  4. js-controller 3.0/3.1 jetzt im Latest!
js-controller
1.3k Beiträge 127 Kommentatoren 607.0k Aufrufe 89 Beobachtet
  • JackDanielJ Online
    JackDanielJ Online
    JackDaniel
    schrieb am zuletzt editiert von JackDaniel
    #1285
    bei mir das selbe nach dem js-controller update mit dem javascript adapter aber unter linux
    das "npm install --production" hat bei mir keine verbesserung gebracht
    host.raspberrypi	2020-06-08 19:28:53.785	info	Restart adapter system.adapter.javascript.0 because enabled
    host.raspberrypi	2020-06-08 19:28:53.785	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2020-06-08 19:28:53.784	error	Caught by controller[0]: }
    host.raspberrypi	2020-06-08 19:28:53.784	error	Caught by controller[0]: ]
    host.raspberrypi	2020-06-08 19:28:53.784	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    host.raspberrypi	2020-06-08 19:28:53.783	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
    host.raspberrypi	2020-06-08 19:28:53.783	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/compiler.js',
    host.raspberrypi	2020-06-08 19:28:53.783	error	Caught by controller[0]: requireStack: [
    host.raspberrypi	2020-06-08 19:28:53.782	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi	2020-06-08 19:28:53.782	error	Caught by controller[0]: {
    host.raspberrypi	2020-06-08 19:28:53.782	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.raspberrypi	2020-06-08 19:28:53.782	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
    host.raspberrypi	2020-06-08 19:28:53.781	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
    host.raspberrypi	2020-06-08 19:28:53.781	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
    host.raspberrypi	2020-06-08 19:28:53.781	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
    host.raspberrypi	2020-06-08 19:28:53.780	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
    host.raspberrypi	2020-06-08 19:28:53.780	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    host.raspberrypi	2020-06-08 19:28:53.780	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
    host.raspberrypi	2020-06-08 19:28:53.779	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
    host.raspberrypi	2020-06-08 19:28:53.779	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
    host.raspberrypi	2020-06-08 19:28:53.779	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
    host.raspberrypi	2020-06-08 19:28:53.778	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
    host.raspberrypi	2020-06-08 19:28:53.778	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
    host.raspberrypi	2020-06-08 19:28:53.778	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
    host.raspberrypi	2020-06-08 19:28:53.777	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
    host.raspberrypi	2020-06-08 19:28:53.777	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
    host.raspberrypi	2020-06-08 19:28:53.777	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
    host.raspberrypi	2020-06-08 19:28:53.776	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
    host.raspberrypi	2020-06-08 19:28:53.776	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
    host.raspberrypi	2020-06-08 19:28:53.776	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
    host.raspberrypi	2020-06-08 19:28:53.775	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
    host.raspberrypi	2020-06-08 19:28:53.775	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
    host.raspberrypi	2020-06-08 19:28:53.775	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
    host.raspberrypi	2020-06-08 19:28:53.774	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
    host.raspberrypi	2020-06-08 19:28:53.773	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
    host.raspberrypi	2020-06-08 19:28:53.773	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    host.raspberrypi	2020-06-08 19:28:53.773	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
    host.raspberrypi	2020-06-08 19:28:53.772	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/compiler.js
    host.raspberrypi	2020-06-08 19:28:53.772	error	Caught by controller[0]: Require stack:
    host.raspberrypi	2020-06-08 19:28:53.771	error	Caught by controller[0]: Error: Cannot find module 'typescript'
    host.raspberrypi	2020-06-08 19:28:53.771	error	Caught by controller[0]: ^
    host.raspberrypi	2020-06-08 19:28:53.770	error	Caught by controller[0]: throw err;
    host.raspberrypi	2020-06-08 19:28:53.769	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
    host.raspberrypi	2020-06-08 19:28:53.443	info	instance system.adapter.javascript.0 started with pid 6547
    host.raspberrypi	2020-06-08 19:28:53.384	info	"system.adapter.javascript.0" enabled
    edit:
    hab den adapter nochmal beendet und dann erneut mit:
    cd /opt/iobroker/node_modules/iobroker.javascript
    jetzt läuft er wieder 👍
    Carpe diem
    • apollon77A apollon77
      @UweRLP Am besten wäre es
      • Ins Verzeichnis des adapter swechseln ... also vom ioBroker verzeichnis aus in node_modules/iobroker.javascript wechseln
      • "npm install --production"
      gehts danach
      UweRLPU Offline
      UweRLPU Offline
      UweRLP
      #1286
      @apollon77 sagte in js-controller 3.0/3.1 jetzt im Latest!:
      gehts danach
      Ja, das hat bei mir geholfen. javascript läuft wieder und alle Adapter sind aktuell.
      Vielen Dank.
      Bei diesem Versuch habe ich die Adapter einzeln mit
      iobroker upgrade adaptername
      bei laufendem iobroker geupdatet, ohne späteres
      iobroker upload all
      Nach einem stoppen vom iobroker und wieder starten hatte ich dann wieder den Fehler mit dem javascript Adapter.
      Nach dem
      im ../node_module/iobroker.javascript läuft es nun wieder.
