  4. JavaScript
  5. [Skript] Absolute Feuchte berechnen
741 Beiträge 97 Kommentatoren 366.9k Aufrufe 82 Beobachtet
  • HomoranH
    #81
    Gerne:
    ! // ----------------------------------------------------------------------------- // Räume mit Sensoren // ----------------------------------------------------------------------------- var raeume = { // Keine Leerzeichen (Name wird als Datenpunktname verwendet!) // Sensoren Aussen "Aussen" : { "Sensor_TEMP" : "hm-rpc.1.JEQ0140901.1.TEMPERATURE" /*Aussenthermometer:1.TEMPERATURE*/, "Sensor_HUM" : "hm-rpc.1.JEQ0140901.1.HUMIDITY" /*Aussenthermometer:1.HUMIDITY*/, "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0 }, // Sensoren Innen "Werkstatt" : { "Sensor_TEMP" : "hm.rpc.1.JEQ0046663.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.JEQ0046663.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" }, "Bad" : { "Sensor_TEMP" : "hm-rpc.1.JEQ0064523.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.JEQ0064523.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" }, "Dachstudio" : { "Sensor_TEMP" : "hm-rpc.1.JEQ0267518.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.JEQ0267518.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" }, "Schlafzimmer" : { "Sensor_TEMP" : "hm-rpc.1.LEQ0080851.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.LEQ0080851.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" }, "Esszimmer" : { "Sensor_TEMP" : "hm-rpc.1.LEQ0081020.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.LEQ0081020.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" }, "Bureau" : { "Sensor_TEMP" : "hm-rpc.1.LEQ0440620.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.LEQ0440620.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" }, "Sauna" : { "Sensor_TEMP" : "hm-rpc.1.MEQ0180889.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.MEQ0180889.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" }, "Gast" : { "Sensor_TEMP" : "hm-rpc.1.MEQ0479049.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.MEQ0479049.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" }, "Bureau2" : { "Sensor_TEMP" : "hm-rpc.1.LEQ0440620.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.LEQ0440620.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" }, "Bureau3" : { "Sensor_TEMP" : "hm-rpc.1.LEQ0440620.1.TEMPERATURE", "Sensor_HUM" : "hm-rpc.1.LEQ0440620.1.HUMIDITY", "Sensor_TEMP_OFFSET" : 0.0, "Sensor_HUM_OFFSET" : 0, "TEMP_Zielwert" : 21, "Aussensensor" : "Aussen" } }; !
    • eric2905E
      eric2905E
      eric2905
      #82
      Sieht erst mal ok aus.
      Kurze Frage : "hm-rpc.1" ist korrekt?
      Was sagt denn das Log?
      Gruß,
      Eric
      • HomoranH
        #83
        Ja! und Nix!
        @eric2905:
        "hm-rpc.1" ist korrekt? `
        Ja, die Werte sind ja korrekt eingelesen.
        @eric2905:
        Was sagt denn das Log? `
        Nix
        • eric2905E
          eric2905E
          eric2905
          #84
          Seltsam.
          Versuche es bitte mal nur mit dem Aussenthermometer und einem Raum.
          Zumindest dieRäume müssen als Datenpunkte usw. angelegt werden.
          Wie sieht der Datenbaum aus?
          Gruß,
          Eric
          • HomoranH
            #85
            Achtung Missverständnis!
            ich glaube wir reden aneinander vorbei.
            @eric2905:
            Zumindest dieRäume müssen als Datenpunkte usw. angelegt werden. `
            sind si ja auch!
            @eric2905:
            Wie sieht der Datenbaum aus? `
            Der ist IMHO komplett in Ordnung.
            Nur die Datenpunkte json und Aktualisiereung sind leer.
            • eric2905E
              eric2905E
              eric2905
              #86
              Lösch mal bitte den Datenbaum ab "Raumklima" und dann starte das Script mal neu (bitte 2-3 mal das Script neu starten).
              Dann bitte einen Screenshot des Datenbaums mit einem aufgeklappten Raum-Ordner aber sichtbaren Aktualisierungs- und JSON-Datenpunkt.
              Gruß,
              Eric
              [Nachtrag]
              Das NPM-Modul "dewpoint" hast Du aber drin?
              • HomoranH
                #87
                Bitte, wie gewünscht:
                Habe sogar die javascript Instanz neu gestartet.
                Dewpoint hatte ich beim ersten Schuss vergessen - wer liest schon die ersten Zeilen im Skript :lol:
                Ist jetzt aber schon lange drin.
