  4. Nach Update läuft nichts mehr!
    6.7k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 96.6k Aufrufe 9 Beobachtet
  • WalW Wal
    sudo ist schlecht.
    Lass mal den Fixer laufen.
    cd /opt/iobroker
    iobroker stop
    curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/fix_installation.sh | bash -
    iobroker update
    iobroker upgrade self
    iobroker start
    Ja, Node gleich auf 12 upgraden.
    curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
    sudo apt-get install -y nodejs
    SaschaS
    @Wal Ohne sudo geht meistens nichts..
    Unabhängig davon bring
    pi@raspberrypi:/opt/iobroker $ iobroker stop
    iobroker controller daemon is not running
    pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
    obwohl
    pi@raspberrypi:/opt/iobroker $ ps auxww | grep io
    root        12  0.0  0.0      0     0 ?        S    08:40   0:00 [migration/0]
    root        15  0.0  0.0      0     0 ?        S    08:40   0:00 [migration/1]
    root        20  0.0  0.0      0     0 ?        S    08:40   0:00 [migration/2]
    root        25  0.0  0.0      0     0 ?        S    08:40   0:00 [migration/3]
    root        41  0.0  0.0      0     0 ?        I<   08:40   0:00 [rpciod]
    root        43  0.0  0.0      0     0 ?        I<   08:40   0:00 [xprtiod]
    root        47  0.0  0.0      0     0 ?        I<   08:40   0:00 [nfsiod]
    root        62  0.0  0.0      0     0 ?        I<   08:40   0:00 [DWC Notificatio]
    message+   355  0.0  0.3   6516  3360 ?        Ss   08:40   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
    iobroker   602 24.5 10.0 185492 95612 ?        Ssl  08:40   1:50 iobroker.js-controller
    iobroker   954  6.9  5.9 156136 56464 ?        Sl   08:40   0:30 io.admin.0
    iobroker  1566  0.7  3.9 130252 37384 ?        Sl   08:40   0:03 io.discovery.0
    iobroker  1609  3.8  5.3 132976 51140 ?        Sl   08:40   0:16 io.history.0
    iobroker  1751  8.2 13.0 201260 123956 ?       Sl   08:41   0:33 io.javascript.0
    iobroker  1761  5.2  5.5 140632 52724 ?        Sl   08:41   0:21 io.stiebel-isg.0
    iobroker  1780  1.2  4.2 133312 40212 ?        Sl   08:41   0:04 io.web.0
    iobroker  1787  2.2  5.0 144104 47728 ?        Sl   08:41   0:09 io.cloud.0
    iobroker  1797  1.3  3.9 132292 37772 ?        Sl   08:41   0:05 io.info.0
    iobroker  1804  1.5  4.3 134372 41328 ?        Sl   08:41   0:06 io.deconz.0
    iobroker  1860  1.5  4.1 134328 39300 ?        Sl   08:41   0:06 io.tankerkoenig.0
    iobroker  2015  6.2  6.4 138548 60808 ?        Sl   08:41   0:24 io.ble.0
    pi        6421  0.0  0.0   4772   532 pts/0    S+   08:48   0:00 grep --color=auto io
    sehr wohl rennt.
    Und daher kommt dann auch immer der Befehl @Jan1
    sudo systemctl stop iobroker
    ins Spiel.
    Und bim Fixer stehe ich vor
    pi@raspberrypi:/opt/iobroker $ curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/fix_installation.sh | bash -
    bash: Zeile 1: 404:: Kommando nicht gefunden.
    WalW J 2 Antworten Letzte Antwort
    • J Jan1
      @SaschaS
      Jou und genau da wird Node 10 benötigt, was auch dabei steht. Wenn Du dann mit Node 8 das Update startest, ist danach erst mal Ruhe im Karton, deshalb nun mal schön auf Node 10, oder besser gleich auf 12 da empfohlen.
      Dazu machst auf dem Pi am besten das was dazu in der Doku zum Thema Node steht. Das hat bei mir aufm Pi immer am besten funktioniert.
      Das ganze gleich mit den angegeben System Updates und wenn es dann immer noch nicht läuft, gehts hier weiter ;-)
      SaschaS
      @Jan1 said in Nach Update läuft nichts mehr!:
      @SaschaS
      Die Doku schaue ich mir nach dem Frühstück an.
      • S SaschaS
        obwohl
        sehr wohl rennt.
        ins Spiel.
        WalW Offline
        WalW Offline
        Wal
        @SaschaS sagte in Nach Update läuft nichts mehr!:
        Stimmt, die Adresse des Fixers ist falsch, ich suche mal.
        Walter
        DoorIO-Adapter
        E 1 Antwort Letzte Antwort
        • WalW Offline
          WalW Offline
          Wal
          schrieb am zuletzt editiert von Wal
          curl -sL https://iobroker.net/fix.sh | bash -
          Walter
          DoorIO-Adapter
          • WalW Wal
            Einstein67
            schrieb am zuletzt editiert von Einstein67
            @Wal said in Nach Update läuft nichts mehr!:
            Man braucht diese Adresse nicht mehr
            "iobroker fix"
            reicht aus!
            Aber solange ein JS-Controler 3.1.x unter Node8 läuft, bringt das alles nichts ...