      • UweRLPU Offline
        UweRLPU Offline
        UweRLP
        #1287
        Der Fehler tritt immer wieder bei Adapterupdates auf.
        • H Offline
          hannoi
          #1288
          Hatte auch gerade nach dem JS-controller Update von 3.1.4 auf 3.1.5 folgende Fehlermeldung und der Javascript Adapter hat nicht mehr gestartet:
          2020-06-11 10:30:15.045	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2020-06-11 10:30:15.045	error	Caught by controller[0]: }
          2020-06-11 10:30:15.045	error	Caught by controller[0]: ]
          2020-06-11 10:30:15.045	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
          2020-06-11 10:30:15.045	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
          2020-06-11 10:30:15.045	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/compiler.js',
          2020-06-11 10:30:15.044	error	Caught by controller[0]: requireStack: [
          2020-06-11 10:30:15.044	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          2020-06-11 10:30:15.044	error	Caught by controller[0]: {
          2020-06-11 10:30:15.044	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
          2020-06-11 10:30:15.044	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
          2020-06-11 10:30:15.044	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
          2020-06-11 10:30:15.044	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
          2020-06-11 10:30:15.043	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
          2020-06-11 10:30:15.043	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
          2020-06-11 10:30:15.043	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
          2020-06-11 10:30:15.043	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
          2020-06-11 10:30:15.043	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
          2020-06-11 10:30:15.043	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
          2020-06-11 10:30:15.043	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
          2020-06-11 10:30:15.042	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
          2020-06-11 10:30:15.042	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
          2020-06-11 10:30:15.042	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
          2020-06-11 10:30:15.042	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
          2020-06-11 10:30:15.042	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
          2020-06-11 10:30:15.042	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
          2020-06-11 10:30:15.042	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
          2020-06-11 10:30:15.041	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
          2020-06-11 10:30:15.041	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
          2020-06-11 10:30:15.041	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
          2020-06-11 10:30:15.041	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
          2020-06-11 10:30:15.041	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
          2020-06-11 10:30:15.041	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
          2020-06-11 10:30:15.041	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
          2020-06-11 10:30:15.040	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
          2020-06-11 10:30:15.040	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/compiler.js
          2020-06-11 10:30:15.040	error	Caught by controller[0]: Require stack:
          2020-06-11 10:30:15.040	error	Caught by controller[0]: Error: Cannot find module 'typescript'
          2020-06-11 10:30:15.040	error	Caught by controller[0]: ^
          2020-06-11 10:30:15.040	error	Caught by controller[0]: throw err;
          2020-06-11 10:30:15.039	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
          Nach einem "npm install typescript" im iobroker dir hat die ScriptEngine wieder funktioniert.
          • FragMikeF Offline
            FragMikeF Offline
            FragMike
            #1289
            habe mir bereits einmal mein IOBROKER WIN SYSTEM geschrottet 😵 ....Klappt das Update nun?
            • FragMikeF FragMike
              haselchenH Offline
              haselchenH Offline
              haselchen
              #1290
              @FragMike
              Unsere Forums- Glaskugel hat heute leider frei.....also wären ein paar Infos nicht schlecht.
              Systeminfos
              Welches Update (von wo nach wo)
              und und und....
              einfach mal ein wenig Input.
              • FragMikeF Offline
                FragMikeF Offline
                FragMike
                #1291
                Hi Sorry....
                Habe IOBROKER auf WIN 10 SYSTEM mit Atom Dualcore 4 gig RAM mit SSD
                Sytemauslastung liegt normalerweise bei 55% wenn alle Skripte laufen.
                Das ist aktuell :
                Typ: js-controller
                Titel: JS controller
                OS: win32
                Verfügbar: 3.1.5
                Installiert: 2.1.0
                Ereignisse: ⇥10 / ↦12
                Ein update des JS Controllers hatte bereits in der Vergangenheit katastrophale Folgen.
                Hatte hier gelesen, dass es ein gesondertes Installationspaket für WIN geben wird...
                Thomas BraunT GarfonsoG 2 Antworten Letzte Antwort
                  Hi Sorry....
                  Das ist aktuell :
                  Typ: js-controller
                  OS: win32
                  Verfügbar: 3.1.5
                  Installiert: 2.1.0
                  #1292
                  @FragMike Ja, da soll was kommen für Windows.
                  FragMikeF 1 Antwort Letzte Antwort
                    FragMikeF Offline
                    FragMikeF Offline
                    FragMike
                    #1293
                    @Thomas-Braun sagte in js-controller 3.0/3.1 jetzt im Latest!:
                    schon seid 6 Monaten ;-)
                    Muss ich wieder auf Linux System umziehen?
                    Raspi hat seinerzeit nur rumgezickt und 2 SD Karten zernichtet.
                    VM mit Linux unter WIN ...dann kann ich auch ein SNAPSHOT als Backup machen...
                    macht das Sinn?
                      macht das Sinn?
                      #1294
                      @FragMike sagte in js-controller 3.0/3.1 jetzt im Latest!:
                      Keine Ahnung. Mein Linux läuft jedenfalls klag- und problemlos.
                      iobroker auf einen Raspbian Buster. Ich persönlich bin kein Fan von VMs.
