  4. Test Adapter ioBroker.backitup v3.1.x
    5.7k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • simatecS simatec
    @deMarvin
    Was kommt für eine Fehlermeldung?
    Bitte poste mal den Log aus dem WebIf vom Backitup Restore
    deMarvin
    #512
    @simatec
    Log Backitup Restore:
    [DEBUG] [mysql] Start mysql Restore ...
    [ERROR] [mysql] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/mysql_restore_backupiobroker.sql'
    [ERROR] [mysql] mysql Restore not completed
    [EXIT] undefined **** Restore completed successfully!! ****
    The log can be closed ...
    backitup.0	2020-06-12 11:35:56.869	info	(20101) [iobroker] backup was activated at 04:00 every 1 day(s)
    backitup.0	2020-06-12 11:35:56.841	warn	(20101) Cannot read log file: ReferenceError: config is not defined
    backitup.0	2020-06-12 11:35:56.836	debug	(20101) [EXIT] undefined
    backitup.0	2020-06-12 11:35:56.835	error	(20101) [ERROR] [mysql] mysql Restore not completed
    backitup.0	2020-06-12 11:35:56.834	error	(20101) [ERROR] [mysql] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/mysql_restore_backupiobroker.sql'
    backitup.0	2020-06-12 11:35:56.832	debug	(20101) [DEBUG] [mysql] Start mysql Restore ...
    backitup.0	2020-06-12 11:35:56.826	debug	(20101) Printing logs of previous backup
    backitup.0	2020-06-12 11:35:56.793	info	(20101) starting. Version 1.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.0, js-controller: 3.1.4
    simatecS Thomas BraunT 3 Antworten Letzte Antwort
    • D deMarvin
      @simatec
      simatecS Offline
      simatecS Offline
      simatec
      #513
      @deMarvin
      Du hast keine Zugriffsrechte auf das mysql backup
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • D deMarvin
        @simatec
        simatecS Offline
        simatecS Offline
        simatec
        #514
        @deMarvin
        Von welchem System gast du dieses Backup?
        Ist das noch eine ältere Iobroker Installation, wo iobroker noch als root lief?
        • D deMarvin
          @simatec
          #515
          @deMarvin sagte in Test Adapter Backitup v1.5.x:
          Wie sehen denn die Rechte an der Datei aus?
          ls -la /opt/iobroker/backups/mysql_restore_backupiobroker.sql
            deMarvin
            #516
            @simatec @Thomas-Braun
            Doch ich habe Rechte an der Datei
            pi@iobroker:~ $ ls -la /opt/iobroker/backups/mysql_restore_backupiobroker.sql
            -rwxrwxrwx 1 root root 36787597 Jun 12 11:35 /opt/iobroker/backups/mysql_restore_backupiobroker.sql
            @simatec said in Test Adapter Backitup v1.5.x:
            @deMarvin
            Nein, iobroker lief bei mir nie als Root
            simatecS 2 Antworten Letzte Antwort
            • D deMarvin
              @deMarvin
              simatecS Offline
              simatecS Offline
              simatec
              #517
              @deMarvin
              Ich schaue mit da mal die Tage den Installer bzw. auch den Fixer an.
              mysqldump ist da definitiv drin, aber für den Restore wird mysql direkt benötigt und da muss ich mal schauen, ob da alle Rechte für den User iobroker passen
              • D deMarvin
                @deMarvin
                simatecS Offline
                simatecS Offline
                simatec
                #518
                @deMarvin
                Noch ne andere Frage ... wie sieht denn deine Installation von mysql aus?
                Hast du User und dB bereits wieder angelegt und passen die Daten der Config für backitup?
                Mich wundert dein Fehler etwas ...
                • simatecS simatec
                  @deMarvin
                  deMarvin
                  #519
                  @simatec
                  Ja habe alles wie vorher angelegt, also gleicher User mit gleichem PW (ist ja nur für den Adapter wichtig) und die DB hat auch den gleichen Namen.
                  • D deMarvin
                    @simatec
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #520
                    @deMarvin
                    Kannst du bitte trotzdem mal versuchen, ein backup, welches mit dem neuen System gemacht wurde wiederherzustellen?
                    • simatecS simatec
                      @deMarvin
                      deMarvin
                      #521
                      @simatec
                      Mit Backup des neuen Systems kommt der gleiche Fehler.
                      • D deMarvin
                        @simatec
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #522
                        @deMarvin
                        Mit 1.5.8 und 1.5.9?
                        • simatecS simatec
                          @deMarvin
                          deMarvin
                          schrieb am zuletzt editiert von deMarvin
                          #523
                          @simatec
                          1.5.9, 1.5.8 müsste ich mal testen
                          [edit]
                          Bei 1.5.8 und 1.5.9 kommt es zum gleichen Fehler.
                          • Markus SeewerM Offline
                            Markus Seewer
                            #524
                            Kann man mit dem Adapter auch Backups an einen SFTP übertragen ähnlich wie beim FTP Service der schon im Adapter vorhanden ist. Und wenn nein, könnte man das nachrüsten mit einem zukünftigen Update?
                            • Markus SeewerM Markus Seewer
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #525
                              @Markus-Seewer
                              Aktuell wird nur ftp unterstützt ...
                              Markus SeewerM 1 Antwort Letzte Antwort
                              • simatecS simatec
                                @Markus-Seewer
                                Markus Seewer
                                #526
                                @simatec könnte man SFTP den nachrüsten?
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #527
                                  @Markus-Seewer
                                  Muss ich mir mal anschauen
                                  • D deMarvin
                                    @simatec
                                    [edit]
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #528
                                    @deMarvin
                                    Habe jetzt mal Zeit gefunden und auf meinem Testsystem Mysql installiert ...
                                    Sowohl Backup als auch den Restore konnte ich mit Backitup 1.5.8 ohne Probleme durchführen.
                                    Irgendwas scheint an deinem System bzw. rechten nicht zu passen.
                                    Bisher habe ich auch keine Meldungen zu dem Thema bekommen, was darauf deutet, dass es auch keine Probleme gibt. Schau mal bitte nach deinen Rechten, gerade auch auf deinem alten System ....
                                    Denn so wie es ausschaut, hat dein mysql Backupfile nicht die benötigten Rechte
                                    • simatecS simatec
                                      @deMarvin
                                      deMarvin
                                      #529
                                      @simatec
                                      Ja ich werde mal wenn ich Zeit habe einen manuellen restore versuchen und guck dann, an welcher Stelle es scheitert und warum. Natürlich gebe ich dann nochmal Rückmeldung.
                                      Trotzdem danke für die Unterstützung bis jetzt 👍
                                      • simatecS simatec
                                        @Markus-Seewer
                                        Markus Seewer
                                        #530
                                        @simatec Besten Dank
                                        • ? Offline
                                          #531
                                          @simatec kann backitup auch sftp? Ich hatte bisher die Verbindung über FTP Port 21 und wollte nun auf SFTP Port 22 umstellen. Die Login Daten habe ich kopiert und per Filezilla geprüft ob ich mich verbinden kann. backitup verbindet sich leider nicht...