                Nicht dass wir uns Missverstehen: Bis auf json und dessen Aktualisierung scheint alles drin zu sein, der alte Screenshot war nur gefiltert.
                rainer
                • HomoranH
                  #88
                  Habe jetzt doch noch eine Error, weiß aber nicht, ob der mit dir zu tun hat:
                  hm-rega-1	05 21:03:33.811	error	runScriptFile Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.hm-rega/lib/../regascripts/alarms.fn'
                  EDIT:
                  Das Skript hat auf jeden Fall immer wieder meinen javascript Adapter ins aus gekickt.
                  Der Adapter brauchte nachher immer >70% CPU un dann war er weg. Adapter neu starten uund das gleiche Spiel von vorne.
                  Habe jetzt erst festgestellt, dass ALLE berechneten Werte fehlen.
                  Nur die nativen Werte sind drin:
                  Ich finde aber auch den Fehler nicht.
                  • eric2905E
                    eric2905E
                    eric2905
                    #89
                    Moin Rainer,
                    @Homoran:
                    Der Adapter brauchte nachher immer >70% CPU un dann war er weg. Adapter neu starten uund das gleiche Spiel von vorne. `
                    das verstehe ich nicht.
                    Bei mir (Cubietruck) läuft der Prozess io.javascript.0 im Durchschnitt mit 3 - 8 % CPU-Last (laut TOP).
                    Wenn ich das Raumklima-Script manuell anstoße, geht die CPU-Last für einen ganz kurzen Moment auf max. 35% hoch - aber nur für ein Messintervall, danach ist er sofort wieder unten.
                    {edit}
                    Ich habe den Code nochmals etwas angepasst:
                    • Wartezeit nach Anlegend er Datenpunkt von 500ms auf 5000ms erhöht (500ms war zu kurz und hat Fehler erzeugt)
                    • Bool "logging" eingeabut. Wenn auf true gesetzt, werden im Log einige Infos erzeugt
                    Hier der neue Code (Demo-Raumdaten !!!)
                    // Berechnet Taupunkt, absolute Luftfeuchtigkeit, Enthalpie, Lüftungsempfehlung,
                    //gemessene Temperatur & Luftfeuctigkeit inkl. Offset zwecks Kalibrierung
                    // benötigt in der Javascript das Modul "dewpoint"
                    // (in der Javascript-Instanz Einstellungen unter "Zusätzliche NPM-Module")
                    // von paul53 übernommen und angepasst
                    // http://forum.iobroker.net/viewtopic.php?f=20&t=2437&hilit=Lüftung*#p21476
                    // und Solear: http://forum.iobroker.net/viewtopic.php?f=21&t=2645&p=23381#p23282
                    // 05.06.2015 Anpassung ericc2905
                    // Boolean "anyLueften", Datenpunkt "Lueften", Datenpunkt "Aktualisierung" und JSON-Ausgabe eingebaut
                    // 06.06.2015 Anpassung ericc2905
                    // Logging (über Bool "logging" eingebaut)
                    ! var nn = 273; // eigene Höhe nn (normalnull), z.B. über http://de.mygeoposition.com zu ermitteln
                    var pfad = "Raumklima" +"."; // Pfad unter dem die Datenpunkte in der Javascript-Instanz angelegt werden
                    var controlPfad = "CONTROL" +"."; // Pfad innerhalb des Raums
                    var skriptConf = true; // true: Raumwerte werden über das Skript geändert / false: Raumwerte werden über Objekte (oder VIS) geändert
                    var defaultTemp = 21; // Default TEMP_Zielwert, wenn im Raum nicht angegeben
                    ! // eric2905 Zusätzliche Variablen definieren
                    var anyLueften = false; // false: Nirgendwo lüften notwendig / true: Lüften notwendig
                    var strJSONfinal = ""; // Fertiges JSON (zum Schreiben in Datenpunkt)
                    var strJSONtemp = ""; // Bastel-JSON (wird suksessive gefüllt)
                    var strDatum = ""; // Datums der Aktualisierung
                    var logging = false; // Sollen Log-Infos ausgegeben werden? [ja/nein]
                    // eric2905 Ende -------------------------------------------------------
                    // Sensoren Aussen
                    "Aussen" : {
                    "Sensor_TEMP" : "hm-rpc.0.IEQ1234560.1.TEMPERATURE",
                    "Sensor_HUM" : "hm-rpc.0.IEQ1234560.1.HUMIDITY",
                    // Sensoren Innen
                    "Raum1" : {
                    "Sensor_TEMP" : "hm-rpc.0.IEQ1234561.1.TEMPERATURE",
                    "Sensor_HUM" : "hm-rpc.0.IEQ1234561.1.HUMIDITY",
                    "Raum2" : {
                    "Sensor_TEMP" : "hm-rpc.0.IEQ1234562.1.TEMPERATURE",
                    "Sensor_HUM" : "hm-rpc.0.IEQ1234562.1.HUMIDITY",
                    "Raum3" : {
                    "Sensor_TEMP" : "hm-rpc.0.IEQ1234563.1.TEMPERATURE",
                    "Sensor_HUM" : "hm-rpc.0.IEQ1234563.1.HUMIDITY",
                    // Skriptbereich. Ab hier muss nichts mehr eingestellt / verändert werden.