                        Hi Sorry....
                        Das ist aktuell :
                        Typ: js-controller
                        OS: win32
                        Verfügbar: 3.1.5
                        Installiert: 2.1.0
                        GarfonsoG Offline
                        GarfonsoG Offline
                        Garfonso
                        #1295
                        @FragMike
                        Das mit dem "speziellen Paket" hab ich auch gelesen. Irgendwo hatte ich auch mal nachgefragt, da hieß es dann, man soll "einfach nochmal den Installer runterladen und ausführen" -> wobei mir dann total unklar ist, was man da machen soll... ein "update" gibt es da leider nicht, nur neuanlegen (beschwert sich, dass es den Instanznamen schon gibt), Löschen und importieren. Vermutlich könnte Instanz Löschen, dann neu anlegen mit Import der "richtige" Weg sein... war mir aber zu unsicher das so zu machen, ohne dass ich da eine offzielle Bestätigung hab (und fände ich auch einen ganz schön umständlichen weg).
                        Daher habe ich das Update auch unter Windows "von Hand" gemacht, ging gut.
                        Also:
                        • mit Startmenü Eintrag die ioBroker Konsole starten
                        • ioBroker stoppen (iob stop bzw. Dienst manuell anhalten)
                        • iob upgrade self (oder, wenn er "nervt" npm install iobroker.js-controller, weiß nicht mehr, welches ging) -> upgrade wird ausgeführt
                        • ioBroker wieder starten iob start / Dienst manuell starten)
                        Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                        Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
                        • GarfonsoG Garfonso
                          @FragMike
                          Also:
                          FragMikeF Offline
                          FragMikeF Offline
                          FragMike
                          #1296
                          @Garfonso
                          Hi..danke für deine Antwort...ich glaube genau so habe ich das seinerzeit gemacht. Ging leider in die Hose...danach half nur noch den Rechner komplett neu aufzusetzen und das Backup wieder einzuspielen. Mal schauen, ob es diesmal klappt 😳🤷
                            @Garfonso
                            JB_SullivanJ Offline
                            JB_Sullivan
                            schrieb am zuletzt editiert von JB_Sullivan
                            #1297
                            @FragMike
                            Wir haben das Thema Windows und ioBroker in einem anderen Thread ausführlich durchgekaut.
                            Der Knackpunkt ist diese Vorgehensweise wie sie AlCalzone dort beschreibt.
                            Dann gibt es auch keine Probleme mehr mit dem zerschießen, wenn ein Adapter aktualisiert / neu installiert oder gelöscht wird.
                            https://forum.iobroker.net/topic/33421/iobroker-unter-windows-installieren-ohne-installer/125
                            • JB_SullivanJ JB_Sullivan
                              @FragMike
                              FragMikeF Offline
                              FragMikeF Offline
                              FragMike
                              #1298
                              @JB_Sullivan
                              Danke...Lesestoff👍
                              • apollon77A Offline
                                #1299
                                Aus gegebenem Anlass hier noch ein Controller Update auf 3.1.6 ab bald im Latest:
                                3.1.6 (2020-06-18) Release Francesca
                                • (foxriver76) fix output of iobroker plugin status command
                                • (foxriver76) fix deletion of states on instance-deletion
                                • (Apollon77) add additional checks to prevent Errors (Sentry)
                                • (Apollon77) Make sure Sentry activation info is also shown on upgrade self command
                                • (Apollon77) Upgrade winston-daily-rotate-file library to prevent a crash case
                                ? UweRLPU 2 Antworten Letzte Antwort
                                  #1300
                                  @apollon77 Hi, hier verträgt sich die Francesca mit der Silvia und dem Buster einwandfrei. :-)
                                    UweRLPU Offline
                                    UweRLPU Offline
                                    UweRLP
                                    #1301
                                    @apollon77 Das Problem https://forum.iobroker.net/post/445338 ist mit js-controller 3.1.6 leider noch nicht behoben. Sowohl nach update vom js-controller auf die 3.1.6 trat das Problem auf, habe ich dann repariert. Aber werden mit der 3.1.6 dann Adapter geupdatet starte der javascript Adaper wieder nicht und eine Reparatur des Adapters ist erneut notwendig.
                                    • UweRLPU UweRLP
                                      #1302
                                      @UweRLP Da kann der Controller nichts dran ändern, das hat mit npm und damit wie die Windows Systeme teilweise installiert sind zu tun ...
                                      UweRLPU 1 Antwort Letzte Antwort
                                        UweRLPU Offline
                                        UweRLPU Offline
                                        UweRLP
                                        #1303
                                        @apollon77 Ok, danke für die Info.
                                        Wenn ich das dann richtig verstanden habe wird es vielleicht eines Tages mit einem Update von NodeJS behoben sein?
                                        • UweRLPU UweRLP
                                          #1304
                                          @UweRLP Wo steht das? In meiner Welt kann das maximal die Nutzung des "neuen" Windows Installers 2.0 oder ne manuelle Installation fixen . aber ich bin zu weit draussen was Windows angeht
