  4. Test Adapter ioBroker.backitup v3.1.x
    5.7k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • simatecS simatec
    @deMarvin
    Welche Version hast du installiert?
    1.5.8?
    deMarvin
    #510
    @simatec
    Nein, die 1.5.9
    • D deMarvin
      @simatec
      Nein, die 1.5.9
      simatecS Offline
      simatecS Offline
      simatec
      #511
      @deMarvin
      Was kommt für eine Fehlermeldung?
      Bitte poste mal den Log aus dem WebIf vom Backitup Restore
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        @deMarvin
        deMarvin
        #512
        @simatec
        Log Backitup Restore:
        [DEBUG] [mysql] Start mysql Restore ...
        [ERROR] [mysql] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/mysql_restore_backupiobroker.sql'
        [ERROR] [mysql] mysql Restore not completed
        [EXIT] undefined **** Restore completed successfully!! ****
        The log can be closed ...
        backitup.0	2020-06-12 11:35:56.869	info	(20101) [iobroker] backup was activated at 04:00 every 1 day(s)
        backitup.0	2020-06-12 11:35:56.841	warn	(20101) Cannot read log file: ReferenceError: config is not defined
        backitup.0	2020-06-12 11:35:56.836	debug	(20101) [EXIT] undefined
        backitup.0	2020-06-12 11:35:56.835	error	(20101) [ERROR] [mysql] mysql Restore not completed
        backitup.0	2020-06-12 11:35:56.834	error	(20101) [ERROR] [mysql] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/mysql_restore_backupiobroker.sql'
        backitup.0	2020-06-12 11:35:56.832	debug	(20101) [DEBUG] [mysql] Start mysql Restore ...
        backitup.0	2020-06-12 11:35:56.826	debug	(20101) Printing logs of previous backup
        backitup.0	2020-06-12 11:35:56.793	info	(20101) starting. Version 1.5.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.0, js-controller: 3.1.4
        simatecS Thomas BraunT 3 Antworten Letzte Antwort
        • D deMarvin
          @simatec
          simatecS Offline
          simatecS Offline
          simatec
          #513
          @deMarvin
          Du hast keine Zugriffsrechte auf das mysql backup
          • D deMarvin
            @simatec
            simatecS Offline
            simatecS Offline
            simatec
            #514
            @deMarvin
            Von welchem System gast du dieses Backup?
            Ist das noch eine ältere Iobroker Installation, wo iobroker noch als root lief?
            • D deMarvin
              @simatec
              #515
              @deMarvin sagte in Test Adapter Backitup v1.5.x:
              Wie sehen denn die Rechte an der Datei aus?
              ls -la /opt/iobroker/backups/mysql_restore_backupiobroker.sql
                deMarvin
                #516
                @simatec @Thomas-Braun
                Doch ich habe Rechte an der Datei
                pi@iobroker:~ $ ls -la /opt/iobroker/backups/mysql_restore_backupiobroker.sql
                -rwxrwxrwx 1 root root 36787597 Jun 12 11:35 /opt/iobroker/backups/mysql_restore_backupiobroker.sql
                @simatec said in Test Adapter Backitup v1.5.x:
                @deMarvin
                Nein, iobroker lief bei mir nie als Root
                simatecS 2 Antworten Letzte Antwort
                • D deMarvin
                  @deMarvin
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #517
                  @deMarvin
                  Ich schaue mit da mal die Tage den Installer bzw. auch den Fixer an.
                  mysqldump ist da definitiv drin, aber für den Restore wird mysql direkt benötigt und da muss ich mal schauen, ob da alle Rechte für den User iobroker passen
                  • D deMarvin
                    @deMarvin
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #518
                    @deMarvin
                    Noch ne andere Frage ... wie sieht denn deine Installation von mysql aus?
                    Hast du User und dB bereits wieder angelegt und passen die Daten der Config für backitup?
                    Mich wundert dein Fehler etwas ...
                    • simatecS simatec
                      @deMarvin
                      deMarvin
                      #519
                      @simatec
                      Ja habe alles wie vorher angelegt, also gleicher User mit gleichem PW (ist ja nur für den Adapter wichtig) und die DB hat auch den gleichen Namen.
                      • D deMarvin
                        @simatec
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #520
                        @deMarvin
                        Kannst du bitte trotzdem mal versuchen, ein backup, welches mit dem neuen System gemacht wurde wiederherzustellen?
                        • simatecS simatec
                          @deMarvin
                          deMarvin
                          #521
                          @simatec
                          Mit Backup des neuen Systems kommt der gleiche Fehler.
                          • D deMarvin
                            @simatec
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #522
                            @deMarvin
                            Mit 1.5.8 und 1.5.9?
                            • simatecS simatec
                              @deMarvin
                              deMarvin
                              schrieb am zuletzt editiert von deMarvin
                              #523
                              @simatec
                              1.5.9, 1.5.8 müsste ich mal testen
                              [edit]
                              Bei 1.5.8 und 1.5.9 kommt es zum gleichen Fehler.
                              • Markus SeewerM Offline
                                Markus Seewer
                                #524
                                Kann man mit dem Adapter auch Backups an einen SFTP übertragen ähnlich wie beim FTP Service der schon im Adapter vorhanden ist. Und wenn nein, könnte man das nachrüsten mit einem zukünftigen Update?
                                • Markus SeewerM Markus Seewer
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #525
                                  @Markus-Seewer
                                  Aktuell wird nur ftp unterstützt ...
                                  Markus SeewerM 1 Antwort Letzte Antwort
                                  • simatecS simatec
                                    @Markus-Seewer
                                    Markus Seewer
                                    #526
                                    @simatec könnte man SFTP den nachrüsten?
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #527
                                      @Markus-Seewer
                                      Muss ich mir mal anschauen
                                      • D deMarvin
                                        @simatec
                                        [edit]
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #528
                                        @deMarvin
                                        Habe jetzt mal Zeit gefunden und auf meinem Testsystem Mysql installiert ...
                                        Sowohl Backup als auch den Restore konnte ich mit Backitup 1.5.8 ohne Probleme durchführen.
                                        Irgendwas scheint an deinem System bzw. rechten nicht zu passen.
                                        Bisher habe ich auch keine Meldungen zu dem Thema bekommen, was darauf deutet, dass es auch keine Probleme gibt. Schau mal bitte nach deinen Rechten, gerade auch auf deinem alten System ....
                                        Denn so wie es ausschaut, hat dein mysql Backupfile nicht die benötigten Rechte
                                        • simatecS simatec
                                          @deMarvin
                                          deMarvin
                                          #529
                                          @simatec
                                          Ja ich werde mal wenn ich Zeit habe einen manuellen restore versuchen und guck dann, an welcher Stelle es scheitert und warum. Natürlich gebe ich dann nochmal Rückmeldung.
                                          Trotzdem danke für die Unterstützung bis jetzt 👍
