  4. IOBroker Auto-Install - Kein Zugriff auf Admin-UI
installationjs controller update
49 Beiträge 3 Kommentatoren 5.9k Aufrufe 3 Beobachtet
    @nils50122
    iobroker update
    iobroker upgrade
    nils50122N Offline
    nils50122N Offline
    nils50122
    @Thomas-Braun said in IOBroker Auto-Install - Kein Zugriff auf Admin-UI:
    iobroker upgrade
    nils@ubuntu-server:/opt/iobroker$ iobroker update
    Used repository: default
    hash changed or no sources cached => force download of new sources
    Cannot download json from http://download.iobroker.net/sources-dist.json. Error: Error: ESOCKETTIMEDOUT
    update done
    nils@ubuntu-server:/opt/iobroker$ iobroker upgrade
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    TypeError: Cannot read property 'indexOf' of undefined
        at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:155:21)
        at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:41:14)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:647:37
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2205:45
        at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:83661
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        at processTicksAndRejections (internal/process/task_queues.js:97:5)
    • nils50122N nils50122
      iobroker upgrade
      update done
              throw e;
      @nils50122
      Der Server kommt nicht raus:
      nils50122N 1 Antwort Letzte Antwort
        @nils50122
        nils50122N Offline
        nils50122N Offline
        nils50122
        @Thomas-Braun
        Welchen Grund kann es dafür geben?
        Ohne Internetzugriff wären ja die ganzen Paketinstallationen nicht gelaufen.
        nils@ubuntu-server:/opt/iobroker$ ping 8.8.8.8
        PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
        64 bytes from 8.8.8.8: icmp_seq=1 ttl=55 time=14.2 ms
        64 bytes from 8.8.8.8: icmp_seq=2 ttl=55 time=13.3 ms
        nils@ubuntu-server:/opt/iobroker$ nslookup
        > google.de
        Server:         127.0.0.53
        Address:        127.0.0.53#53
        Non-authoritative answer:
        Address: 172.217.21.227
        Address: 2a00:1450:4001:81c::2003
          @Thomas-Braun
          > google.de
          Server:         127.0.0.53
          @nils50122
          Füg mal
          http://iobroker.live/repo/sources-dist.json
          als weiteren Verwahrungsort hinzu. Geht über den 'Schraubenschlüssel' / zweiter Reiter dann.
            @nils50122
            Füg mal
            nils50122N Offline
            nils50122N Offline
            nils50122
            @Thomas-Braun
            Erledigt.
            Allerdings holt sich der Iobroker nur den default.
            update done
              @Thomas-Braun
              Erledigt.
              update done
              @nils50122
              Hast du auch den Verwahlungsort umgestellt?
              Schaut so aus bei mir:
              nils50122N 2 Antworten Letzte Antwort
                @nils50122
                nils50122N Offline
                nils50122N Offline
                nils50122
                @Thomas-Braun
                Danke, nun bekomme ich auch die Aktualisierung direkt in der UI angezeigt.
                  @nils50122
                  nils50122N Offline
                  nils50122N Offline
                  nils50122
                  schrieb am zuletzt editiert von nils50122
                  @Thomas-Braun
                  nach einem Reboot des Servers kommt der IOBroker UI nicht hoch.
                  Unter netstat sehe ich das wieder der Port 9001 in Nutzung ist.
                  Ein Prozess killen hilft hier auch nicht.
                  Wie mache ich ausfindig wofür Node benötigt wird oder wie ändere ich den Port?
                  Das hier habe ich im Log gefunden.
                  ^[[32minfo^[[39m: host.ubuntu-server  Error inMem-objects listening on port 9001
                  Doppelinstallation kann ich ausschließen:
                  nils@ubuntu-server:/opt/iobroker/log$ sudo find / -type d -name "admin"
                  /opt/iobroker/node_modules/iobroker.samsung/admin
                  /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin
                  /opt/iobroker/node_modules/iobroker.vis-justgage/admin
                  /opt/iobroker/node_modules/iobroker.cloud/admin
                  /opt/iobroker/node_modules/iobroker.tankerkoenig/admin
                  /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin
                  /opt/iobroker/node_modules/iobroker.info/admin
                  /opt/iobroker/node_modules/iobroker.backitup/admin
                  /opt/iobroker/node_modules/iobroker.fritzdect/admin
                  /opt/iobroker/node_modules/iobroker.vis-history/admin
                  /opt/iobroker/node_modules/iobroker.alexa2/admin
                  /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin
                  /opt/iobroker/node_modules/iobroker.vis-metro/admin
                  /opt/iobroker/node_modules/iobroker.hm-rpc/admin
                  /opt/iobroker/node_modules/iobroker.influxdb/admin
                  /opt/iobroker/node_modules/iobroker.simple-api/admin
                  /opt/iobroker/node_modules/iobroker.pollenflug/admin
                  /opt/iobroker/node_modules/iobroker.trashschedule/admin
                  /opt/iobroker/node_modules/iobroker.daswetter/admin
                  /opt/iobroker/node_modules/iobroker.hm-rega/admin
                  /opt/iobroker/node_modules/googleapis/build/src/apis/admin
                  /opt/iobroker/node_modules/iobroker.find-my-iphone/admin
                  /opt/iobroker/node_modules/iobroker.homeconnect/admin
                  /opt/iobroker/node_modules/iobroker.vis-players/admin
                  /opt/iobroker/node_modules/iobroker.dwd/admin
                  /opt/iobroker/node_modules/iobroker.robonect/admin
                  /opt/iobroker/node_modules/iobroker.discovery/admin
                  /opt/iobroker/node_modules/iobroker.flot/admin
                  /opt/iobroker/node_modules/iobroker.mobile/admin
                  /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin
                  /opt/iobroker/node_modules/iobroker.openhab/admin
                  /opt/iobroker/node_modules/iobroker.nina/admin
                  /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin
                  /opt/iobroker/node_modules/iobroker.hue-extended/admin
                  /opt/iobroker/node_modules/iobroker.fullybrowser/admin
                  /opt/iobroker/node_modules/iobroker.tr-064/admin
                  /opt/iobroker/node_modules/iobroker.icons-mfd-png/admin