                    var raumDatenpunkte = {
                    "x" : {
                    "DpName" : "Feuchtegehalt_Absolut",
                    "init": 0,
                    "dp": {
                    "name": 'absoluter Feuchtegehalt',
                    "desc": 'absoluter Feuchtegehalt, errechnet',
                    "type": 'number',
                    "role": 'value',
                    "unit": 'g/kg'
                    "rh" : {
                    "DpName" : "relative_Luftfeuchtigkeit",
                    "init": 0,
                    "dp": {
                    "name": 'gemessene relative Luftfeuchtigkeit (inkl. Offset)',
                    "desc": 'relative Luftfeuchtigkeit, vom Sensor + Offset zum Ausgleich von Messungenauigkeiten des Geräts',
                    "type": 'number',
                    "role": 'value',
                    "unit": '%'
                    "dp" : {
                    "DpName" : "Taupunkt",
                    "init": 0,
                    "dp": {
                    "name": 'Taupunkt',
                    "desc": 'Taupunkt. Temperatur von Wänden, Fenstern, usw. ab der sich die Feuchtigkeit niederschlägt.',
                    "type": 'number',
                    "role": 'value',
                    "unit": '°C'
                    "t" : {
                    "DpName" : "Temperatur",
                    "init": 0,
                    "dp": {
                    "name": 'gemessene Temperatur (inkl. Offset)',
                    "desc": 'gemessene Temperatur vom Sensor zzgl. eines Offsets um Geräteungenauigkeiten auszugleichen',
                    "type": 'number',
                    "role": 'value',
                    "unit": '°C'
                    "h" : {
                    "DpName" : "Enthalpie",
                    "init": 0,
                    "dp": {
                    "name": 'Enthalpie',
                    "desc": 'Enthalpie',
                    "type": 'number',
                    "role": 'value',
                    "unit": 'kJ/kg'
                    "lüften" : {
                    "DpName" : "Lüftungsempfehlung",
                    //"init": false,
                    "dp": {
                    "name": 'Lüftungsempfehlung',
                    "desc": 'Lüftungsempfehlung',
                    "type" : 'boolean',
                    "role": 'value'
                    ! var raumControl = {
                    "Sensor_TEMP_OFFSET" : {
                    "DpName" : "Sensor_TEMP_OFFSET",
                    "init": 0,
                    "dp": {
                    "name": 'Offset Temperatur zum Sensormesswert (Ausgleich von Ungenauigkeiten)',
                    "desc": 'Offset Temperatur zum Sensormesswert (Ausgleich von Ungenauigkeiten)',
                    "type": 'number',
                    "role": 'control.value',
                    "unit": '°C'
                    "Sensor_HUM_OFFSET" : {
                    "DpName" : "Sensor_HUM_OFFSET",
                    "init": 0,
                    "dp": {
                    "name": 'Offset Luftfeuchtigkeit zum Sensormesswert (Ausgleich von Ungenauigkeiten)',
                    "desc": 'Offset Luftfeuchtigkeit zum Sensormesswert (Ausgleich von Ungenauigkeiten)',
                    "type": 'number',
                    "unit": '%'
                    "TEMP_Zielwert" : {
                    "DpName" : "TEMP_Zielwert",
                    "init": 0,
                    "dp": {
                    "name": 'Temperatursteuerwert zum lüften',
                    "desc": 'Temperatursteuerwert zum lüften',
                    "type": 'number',
                    "unit": '°C'
                    "Aussensensor" : {
                    "DpName" : "Aussensensor",
                    "init": "",
                    "dp": {
                    "name": 'Aussensensor, der zum Vergleich genommen wird',
                    "desc": 'Aussensensor, der zum Vergleich genommen wird',
                    "type": 'string',
                    ! var DP = require('dewpoint'); // Das Modul dewpoint einlesen
                    var xdp = new DP(nn);
                    ! function createDp() {
                    var name;
                    var init;
                    var forceCreation;
                    var common;
                    if (logging) log("Start Erzeugung Datenpunkte");
                    //eric2905 Datenpunkt "Lüften" erzeugen
                    createState(pfad + 'Lüften', "", {
                    name: 'Muss irgendwo gelüftet werden',
                    desc: 'Muss irgendwo gelüftet werden',
                    type: 'boolean',
                    unit: '',
                    role: 'value'
                    if (logging) log("Datenpunkt Lüften erzeugt");
                    ! //eric2905 Datenpunkt "JSON" erzeugen
                    createState(pfad + 'JSON', "", {