            • S SaschaS
              obwohl
              sehr wohl rennt.
              ins Spiel.
              Jan1
              und wo genau hast diesen Befehl ausgegraben? Das ist alt und wenn Du mit so alten Zeug weiter machen willst, ist es allein Dein Problem.
              Genau so wie die uralte Adresse des Fixer, wo hast die denn her? Du verwendest irgend welche Anleitungen die sehr alt sind und das macht es nur schlimmer.
              Las den Fixer laufen:
              oder mit:
              iobroker fix
              Danach ein System Update:
              sudo apt-get update && sudo apt-get upgrade
              Dann die Node nach der Doku und es sollte wieder laufen.
              WalW 2 Antworten Letzte Antwort
              • J Jan1
                oder mit:
                iobroker fix
                WalW Offline
                WalW Offline
                Wal
                @Jan1 sagte in Nach Update läuft nichts mehr!:
                Wenn er vor deinen Befehlen ein
                macht, wird nodejs geupdatet.
                Walter
                DoorIO-Adapter
                • E Offline
                  Einstein67
                  Ich fürchte dann hat er beide Versionen drauf!
                  Deshalb erst die Alte Version deinstallieren und dann mit dem Befehl die neue drauf ... wie es im Doku-Link von Jan1 steht.
                  • WalW Wal
                    Jan1
                    @Wal
                    Ja wird es nur will ich das erst mal machen, wenn der Rest aktuell ist und nicht irgendwo im Nirwana steht.
                    Deshalb verweise ich auch auf die Doku, wo dieser Befehl (allerdings für 10) ebenfalls drin steht ;-)
                    Einstein war schneller, denn das befürchte ich auch und genau aus dem Grund nach Doku, weil dann die alte Node weg ist.
                    • J Jan1
                      oder mit:
                      iobroker fix
                      WalW Offline
                      WalW Offline
                      Wal
                      Da gehste mal auf die Doku von Iobroker installation linux, da steht das noch.
                      Walter
                      DoorIO-Adapter
                      • WalW Wal
                        Jan1
                        @Wal
                        Dann hast die alte Doku Du Held ;-)
                        WalW 1 Antwort Letzte Antwort
                        • J Jan1
                          @Wal
                          WalW Offline
                          WalW Offline
                          Wal
                          @Wal
                          Ich weiss, er aber nicht.😊
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            @Wal
                            Jan1
                            @Wal
                            Es geistert immer noch der Link zur alten rum, deshalb bitte immer oben den Link verwenden.
                            • J Jan1
                              @Wal
                              WalW Offline
                              WalW Offline
                              Wal
                              @Wal
                              Genau den Link, den du gepostet hast steht der Befehl drin. Ganz weit unten. ;-)
                              Walter
                              DoorIO-Adapter
                              • WalW Wal
                                @Wal
                                Jan1
                                @Wal
                                Für den Fixer ja, aber nicht für das Stoppen des IOBroker
                                Wobei das Fixer Script immer noch läuft.
                                • J Jan1
                                  @Wal
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  @Jan1
                                  mich brauchst du nicht überzeugen, ich habe diese Probleme nicht.
                                  Wir sollten zurück zum Thema und dem TE helfen.
                                  Walter
                                  DoorIO-Adapter
                                  • WalW Wal
                                    @Jan1
                                    Jan1
                                    @Wal
                                    Dann lass die Behauptungen bleiben ;-)
                                    Edit:
                                    Du hattest recht, steht da auch noch, voll überlesen😁
                                    Ich kenne aber auch die alte Doku, da steht das auch drin, allerdings etwas größer.
                                    @apollon77
                                    könnte die Doku an der Stelle bitte aktualisiert werden? Das ist sehr verwirrend wenn man sich eh nicht auskennt.
                                    @SaschaS
                                    Also hier noch mal bevor das überlesen wird:
                                    oder mit:
                                    iobroker fix
                                    • J Jan1
                                      @Wal
                                      Edit:
                                      @apollon77
                                      @SaschaS
                                      oder mit:
                                      iobroker fix
                                      @Jan1 @SaschaS
                                      Ich würde da jetzt mal ganz langsam 'von unten' herangehen.
                                      Alles als user:
                                      groups
                                      sudo whoami
                                      lsb_release -a
                                      apt policy nodejs
                                      nodejs -v && node -v && npm -v
                                      which nodejs && which node && which npm
                                        @Jan1 @SaschaS
                                        Alles als user:
                                        groups
                                        sudo whoami
                                        lsb_release -a
                                        apt policy nodejs
                                        Jan1
                                        @Thomas-Braun
                                        Ja geht natürlich auch. Wobei ich mir bei der Hälfte der Abfragen schon sicher bin was raus kommt ;-)
                                        Bei Node 8 hat er auf alle Fälle kein Buster laufen. Die Node Version hat er schon gepostet.
                                        Sein Fehler liegt an Node 8, wenn er nach dem Admin Update nicht mehr drauf kommt.
                                        • J Jan1
                                          @Thomas-Braun
                                          @Jan1 Da stimmt aber auch irgendwas nicht bei npm. Das ist eigentlich zu neu für eine reine node 8. Das dürfte von irgendwosonst herkommen.