                  /opt/iobroker/node_modules/iobroker.vis-bars/admin
                  /opt/iobroker/node_modules/iobroker.iot/admin
                  /opt/iobroker/node_modules/iobroker.admin/admin
                  /opt/iobroker/node_modules/iobroker.bring/admin
                  /opt/iobroker/node_modules/iobroker.openweathermap/admin
                  /opt/iobroker/node_modules/iobroker.ical/admin
                  /opt/iobroker/node_modules/iobroker.bmw/admin
                  /opt/iobroker/node_modules/iobroker.hue/admin
                  /opt/iobroker/node_modules/iobroker.vis/admin
                  /opt/iobroker/node_modules/iobroker.socketio/admin
                  /opt/iobroker/node_modules/iobroker.javascript/admin
                  /opt/iobroker/node_modules/iobroker.ping/admin
                  /opt/iobroker/node_modules/iobroker.web/admin
                  /opt/iobroker/node_modules/iobroker.web/www/admin
                  /opt/iobroker/node_modules/iobroker.nuki/admin
                  /opt/iobroker/iobroker-data/files/web/admin
                  /usr/share/grafana/public/app/features/admin
                  Output von:
                  node node_modules/iobroker.js-controller/controller.js --logs
                  2020-06-08 11:56:36.819  - info: host.ubuntu-server iobroker.js-controller version 3.1.5 js-controller starting
                  2020-06-08 11:56:36.832  - info: host.ubuntu-server Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                  2020-06-08 11:56:36.833  - info: host.ubuntu-server hostname: ubuntu-server, node: v12.18.0
                  2020-06-08 11:56:36.837  - info: host.ubuntu-server ip addresses: 192.168.178.150 fe80::11:32ff:fe27:e82b
                  2020-06-08 11:56:38.365  - info: host.ubuntu-server  Error inMem-objects listening on port 9001
                  2020-06-08 11:56:38.538  - info: host.ubuntu-server  Error inMem-states listening on port 9000
                  2020-06-08 11:56:39.066  - info: host.ubuntu-server connected to Objects and States
                  2020-06-08 11:56:39.731  - info: host.ubuntu-server 55 instances found
                    @Thomas-Braun
                    Output von:
                    @nils50122 sagte in IOBroker Auto-Install - Kein Zugriff auf Admin-UI:
                    nodejs wird als Laufzeitumgebung für den iobroker benötigt.
                    Mit den Ausgaben von oben kann ich nix anfangen. Die Ausgaben gehören zu welchen Eingaben?
                      nils50122N Offline
                      nils50122N Offline
                      nils50122
                      @Thomas-Braun
                      Erstes Output war im Current-Logfile vom IOBroker zu finden.
                      Zweiter Output war das Ergebnis von:
                      Dritter Output war das Ergebnis von:
                        @Thomas-Braun
                        @nils50122
                        Ich verstehe nicht was du mit den beiden Dingen zeigen willst.
                        Zeit mal lieber was dabei herum kommt:
                        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          @nils50122
                          nils50122N Offline
                          nils50122N Offline
                          nils50122
                          @Thomas-Braun
                          Gerne.
                          nils@ubuntu-server:/opt/iobroker$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          /usr/bin/nodejs
                          v12.18.0
                          /usr/bin/node
                          v12.18.0
                          /usr/bin/npm
                          6.14.4
                          nodejs:
                            Installiert:           12.18.0-1nodesource1
                            Installationskandidat: 12.18.0-1nodesource1
                            Versionstabelle:
                           *** 12.18.0-1nodesource1 500
                                  500 https://deb.nodesource.com/node_12.x bionic/main amd64 Packages
                               8.10.0~dfsg-2ubuntu0.4 500
                                  500 http://de.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                               8.10.0~dfsg-2ubuntu0.2 500
                                  500 http://de.archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                               8.10.0~dfsg-2 500
                                  500 http://de.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                            @Thomas-Braun
                            Gerne.
                            /usr/bin/nodejs
                            v12.18.0
                            /usr/bin/node
                            v12.18.0
                            /usr/bin/npm
                            6.14.4
                            nodejs:
                              Versionstabelle:
                                 8.10.0~dfsg-2 500
                            @nils50122
                            Starte den Server mal durch.
                              @nils50122
                              nils50122N Offline
                              nils50122N Offline
                              nils50122
                              @Thomas-Braun
                              Das gibt es doch jetzt nicht...
                              ... läuft wieder.
                              Ich habe den Server garantiert 3-4x neugestartet bevor ich einen neuen Beitrag geschrieben habe.
                                @Thomas-Braun
                                ... läuft wieder.
                                nils50122N Offline
                                nils50122N Offline
                                nils50122
                                @Thomas-Braun
                                Ich glaube ich hab den Fehler, der Openhab Log Viewer benutzt den Port 9001.
                                Jetzt geht dieser nicht mehr.
                                Ich denke hier war bisher wer zuerst kommt malt zuerst angesagt.
                                Wie ändere ich den Port im IOBroker weg von 9001?
                                  @Thomas-Braun
                                  @nils50122
                                  iobroker setup custom
                                    @nils50122
                                    nils50122N Offline
                                    nils50122N Offline
                                    nils50122
                                    @Thomas-Braun
                                    Besten Dank!