                    name: 'JSON-Ausgabe aller Werte',
                    desc: 'JSON-Ausgabe aller Werte',
                    type: 'string',
                    unit: '',
                    role: 'value'
                    if (logging === true) log("Datenpunkt JSON erzeugt")
                    ! //eric2905 Datenpunkt "Aktualsierung" erzeugen
                    createState(pfad + 'Aktualsierung', "", {
                    name: 'Aktualisierungszeitpunkt der JSON-Ausgabe',
                    desc: 'Aktualisierungszeitpunkt der JSON-Ausgabe',
                    type: 'string',
                    unit: '',
                    role: 'value'
                    if (logging) log("Datenpunkt Aktualisierung erzeugt");
                    for (var raum in raeume) {
                    for (var datenpunktID in raumDatenpunkte) {
                    name = pfad + raum + "." + raumDatenpunkte[datenpunktID].DpName;
                    init = raumDatenpunkte[datenpunktID].init;
                    forceCreation = false; // Init der Datenpunkte wird nur beim ersten Star angelegt. Danach bleiben die Wert auch nach Skritpstart enthalten.
                    common = raumDatenpunkte[datenpunktID].dp;
                    createState(name, init , forceCreation, common);
                    log("neuer Datenpunkt: " + name,"debug");
                    for (var control in raumControl) {
                    name = pfad + raum + "." + controlPfad + raumControl[control].DpName;
                    //init = raumControl[control].init;
                    forceCreation = skriptConf;
                    common = raumControl[control].dp;
                    if (typeof raeume[raum][raumControl[control].DpName] !=="undefined") {
                    init = raeume[raum][raumControl[control].DpName];
                    ! function runden(wert,stellen) {
                    var gerundet = Math.round(wert10stellen)/(10*stellen);
                    return gerundet;
                    ! //eric2905 JSON erzeuen
                    function createJSON() {
                    var temppfad = "";
                    var tempVal = "";
                    strJSONfinal = "[";
                    strJSONtemp = "";
                    if (logging) log("Erzeugung JSON gestartet");
                    if (raum != "Aussen") {
                    strJSONtemp = strJSONtemp + "{";
                    strJSONtemp = strJSONtemp + ""Raum":"" + raum + "",";
                    temppfad = pfad + raum + "." + raumDatenpunkte[datenpunktID].DpName;
                    tempVal = getState(temppfad).val;
                    if(raumDatenpunkte[datenpunktID].DpName != "Lüftungsempfehlung") {
                    tempVal = parseFloat(tempVal);
                    tempVal = tempVal.toFixed(2);
                    strJSONtemp = strJSONtemp + """ + raumDatenpunkte[datenpunktID].DpName + "":"" + tempVal + "",";
                    strJSONtemp = strJSONtemp.substr(0, strJSONtemp.length - 1);
                    strJSONtemp = strJSONtemp + "},";
                    strJSONfinal = strJSONfinal + strJSONtemp + "]";
                    if (logging) log("strJSONfinal : " + strJSONfinal);
                    ! function calc(raum) { // Über Modul Dewpoint absolute Feuchte berechnen
                    var t = getState(raeume[raum].Sensor_TEMP).val; // Temperatur auslesen
                    var rh = getState(raeume[raum].Sensor_HUM).val; // Feuchtigkeit relativ auslesen
                    var y = xdp.Calc(t, rh);
                    var toffset = 0.0; // Offset in °C
                    var rhoffset = 0; // Offset in %
                    if (logging) log("Function CALC gestartet");
                    if(typeof raeume[raum].Sensor_TEMP_OFFSET !=="undefined") {
                    var idtoffset = pfad + raum + "." + controlPfad + "Sensor_TEMP_OFFSET";
                    toffset = getState(idtoffset).val; // Offset aus den Objekten/Datenpunkt auslesen
                    if(typeof raeume[raum].Sensor_HUM_OFFSET !=="undefined") {
                    var idrhoffset = pfad + raum + "." + controlPfad + "Sensor_HUM_OFFSET";
                    rhoffset = getState(idrhoffset).val; // Offset aus den Objekten/Datenpunkt auslesen
                    ! t = t + toffset;
                    rh = rh + rhoffset;
                    ! var x = y.x; // Zu errechnende Variable für Feuchtegehalt in g/kg
                    var dp = y.dp; // Zu errechnende Variable für Taupunkt in °C
                    ! var h = 1.00545 * t + (2.500827 + 0.00185894 * t) * x;
                    ! var idx = pfad + raum + "." + raumDatenpunkte["x"].DpName;
                    var iddp = pfad + raum + "." + raumDatenpunkte["dp"].DpName;
                    var idt = pfad + raum + "." + raumDatenpunkte["t"].DpName;
                    var idrh = pfad + raum + "." + raumDatenpunkte["rh"].DpName;
