  4. Test Adaper Discovergy v0.4.x
energie
294 Beiträge 33 Kommentatoren 69.6k Aufrufe 21 Beobachtet
  • Holger76H Offline
    Holger76H Offline
    Holger76
    schrieb am zuletzt editiert von Holger76
    #233
    mit dem neuesten JS Controller 3.1.2 verbindet sich der Discovergy Adapter nicht mehr bei mir. es kommt folgende Meldung (Ja, login Daten sind korrekt und neu eingegeben, mit der alten Controller Version läufts)
    LOG:
    2020-05-10 00:02:01.030 - info: discovergy.0 (3267) starting. Version 0.5.4 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.16.3, js-controller: 3.1.2
    2020-05-10 00:02:01.044 - info: discovergy.0 (3267) Discovergy Adapter startet, trying to discover meters associated with your account
    2020-05-10 00:02:01.209 - error: discovergy.0 (3267) Connection_Failed at meter indication run, check your credentials !
    2020-05-10 00:02:01.211 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-05-10 00:02:01.211 - error: discovergy.0 (3267) unhandled promise rejection: 401 - "401 Unauthorized: Invalid email or password supplied in the HTTP Authorization header"
    2020-05-10 00:02:01.214 - error: discovergy.0 (3267) StatusCodeError: 401 - "401 Unauthorized: Invalid email or password supplied in the HTTP Authorization header"
    at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15)
    at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33)
    at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
    at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    at Request.emit (events.js:310:20)
    at Request.EventEmitter.emit (domain.js:482:12)
    at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
    at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
    2020-05-10 00:02:01.214 - info: discovergy.0 (3267) cleaned everything up...
    2020-05-10 00:02:01.266 - info: discovergy.0 (3267) terminating
    2020-05-10 00:02:01.267 - info: discovergy.0 (3267) Terminated (NO_ERROR): Without reason
    2020-05-10 00:02:01.789 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-05-10 00:02:01.790 - error: host.ioBroker Caught by controller[1]: StatusCodeError: 401 - "401 Unauthorized: Invalid email or password supplied in the HTTP Authorization header"
    2020-05-10 00:02:01.790 - error: host.ioBroker Caught by controller[1]: at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15)
    2020-05-10 00:02:01.790 - error: host.ioBroker Caught by controller[1]: at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33)
    2020-05-10 00:02:01.790 - error: host.ioBroker Caught by controller[1]: at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
    2020-05-10 00:02:01.791 - error: host.ioBroker Caught by controller[1]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    2020-05-10 00:02:01.791 - error: host.ioBroker Caught by controller[1]: at Request.emit (events.js:310:20)
    2020-05-10 00:02:01.791 - error: host.ioBroker Caught by controller[1]: at Request.EventEmitter.emit (domain.js:482:12)
    2020-05-10 00:02:01.791 - error: host.ioBroker Caught by controller[1]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
    2020-05-10 00:02:01.792 - error: host.ioBroker Caught by controller[1]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
    2020-05-10 00:02:01.792 - info: host.ioBroker instance system.adapter.discovergy.0 terminated with code 0 (NO_ERROR)
    2020-05-10 00:02:01.792 - info: host.ioBroker Restart adapter system.adapter.discovergy.0 because enabled
    Alle Adapter sind latest.
    Debian 10, NodeJS12
    EDIT: hat sich mit der neuesten Version 3.1.3 von heute Nacht erledigt. Alles gut
    NUC12i7 -> Proxmox VM [ioBroker.Pro]+[InfluxDB/Grafana]+[AdGuard]+[ OpenCCU ]+[Conbee3] +[Graylog]+[Octopi]+[OpenClaw]
    NUC6CAYH (16GB) [Proxmox Backup Server]+[OMV]
    • Ivan AndricI Offline
      Ivan Andric
      #234
      Hallo, wenn ich es in diesem Forum richtig verstanden habe, soll es einen Test Account geben, mit dem man seinen Discovergy Adapter vorab testen kann, auch ohne eigenen Zähler. Das würde ich gerne machen, jedoch finde ich bisher keine Zugangsdaten zu diesem Account. Laut Discovergy Forum soll es keinen solchen Account geben. Was ich nur bisher gefunden habe ist die Demo WEB-Seite von Discovergy, aber die bringt mich nicht weiter. Kann mir da jemand von euch weiter helfen?
      Vielen Dank!
      • Palm_ManiacP Offline
        Palm_Maniac
        #235
        Anscheinend gibts Probleme bei Discovergy. Es werden keine Daten mehr geliefert und ich kann die Seite nicht ansurfen. Kann das jemand mal gegenchecken?
