter    "lifx"          : 0.1.0
                  Adapter    "lightify"      : 0.2.16
                  Adapter    "link"          : 0.5.9
                  Adapter    "linkeddevices" : 1.1.4
                  Adapter    "lovelace"      : 1.0.16
                  Adapter    "loxone"        : 1.0.0
                  Adapter    "luftdaten"     : 0.0.15
                  Adapter    "lupusec"       : 1.2.6
                  Adapter    "luxtronik1"    : 0.2.2
                  Adapter    "material"      : 0.13.8   , installed 0.13.8
                  Adapter    "maxcube"       : 0.1.2
                  Adapter    "maxcul"        : 1.3.0
                  Adapter    "mbus"          : 2.1.4
                  Adapter    "mclighting"    : 0.1.1
                  Adapter    "megad"         : 1.2.1
                  Adapter    "megadd"        : 0.2.0
                  Adapter    "megaesp"       : 0.1.0
                  Adapter    "mercedesme"    : 0.0.21
                  Adapter    "mercury"       : 0.1.1
                  Adapter    "meross"        : 1.3.11
                  Adapter    "meteoalarm"    : 1.0.9
                  Adapter    "midea"         : 0.0.6
                  Adapter    "miele"         : 0.1.5
                  Adapter    "mielecloudservice": 1.2.1
                  Adapter    "mihome"        : 1.3.0
                  Adapter    "mihome-lamp"   : 1.1.0
                  Adapter    "mihome-plug"   : 0.2.0
                  Adapter    "mihome-vacuum" : 1.1.5
                  Adapter    "mikrotik"      : 1.0.11
                  Adapter    "milight"       : 0.3.6
                  Adapter    "milight-smart-light": 0.2.7
                  Adapter    "mobile"        : 0.5.0
                  Adapter    "modbus"        : 3.0.0
                  Adapter    "moma"          : 1.2.6
                  Adapter    "mpd"           : 1.0.5
                  Adapter    "mqtt"          : 2.1.2    , installed 2.1.2
                  Adapter    "mqtt-client"   : 1.3.1
                  Adapter    "musiccast"     : 0.1.3
                  Adapter    "mysensors"     : 2.0.0
                  Adapter    "nanoleaf-lightpanels": 0.8.1
                  Adapter    "nello"         : 2.0.6
                  Adapter    "netatmo"       : 1.3.1
                  Adapter    "nibeuplink"    : 0.3.0
                  Adapter    "nina"          : 0.0.22
                  Adapter    "node-red"      : 1.13.0
                  Adapter    "nuki"          : 1.2.3
                  Adapter    "nuki-extended" : 2.2.5
                  Adapter    "nut"           : 1.1.3
                  Adapter    "odl"           : 1.0.5
                  Adapter    "oilfox"        : 0.0.5
                  Adapter    "onkyo"         : 2.0.3    , installed 2.0.3
                  Adapter    "onvif"         : 0.0.2
                  Adapter    "openhab"       : 1.1.0
                  Adapter    "openligadb"    : 1.1.0
                  Adapter    "openweathermap": 0.1.0
                  Adapter    "opi"           : 0.1.1
                  Adapter    "oppoplayer"    : 0.2.1
                  Adapter    "owfs"          : 0.6.4
                  Adapter    "owntracks"     : 0.6.2
                  Adapter    "panasonic-viera": 1.0.2
                  Adapter    "parser"        : 1.0.7
                  Adapter    "paw"           : 0.0.7
                  Adapter    "phantomjs"     : 1.0.1
                  Adapter    "pi-hole"       : 1.2.3
                  Adapter    "piface"        : 1.0.0
                  Adapter    "pimatic"       : 0.3.0
                  Adapter    "ping"          : 1.4.7
                  Adapter    "places"        : 0.7.0
                  Adapter    "plex"          : 0.8.11
                  Adapter    "plexconnect"   : 0.0.7
                  Adapter    "pollenflug"    : 1.0.6
                  Adapter    "proxmox"       : 1.0.1
                  Adapter    "proxy"         : 1.1.1
                  Adapter    "pushbullet"    : 0.0.11
                  Adapter    "pushover"      : 2.0.2    , installed 2.0.2
                  Adapter    "pushsafer"     : 0.1.8
                  Adapter    "radar2"        : 1.0.9
                  Adapter    "radiohead"     : 1.0.4
                  Adapter    "rflink"        : 2.0.0
                  Adapter    "rickshaw"      : 1.0.0