                    var ih = pfad + raum + "." + raumDatenpunkte["h"].DpName;
                    setState(idx    , runden(x,2));     // errechnete absolute Feuchte in Variable schreiben
                    setState(iddp   , runden(dp,1));    // errechneter Taupunkt in Variable schreiben
                    setState(idt    , t);               // Sensor Temperatur        inkl. Offset
                    setState(idrh   , rh);              // Sensor Relative Feuchte  inkl. Offset
                    setState(ih     , runden(h,2));     // Enthalpie
                    ! // Lüften
                    if(typeof raeume[raum].Aussensensor !=="undefined") {
                    var aussen = raeume[raum].Aussensensor;
                    var idta = pfad + aussen + "." + raumDatenpunkte["t"].DpName;
                    var idxa = pfad + aussen + "." + raumDatenpunkte["rh"].DpName;
                    } else {
                    return;
                    ! var ti = t; // Raumtemperatur in °C
                    var xi = rh; // Raumfeuchtegehalt in g/kg
                    var ta = getState(idta).val; // Aussentemperatur in °C
                    var xa = getState(idxa).val; // Aussenfeuchtegehalt in g/kg
                    if (xa == 0) return;
                    var mi = defaultTemp;           // Temperaturmittelwert auf Default
                    ! if(typeof raeume[raum].TEMP_Zielwert !=="undefined") {
                    mi = raeume[raum].TEMP_Zielwert;
                    var mih = mi + 0.25; // Temperaturmittelwert hoch
                    var mit = mi - 0.25; // Temperaturmittelwert tief
                    ! var idLueften = pfad + raum + "." + raumDatenpunkte["lüften"].DpName;
                    // Lüftungsempfehlung steuern mit 0,3 g/kg und 0,5 K Hysterese
                    //eric2905 Originalblock
                    //if (xa <= (xi - 0.4) && ta <= (ti - 0.6) && ti >= mih) setState(idLueften, true);
                    //else if (xa >= (xi - 0.1) || ta >= (ti - 0.1) || ti <= mit) setState(idLueften, false);
                    if      (xa <= (xi - 0.4) && ta <= (ti - 0.6) && ti >= mih) {
                        anyLueften = true;
                    if (logging) log("Raumwete : " + raum+", ti:"+ti+", ta: "+ta+", xi:"+xi+", xa: "+xa+", mih:"+mih+", mit:"+mit,"debug");
                    ! function calcAll () {
                    calc(raum);
                    ! function Datum() {
                    var jetzt = new Date();
                    var jahr = String(jetzt.getFullYear());
                    var monat = jetzt.getMonth() + 1;
                    if(monat<10) {
                    monat = "0" + String(jetzt.getMonth() + 1);
                    } else {
                    monat = String(jetzt.getMonth() + 1);
                    var tag = jetzt.getDate();
                    if(tag<10) {
                    tag = "0" + String(jetzt.getDate());
                    } else {
                    tag = String(jetzt.getDate());
                    var stunden = jetzt.getHours();
                    if(stunden<10) {
                    stunden = "0" + String(jetzt.getHours());
                    } else {
                    stunden = String(jetzt.getHours());
                    var minuten = jetzt.getMinutes();
                    if(minuten<10) {
                    minuten = "0" + String(jetzt.getMinutes());
                    } else {
                    minuten = String(jetzt.getMinutes());
                    var sekunden = jetzt.getSeconds();
                    if(sekunden<10) {
                    sekunden = "0" + String(jetzt.getSeconds());
                    } else {
                    sekunden = String(jetzt.getSeconds());
                    strDatum = tag + "."+ monat + "." + jahr + " - " + stunden + ":" + minuten + ":" + sekunden;
                    ! // alle zwei Minuten neu berechnen
                    schedule("*/2 * * * *", function () {
                    calcAll();
                    // eric2905 Aufruf eingebaut und Datenpunkt befüllen
                    createJSON();
                    Datum();
                    setState(pfad + 'Lüften', anyLueften);
                    setState(pfad + 'JSON', strJSONfinal);
                    setState(pfad + 'Aktualsierung', strDatum);
                    ! function main() {
                    calcAll();
                    createJSON();
                    Datum();
                    ! if (logging) {
                    log("----------------------------------------------------------");
                    log("Script-Start");
                    createDp(); // Datenpunkte anlegen
                    if (logging) log("Datenpunkte angelegt");
                    setTimeout(main, 5000); // Zum Skriptstart ausführen
                    {/edit}
                    Hat sonst noch jemand ähnliche Phänomene?