        • Palm_ManiacP Palm_Maniac
          #236
          @Palm_Maniac
          lt. meinen Grafana Werten ist das seit 5 Uhr heute morgen so.
          Der Nachtwächter ist bestimmt über das Kabel gestolpert ;)
          L 1 Antwort Letzte Antwort
            @Palm_Maniac
            leuchtturm
            #237
            @Blechsoldat Ja, kann ich auch bestätigen.
            Kommt in letzter Zeit recht häufig vor.
              Palm_Maniac
              #238
              Stimmt, seit 5:11Uhr ist es so. Also kein Systemproblem bei mir. :) Mal schauen wie lange es dauert, bis der Admin dort das merkt.
              • ? Offline
                #239
                Es passiert was. Nun Error 502 Bad Gateway!
                • ? Offline
                  #240
                  Ha ! Der Stecker ist wieder drinn. Alles funktioniert wieder.
                    Palm_Maniac
                    #241
                    Jupp, geht wieder. :)
                    • WebrangerW Offline
                      WebrangerW Offline
                      Webranger
                      schrieb am zuletzt editiert von Webranger
                      #242
                      Gab oder gibt es heute wieder probleme?
                      Seit 12.28 Uhr bekommt die Discovergy Seite keine Daten mehr von mir.
                      Gerade alles überprüft Internet Leitung steht, switch blinkt als wenn daten gesendet werden aber auf der webseite von discovergy kommt nix an.
                      Wurde nur nervös weil ich eine email bekam von discovery das seit 30 minuten keine Daten mehr gesendet werden.
                      Alles merkwürdig ........
                      Ist das nur bei mir so oder bei euch auch?
                      Wenn ich damit nicht alleine bin bräuchte ich wenogstens nicht weiter suchen.
                      Gruss Danyel
                      Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                      • JB_SullivanJ Offline
                        JB_Sullivan
                        #243
                        Nö - bei mir läuft alles - keine Ausfälle den ganzen Tag über. Oftmals hat man solche Ausfälle wenn das Internet mal weg war oder der Router neu gestartet wurde. Einfach mal den Reset Knopf am Zähler drücken - in 99% der Fälle geht es dann wieder.
                        WebrangerW 1 Antwort Letzte Antwort
                        • JB_SullivanJ JB_Sullivan
                          WebrangerW Offline
                          WebrangerW Offline
                          Webranger
                          #244
                          @JB_Sullivan das war es tatsächlich.
                          ich vergesse immer wieder den kleinen knopp wenn alles normal blinkt am Zähler
                          • WebrangerW Webranger
                            JB_Sullivan
                            #245
                            @Webranger
                            Darum habe ich mir einen Switchbot gegönnt, der diese drücken für mich erledigt. Leider ist mein Zählerkasten "etwas" verbaut und das Knöpfchen drücken ist mit einigem Aufwand verbunden.
                            Ich brauche bei Datenunterbrechnung in ioB nur das Skript ausführen, dann passiert das hier .........
                            https://photos.app.goo.gl/Y5tHXHxsLRwCeVXX6
                              JB_Sullivan
                              #246
                              Seit Montag spinnt der Discovergy Adapter und gibt lustig negative und sonstige skurile Werte aus.
                              Ich habe seit Wochen nichts mehr an der VIS im Bereich Discovergy gemacht. Wie gesagt, seit Montag von jetzt auf gleich.
                              Hat noch jemand ähnliches beobachtet?
                                Palm_Maniac
                                #247
                                Hatte ich kurz auch, aber ein Neustart des Adapters hat es wieder gerichtet, zumindest bei mir.
                                  Dennis93
                                  #248
                                  Kann mir jemand sagen was da lost ist?
                                  Palm_ManiacP 1 Antwort Letzte Antwort
                                  • D Dennis93
                                    Palm_Maniac
                                    #249
                                    @Dennis93 Den Adapter hast du schon neu gestartet? Setze auch mal deine Zugangsdaten neu, eventuell hilft das. In jedem Fall liefert Discovergy Daten, hab nachgeschaut.
                                      JB_Sullivan
                                      #250
                                      Drück mal das Reset Knöpfchen an deinem Zähler - ich hatte das wenn keine Verbindung zu den Discovergy Servern besteht.
                                        Dennis93
                                        #251
                                        @JB_Sullivan auf der Homepage ist alles bestens, da bekomme ich alle Daten.
                                          Dennis93
                                          #252
                                          @Palm_Maniac Funktioniert leider auch nicht, Daten sind einmal komplett neu geschrieben.