                  Adapter    "ring"          : 1.1.3
                  Adapter    "robonect"      : 0.1.3
                  Adapter    "roomba"        : 1.1.1
                  Adapter    "rpi2"          : 1.1.1
                  Adapter    "s7"            : 1.1.7
                  Adapter    "samsung"       : 0.2.9
                  Adapter    "sayit"         : 1.9.4
                  Adapter    "sbfspot"       : 3.0.0
                  Adapter    "scenes"        : 1.1.0    , installed 1.1.0
                  Adapter    "schoolfree"    : 0.5.0
                  Adapter    "shelly"        : 3.2.8    , installed 3.2.8
                  Adapter    "shuttercontrol": 0.4.3
                  Adapter    "sia"           : 1.0.4
                  Adapter    "siegenia"      : 1.0.0
                  Adapter    "simple-api"    : 2.4.5    , installed 2.4.5
                  Adapter    "smappee"       : 0.2.2
                  Adapter    "smartmeter"    : 3.0.10
                  Adapter    "snips"         : 1.5.0
                  Adapter    "snmp"          : 0.5.0
                  Adapter    "socketio"      : 3.0.7    , installed 3.0.7
                  Adapter    "solarlog"      : 2.0.0
                  Adapter    "solarwetter"   : 1.0.0
                  Adapter    "sonnen"        : 1.5.2
                  Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                  Adapter    "sonos"         : 2.0.1
                  Adapter    "sony-bravia"   : 1.0.1
                  Adapter    "spotify-premium": 1.0.0
                  Adapter    "sql"           : 1.12.5
                  Adapter    "squeezebox"    : 1.0.0
                  Adapter    "squeezeboxrpc" : 1.0.0
                  Adapter    "starline"      : 1.0.0
                  Adapter    "statistics"    : 0.2.2
                  Adapter    "stiebel-isg"   : 1.4.11
                  Adapter    "sunnyportal"   : 0.1.5
                  Adapter    "swiss-weather-api": 0.2.0
                  Adapter    "synology"      : 0.1.16
                  Adapter    "systeminfo"    : 0.3.1
                  Adapter    "tahoma"        : 0.3.2
                  Adapter    "tankerkoenig"  : 2.0.5
                  Adapter    "telegram"      : 1.5.9
                  Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                  Adapter    "tesla-motors"  : 0.2.3
                  Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                  Adapter    "tr-064"        : 4.0.3    , installed 0.4.18 [Updateable]
                  Adapter    "tradfri"       : 2.6.2
                  Adapter    "trashschedule" : 0.0.7
                  Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                  Adapter    "tuya"          : 3.2.2
                  Adapter    "tvspielfilm"   : 1.0.4
                  Adapter    "unifi"         : 0.4.3
                  Adapter    "upnp"          : 1.0.16
                  Adapter    "vaillant"      : 0.0.10
                  Adapter    "valloxmv"      : 1.0.3
                  Adapter    "vcard"         : 0.0.9
                  Adapter    "velux"         : 0.0.5
                  Adapter    "viessmann"     : 1.2.4
                  Adapter    "virtualpowermeter": 1.2.1
                  Adapter    "vis"           : 1.2.4    , installed 1.2.4
                  Adapter    "vis-bars"      : 0.1.4
                  Adapter    "vis-canvas-gauges": 0.1.5
                  Adapter    "vis-colorpicker": 1.1.1
                  Adapter    "vis-fancyswitch": 1.1.0
                  Adapter    "vis-google-fonts": 0.1.0
                  Adapter    "vis-history"   : 1.0.0
                  Adapter    "vis-hqwidgets" : 1.1.4
                  Adapter    "vis-inventwo"  : 1.3.3
                  Adapter    "vis-jqui-mfd"  : 1.0.12
                  Adapter    "vis-justgage"  : 1.0.2
                  Adapter    "vis-keyboard"  : 0.0.2
                  Adapter    "vis-lcars"     : 1.0.4
                  Adapter    "vis-map"       : 1.0.4
                  Adapter    "vis-metro"     : 1.1.2
                  Adapter    "vis-players"   : 0.1.5
                  Adapter    "vis-plumb"     : 1.0.2
                  Adapter    "vis-rgraph"    : 0.0.2
                  Adapter    "vis-timeandweather": 1.1.7
                  Adapter    "vis-weather"   : 2.5.2