                    Gruß,
                    Eric
                    • HomoranH
                      #90
                      Hallo Eric,
                      hilft nicht, der Fehler schein woanders:
                      TypeError: Cannot read property 'val' of null at calc (script.js.Klima.Feuchteberechnung:458:57) at calcAll (script.js.Klima.Feuchteberechnung:538:9) at Object.main (script.js.Klima.Feuchteberechnung:598:5) at null. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1800:44) at ontimeout [as _onTimeout] (timers.js:209:34) at Timer.listOnTimeout (timers.js:92:15)
                      ` > var tag = jetzt.getDate();
                      if(tag<10) {
                      } else { tag = "0" + String(jetzt.getDate()); `
                      Sind das nicht Zeilennummern?
                      Diese Zeile gibt es nicht.
                      EDIT:
                      Habe alle Skripte deaktiviert, javascript auf debug gestellt, und Instanz neu gestartet. Jetzt gerade eine Fehlermeldung:
                      javascript-0	2016-06-06 08:24:12.430	warn	State "hm.rpc.1.JEQ0046663.1.TEMPERATURE" not found
                      Muss mal sehen, wo der Wurm drin ist.
                      ****EDIT2:
                      Läuft!!!
                      da war ein Punkt, statt eines Bindestrichs!
                      Das muss man erst mal sehen.
                      DANKE nochmal.****
                      Danke erst mal
                      • eric2905E
                        eric2905E
                        eric2905
                        #91
                        @Homoran:
                        Läuft!!! `
                        Das ließt man doch gerne :D
                        Dafür ist jetzt ein Logging mit drin, das man per Bool ein-/ausschalten kann.
                        Ich baue die Funktion "createJSON" noch dahin um, das auch die Aussenwerte mit aufgenommen werden - das sieht dann einfach schöner aus.
                        Noch eine Frage an die ursprünglichen Script-Ersteller:
                        Ist die Einheit für die absolute Feuchte tatsächlich "g/kg" (ist so in der Datenpunkt-Definition angegeben)?
                        Ich lese immer nur von "g/m3".
                        Gruß,
                        Eric
                        • paul53P
                          paul53P
                          #92
                          Der Begriff "absolute Luftfeuchte" wird sowohl für g Wasser pro kg trockene Luft (auch Feuchtegehalt oder Mischungsverhältnis genannt) als auch für g Wasser pro m³ feuchte Luft verwendet, wobei g/m³ häufiger ist. Deshalb bevorzuge ich die Bezeichnung "Feuchtegehalt" für g/kg.
                          Bei der Auslegung von Luftaufbereitungsanlagen wird mit dem https://de.wikipedia.org/wiki/Mollier-h-x-Diagramm gearbeitet und der Feuchtegehalt x verwendet.
                          Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                          • eric2905E
                            eric2905E
                            eric2905
                            #93
                            Hi paul53,
                            danke für die Info.
                            Was hast Du denn eingesetzt / verwendet? Sofern ich verstanden habe, ist das ursprüngliche Berechnungs-Script ja von Dir.
                            Dann passe ich später die Ausgaben so an, das dort eine eindeutige Bezeichnung steht.
