  4. [gelöst] Fehler Adapter tr-064 - Startet nicht
Geplant Angeheftet Gesperrt Verschoben Gelöst ioBroker Allgemein
tr-064
82 Beiträge 14 Kommentatoren 16.8k Aufrufe 9 Beobachtet
  • KusselinK Offline
    KusselinK Offline
    Kusselin
    doch schau:
    pi@raspberrypi:~ $ iobroker add tr-064
    host.raspberrypi install adapter tr-064
    upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/wordss words.js application/javascript
    upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-06png tr-064.png image/png
    upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/indextml index.html text/html
    host.raspberrypi object system.adapter.tr-064 created/updated
    host.raspberrypi create instance tr-064
    host.raspberrypi object system.adapter.tr-064.0.sigKill created
    host.raspberrypi object system.adapter.tr-064.0.eventLoopLag created
    host.raspberrypi object system.adapter.tr-064.0.outputCount created
    host.raspberrypi object system.adapter.tr-064.0.inputCount created
    host.raspberrypi object system.adapter.tr-064.0.uptime created
    host.raspberrypi object system.adapter.tr-064.0.memRss created
    host.raspberrypi object system.adapter.tr-064.0.memHeapTotal created
    host.raspberrypi object system.adapter.tr-064.0.memHeapUsed created
    host.raspberrypi object system.adapter.tr-064.0.cputime created
    host.raspberrypi object system.adapter.tr-064.0.cpu created
    host.raspberrypi object system.adapter.tr-064.0.compactMode created
    host.raspberrypi object system.adapter.tr-064.0.connected created
    host.raspberrypi object system.adapter.tr-064.0.alive created
    host.raspberrypi object system.adapter.tr-064.0 created
    pi@raspberrypi:~ $ ^C
    • KusselinK Kusselin
      doch schau:
      @Kusselin
      Und was macht das
      iobroker upgrade
      nun?
      • KusselinK Offline
        KusselinK Offline
        Kusselin
        schrieb am zuletzt editiert von Kusselin
        kommt gleich..
        das discovery wird jetzt grad geupdatet auf 2.3.5
        das dauert schon ne ewigkeit.......
        • KusselinK Offline
          KusselinK Offline
          Kusselin
          #66
          pi@raspberrypi:~ $ iobroker upgrade
          Adapter "admin"          is up to date.
          Adapter "alarm"          is not installed.
          Adapter "alexa2"         is up to date.
          Adapter "alpha2"         is not installed.
          Adapter "amazon-dash"    is not installed.
          Adapter "artnet"         is not installed.
          Adapter "asterisk"       is not installed.
          Adapter "asuswrt"        is not installed.
          Adapter "b-control-em"   is not installed.
          Adapter "backitup"       is not installed.
          Adapter "beckhoff"       is not installed.
          Adapter "benq"           is not installed.
          Adapter "binance"        is not installed.
          Adapter "ble"            is up to date.
          Adapter "bmw"            is not installed.
          Adapter "bosesoundtouch" is not installed.
          Adapter "botvac"         is not installed.
          Adapter "bring"          is not installed.
          Adapter "broadlink2"     is not installed.
          Adapter "bsblan"         is not installed.
          Adapter "bshb"           is not installed.
          Adapter "chromecast"     is not installed.
          Adapter "cloud"          is up to date.
          Adapter "comfoair"       is not installed.
          Adapter "contactid"      is not installed.
          Adapter "coronavirus-statistics" is not installed.
          Adapter "countdown"      is not installed.
          Adapter "cul"            is not installed.
          Adapter "daikin"         is not installed.
          Adapter "daswetter"      is up to date.
          Adapter "deconz"         is not installed.
          Adapter "denon"          is up to date.
          Adapter "devices"        is not installed.
          Adapter "digitalstrom"   is not installed.
          Adapter "discovergy"     is not installed.
          Update discovery from @2.2.2 to @2.3.5
          NPM version: 6.14.5
          npm install iobroker.discovery@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
          ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
          info sharp Attempting to build from source via node-gyp but this may fail due to the above error
          info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
          ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
           #include <vips/vips8>
          compilation terminated.
          make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
          gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          gyp ERR! System Linux 4.19.66-v7+
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/sharp
          gyp ERR! node -v v10.21.0
          gyp ERR! node-gyp -v v5.1.0
          gyp ERR! not ok
            NPM version: 6.14.5
            gyp ERR! not ok
            #67
            @Kusselin sagte in [gelöst] Fehler Adapter tr-064 - Startet nicht:
            libvips
            Musst du vermutlich händisch bauen.
            https://libvips.github.io/libvips/install.html#building-libvips-from-a-source-tarball
            • KusselinK Offline
              KusselinK Offline
              Kusselin
              #68
              was ist das und was sagt mir das jetzt...was ist eigentlich mein problem???
              habe ein komplettimage neu aufgespielt....und seit dem kann ich den adapter tr-064 nicht updaten......