                  Adapter    "vr200"         : 1.0.0
                  Adapter    "vw-connect"    : 0.0.15
                  Adapter    "weatherunderground": 3.1.6
                  Adapter    "web"           : 3.0.8    , installed 3.0.7 [Updateable]
                  Adapter    "weishaupt-wem" : 0.0.8
                  Adapter    "wiffi-wz"      : 2.2.0
                  Adapter    "wifilight"     : 1.1.0
                  Adapter    "windows-control": 0.1.3
                  Adapter    "wled"          : 0.5.0
                  Adapter    "wm-bus"        : 0.1.12
                  Adapter    "wolf"          : 0.9.2
                  Adapter    "worx"          : 1.0.0
                  Adapter    "xbox"          : 0.6.5
                  Adapter    "xs1"           : 1.0.2
                  Adapter    "yahka"         : 0.11.0   , installed 0.11.0
                  Adapter    "yamaha"        : 0.3.19
                  Adapter    "yeelight-2"    : 1.0.3
                  Adapter    "youtube"       : 0.0.11
                  Adapter    "yr"            : 2.0.3
                  Adapter    "zigbee"        : 1.0.4    , installed 1.0.4
                  Adapter    "zont"          : 0.5.3
                  Adapter    "zwave"         : 2.0.1
                  Adapter    "zwave2"        : 1.0.0
                  und
                  pi@raspberrypi:~ $ iobroker add tr-064
                  host.raspberrypi install adapter tr-064
                  upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                  upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                  upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index.html index.html text/html
                  host.raspberrypi object system.adapter.tr-064 created/updated
                  host.raspberrypi create instance tr-064
                  host.raspberrypi object system.adapter.tr-064.0.sigKill created
                  host.raspberrypi object system.adapter.tr-064.0.eventLoopLag created
                  host.raspberrypi object system.adapter.tr-064.0.outputCount created
                  host.raspberrypi object system.adapter.tr-064.0.inputCount created
                  host.raspberrypi object system.adapter.tr-064.0.uptime created
                  host.raspberrypi object system.adapter.tr-064.0.memRss created
                  host.raspberrypi object system.adapter.tr-064.0.memHeapTotal created
                  host.raspberrypi object system.adapter.tr-064.0.memHeapUsed created
                  host.raspberrypi object system.adapter.tr-064.0.cputime created
                  host.raspberrypi object system.adapter.tr-064.0.cpu created
                  host.raspberrypi object system.adapter.tr-064.0.compactMode created
                  host.raspberrypi object system.adapter.tr-064.0.connected created
                  host.raspberrypi object system.adapter.tr-064.0.alive created
                  host.raspberrypi object system.adapter.tr-064.0 created
                  und jetzt?
                    update done
                    und
                    und jetzt?
                    @Kusselin
                    Das ist vermutlich aber nicht die komplette Ausgabe beim zweiten Befehl.
                    Egal:
                    iobroker upgrade
                    • KusselinK Offline
                      KusselinK Offline
                      Kusselin
                      doch schau:
                      upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/wordss words.js application/javascript
                      upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-06png tr-064.png image/png
                      upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/indextml index.html text/html
                      pi@raspberrypi:~ $ ^C
                        doch schau:
                        @Kusselin
                        Und was macht das
                        iobroker upgrade
                        nun?
                        • KusselinK Offline
                          KusselinK Offline
                          Kusselin
                          kommt gleich..
                          das discovery wird jetzt grad geupdatet auf 2.3.5
                          das dauert schon ne ewigkeit.......