                            Danke und Gruß,
                            Eric
                            • S
                              S
                              Solear
                              #94
                              Im Script läuft alles über g/kg.
                              (Achtung: beim vergleich der Werte mit CUxD-Werten, dort muss man von g/m³ auf g/kg umstellen!)
                              iobroker als LXC unter Proxmox
                              • HomoranH
                                #95
                                zur Einheit der absoluten Feuchte:
                                ich persönlich dneke, dass es einfach für die meisten verständlicher ist sich 10g Wasser in einm m³ Luft vorzustellen, als in einem kg Luft ("was bitte ist ein kg Luft?").
                                Daher hatte ich diese Berechnung nach http://hobby-photo.de/download/Luftfeuchte_hobby-photo.xlsfrüher benutzt.
                                Die errechneten Werte sind jedoch unterschiedlich.
                                Ich habe bei mir den Begriff "Wassergehalt" für die abs. Feuchte benutzt, (<size size="50">damit meine Frau auch das Lüften versteht</size>).
                                Hier mal der Vergleich meiner auf der CCU berechneten Werte und mühsamm zusammengeklickten "Tabelle" und der Paul/Eric-Variante:
                                Die Datenpunkte in der JSON-Tabelle scheinen ja nach der Reihenfolge der Zimmer im Skriptkopf sortiert zu sein.
                                Muss ich dort die Reihenfolge ändern, um die Tabelle umzusortieren?
                                rainer
                                • eric2905E
                                  eric2905E
                                  eric2905
                                  #96
                                  @Solear:
                                  Im Script läuft alles über g/kg. `
                                  danke für die Info - dann baue ich die Ausgaben heute Abend so um, das es eindeutig ist
                                  @Solear:
                                  (Achtung: beim vergleich der Werte mit CUxD-Werten, dort muss man von g/m³ auf g/kg umstellen! `
                                  Das nehme ich als Hinweis in den Header mit auf - danke für die Warnung.
                                  @Rainer:
                                  @Homoran:
                                  Muss ich dort die Reihenfolge ändern, um die Tabelle umzusortieren? `
                                  Ja, ich lese sie in der gleichen Reihenfolge ein, wie sie erstellt werden.
                                  Gruß,
                                  Eric
                                  • paul53P
                                    paul53P
                                    #97
                                    @eric2905:
                                    Grundlage für die Berechnungen im NPM-Modul "dewpoint" sind die Magnus-Formel (siehe Anlage) und die barometrische Höhenformel.
                                    theorie_der_feuchte
                                    EDIT: Die Berechnung ist übrigens kein Geheimnis; wenn das NPM-Module "dewpoint" in der Javascript-Instanz geladen wurde, befindet sich die Datei "dewpoint.js" im Ordner "/opt/iobroker/node_modules/iobroker.javascript/node_modules/dewpoint".
                                    • eric2905E
                                      eric2905E
                                      eric2905
                                      #98
                                      dann hier die letzte Version (Script und Widget).
                                      Der Header des Scripts mit wichtigen Hinweisen und der Historie des Scripts
                                      ! ` > // Berechnet Taupunkt, absolute Luftfeuchtigkeit, Enthalpie, Lüftungsempfehlung,
                                      // Achtung: Wichtiger Hinweise
                                      // Beim vergleich der Werte mit CUxD-Werten, dort muss man von g/m³ auf g/kg umstellen!