                #69
                @Kusselin Wann hast du denn das Image aufgespielt? So mal ganz neugierig.
                • KusselinK Offline
                  KusselinK Offline
                  Kusselin
                  #70
                  am sonntag muss das gewesen sein......thomas...wieso fragst du
                  hab ich da fehler mit gezogen?
                    #71
                    @Kusselin
                    Ich hätte ja ein Image mit Buster und nicht mit Stretch drauf geworfen.
                    Bzw. gar kein Image sondern ein netinstall / lite gemacht.
                    • KusselinK Offline
                      KusselinK Offline
                      Kusselin
                      #72
                      dann hätte ich alles frisch machen müssen..ich habe ein Komplettsicherungsimage aufgespielt....
                        #73
                        @Kusselin
                        Wie willst du jetzt weiter mache? libvips bauen oder ein Backup im ioBroker ziehen und auf einer frischen Installation von Buster einspielen?
                        Oder den ollen Stretch per dist-upgrade auf Buster bringen?
                        • KusselinK Offline
                          KusselinK Offline
                          Kusselin
                          #74
                          was ist eigemtlich mein Problem thomas..??? sind die adapter denn nicht mehr lauffähig mit dem stretch???? erklärs mir doch bitte..
                            #75
                            @Kusselin
                            Irgendein Adapter benötigt die Graphik-Bibliothek sharp, diese wiederum benötigt libvips und das muss man unter stretch selber bauen, weil das sonst niemand macht.
                            • KusselinK Offline
                              KusselinK Offline
                              Kusselin
                              #76
                              oder ich ziehe ein iobroker backup und kein komplettbackupimage und installiere von hier das lite
                              https://www.raspberrypi.org/downloads/raspberry-pi-os/
                              und spiele dann das iobroker backup wieder ein...richtig......?
                                #77
                                @Kusselin Ja, das wäre meine Empfehlung.
                                Und dann würde ich auch gleich node12 installieren, nicht mehr node10.
                                • KusselinK Offline
                                  KusselinK Offline
                                  Kusselin
                                  #78
                                  o.k. verstanden....ist halt wieder mortz arbeit :-(
                                  aber o.k. das hab ich verstanden....ist beim backup dann was zu beachten noch?
                                  und soll ich das Pi OS lite nehmen?
                                    #79
                                    @Kusselin
                                    Ist doch ratzfatz erledigt.
                                    Backup? Am besten mit dem Backitup-Adapter machen.
                                    Und ich würde Pi OS lite nehmen. Desktop brauchst und willst du auf dem Pi ja nicht.
                                    • KusselinK Offline
                                      KusselinK Offline
                                      Kusselin
                                      #80
                                      ok danke dir thomas für die hilfe und geduld...ich melde mich wieder......
                                        Jan1
                                        #81
                                        @Kusselin
                                        So noch mal kurz zu Deinem eigentlich von Dir ursprünglich genanntem Problem. Die Antwort darauf war der Fixer, der auch in der Beschreibung des Images genannt wurde. Dann war der TR-064 in all Deinen Logs nie zu sehen und Du hast versucht diesen zu deinstallieren, was kein Sinn ergibt.
                                        Die Ausführung des Fixer lief nicht weil im Log schon stand, dass der IOBroker vorher zu stoppen ist.
                                        Du hast den IOBroker so wie ich es verstanden habe ja eh neu und noch keine Scripte oder sonst was damit gemacht, dann ist der Mehraufwand wenn man alles selber macht minimal und wesentlich besser, da man gleich alles aktuell aufbauen kann und nicht erst ein altes Image auf neu umbiegen muss.
                                        Ein Backup vom jetzigen System kann man schon einspielen, nur da ist außer die Adapter ja nix drauf, somit würde ich das ganze wie Thomas schon schrieb selber neu machen.
                                        KusselinK 1 Antwort Letzte Antwort
                                        • J Jan1
                                          @Kusselin
                                          KusselinK Offline
                                          KusselinK Offline
                                          Kusselin
                                          #82
                                          @Jan1 ok danke für die Tipps