                          • KusselinK Offline
                            KusselinK Offline
                            Kusselin
                            #66
                            pi@raspberrypi:~ $ iobroker upgrade
                            Adapter "admin"          is up to date.
                            Adapter "alarm"          is not installed.
                            Adapter "alexa2"         is up to date.
                            Adapter "alpha2"         is not installed.
                            Adapter "amazon-dash"    is not installed.
                            Adapter "artnet"         is not installed.
                            Adapter "asterisk"       is not installed.
                            Adapter "asuswrt"        is not installed.
                            Adapter "b-control-em"   is not installed.
                            Adapter "backitup"       is not installed.
                            Adapter "beckhoff"       is not installed.
                            Adapter "benq"           is not installed.
                            Adapter "binance"        is not installed.
                            Adapter "ble"            is up to date.
                            Adapter "bmw"            is not installed.
                            Adapter "bosesoundtouch" is not installed.
                            Adapter "botvac"         is not installed.
                            Adapter "bring"          is not installed.
                            Adapter "broadlink2"     is not installed.
                            Adapter "bsblan"         is not installed.
                            Adapter "bshb"           is not installed.
                            Adapter "chromecast"     is not installed.
                            Adapter "cloud"          is up to date.
                            Adapter "comfoair"       is not installed.
                            Adapter "contactid"      is not installed.
                            Adapter "coronavirus-statistics" is not installed.
                            Adapter "countdown"      is not installed.
                            Adapter "cul"            is not installed.
                            Adapter "daikin"         is not installed.
                            Adapter "daswetter"      is up to date.
                            Adapter "deconz"         is not installed.
                            Adapter "denon"          is up to date.
                            Adapter "devices"        is not installed.
                            Adapter "digitalstrom"   is not installed.
                            Adapter "discovergy"     is not installed.
                            Update discovery from @2.2.2 to @2.3.5
                            NPM version: 6.14.5
                            npm install iobroker.discovery@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
                            ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
                            info sharp Attempting to build from source via node-gyp but this may fail due to the above error
                            info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
                            ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
                             #include <vips/vips8>
                            compilation terminated.
                            make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
                            gyp ERR! build error
                            gyp ERR! stack Error: `make` failed with exit code: 2
                            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
                            gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                            gyp ERR! System Linux 4.19.66-v7+
                            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                            gyp ERR! cwd /opt/iobroker/node_modules/sharp
                            gyp ERR! node -v v10.21.0
                            gyp ERR! node-gyp -v v5.1.0
                            gyp ERR! not ok
                              NPM version: 6.14.5
                              gyp ERR! not ok
                              #67
                              @Kusselin sagte in [gelöst] Fehler Adapter tr-064 - Startet nicht:
                              libvips
                              Musst du vermutlich händisch bauen.
                              https://libvips.github.io/libvips/install.html#building-libvips-from-a-source-tarball
                              • KusselinK Offline
                                KusselinK Offline
                                Kusselin
                                #68
                                was ist das und was sagt mir das jetzt...was ist eigentlich mein problem???
                                habe ein komplettimage neu aufgespielt....und seit dem kann ich den adapter tr-064 nicht updaten......
                                  #69
                                  @Kusselin Wann hast du denn das Image aufgespielt? So mal ganz neugierig.
                                  • KusselinK Offline
                                    KusselinK Offline
                                    Kusselin
                                    #70
                                    am sonntag muss das gewesen sein......thomas...wieso fragst du
                                    hab ich da fehler mit gezogen?
                                      #71
                                      @Kusselin
                                      Ich hätte ja ein Image mit Buster und nicht mit Stretch drauf geworfen.
                                      Bzw. gar kein Image sondern ein netinstall / lite gemacht.
                                      • KusselinK Offline
                                        KusselinK Offline
                                        Kusselin
                                        #72
                                        dann hätte ich alles frisch machen müssen..ich habe ein Komplettsicherungsimage aufgespielt....
                                          #73
                                          @Kusselin
                                          Wie willst du jetzt weiter mache? libvips bauen oder ein Backup im ioBroker ziehen und auf einer frischen Installation von Buster einspielen?
                                          Oder den ollen Stretch per dist-upgrade auf Buster bringen?