                                      // Historie
                                      // http://forum.iobroker.net/viewtopic.php ... %2A#p21476
                                      // und Solear: http://forum.iobroker.net/viewtopic.php ... 381#p23282
                                      // Ausgabe der Daten von "Aussen" im JSON mit eingebaut
                                      Hier der aktuelle Code (Demo-Raumdaten !!!) - 06.06.2016 - 19:50
                                      // Historie
                                      // Wartezeit nach dem Anlegen der Datenpunkte von 500ms auf 5000ms erhöht (es gab Probleme, das die DP noch nicht erreichbar waren und das Script hängen blieb)
                                      // Ausgabe der Daten von "Aussen" im JSON mit eingebaut (JSON-Feld "Lüftungsempfehlung" bleibt leer)
                                      // Sensoren Aussen
                                      "Aussen" : {
                                      // Sensoren Innen
                                      "Raum1" : {
                                      "Raum2" : {
                                      "Raum3" : {
                                      "x" : {
                                      "init": 0,
                                      "dp": {
                                      "type": 'number',
                                      "role": 'value',
                                      "unit": 'g/kg'
                                      "rh" : {
                                      "init": 0,
                                      "dp": {
                                      "type": 'number',
                                      "role": 'value',
                                      "unit": '%'
                                      "dp" : {
                                      "init": 0,
                                      "dp": {
                                      "name": 'Taupunkt',
                                      "type": 'number',
                                      "role": 'value',
                                      "unit": '°C'
                                      "t" : {
                                      "init": 0,
                                      "dp": {
                                      "type": 'number',
                                      "role": 'value',
                                      "unit": '°C'
                                      "h" : {
                                      "init": 0,
                                      "dp": {
                                      "type": 'number',
                                      "role": 'value',
                                      "unit": 'kJ/kg'
                                      "lüften" : {
                                      //"init": false,
                                      "dp": {
                                      "type" : 'boolean',
                                      "role": 'value'
                                      "init": 0,
                                      "dp": {
                                      "type": 'number',
                                      "unit": '°C'
                                      "init": 0,
                                      "dp": {
                                      "type": 'number',
                                      "unit": '%'
                                      "TEMP_Zielwert" : {
                                      "init": 0,
                                      "dp": {
                                      "type": 'number',
                                      "unit": '°C'
                                      "Aussensensor" : {
                                      "init": "",
                                      "dp": {
                                      "type": 'string',
                                      var name;
                                      var init;
                                      var forceCreation;
                                      var common;
                                      type: 'boolean',
                                      unit: '',
                                      role: 'value'
                                      type: 'string',
                                      unit: '',
                                      role: 'value'
                                      type: 'string',
                                      unit: '',
                                      role: 'value'
                                      return gerundet;
                                      var temppfad = "";
                                      var tempVal = "";
                                      strJSONfinal = "[";
                                      strJSONtemp = "";
                                          strJSONtemp = strJSONtemp + "\"Raum\":\"" + raum + "\",";
                                              if (tempVal === null) tempVal = "";
                                              if (logging) log("tempVal : " + tempVal);
                                              strJSONtemp = strJSONtemp + "\"" + raumDatenpunkte[datenpunktID].DpName + "\":\"" + tempVal + "\",";
                                      ! t = t + toffset;
                                      rh = rh + rhoffset;
                                      ! // Lüften
                                      } else {
                                      return;
                                          anyLueften = true;
                                      calc(raum);
                                      if(monat<10) {
                                      } else {
                                      if(tag<10) {
                                      } else {
                                      if(stunden<10) {
                                      } else {
                                      if(minuten<10) {
                                      } else {
                                      if(sekunden<10) {
                                      } else {
                                      calcAll();
                                      createJSON();
                                      Datum();
                                      ! function main() {
                                      calcAll();
                                      createJSON();
                                      Datum();
                                      ! if (logging) {
                                      Und dann hier noch das Widget - 06.06.2016 - 19:50
                                      [{"tpl":"tplTableBody","data":{"visibility-cond":"==","visibility-val":1,"static_value":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"colCount":"6","hide_header":false,"colWidth1":"20%","colName1":"Raum","colAttr1":"Raum","colWidth2":"20%","colName2":"Feuchtegehalt (g/kg)","colName3":"Rel. Feuchte (%)","colWidth3":"15","colWidth4":"15%","colWidth5":"15%","colWidth7":"10%","colName7":"Lüften","colAttr6":"Lüftungsempfehlung","colName6":"Lüften","colWidth6":"15%","table_oid":"javascript.0.Raumklima.JSON","colName4":"Taupunkt (ºC)","colName5":"Temperatur (ºC)"},"style":{"left":"45px","top":"85px","width":"921px","height":"540px","z-index":"20","text-align":"center","font-family":"Arial, Helvetica, sans-serif","font-size":"medium"},"widgetSet":"basic"}]
                                      Rückmeldungen sind absolut erbeten !!!
                                      Gruß,
                                      Eric
                                      • ruhr70R
                                        ruhr70R
                                        ruhr70
                                        #99
                                        Schöne Erweiterung von dem Skript :-)
                                        Gesendet von iPad mit Tapatalk
                                        • eric2905E
                                          eric2905E
                                          eric2905
                                          #100
                                          @ruhr70:
                                          Schöne Erweiterung von dem Skript :-) `
                                          Danke :D
                                          Und meine ersten (erfolgreichen?) Gehversuche mit Javascript … und das mir, der immer gesagt hat "Java ist die Programmiersprache der Zukunft,nicht die der Gegenwart" .... :lol:
                                          Gruß,
                                          Eric
                                          84.2k
