  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 607.0k Aufrufe 89 Beobachtet
  • H Offline
    hannoi
    #1288
    Hatte auch gerade nach dem JS-controller Update von 3.1.4 auf 3.1.5 folgende Fehlermeldung und der Javascript Adapter hat nicht mehr gestartet:
    2020-06-11 10:30:15.045	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2020-06-11 10:30:15.045	error	Caught by controller[0]: }
    2020-06-11 10:30:15.045	error	Caught by controller[0]: ]
    2020-06-11 10:30:15.045	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    2020-06-11 10:30:15.045	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
    2020-06-11 10:30:15.045	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/compiler.js',
    2020-06-11 10:30:15.044	error	Caught by controller[0]: requireStack: [
    2020-06-11 10:30:15.044	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2020-06-11 10:30:15.044	error	Caught by controller[0]: {
    2020-06-11 10:30:15.044	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    2020-06-11 10:30:15.044	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
    2020-06-11 10:30:15.044	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
    2020-06-11 10:30:15.044	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
    2020-06-11 10:30:15.043	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
    2020-06-11 10:30:15.043	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
    2020-06-11 10:30:15.043	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    2020-06-11 10:30:15.043	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
    2020-06-11 10:30:15.043	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
    2020-06-11 10:30:15.043	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
    2020-06-11 10:30:15.043	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
    2020-06-11 10:30:15.042	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
    2020-06-11 10:30:15.042	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
    2020-06-11 10:30:15.042	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
    2020-06-11 10:30:15.042	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
    2020-06-11 10:30:15.042	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
    2020-06-11 10:30:15.042	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
    2020-06-11 10:30:15.042	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
    2020-06-11 10:30:15.041	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
    2020-06-11 10:30:15.041	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
    2020-06-11 10:30:15.041	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
    2020-06-11 10:30:15.041	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
    2020-06-11 10:30:15.041	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
    2020-06-11 10:30:15.041	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
    2020-06-11 10:30:15.041	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    2020-06-11 10:30:15.040	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
    2020-06-11 10:30:15.040	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/compiler.js
    2020-06-11 10:30:15.040	error	Caught by controller[0]: Require stack:
    2020-06-11 10:30:15.040	error	Caught by controller[0]: Error: Cannot find module 'typescript'
    2020-06-11 10:30:15.040	error	Caught by controller[0]: ^
    2020-06-11 10:30:15.040	error	Caught by controller[0]: throw err;
    2020-06-11 10:30:15.039	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
    Nach einem "npm install typescript" im iobroker dir hat die ScriptEngine wieder funktioniert.
    • FragMikeF Offline
      FragMikeF Offline
      FragMike
      #1289
      habe mir bereits einmal mein IOBROKER WIN SYSTEM geschrottet 😵 ....Klappt das Update nun?
      • FragMikeF FragMike
        haselchenH Offline
        haselchenH Offline
        haselchen
        #1290
        @FragMike
        Unsere Forums- Glaskugel hat heute leider frei.....also wären ein paar Infos nicht schlecht.
        Systeminfos
        Welches Update (von wo nach wo)
        und und und....
        einfach mal ein wenig Input.
        • FragMikeF Offline
          FragMikeF Offline
          FragMike
          #1291
          Hi Sorry....
          Habe IOBROKER auf WIN 10 SYSTEM mit Atom Dualcore 4 gig RAM mit SSD
          Sytemauslastung liegt normalerweise bei 55% wenn alle Skripte laufen.
          Das ist aktuell :
          Typ: js-controller
          Titel: JS controller
          OS: win32
          Verfügbar: 3.1.5
          Installiert: 2.1.0
          Ereignisse: ⇥10 / ↦12
          Ein update des JS Controllers hatte bereits in der Vergangenheit katastrophale Folgen.
          Hatte hier gelesen, dass es ein gesondertes Installationspaket für WIN geben wird...
          Thomas BraunT GarfonsoG 2 Antworten Letzte Antwort
            Hi Sorry....
            Das ist aktuell :
            Typ: js-controller
            OS: win32
            Verfügbar: 3.1.5
            Installiert: 2.1.0
            #1292
            @FragMike Ja, da soll was kommen für Windows.
            FragMikeF 1 Antwort Letzte Antwort
              FragMikeF Offline
              FragMikeF Offline
              FragMike
              #1293
              @Thomas-Braun sagte in js-controller 3.0/3.1 jetzt im Latest!:
              schon seid 6 Monaten ;-)
              Muss ich wieder auf Linux System umziehen?
              Raspi hat seinerzeit nur rumgezickt und 2 SD Karten zernichtet.
              VM mit Linux unter WIN ...dann kann ich auch ein SNAPSHOT als Backup machen...
              macht das Sinn?
                macht das Sinn?
                #1294
                @FragMike sagte in js-controller 3.0/3.1 jetzt im Latest!:
                Keine Ahnung. Mein Linux läuft jedenfalls klag- und problemlos.
                iobroker auf einen Raspbian Buster. Ich persönlich bin kein Fan von VMs.
                  Hi Sorry....
                  Das ist aktuell :
                  Typ: js-controller
                  OS: win32
                  Verfügbar: 3.1.5
                  Installiert: 2.1.0
                  GarfonsoG Offline
                  GarfonsoG Offline
                  Garfonso
                  #1295
                  @FragMike
                  Das mit dem "speziellen Paket" hab ich auch gelesen. Irgendwo hatte ich auch mal nachgefragt, da hieß es dann, man soll "einfach nochmal den Installer runterladen und ausführen" -> wobei mir dann total unklar ist, was man da machen soll... ein "update" gibt es da leider nicht, nur neuanlegen (beschwert sich, dass es den Instanznamen schon gibt), Löschen und importieren. Vermutlich könnte Instanz Löschen, dann neu anlegen mit Import der "richtige" Weg sein... war mir aber zu unsicher das so zu machen, ohne dass ich da eine offzielle Bestätigung hab (und fände ich auch einen ganz schön umständlichen weg).
                  Daher habe ich das Update auch unter Windows "von Hand" gemacht, ging gut.
                  Also:
                  • mit Startmenü Eintrag die ioBroker Konsole starten
                  • ioBroker stoppen (iob stop bzw. Dienst manuell anhalten)
                  • iob upgrade self (oder, wenn er "nervt" npm install iobroker.js-controller, weiß nicht mehr, welches ging) -> upgrade wird ausgeführt
                  • ioBroker wieder starten iob start / Dienst manuell starten)
                  Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                  Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
                  • GarfonsoG Garfonso
                    @FragMike
                    Also:
                    FragMikeF Offline
                    FragMikeF Offline
                    FragMike
                    #1296
                    @Garfonso
                    Hi..danke für deine Antwort...ich glaube genau so habe ich das seinerzeit gemacht. Ging leider in die Hose...danach half nur noch den Rechner komplett neu aufzusetzen und das Backup wieder einzuspielen. Mal schauen, ob es diesmal klappt 😳🤷
                      @Garfonso
                      JB_SullivanJ Offline
                      JB_Sullivan
                      schrieb am zuletzt editiert von JB_Sullivan
                      #1297
                      @FragMike
                      Wir haben das Thema Windows und ioBroker in einem anderen Thread ausführlich durchgekaut.
                      Der Knackpunkt ist diese Vorgehensweise wie sie AlCalzone dort beschreibt.
                      Dann gibt es auch keine Probleme mehr mit dem zerschießen, wenn ein Adapter aktualisiert / neu installiert oder gelöscht wird.
                      https://forum.iobroker.net/topic/33421/iobroker-unter-windows-installieren-ohne-installer/125
                      • JB_SullivanJ JB_Sullivan
                        @FragMike
                        FragMikeF Offline
                        FragMikeF Offline
                        FragMike
                        #1298
                        @JB_Sullivan
                        Danke...Lesestoff👍
                        • apollon77A Offline
                          #1299
                          Aus gegebenem Anlass hier noch ein Controller Update auf 3.1.6 ab bald im Latest:
                          3.1.6 (2020-06-18) Release Francesca
                          • (foxriver76) fix output of iobroker plugin status command
                          • (foxriver76) fix deletion of states on instance-deletion
                          • (Apollon77) add additional checks to prevent Errors (Sentry)
                          • (Apollon77) Make sure Sentry activation info is also shown on upgrade self command
                          • (Apollon77) Upgrade winston-daily-rotate-file library to prevent a crash case
                          ? UweRLPU 2 Antworten Letzte Antwort
                          • apollon77A apollon77
                            #1300
                            @apollon77 Hi, hier verträgt sich die Francesca mit der Silvia und dem Buster einwandfrei. :-)
                              UweRLPU Offline
                              UweRLPU Offline
                              UweRLP
                              #1301
                              @apollon77 Das Problem https://forum.iobroker.net/post/445338 ist mit js-controller 3.1.6 leider noch nicht behoben. Sowohl nach update vom js-controller auf die 3.1.6 trat das Problem auf, habe ich dann repariert. Aber werden mit der 3.1.6 dann Adapter geupdatet starte der javascript Adaper wieder nicht und eine Reparatur des Adapters ist erneut notwendig.
                              • UweRLPU UweRLP
                                #1302
                                @UweRLP Da kann der Controller nichts dran ändern, das hat mit npm und damit wie die Windows Systeme teilweise installiert sind zu tun ...
                                UweRLPU 1 Antwort Letzte Antwort
                                  UweRLPU Offline
                                  UweRLPU Offline
                                  UweRLP
                                  #1303
                                  @apollon77 Ok, danke für die Info.
                                  Wenn ich das dann richtig verstanden habe wird es vielleicht eines Tages mit einem Update von NodeJS behoben sein?
                                  • UweRLPU UweRLP
                                    #1304
                                    @UweRLP Wo steht das? In meiner Welt kann das maximal die Nutzung des "neuen" Windows Installers 2.0 oder ne manuelle Installation fixen . aber ich bin zu weit draussen was Windows angeht
                                      UweRLPU Offline
                                      UweRLPU Offline
                                      UweRLP
                                      #1305
                                      @apollon77 sagte in js-controller 3.0/3.1 jetzt im Latest!:
                                      Das war meine Interpretation, allerdingt verstehe ich auch nicht immer alles so wie es gemeint war 😊
                                      Für mich nehme ich dann erst mal mit, dass ich diesen Fehler nicht mehr weiter zu melden brauche und warte bis es einen neuen Installer gibt. 👍
                                      • UweRLPU UweRLP
                                        #1306
                                        @UweRLP sagte in js-controller 3.0/3.1 jetzt im Latest!:
                                        Oder sich endlich von Windows verabschieden und auf eine ordentliche Linux Distribution setzen :-)
                                        -1
                                          sigi234S Online
                                          sigi234S Online
                                          #1307
                                          @Yetiberg sagte in js-controller 3.0/3.1 jetzt im Latest!:
                                          Warum? Ist ioBroker nicht für Alle Betriebssysteme?
